    3. Einsteigerfragen
    4. Steuerung Gecko in Touch 2 per iob möglich? (Wellis)
      tklein @rrov1 last edited by
      @rrov1 Hier der Aufruf von der Kommandozeile:
      pi@raspberrypi-iob:~/wellis/v4 $ python3.10 /home/pi/wellis/v4/spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 1 0 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch
      pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/home/pi/.local/lib/python3.10/site-packages', '/usr/local/lib/python3.10/site-packages']
      current version: 3.10.9 (main, Jan  7 2023, 17:15:23) [GCC 8.3.0]
      Hier per DP:
      031288	2023-02-22 10:13:19.577	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** setting state of:javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch to old value: 0
      031288	2023-02-22 10:13:19.576	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** stderr: Error: Command failed: /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 0 2 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1 Traceback (most recent call last): File "/home/pi/wellis/v4/spa_switchPump.py", line 8, in <module> import requests ModuleNotFoundError: No module named 'requests'
      031288	2023-02-22 10:13:19.576	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** stdout: pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/usr/local/lib/python3.10/site-packages'] current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10
      Und noch aus dem Blockly per excec:
      javascript.0 (31288) script.js.common.Draussen.Wellis_Whirlpool.Pumpe_1_schalten: pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/usr/local/lib/python3.10/site-packages'] current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10
      pip3 install requests ergibt:
      Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
      Requirement already satisfied: requests in /usr/lib/python3/dist-packages (2.21.0)
      Welcher Pfad soll da rein? vom 3er oder 3.10?
      sys.path.append("/usr/lib/python3/dist-packages")
      3er:
      3.10
      pi@raspberrypi-iob:~ $ python3.10 -m pip install requests
      Defaulting to user installation because normal site-packages is not writeable
      Requirement already satisfied: requests in ./.local/lib/python3.10/site-packages (2.28.2)
      Requirement already satisfied: charset-normalizer<4,>=2 in ./.local/lib/python3.10/site-packages (from requests) (3.0.1)
      Requirement already satisfied: idna<4,>=2.5 in ./.local/lib/python3.10/site-packages (from requests) (3.4)
      Requirement already satisfied: urllib3<1.27,>=1.21.1 in ./.local/lib/python3.10/site-packages (from requests) (1.26.14)
      Requirement already satisfied: certifi>=2017.4.17 in ./.local/lib/python3.10/site-packages (from requests) (2022.12.7)
      Das Skript rufe ich mit dem User "pi" auf. Aus iobroker wird glaube ich "iobroker" genommen. Aber per chmod 775 *.py sollte jeder darauf zugriff haben, oder?
      pi@raspberrypi-iob:~/wellis/v4 $ ls -la
      total 48
      drwxrwxrwx 2 pi pi 4096 Feb 22 10:08 .
      drwxrwxrwx 5 pi pi 4096 Feb 14 17:50 ..
      -rwxrwxr-x 1 pi pi  189 Feb 20 22:52 python_version.py
      -rwxr-xr-x 1 pi pi 4512 Feb 21 15:58 spa_config.py
      -rwxr-xr-x 1 pi pi 4184 Feb 20 22:34 spa_setTargetTemp.py
      -rwxr-xr-x 1 pi pi 4982 Feb 22 10:08 spa_switchPump.py
      -rwxr-xr-x 1 pi pi 3747 Feb 22 09:31 spa_toggleLight.py
      -rwxr-xr-x 1 pi pi 4704 Feb 14 17:55 spa_updateBulk.py
      rrov1 1 Reply Last reply Reply Quote 0
        @rrov1 said in Steuerung Gecko in Touch 2 per iob möglich? (Wellis):
        @tklein said in Steuerung Gecko in Touch 2 per iob möglich? (Wellis):
        Ok, das mit den "**$**" im regulären Ausdruck ist schlecht. Wo die herkommen kann ich mir gerade nicht erklären auf github im Skript LightToggle.js schaut es fein aus.
        Dann muss das "$" im Pfad mit drinstehen? die "*" sind hier vom editor gekommen. Sollte bold sein.
