    3. Off Topic
    4. Bildschirm drehen
    Bildschirm drehen
    • wendy2702
      wendy2702 @Phil87 last edited by
      @phil87 sagte in Bildschirm drehen:
      einen der beiden HDMI-Schnittstellen angeschlossen.
      Aha…
      Und von was für einem System / Hardware reden wir hier?
        Phil87 @wendy2702 last edited by
        @wendy2702
        Ich habe eine Raspberry Pi 4 im Einsatz. Auf linux Basis.
        DJMarc75 wendy2702 2 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @Phil87 last edited by
          na dann zeig mal KOMPLETT:
          iob diag
          P wendy2702 2 Replies Last reply Reply Quote 0
          • wendy2702
            @phil87 Schau mal ob dir hier der erste Beitrag Hilft.
            Da steht was von Lösung:
            https://forum-raspberrypi.de/forum/thread/54432-bullseye-raspberry-pi-7-display-180-grad-drehen-so-geht-s-nicht/
              Phil87 @DJMarc75 last edited by
              @djmarc75 sagte in Bildschirm drehen:
              iob diag
              pi@raspberrypi:~ $ iob diag
              iobroker [command]
              Commands:
                iobroker setup                                               Setup ioBroker
                iobroker start [all|<adapter>.<instance>]                    Starts the js-con        troller or a specified adapter instance
                iobroker stop [<adapter>.<instance>]                         stops the js-cont        roller or a specified adapter instance
                iobroker restart [<adapter>.<instance>]                      Restarts js-contr        oller or a specified adapter instance  [aliases: r]
                iobroker debug <adapter>[.<instance>]                        Starts a Node.js        debugging session for the adapter instance
                iobroker info                                                Shows the host in        fo
                iobroker logs [<adapter>]                                    Monitor log
                iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter  [aliases: a]
                iobroker install <adapter>                                   Installs a specif        ied adapter  [aliases: i]
                iobroker rebuild [<module>]                                  Rebuild all nativ        e modules or path
                iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
                iobroker del <adapter>                                       Remove adapter an        d all instances from this host  [aliases: delete]
                iobroker del <adapter>.<instance>                            Remove adapter in        stance  [aliases: delete]
                iobroker update [<repositoryUrl>]                            Update repository        and list adapters
                iobroker upgrade                                             Upgrade managemen        t
                iobroker upload [all|<adapter>]                              Upload management        [aliases: u]
                iobroker object                                              Object management        [aliases: o]
                iobroker state                                               State management        [aliases: s]
                iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
                iobroker list <type> [<filter>]                              List all entries,        like objects
                iobroker chmod <mode> <file>                                 Change file right        s
                iobroker chown <user> <group> <file>                         Change file owner        ship
                iobroker touch <file>                                        Touch file
                iobroker rm <file>                                           Remove file
                iobroker file                                                File management
                iobroker user                                                User commands
                iobroker group                                               group management
                iobroker host <hostname>                                     Set host to given        hostname
                iobroker set <adapter>.<instance>                            Change settings o        f adapter config
                iobroker license <license.file or license.text>              Update license by        given file
                iobroker cert                                                Certificate manag        ement
                iobroker clean <yes>                                         Clears all object        s and states
                iobroker backup                                              Create backup
                iobroker restore <backup name or path>                       Restore a specifi        ed backup
                iobroker validate <backup name or path>                      Validate a specif        ied backup
                iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance  [aliases: isrun]
                iobroker repo [<name>]                                       Show repo informa        tion
                iobroker uuid                                                Show uuid of the        installation  [aliases: id]
                iobroker unsetup                                             Reset license, in        stallation secret and language
                iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
                iobroker multihost                                           Multihost managem        ent
                iobroker compact                                             compact group man        agement
                iobroker plugin                                              Plugin management
                iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter  [aliases: v]
              Options:
                --help  Show help  [boolean]
              • wendy2702
                wendy2702 @DJMarc75 last edited by
                iob diag
                Das hilft Ihm nicht weiter. Er ist ja noch im Boot Vorgang.
                • DJMarc75
                  DJMarc75 @wendy2702 last edited by
                  @wendy2702 sagte in Bildschirm drehen:
                  Stimmt... und er hat ja auch keinen iob installiert 😁
                    Thomas Braun Most Active @DJMarc75 last edited by
                    @djmarc75
                    iobroker ist schon installiert, allerdings noch ohne den Patch für iob diag
                    Kann man mit
                    iob fix
                    aber nachholen.
                    Unabhängig davon:
                    randr
                    ist vermutlich die richtige Richtung. Für Details müsste ich mich aber jetzt auch reinknien.
                      liv-in-sky @Phil87 last edited by liv-in-sky
                      @phil87
                      ist schon ewig her, aber hast du eine gui installiert - ich hatte dies mal, um mit chromium eine vis view anzuzeigen - habe das drehen auf hochkant in der gui gemacht, da funktionierte es dann-
                        A Former User @Phil87 last edited by A Former User
                        @phil87
                        Moin,
                        ist zwar noch für Buster sollte aber als Denkanstoß auch für hoffentlich Bullseye gelten https://unix.stackexchange.com/questions/680005/rotating-display-on-debian-buster-from-cli.
                        Nach diesem Post https://raspberrypi.stackexchange.com/questions/136497/how-do-i-rotate-the-screen-at-boot-time-gui-is-rotated-but-boot-messages-are-st soll ein Eintrag in die /boot/config.txt helfen, ist aber LCD Screen auf dem GPIO
                        fbcon=rotate:2
                        Ansonnsten kenne ich das nur noch aus dem Desktop und entsprechender X-Server Konfiguration.
                        # randr
                        Hier https://forums.raspberrypi.com/viewtopic.php?t=265449 vielleicht auch noch Denkanstöße.
                        VG
                        Bernd
                          Danke für die Hilfen.
                          Ich habe jetzt eine mechanische Lösung gefunden, war nicht ganz einfach aber schneller.
                          1.0k
                          1061
