    4. Problem beim Update von Adaptern/Modulen/Controller
    • werner2000x
      werner2000x last edited by werner2000x
      @thomas-braun Ich kann seit heute keine Adapter mehr aktualisieren.
      Bei drei Updates von Adaptern bekomme ich folgenden Fehler:
      host.raspberrypi
      2023-02-23 18:12:32.344	error	iobroker host.raspberrypi Cannot install iobroker.echarts@1.4.9: 217
      host.raspberrypi
      2023-02-23 18:11:08.729	error	iobroker host.raspberrypi Cannot install iobroker.text2command@3.0.1: 217
      host.raspberrypi
      2023-02-23 18:10:15.435	error	iobroker host.raspberrypi Cannot install iobroker.backitup@2.6.2: 217
      und mit "iob diag" folgendes
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.6
      javascript:     "javascript" not found
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
      npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
      npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
      npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
      npm ERR!     /home/pi/.npm/_logs/2023-02-23T17_20_26_124Z-debug-0.log
      Adapters from github:   1
      Hat jemand eine Idee?log230223.txt
        Thomas Braun Most Active @werner2000x last edited by
        @werner2000x
        Bitte jeweils vollständig posten, Eingabezeile inklusive.
        • werner2000x
          werner2000x last edited by Homoran
          Nach Befehl iob diag erhalte ich folgende Ausgabe:
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Architecture:   armv7l
          Docker:         false
          Virtualization: none
          Distributor ID: Raspbian
          Description:    Raspbian GNU/Linux 10 (buster)
          Release:        10
          Codename:       buster
          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
          NAME="Raspbian GNU/Linux"
          VERSION_ID="10"
          VERSION="10 (buster)"
          VERSION_CODENAME=buster
          ID=raspbian
          ID_LIKE=debian
          HOME_URL="http://www.raspbian.org/"
          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          Systemuptime and Load:
           18:20:02 up 14 min,  2 users,  load average: 0.85, 0.82, 0.81
          CPU threads: 4
          *** Time and Time Zones ***
          Thu Feb 23 17:20:02 UTC 2023
          Thu Feb 23 18:20:02 CET 2023
          CET +0100
          Europe/Berlin
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev bluetooth lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:           7.9G        2.0G        5.1G        9.0M        839M        6.2G
          Swap:           99M          0B         99M
          Total:         8.0G        2.0G        5.2G
                   7898 M total memory
                   1996 M used memory
                    314 M active memory
                   2398 M inactive memory
                   5062 M free memory
                    128 M buffer memory
                    710 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /dev/root      ext4      117G   21G   92G  19% /
          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     3.9G  9.5M  3.9G   1% /run
          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
          Messages in dmesg:
          [Thu Feb 23 18:05:12 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Thu Feb 23 18:05:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Feb 23 18:05:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Feb 23 18:05:15 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          Show mounted filesystems (real ones only):
          TARGET        SOURCE         FSTYPE OPTIONS
          /             /dev/mmcblk0p2 ext4   rw,noatime
          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          4.3G    /var/
          2.9G    /var/cache/apt
          2.9G    /var/cache
          2.8G    /var/cache/apt/archives
          719M    /var/log
          /opt/iobroker/backups:
          1.8G    /opt/iobroker/backups/
          296K    /opt/iobroker/backups/scripte
          268K    /opt/iobroker/backups/scripte/Meine_Geräte
          252K    /opt/iobroker/backups/Meine_Geräte
          8.0K    /opt/iobroker/backups/scripte/common
          /opt/iobroker/iobroker-data:
          1.6G    /opt/iobroker/iobroker-data/
          761M    /opt/iobroker/iobroker-data/node-red/node_modules
          601M    /opt/iobroker/iobroker-data/files
          531M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow
          197M    /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow.so.2.5.0
          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          33M     /opt/iobroker/iobroker-data/node-red/node_modules/@tensorflow/tfjs-node/deps/lib/libtensorflow_framework.so.2.5.0
          33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
          23M     /opt/iobroker/iobroker-data/objects.jsonl
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v14.21.3
          /usr/bin/node           v14.21.3
          /usr/bin/npm            9.5.0
          /usr/bin/npx            9.5.0
          nodejs:
            Installed: 14.21.3-deb-1nodesource1
            Candidate: 14.21.3-deb-1nodesource1
            Version table:
           *** 14.21.3-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u2 500
          Temp directories causing npm8 problem: 1
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.6
