    4. Problem beim Update von Adaptern/Modulen/Controller
      Thomas Braun Most Active @corny456 last edited by Thomas Braun
      @corny456
      Die alte Leier...
      NICHT als root herumkaspern, nodeJS sauber senkrecht per Paketmanager installieren, Buster beerdigen, Bullseye installieren.
      • werner2000x
        werner2000x last edited by werner2000x
        @thomas-braun Ich kann seit heute keine Adapter mehr aktualisieren.
        Bei drei Updates von Adaptern bekomme ich folgenden Fehler:
        host.raspberrypi
        2023-02-23 18:12:32.344	error	iobroker host.raspberrypi Cannot install iobroker.echarts@1.4.9: 217
        host.raspberrypi
        2023-02-23 18:11:08.729	error	iobroker host.raspberrypi Cannot install iobroker.text2command@3.0.1: 217
        host.raspberrypi
        2023-02-23 18:10:15.435	error	iobroker host.raspberrypi Cannot install iobroker.backitup@2.6.2: 217
        und mit "iob diag" folgendes
        Core adapters versions
        js-controller:  4.0.24
        admin:          6.3.6
        javascript:     "javascript" not found
        npm ERR! code ELSPROBLEMS
        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
        npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
        npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
        npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
        npm ERR!     /home/pi/.npm/_logs/2023-02-23T17_20_26_124Z-debug-0.log
        Adapters from github:   1
        Hat jemand eine Idee?log230223.txt
          Thomas Braun Most Active @werner2000x last edited by
          @werner2000x
          Bitte jeweils vollständig posten, Eingabezeile inklusive.
          • werner2000x
            werner2000x last edited by Homoran
            Nach Befehl iob diag erhalte ich folgende Ausgabe:
            Skript v.2023-01-02
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Architecture:   armv7l
            Docker:         false
            Virtualization: none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 10 (buster)
            Release:        10
            Codename:       buster
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             18:20:02 up 14 min,  2 users,  load average: 0.85, 0.82, 0.81
            CPU threads: 4
            *** Time and Time Zones ***
            Thu Feb 23 17:20:02 UTC 2023
            Thu Feb 23 18:20:02 CET 2023
            CET +0100
            Europe/Berlin
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input netdev bluetooth lpadmin gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:           7.9G        2.0G        5.1G        9.0M        839M        6.2G
            Swap:           99M          0B         99M
            Total:         8.0G        2.0G        5.2G
                     7898 M total memory
                     1996 M used memory
                      314 M active memory
                     2398 M inactive memory
                     5062 M free memory
                      128 M buffer memory
                      710 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /dev/root      ext4      117G   21G   92G  19% /
            devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
            tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
            tmpfs          tmpfs     3.9G  9.5M  3.9G   1% /run
            tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
            Messages in dmesg:
            [Thu Feb 23 18:05:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Thu Feb 23 18:05:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Thu Feb 23 18:05:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Thu Feb 23 18:05:15 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            Show mounted filesystems (real ones only):
            TARGET        SOURCE         FSTYPE OPTIONS
            /             /dev/mmcblk0p2 ext4   rw,noatime
            |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            4.3G    /var/
            2.9G    /var/cache/apt
            2.9G    /var/cache
            2.8G    /var/cache/apt/archives
            719M    /var/log
            /opt/iobroker/backups:
            1.8G    /opt/iobroker/backups/
            296K    /opt/iobroker/backups/scripte
            268K    /opt/iobroker/backups/scripte/Meine_Geräte
            252K    /opt/iobroker/backups/Meine_Geräte
            8.0K    /opt/iobroker/backups/scripte/common
            /opt/iobroker/iobroker-data:
            1.6G    /opt/iobroker/iobroker-data/
            761M    /opt/iobroker/iobroker-data/node-red/node_modules
            601M    /opt/iobroker/iobroker-data/files
            531M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow
            197M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow.so.2.5.0
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            33M     /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow_framework.so.2.5.0
            33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
            23M     /opt/iobroker/iobroker-data/objects.jsonl
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v14.21.3
            /usr/bin/node           v14.21.3
            /usr/bin/npm            9.5.0
            /usr/bin/npx            9.5.0
            nodejs:
              Installed: 14.21.3-deb-1nodesource1
              Candidate: 14.21.3-deb-1nodesource1
              Version table:
             *** 14.21.3-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u2 500
            Temp directories causing npm8 problem: 1
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.6
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
              system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
              system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
            + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
              system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
            + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
            + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
            + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
            + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
              system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
            + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
            + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
            + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
            + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
            + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
            + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
            + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
            + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
              system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
              system.adapter.km200.0                  : km200                 : raspberrypi                              - disabled
              system.adapter.material.0               : material              : raspberrypi                              - disabled
            + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.198.39
            + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
            + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
              system.adapter.rainbird.0               : rainbird              : raspberrypi                              - disabled
            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
            + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
              system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
              system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              - disabled
            + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
              system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
            + system.adapter.tuya.1                   : tuya                  : raspberrypi                              -  enabled
              system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
              system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
              system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
              system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
              system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
              system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled
            + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + instance is alive
            ioBroker-Repositories
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "admin"        : 6.3.6    , installed 6.3.6
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "backitup"     : 2.6.2    , installed 2.6.1  [Updatable]
            Adapter    "ble"          : 0.13.3   , installed 0.13.3
            Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
            Adapter    "cloud"        : 4.3.1    , installed 4.3.1
            Adapter    "daikin"       : 1.4.2    , installed 1.4.2
            Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
            Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
            Adapter    "device-reminder": 1.2.9  , installed 1.2.9
            Adapter    "devices"      : 1.1.2    , installed 1.1.2
            Adapter    "discovery"    : 3.1.0    , installed 3.1.0
            Adapter    "echarts"      : 1.4.9    , installed 1.4.7  [Updatable]
            Adapter    "ems-esp"      : 1.22.0   , installed 1.22.0
            Adapter    "energymanager": 1.4.1    , installed 1.4.1
            Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
            Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
            Adapter    "history"      : 2.2.4    , installed 2.2.4
            Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
            Adapter    "hue"          : 3.7.1    , installed 3.7.1
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "ical"         : 1.13.2   , installed 1.13.2
            Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
            Adapter    "info"         : 1.9.26   , installed 1.9.26
            Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
            Adapter    "iot"          : 1.14.3   , installed 1.14.3
            Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
            Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
            Controller "js-controller": 4.0.24   , installed 4.0.24
            Adapter    "km200"        : 2.0.3    , installed 2.0.3
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "meross"       : 1.15.0   , installed 1.15.0
            Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
            Adapter    "node-red"     : 4.0.0    , installed 4.0.0
            Adapter    "parser"       : 1.3.2    , installed 1.3.2
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "pushover"     : 3.0.3    , installed 3.0.3
            Adapter    "rainbird"     : 0.2.2    , installed 0.2.2
            Adapter    "socketio"     : 6.3.3    , installed 6.3.3
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
            Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
            Adapter    "text2command" : 3.0.1    , installed 3.0.0  [Updatable]
            Adapter    "trashschedule": 2.2.0    , installed 2.2.0
            Adapter    "tuya"         : 3.14.1   , installed 3.14.1
            Adapter    "vis"          : 1.4.16   , installed 1.4.16
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
            Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
            Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
            Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
            Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
            Adapter    "vw-connect"   : 0.0.60   , installed 0.0.60
            Adapter    "web"          : 5.5.0    , installed 5.5.0
            Adapter    "ws"           : 2.3.5    , installed 2.3.5
            Objects and States
            Objects:        21475
            States:         18373
            Hit:1 http://archive.raspberrypi.org/debian buster InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:3 https://apt.grafana.com stable InRelease
            Hit:4 https://repos.influxdata.com/debian stable InRelease
            Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            Proto Recv-Q Send-Q Local Address           Foreign Address         State
            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN
            tcp        0      0 192.168.198.39:8081     0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
            tcp        0      0 192.168.198.39:1880     0.0.0.0:*               LISTEN
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
            tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN
            tcp6       0      0 :::8082                 :::*                    LISTEN
            tcp6       0      0 :::8086                 :::*                    LISTEN
            tcp6       0      0 ::1:3350                :::*                    LISTEN
            tcp6       0      0 :::22                   :::*                    LISTEN
            tcp6       0      0 :::8087                 :::*                    LISTEN
