    4. Problem beim Update von Adaptern/Modulen/Controller
    • corny456
      corny456 @arteck last edited by
      @arteck said in Problem beim Update von Adaptern/Modulen/Controller:
      iob diag
      diag sagt:
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Architecture: 	armv7l
      Docker: 	false
      Virtualization: none
      Distributor ID:	Raspbian
      Description:	Raspbian GNU/Linux 10 (buster)
      Release:	10
      Codename:	buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       10:56:53 up 10:51,  2 users,  load average: 1.50, 1.40, 1.45
      CPU threads: 4
      *** Time and Time Zones ***
      Wed Feb 15 09:56:53 UTC 2023
      Wed Feb 15 10:56:53 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	graphical.target
      *** MEMORY ***
      Mem:           3.9G        1.8G        1.3G        175M        727M        1.9G
      Swap:          4.1G         67M        4.0G
      Total:         8.0G        1.9G        5.4G
               3888 M total memory
               1828 M used memory
                375 M active memory
               2032 M inactive memory
               1333 M free memory
                 77 M buffer memory
                649 M swap cache
               4095 M total swap
                 67 M used swap
               4028 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4      110G   11G   95G  11% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     1.9G  980K  1.9G   1% /dev/shm
      tmpfs          tmpfs     1.9G  179M  1.8G  10% /run
      tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
      tmpfs          tmpfs      10M     0   10M   0% /opt/iobroker/tmp
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     389M     0  389M   0% /run/user/0
      Messages in dmesg:
      Show mounted filesystems (real ones only):
      TARGET        SOURCE    FSTYPE OPTIONS
      /             /dev/sda2 ext4   rw,noatime
      |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      5.1G	/var/
      699M	/var/log
      264M	/var/cache
      259M	/var/cache/apt
      200M	/var/cache/apt/archives
      /opt/iobroker/backups:
      116M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      493M	/opt/iobroker/iobroker-data/
      179M	/opt/iobroker/iobroker-data/backup-objects
      144M	/opt/iobroker/iobroker-data/files
      48M	/opt/iobroker/iobroker-data/files/javascript.admin
      32M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      79M	/opt/iobroker/iobroker-data/states.jsonl
      73M	/opt/iobroker/iobroker-data/objects.jsonl
      12M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
      11M	/opt/iobroker/iobroker-data/files/s7.admin/static/js/main.235e4edd.js.map
      7.5M	/opt/iobroker/iobroker-data/objects.json.migrated
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v16.19.0
      /usr/bin/node 		v16.19.0
      /usr/local/bin/npm 		8.19.3
      /usr/local/bin/npx 		8.19.3
      nodejs:
        Installed: 16.19.0-deb-1nodesource1
        Candidate: 16.19.0-deb-1nodesource1
        Version table:
       *** 16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u2 500
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.23
      admin: 		6.2.23
      javascript: 	6.0.3
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @serialport/parser-byte-length@9.0.7 /opt/iobroker/node_modules/@serialport/parser-byte-length
      npm ERR! extraneous: @serialport/parser-cctalk@9.0.7 /opt/iobroker/node_modules/@serialport/parser-cctalk
      npm ERR! extraneous: @serialport/parser-delimiter@9.0.7 /opt/iobroker/node_modules/@serialport/parser-delimiter
      npm ERR! extraneous: @serialport/parser-readline@9.0.7 /opt/iobroker/node_modules/@serialport/parser-readline
      npm ERR! extraneous: @serialport/parser-ready@9.0.7 /opt/iobroker/node_modules/@serialport/parser-ready
      npm ERR! extraneous: @serialport/parser-regex@9.0.7 /opt/iobroker/node_modules/@serialport/parser-regex
      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: ansi-bgblack@0.1.1 /opt/iobroker/node_modules/ansi-bgblack
      npm ERR! extraneous: ansi-bgblue@0.1.1 /opt/iobroker/node_modules/ansi-bgblue
      npm ERR! extraneous: ansi-bgcyan@0.1.1 /opt/iobroker/node_modules/ansi-bgcyan
      npm ERR! extraneous: ansi-bggreen@0.1.1 /opt/iobroker/node_modules/ansi-bggreen
      npm ERR! extraneous: ansi-bgmagenta@0.1.1 /opt/iobroker/node_modules/ansi-bgmagenta
      npm ERR! extraneous: ansi-bgred@0.1.1 /opt/iobroker/node_modules/ansi-bgred
      npm ERR! extraneous: ansi-bgwhite@0.1.1 /opt/iobroker/node_modules/ansi-bgwhite
      npm ERR! extraneous: ansi-bgyellow@0.1.1 /opt/iobroker/node_modules/ansi-bgyellow
      npm ERR! extraneous: ansi-black@0.1.1 /opt/iobroker/node_modules/ansi-black
      npm ERR! extraneous: ansi-blue@0.1.1 /opt/iobroker/node_modules/ansi-blue
      npm ERR! extraneous: ansi-bold@0.1.1 /opt/iobroker/node_modules/ansi-bold
      npm ERR! extraneous: ansi-colors@0.2.0 /opt/iobroker/node_modules/ansi-colors
      npm ERR! extraneous: ansi-cyan@0.1.1 /opt/iobroker/node_modules/ansi-cyan
      npm ERR! extraneous: ansi-dim@0.1.1 /opt/iobroker/node_modules/ansi-dim
      npm ERR! extraneous: ansi-gray@0.1.1 /opt/iobroker/node_modules/ansi-gray