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 192.168.198.39, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              -  enabled
            system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
          + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
            system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
          + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
          + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi                              -  enabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          + system.adapter.device-reminder.1        : device-reminder       : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
            system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
          + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
          + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
          + system.adapter.history.0                : history               : raspberrypi                              -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
          + system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              -  enabled
          + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.innogy-smarthome.0       : innogy-smarthome      : raspberrypi                              -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            system.adapter.km200.0                  : km200                 : raspberrypi                              - disabled
            system.adapter.material.0               : material              : raspberrypi                              - disabled
          + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.198.39
          + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
          + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
            system.adapter.rainbird.0               : rainbird              : raspberrypi                              - disabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
            system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
            system.adapter.systeminfo.0             : systeminfo            : raspberrypi                              - disabled
          + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
            system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
          + system.adapter.tuya.1                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
            system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
            system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.3.6    , installed 6.3.6
          Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
          Adapter    "backitup"     : 2.6.2    , installed 2.6.1  [Updatable]
          Adapter    "ble"          : 0.13.3   , installed 0.13.3
          Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
          Adapter    "cloud"        : 4.3.1    , installed 4.3.1
          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
          Adapter    "daikin-cloud" : 0.2.3    , installed 0.2.3
          Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
          Adapter    "devices"      : 1.1.2    , installed 1.1.2
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "echarts"      : 1.4.9    , installed 1.4.7  [Updatable]
          Adapter    "ems-esp"      : 1.22.0   , installed 1.22.0
          Adapter    "energymanager": 1.4.1    , installed 1.4.1
          Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
          Adapter    "history"      : 2.2.4    , installed 2.2.4
          Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
          Adapter    "hue"          : 3.7.1    , installed 3.7.1
          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
          Adapter    "ical"         : 1.13.2   , installed 1.13.2
          Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
          Adapter    "info"         : 1.9.26   , installed 1.9.26
          Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
          Adapter    "iot"          : 1.14.3   , installed 1.14.3
          Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "km200"        : 2.0.3    , installed 2.0.3
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "meross"       : 1.15.0   , installed 1.15.0
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
          Adapter    "parser"       : 1.3.2    , installed 1.3.2
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "pushover"     : 3.0.3    , installed 3.0.3
          Adapter    "rainbird"     : 0.2.2    , installed 0.2.2
          Adapter    "socketio"     : 6.3.3    , installed 6.3.3
          Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
          Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
          Adapter    "systeminfo"   : 0.3.1    , installed 0.3.1
          Adapter    "text2command" : 3.0.1    , installed 3.0.0  [Updatable]
          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
          Adapter    "tuya"         : 3.14.1   , installed 3.14.1
          Adapter    "vis"          : 1.4.16   , installed 1.4.16
          Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
          Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
          Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
          Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
          Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
          Adapter    "vw-connect"   : 0.0.60   , installed 0.0.60
          Adapter    "web"          : 5.5.0    , installed 5.5.0
          Adapter    "ws"           : 2.3.5    , installed 2.3.5
          Objects and States
          Objects:        21475
          States:         18373
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 https://apt.grafana.com stable InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          Proto Recv-Q Send-Q Local Address           Foreign Address         State
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN
          tcp        0      0 192.168.198.39:8081     0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN
          tcp        0      0 192.168.198.39:1880     0.0.0.0:*               LISTEN
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN
          tcp6       0      0 :::8082                 :::*                    LISTEN
          tcp6       0      0 :::8086                 :::*                    LISTEN
          tcp6       0      0 ::1:3350                :::*                    LISTEN
          tcp6       0      0 :::22                   :::*                    LISTEN
          tcp6       0      0 :::8087                 :::*                    LISTEN
          tcp6       0      0 ::1:631                 :::*                    LISTEN
          tcp6       0      0 :::3000                 :::*                    LISTEN
          tcp6       0      0 :::3389                 :::*                    LISTEN
          tcp6       0      0 :::445                  :::*                    LISTEN
          tcp6       0      0 :::139                  :::*                    LISTEN
          tcp6       0      0 :::5900                 :::*                    LISTEN
          udp        0      0 0.0.0.0:6666            0.0.0.0:*
          udp        0      0 0.0.0.0:6667            0.0.0.0:*
          udp        0      0 0.0.0.0:68              0.0.0.0:*
          udp        0      0 0.0.0.0:631             0.0.0.0:*
          udp        0      0 192.168.198.255:137     0.0.0.0:*
          udp        0      0 192.168.198.39:137      0.0.0.0:*
          udp        0      0 192.168.198.42:137      0.0.0.0:*
          udp        0      0 0.0.0.0:137             0.0.0.0:*
          udp        0      0 192.168.198.255:138     0.0.0.0:*
          udp        0      0 192.168.198.39:138      0.0.0.0:*
          udp        0      0 192.168.198.42:138      0.0.0.0:*
          udp        0      0 0.0.0.0:138             0.0.0.0:*
          udp        0      0 0.0.0.0:58511           0.0.0.0:*
          udp        0      0 0.0.0.0:38566           0.0.0.0:*
          udp        0      0 192.168.198.39:1194     0.0.0.0:*
          udp        0      0 0.0.0.0:5353            0.0.0.0:*
          udp6       0      0 :::41388                :::*
          udp6       0      0 :::546                  :::*
          udp6       0      0 :::5353                 :::*
          2023-02-23 18:19:09.154  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
          2023-02-23 18:19:59.080  - info: influxdb.0 (1263) No Data
          2023-02-23 18:19:59.173  - info: influxdb.0 (1263) No Data
          2023-02-23 18:19:59.478  - info: influxdb.0 (1263) No Data
          2023-02-23 18:20:00.146  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
          2023-02-23 18:20:00.610  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
          2023-02-23 18:20:08.693  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
          2023-02-23 18:20:09.351  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
          2023-02-23 18:20:24.470  - info: meross.0 (1531) Can not get Data for Device 211
          2023-02-23 18:20:24.471  - warn: meross.0 (1531) Can not get Data for Device 211
          2023-02-23 18:20:59.142  - info: influxdb.0 (1263) No Data
          2023-02-23 18:20:59.565  - info: influxdb.0 (1263) No Data
          2023-02-23 18:21:08.868  - debug: daikin-cloud.0 (1579) update state: 09d81369-d
          2023-02-23 18:21:08.881  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
          2023-02-23 18:21:08.889  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
          2023-02-23 18:21:08.895  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.09d
          2023-02-23 18:21:09.659  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
          2023-02-23 18:21:09.660  - debug: daikin-cloud.0 (1579) update state: f7b00bf0-d
          2023-02-23 18:21:09.667  - warn: daikin-cloud.0 (1579) State "daikin-cloud.0.f7b
          2023-02-23 18:21:09.675  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
          2023-02-23 18:21:09.679  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
          2023-02-23 18:21:09.688  - debug: daikin-cloud.0 (1579) state daikin-cloud.0.f7b
          2023-02-23 18:21:11.789  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
          2023-02-23 18:21:12.173  - info: tuya.1 (1598) bff726197434978f13tvtd: Received
          iob diag has finished.
            Thomas Braun Most Active @werner2000x last edited by Thomas Braun
            @werner2000x
            Die Lösung dazu findet sich in den oben festgepinnten Threads.
            https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
            Und npm wird nicht von Hand aktualisiert!