            tcp6       0      0 ::1:631                 :::*                    LISTEN
            tcp6       0      0 :::3000                 :::*                    LISTEN
            tcp6       0      0 :::3389                 :::*                    LISTEN
            tcp6       0      0 :::445                  :::*                    LISTEN
            tcp6       0      0 :::139                  :::*                    LISTEN
            tcp6       0      0 :::5900                 :::*                    LISTEN
            udp        0      0 0.0.0.0:6666            0.0.0.0:*
            udp        0      0 0.0.0.0:6667            0.0.0.0:*
            udp        0      0 0.0.0.0:68              0.0.0.0:*
            udp        0      0 0.0.0.0:631             0.0.0.0:*
            udp        0      0 192.168.198.255:137     0.0.0.0:*
            udp        0      0 192.168.198.39:137      0.0.0.0:*
            udp        0      0 192.168.198.42:137      0.0.0.0:*
            udp        0      0 0.0.0.0:137             0.0.0.0:*
            udp        0      0 192.168.198.255:138     0.0.0.0:*
            udp        0      0 192.168.198.39:138      0.0.0.0:*
            udp        0      0 192.168.198.42:138      0.0.0.0:*
            udp        0      0 0.0.0.0:138             0.0.0.0:*
            udp        0      0 0.0.0.0:58511           0.0.0.0:*
            udp        0      0 0.0.0.0:38566           0.0.0.0:*
            udp        0      0 192.168.198.39:1194     0.0.0.0:*
            udp        0      0 0.0.0.0:5353            0.0.0.0:*
            udp6       0      0 :::41388                :::*
            udp6       0      0 :::546                  :::*
            udp6       0      0 :::5353                 :::*
            2023-02-23 18:19:09.154  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
            2023-02-23 18:19:59.080  - info: influxdb.0 (1263) No Data
            2023-02-23 18:19:59.173  - info: influxdb.0 (1263) No Data
            2023-02-23 18:19:59.478  - info: influxdb.0 (1263) No Data
            2023-02-23 18:20:00.146  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
            2023-02-23 18:20:00.610  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
            2023-02-23 18:20:08.693  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
            2023-02-23 18:20:09.351  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
            2023-02-23 18:20:24.470  - info: meross.0 (1531) Can not get Data for Device 211
            2023-02-23 18:20:24.471  - warn: meross.0 (1531) Can not get Data for Device 211
            2023-02-23 18:20:59.142  - info: influxdb.0 (1263) No Data
            2023-02-23 18:20:59.565  - info: influxdb.0 (1263) No Data
            2023-02-23 18:21:08.868  - debug: daikin-cloud.0 (1579) update state: 09d81369-d
            2023-02-23 18:21:08.881  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
            2023-02-23 18:21:08.889  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
            2023-02-23 18:21:08.895  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
            2023-02-23 18:21:09.659  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
            2023-02-23 18:21:09.660  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
            2023-02-23 18:21:09.667  - warn: daikin-cloud.0 (1579) State "daikin-cloud.0.f7b
            2023-02-23 18:21:09.675  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
            2023-02-23 18:21:09.679  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
            2023-02-23 18:21:09.688  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
            2023-02-23 18:21:11.789  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
            2023-02-23 18:21:12.173  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
            iob diag has finished.
              Thomas Braun Most Active @werner2000x last edited by Thomas Braun
              @werner2000x
              Die Lösung dazu findet sich in den oben festgepinnten Threads.
              https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
              Und npm wird nicht von Hand aktualisiert!
              Dein Betriebssystem ist abgekündigt, installiert da das aktuelle stabile Release 'Bullseye'.
              • ostseereiter
                ostseereiter last edited by
                Ich habe das schon seit ein viertel Jahr das sich kein Adapter mehr aktualisieren kann. Es ist aber erst seid Node JS 16 wenn man auf die 14 zurückgehrt dann klappt das wieder habe ich gelesen. Nu sind es bei mir schon fast 40 Adapter die aktualiersiert werden möchten. Ich lass es jetzt einfach so System läuft trotzdem super.Wenn es meine Zeit zuläßt werde ich dann Iobroker neu installieren. Solange es läuft ist es gut und das andere ist alles flickschusterei denke ich, denn der festgepinnte Thred haut auch nicht hin weil bei mir nur der Fehler 0 kommt.
                  Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                  @ostseereiter sagte in Problem beim Update von Adaptern/Modulen/Controller:
                  Das nur die Meldung 0 kommt glaube ich nicht.
                  Aber deine Beschreibung ist auch etwas dünn.
                  Wenigstens mal ein
                  iob diag
                  oder wenigstens
                  iob update
                  iob upgrade ADAPTER --debug
                  wäre fein. So kann man nichts weiter dazu sagen.
                  • werner2000x
                    Ich habe jetzt das Problem, dass der Javascript adapter nicht mehr startet (rot).
                    Wenn ich den Befehl "iob upgrade ADAPTER --debug" aufrufen, dann kommt: Adapter "ADAPTER" is not installed.
                    Ich habe auch schon javascript neu installiert und gebootet - leider keine Abhilfe.
                    Gibt es eine Lösung oder nur mit "Bullseye"?
                      @werner2000x
                      Du hast aber schon gesehen, dass 'ADAPTER' nur ein Platzhalter ist und durch den Adapternamen ersetzt werden muss?
                      iobroker upgrade javascript --debug
                      werner2000x 1 Reply Last reply Reply Quote 0
                      • werner2000x
                        werner2000x @Thomas Braun last edited by
                        @thomas-braun Ja, Danke das katte ich übersehen.
                        Nun habe ich den Adapter javascript deinstalliert und er erscheint auch nicht mehr in der Instance Liste.
                        Wenn ich nun den folgenden Befehl aurufe:
                        iob upgrade javascript --debug
                        Adapter "javascript"     is not installed.