      npm ERR! extraneous: ansi-green@0.1.1 /opt/iobroker/node_modules/ansi-green
      npm ERR! extraneous: ansi-grey@0.1.1 /opt/iobroker/node_modules/ansi-grey
      npm ERR! extraneous: ansi-hidden@0.1.1 /opt/iobroker/node_modules/ansi-hidden
      npm ERR! extraneous: ansi-inverse@0.1.1 /opt/iobroker/node_modules/ansi-inverse
      npm ERR! extraneous: ansi-italic@0.1.1 /opt/iobroker/node_modules/ansi-italic
      npm ERR! extraneous: ansi-magenta@0.1.1 /opt/iobroker/node_modules/ansi-magenta
      npm ERR! extraneous: ansi-red@0.1.1 /opt/iobroker/node_modules/ansi-red
      npm ERR! extraneous: ansi-reset@0.1.1 /opt/iobroker/node_modules/ansi-reset
      npm ERR! extraneous: ansi-strikethrough@0.1.1 /opt/iobroker/node_modules/ansi-strikethrough
      npm ERR! extraneous: ansi-underline@0.1.1 /opt/iobroker/node_modules/ansi-underline
      npm ERR! extraneous: ansi-white@0.1.1 /opt/iobroker/node_modules/ansi-white
      npm ERR! extraneous: ansi-wrap@0.1.0 /opt/iobroker/node_modules/ansi-wrap
      npm ERR! extraneous: ansi-yellow@0.1.1 /opt/iobroker/node_modules/ansi-yellow
      npm ERR! extraneous: arr-flatten@1.1.0 /opt/iobroker/node_modules/arr-flatten
      npm ERR! extraneous: arr-swap@1.0.1 /opt/iobroker/node_modules/arr-swap
      npm ERR! extraneous: arraybuffer.slice@0.0.7 /opt/iobroker/node_modules/arraybuffer.slice
      npm ERR! extraneous: async-retry@1.3.1 /opt/iobroker/node_modules/async-retry
      npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
      npm ERR! extraneous: blob@0.0.5 /opt/iobroker/node_modules/blob
      npm ERR! extraneous: buffer-alloc-unsafe@1.1.0 /opt/iobroker/node_modules/buffer-alloc-unsafe
      npm ERR! extraneous: buffer-alloc@1.2.0 /opt/iobroker/node_modules/buffer-alloc
      npm ERR! extraneous: buffer-fill@1.0.0 /opt/iobroker/node_modules/buffer-fill
      npm ERR! extraneous: button-events@1.0.2 /opt/iobroker/node_modules/button-events
      npm ERR! extraneous: choices-separator@2.0.0 /opt/iobroker/node_modules/choices-separator
      npm ERR! extraneous: clone-deep@1.0.0 /opt/iobroker/node_modules/clone-deep
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! extraneous: collection-visit@1.0.0 /opt/iobroker/node_modules/collection-visit
      npm ERR! extraneous: commander@2.20.3 /opt/iobroker/node_modules/commander
      npm ERR! extraneous: component-emitter@1.3.0 /opt/iobroker/node_modules/component-emitter
      npm ERR! extraneous: copy-descriptor@0.1.1 /opt/iobroker/node_modules/copy-descriptor
      npm ERR! extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/decompress-response
      npm ERR! extraneous: define-property@1.0.0 /opt/iobroker/node_modules/define-property
      npm ERR! extraneous: engine.io-client@3.5.2 /opt/iobroker/node_modules/engine.io-client
      npm ERR! extraneous: engine.io-parser@2.2.1 /opt/iobroker/node_modules/engine.io-parser
      npm ERR! extraneous: engine.io@3.5.0 /opt/iobroker/node_modules/engine.io
      npm ERR! extraneous: epoll@2.0.10 /opt/iobroker/node_modules/epoll
      npm ERR! extraneous: error-symbol@0.1.0 /opt/iobroker/node_modules/error-symbol
      npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
      npm ERR! extraneous: extend-shallow@2.0.1 /opt/iobroker/node_modules/extend-shallow
      npm ERR! extraneous: for-in@1.0.2 /opt/iobroker/node_modules/for-in
      npm ERR! extraneous: for-own@1.0.0 /opt/iobroker/node_modules/for-own
      npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
      npm ERR! extraneous: info-symbol@0.1.0 /opt/iobroker/node_modules/info-symbol
      npm ERR! missing: iobroker.adguard@0.0.8, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.alarm@3.1.1, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.device-reminder@1.2.9, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.mobile@^1.0.1, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.modbus@5.0.5, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.rpi2@1.3.2, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.signal-cmb@0.1.7, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.socketio@4.2.0, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.tankerkoenig@2.1.1, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.traccar@0.0.12, required by iobroker.inst@2.0.3
      npm ERR! missing: iobroker.vis-colorpicker@^1.2.0, required by iobroker.inst@2.0.3
      npm ERR! extraneous: is-accessor-descriptor@1.0.0 /opt/iobroker/node_modules/is-accessor-descriptor
      npm ERR! extraneous: is-data-descriptor@1.0.0 /opt/iobroker/node_modules/is-data-descriptor
      npm ERR! extraneous: is-descriptor@1.0.2 /opt/iobroker/node_modules/is-descriptor
      npm ERR! extraneous: is-extendable@0.1.1 /opt/iobroker/node_modules/is-extendable
      npm ERR! extraneous: is-number@6.0.0 /opt/iobroker/node_modules/is-number
      npm ERR! extraneous: is-plain-object@2.0.4 /opt/iobroker/node_modules/is-plain-object
      npm ERR! extraneous: is-windows@1.0.2 /opt/iobroker/node_modules/is-windows
      npm ERR! extraneous: isarray@2.0.1 /opt/iobroker/node_modules/isarray
      npm ERR! extraneous: isobject@3.0.1 /opt/iobroker/node_modules/isobject
      npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