            Dein Betriebssystem ist abgekündigt, installiert da das aktuelle stabile Release 'Bullseye'.
            • ostseereiter
              ostseereiter last edited by
              Ich habe das schon seit ein viertel Jahr das sich kein Adapter mehr aktualisieren kann. Es ist aber erst seid Node JS 16 wenn man auf die 14 zurückgehrt dann klappt das wieder habe ich gelesen. Nu sind es bei mir schon fast 40 Adapter die aktualiersiert werden möchten. Ich lass es jetzt einfach so System läuft trotzdem super.Wenn es meine Zeit zuläßt werde ich dann Iobroker neu installieren. Solange es läuft ist es gut und das andere ist alles flickschusterei denke ich, denn der festgepinnte Thred haut auch nicht hin weil bei mir nur der Fehler 0 kommt.
                Thomas Braun Most Active @ostseereiter last edited by Thomas Braun
                @ostseereiter sagte in Problem beim Update von Adaptern/Modulen/Controller:
                Das nur die Meldung 0 kommt glaube ich nicht.
                Aber deine Beschreibung ist auch etwas dünn.
                Wenigstens mal ein
                iob diag
                oder wenigstens
                iob update
                iob upgrade ADAPTER --debug
                wäre fein. So kann man nichts weiter dazu sagen.
                • werner2000x
                  Ich habe jetzt das Problem, dass der Javascript adapter nicht mehr startet (rot).
                  Wenn ich den Befehl "iob upgrade ADAPTER --debug" aufrufen, dann kommt: Adapter "ADAPTER" is not installed.
                  Ich habe auch schon javascript neu installiert und gebootet - leider keine Abhilfe.
                  Gibt es eine Lösung oder nur mit "Bullseye"?
                    @werner2000x
                    Du hast aber schon gesehen, dass 'ADAPTER' nur ein Platzhalter ist und durch den Adapternamen ersetzt werden muss?
                    iobroker upgrade javascript --debug
                    werner2000x 1 Reply Last reply Reply Quote 0
                    • werner2000x
                      werner2000x @Thomas Braun last edited by
                      @thomas-braun Ja, Danke das katte ich übersehen.
                      Nun habe ich den Adapter javascript deinstalliert und er erscheint auch nicht mehr in der Instance Liste.
                      Wenn ich nun den folgenden Befehl aurufe:
                      iob upgrade javascript --debug
                      Adapter "javascript"     is not installed.
                      erhalt ich die Meldung wie vorstehend. Wie kann ich denn den Adapter neu installieren?
                        @werner2000x
                        iobroker add javascript --debug
                        • werner2000x
                          Dann kommt folgendes:
                          NPM version: 9.5.0
                          Installing iobroker.javascript@7.0.1... (System call)
                          npm ERR! code ENOTEMPTY
                          npm ERR! syscall rename
                          npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                          npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                          npm ERR! errno -39
                          npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                          npm ERR!     /home/iobroker/.npm/_logs/2023-02-24T14_10_51_991Z-debug-0.log
                          host.raspberrypi Cannot install iobroker.javascript@7.0.1: 217
                            Homoran Global Moderator Administrators @werner2000x last edited by
                            @werner2000x sagte in Problem beim Update von Adaptern/Modulen/Controller:
                            warum?
                            dann geht natürlich kein upgrade mehr
                              217
                              • werner2000x
                                werner2000x @Homoran last edited by werner2000x
                                @homoran Ich habe ihn deinstalliert weil er immer Rot in den instancen war.
                                  NPM version: 9.5.0
                                  Von Hand dran herumgefummelt.
                                  NICHT machen.
                                  nodejs (inkl. npm) neuinstallieren.
                                  Beta-Software:
                                  javascript@7.0.1
                                  Ich denke im Beta-Repository bist du vollkommen falsch aufgehoben.
