    4. Problem beim Update von Adaptern/Modulen/Controller
      arteck Developer Most Active @corny456 last edited by
      @corny456 was sagt den
      iob diag
      corny456 1 Reply Last reply Reply Quote 1
      • corny456
        corny456 @arteck last edited by
        @arteck said in Problem beim Update von Adaptern/Modulen/Controller:
        iob diag
        diag sagt:
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Model		: Raspberry Pi 4 Model B Rev 1.1
        Architecture: 	armv7l
        Docker: 	false
        Virtualization: none
        Distributor ID:	Raspbian
        Description:	Raspbian GNU/Linux 10 (buster)
        Release:	10
        Codename:	buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         10:56:53 up 10:51,  2 users,  load average: 1.50, 1.40, 1.45
        CPU threads: 4
        *** Time and Time Zones ***
        Wed Feb 15 09:56:53 UTC 2023
        Wed Feb 15 10:56:53 CET 2023
        CET +0100
        Europe/Berlin
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:           3.9G        1.8G        1.3G        175M        727M        1.9G
        Swap:          4.1G         67M        4.0G
        Total:         8.0G        1.9G        5.4G
                 3888 M total memory
                 1828 M used memory
                  375 M active memory
                 2032 M inactive memory
                 1333 M free memory
                   77 M buffer memory
                  649 M swap cache
                 4095 M total swap
                   67 M used swap
                 4028 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4      110G   11G   95G  11% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G  980K  1.9G   1% /dev/shm
        tmpfs          tmpfs     1.9G  179M  1.8G  10% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        tmpfs          tmpfs      10M     0   10M   0% /opt/iobroker/tmp
        /dev/sda1      vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     389M     0  389M   0% /run/user/0
        Messages in dmesg:
        Show mounted filesystems (real ones only):
        TARGET        SOURCE    FSTYPE OPTIONS
        /             /dev/sda2 ext4   rw,noatime
        |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        5.1G	/var/
        699M	/var/log
        264M	/var/cache
        259M	/var/cache/apt
        200M	/var/cache/apt/archives
        /opt/iobroker/backups:
        116M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        493M	/opt/iobroker/iobroker-data/
        179M	/opt/iobroker/iobroker-data/backup-objects
        144M	/opt/iobroker/iobroker-data/files
        48M	/opt/iobroker/iobroker-data/files/javascript.admin
        32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        79M	/opt/iobroker/iobroker-data/states.jsonl
        73M	/opt/iobroker/iobroker-data/objects.jsonl
        12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
        11M	/opt/iobroker/iobroker-data/files/s7.admin/static/js/main.235e4edd.js.map
        7.5M	/opt/iobroker/iobroker-data/objects.json.migrated
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v16.19.0
        /usr/bin/node 		v16.19.0
        /usr/local/bin/npm 		8.19.3
        /usr/local/bin/npx 		8.19.3
        nodejs:
          Installed: 16.19.0-deb-1nodesource1
          Candidate: 16.19.0-deb-1nodesource1
          Version table:
         *** 16.19.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u2 500
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	4.0.23
        admin: 		6.2.23
        javascript: 	6.0.3
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @serialport/parser-byte-length@9.0.7 /opt/iobroker/node_modules/@serialport/parser-byte-length
        npm ERR! extraneous: @serialport/parser-cctalk@9.0.7 /opt/iobroker/node_modules/@serialport/parser-cctalk
        npm ERR! extraneous: @serialport/parser-delimiter@9.0.7 /opt/iobroker/node_modules/@serialport/parser-delimiter
        npm ERR! extraneous: @serialport/parser-readline@9.0.7 /opt/iobroker/node_modules/@serialport/parser-readline
        npm ERR! extraneous: @serialport/parser-ready@9.0.7 /opt/iobroker/node_modules/@serialport/parser-ready
        npm ERR! extraneous: @serialport/parser-regex@9.0.7 /opt/iobroker/node_modules/@serialport/parser-regex
        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: ansi-bgblack@0.1.1 /opt/iobroker/node_modules/ansi-bgblack
        npm ERR! extraneous: ansi-bgblue@0.1.1 /opt/iobroker/node_modules/ansi-bgblue
        npm ERR! extraneous: ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/ansi-bgcyan
        npm ERR! extraneous: ansi-bggreen@0.1.1 /opt/iobroker/node_modules/ansi-bggreen
        npm ERR! extraneous: ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/ansi-bgmagenta
        npm ERR! extraneous: ansi-bgred@0.1.1 /opt/iobroker/node_modules/ansi-bgred
        npm ERR! extraneous: ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/ansi-bgwhite
        npm ERR! extraneous: ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/ansi-bgyellow
        npm ERR! extraneous: ansi-black@0.1.1 /opt/iobroker/node_modules/ansi-black
        npm ERR! extraneous: ansi-blue@0.1.1 /opt/iobroker/node_modules/ansi-blue
        npm ERR! extraneous: ansi-bold@0.1.1 /opt/iobroker/node_modules/ansi-bold
        npm ERR! extraneous: ansi-colors@0.2.0 /opt/iobroker/node_modules/ansi-colors
        npm ERR! extraneous: ansi-cyan@0.1.1 /opt/iobroker/node_modules/ansi-cyan
        npm ERR! extraneous: ansi-dim@0.1.1 /opt/iobroker/node_modules/ansi-dim
        npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/ansi-gray
        npm ERR! extraneous: ansi-green@0.1.1 /opt/iobroker/node_modules/ansi-green
        npm ERR! extraneous: ansi-grey@0.1.1 /opt/iobroker/node_modules/ansi-grey
        npm ERR! extraneous: ansi-hidden@0.1.1 /opt/iobroker/node_modules/ansi-hidden
        npm ERR! extraneous: ansi-inverse@0.1.1 /opt/iobroker/node_modules/ansi-inverse
        npm ERR! extraneous: ansi-italic@0.1.1 /opt/iobroker/node_modules/ansi-italic
        npm ERR! extraneous: ansi-magenta@0.1.1 /opt/iobroker/node_modules/ansi-magenta
        npm ERR! extraneous: ansi-red@0.1.1 /opt/iobroker/node_modules/ansi-red
        npm ERR! extraneous: ansi-reset@0.1.1 /opt/iobroker/node_modules/ansi-reset
        npm ERR! extraneous: ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/ansi-strikethrough
        npm ERR! extraneous: ansi-underline@0.1.1 /opt/iobroker/node_modules/ansi-underline
        npm ERR! extraneous: ansi-white@0.1.1 /opt/iobroker/node_modules/ansi-white
        npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/ansi-wrap
        npm ERR! extraneous: ansi-yellow@0.1.1 /opt/iobroker/node_modules/ansi-yellow
        npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/arr-flatten
        npm ERR! extraneous: arr-swap@1.0.1 /opt/iobroker/node_modules/arr-swap
        npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
        npm ERR! extraneous: async-retry@1.3.1 /opt/iobroker/node_modules/async-retry
        npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
        npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
        npm ERR! extraneous: buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/buffer-alloc-unsafe
        npm ERR! extraneous: buffer-alloc@1.2.0 /opt/iobroker/node_modules/buffer-alloc
        npm ERR! extraneous: buffer-fill@1.0.0 /opt/iobroker/node_modules/buffer-fill
        npm ERR! extraneous: button-events@1.0.2 /opt/iobroker/node_modules/button-events
        npm ERR! extraneous: choices-separator@2.0.0 /opt/iobroker/node_modules/choices-separator
        npm ERR! extraneous: clone-deep@1.0.0 /opt/iobroker/node_modules/clone-deep
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/collection-visit
        npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/commander
        npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
        npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/copy-descriptor
        npm ERR! extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/decompress-response
        npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/define-property
        npm ERR! extraneous: engine.io-client@3.5.2 /opt/iobroker/node_modules/engine.io-client
        npm ERR! extraneous: engine.io-parser@2.2.1 /opt/iobroker/node_modules/engine.io-parser
        npm ERR! extraneous: engine.io@3.5.0 /opt/iobroker/node_modules/engine.io
        npm ERR! extraneous: epoll@2.0.10 /opt/iobroker/node_modules/epoll
        npm ERR! extraneous: error-symbol@0.1.0 /opt/iobroker/node_modules/error-symbol
        npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
        npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
        npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/for-in
        npm ERR! extraneous: for-own@1.0.0 /opt/iobroker/node_modules/for-own
        npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
        npm ERR! extraneous: info-symbol@0.1.0 /opt/iobroker/node_modules/info-symbol
        npm ERR! missing: iobroker.adguard@0.0.8, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.alarm@3.1.1, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.device-reminder@1.2.9, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.mobile@^1.0.1, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.modbus@5.0.5, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.rpi2@1.3.2, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.signal-cmb@0.1.7, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.tankerkoenig@2.1.1, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.traccar@0.0.12, required by iobroker.inst@2.0.3
        npm ERR! missing: iobroker.vis-colorpicker@^1.2.0, required by iobroker.inst@2.0.3
        npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/is-accessor-descriptor
        npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/is-data-descriptor
        npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/is-descriptor
        npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
        npm ERR! extraneous: is-number@6.0.0 /opt/iobroker/node_modules/is-number
        npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/is-plain-object
        npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/is-windows
        npm ERR! extraneous: isarray@2.0.1 /opt/iobroker/node_modules/isarray
        npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/isobject
        npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
        npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/kind-of
        npm ERR! extraneous: koalas@1.0.2 /opt/iobroker/node_modules/koalas
        npm ERR! extraneous: lazy-cache@2.0.2 /opt/iobroker/node_modules/lazy-cache
        npm ERR! extraneous: log-ok@0.1.1 /opt/iobroker/node_modules/log-ok
        npm ERR! extraneous: log-utils@0.2.1 /opt/iobroker/node_modules/log-utils
        npm ERR! extraneous: map-visit@1.0.0 /opt/iobroker/node_modules/map-visit
        npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
        npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/mixin-object
        npm ERR! extraneous: mkdirp@0.5.1 /opt/iobroker/node_modules/mkdirp
        npm ERR! extraneous: moment-timezone@0.5.34 /opt/iobroker/node_modules/moment-timezone
        npm ERR! extraneous: node-dht-sensor@0.4.3 /opt/iobroker/node_modules/node-dht-sensor
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
        npm ERR! extraneous: object-copy@0.1.0 /opt/iobroker/node_modules/object-copy
        npm ERR! extraneous: object-visit@1.0.1 /opt/iobroker/node_modules/object-visit
        npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: pointer-symbol@1.0.0 /opt/iobroker/node_modules/pointer-symbol
        npm ERR! extraneous: prebuild-install@6.1.2 /opt/iobroker/node_modules/prebuild-install
        npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
        npm ERR! extraneous: prompt-actions@3.0.2 /opt/iobroker/node_modules/prompt-actions
        npm ERR! extraneous: prompt-base@4.1.0 /opt/iobroker/node_modules/prompt-base
        npm ERR! extraneous: prompt-checkbox@2.2.0 /opt/iobroker/node_modules/prompt-checkbox
        npm ERR! extraneous: prompt-choices@4.1.0 /opt/iobroker/node_modules/prompt-choices
        npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
        npm ERR! extraneous: prompt-question@5.0.2 /opt/iobroker/node_modules/prompt-question
        npm ERR! extraneous: prompt-radio@1.2.1 /opt/iobroker/node_modules/prompt-radio
        npm ERR! extraneous: put@0.0.6 /opt/iobroker/node_modules/put
        npm ERR! extraneous: radio-symbol@2.0.0 /opt/iobroker/node_modules/radio-symbol
        npm ERR! extraneous: readline-ui@2.2.3 /opt/iobroker/node_modules/readline-ui
        npm ERR! extraneous: readline-utils@2.2.3 /opt/iobroker/node_modules/readline-utils
        npm ERR! extraneous: rpi-gpio-buttons@2.0.1 /opt/iobroker/node_modules/rpi-gpio-buttons
        npm ERR! extraneous: rpi-gpio@2.1.7 /opt/iobroker/node_modules/rpi-gpio
        npm ERR! invalid: serialport@9.0.7 /opt/iobroker/node_modules/serialport
        npm ERR! extraneous: set-getter@0.1.0 /opt/iobroker/node_modules/set-getter
        npm ERR! extraneous: set-value@3.0.1 /opt/iobroker/node_modules/set-value
        npm ERR! extraneous: shallow-clone@1.0.0 /opt/iobroker/node_modules/shallow-clone
        npm ERR! extraneous: simple-get@3.1.0 /opt/iobroker/node_modules/simple-get
        npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
        npm ERR! extraneous: socket.io-client@2.4.0 /opt/iobroker/node_modules/socket.io-client
        npm ERR! extraneous: socket.io-parser@3.3.1 /opt/iobroker/node_modules/socket.io-parser
        npm ERR! extraneous: socket.io@2.4.1 /opt/iobroker/node_modules/socket.io
        npm ERR! extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
        npm ERR! extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
        npm ERR! extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
        npm ERR! extraneous: static-extend@0.1.2 /opt/iobroker/node_modules/static-extend
        npm ERR! extraneous: strip-color@0.1.0 /opt/iobroker/node_modules/strip-color
        npm ERR! extraneous: success-symbol@0.1.0 /opt/iobroker/node_modules/success-symbol
        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
        npm ERR! extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
        npm ERR! extraneous: sync-exec@0.6.2 /opt/iobroker/node_modules/sync-exec
        npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
        npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
        npm ERR! extraneous: terminal-paginator@2.0.2 /opt/iobroker/node_modules/terminal-paginator
        npm ERR! extraneous: time-stamp@1.1.0 /opt/iobroker/node_modules/time-stamp
        npm ERR! extraneous: to-buffer@1.1.1 /opt/iobroker/node_modules/to-buffer
        npm ERR! extraneous: to-object-path@0.3.0 /opt/iobroker/node_modules/to-object-path
        npm ERR! extraneous: toggle-array@1.0.1 /opt/iobroker/node_modules/toggle-array
        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR! extraneous: warning-symbol@0.1.0 /opt/iobroker/node_modules/warning-symbol
        npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
        npm ERR! extraneous: window-size@1.1.1 /opt/iobroker/node_modules/window-size
        npm ERR! extraneous: ws@7.4.6 /opt/iobroker/node_modules/ws
        npm ERR!     /root/.npm/_logs/2023-02-15T09_57_19_152Z-debug-0.log
        Adapters from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : automation-pi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.alexa2.0                 : alexa2                : automation-pi                            -  enabled
        + system.adapter.backitup.0               : backitup              : automation-pi                            -  enabled
        + system.adapter.cloud.0                  : cloud                 : automation-pi                            -  enabled
        + system.adapter.discovery.0              : discovery             : automation-pi                            -  enabled
          system.adapter.fullybrowser.0           : fullybrowser          : automation-pi                            - disabled
        + system.adapter.hue.0                    : hue                   : automation-pi                            -  enabled, port: 443
        + system.adapter.influxdb.0               : influxdb              : automation-pi                            -  enabled, port: 443