      npm ERR! extraneous: kind-of@3.2.2 /opt/iobroker/node_modules/kind-of
      npm ERR! extraneous: koalas@1.0.2 /opt/iobroker/node_modules/koalas
      npm ERR! extraneous: lazy-cache@2.0.2 /opt/iobroker/node_modules/lazy-cache
      npm ERR! extraneous: log-ok@0.1.1 /opt/iobroker/node_modules/log-ok
      npm ERR! extraneous: log-utils@0.2.1 /opt/iobroker/node_modules/log-utils
      npm ERR! extraneous: map-visit@1.0.0 /opt/iobroker/node_modules/map-visit
      npm ERR! extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
      npm ERR! extraneous: mixin-object@2.0.1 /opt/iobroker/node_modules/mixin-object
      npm ERR! extraneous: mkdirp@0.5.1 /opt/iobroker/node_modules/mkdirp
      npm ERR! extraneous: moment-timezone@0.5.34 /opt/iobroker/node_modules/moment-timezone
      npm ERR! extraneous: node-dht-sensor@0.4.3 /opt/iobroker/node_modules/node-dht-sensor
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: noop-logger@0.1.1 /opt/iobroker/node_modules/noop-logger
      npm ERR! extraneous: object-copy@0.1.0 /opt/iobroker/node_modules/object-copy
      npm ERR! extraneous: object-visit@1.0.1 /opt/iobroker/node_modules/object-visit
      npm ERR! extraneous: os-homedir@1.0.2 /opt/iobroker/node_modules/os-homedir
      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: pointer-symbol@1.0.0 /opt/iobroker/node_modules/pointer-symbol
      npm ERR! extraneous: prebuild-install@6.1.2 /opt/iobroker/node_modules/prebuild-install
      npm ERR! extraneous: promirepl@1.0.1 /opt/iobroker/node_modules/promirepl
      npm ERR! extraneous: prompt-actions@3.0.2 /opt/iobroker/node_modules/prompt-actions
      npm ERR! extraneous: prompt-base@4.1.0 /opt/iobroker/node_modules/prompt-base
      npm ERR! extraneous: prompt-checkbox@2.2.0 /opt/iobroker/node_modules/prompt-checkbox
      npm ERR! extraneous: prompt-choices@4.1.0 /opt/iobroker/node_modules/prompt-choices
      npm ERR! extraneous: prompt-list@3.2.0 /opt/iobroker/node_modules/prompt-list
      npm ERR! extraneous: prompt-question@5.0.2 /opt/iobroker/node_modules/prompt-question
      npm ERR! extraneous: prompt-radio@1.2.1 /opt/iobroker/node_modules/prompt-radio
      npm ERR! extraneous: put@0.0.6 /opt/iobroker/node_modules/put
      npm ERR! extraneous: radio-symbol@2.0.0 /opt/iobroker/node_modules/radio-symbol
      npm ERR! extraneous: readline-ui@2.2.3 /opt/iobroker/node_modules/readline-ui
      npm ERR! extraneous: readline-utils@2.2.3 /opt/iobroker/node_modules/readline-utils
      npm ERR! extraneous: rpi-gpio-buttons@2.0.1 /opt/iobroker/node_modules/rpi-gpio-buttons
      npm ERR! extraneous: rpi-gpio@2.1.7 /opt/iobroker/node_modules/rpi-gpio
      npm ERR! invalid: serialport@9.0.7 /opt/iobroker/node_modules/serialport
      npm ERR! extraneous: set-getter@0.1.0 /opt/iobroker/node_modules/set-getter
      npm ERR! extraneous: set-value@3.0.1 /opt/iobroker/node_modules/set-value
      npm ERR! extraneous: shallow-clone@1.0.0 /opt/iobroker/node_modules/shallow-clone
      npm ERR! extraneous: simple-get@3.1.0 /opt/iobroker/node_modules/simple-get
      npm ERR! extraneous: socket.io-adapter@1.1.2 /opt/iobroker/node_modules/socket.io-adapter
      npm ERR! extraneous: socket.io-client@2.4.0 /opt/iobroker/node_modules/socket.io-client
      npm ERR! extraneous: socket.io-parser@3.3.1 /opt/iobroker/node_modules/socket.io-parser
      npm ERR! extraneous: socket.io@2.4.1 /opt/iobroker/node_modules/socket.io
      npm ERR! extraneous: stampit-event-bus@0.1.1 /opt/iobroker/node_modules/stampit-event-bus
      npm ERR! extraneous: stampit-state-machine@0.2.1 /opt/iobroker/node_modules/stampit-state-machine
      npm ERR! extraneous: stampit@2.1.2 /opt/iobroker/node_modules/stampit
      npm ERR! extraneous: static-extend@0.1.2 /opt/iobroker/node_modules/static-extend
      npm ERR! extraneous: strip-color@0.1.0 /opt/iobroker/node_modules/strip-color
      npm ERR! extraneous: success-symbol@0.1.0 /opt/iobroker/node_modules/success-symbol
      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
      npm ERR! extraneous: supermixer@1.0.5 /opt/iobroker/node_modules/supermixer
      npm ERR! extraneous: sync-exec@0.6.2 /opt/iobroker/node_modules/sync-exec
      npm ERR! extraneous: tar-fs@2.1.1 /opt/iobroker/node_modules/tar-fs
      npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
      npm ERR! extraneous: terminal-paginator@2.0.2 /opt/iobroker/node_modules/terminal-paginator
      npm ERR! extraneous: time-stamp@1.1.0 /opt/iobroker/node_modules/time-stamp
      npm ERR! extraneous: to-buffer@1.1.1 /opt/iobroker/node_modules/to-buffer
      npm ERR! extraneous: to-object-path@0.3.0 /opt/iobroker/node_modules/to-object-path
      npm ERR! extraneous: toggle-array@1.0.1 /opt/iobroker/node_modules/toggle-array
      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: warning-symbol@0.1.0 /opt/iobroker/node_modules/warning-symbol
      npm ERR! extraneous: which-pm-runs@1.0.0 /opt/iobroker/node_modules/which-pm-runs
      npm ERR! extraneous: window-size@1.1.1 /opt/iobroker/node_modules/window-size
      npm ERR! extraneous: ws@7.4.6 /opt/iobroker/node_modules/ws
      npm ERR!     /root/.npm/_logs/2023-02-15T09_57_19_152Z-debug-0.log
