    4. Test Adapter EnOcean v0.8.x
    • Jey Cee
      Jey Cee Developer @Wahl-HHer last edited by Jey Cee
      @wahl-hher was steht den im Log?
      Edit: Ich seh gerade das wohl nicht von Github sondern npm installiert wurde.
      W 2 Replies Last reply Reply Quote 0
        Wahl-HHer @Jey Cee last edited by
        @jey-cee
        2023-02-11 16:10:53.878 - warn: enocean.0 (2827) Got terminate signal. Checking desired PID: 0 vs own PID 2827
        2023-02-11 16:10:53.923 - info: host.RPi64 instance system.adapter.enocean.0 started with pid 3008
        2023-02-11 16:10:53.886 - info: enocean.0 (2827) cleaned everything up...
        2023-02-11 16:10:53.888 - info: enocean.0 (2827) terminating
        2023-02-11 16:10:53.890 - info: enocean.0 (2827) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2023-02-11 16:10:54.660 - warn: enocean.0 (2827) Error sending data: Error: Port is not open
        2023-02-11 16:10:54.663 - warn: enocean.0 (2827) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
        2023-02-11 16:10:54.664 - warn: enocean.0 (2827) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
        2023-02-11 16:10:54.665 - warn: enocean.0 (2827) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
        2023-02-11 16:10:54.666 - warn: enocean.0 (2827) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
        2023-02-11 16:10:54.668 - warn: enocean.0 (2827) An error occured at serial port: Error: Port is not open
        2023-02-11 16:10:54.669 - info: enocean.0 (2827) The serial port was closed.
        2023-02-11 16:10:55.395 - info: enocean.0 (2827) The serial port was closed.
        2023-02-11 16:10:55.410 - warn: enocean.0 (2827) Got terminate signal. Checking desired PID: 3008 vs own PID 2827
        2023-02-11 16:10:55.433 - warn: enocean.0 (2827) get state error: DB closed
        2023-02-11 16:10:55.436 - warn: enocean.0 (2827) get state error: Connection is closed.
        2023-02-11 16:10:55.468 - warn: enocean.0 (2827) get state error: Connection is closed.
        2023-02-11 16:10:55.811 - error: host.RPi64 instance system.adapter.enocean.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        2023-02-11 16:10:55.812 - info: host.RPi64 Do not restart adapter system.adapter.enocean.0 because desired by instance
        2023-02-11 16:10:56.660 - debug: enocean.0 (3008) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2023-02-11 16:10:56.727 - debug: enocean.0 (3008) Objects client ready ... initialize now
        2023-02-11 16:10:56.730 - debug: enocean.0 (3008) Objects create System PubSub Client
        2023-02-11 16:10:56.731 - debug: enocean.0 (3008) Objects create User PubSub Client
        2023-02-11 16:10:56.903 - debug: enocean.0 (3008) Objects client initialize lua scripts
        2023-02-11 16:10:56.957 - debug: enocean.0 (3008) Objects connected to redis: 0.0.0.0:9001
        2023-02-11 16:10:57.016 - debug: enocean.0 (3008) Redis States: Use Redis connection: 0.0.0.0:9000
        2023-02-11 16:10:57.051 - debug: enocean.0 (3008) States create System PubSub Client
        2023-02-11 16:10:57.053 - debug: enocean.0 (3008) States create User PubSub Client
        2023-02-11 16:10:57.153 - debug: enocean.0 (3008) States connected to redis: 0.0.0.0:9000
        2023-02-11 16:10:57.720 - info: enocean.0 (3008) starting. Version 0.8.4 (non-npm: jey-cee/ioBroker.enocean) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.0, js-controller: 4.0.24
        2023-02-11 16:10:59.586 - error: enocean.0 (3008) Timeout for response: Get version information
        2023-02-11 16:11:01.088 - error: enocean.0 (3008) Timeout for response: Get repeater mode and level
        2023-02-11 16:11:02.590 - error: enocean.0 (3008) Timeout for response: Get frequency
        2023-02-11 16:11:04.091 - error: enocean.0 (3008) Timeout for response: Get base ID
        2023-02-11 16:11:05.601 - error: enocean.0 (3008) Timeout for response: Read learnd devices
        2023-02-11 16:11:05.602 - info: enocean.0 (3008) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
          Wahl-HHer @Jey Cee last edited by Wahl-HHer
          Ah mein Fehler. Jetzt startet die Instanz. Ich musste den Raspi neu aufsetzen und hatte vergessen Bluetooth zu deaktieren und den Serial Port zu aktivieren.
          Supportinformationen:
          "nodeVersion": "v16.19.0",
          "serialDevices": [
          "/dev/ttyACM0",
          "/dev/ttyAMA0",
          "/dev/serial/by-id/usb-0658_0200-if00"
          "instance": {
          "native": {
          "serialport": "/dev/ttyAMA0",
          "ser2net": false,
          "ser2net-ip": "",
          "ser2net-port": "",
          "esp2Switch": false,
          "gateway": "usb300",
          "device-id": "",
          "device-name": ""
          "version": "0.8.4",
          "installedFrom": "jey-cee/ioBroker.enocean"
          "devices": [
          "_id": "enocean.0.gateway",
          "native": {
          "BaseID": "ffc32880",
          "AppVersion": "2.11.1.0",
          "ApiVersion": "2.6.3.0",
          "ChipID": "05008651",
          "ChipVersion": "454f0103",
          "AppDescription": "GATEWAYCTRL",
          "senderIDs": {
          "ffc32881": "",
          "ffc32882": "",
          "ffc32883": "",
          "ffc32884": "",
          "ffc32885": "",
          "ffc32886": "",
          "ffc32887": "",
          "ffc32888": "",
          "ffc32889": "",
          "ffc3288a": "",
          "ffc3288b": "",
          "ffc3288c": "",
          "ffc3288d": "",
          "ffc3288e": "",
          "ffc3288f": "",
          "ffc32890": "",
          "ffc32891": "",
          "ffc32892": "",
          "ffc32893": "",
          "ffc32894": "",
          "ffc32895": "",
          "ffc32896": "",
          "ffc32897": "",
          "ffc32898": "",
          "ffc32899": "",
          "ffc3289a": "",
          "ffc3289b": "",
          "ffc3289c": "",
          "ffc3289d": "",
          "ffc3289e": "",
          "ffc3289f": "",
          "ffc328a0": "",
          "ffc328a1": "",
          "ffc328a2": "",
          "ffc328a3": "",
          "ffc328a4": "",
          "ffc328a5": "",
          "ffc328a6": "",
          "ffc328a7": "",
          "ffc328a8": "",
          "ffc328a9": "",
          "ffc328aa": "",
          "ffc328ab": "",
          "ffc328ac": "",
          "ffc328ad": "",
          "ffc328ae": "",
          "ffc328af": "",
          "ffc328b0": "",
          "ffc328b1": "",
          "ffc328b2": "",
          "ffc328b3": "",
          "ffc328b4": "",
          "ffc328b5": "",
          "ffc328b6": "",
          "ffc328b7": "",
          "ffc328b8": "",
          "ffc328b9": "",
          "ffc328ba": "",
          "ffc328bb": "",
          "ffc328bc": "",
          "ffc328bd": "",
          "ffc328be": "",
          "ffc328bf": "",
          "ffc328c0": "",
          "ffc328c1": "",
          "ffc328c2": "",
          "ffc328c3": "",
          "ffc328c4": "",
          "ffc328c5": "",
          "ffc328c6": "",
          "ffc328c7": "",
          "ffc328c8": "",
          "ffc328c9": "",
          "ffc328ca": "",
          "ffc328cb": "",
          "ffc328cc": "",
          "ffc328cd": "",
          "ffc328ce": "",
          "ffc328cf": "",
          "ffc328d0": "",
          "ffc328d1": "",
          "ffc328d2": "",
          "ffc328d3": "",
          "ffc328d4": "",
          "ffc328d5": "",
          "ffc328d6": "",
          "ffc328d7": "",
          "ffc328d8": "",
          "ffc328d9": "",
          "ffc328da": "",
          "ffc328db": "",
          "ffc328dc": "",
          "ffc328dd": "",
          "ffc328de": "",
          "ffc328df": "",
          "ffc328e0": "",
          "ffc328e1": "",
          "ffc328e2": "",
          "ffc328e3": "",
          "ffc328e4": "",
          "ffc328e5": "",
          "ffc328e6": "",
          "ffc328e7": "",
          "ffc328e8": "",
          "ffc328e9": "",
          "ffc328ea": "",
          "ffc328eb": "",
          "ffc328ec": "",
          "ffc328ed": "",
          "ffc328ee": "",
          "ffc328ef": "",
          "ffc328f0": "",
          "ffc328f1": "",
          "ffc328f2": "",
          "ffc328f3": "",
          "ffc328f4": "",
          "ffc328f5": "",
          "ffc328f6": "",
          "ffc328f7": "",
          "ffc328f8": "",
          "ffc328f9": "",
          "ffc328fa": "",
          "ffc328fb": "",
          "ffc328fc": "",
          "ffc328fd": "",
          "ffc328fe": ""
          "native": {
          "id": "0509fe78",
          "eep": [
          "D2-01-09"
          "manufacturer": "PERMUNDO_GMBH"
          "_id": "enocean.0.0509fe78"
          Der Afriso APR 234 funktioniert aber trotzdem noch nicht richtig.