        • rrov1
          rrov1 @tklein last edited by
          @tklein Ich glaube wir nähern uns der Lösung. Hätte ich vielleicht schon eher drauf kommen können. Die vorletzte Ausgabe ist interessant:
          in Verbindung mit den 3 ersten Ausgaben. Denn dieser Pfad zeigt im Kontext des user pi nach: /home/pi/.local/lib/python3.10/site-packages. In diesem Ordner liegt das Modul "requests" und wenn du unter dem User pi die Scripte ausführst ist auch alles fein, weil dieser Ordner im Python-Environment (sys.path) enthalten ist. Wenn ein Script unter einem anderen User (iobroker) ausgeführt wird ist dieser Pfad aber nicht enthalten.
          Das reparieren wir aber nicht, weil wir dann alles nur noch krummer machen als nötig.
          Führe doch mal mal:
          sudo python3.10 -m pip install requests
          Dann sollte er das Modul requests in den Pfad: /usr/local/lib/python3.10/site-packages installieren (poste doch mal die Ausgabe).
          Dann sollten auch die Aufrufe von ioBroker aus gehen.
            @rrov1 Hi, es wird immer besser.Jetzt klappt das schalten prinzipiell per DP. Nur nicht jedes mal. Kann es sein, dass es Probleme gibt, wenn gerade der minütliche Updatecron läuft?
            Kommandozeile (noch mit meinen Debug LOG-Ausgaben:
            Log 1
            Log 2
            Log 3
            Log 4
            Total arguments passed: 6
            Log 5
            Connecting using client id 916b0096-ab56-4344-8728-43a8259c63c2
            Connecting to spa id SPAe8:eb:1b:1c:5e:46
            Switching pump id 1
            Switching pump to state id 0
            Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch
            Log A
            Looking for spas on your network ...
            2023-02-23 08:40:42,631> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)]
            *** connecting to spa
            *** pump name: Pump 2
            *** pump modes: ['OFF', 'LO', 'HI']
            *** current pump mode: OFF
            *** new pump state name: OFF
            *** found: 3 pumps
            *** nothing to do, pump mode is already: OFF
            *** end
            DP:
            31288	2023-02-23 08:43:19.604	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** setting state of:javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch to old value: 2
            31288	2023-02-23 08:43:19.603	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** stderr: Error: Command failed: /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 0 0 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1 2023-02-23 08:43:08,684> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)] 2023-02-23 08:43:18,691> ERROR Exception during spa connection Traceback (most recent call last): File "/usr/local/lib/python3.10/site-packages/geckolib/async_spa.py", line 367, in connect await self._connect() File "/usr/local/lib/python3.10/site-packages/geckolib/async_spa.py", line 334, in _connect if not await self.struct.get( File "/usr/local/lib/python3.10/site-packages/geckolib/driver/async_spastruct.py", line 75, in get if await request.wait_for_response(protocol): File "/usr/local/lib/python3.10/site-packages/geckolib/driver/udp_protocol_handler.py", line 143, in wait_for_response await asyncio.sleep(GeckoConstants.ASYNCIO_SLEEP_TIMEOUT_FOR_YIELD) File "/usr/local/lib/python3.10/asyncio/tasks.py", line 605, in sleep return await future asyncio.exceptions.CancelledError Traceback (most recent call last): File "/home/pi/wellis/v4/spa_switchPump.py", line 132, in <module> asyncio.run(main()) File "/usr/local/lib/python3.10/asyncio/runners.py", line 44, in run return loop.run_until_complete(main) File "/usr/local/lib/python3.10/asyncio/base_events.py", line 649, in run_until_complete return future.result() File "/home/pi/wellis/v4/spa_switchPump.py", line 76, in main print(f"*** pump name: {spaman.facade.pumps[PUMP_ID].name}") AttributeError: 'NoneType' object has no attribute 'pumps'
            31288	2023-02-23 08:43:19.602	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** stdout: pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/usr/local/lib/python3.10/site-packages'] current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10 Log 1 Log 2 Log 3 Log 4 Total arguments passed: 6 Log 5 Connecting using client id 916b0096-ab56-4344-8728-43a8259c63c2 Connecting to spa id SPAe8:eb:1b:1c:5e:46 Switching pump id 0 Switching pump to state id 0 Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1 Log A Looking for spas on your network ... *** connecting to spa
            31288	2023-02-23 08:43:03.936	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** new pump state: 0
            31288	2023-02-23 08:43:03.936	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** pump id: 0
            31288	2023-02-23 08:43:03.936	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** spaId: SPAe8:eb:1b:1c:5e:46
            31288	2023-02-23 08:43:03.935	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** clientId: 916b0096-ab56-4344-8728-43a8259c63c2
            31288	2023-02-23 08:43:00.103	info	script.js.common.Draussen.Wellis_Whirlpool.get_updates_by_cron: exec: python3 /home/pi/wellis/v4/spa_updateBulk.py
            31288	2023-02-23 08:42:33.054	info	script.js.common.Draussen.Wellis_Whirlpool.PumpSwitches: *** stdout: pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/usr/local/lib/python3.10/site-packages'] current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10 Log 1 Log 2 Log 3 Log 4 Total arguments passed: 6 Log 5 Connecting using client id 916b0096-ab56-4344-8728-43a8259c63c2 Connecting to spa id SPAe8:eb:1b:1c:5e:46 Switching pump id 0 Switching pump to state id 1 Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1 Log A Looking for spas on your network ... *** connecting to spa *** pump name: Pump 1 *** pump modes: ['OFF', 'LO', 'HI'] *** current pump mode: HI *** new pump state name: LO *** found: 3 pumps *** pump mode is now: HI *** end
            Hier hatte es nicht geklappt.