        + system.adapter.info.0                   : info                  : automation-pi                            -  enabled
        + system.adapter.iot.0                    : iot                   : automation-pi                            -  enabled
        + system.adapter.javascript.0             : javascript            : automation-pi                            -  enabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : automation-pi                            - disabled, port: 54321
        + system.adapter.mqtt.0                   : mqtt                  : automation-pi                            -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.mqtt.1                   : mqtt                  : automation-pi                            -  enabled, port: 8883, bind: 0.0.0.0
        + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : automation-pi                            -  enabled, port: 16021
        + system.adapter.nut.0                    : nut                   : automation-pi                            -  enabled
        + system.adapter.pushover.0               : pushover              : automation-pi                            -  enabled
        + system.adapter.s7.0                     : s7                    : automation-pi                            -  enabled
        + system.adapter.shelly.0                 : shelly                : automation-pi                            -  enabled, port: 1882, bind: 192.168.151.10
        + system.adapter.simple-api.0             : simple-api            : automation-pi                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : automation-pi                            -  enabled
        + system.adapter.sonoff.0                 : sonoff                : automation-pi                            -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.telegram.0               : telegram              : automation-pi                            -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : automation-pi                            -  enabled
        + system.adapter.unifi.0                  : unifi                 : automation-pi                            -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : automation-pi                            - disabled
          system.adapter.vis.0                    : vis                   : automation-pi                            -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : automation-pi                            -  enabled
        + system.adapter.web.0                    : web                   : automation-pi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.wled.0                   : wled                  : automation-pi                            -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.3.5    , installed 6.2.23 [Updatable]
        Adapter    "alexa2"       : 3.23.2   , installed 3.21.0 [Updatable]
        Adapter    "backitup"     : 2.5.12   , installed 2.5.4  [Updatable]
        Adapter    "cloud"        : 4.3.0    , installed 4.2.2  [Updatable]
        Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
        Adapter    "hue"          : 3.7.1    , installed 3.7.1
        Adapter    "influxdb"     : 3.2.0    , installed 3.1.8  [Updatable]
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
        Adapter    "javascript"   : 6.1.4    , installed 6.0.3  [Updatable]
        Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
        Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.6  [Updatable]
        Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
        Adapter    "nanoleaf-lightpanels": 1.3.1, installed 1.3.1
        Adapter    "nut"          : 1.5.1    , installed 1.5.1
        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
        Adapter    "s7"           : 1.3.14   , installed 1.3.13 [Updatable]
        Adapter    "shelly"       : 6.3.1    , installed 6.0.0  [Updatable]
        Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
        Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "telegram"     : 1.15.2   , installed 1.14.1 [Updatable]
        Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
        Adapter    "unifi"        : 0.5.10   , installed 0.5.10
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "wled"         : 0.6.7    , installed 0.6.7
        Objects and States
        Objects: 	135750
        States: 	129134
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
        Hit:4 https://repos.influxdata.com/debian buster InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          19804      596/codesyscontrol.
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16926      598/sshd
        tcp        0      0 192.168.151.10:1882     0.0.0.0:*               LISTEN      1001       4217754    28597/io.shelly.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          18500      567/mosquitto
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       4249042    28627/io.sonoff.0
        tcp        0      0 0.0.0.0:11740           0.0.0.0:*               LISTEN      0          14282      596/codesyscontrol.
        tcp        0      0 0.0.0.0:1217            0.0.0.0:*               LISTEN      0          14023      585/codesysedge.bin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4192764    28024/iobroker.js-c
        tcp        0      0 127.0.0.1:4840          0.0.0.0:*               LISTEN      0          19693      596/codesyscontrol.
        tcp        0      0 192.168.151.10:4840     0.0.0.0:*               LISTEN      0          19692      596/codesyscontrol.