          Kommunikation besteht nur kurz und auch nur unidirektional.
          Wenn ich am Stecker schalte, ändert sich der Punkt "OV" von 0 auf 100 bzw. von 100 auf 0.
          • Jey Cee
            @wahl-hher das Log vom Anlernvorgang wäre interessant.
            @wahl-hher sagte in Test Adapter EnOcean v0.8.x:
            Wie darf ich das verstehen? Der Aktor sendet nicht Regelmäßig sondern nur bei Änderungen bzw. wenn bestimmte Werteschwellen überschritten wurden.
              @jey-cee
              Log: (es geht um die ID 0509fe78)
              2023-02-12 00:42:23.298 - debug: enocean.0 (13518) 55000a0701eba5000807090509fe600001ffffffff2900
              2023-02-12 00:42:23.301 - debug: enocean.0 (13518) Message for ID 0509fe60 has been received. It was repeated 0 times.
              2023-02-12 00:42:26.215 - info: enocean.0 (13518) ["/dev/ttyACM0","/dev/ttyAMA0","/dev/serial/by-id/usb-0658_0200-if00"]
              2023-02-12 00:43:44.672 - info: enocean.0 (13518) ["/dev/ttyACM0","/dev/ttyAMA0","/dev/serial/by-id/usb-0658_0200-if00"]
              2023-02-12 00:44:23.864 - debug: enocean.0 (13518) 550009070156d20460800509fe780001ffffffff3500
              2023-02-12 00:44:23.866 - debug: enocean.0 (13518) Message for ID 0509fe78 has been received. It was repeated 0 times.
              2023-02-12 00:45:06.550 - debug: enocean.0 (13518) 55000d0701fdd4a0ff33000901d20509fe780001ffffffff3200
              2023-02-12 00:45:06.803 - debug: enocean.0 (13518) teachinMethod: UTE from ID "0509fe78"
              2023-02-12 00:45:06.812 - info: enocean.0 (13518) Create objects for D2-01-09 from PERMUNDO_GMBH with id: 0509fe78
              2023-02-12 00:45:06.813 - debug: enocean.0 (13518) Sent data: 55000e070140d491025530000901d2ffc3288000010509fe78ff00a3
              2023-02-12 00:45:06.818 - debug: enocean.0 (13518) Sent data: 55000e070140d491025530000901d2ffc3288000010509fe78ff00a3
              2023-02-12 00:45:06.822 - debug: enocean.0 (13518) 55000100026500
              2023-02-12 00:45:06.823 - debug: enocean.0 (13518) Packet type 2 received: {"code":"OK"}
              2023-02-12 00:45:06.833 - debug: enocean.0 (13518) 55000100026500
              2023-02-12 00:45:06.834 - debug: enocean.0 (13518) Packet type 2 received: {"code":"OK"}
              2023-02-12 00:47:44.394 - debug: enocean.0 (13518) 55000a0701eba50000000c0509fe600001ffffffff3400
              2023-02-12 00:47:44.396 - debug: enocean.0 (13518) Message for ID 0509fe60 has been received. It was repeated 0 times.
              2023-02-12 00:48:08.494 - debug: enocean.0 (13518) 550009070156d20460800509fe780001ffffffff3500
              2023-02-12 00:48:08.496 - debug: enocean.0 (13518) Message for ID 0509fe78 has been received. It was repeated 0 times.
              2023-02-12 00:48:12.675 - debug: enocean.0 (13518) 550009070156d20460e40509fe780001ffffffff3400
              2023-02-12 00:48:12.677 - debug: enocean.0 (13518) Message for ID 0509fe78 has been received. It was repeated 0 times.
              2023-02-12 00:48:15.788 - debug: enocean.0 (13518) 550009070156d20460800509fe780001ffffffff3400
              2023-02-12 00:48:15.792 - debug: enocean.0 (13518) Message for ID 0509fe78 has been received. It was repeated 0 times.
              2023-02-12 00:48:51.368 - debug: enocean.0 (13518) 55000a0701eba57a02200805193d660001ffffffff4400
              2023-02-12 00:48:51.370 - debug: enocean.0 (13518) Message for ID 05193d66 has been received. It was repeated 0 times.
              2023-02-12 00:48:53.836 - debug: enocean.0 (13518) 55000c070196d20720000001330509bff00001ffffffff3100
              2023-02-12 00:48:53.839 - debug: enocean.0 (13518) Message for ID 0509bff0 has been received. It was repeated 0 times.
              2023-02-12 00:49:04.263 - debug: enocean.0 (13518) 55000a0701eba500f0540f059a08200001ffffffff4600
              2023-02-12 00:49:04.284 - debug: enocean.0 (13518) Message for ID 059a0820 has been received. It was repeated 0 times.
              @jey-cee sagte in Test Adapter EnOcean v0.8.x:
              Ich hatte den Eindruck, dass ich erst noch Änderungen am Attribut "OV" sehen kann, wenn ich direkt am Gerät schalte, und nach ein paar Minuten dann nicht mehr.
              Aber das kann ich jetzt nicht mehr nachstellen.
              Fest steht: Ich bekomme beim Anlernen nur 1x grünes Blinken, nicht 2x. Daher nur unidirektionale Kommunikation vom Aktor zum Enocean-Gateway. Befehle kann ich nicht senden.
              • Jey Cee
                @wahl-hher hab den Fehler gefunden. Fix ist auf Github, einfach drüber installieren.
                  @jey-cee
                  Erster kurzer Test:
                  Ich kann das Gerät jetzt zwar ausschalten, aber nicht wieder einschalten.
                  Mehr Infos und ein Log kann ich bestimmt heute Abend liefern.
                    @jey-cee
                    Also ich habe das Gerät jetzt mal in den Objekten gelöscht. Dann auf die Werkseinstellungen zurückgesetzt und neu angelernt.
                    Hier das Log dazu:
                    2023-02-13 16:28:02.578 - debug: enocean.0 (76937) 55000a0701eba56d021d0805193d7a0001ffffffff3100
                    2023-02-13 16:28:02.590 - debug: enocean.0 (76937) Message for ID 05193d7a has been received. It was repeated 0 times.
                    2023-02-13 16:28:03.691 - info: enocean.0 (76937) ["/dev/ttyACM0","/dev/ttyAMA0","/dev/serial/by-id/usb-0658_0200-if00"]
                    2023-02-13 16:28:11.314 - debug: enocean.0 (76937) 55000a0701eba56e021f08051947f50001ffffffff2d00
                    2023-02-13 16:28:11.316 - debug: enocean.0 (76937) Message for ID 051947f5 has been received. It was repeated 0 times.
                    2023-02-13 16:28:21.127 - debug: enocean.0 (76937) 55000d0701fdd4a0ff33000901d20509fe780001ffffffff2d00
                    2023-02-13 16:28:21.377 - debug: enocean.0 (76937) teachinMethod: UTE from ID "0509fe78"
                    2023-02-13 16:28:21.386 - info: enocean.0 (76937) Create objects for D2-01-09 from PERMUNDO_GMBH with id: 0509fe78
                    2023-02-13 16:28:21.388 - debug: enocean.0 (76937) Sent data: 55000d0701fdd491ff33000901d2ffc3288000010509fe78ff00c4
                    2023-02-13 16:28:21.389 - debug: enocean.0 (76937) Sent data: 55000d0701fdd491ff33000901d2ffc3288000010509fe78ff00c4
                    2023-02-13 16:28:21.396 - debug: enocean.0 (76937) 55000100026500
                    2023-02-13 16:28:21.397 - debug: enocean.0 (76937) Packet type 2 received: {"code":"OK"}
                    2023-02-13 16:28:21.404 - debug: enocean.0 (76937) 55000100026500
                    2023-02-13 16:28:21.405 - debug: enocean.0 (76937) Packet type 2 received: {"code":"OK"}
                    2023-02-13 16:28:27.419 - debug: enocean.0 (76937) 55000d0701fdd4a0ff33000901d20509fe780001ffffffff2d00
                    2023-02-13 16:28:27.467 - debug: enocean.0 (76937) Message for ID 0509fe78 has been received. It was repeated 0 times.