            Blockly:
            31288	2023-02-23 08:47:22.093	warn	script.js.common.Draussen.Wellis_Whirlpool.Pumpe_1_schalten: pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/usr/local/lib/python3.10/site-packages'] current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10 Log 1 Log 2 Log 3 Log 4 Total arguments passed: 6 Log 5 Connecting using client id 916b0096-ab56-4344-8728-43a8259c63c2 Connecting to spa id SPAe8:eb:1b:1c:5e:46 Switching pump id 1 Switching pump to state id 2 Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch Log A Looking for spas on your network ... *** connecting to spa
            31288	2023-02-23 08:47:07.243	info	script.js.common.Draussen.Wellis_Whirlpool.Pumpe_1_schalten: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            31288	2023-02-23 08:47:07.242	warn	script.js.common.Draussen.Wellis_Whirlpool.Pumpe_1_schalten: exec: /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_switchPump.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 1 2 javascript.0.Datenpunkte.SwimSpa.0.Pumpen.P1.Switch
            31288	2023-02-23 08:47:07.106	info	Start javascript script.js.common.Draussen.Wellis_Whirlpool.Pumpe_1_schalten
            Es wird 🙂 Juhu!!
              @rrov1 für das Licht, werde ich die neuese Version ziehen.
              Versuch A:
              31288	2023-02-23 09:12:48.661	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: python3 spa_toggleLight.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 LI javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI
              31288	2023-02-23 09:14:15.874	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** setting state of:javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI.Switch to old value: true
              31288	2023-02-23 09:14:15.873	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** stderr: Error: Command failed: /usr/local/bin/python3.10 /home/pi/wellis/v4/spa_toggleLight.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 LI javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI 2023-02-23 09:14:05,767> INFO Found 1 spas ... [Wellness(SPAe8:eb:1b:1c:5e:46)] 2023-02-23 09:14:15,772> ERROR Exception during spa connection Traceback (most recent call last): File "/usr/local/lib/python3.10/site-packages/geckolib/async_spa.py", line 367, in connect await self._connect() File "/usr/local/lib/python3.10/site-packages/geckolib/async_spa.py", line 334, in _connect if not await self.struct.get( File "/usr/local/lib/python3.10/site-packages/geckolib/driver/async_spastruct.py", line 75, in get if await request.wait_for_response(protocol): File "/usr/local/lib/python3.10/site-packages/geckolib/driver/udp_protocol_handler.py", line 143, in wait_for_response await asyncio.sleep(GeckoConstants.ASYNCIO_SLEEP_TIMEOUT_FOR_YIELD) File "/usr/local/lib/python3.10/asyncio/tasks.py", line 605, in sleep return await future asyncio.exceptions.CancelledError Traceback (most recent call last): File "/home/pi/wellis/v4/spa_toggleLight.py", line 103, in <module> asyncio.run(main()) File "/usr/local/lib/python3.10/asyncio/runners.py", line 44, in run return loop.run_until_complete(main) File "/usr/local/lib/python3.10/asyncio/base_events.py", line 649, in run_until_complete return future.result() File "/home/pi/wellis/v4/spa_toggleLight.py", line 55, in main if len(spaman.facade.lights) > 0: AttributeError: 'NoneType' object has no attribute 'lights'
              31288	2023-02-23 09:14:15.872	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** stdout: pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/usr/local/lib/python3.10/site-packages'] current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10 Total arguments passed: 5 Connecting using client id 916b0096-ab56-4344-8728-43a8259c63c2 Connecting to spa id SPAe8:eb:1b:1c:5e:46 Switching light: LI Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI Looking for spas on your network ... *** connecting to spa