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4182944    28024/iobroker.js-c
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4231875    28310/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4217724    28749/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          16928      598/sshd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       4217652    28766/io.simple-api
        tcp6       0      0 :::1883                 :::*                    LISTEN      0          18501      567/mosquitto
        udp        0      0 192.168.151.10:49152    0.0.0.0:*                           0          19927      596/codesyscontrol.
        udp        0      0 192.168.151.10:34964    0.0.0.0:*                           0          19926      596/codesyscontrol.
        udp        0      0 192.168.151.10:161      0.0.0.0:*                           0          19928      596/codesyscontrol.
        udp        0      0 192.168.151.255:1740    0.0.0.0:*                           0          14049      596/codesyscontrol.
        udp        0      0 192.168.151.10:1740     0.0.0.0:*                           0          14048      596/codesyscontrol.
        udp        0      0 192.168.151.255:1743    0.0.0.0:*                           0          18510      585/codesysedge.bin
        udp        0      0 192.168.151.10:1743     0.0.0.0:*                           0          18509      585/codesysedge.bin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4217487    28760/io.wled.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13794      364/avahi-daemon: r
        udp        0      0 0.0.0.0:52022           0.0.0.0:*                           108        13796      364/avahi-daemon: r
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4247847    28707/io.nanoleaf-l
        udp6       0      0 :::5353                 :::*                                108        13795      364/avahi-daemon: r
        udp6       0      0 :::38174                :::*                                108        13797      364/avahi-daemon: r
        2023-02-15 10:11:18.218  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 killing pid 28215
        2023-02-15 10:11:18.998  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-02-15 10:11:21.381  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 started with pid 29365
        2023-02-15 10:11:50.226  - info: host.automation-pi "system.adapter.mihome-vacuum.0" disabled
        2023-02-15 10:11:50.227  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
        2023-02-15 10:11:50.237  - error: mihome-vacuum.0 (29365) Socket Close
        2023-02-15 10:11:50.247  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 send kill signal
        2023-02-15 10:11:51.326  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 killing pid 29365
        2023-02-15 10:11:52.586  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2023-02-15 10:15:10.977  - info: host.automation-pi "system.adapter.telegram.0" disabled
        2023-02-15 10:15:10.978  - info: host.automation-pi stopInstance system.adapter.telegram.0 (force=false, process=true)
        2023-02-15 10:15:10.999  - info: host.automation-pi stopInstance system.adapter.telegram.0 send kill signal
        2023-02-15 10:15:12.483  - info: host.automation-pi stopInstance system.adapter.telegram.0 killing pid 28404
        2023-02-15 10:15:13.763  - info: host.automation-pi instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
        2023-02-15 10:16:02.470  - info: host.automation-pi "system.adapter.telegram.0" enabled
        2023-02-15 10:16:07.360  - info: host.automation-pi instance system.adapter.telegram.0 started with pid 29466
        2023-02-15 10:16:49.601  - info: host.automation-pi "system.adapter.telegram.0" disabled
        2023-02-15 10:16:49.604  - info: host.automation-pi stopInstance system.adapter.telegram.0 (force=false, process=true)
        2023-02-15 10:16:50.498  - info: host.automation-pi stopInstance system.adapter.telegram.0 send kill signal
        2023-02-15 10:16:51.797  - info: host.automation-pi instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
        2023-02-15 10:17:37.187  - info: host.automation-pi "system.adapter.telegram.0" enabled
        2023-02-15 10:17:38.657  - info: host.automation-pi instance system.adapter.telegram.0 started with pid 29570
        2023-02-15 10:18:27.288  - error: unifi.0 (28621) Error: Login required. Check username and password.
        2023-02-15 10:53:00.601  - info: host.automation-pi instance system.adapter.weatherunderground.0 started with pid 29730
        2023-02-15 10:53:46.395  - info: host.automation-pi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        		     v.2023-01-02
        Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
        Installation: 		Native
        Timezone: 		Europe/Berlin
        User-ID: 		0
        X-Server: 		false
        Pending OS-Updates: 	0
        Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
        ioBroker Core: 		js-controller 		4.0.23
        			admin 			6.2.23
        ioBroker Status: 	iobroker is running on this host.
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Pending iob updates: 	16
        Objects: 		135750
        States: 		129134
        Size of iob-Database:
        7.5M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
        2.3M	/opt/iobroker/iobroker-data/states.json.migrated
        2.3M	/opt/iobroker/iobroker-data/states.json.bak.migrated
        0	/opt/iobroker/iobroker-data/states.json.broken
          Thomas Braun Most Active @corny456 last edited by Thomas Braun
          @corny456
          Die alte Leier...
          NICHT als root herumkaspern, nodeJS sauber senkrecht per Paketmanager installieren, Buster beerdigen, Bullseye installieren.
          • werner2000x
            werner2000x last edited by werner2000x
            @thomas-braun Ich kann seit heute keine Adapter mehr aktualisieren.