                    2023-02-13 16:28:33.233 - debug: enocean.0 (76937) 55000d0701fdd4a0ff33000901d20509fe780001ffffffff2d00
                    2023-02-13 16:28:33.462 - debug: enocean.0 (76937) Message for ID 0509fe78 has been received. It was repeated 0 times.
                    2023-02-13 16:28:34.262 - debug: enocean.0 (76937) 55000a0701eba5480833800509fe780001ffffffff2d00
                    2023-02-13 16:28:34.265 - debug: enocean.0 (76937) Message for ID 0509fe78 has been received. It was repeated 0 times.
                    Wie ich schon schrieb, kann ich das Gerät zwar ausschalten, aber nicht einschalten.
                    Das Log dazu hier: (ID:0509fe78)
                    2023-02-13 16:31:06.538 - debug: enocean.0 (76937) 550009070156d20460e40509fe780001ffffffff2d00
                    2023-02-13 16:31:06.539 - debug: enocean.0 (76937) Message for ID 0509fe78 has been received. It was repeated 0 times.
                    2023-02-13 16:31:20.835 - debug: enocean.0 (76937) state 0509fe78.CMD changed: 0 (ack = false) state: {"val":0,"ack":false,"ts":1676302280828,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1676302280828}
                    2023-02-13 16:31:20.873 - debug: enocean.0 (76937) Sent data: 550009070156d2010000ffc3288000000509fe78ff0086
                    2023-02-13 16:31:20.882 - debug: enocean.0 (76937) 55000100026500
                    2023-02-13 16:31:20.883 - debug: enocean.0 (76937) Packet type 2 received: {"code":"OK"}
                    2023-02-13 16:31:20.997 - debug: enocean.0 (76937) 550009070156d20460800509fe780001ffffffff2900
                    2023-02-13 16:31:21.000 - debug: enocean.0 (76937) Message for ID 0509fe78 has been received. It was repeated 0 times.
                    2023-02-13 16:31:27.815 - debug: enocean.0 (76937) 55000a0701eba56f02210805193d660001ffffffff3400
                    2023-02-13 16:31:27.816 - debug: enocean.0 (76937) Message for ID 05193d66 has been received. It was repeated 0 times.
                    Leistungsmessung funktioniert auch.
                      RoGo @Jey Cee last edited by
                      @jey-cee Ich hatte leider jetzt erst wieder Zeit zum Testen.
                      Vielen Dank für das Update. Es funktioniert jetzt, dass mehrere Geräte angelernt werden können. Beim Testen ist mir dann auch wieder eingefallen, dass es ja nicht nur um das Anlernen geht, da ich per PCT 14 alle Geräte schon mit der Sender ID versehen hatte. Es war also auch das Problem beim Senden anderer Befehle.
                      Noch als Info an @Black-Raven :
                      Da die Sender ID jetzt fortlaufend in Hex zählt (was der Adapter in meiner Alt-Installation eben auch gemacht hat), das aber zuvor in einer neuen Installation nicht der Fall war, müssen die SenderIDs im Eltako ggf. angepasst werden. Also nur Updaten und die Geräte in alter Reihenfolge neu anlegen könnte erstmal zu funktionsverlusten im Haus führen ☺ .
                        Black-Raven @RoGo last edited by
                        @rogo So jetzt bin ich auch mal wieder zum probieren gekommen. Jetzt kann ich mehrere Teilnehmer einlernen. Jetzt bin ich wieder bei dem Problem mit den fehlenden Rückmeldungen der Aktoren. In der PCT 14 hinterlässt der Einlernprozess den erwarteten Eintrag der Adresse. Muss nacher noch mal bissel rumprobieren.
                          Black-Raven @Black-Raven last edited by
                          @black-raven Sorry, sorry, Fehler meinerseits. Jetzt läufts. Hab jetzt mal 10 Geräte zum Testen eingelernt ohne Probleme
                            Black-Raven @Jey Cee last edited by
                            @jey-cee So aktueller Stand bei mir. Ich hab jetzt diese Woche genutzt und meine ganze Bude auf ioBroker umgestellt. Der Bus läuft prima, alles stabil. Aktuell verwaltet dein Adapter also 40 Ausgänge und 90 Eingänge über die FTS14EM. Klasse Arbeit. Vielen lieben Dank.
                            Jey Cee B 2 Replies Last reply Reply Quote 0
                            • Jey Cee
                              Jey Cee Developer @Black-Raven last edited by
                              @black-raven freut mich das es stabil läuft.
                                ares44 @Jey Cee last edited by
                                @jey-cee Laut log soll es ja schon die Version 0.8.5 seit 2023-02-11. Wie ist denn der "normale" Weg das update zu erhalten?
                                • Jey Cee
                                  Jey Cee Developer @ares44 last edited by
                                  @ares44 sagte in Test Adapter EnOcean v0.8.x:
                                  Warten bis es angezeigt wird.
                                  T A 2 Replies Last reply Reply Quote 0
                                    TimoWald @Jey Cee last edited by
                                    @jey-cee hallo, ich bekomme meinen USB300 auch nicht grün. Woran liegt es bei mir?
                                    Version 0.8.5 ist installiert.
                                    2023-03-28 17:15:10.250 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                    2023-03-28 17:15:10.256 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2023-03-28 17:15:10.258 - info: host.raspberrypi hostname: raspberrypi, node: v16.19.1
                                    2023-03-28 17:15:10.259 - info: host.raspberrypi ip addresses: 192.168.9.166 2003:e1:ef09:2800:7e02:d79a:15c2:6ccb fe80::66bf:f25a:da47:f65f
                                    2023-03-28 17:15:10.669 - info: host.raspberrypi connected to Objects and States
                                    2023-03-28 17:15:10.697 - info: host.raspberrypi Node.js version has changed from unknown to 16.19.1
                                    2023-03-28 17:15:10.768 - info: host.raspberrypi added notifications configuration of host
                                    2023-03-28 17:15:11.300 - info: host.raspberrypi Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                    2023-03-28 17:15:11.334 - info: host.raspberrypi 3 instances found
                                    2023-03-28 17:15:11.344 - info: host.raspberrypi starting 3 instances
                                    2023-03-28 17:15:11.411 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 6846
                                    2023-03-28 17:15:13.842 - info: admin.0 (6846) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:15:13.906 - info: admin.0 (6846) requesting all states
                                    2023-03-28 17:15:13.907 - info: admin.0 (6846) requesting all objects
                                    2023-03-28 17:15:14.023 - info: admin.0 (6846) received all objects
                                    2023-03-28 17:15:14.292 - info: admin.0 (6846) http server listening on port 8081
                                    2023-03-28 17:15:14.292 - info: admin.0 (6846) Use link "http://localhost:8081" to configure.