      Adapters from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : automation-pi                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : automation-pi                            -  enabled
      + system.adapter.backitup.0               : backitup              : automation-pi                            -  enabled
      + system.adapter.cloud.0                  : cloud                 : automation-pi                            -  enabled
      + system.adapter.discovery.0              : discovery             : automation-pi                            -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : automation-pi                            - disabled
      + system.adapter.hue.0                    : hue                   : automation-pi                            -  enabled, port: 443
      + system.adapter.influxdb.0               : influxdb              : automation-pi                            -  enabled, port: 443
      + system.adapter.info.0                   : info                  : automation-pi                            -  enabled
      + system.adapter.iot.0                    : iot                   : automation-pi                            -  enabled
      + system.adapter.javascript.0             : javascript            : automation-pi                            -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : automation-pi                            - disabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : automation-pi                            -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : automation-pi                            -  enabled, port: 8883, bind: 0.0.0.0
      + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : automation-pi                            -  enabled, port: 16021
      + system.adapter.nut.0                    : nut                   : automation-pi                            -  enabled
      + system.adapter.pushover.0               : pushover              : automation-pi                            -  enabled
      + system.adapter.s7.0                     : s7                    : automation-pi                            -  enabled
      + system.adapter.shelly.0                 : shelly                : automation-pi                            -  enabled, port: 1882, bind: 192.168.151.10
      + system.adapter.simple-api.0             : simple-api            : automation-pi                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : automation-pi                            -  enabled
      + system.adapter.sonoff.0                 : sonoff                : automation-pi                            -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : automation-pi                            -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : automation-pi                            -  enabled
      + system.adapter.unifi.0                  : unifi                 : automation-pi                            -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : automation-pi                            - disabled
        system.adapter.vis.0                    : vis                   : automation-pi                            -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : automation-pi                            -  enabled
      + system.adapter.web.0                    : web                   : automation-pi                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : automation-pi                            -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.3.5    , installed 6.2.23 [Updatable]
      Adapter    "alexa2"       : 3.23.2   , installed 3.21.0 [Updatable]
      Adapter    "backitup"     : 2.5.12   , installed 2.5.4  [Updatable]
      Adapter    "cloud"        : 4.3.0    , installed 4.2.2  [Updatable]
      Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
      Adapter    "hue"          : 3.7.1    , installed 3.7.1
      Adapter    "influxdb"     : 3.2.0    , installed 3.1.8  [Updatable]
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
      Adapter    "javascript"   : 6.1.4    , installed 6.0.3  [Updatable]
      Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
      Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.6  [Updatable]
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "nanoleaf-lightpanels": 1.3.1, installed 1.3.1
      Adapter    "nut"          : 1.5.1    , installed 1.5.1
      Adapter    "pushover"     : 3.0.3    , installed 3.0.3
      Adapter    "s7"           : 1.3.14   , installed 1.3.13 [Updatable]
      Adapter    "shelly"       : 6.3.1    , installed 6.0.0  [Updatable]
      Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
      Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "telegram"     : 1.15.2   , installed 1.14.1 [Updatable]
      Adapter    "text2command" : 2.3.0    , installed 2.2.2  [Updatable]
      Adapter    "unifi"        : 0.5.10   , installed 0.5.10
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Objects and States
      Objects: 	135750
      States: 	129134
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
      Hit:4 https://repos.influxdata.com/debian buster InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      0          19804      596/codesyscontrol.