              31288	2023-02-23 09:14:01.016	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: python3 spa_toggleLight.py 916b0096-ab56-4344-8728-43a8259c63c2 SPAe8:eb:1b:1c:5e:46 LI javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI
              31288	2023-02-23 09:14:01.016	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** light key: LI
              31288	2023-02-23 09:14:01.016	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** spaId: SPAe8:eb:1b:1c:5e:46
              31288	2023-02-23 09:14:01.015	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** clientId: 916b0096-ab56-4344-8728-43a8259c63c2
              Versuch B:
              31288	2023-02-23 09:15:34.232	info	script.js.common.Draussen.Wellis_Whirlpool.LightToggle: *** stdout: pfad: ['/home/pi/wellis/v4', '/usr/local/lib/python310.zip', '/usr/local/lib/python3.10', '/usr/local/lib/python3.10/lib-dynload', '/usr/local/lib/python3.10/site-packages'] current version: 3.10.9 (main, Jan 7 2023, 17:15:23) [GCC 8.3.0] interpreter directory: /usr/local/bin/python3.10 Total arguments passed: 5 Connecting using client id 916b0096-ab56-4344-8728-43a8259c63c2 Connecting to spa id SPAe8:eb:1b:1c:5e:46 Switching light: LI Got channel for update: javascript.0.Datenpunkte.SwimSpa.0.Lichter.LI Looking for spas on your network ... *** connecting to spa *** light count: 1 *** found light with key LI and name: Lights with state True *** switching light off *** light mode is now: False *** end
              • rrov1
                @tklein Na sieht doch gut aus. Ich habe mir die beiden Fehler angeschaut, da kannst du momentan nichts machen, die passieren ggf. in allen *.py-Skripten. Hier muss ich noch das Fehlerhandling verbessern, steht auf der ToDo Liste als nächstes, weil mich das auch nervt. Ich würde dieses WE aber erst mal das Ändern des Wasserpflegemodus noch fertig machen, weil das schon halbfertig rumliegt und ich dann glaub ich erst mal alle grundsätzlichen Sachen die man man so können muss fertig habe.
                  @rrov1 ok, bei den remindern gibt es auch noch herausforderungen bei mir. 🙂 da kommt immer anzahl 0
                  Es wird nicht langweilig. 🙂
                  Was hälst du von Versionsnummern in den Skripten?
                  LG
                  Thomas
                  • rrov1
                    @tklein Dringe
                    Jup, dringend nötig :-), sowohl auf Javascript als auch auf Python Ebene.
                    • rrov1
                      rrov1 @rrov1 last edited by
                      @rrov1 So, den Wasserpflegemodus kann man jetzt auch setzen:
                      • Im Javascript Adapter: WatercareMode.js hinzufügen
                      • Neues Script: spa_setWatercareMode.py (Parameter: ClientGUID SpaId waterCareModeIdx DevicePath) bereitstellen und die IP vom ioBroker nicht vergessen dort einzutragen.
                      Wichtig: Ich habe gesehen, das es eine neue Version 0.4.8 der geckolib gibt. Ich werde diese einsetzen (ab nächste Woche), bitte mal aktualisieren. Bei mir war ein:
                      pip install geckolib --upgrade
                      fällig, bei Dir evtl. mit vorangestellten "sudo"...
                      Ich werde
                        tklein @rrov1 last edited by tklein
                        thx, das update hat geklappt. Habe jetzt auch die 0.4.8 Version. WaterCareMode werde ich wahrscheinlich erst später mal mit einer PV Anlage nutzen.
                        Kannst du mir bitte dennoch einen exemplarischen Aufruf zum Wassermode posten? Das kann ich nicht so richtig greifen?
                        --> "waterCareModeIdx" Wäre das z.B. Energy Saving. Müssen die in "" stehen?