                                    2023-03-28 17:15:14.301 - info: admin.0 (6846) socket.io server listening on port 8081
                                    2023-03-28 17:15:14.384 - warn: admin.0 (6846) Repository cannot be read: Active repo - stable
                                    2023-03-28 17:15:14.386 - warn: admin.0 (6846) Active repository "stable" cannot be read
                                    2023-03-28 17:15:15.379 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 6873
                                    2023-03-28 17:15:17.203 - info: discovery.0 (6873) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:15:19.400 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 6888
                                    2023-03-28 17:15:21.335 - info: backitup.0 (6888) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:16:04.837 - info: backitup.0 (6888) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2023-03-28 17:23:07.582 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:23:07.693 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                    2023-03-28 17:26:04.944 - info: host.raspberrypi iobroker url https://github.com/Jey-Cee/ioBroker.enocean.git --host raspberrypi --debug
                                    2023-03-28 17:26:07.469 - info: host.raspberrypi iobroker install Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a
                                    2023-03-28 17:26:08.464 - info: host.raspberrypi iobroker NPM version: 8.19.3
                                    2023-03-28 17:26:08.467 - info: host.raspberrypi iobroker Installing Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a... (System call)
                                    2023-03-28 17:28:12.153 - info: host.raspberrypi iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/Jey-Cee/ioBroker.enocean.git
                                    2023-03-28 17:29:40.588 - info: host.raspberrypi iobroker
                                    2023-03-28 17:29:40.590 - info: host.raspberrypi iobroker added 21 packages in 4m
                                    2023-03-28 17:29:40.593 - info: host.raspberrypi iobroker 48 packages are looking for funding
                                    2023-03-28 17:29:40.597 - info: host.raspberrypi iobroker run `npm fund` for details
                                    2023-03-28 17:29:40.700 - info: host.raspberrypi iobroker upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/admin.d.ts admin.d.ts video/mp2t
                                    2023-03-28 17:30:06.380 - info: host.raspberrypi iobroker upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/components.js components.js application/javascript
                                    2023-03-28 17:30:07.708 - info: host.raspberrypi iobroker upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/enocean.png enocean.png image/png
                                    2023-03-28 17:30:07.719 - info: host.raspberrypi iobroker upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/github.js github.js application/javascript
                                    2023-03-28 17:30:07.733 - info: host.raspberrypi iobroker upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
                                    2023-03-28 17:30:07.745 - info: host.raspberrypi iobroker upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/style.css style.css text/css
                                    2023-03-28 17:30:07.755 - info: host.raspberrypi iobroker upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
                                    2023-03-28 17:30:08.822 - info: host.raspberrypi iobroker exit 0
                                    2023-03-28 17:32:31.388 - info: host.raspberrypi iobroker add enocean auto --host raspberrypi --debug
                                    2023-03-28 17:32:34.135 - info: host.raspberrypi iobroker host.raspberrypi create instance enocean
                                    2023-03-28 17:32:34.152 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.alive created
                                    2023-03-28 17:32:34.163 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.connected created
                                    2023-03-28 17:32:34.172 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.compactMode created
                                    2023-03-28 17:32:34.181 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.cpu created
                                    2023-03-28 17:32:34.189 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.cputime created
                                    2023-03-28 17:32:34.196 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.memHeapUsed created
                                    2023-03-28 17:32:34.204 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.memHeapTotal created
                                    2023-03-28 17:32:34.212 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.memRss created
                                    2023-03-28 17:32:34.220 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.uptime created
                                    2023-03-28 17:32:34.228 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.inputCount created
                                    2023-03-28 17:32:34.235 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.outputCount created
                                    2023-03-28 17:32:34.245 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.eventLoopLag created
                                    2023-03-28 17:32:34.252 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.sigKill created
                                    2023-03-28 17:32:34.264 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0.logLevel created
                                    2023-03-28 17:32:34.270 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.info created
                                    2023-03-28 17:32:34.276 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.info.connection created
                                    2023-03-28 17:32:34.282 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway created
                                    2023-03-28 17:32:34.288 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.teachin created
                                    2023-03-28 17:32:34.294 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.lastID created
                                    2023-03-28 17:32:34.300 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.repeater created
                                    2023-03-28 17:32:34.307 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.repeater.mode created
                                    2023-03-28 17:32:34.312 - info: host.raspberrypi iobroker host.raspberrypi object enocean.0.gateway.repeater.level created
                                    2023-03-28 17:32:34.318 - info: host.raspberrypi iobroker host.raspberrypi Set default value of enocean.0.info.connection: false
                                    2023-03-28 17:32:34.328 - info: host.raspberrypi iobroker host.raspberrypi Set default value of enocean.0.gateway.teachin: false
                                    2023-03-28 17:32:34.344 - info: host.raspberrypi iobroker host.raspberrypi object system.adapter.enocean.0 created
                                    2023-03-28 17:32:35.372 - info: host.raspberrypi iobroker exit 0
                                    2023-03-28 17:32:36.844 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:32:37.379 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7145
                                    2023-03-28 17:32:39.229 - info: enocean.0 (7145) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:33:25.115 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:33:25.126 - info: enocean.0 (7145) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:33:25.131 - info: enocean.0 (7145) cleaned everything up...
                                    2023-03-28 17:33:25.134 - info: enocean.0 (7145) terminating
                                    2023-03-28 17:33:25.137 - info: enocean.0 (7145) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:33:25.162 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:33:25.725 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-03-28 17:33:28.191 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7161
                                    2023-03-28 17:33:30.013 - info: enocean.0 (7161) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:33:33.615 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:33:40.765 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:33:40.852 - info: enocean.0 (7161) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:33:46.872 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:33:46.877 - info: enocean.0 (7161) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:33:46.880 - info: enocean.0 (7161) cleaned everything up...
                                    2023-03-28 17:33:46.881 - info: enocean.0 (7161) terminating
                                    2023-03-28 17:33:46.883 - info: enocean.0 (7161) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:33:46.917 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:33:47.424 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-03-28 17:33:49.942 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7177
                                    2023-03-28 17:33:51.721 - info: enocean.0 (7177) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:33:53.539 - error: enocean.0 (7177) Timeout for response: Get version information
                                    2023-03-28 17:33:55.068 - error: enocean.0 (7177) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:33:56.575 - error: enocean.0 (7177) Timeout for response: Get frequency
                                    2023-03-28 17:33:58.076 - error: enocean.0 (7177) Timeout for response: Get base ID
                                    2023-03-28 17:33:59.646 - error: enocean.0 (7177) Timeout for response: Read learnd devices
                                    2023-03-28 17:33:59.652 - info: enocean.0 (7177) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:34:02.059 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:34:05.620 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:34:05.692 - info: enocean.0 (7177) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:35:52.958 - info: enocean.0 (7177) Create objects for A5-14-01 from WINKHAUS with id: 059565A8
                                    2023-03-28 17:36:03.833 - info: enocean.0 (7177) Create objects for A5-14-01 from WINKHAUS with id: 059565A8
                                    2023-03-28 17:36:37.245 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:36:41.591 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:36:41.667 - info: enocean.0 (7177) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:37:23.001 - info: enocean.0 (7177) Create objects for A5-14-0A from WINKHAUS with id: 059565A8
                                    2023-03-28 17:37:32.199 - info: enocean.0 (7177) Create objects for A5-14-0A from WINKHAUS with id: 059565A8
                                    2023-03-28 17:37:34.602 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:37:36.306 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:37:36.331 - info: enocean.0 (7177) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:37:36.355 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:37:37.358 - info: host.raspberrypi stopInstance system.adapter.enocean.0 killing pid 7177
                                    2023-03-28 17:37:36.346 - info: enocean.0 (7177) cleaned everything up...
                                    2023-03-28 17:37:36.347 - info: enocean.0 (7177) terminating
                                    2023-03-28 17:37:36.348 - info: enocean.0 (7177) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:37:39.395 - warn: enocean.0 (7177) Error sending data: Error: Port is not open
                                    2023-03-28 17:37:39.400 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:37:39.401 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:37:39.403 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:37:39.404 - warn: enocean.0 (7177) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:37:39.406 - warn: enocean.0 (7177) An error occured at serial port: Error: Port is not open
                                    2023-03-28 17:37:39.407 - info: enocean.0 (7177) The serial port was closed.
                                    2023-03-28 17:37:39.413 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7266
                                    2023-03-28 17:37:39.412 - info: enocean.0 (7177) The serial port was closed.
                                    2023-03-28 17:37:39.743 - warn: enocean.0 (7177) Got terminate signal. Checking desired PID: 0 vs own PID 7177
                                    2023-03-28 17:37:39.748 - warn: enocean.0 (7177) Got terminate signal. Checking desired PID: 7266 vs own PID 7177
                                    2023-03-28 17:37:39.790 - warn: enocean.0 (7177) get state error: DB closed
                                    2023-03-28 17:37:39.792 - warn: enocean.0 (7177) get state error: DB closed
                                    2023-03-28 17:37:39.827 - warn: enocean.0 (7177) get state error: Connection is closed.