            Bei drei Updates von Adaptern bekomme ich folgenden Fehler:
            host.raspberrypi
            2023-02-23 18:12:32.344	error	iobroker host.raspberrypi Cannot install iobroker.echarts@1.4.9: 217
            host.raspberrypi
            2023-02-23 18:11:08.729	error	iobroker host.raspberrypi Cannot install iobroker.text2command@3.0.1: 217
            host.raspberrypi
            2023-02-23 18:10:15.435	error	iobroker host.raspberrypi Cannot install iobroker.backitup@2.6.2: 217
            und mit "iob diag" folgendes
            js-controller:  4.0.24
            admin:          6.3.6
            javascript:     "javascript" not found
            npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
            npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
            npm ERR!     /home/pi/.npm/_logs/2023-02-23T17_20_26_124Z-debug-0.log
            Adapters from github:   1
            Hat jemand eine Idee?log230223.txt
              Thomas Braun Most Active @werner2000x last edited by
              @werner2000x
              Bitte jeweils vollständig posten, Eingabezeile inklusive.
              • werner2000x
                werner2000x last edited by Homoran
                Nach Befehl iob diag erhalte ich folgende Ausgabe:
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 4 Model B Rev 1.4
                Docker:         false
                Release:        10
                Codename:       buster
                VERSION_ID="10"
                ID=raspbian
                ID_LIKE=debian
                 18:20:02 up 14 min,  2 users,  load average: 0.85, 0.82, 0.81
                CPU threads: 4
                Thu Feb 23 17:20:02 UTC 2023
                Thu Feb 23 18:20:02 CET 2023
                CET +0100
                Europe/Berlin
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input netdev bluetooth lpadmin gpio i2c spi iobroker
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:           7.9G        2.0G        5.1G        9.0M        839M        6.2G
                Swap:           99M          0B         99M
                Total:         8.0G        2.0G        5.2G
                         7898 M total memory
                         1996 M used memory
                          314 M active memory
                         2398 M inactive memory
                         5062 M free memory
                          128 M buffer memory
                          710 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                /dev/root      ext4      117G   21G   92G  19% /
                devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                tmpfs          tmpfs     3.9G  9.5M  3.9G   1% /run
                tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                Messages in dmesg:
                [Thu Feb 23 18:05:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Thu Feb 23 18:05:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                [Thu Feb 23 18:05:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Thu Feb 23 18:05:15 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                /             /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                4.3G    /var/
                2.9G    /var/cache/apt
                2.9G    /var/cache
                2.8G    /var/cache/apt/archives
                719M    /var/log
                1.8G    /opt/iobroker/backups/
                296K    /opt/iobroker/backups/scripte
                268K    /opt/iobroker/backups/scripte/Meine_Geräte
                252K    /opt/iobroker/backups/Meine_Geräte
                8.0K    /opt/iobroker/backups/scripte/common
                1.6G    /opt/iobroker/iobroker-data/
                761M    /opt/iobroker/iobroker-data/node-red/node_modules
                601M    /opt/iobroker/iobroker-data/files
                531M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow
                197M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow.so.2.5.0
                41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                33M     /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow_framework.so.2.5.0
                33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                23M     /opt/iobroker/iobroker-data/objects.jsonl
                /usr/bin/nodejs         v14.21.3
                /usr/bin/node           v14.21.3
                /usr/bin/npm            9.5.0
                /usr/bin/npx            9.5.0
                nodejs:
                  Installed: 14.21.3-deb-1nodesource1
                  Candidate: 14.21.3-deb-1nodesource1
                  Version table:
                 *** 14.21.3-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                Temp directories causing npm8 problem: 1
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.6
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                  system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
                  system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
                  system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
                + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
                  system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                  system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
                + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
                + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                  system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                  system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
                + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
                + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                  system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  system.adapter.km200.0                  : km200                 : raspberrypi                              - disabled
                  system.adapter.material.0               : material              : raspberrypi                              - disabled
                + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.198.39
                + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                  system.adapter.rainbird.0               : rainbird              : raspberrypi                              - disabled
                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                  system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
                  system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              - disabled
                + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                  system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                + system.adapter.tuya.1                   : tuya                  : raspberrypi                              -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                  system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                  system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                  system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                  system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                  system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                  system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                  system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled
                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                Active repo(s): beta
                Used repository: beta
                Adapter    "admin"        : 6.3.6    , installed 6.3.6
                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                Adapter    "backitup"     : 2.6.2    , installed 2.6.1  [Updatable]