                        erhalt ich die Meldung wie vorstehend. Wie kann ich denn den Adapter neu installieren?
                          @werner2000x
                          iobroker add javascript --debug
                          • werner2000x
                            Dann kommt folgendes:
                            NPM version: 9.5.0
                            Installing iobroker.javascript@7.0.1... (System call)
                            npm ERR! code ENOTEMPTY
                            npm ERR! syscall rename
                            npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                            npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                            npm ERR!     /home/iobroker/.npm/_logs/2023-02-24T14_10_51_991Z-debug-0.log
                            host.raspberrypi Cannot install iobroker.javascript@7.0.1: 217
                              Homoran Global Moderator Administrators @werner2000x last edited by
                              @werner2000x sagte in Problem beim Update von Adaptern/Modulen/Controller:
                              warum?
                              dann geht natürlich kein upgrade mehr
                                217
                                • werner2000x
                                  werner2000x @Homoran last edited by werner2000x
                                  @homoran Ich habe ihn deinstalliert weil er immer Rot in den instancen war.
                                    NPM version: 9.5.0
                                    Von Hand dran herumgefummelt.
                                    NICHT machen.
                                    nodejs (inkl. npm) neuinstallieren.
                                    Beta-Software:
                                    javascript@7.0.1
                                    Ich denke im Beta-Repository bist du vollkommen falsch aufgehoben.
                                      warum fummelt man an der Installation rum während andere versuchen zu helfen?
                                      Der Wissensstand der helfenden ist damit ständig veraltet.
                                      https://forum.iobroker.net/post/884324
                                      • werner2000x
                                        @homoran Ja, ich war etwas voreilig. Kann man denn trotzdem noch was retten obwohl kein javascript adapter mehr da ist?
                                          @werner2000x
                                          Frische Ausgabe von
                                          iob diag
                                          bereitstellen, dann nix mehr fummeln.
                                          • werner2000x
                                            werner2000x last edited by wendy2702
                                            @thomas-braun Leider ist das Problem damit nicht gelöst. Es fehlt immer noch der javascipt Adapter s. Logfile.
                                            log.txt
                                            *** ioBroker Diagnosis ***
                                            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                            Just copy and paste the Summary Page, including the ``` characters at start and end.
                                            It helps us to help you!
                                            Press any key to continue
                                            Skript v.2023-01-02
                                            *** BASE SYSTEM ***
                                            Docker: 	false
                                            Release:	10
                                            Codename:	buster
                                            VERSION_ID="10"
                                            ID=raspbian
                                            ID_LIKE=debian
                                             16:15:22 up  1:46,  3 users,  load average: 2.10, 1.83, 1.65
                                            CPU threads: 4
                                            Fri Feb 24 15:15:22 UTC 2023
                                            Fri Feb 24 16:15:22 CET 2023
                                            CET +0100
                                            Europe/Berlin
                                            pi
                                            /home/pi
                                            X-Server: 	false
                                            Desktop:
                                            Terminal: 	tty
                                            Boot Target: 	graphical.target
                                            *** MEMORY ***
                                            Mem:           7.9G        1.5G        4.6G         17M        1.8G        6.5G
                                            Swap:           99M          0B         99M
                                            Total:         8.0G        1.5G        4.7G
                                                     7898 M total memory
                                                     1494 M used memory
                                                      535 M active memory
                                                     2581 M inactive memory
                                                     4559 M free memory
                                                      193 M buffer memory
                                                     1651 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            *** FILESYSTEM ***
                                            /dev/root      ext4      117G   21G   92G  18% /
                                            tmpfs          tmpfs     3.9G   18M  3.9G   1% /run
                                            Messages in dmesg:
                                            [Fri Feb 24 14:29:05 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                            [Fri Feb 24 14:29:06 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                            [Fri Feb 24 14:29:06 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                            [Fri Feb 24 14:29:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                            /var:
                                            4.3G	/var/
                                            2.9G	/var/cache/apt
                                            2.9G	/var/cache
                                            729M	/var/log
                                            557M	/opt/iobroker/iobroker-data/files
                                            34M	/opt/iobroker/iobroker-data/objects.jsonl
                                            23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.f59a8c63.js.map
                                            /usr/bin/npm 		9.5.1
                                            /usr/bin/npx 		9.5.1
                                            nodejs:
                                              Version table:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            admin: 		6.3.5
                                            Adapters from github: 	0
                                            Adapter State
                                            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                              system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                            + instance is alive
                                            Adapter    "admin"        : 6.3.6    , installed 6.3.5  [Updatable]
                                            Adapter    "backitup"     : 2.6.2    , installed 2.5.12 [Updatable]
                                            Objects and States
                                            MOD EDIT: LOG FILE AUS TEXT FILE IN CODE TAGS </> GESETZT
                                            1970
