    3. Einsteigerfragen
    4. Automatisierung
    5. Node Red: Fragen zu einfachen Steuerungsaufgaben
      Bastel2021 @mickym last edited by
      • mickym
        mickym Most Active @Bastel2021 last edited by
        @bastel2021 sagte in Node Red: Fragen zu einfachen Steuerungsaufgaben:
        @mickym Ja genau wie du das geschrieben hast!
        wie mache ich das wenn ich auf ein Komentar von dir antworten will?
        Mit Zitieren - dann wird der ganze Post mitgenommen.
          @mickym Heute gibt es reichlich Input 👍
          • mickym
            mickym Most Active @Bastel2021 last edited by mickym
            @bastel2021 Na der Flow muss etwas geändert werden:
            Das heißt uns interessieren nur true nachrichten und nur brightness_stop = true stoppt.
                   "id": "84a4665253f9d3cd",
                   "type": "inject",
                   "z": "289f539dcc33814e",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "brightness_move_up",
                   "payload": "true",
                   "payloadType": "bool",
                   "x": 770,
                   "y": 2880,
                   "wires": [
                           "9c5488d58e7db53c"
                   "id": "bd70628635955989",
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "payload": "false",
                   "x": 770,
                   "y": 2920,
                   "wires": [
                           "9c5488d58e7db53c"
                   "id": "7a6bf28cab9967c7",
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "brightness_move_down",
                   "payload": "true",
                   "x": 760,
                   "y": 2980,
                   "wires": [
                           "9c5488d58e7db53c"
                   "id": "6eeb20c4814fd414",
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "payload": "false",
                   "x": 760,
                   "y": 3020,
                   "wires": [
                           "9c5488d58e7db53c"
                   "id": "b85b9d8b1ab20bb4",
                   "type": "switch",
                   "name": "",
                   "property": "topic",
                   "propertyType": "msg",
                   "rules": [
                           "t": "cont",
                           "v": "move_up",
                           "vt": "str"
                           "t": "cont",
                           "v": "move_down",
                           "vt": "str"
                           "t": "cont",
                           "v": "stop",
                           "vt": "str"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 3,
                   "x": 1190,
                   "y": 3000,
                   "wires": [
                           "18090ccc2bc2dc3e"
                           "dfa206edcb309a1b"
                           "7a72c3826d0c09b8"
                   "id": "18090ccc2bc2dc3e",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1410,
                   "y": 2940,
                   "wires": [
                           "d6c2e76969e5203a"
                   "id": "dfa206edcb309a1b",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "-5",
                           "tot": "num"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1410,
                   "y": 3000,
                   "wires": [
                           "d6c2e76969e5203a"
                   "id": "d8430976fbf77055",
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "brightness_stop",
                   "payload": "true",
                   "x": 790,
                   "y": 3080,
                   "wires": [
                           "9c5488d58e7db53c"
                   "id": "2b689b0579f31c05",
                   "type": "inject",
                   "name": "",
                   "props": [
                           "p": "payload"
                           "p": "topic",
                           "vt": "str"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "payload": "false",
                   "x": 780,
                   "y": 3120,
                   "wires": [
                           "9c5488d58e7db53c"
                   "id": "9c5488d58e7db53c",
                   "type": "switch",
                   "name": "nur true",
                   "property": "payload",
                   "rules": [
                           "t": "true"
                   "checkall": "true",
                   "repair": false,
                   "outputs": 1,
                   "x": 1040,
                   "y": 3000,
                   "wires": [
                           "b85b9d8b1ab20bb4"
                   "id": "7a72c3826d0c09b8",
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "false",
                           "tot": "bool"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1410,
                   "y": 3060,
                   "wires": [
                           "d6c2e76969e5203a"
            Deine In-Nodes (also move_up und move_down und stop) kannst noch dazu hängen. Und wenn Du die Inject nodes nicht mehr brauchst - löschst die halt.
              @mickym eigentlich brauch man dann ja die ganzen Injekt false nicht mehr oder?
              • mickym
                Stimmt 🙂
                  @mickym okay dann wird es jetzt ernst ...