                                    2023-03-28 17:37:40.290 - error: host.raspberrypi instance system.adapter.enocean.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2023-03-28 17:37:40.293 - info: host.raspberrypi Do not restart adapter system.adapter.enocean.0 because desired by instance
                                    2023-03-28 17:37:43.424 - info: enocean.0 (7266) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:37:45.362 - error: enocean.0 (7266) Timeout for response: Get version information
                                    2023-03-28 17:37:46.864 - error: enocean.0 (7266) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:37:48.366 - error: enocean.0 (7266) Timeout for response: Get frequency
                                    2023-03-28 17:37:49.869 - error: enocean.0 (7266) Timeout for response: Get base ID
                                    2023-03-28 17:37:51.370 - error: enocean.0 (7266) Timeout for response: Read learnd devices
                                    2023-03-28 17:37:51.371 - info: enocean.0 (7266) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:39:25.468 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:39:25.564 - info: enocean.0 (7266) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:40:17.980 - info: admin.0 (6846) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:41:02.791 - info: admin.0 (6846) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:41:02.877 - info: enocean.0 (7266) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:43:06.011 - error: host.raspberrypi Caught by controller[0]: <--- Last few GCs --->
                                    2023-03-28 17:43:06.013 - error: host.raspberrypi Caught by controller[0]: [7266:0x4244cc20] 322568 ms: Scavenge 919.9 (939.2) -> 918.5 (939.2) MB, 2.7 / 0.0 ms (average mu = 0.275, current mu = 0.331) task
                                    2023-03-28 17:43:06.013 - error: host.raspberrypi Caught by controller[0]: [7266:0x4244cc20] 322594 ms: Scavenge 920.0 (939.2) -> 918.5 (939.2) MB, 2.7 / 0.0 ms (average mu = 0.275, current mu = 0.331) task
                                    2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[0]: [7266:0x4244cc20] 322620 ms: Scavenge 920.1 (939.2) -> 918.6 (943.2) MB, 3.2 / 0.0 ms (average mu = 0.275, current mu = 0.331) task
                                    2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[0]: <--- JS stacktrace --->
                                    2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                    2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[1]: 1: 0xb00584 node::Abort() [io.enocean.0]
                                    2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[2]: 2: 0xa21604 void node::FPrintF<>(_IO_FILE*, char const*) [io.enocean.0]
                                    2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[3]: 3: 0xccfb50 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
                                    2023-03-28 17:43:06.014 - error: host.raspberrypi Caught by controller[4]: 4: 0xccfd20 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
                                    2023-03-28 17:43:06.015 - error: host.raspberrypi Caught by controller[5]: 5: 0xe8ba3c [io.enocean.0]
                                    2023-03-28 17:43:06.015 - error: host.raspberrypi Caught by controller[6]: 6: 0xe8c4c4 [io.enocean.0]
                                    2023-03-28 17:43:06.015 - error: host.raspberrypi Caught by controller[7]: 7: 0xe9a90c [io.enocean.0]
                                    2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[8]: 8: 0xe9b12c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.enocean.0]
                                    2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 9: 0xe9c178 v8::internal::Heap::FinalizeIncrementalMarkingIfComplete(v8::internal::GarbageCollectionReason) [io.enocean.0]
                                    2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 10: 0xe9f85c v8::internal::IncrementalMarkingJob::Task::RunInternal() [io.enocean.0]
                                    2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 11: 0xd99d38 non-virtual thunk to v8::internal::CancelableTask::Run() [io.enocean.0]
                                    2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 12: 0xb62824 [io.enocean.0]
                                    2023-03-28 17:43:06.016 - error: host.raspberrypi Caught by controller[9]: 13: 0xb65dc8 node::PerIsolatePlatformData::FlushForegroundTasksInternal() [io.enocean.0]
                                    2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[9]: 14: 0x14f8b74 [io.enocean.0]
                                    2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[9]: 15: 0x150abd8 [io.enocean.0]
                                    2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[9]: 16: 0x14f95b0 uv_run [io.enocean.0]
                                    2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[10]: 17: 0xa4a0ac node::SpinEventLoop(node::Environment*) [io.enocean.0]
                                    2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[11]: 18: 0xb3d340 node::NodeMainInstance::Run() [io.enocean.0]
                                    2023-03-28 17:43:06.017 - error: host.raspberrypi Caught by controller[11]: 19: 0xac7c78 node::Start(int, char**) [io.enocean.0]
                                    2023-03-28 17:43:06.018 - error: host.raspberrypi Caught by controller[11]: 20: 0x7fb8ec9e18 __libc_start_main [/lib/aarch64-linux-gnu/libc.so.6]
                                    2023-03-28 17:43:06.018 - error: host.raspberrypi Caught by controller[12]: 21: 0xa48724 [io.enocean.0]
                                    2023-03-28 17:43:06.018 - warn: host.raspberrypi instance system.adapter.enocean.0 terminated due to SIGABRT
                                    2023-03-28 17:43:06.018 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code NaN ()
                                    2023-03-28 17:43:06.018 - info: host.raspberrypi Restart adapter system.adapter.enocean.0 because enabled
                                    2023-03-28 17:43:36.084 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7291
                                    2023-03-28 17:43:37.916 - info: enocean.0 (7291) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:43:39.738 - error: enocean.0 (7291) Timeout for response: Get version information
                                    2023-03-28 17:43:41.240 - error: enocean.0 (7291) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:43:42.742 - error: enocean.0 (7291) Timeout for response: Get frequency
                                    2023-03-28 17:43:44.244 - error: enocean.0 (7291) Timeout for response: Get base ID
                                    2023-03-28 17:43:45.745 - error: enocean.0 (7291) Timeout for response: Read learnd devices
                                    2023-03-28 17:43:45.746 - info: enocean.0 (7291) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:48:56.116 - error: host.raspberrypi Caught by controller[0]: <--- Last few GCs --->
                                    2023-03-28 17:48:56.117 - error: host.raspberrypi Caught by controller[0]: [7291:0x360d6c20] 316116 ms: Scavenge 919.6 (938.7) -> 918.2 (938.9) MB, 2.9 / 0.0 ms (average mu = 0.228, current mu = 0.175) task
                                    2023-03-28 17:48:56.117 - error: host.raspberrypi Caught by controller[0]: [7291:0x360d6c20] 316141 ms: Scavenge 919.7 (938.9) -> 918.3 (938.9) MB, 2.7 / 0.0 ms (average mu = 0.228, current mu = 0.175) task
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[0]: [7291:0x360d6c20] 316168 ms: Scavenge 919.8 (938.9) -> 918.3 (942.9) MB, 3.2 / 0.0 ms (average mu = 0.228, current mu = 0.175) task
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[0]: <--- JS stacktrace --->
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[1]: 1: 0xb00584 node::Abort() [io.enocean.0]
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[2]: 2: 0xa21604 void node::FPrintF<>(_IO_FILE*, char const*) [io.enocean.0]
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[3]: 3: 0xccfb50 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[4]: 4: 0xccfd20 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.enocean.0]
                                    2023-03-28 17:48:56.118 - error: host.raspberrypi Caught by controller[5]: 5: 0xe8ba3c [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 6: 0xe8c4c4 [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 7: 0xe9a90c [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 8: 0xe9b12c v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 9: 0xe9c178 v8::internal::Heap::FinalizeIncrementalMarkingIfComplete(v8::internal::GarbageCollectionReason) [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[6]: 10: 0xe9f85c v8::internal::IncrementalMarkingJob::Task::RunInternal() [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[7]: 11: 0xd99d38 non-virtual thunk to v8::internal::CancelableTask::Run() [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[8]: 12: 0xb62824 [io.enocean.0]
                                    2023-03-28 17:48:56.119 - error: host.raspberrypi Caught by controller[9]: 13: 0xb65dc8 node::PerIsolatePlatformData::FlushForegroundTasksInternal() [io.enocean.0]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[10]: 14: 0x14f8b74 [io.enocean.0]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[11]: 15: 0x150abd8 [io.enocean.0]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[12]: 16: 0x14f95b0 uv_run [io.enocean.0]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[13]: 17: 0xa4a0ac node::SpinEventLoop(node::Environment*) [io.enocean.0]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[14]: 18: 0xb3d340 node::NodeMainInstance::Run() [io.enocean.0]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[15]: 19: 0xac7c78 node::Start(int, char**) [io.enocean.0]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[15]: 20: 0x7fb202fe18 __libc_start_main [/lib/aarch64-linux-gnu/libc.so.6]
                                    2023-03-28 17:48:56.120 - error: host.raspberrypi Caught by controller[16]: 21: 0xa48724 [io.enocean.0]
                                    2023-03-28 17:48:56.121 - warn: host.raspberrypi instance system.adapter.enocean.0 terminated due to SIGABRT
                                    2023-03-28 17:48:56.121 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code NaN ()
                                    2023-03-28 17:48:56.121 - info: host.raspberrypi Restart adapter system.adapter.enocean.0 because enabled
                                    2023-03-28 17:49:26.179 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 7391
                                    2023-03-28 17:49:28.893 - info: enocean.0 (7391) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:49:30.812 - error: enocean.0 (7391) Timeout for response: Get version information
                                    2023-03-28 17:49:32.314 - error: enocean.0 (7391) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:49:33.816 - error: enocean.0 (7391) Timeout for response: Get frequency
                                    2023-03-28 17:49:35.318 - error: enocean.0 (7391) Timeout for response: Get base ID
                                    2023-03-28 17:49:36.819 - error: enocean.0 (7391) Timeout for response: Read learnd devices
                                    2023-03-28 17:49:36.820 - info: enocean.0 (7391) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:49:40.783 - info: host.raspberrypi received SIGTERM
                                    2023-03-28 17:49:40.787 - info: backitup.0 (6888) cleaned everything up...
