    4. Zigbee: Resource temporarily unavailable Cannot lock port
      roughestboy @Thomas Braun last edited by
      Zigbee Adapter ist ein CC2538 von Arteck. Update folgt.
        Thomas Braun Most Active @roughestboy last edited by
        @roughestboy sagte in Zigbee: Resource temporarily unavailable Cannot lock port:
        CC2538
        Ich dachte da sei vielleicht der Firmware-Stack falsch. Aber 3.0.x passt da.
          System ist up2date, js-controller 4.0.24. npm 8.19.2 und node.js 16.18.0 nahezu.
          Log mit Start der Zigbee Instanz sieht nun so aus:
          zigbee.0
          2023-02-26 16:03:00.572	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          zigbee.0
          2023-02-26 16:03:00.570	info	terminating
          zigbee.0
          2023-02-26 16:03:00.071	info	Zigbee: disabling joining new devices.
          zigbee.0
          2023-02-26 16:03:00.067	info	cleaned everything up...
          zigbee.0
          2023-02-26 16:03:00.040	error	Cannot read properties of undefined (reading 'mapped')
          zigbee.0
          2023-02-26 16:03:00.037	error	TypeError: Cannot read properties of undefined (reading 'mapped') at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:571:36)
          zigbee.0
          2023-02-26 16:03:00.035	error	unhandled promise rejection: Cannot read properties of undefined (reading 'mapped')
          zigbee.0
          2023-02-26 16:03:00.031	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          zigbee.0
          2023-02-26 16:02:58.359	info	debug devices set to []
          zigbee.0
          2023-02-26 16:02:58.280	info	Zigbee started
          zigbee.0
          2023-02-26 16:02:58.278	info	Currently no devices.
          zigbee.0
          2023-02-26 16:02:58.263	info	--> transmitPower : high
          zigbee.0
          2023-02-26 16:02:58.245	info	Unable to disable LED, unsupported function.
          zigbee.0
          2023-02-26 16:02:58.244	info	Disable LED
          zigbee.0
          2023-02-26 16:02:58.237	info	Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200327}}
          zigbee.0
          2023-02-26 16:02:57.965	info	Installed Version: iobroker.zigbee@1.8.10
          zigbee.0
          2023-02-26 16:02:57.340	info	Starting Zigbee npm ...
          zigbee.0
          2023-02-26 16:02:57.337	info	delete old Backup files. keep only last 10
          zigbee.0
          2023-02-26 16:02:57.212	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.24
          Kann es ein Hardware Prob sein ? Verkabelung habe ich neu gesteckt, allerdings siehen
          lsusb
          Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
          Bus 001 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
          Bus 001 Device 003: ID 0451:16c8 Texas Instruments, Inc. CC2538 USB CDC
          Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
          Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
          und ls -l /dev/serial/by-id
          lrwxrwxrwx 1 root root 13 26. Feb 15:44 usb-EnOcean_GmbH_EnOcean_USB_300_DB_FT3FUSTH-if00-port0 -> ../../ttyUSB0
          lrwxrwxrwx 1 root root 13 26. Feb 15:44 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
          nicht verkehrt aus.
            nahezu
            Dann mach es vollständig.
              Ich habe jetzt ein völlig aktuelles System. Bzgl. dem Zigbee Prob bringt das nichts.
              Testweise einen anderen USB Anschluss verwendet und eine 2. Instanz erzeugt, Instanz läuft trotzdem auf rot.
              crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                crunchip Forum Testing Most Active @roughestboy last edited by
                @roughestboy wenn du die nvbackup.json wieder einfügst?
                  @roughestboy
                  Dann erzähl uns mal mehr zu deinem System.
                  Z.B. per Ausgabe von
                  iob diag
                    roughestboy @crunchip last edited by roughestboy
                    @crunchip
                    Ja, die alte nvbackup.json is ja auch noch da. Wenn ich die wieder einsetze, sehen die Fehlermeldungen anders aus, Instanz bleibt aber auf gelb:
                    zigbee.0
                    2023-02-26 18:00:06.605	error	Error herdsman start
                    zigbee.0
                    2023-02-26 18:00:06.604	error	Failed to start Zigbee
                    zigbee.0
                    2023-02-26 18:00:06.598	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                    zigbee.0
                    2023-02-26 18:00:06.199	info	Installed Version: iobroker.zigbee@1.8.10
                    zigbee.0
                    2023-02-26 18:00:06.131	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-02-26 18:00:06.128	info	Try to reconnect. 1 attempts left
                    zigbee.0
                    2023-02-26 17:59:56.121	error	Error herdsman start
                    zigbee.0
                    2023-02-26 17:59:56.120	error	Failed to start Zigbee
                    zigbee.0
                    2023-02-26 17:59:56.117	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                    zigbee.0
                    2023-02-26 17:59:46.937	info	Installed Version: iobroker.zigbee@1.8.10
                    zigbee.0
                    2023-02-26 17:59:46.246	info	Starting Zigbee npm ...
                    zigbee.0
                    2023-02-26 17:59:46.242	info	delete old Backup files. keep only last 10
                    zigbee.0
                    2023-02-26 17:59:46.102	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                                           v.2023-01-02
                      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
                      Installation:           Native
                      Timezone:               Europe/Berlin
                      User-ID:                1000
                      X-Server:               false
                      Boot Target:            multi-user.target
                      Pending OS-Updates:     54
                      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                              /usr/bin/node           v16.19.1
                                              /usr/bin/npm            8.19.3
                                              /usr/bin/npx            8.19.3
                      ioBroker Core:          js-controller           4.0.24
                                              admin                   6.3.6
                      Objects type: jsonl
                      States  type: redis
                      Status admin:
                      + system.adapter.admin.0                  : admin                 : pi4iobroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      Pending iob updates:    0
                      Active repo(s): beta
                      Objects:                4090
                      States:                 2820
                      Size of iob-Database:
                      25M     /opt/iobroker/iobroker-data/objects.jsonl
                      552K    /opt/iobroker/iobroker-data/states.jsonl
                        @roughestboy
                        Updaten...