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16926      598/sshd
      tcp        0      0 192.168.151.10:1882     0.0.0.0:*               LISTEN      1001       4217754    28597/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          18500      567/mosquitto
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       4249042    28627/io.sonoff.0
      tcp        0      0 0.0.0.0:11740           0.0.0.0:*               LISTEN      0          14282      596/codesyscontrol.
      tcp        0      0 0.0.0.0:1217            0.0.0.0:*               LISTEN      0          14023      585/codesysedge.bin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4192764    28024/iobroker.js-c
      tcp        0      0 127.0.0.1:4840          0.0.0.0:*               LISTEN      0          19693      596/codesyscontrol.
      tcp        0      0 192.168.151.10:4840     0.0.0.0:*               LISTEN      0          19692      596/codesyscontrol.
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4182944    28024/iobroker.js-c
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4231875    28310/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       4217724    28749/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16928      598/sshd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       4217652    28766/io.simple-api
      tcp6       0      0 :::1883                 :::*                    LISTEN      0          18501      567/mosquitto
      udp        0      0 192.168.151.10:49152    0.0.0.0:*                           0          19927      596/codesyscontrol.
      udp        0      0 192.168.151.10:34964    0.0.0.0:*                           0          19926      596/codesyscontrol.
      udp        0      0 192.168.151.10:161      0.0.0.0:*                           0          19928      596/codesyscontrol.
      udp        0      0 192.168.151.255:1740    0.0.0.0:*                           0          14049      596/codesyscontrol.
      udp        0      0 192.168.151.10:1740     0.0.0.0:*                           0          14048      596/codesyscontrol.
      udp        0      0 192.168.151.255:1743    0.0.0.0:*                           0          18510      585/codesysedge.bin
      udp        0      0 192.168.151.10:1743     0.0.0.0:*                           0          18509      585/codesysedge.bin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       4217487    28760/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13794      364/avahi-daemon: r
      udp        0      0 0.0.0.0:52022           0.0.0.0:*                           108        13796      364/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4247847    28707/io.nanoleaf-l
      udp6       0      0 :::5353                 :::*                                108        13795      364/avahi-daemon: r
      udp6       0      0 :::38174                :::*                                108        13797      364/avahi-daemon: r
      2023-02-15 10:11:18.218  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 killing pid 28215
      2023-02-15 10:11:18.998  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-02-15 10:11:21.381  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 started with pid 29365
      2023-02-15 10:11:50.226  - info: host.automation-pi "system.adapter.mihome-vacuum.0" disabled
      2023-02-15 10:11:50.227  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
      2023-02-15 10:11:50.237  - error: mihome-vacuum.0 (29365) Socket Close
      2023-02-15 10:11:50.247  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 send kill signal
      2023-02-15 10:11:51.326  - info: host.automation-pi stopInstance system.adapter.mihome-vacuum.0 killing pid 29365
      2023-02-15 10:11:52.586  - info: host.automation-pi instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-02-15 10:15:10.977  - info: host.automation-pi "system.adapter.telegram.0" disabled
      2023-02-15 10:15:10.978  - info: host.automation-pi stopInstance system.adapter.telegram.0 (force=false, process=true)
      2023-02-15 10:15:10.999  - info: host.automation-pi stopInstance system.adapter.telegram.0 send kill signal
      2023-02-15 10:15:12.483  - info: host.automation-pi stopInstance system.adapter.telegram.0 killing pid 28404
      2023-02-15 10:15:13.763  - info: host.automation-pi instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
      2023-02-15 10:16:02.470  - info: host.automation-pi "system.adapter.telegram.0" enabled
      2023-02-15 10:16:07.360  - info: host.automation-pi instance system.adapter.telegram.0 started with pid 29466
      2023-02-15 10:16:49.601  - info: host.automation-pi "system.adapter.telegram.0" disabled
      2023-02-15 10:16:49.604  - info: host.automation-pi stopInstance system.adapter.telegram.0 (force=false, process=true)
      2023-02-15 10:16:50.498  - info: host.automation-pi stopInstance system.adapter.telegram.0 send kill signal
      2023-02-15 10:16:51.797  - info: host.automation-pi instance system.adapter.telegram.0 terminated with code 0 (NO_ERROR)
      2023-02-15 10:17:37.187  - info: host.automation-pi "system.adapter.telegram.0" enabled
      2023-02-15 10:17:38.657  - info: host.automation-pi instance system.adapter.telegram.0 started with pid 29570
      2023-02-15 10:18:27.288  - error: unifi.0 (28621) Error: Login required. Check username and password.
      2023-02-15 10:53:00.601  - info: host.automation-pi instance system.adapter.weatherunderground.0 started with pid 29730
      2023-02-15 10:53:46.395  - info: host.automation-pi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      		     v.2023-01-02
      Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
      Installation: 		Native
      Timezone: 		Europe/Berlin
      User-ID: 		0
      X-Server: 		false
      Pending OS-Updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
      ioBroker Core: 		js-controller 		4.0.23
      			admin 			6.2.23
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Pending iob updates: 	16
      Objects: 		135750
      States: 		129134
      Size of iob-Database:
      7.5M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      2.3M	/opt/iobroker/iobroker-data/states.json.migrated
      2.3M	/opt/iobroker/iobroker-data/states.json.bak.migrated
      0	/opt/iobroker/iobroker-data/states.json.broken
        Thomas Braun Most Active @corny456 last edited by Thomas Braun
        @corny456
        Die alte Leier...