                                    2023-03-28 17:49:40.786 - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
                                    2023-03-28 17:49:40.788 - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
                                    2023-03-28 17:49:40.789 - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
                                    2023-03-28 17:49:40.790 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:49:40.789 - info: admin.0 (6846) terminating http server on port 8081
                                    2023-03-28 17:49:40.806 - info: enocean.0 (7391) cleaned everything up...
                                    2023-03-28 17:49:40.816 - info: backitup.0 (6888) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:49:40.821 - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
                                    2023-03-28 17:49:40.821 - info: backitup.0 (6888) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2023-03-28 17:49:40.823 - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
                                    2023-03-28 17:49:40.828 - info: admin.0 (6846) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:49:40.824 - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
                                    2023-03-28 17:49:40.824 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:49:40.846 - info: admin.0 (6846) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2023-03-28 17:49:40.955 - warn: enocean.0 (7391) Error sending data: Error: Port is not open
                                    2023-03-28 17:49:40.958 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:49:40.959 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:49:40.960 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:49:40.961 - warn: enocean.0 (7391) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:49:40.962 - warn: enocean.0 (7391) An error occured at serial port: Error: Port is not open
                                    2023-03-28 17:49:40.963 - info: enocean.0 (7391) The serial port was closed.
                                    2023-03-28 17:49:40.965 - info: enocean.0 (7391) The serial port was closed.
                                    2023-03-28 17:49:40.970 - info: enocean.0 (7391) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:49:41.018 - info: enocean.0 (7391) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2023-03-28 17:49:41.372 - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2023-03-28 17:49:41.567 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2023-03-28 17:49:41.823 - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 6846
                                    2023-03-28 17:49:41.824 - info: host.raspberrypi stopInstance system.adapter.discovery.0 killing pid 6873
                                    2023-03-28 17:49:42.749 - warn: host.raspberrypi instance system.adapter.discovery.0 terminated due to SIGTERM
                                    2023-03-28 17:49:42.749 - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code null ()
                                    2023-03-28 17:49:42.750 - info: host.raspberrypi All instances are stopped.
                                    2023-03-28 17:49:43.984 - warn: host.raspberrypi Cannot get view: Connection is closed.
                                    2023-03-28 17:49:43.986 - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2023-03-28 17:49:43.987 - info: host.raspberrypi All instances are stopped.
                                    2023-03-28 17:49:46.435 - info: host.raspberrypi terminated
                                    2023-03-28 17:50:01.860 - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                                    2023-03-28 17:50:01.867 - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                    2023-03-28 17:50:01.868 - info: host.raspberrypi hostname: raspberrypi, node: v16.19.1
                                    2023-03-28 17:50:01.869 - info: host.raspberrypi ip addresses: 2003:e1:ef09:2800:7e02:d79a:15c2:6ccb fe80::66bf:f25a:da47:f65f
                                    2023-03-28 17:50:14.561 - info: host.raspberrypi connected to Objects and States
                                    2023-03-28 17:50:14.635 - info: host.raspberrypi added notifications configuration of host
                                    2023-03-28 17:50:18.272 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
                                    2023-03-28 17:50:18.283 - info: host.raspberrypi 4 instances found
                                    2023-03-28 17:50:18.301 - info: host.raspberrypi starting 4 instances
                                    2023-03-28 17:50:19.732 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
                                    2023-03-28 17:50:19.768 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
                                    2023-03-28 17:50:19.798 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
                                    2023-03-28 17:50:19.831 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1091
                                    2023-03-28 17:50:19.848 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
                                    2023-03-28 17:50:19.914 - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
                                    2023-03-28 17:50:19.934 - info: host.raspberrypi Some obsolete host states deleted.
                                    2023-03-28 17:50:22.357 - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 1213
                                    2023-03-28 17:50:46.461 - info: admin.0 (1091) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:50:46.536 - info: admin.0 (1091) requesting all states
                                    2023-03-28 17:50:46.537 - info: admin.0 (1091) requesting all objects
                                    2023-03-28 17:50:47.168 - info: admin.0 (1091) received all objects
                                    2023-03-28 17:50:47.690 - info: discovery.0 (1213) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:50:47.786 - info: admin.0 (1091) http server listening on port 8081
                                    2023-03-28 17:50:47.788 - info: admin.0 (1091) Use link "http://localhost:8081" to configure.
                                    2023-03-28 17:50:47.817 - info: admin.0 (1091) socket.io server listening on port 8081
                                    2023-03-28 17:50:47.882 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:50:47.898 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
                                    2023-03-28 17:50:48.678 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1324
                                    2023-03-28 17:50:50.273 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:50:51.258 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:50:52.990 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1697
                                    2023-03-28 17:50:53.515 - info: backitup.0 (1324) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:50:56.393 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:51:09.110 - info: backitup.0 (1324) [iobroker] backup was activated at 02:40 every 1 day(s)
                                    2023-03-28 17:51:11.419 - info: enocean.0 (1697) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:51:13.251 - error: enocean.0 (1697) Timeout for response: Get version information
                                    2023-03-28 17:51:14.752 - error: enocean.0 (1697) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:51:16.258 - error: enocean.0 (1697) Timeout for response: Get frequency
                                    2023-03-28 17:51:17.759 - error: enocean.0 (1697) Timeout for response: Get base ID
                                    2023-03-28 17:51:19.260 - error: enocean.0 (1697) Timeout for response: Read learnd devices
                                    2023-03-28 17:51:19.261 - info: enocean.0 (1697) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:51:43.130 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
                                    2023-03-28 17:51:47.110 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:51:47.120 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50 admin
                                    2023-03-28 17:51:50.463 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:52:09.168 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:52:09.258 - info: enocean.0 (1697) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:52:14.389 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:52:14.405 - info: enocean.0 (1697) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:52:14.448 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:52:14.419 - info: enocean.0 (1697) cleaned everything up...
                                    2023-03-28 17:52:14.420 - info: enocean.0 (1697) terminating
                                    2023-03-28 17:52:14.421 - info: enocean.0 (1697) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:52:15.026 - warn: enocean.0 (1697) Error sending data: Error: Port is not open
                                    2023-03-28 17:52:15.028 - warn: enocean.0 (1697) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:52:15.029 - warn: enocean.0 (1697) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:52:15.031 - warn: enocean.0 (1697) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:52:15.032 - warn: enocean.0 (1697) An error occured at serial port: Error: Port is not open
                                    2023-03-28 17:52:15.033 - info: enocean.0 (1697) The serial port was closed.
                                    2023-03-28 17:52:15.035 - info: enocean.0 (1697) The serial port was closed.
                                    2023-03-28 17:52:15.056 - warn: enocean.0 (1697) get state error: DB closed
                                    2023-03-28 17:52:15.062 - warn: enocean.0 (1697) get state error: Connection is closed.
                                    2023-03-28 17:52:15.065 - warn: enocean.0 (1697) get state error: Connection is closed.
                                    2023-03-28 17:52:15.140 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-03-28 17:52:17.485 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1774
                                    2023-03-28 17:52:19.391 - info: enocean.0 (1774) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:52:21.174 - error: enocean.0 (1774) Timeout for response: Get version information
                                    2023-03-28 17:52:22.675 - error: enocean.0 (1774) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:52:24.178 - error: enocean.0 (1774) Timeout for response: Get frequency
                                    2023-03-28 17:52:25.679 - error: enocean.0 (1774) Timeout for response: Get base ID
                                    2023-03-28 17:52:27.180 - error: enocean.0 (1774) Timeout for response: Read learnd devices
                                    2023-03-28 17:52:27.181 - info: enocean.0 (1774) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:52:53.765 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:52:55.651 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:52:55.662 - info: enocean.0 (1774) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:52:55.699 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:52:55.666 - info: enocean.0 (1774) cleaned everything up...