                Adapter    "ble"          : 0.13.3   , installed 0.13.3
                Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                Adapter    "cloud"        : 4.3.1    , installed 4.3.1
                Adapter    "daikin"       : 1.4.2    , installed 1.4.2
                Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
                Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                Adapter    "devices"      : 1.1.2    , installed 1.1.2
                Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                Adapter    "echarts"      : 1.4.9    , installed 1.4.7  [Updatable]
                Adapter    "ems-esp"      : 1.22.0   , installed 1.22.0
                Adapter    "energymanager": 1.4.1    , installed 1.4.1
                Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
                Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                Adapter    "history"      : 2.2.4    , installed 2.2.4
                Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
                Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                Adapter    "ical"         : 1.13.2   , installed 1.13.2
                Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                Adapter    "info"         : 1.9.26   , installed 1.9.26
                Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
                Adapter    "iot"          : 1.14.3   , installed 1.14.3
                Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
                Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                Controller "js-controller": 4.0.24   , installed 4.0.24
                Adapter    "km200"        : 2.0.3    , installed 2.0.3
                Adapter    "material"     : 1.3.1    , installed 1.3.1
                Adapter    "meross"       : 1.15.0   , installed 1.15.0
                Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                Adapter    "parser"       : 1.3.2    , installed 1.3.2
                Adapter    "ping"         : 1.5.3    , installed 1.5.3
                Adapter    "rainbird"     : 0.2.2    , installed 0.2.2
                Adapter    "socketio"     : 6.3.3    , installed 6.3.3
                Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
                Adapter    "text2command" : 3.0.1    , installed 3.0.0  [Updatable]
                Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                Adapter    "tuya"         : 3.14.1   , installed 3.14.1
                Adapter    "vis"          : 1.4.16   , installed 1.4.16
                Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
                Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                Adapter    "vw-connect"   : 0.0.60   , installed 0.0.60
                Adapter    "web"          : 5.5.0    , installed 5.5.0
                Adapter    "ws"           : 2.3.5    , installed 2.3.5
                Objects and States
                Objects:        21475
                States:         18373
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:3 https://apt.grafana.com stable InRelease
                Hit:4 https://repos.influxdata.com/debian stable InRelease
                Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
                Pending Updates: 0
                Proto Recv-Q Send-Q Local Address           Foreign Address         State
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN
                tcp        0      0 192.168.198.39:8081     0.0.0.0:*               LISTEN
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
                tcp        0      0 192.168.198.39:1880     0.0.0.0:*               LISTEN
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
                tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN
                tcp6       0      0 :::8086                 :::*                    LISTEN
                tcp6       0      0 ::1:3350                :::*                    LISTEN
                tcp6       0      0 ::1:631                 :::*                    LISTEN
                tcp6       0      0 :::3000                 :::*                    LISTEN
                tcp6       0      0 :::3389                 :::*                    LISTEN
                tcp6       0      0 :::445                  :::*                    LISTEN
                tcp6       0      0 :::139                  :::*                    LISTEN
                tcp6       0      0 :::5900                 :::*                    LISTEN
                udp        0      0 0.0.0.0:6666            0.0.0.0:*
                udp        0      0 0.0.0.0:6667            0.0.0.0:*
                udp        0      0 0.0.0.0:68              0.0.0.0:*
                udp        0      0 0.0.0.0:631             0.0.0.0:*
                udp        0      0 192.168.198.255:137     0.0.0.0:*
                udp        0      0 192.168.198.39:137      0.0.0.0:*
                udp        0      0 192.168.198.42:137      0.0.0.0:*
                udp        0      0 0.0.0.0:137             0.0.0.0:*
                udp        0      0 192.168.198.255:138     0.0.0.0:*
                udp        0      0 192.168.198.39:138      0.0.0.0:*
                udp        0      0 192.168.198.42:138      0.0.0.0:*
                udp        0      0 0.0.0.0:138             0.0.0.0:*
                udp        0      0 0.0.0.0:58511           0.0.0.0:*
                udp        0      0 0.0.0.0:38566           0.0.0.0:*
                udp        0      0 192.168.198.39:1194     0.0.0.0:*
                udp6       0      0 :::41388                :::*
                udp6       0      0 :::546                  :::*
                2023-02-23 18:19:09.154  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                2023-02-23 18:19:59.080  - info: influxdb.0 (1263) No Data
                2023-02-23 18:19:59.173  - info: influxdb.0 (1263) No Data
                2023-02-23 18:19:59.478  - info: influxdb.0 (1263) No Data
                2023-02-23 18:20:00.146  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                2023-02-23 18:20:00.610  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                2023-02-23 18:20:08.693  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                2023-02-23 18:20:09.351  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                2023-02-23 18:20:24.470  - info: meross.0 (1531) Can not get Data for Device 211
                2023-02-23 18:20:24.471  - warn: meross.0 (1531) Can not get Data for Device 211
                2023-02-23 18:20:59.142  - info: influxdb.0 (1263) No Data
                2023-02-23 18:20:59.565  - info: influxdb.0 (1263) No Data
                2023-02-23 18:21:08.868  - debug: daikin-cloud.0 (1579) update state: 09d81369-d
                2023-02-23 18:21:08.881  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                2023-02-23 18:21:08.889  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                2023-02-23 18:21:08.895  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
                2023-02-23 18:21:09.659  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
                2023-02-23 18:21:09.660  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
                2023-02-23 18:21:09.667  - warn: daikin-cloud.0 (1579) State "daikin-cloud.0.f7b
                2023-02-23 18:21:09.675  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                2023-02-23 18:21:09.679  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                2023-02-23 18:21:09.688  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
                2023-02-23 18:21:11.789  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                2023-02-23 18:21:12.173  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
                iob diag has finished.