        NICHT als root herumkaspern, nodeJS sauber senkrecht per Paketmanager installieren, Buster beerdigen, Bullseye installieren.
        • werner2000x
          werner2000x last edited by werner2000x
          @thomas-braun Ich kann seit heute keine Adapter mehr aktualisieren.
          Bei drei Updates von Adaptern bekomme ich folgenden Fehler:
          host.raspberrypi
          2023-02-23 18:12:32.344	error	iobroker host.raspberrypi Cannot install iobroker.echarts@1.4.9: 217
          host.raspberrypi
          2023-02-23 18:11:08.729	error	iobroker host.raspberrypi Cannot install iobroker.text2command@3.0.1: 217
          host.raspberrypi
          2023-02-23 18:10:15.435	error	iobroker host.raspberrypi Cannot install iobroker.backitup@2.6.2: 217
          und mit "iob diag" folgendes
          js-controller:  4.0.24
          admin:          6.3.6
          javascript:     "javascript" not found
          npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
          npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
          npm ERR!     /home/pi/.npm/_logs/2023-02-23T17_20_26_124Z-debug-0.log
          Adapters from github:   1
          Hat jemand eine Idee?log230223.txt
            Thomas Braun Most Active @werner2000x last edited by
            @werner2000x
            Bitte jeweils vollständig posten, Eingabezeile inklusive.
            • werner2000x
              werner2000x last edited by Homoran
              Nach Befehl iob diag erhalte ich folgende Ausgabe:
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Model           : Raspberry Pi 4 Model B Rev 1.4
              Docker:         false
              Release:        10
              Codename:       buster
              VERSION_ID="10"
              ID=raspbian
              ID_LIKE=debian
               18:20:02 up 14 min,  2 users,  load average: 0.85, 0.82, 0.81
              CPU threads: 4
              Thu Feb 23 17:20:02 UTC 2023
              Thu Feb 23 18:20:02 CET 2023
              CET +0100
              Europe/Berlin
              pi
              /home/pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev bluetooth lpadmin gpio i2c spi iobroker
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:           7.9G        2.0G        5.1G        9.0M        839M        6.2G
              Swap:           99M          0B         99M
              Total:         8.0G        2.0G        5.2G
                       7898 M total memory
                       1996 M used memory
                        314 M active memory
                       2398 M inactive memory
                       5062 M free memory
                        128 M buffer memory
                        710 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              *** FILESYSTEM ***
              /dev/root      ext4      117G   21G   92G  19% /
              devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
              tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs          tmpfs     3.9G  9.5M  3.9G   1% /run
              tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
              /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
              tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
              Messages in dmesg:
              [Thu Feb 23 18:05:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
              [Thu Feb 23 18:05:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
              [Thu Feb 23 18:05:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
              [Thu Feb 23 18:05:15 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
              /             /dev/mmcblk0p2 ext4   rw,noatime
              `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              4.3G    /var/
              2.9G    /var/cache/apt
              2.9G    /var/cache
              2.8G    /var/cache/apt/archives
              719M    /var/log
              1.8G    /opt/iobroker/backups/
              296K    /opt/iobroker/backups/scripte
              268K    /opt/iobroker/backups/scripte/Meine_Geräte
              252K    /opt/iobroker/backups/Meine_Geräte
              8.0K    /opt/iobroker/backups/scripte/common
              1.6G    /opt/iobroker/iobroker-data/
              761M    /opt/iobroker/iobroker-data/node-red/node_modules
              601M    /opt/iobroker/iobroker-data/files
              531M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow
              197M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow.so.2.5.0
              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
              33M     /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow_framework.so.2.5.0
              33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
              23M     /opt/iobroker/iobroker-data/objects.jsonl
              /usr/bin/nodejs         v14.21.3
              /usr/bin/node           v14.21.3
              /usr/bin/npm            9.5.0
              /usr/bin/npx            9.5.0
              nodejs:
                Installed: 14.21.3-deb-1nodesource1
                Candidate: 14.21.3-deb-1nodesource1
                Version table:
               *** 14.21.3-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
              Temp directories causing npm8 problem: 1
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.6
              Adapter State
              + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
                system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
              + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
                system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
              + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
              + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
              + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
              + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
              + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
                system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
              + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
              + system.adapter.history.0                : history               : raspberrypi                              -  enabled
              + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
              + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
              + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
              + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
              + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
              + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
              + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                system.adapter.km200.0                  : km200                 : raspberrypi                              - disabled
                system.adapter.material.0               : material              : raspberrypi                              - disabled
              + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.198.39
              + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
                system.adapter.rainbird.0               : rainbird              : raspberrypi                              - disabled
              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
              + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
                system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              - disabled
              + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
              + system.adapter.tuya.1                   : tuya                  : raspberrypi                              -  enabled
                system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
                system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled
              + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              Active repo(s): beta
              Used repository: beta