                                    2023-03-28 17:52:55.668 - info: enocean.0 (1774) terminating
                                    2023-03-28 17:52:55.669 - info: enocean.0 (1774) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:52:55.863 - warn: enocean.0 (1774) Error sending data: Error: Port is not open
                                    2023-03-28 17:52:55.865 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:52:55.866 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:52:55.867 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:52:55.868 - warn: enocean.0 (1774) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:52:55.869 - warn: enocean.0 (1774) An error occured at serial port: Error: Port is not open
                                    2023-03-28 17:52:55.870 - info: enocean.0 (1774) The serial port was closed.
                                    2023-03-28 17:52:56.043 - info: enocean.0 (1774) The serial port was closed.
                                    2023-03-28 17:52:56.185 - warn: enocean.0 (1774) get state error: Connection is closed.
                                    2023-03-28 17:52:56.187 - warn: enocean.0 (1774) get state error: DB closed
                                    2023-03-28 17:52:56.242 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-03-28 17:52:58.725 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1790
                                    2023-03-28 17:53:00.564 - info: enocean.0 (1790) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:53:02.385 - error: enocean.0 (1790) Timeout for response: Get version information
                                    2023-03-28 17:53:03.890 - error: enocean.0 (1790) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:53:05.391 - error: enocean.0 (1790) Timeout for response: Get frequency
                                    2023-03-28 17:53:06.893 - error: enocean.0 (1790) Timeout for response: Get base ID
                                    2023-03-28 17:53:08.394 - error: enocean.0 (1790) Timeout for response: Read learnd devices
                                    2023-03-28 17:53:08.395 - info: enocean.0 (1790) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:53:51.903 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:53:51.982 - info: enocean.0 (1790) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:54:10.343 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:54:10.349 - info: enocean.0 (1790) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:54:10.391 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:54:10.353 - info: enocean.0 (1790) cleaned everything up...
                                    2023-03-28 17:54:10.354 - info: enocean.0 (1790) terminating
                                    2023-03-28 17:54:10.355 - info: enocean.0 (1790) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:54:11.038 - warn: enocean.0 (1790) Error sending data: Error: Port is not open
                                    2023-03-28 17:54:11.040 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:54:11.041 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:54:11.042 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:54:11.043 - warn: enocean.0 (1790) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:54:11.045 - warn: enocean.0 (1790) An error occured at serial port: Error: Port is not open
                                    2023-03-28 17:54:11.045 - info: enocean.0 (1790) The serial port was closed.
                                    2023-03-28 17:54:11.048 - info: enocean.0 (1790) The serial port was closed.
                                    2023-03-28 17:54:11.067 - warn: enocean.0 (1790) get state error: Connection is closed.
                                    2023-03-28 17:54:11.068 - warn: enocean.0 (1790) get state error: DB closed
                                    2023-03-28 17:54:11.075 - warn: enocean.0 (1790) get state error: Connection is closed.
                                    2023-03-28 17:54:11.140 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-03-28 17:54:13.420 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1807
                                    2023-03-28 17:54:15.250 - info: enocean.0 (1807) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:54:15.526 - warn: enocean.0 (1807) An error occured at serial port: Error: Error: No such file or directory, cannot open Choose
                                    2023-03-28 17:55:03.052 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:55:04.898 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:55:04.965 - info: enocean.0 (1807) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 17:55:08.653 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:55:08.659 - info: enocean.0 (1807) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:55:08.662 - info: enocean.0 (1807) cleaned everything up...
                                    2023-03-28 17:55:08.662 - info: enocean.0 (1807) terminating
                                    2023-03-28 17:55:08.663 - info: enocean.0 (1807) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:55:08.665 - warn: enocean.0 (1807) An error occured at serial port: Error: Port is not open
                                    2023-03-28 17:55:08.702 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:55:09.201 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-03-28 17:55:11.305 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:55:11.751 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1826
                                    2023-03-28 17:55:13.610 - info: enocean.0 (1826) starting. Version 0.8.5 (non-npm: Jey-Cee/ioBroker.enocean#cbd35ff4c03aca0d7d8b0d4ca95fab310f52305a) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:55:15.395 - error: enocean.0 (1826) Timeout for response: Get version information
                                    2023-03-28 17:55:16.896 - error: enocean.0 (1826) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:55:18.398 - error: enocean.0 (1826) Timeout for response: Get frequency
                                    2023-03-28 17:55:19.900 - error: enocean.0 (1826) Timeout for response: Get base ID
                                    2023-03-28 17:55:21.401 - error: enocean.0 (1826) Timeout for response: Read learnd devices
                                    2023-03-28 17:55:21.402 - info: enocean.0 (1826) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:56:24.597 - info: host.raspberrypi iobroker url https://github.com/iobroker-community-adapters/ioBroker.enocean.git --host raspberrypi --debug
                                    2023-03-28 17:56:28.237 - info: host.raspberrypi iobroker install iobroker-community-adapters/ioBroker.enocean#62d2b5b1fcbdd1c24af22ae3b9225b7e1ec57db4
                                    2023-03-28 17:56:29.387 - info: host.raspberrypi iobroker NPM version: 8.19.3
                                    2023-03-28 17:56:29.391 - info: host.raspberrypi iobroker Installing iobroker-community-adapters/ioBroker.enocean#62d2b5b1fcbdd1c24af22ae3b9225b7e1ec57db4... (System call)
                                    2023-03-28 17:56:46.117 - info: host.raspberrypi iobroker npm WARN skipping integrity check for git dependency ssh://git@github.com/iobroker-community-adapters/ioBroker.enocean.git
                                    2023-03-28 17:56:56.916 - info: host.raspberrypi iobroker npm ERR! code 1
                                    2023-03-28 17:56:56.920 - info: host.raspberrypi iobroker npm ERR! path /opt/iobroker/node_modules/@serialport/bindings
                                    2023-03-28 17:56:56.928 - info: host.raspberrypi iobroker npm ERR! command failed
                                    2023-03-28 17:56:56.933 - info: host.raspberrypi iobroker npm ERR! command sh -c -- prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                    2023-03-28 17:56:56.938 - info: host.raspberrypi iobroker npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird betreten
                                    2023-03-28 17:56:56.944 - info: host.raspberrypi iobroker npm ERR! CXX(target) Release/obj.target/bindings/src/serialport.onpm ERR! make: Verzeichnis „/opt/iobroker/node_modules/@serialport/bindings/build“ wird verlassennpm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.1.0npm ERR! gyp info using node@16.19.1 | linux | arm64npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"npm ERR! gyp http GET https://nodejs.org/download/release/v16.19.1/node-v16.19.1-headers.tar.gznpm ERR! gyp http 200 https://nodejs.org/download/release/v16.19.1/node-v16.19.1-headers.tar.gznpm ERR! gyp http GET https://nodejs.org/download/release/v16.19.1/SHASUMS256.txtnpm ERR! gyp http 200 https://nodejs.org/download/release/v16.19.1/SHASUMS256.txtnpm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [
                                    2023-03-28 17:56:56.946 - info: host.raspberrypi iobroker npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/@serialport/bindings/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/16.19.1/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.19.1',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.19.1/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/@serialport/bindings',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 78 | uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 135 | uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 175 | uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 215 | uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:270:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 270 | uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:314:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 314 | uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                    2023-03-28 17:56:56.952 - info: host.raspberrypi iobroker npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::FactoryBase::return_t)’npm ERR! 329 | results->Set(Nan::New("cts").ToLocalChecked(), Nan::New(data->cts));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::FactoryBase::return_t)’npm ERR! 330 | results->Set(Nan::New("dsr").ToLocalChecked(), Nan::New(data->dsr));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::FactoryBase::return_t)’npm ERR! 331 | results->Set(Nan::New("dcd").ToLocalChecked(), Nan::New(data->dcd));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:363:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 