                          @roughestboy und wenn du den Stick mal kurz absteckst?
                            @crunchip ändert nichts.
                              Habe jetzt Pending OS-Updates auf Null. Zwischendurch Kabel zum Stick getauscht, den Stick gegen einen identischen gewechselt, und ein Backitup vom 2.2. eingespielt, da war das Problem noch nicht. Auch noch eine neue, 2te Instanz angelegt. Es bleibt immer bei einem 'zigbee-herdsman Problem,' "Cannot read properties of undefined (reading 'payload')" und "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'". Letztes log:
                              zigbee.0
                              	2023-03-04 11:48:47.327	error	Error herdsman start
                              zigbee.0
                              	2023-03-04 11:48:47.325	error	Failed to start Zigbee
                              zigbee.0
                              	2023-03-04 11:48:47.324	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                              zigbee.0
                              	2023-03-04 11:48:47.127	info	Installed Version: iobroker.zigbee@1.8.10
                              zigbee.0
                              	2023-03-04 11:48:47.103	info	Starting Zigbee npm ...
                              zigbee.0
                              	2023-03-04 11:48:47.102	info	Try to reconnect. 1 attempts left
                              zigbee.0
                              	2023-03-04 11:48:37.083	error	Error herdsman start
                              zigbee.0
                              	2023-03-04 11:48:37.083	error	Failed to start Zigbee
                              zigbee.0
                              	2023-03-04 11:48:37.081	error	Starting zigbee-herdsman problem : "Cannot read properties of undefined (reading 'payload')"
                              zigbee.0
                              	2023-03-04 11:48:28.346	info	Installed Version: iobroker.zigbee@1.8.10
                              zigbee.0
                              	2023-03-04 11:48:27.652	info	Starting Zigbee npm ...
                              zigbee.0
                              	2023-03-04 11:48:27.483	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.1, js-controller: 4.0.24
                                Frage: gibts in iobroker irgendetwas oder einen anderen Adapter, der sich den Zigbee Stick schnappt, in etwa sowas wie hier:
                                502 - Bad Gateway =>TypeError: Cannot read property 'payload' of undefined
                                  So, um das hier noch abzuschließen. Habe mich wegen eines anderen 'Großprojekts' lange nicht kümmern können und erstmal ohne Zigbee leben müssen.
                                  Nun ist raus, es war ein 'schlechtes' udev-Paket. Siehe auch
                                  zigbee-conbee2-funktioniert-nach-update-nicht-mehr-udev
                                  Für mich war es dann die Möglichkeit 2.
                                    micw42 last edited by micw42
                                    ich habe heute den js-controller aktualisiert und danach node.js und den zigbee-Adapter. Sonst habe ich nichts verändert!
                                    Leider bekomme ich nun auch die Meldung und der Adapter startet nicht mehr:
                                    zigbee.0
                                    2024-01-03 23:02:48.184	error	Error herdsman start
                                    zigbee.0
                                    2024-01-03 23:02:48.183	error	Failed to start Zigbee
                                    zigbee.0
                                    2024-01-03 23:02:48.182	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    zigbee.0
                                    2024-01-03 23:02:47.835	info	Installed Version: iobroker.zigbee@1.9.5
                                    zigbee.0
                                    2024-01-03 23:02:47.802	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2024-01-03 23:02:47.801	info	Try to reconnect. 1 attempts left
                                    zigbee.0
                                    2024-01-03 23:02:37.795	error	Error herdsman start
                                    zigbee.0
                                    2024-01-03 23:02:37.794	error	Failed to start Zigbee
                                    zigbee.0
                                    2024-01-03 23:02:37.793	error	Starting zigbee-herdsman problem : undefined
                                    zigbee.0
                                    2024-01-03 23:02:26.289	info	Installed Version: iobroker.zigbee@1.9.5
                                    zigbee.0
                                    2024-01-03 23:02:25.619	info	Starting Zigbee npm ...
                                    zigbee.0
                                    2024-01-03 23:02:25.616	info	delete old Backup files. keep only last 10
                                    zigbee.0
                                    2024-01-03 23:02:25.317	info	starting. Version 1.9.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                                      Thomas Braun Most Active @micw42 last edited by
                                      @micw42
                                      iob diag
                                      in der Langfassung anschauen.
                                        micw42 @Thomas Braun last edited by micw42
                                        Ich muss wohl noch dazu sagen, dass ich einen RaspBee II Stick habe.
                                          @micw42 sagte in Zigbee: Resource temporarily unavailable Cannot lock port:
                                          Was davon ist denn interessant?
                                          Alles. Im gesamten gibt es ein Bild.
                                            Habe es in dem vorigen Beitrag reingepackt.
                                            2920