              Adapter    "admin"        : 6.3.6    , installed 6.3.6
              Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
              Adapter    "backitup"     : 2.6.2    , installed 2.6.1  [Updatable]
              Adapter    "ble"          : 0.13.3   , installed 0.13.3
              Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
              Adapter    "cloud"        : 4.3.1    , installed 4.3.1
              Adapter    "daikin"       : 1.4.2    , installed 1.4.2
              Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
              Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
              Adapter    "device-reminder": 1.2.9  , installed 1.2.9
              Adapter    "devices"      : 1.1.2    , installed 1.1.2
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "echarts"      : 1.4.9    , installed 1.4.7  [Updatable]
              Adapter    "ems-esp"      : 1.22.0   , installed 1.22.0
              Adapter    "energymanager": 1.4.1    , installed 1.4.1
              Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
              Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
              Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
              Adapter    "ical"         : 1.13.2   , installed 1.13.2
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "info"         : 1.9.26   , installed 1.9.26
              Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
              Adapter    "iot"          : 1.14.3   , installed 1.14.3
              Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
              Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
              Controller "js-controller": 4.0.24   , installed 4.0.24
              Adapter    "km200"        : 2.0.3    , installed 2.0.3
              Adapter    "material"     : 1.3.1    , installed 1.3.1
              Adapter    "meross"       : 1.15.0   , installed 1.15.0
              Adapter    "node-red"     : 4.0.0    , installed 4.0.0
              Adapter    "parser"       : 1.3.2    , installed 1.3.2
              Adapter    "ping"         : 1.5.3    , installed 1.5.3
              Adapter    "rainbird"     : 0.2.2    , installed 0.2.2
              Adapter    "socketio"     : 6.3.3    , installed 6.3.3
              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
              Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
              Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
              Adapter    "text2command" : 3.0.1    , installed 3.0.0  [Updatable]
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "tuya"         : 3.14.1   , installed 3.14.1
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
              Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
              Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
              Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
              Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
              Adapter    "vw-connect"   : 0.0.60   , installed 0.0.60
              Adapter    "web"          : 5.5.0    , installed 5.5.0
              Adapter    "ws"           : 2.3.5    , installed 2.3.5
              Objects and States
              Objects:        21475
              States:         18373
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 https://apt.grafana.com stable InRelease
              Hit:4 https://repos.influxdata.com/debian stable InRelease
              Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
              Pending Updates: 0
              Proto Recv-Q Send-Q Local Address           Foreign Address         State
              tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN
              tcp        0      0 192.168.198.39:8081     0.0.0.0:*               LISTEN
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
              tcp        0      0 192.168.198.39:1880     0.0.0.0:*               LISTEN
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
              tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN
              tcp6       0      0 :::8086                 :::*                    LISTEN
              tcp6       0      0 ::1:3350                :::*                    LISTEN
              tcp6       0      0 ::1:631                 :::*                    LISTEN
              tcp6       0      0 :::3000                 :::*                    LISTEN
              tcp6       0      0 :::3389                 :::*                    LISTEN
              tcp6       0      0 :::445                  :::*                    LISTEN
              tcp6       0      0 :::139                  :::*                    LISTEN
              tcp6       0      0 :::5900                 :::*                    LISTEN
              udp        0      0 0.0.0.0:6666            0.0.0.0:*
              udp        0      0 0.0.0.0:6667            0.0.0.0:*
              udp        0      0 0.0.0.0:68              0.0.0.0:*
              udp        0      0 0.0.0.0:631             0.0.0.0:*
              udp        0      0 192.168.198.255:137     0.0.0.0:*
              udp        0      0 192.168.198.39:137      0.0.0.0:*
              udp        0      0 192.168.198.42:137      0.0.0.0:*
              udp        0      0 0.0.0.0:137             0.0.0.0:*
              udp        0      0 192.168.198.255:138     0.0.0.0:*
              udp        0      0 192.168.198.39:138      0.0.0.0:*
              udp        0      0 192.168.198.42:138      0.0.0.0:*
              udp        0      0 0.0.0.0:138             0.0.0.0:*
              udp        0      0 0.0.0.0:58511           0.0.0.0:*
              udp        0      0 0.0.0.0:38566           0.0.0.0:*
              udp        0      0 192.168.198.39:1194     0.0.0.0:*
              udp6       0      0 :::41388                :::*
              udp6       0      0 :::546                  :::*
              2023-02-23 18:19:09.154  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
              2023-02-23 18:19:59.080  - info: influxdb.0 (1263) No Data
              2023-02-23 18:19:59.173  - info: influxdb.0 (1263) No Data
              2023-02-23 18:19:59.478  - info: influxdb.0 (1263) No Data
              2023-02-23 18:20:00.146  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
              2023-02-23 18:20:00.610  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
              2023-02-23 18:20:08.693  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
              2023-02-23 18:20:09.351  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
              2023-02-23 18:20:24.470  - info: meross.0 (1531) Can not get Data for Device 211
              2023-02-23 18:20:24.471  - warn: meross.0 (1531) Can not get Data for Device 211
              2023-02-23 18:20:59.142  - info: influxdb.0 (1263) No Data
              2023-02-23 18:20:59.565  - info: influxdb.0 (1263) No Data
              2023-02-23 18:21:08.868  - debug: daikin-cloud.0 (1579) update state: 09d81369-d
              2023-02-23 18:21:08.881  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
              2023-02-23 18:21:08.889  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
              2023-02-23 18:21:08.895  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
              2023-02-23 18:21:09.659  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
              2023-02-23 18:21:09.660  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
              2023-02-23 18:21:09.667  - warn: daikin-cloud.0 (1579) State "daikin-cloud.0.f7b
              2023-02-23 18:21:09.675  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
              2023-02-23 18:21:09.679  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
              2023-02-23 18:21:09.688  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
              2023-02-23 18:21:11.789  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
              2023-02-23 18:21:12.173  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
              iob diag has finished.