                  Thomas Braun Most Active @werner2000x last edited by Thomas Braun
                  @werner2000x
                  Die Lösung dazu findet sich in den oben festgepinnten Threads.
                  https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                  Und npm wird nicht von Hand aktualisiert!
                  Dein Betriebssystem ist abgekündigt, installiert da das aktuelle stabile Release 'Bullseye'.
                  • ostseereiter
                    ostseereiter last edited by
                    Ich habe das schon seit ein viertel Jahr das sich kein Adapter mehr aktualisieren kann. Es ist aber erst seid Node JS 16 wenn man auf die 14 zurückgehrt dann klappt das wieder habe ich gelesen. Nu sind es bei mir schon fast 40 Adapter die aktualiersiert werden möchten. Ich lass es jetzt einfach so System läuft trotzdem super.Wenn es meine Zeit zuläßt werde ich dann Iobroker neu installieren. Solange es läuft ist es gut und das andere ist alles flickschusterei denke ich, denn der festgepinnte Thred haut auch nicht hin weil bei mir nur der Fehler 0 kommt.
                      Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                      @ostseereiter sagte in Problem beim Update von Adaptern/Modulen/Controller:
                      Das nur die Meldung 0 kommt glaube ich nicht.
                      Aber deine Beschreibung ist auch etwas dünn.
                      Wenigstens mal ein
                      iob diag
                      oder wenigstens
                      iob update
                      iob upgrade ADAPTER --debug
                      wäre fein. So kann man nichts weiter dazu sagen.
                      • werner2000x
                        Ich habe jetzt das Problem, dass der Javascript adapter nicht mehr startet (rot).
                        Wenn ich den Befehl "iob upgrade ADAPTER --debug" aufrufen, dann kommt: Adapter "ADAPTER" is not installed.
                        Ich habe auch schon javascript neu installiert und gebootet - leider keine Abhilfe.
                        Gibt es eine Lösung oder nur mit "Bullseye"?
                          @werner2000x
                          Du hast aber schon gesehen, dass 'ADAPTER' nur ein Platzhalter ist und durch den Adapternamen ersetzt werden muss?
                          iobroker upgrade javascript --debug
                          werner2000x 1 Reply Last reply Reply Quote 0
                          • werner2000x
                            werner2000x @Thomas Braun last edited by
                            @thomas-braun Ja, Danke das katte ich übersehen.
                            Nun habe ich den Adapter javascript deinstalliert und er erscheint auch nicht mehr in der Instance Liste.
                            Wenn ich nun den folgenden Befehl aurufe:
                            iob upgrade javascript --debug
                            Adapter "javascript"     is not installed.
                            erhalt ich die Meldung wie vorstehend. Wie kann ich denn den Adapter neu installieren?
                              @werner2000x
                              iobroker add javascript --debug
                              • werner2000x
                                Dann kommt folgendes:
                                NPM version: 9.5.0
                                Installing iobroker.javascript@7.0.1... (System call)
                                npm ERR! code ENOTEMPTY
                                npm ERR! syscall rename
                                npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                                npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                                npm ERR! errno -39
                                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                                npm ERR!     /home/iobroker/.npm/_logs/2023-02-24T14_10_51_991Z-debug-0.log
                                host.raspberrypi Cannot install iobroker.javascript@7.0.1: 217
                                  Homoran Global Moderator Administrators @werner2000x last edited by
                                  @werner2000x sagte in Problem beim Update von Adaptern/Modulen/Controller:
                                  warum?
                                  dann geht natürlich kein upgrade mehr
                                    217
                                    • werner2000x
                                      werner2000x @Homoran last edited by werner2000x
                                      @homoran Ich habe ihn deinstalliert weil er immer Rot in den instancen war.
                                        NPM version: 9.5.0
                                        Von Hand dran herumgefummelt.
                                        NICHT machen.
                                        nodejs (inkl. npm) neuinstallieren.
                                        Beta-Software:
                                        javascript@7.0.1
                                        Ich denke im Beta-Repository bist du vollkommen falsch aufgehoben.
                                          warum fummelt man an der Installation rum während andere versuchen zu helfen?
                                          Der Wissensstand der helfenden ist damit ständig veraltet.
                                          https://forum.iobroker.net/post/884324
                                          • werner2000x
                                            @homoran Ja, ich war etwas voreilig. Kann man denn trotzdem noch was retten obwohl kein javascript adapter mehr da ist?
                                            1970