                                    warum fummelt man an der Installation rum während andere versuchen zu helfen?
                                    Der Wissensstand der helfenden ist damit ständig veraltet.
                                    https://forum.iobroker.net/post/884324
                                    • werner2000x
                                      @homoran Ja, ich war etwas voreilig. Kann man denn trotzdem noch was retten obwohl kein javascript adapter mehr da ist?
                                        @werner2000x
                                        Frische Ausgabe von
                                        iob diag
                                        bereitstellen, dann nix mehr fummeln.
                                        • werner2000x
                                          werner2000x last edited by wendy2702
                                          @thomas-braun Leider ist das Problem damit nicht gelöst. Es fehlt immer noch der javascipt Adapter s. Logfile.
                                          log.txt
                                          *** ioBroker Diagnosis ***
                                          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                                          Just copy and paste the Summary Page, including the ``` characters at start and end.
                                          It helps us to help you!
                                          Press any key to continue
                                          Skript v.2023-01-02
                                          *** BASE SYSTEM ***
                                          Docker: 	false
                                          Release:	10
                                          Codename:	buster
                                          VERSION_ID="10"
                                          ID=raspbian
                                          ID_LIKE=debian
                                           16:15:22 up  1:46,  3 users,  load average: 2.10, 1.83, 1.65
                                          CPU threads: 4
                                          Fri Feb 24 15:15:22 UTC 2023
                                          Fri Feb 24 16:15:22 CET 2023
                                          CET +0100
                                          Europe/Berlin
                                          pi
                                          /home/pi
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          Boot Target: 	graphical.target
                                          *** MEMORY ***
                                          Mem:           7.9G        1.5G        4.6G         17M        1.8G        6.5G
                                          Swap:           99M          0B         99M
                                          Total:         8.0G        1.5G        4.7G
                                                   7898 M total memory
                                                   1494 M used memory
                                                    535 M active memory
                                                   2581 M inactive memory
                                                   4559 M free memory
                                                    193 M buffer memory
                                                   1651 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          *** FILESYSTEM ***
                                          /dev/root      ext4      117G   21G   92G  18% /
                                          tmpfs          tmpfs     3.9G   18M  3.9G   1% /run
                                          Messages in dmesg:
                                          [Fri Feb 24 14:29:05 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:C4:F8:86 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a7cf6190-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                          [Fri Feb 24 14:29:06 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                          [Fri Feb 24 14:29:06 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Fri Feb 24 14:29:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                          /var:
                                          4.3G	/var/
                                          2.9G	/var/cache/apt
                                          2.9G	/var/cache
                                          729M	/var/log
                                          557M	/opt/iobroker/iobroker-data/files
                                          34M	/opt/iobroker/iobroker-data/objects.jsonl
                                          23M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.f59a8c63.js.map
                                          /usr/bin/npm 		9.5.1
                                          /usr/bin/npx 		9.5.1
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin: 		6.3.5
                                          Adapters from github: 	0
                                          Adapter State
                                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                            system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
                                          + instance is alive
                                          Adapter    "admin"        : 6.3.6    , installed 6.3.5  [Updatable]
                                          Adapter    "backitup"     : 2.6.2    , installed 2.5.12 [Updatable]
                                          Objects and States
                                          MOD EDIT: LOG FILE AUS TEXT FILE IN CODE TAGS </> GESETZT
                                          • wendy2702
                                            wendy2702 @werner2000x last edited by
                                            buster
                                            Ich weiss schon was @Thomas-Braun sagt 😉
                                            Buster ist tod... installiere Bullseye neu
                                            /usr/bin/npm 9.5.1
                                            /usr/bin/npx 9.5.1
                                            Installiere Node und NPM Sauber, wie das geht steht in der Signatur von Thomas.
                                            Kannst du dir allerdings sparen wenn du eh Bullseye und den iob per einzeiler neu installierst.
                                            Dann backup einspielen und alles ist wieder schick.
                                            1970