                Thomas Braun Most Active @werner2000x last edited by Thomas Braun
                @werner2000x
                Die Lösung dazu findet sich in den oben festgepinnten Threads.
                https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                Und npm wird nicht von Hand aktualisiert!
                Dein Betriebssystem ist abgekündigt, installiert da das aktuelle stabile Release 'Bullseye'.
                • ostseereiter
                  ostseereiter last edited by
                  Ich habe das schon seit ein viertel Jahr das sich kein Adapter mehr aktualisieren kann. Es ist aber erst seid Node JS 16 wenn man auf die 14 zurückgehrt dann klappt das wieder habe ich gelesen. Nu sind es bei mir schon fast 40 Adapter die aktualiersiert werden möchten. Ich lass es jetzt einfach so System läuft trotzdem super.Wenn es meine Zeit zuläßt werde ich dann Iobroker neu installieren. Solange es läuft ist es gut und das andere ist alles flickschusterei denke ich, denn der festgepinnte Thred haut auch nicht hin weil bei mir nur der Fehler 0 kommt.
                    Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                    @ostseereiter sagte in Problem beim Update von Adaptern/Modulen/Controller:
                    Das nur die Meldung 0 kommt glaube ich nicht.
                    Aber deine Beschreibung ist auch etwas dünn.
                    Wenigstens mal ein
                    iob diag
                    oder wenigstens
                    iob update
                    iob upgrade ADAPTER --debug
                    wäre fein. So kann man nichts weiter dazu sagen.
                    • werner2000x
                      Ich habe jetzt das Problem, dass der Javascript adapter nicht mehr startet (rot).
                      Wenn ich den Befehl "iob upgrade ADAPTER --debug" aufrufen, dann kommt: Adapter "ADAPTER" is not installed.
                      Ich habe auch schon javascript neu installiert und gebootet - leider keine Abhilfe.
                      Gibt es eine Lösung oder nur mit "Bullseye"?
                        @werner2000x
                        Du hast aber schon gesehen, dass 'ADAPTER' nur ein Platzhalter ist und durch den Adapternamen ersetzt werden muss?
                        iobroker upgrade javascript --debug
                        werner2000x 1 Reply Last reply Reply Quote 0
                        • werner2000x
                          werner2000x @Thomas Braun last edited by
                          @thomas-braun Ja, Danke das katte ich übersehen.
                          Nun habe ich den Adapter javascript deinstalliert und er erscheint auch nicht mehr in der Instance Liste.
                          Wenn ich nun den folgenden Befehl aurufe:
                          iob upgrade javascript --debug
                          Adapter "javascript"     is not installed.
                          erhalt ich die Meldung wie vorstehend. Wie kann ich denn den Adapter neu installieren?
                            @werner2000x
                            iobroker add javascript --debug
                            • werner2000x
                              Dann kommt folgendes:
                              NPM version: 9.5.0
                              Installing iobroker.javascript@7.0.1... (System call)
                              npm ERR! code ENOTEMPTY
                              npm ERR! syscall rename
                              npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                              npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                              npm ERR! errno -39
                              npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                              npm ERR!     /home/iobroker/.npm/_logs/2023-02-24T14_10_51_991Z-debug-0.log
                              host.raspberrypi Cannot install iobroker.javascript@7.0.1: 217
                                Homoran Global Moderator Administrators @werner2000x last edited by
                                @werner2000x sagte in Problem beim Update von Adaptern/Modulen/Controller:
                                warum?
                                dann geht natürlich kein upgrade mehr
                                  217
                                  • werner2000x
                                    werner2000x @Homoran last edited by werner2000x
                                    @homoran Ich habe ihn deinstalliert weil er immer Rot in den instancen war.
                                      NPM version: 9.5.0
                                      Von Hand dran herumgefummelt.
                                      NICHT machen.
                                      nodejs (inkl. npm) neuinstallieren.
                                      Beta-Software:
                                      javascript@7.0.1
                                      Ich denke im Beta-Repository bist du vollkommen falsch aufgehoben.
                                        warum fummelt man an der Installation rum während andere versuchen zu helfen?
                                        Der Wissensstand der helfenden ist damit ständig veraltet.
                                        https://forum.iobroker.net/post/884324
                                        • werner2000x
                                          @homoran Ja, ich war etwas voreilig. Kann man denn trotzdem noch was retten obwohl kein javascript adapter mehr da ist?
                                            @werner2000x
                                            Frische Ausgabe von
                                            iob diag
                                            bereitstellen, dann nix mehr fummeln.
                                            1970