363 | uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local, Nan::imp::IntegerFactory::return_t)’npm ERR! 378 | results->Set(Nan::New("baudRate").ToLocalChecked(), Nan::New(data->baudRate));npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:73,npm ERR! from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, v8::Local, v8::Local)’npm ERR! 3961 | V8_WARN_UNUSED_RESULT Maybe Set(Local context,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 providednpm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe v8::Object::Set(v8::Local, uint32_t, v8::Local)’npm ERR! 3964 | V8_WARN_UNUSED_RESULT Maybe Set(Local context, uint32_t index,npm ERR! | ^~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 providednpm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:npm ERR! ../src/serialport.cpp:409:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]npm ERR! 409 | uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../src/serialport.cpp: At global scope:npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                    2023-03-28 17:56:56.966 - info: host.raspberrypi iobroker npm ERR! 430 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) {npm ERR! | ^npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]npm ERR! 449 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {npm ERR! | ^npm ERR! In file included from ../../../nan/nan.h:60,npm ERR! from ../src/./serialport.h:6,npm ERR! from ../src/serialport.cpp:1:npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:887:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]npm ERR! 887 | (node::addon_register_func) (regfunc), \npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! /home/iobroker/.cache/node-gyp/16.19.1/include/node/node.h:921:3: note: in expansion of macro ‘NODE_MODULE_X’npm ERR! 921 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm ERR! | ^~~~~~~~~~~~~npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’npm ERR! 483 | NODE_MODULE(serialport, init);npm ERR! | ^~~~~~~~~~~npm ERR! make: *** [bindings.target.mk:114: Release/obj.target/bindings/src/serialport.o] Fehler 1npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:201:23)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:293:12)npm ERR! gyp ERR! System Linux 6.1.19-v8+npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindingsnpm ERR! gyp ERR! node -v v16.19.1npm ERR! gyp ERR! node-gyp -v v9.1.0npm ERR! gyp ERR! not oknpm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-03-28T15_56_30_480Z-debug-0.log
                                    2023-03-28 17:56:57.060 - info: host.raspberrypi iobroker upload [6] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/admin.d.ts admin.d.ts video/mp2t
                                    2023-03-28 17:56:57.105 - info: host.raspberrypi iobroker upload [5] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/components.js components.js application/javascript
                                    2023-03-28 17:56:57.127 - info: host.raspberrypi iobroker upload [4] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/enocean.png enocean.png image/png
                                    2023-03-28 17:56:57.153 - info: host.raspberrypi iobroker upload [3] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/github.js github.js application/javascript
                                    2023-03-28 17:56:57.177 - info: host.raspberrypi iobroker upload [2] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/index_m.html index_m.html text/html
                                    2023-03-28 17:56:57.212 - info: host.raspberrypi iobroker upload [1] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/style.css style.css text/css
                                    2023-03-28 17:56:57.254 - info: host.raspberrypi iobroker upload [0] enocean.admin /opt/iobroker/node_modules/iobroker.enocean/admin/words.js words.js application/javascript
                                    2023-03-28 17:56:57.316 - info: host.raspberrypi iobroker Update "system.adapter.enocean.0"
                                    2023-03-28 17:56:57.327 - info: host.raspberrypi stopInstance system.adapter.enocean.0 (force=false, process=true)
                                    2023-03-28 17:56:57.338 - info: enocean.0 (1826) Got terminate signal TERMINATE_YOURSELF
                                    2023-03-28 17:56:57.376 - info: host.raspberrypi stopInstance system.adapter.enocean.0 send kill signal
                                    2023-03-28 17:56:57.348 - info: enocean.0 (1826) cleaned everything up...
                                    2023-03-28 17:56:57.349 - info: enocean.0 (1826) terminating
                                    2023-03-28 17:56:57.350 - info: enocean.0 (1826) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-03-28 17:56:57.841 - warn: enocean.0 (1826) Error sending data: Error: Port is not open
                                    2023-03-28 17:56:57.843 - warn: enocean.0 (1826) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:56:57.844 - warn: enocean.0 (1826) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:56:57.845 - warn: enocean.0 (1826) Error sending data: Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                                    2023-03-28 17:56:57.847 - warn: enocean.0 (1826) An error occured at serial port: Error: Port is not open
                                    2023-03-28 17:56:57.848 - info: enocean.0 (1826) The serial port was closed.
                                    2023-03-28 17:56:58.292 - info: enocean.0 (1826) The serial port was closed.
                                    2023-03-28 17:56:58.318 - warn: enocean.0 (1826) get state error: Connection is closed.
                                    2023-03-28 17:56:58.319 - warn: enocean.0 (1826) get state error: DB closed
                                    2023-03-28 17:56:58.325 - warn: enocean.0 (1826) get state error: Connection is closed.
                                    2023-03-28 17:56:58.361 - info: host.raspberrypi iobroker exit 0
                                    2023-03-28 17:56:58.380 - info: host.raspberrypi stopInstance system.adapter.enocean.0 killing pid 1826
                                    2023-03-28 17:56:58.417 - info: host.raspberrypi instance system.adapter.enocean.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-03-28 17:57:00.414 - info: host.raspberrypi instance system.adapter.enocean.0 started with pid 1921
                                    2023-03-28 17:57:03.048 - info: enocean.0 (1921) starting. Version 0.8.5 (non-npm: iobroker-community-adapters/ioBroker.enocean#62d2b5b1fcbdd1c24af22ae3b9225b7e1ec57db4) in /opt/iobroker/node_modules/iobroker.enocean, node: v16.19.1, js-controller: 4.0.24
                                    2023-03-28 17:57:04.841 - error: enocean.0 (1921) Timeout for response: Get version information
                                    2023-03-28 17:57:06.343 - error: enocean.0 (1921) Timeout for response: Get repeater mode and level
                                    2023-03-28 17:57:07.844 - error: enocean.0 (1921) Timeout for response: Get frequency
                                    2023-03-28 17:57:09.348 - error: enocean.0 (1921) Timeout for response: Get base ID
                                    2023-03-28 17:57:10.852 - error: enocean.0 (1921) Timeout for response: Read learnd devices
                                    2023-03-28 17:57:10.853 - info: enocean.0 (1921) {"AppVersion":"undefined.undefined.undefined.undefined","ApiVersion":"undefined.undefined.undefined.undefined"}
                                    2023-03-28 17:59:00.437 - info: admin.0 (1091) ==> Connected system.user.admin from ::ffff:192.168.9.50
                                    2023-03-28 17:59:00.520 - info: enocean.0 (1921) ["/dev/ttyAMA0","/dev/ttyUSB0","/dev/serial/by-id/usb-EnOcean_GmbH_USB_300_DE_EO76BS6M-if00-port0"]
                                    2023-03-28 18:00:57.399 - info: admin.0 (1091) <== Disconnect system.user.admin from ::ffff:192.168.9.50
                                    • Jey Cee
                                      Jey Cee Developer @TimoWald last edited by
                                      @timowald sorry für die Späte Antwort. Du musst schon den richtigen Port auswählen.
                                        blackbirdN510 @Black-Raven last edited by
                                        @black-raven darf ich fragen wie du den FTS14EM zum laufen bekommen hast? Braucht man einen FTS14FA oder geht das auch ohne? Allgemein funktioniert es mit meinen FUD und FSR aber den FTS bekomme ich nicht in den ioBroker.
                                        Viele Grüße
                                        Matthias
                                        R B 2 Replies Last reply Reply Quote 0
                                          RoGo @blackbirdN510 last edited by
                                          @blackbirdn510 bei Verwendung des USB 300 wird der FTS14FA benötigt, da Zustände der Eingänge nicht über das FAM 14 in den Gebäudefunk gesendet werden. Das macht dann der FTS14FA. Bei Verwendung des FGW14USB wird der FTS14FA nicht benötigt, da dort die Eingänge vom RS485 mit über USB ausgegeben werden.
                                          Das war auch der Grund meiner Umstellung auf USB. Die Häufigkeit, in der die Telegramme über Funk versendet werden erhöht sich mit den 3 "Sendern" FTS14FA, USB300 und FAM14 enorm. Erkennt man auch an der roten LED am FAM 14. Ein Tastendruck verursacht mehrere Funktelegramme. Wenn man bedenkt, dass das Enocean darauf basiert, lediglich 2 Telegramme abzusetzen und davon ausgeht, dass der Empfänger das Telegramm auch empfangen haben muss (ohne Rückmeldung ob das geschehen ist) sollte das Telegrammaufkommen niedrig gehalten werden. Gleichzeitig versendete Telegramme von mehreren Teilnehmern kann zu Störungen führen.
                                          Mein FTS14FA liegt jetzt jedenfalls nutzlos herum 🙂
                                            Black-Raven @blackbirdN510 last edited by
                                            @blackbirdn510 RoGo hat eigentlich alles gesagt. Übers FGW14USB geht das FTS14EM auch ohne das FTS14FA.
                                            enocean
                                            25
                                            248
                                            45012