                    Bastel2021 @mickym last edited by Bastel2021
                    @mickym 👍 👍 👍 👍 👍 👍
                    Super genial! Und wenn es auch für mich schwer verständlich ist, kann ich es doch in etwa nachvollziehen. Da ist Blockly doch, jedenfalls für mich, noch schwieriger zu verstehen
                    Das war wirklich sehr aufschlussreich!
                    • mickym
                      @bastel2021 Wenn Du noch eine Sicherheitsabschaltung haben möchtest, sprich auch wenn Du den Taster gedrückt hälst aber das untere oder obere Level bereits erreicht ist kannst Du mit einer switch Node noch den stop Trigger simulieren:
                              "id": "747b8c17765e922d",
                              "type": "switch",
                              "name": "stop flow",
                              "rules": [
                                      "t": "jsonata_exp",
                                      "v": "payload=5 or payload=100",
                                      "vt": "jsonata"
                              "checkall": "true",
                              "repair": false,
                              "outputs": 1,
                              "x": 2340,
                              "y": 3060,
                              "wires": [
                                      "7a72c3826d0c09b8"
                      • mickym
                        @mickym 👍 👍 👍 👍 👍 👍
                        Ja Du musst verstehen - das schöne an Node Red ist halt das man mal schnell ein Kabel durchtrennt hat oder hingemacht hat um Fehler einzugrenzen. Wie gesagt Du arbeitest Dich immer von links nach rechts 😉 und änderst die Bedingungen so, dass das rauskommt, was der Adapter oder die Hardware erwartet.
                        Und wenn Du den anderen Thread kennst - dann siehst ja das man auch langsam voran gehen kann. 😉
                        • mickym
                          Und wenn ich noch was erklären kann oder dafür tun kann, dass es leichter verständlich wird, dann lass es mich wissen. Nur wenn Du Fragen stellst, dann kann ich helfen oder vielleicht helfen.
                            @mickym ja ich gebe dir da recht. Für mich verdichtet sich das immer mehr nach Node Red. Aber da muss man selber erst mal hinkommen. Halt ein Lernprozess.
                            Und mir schweben da auch noch andere Dinge im Kopf rum wie z,B. ob ich nicht auch mehr mit Zigbeetomqtt arbeiten sollte. Aber immer schön der Reihe nach. jetzt baue ich noch kurz die Änderung ein.
                              • mickym
                                Nun das ist halt eine Frage der Philosophie. Die Adapter sind im ersten Augenblick für viele einfacher - aber wenn Du mal die Grundlagen verstehst was Arrays und Objekte sind - und das muss man halt mal verstehen, dann kann man auch mit mqtt direkt arbeiten. Ich habe jedenfalls kein Adapter im Einsatz ausser dem mqtt-Adapter und mein mosquitto (muss nicht) und verarbeitet halt die Nachrichten direkt.
                                Wie gesagt die Adapter machen vieles einfacher - aber Du bist halt immer darauf angewiesen, dass diese die Geräte kennen, die analysiert werden.
                                Du siehst bei mir ist alles direkt im mqtt:
                                owntracks, shellies, tasmota und zigbee2mqtt
                                  @mickym Was ich z.B. auch sehr unübersichtlich finde ist die einzelnen Geräte im Zigbee Adapter zu erkennen. Aber liegt vielleicht auch an meiner Unwissenheit das vernüftig zu strukturieren
                                    @mickym Ich habe das jetzt eingearbeitet, Wenn ich den Taster weiter betätige gehen die Werte aber trotzdem noch in die Debug rein ist das richtig?
                                    B mickym 2 Replies Last reply Reply Quote 0
                                    • mickym
                                      @bastel2021 Du kannst den Namen ja abändern. 😉 Bei MQTT kannst Du halt noch eine Struktur machen, um die Geräte zu strukturieren, dann hast Du nicht so eine flache Struktur.
                                      Ich hab das meist mit Gerätetyp, dann Raum und dann das Gerät selbst struktieriert. Damit findet man es eigentlich ganz gut.
                                        Bastel2021 @Bastel2021 last edited by
                                        Sorry hab noch nicht deployd. Funktioniert alles
                                        • mickym
                                          Oh immer diese Schrecksekunden. 😰
                                            @mickym Sorry
                                            29622