                        --> ist das der korrekte/angedachte Devicepath? javascript.0.Datenpunkte.SwimSpa.0.WasserpflegeSwitch
                         sudo pip3 install geckolib --upgrade
                        Collecting geckolib
                          Downloading https://files.pythonhosted.org/packages/95/b5/6b1293493ddbcef8c576a68adf05cdcc40b9387619507179d3b4607beabd/geckolib-0.4.8-py3-none-any.whl (1.2MB)
                            100% |████████████████████████████████| 1.2MB 341kB/s
                        Requirement already satisfied, skipping upgrade: python-version>="3.7" in /usr/local/lib/python3.7/dist-packages (from geckolib) (0.0.2)
                        Installing collected packages: geckolib
                          Found existing installation: geckolib 0.4.7
                            Uninstalling geckolib-0.4.7:
                              Successfully uninstalled geckolib-0.4.7
                        Successfully installed geckolib-0.4.8
                        T rrov1 2 Replies Last reply Reply Quote 0
                          tklein @tklein last edited by
                          Der Teufel steckt im Detail.
                          Wenn ich die Zeiltemp per DP ändere, wird der immer mit dem Ergebnis aus dem API Call überschrieben. (A,B,D)
                          Wenn die Zieltemp per Kommandozeile geändert wird, bleibt der Wert. (C)
                          Dann muss ich noch die Herausforderung meistern, dass Alexa den Temeperaturwert (per iot Adapter als Thermostat) nicht korrekt übernimmt. Wert sollte z.B. 38 Grad sein, dann wird der auf 24,5 gesetzt. Das hat aber ja nix mit deinem Code zu tun.
                          • rrov1
                            waterCareModeIdx: Schau mal in den Datenpunkt "WasserpflegeModi". Dort sollten 5 Werte drinnen stehen, das sind die wählbaren Wasserpflegemodi. Der Index ist praktisch 0 basiert, also der erste Wert "Away from Home" == 0, die weiteren dann 1-4.
                            devicePath: Schau mal im Objektbaum die Spalte Type an, das Device ist der Pfad: javascript.0.Datenpunkte.SwimSpa.0
                            ioBroker kennt da einige Typen, bei mir kommen 4 vor:
                            folder - einfach nur eine Ebene im Baum
                            device - der Pfad zum Spa Controller Gerät
                            channel - ein Pfad unter dem einige states gleichen Typs gruppiert werden, z.B. Pumpen, Erinnerungen, Lichter, ...
                            state - der Datenpunkt der einen tatsächlichen Wert enthält.
                            Manchmal, wenn ich in meinen Scripten mehrere States auf einmal setzen möchte (in dem Fall die DP Wasserpflege und WasserpflegeSwitch), dann übergebe ich dem Script den übergeordneten Pfad und ergänze dann nur noch die Namen der Datenpunkte. Wenn ich nur einen Datenpunkt aktualisieren will (Zieltemperatur), dann übergebe ich dem Skript den Namen des Datenpunktes.
                            • rrov1
                              rrov1 @tklein last edited by rrov1
                              Ich bin mir gerade nicht sicher ob ich dich richtig verstehe. Meine Vermutung ist, das du beim setzen des Datenpunktes zusätzlich ack=true mitgibst (zumindest die Fälle A&D). Da passiert aber nichts. Ich halte mich an die ioBroker Logik, nach der ein "GUI"-Element den Datenpunkt setzt mit ack=false (das ist der Default, wenn man nichts mitgibt). Nur in dem Fall wird über die on()-Subscription ein Script ausgelöst, was tatsächlich eine Aktion auf dem Zielgerät (Spa Controller) auslöst und, wenn erfolgreich, den Datenpunkt noch mal mit dem neuen Wert und ack=true setzt.
                              Prüfe bitte auch im Protokoll, ob mein Script nach setzen der neuen Zieltemperatur wirklich aufgerufen wird.
                              Alexa igrnoriere ich seit über einen Jahr, die ist so umständlich und versteht mich nicht zuverlässig genug.
                                @rrov1 ja es war ack = true das Problem. Wie immer sehr gut und verständlich erklärt.
                                  ach so, quasi ein batchänderung wobei der passenste "root"-ordner übergeben wird.
                                  Fühl dich eingeladen, wenn du mal im Raum MS/OS unterwegs bist. Lege gerne etwas auf den Grill oder es gibt einen Cappuchino etc. Danke für die unzähligen erstklassigen Hilfestellungen!
                                  • rrov1
                                    @tklein Danke für die Einladung. Ich helfe doch gerne und das Forum ist ja auch dazu da etwas Wissen zu teilen. Wenn ich mal ne Frage habe, hoffe ich ja auch, das man mir hilft. Außerdem habe ich so einen Grund an der Steuerung zu feilen, nur für mich hätte wahrscheinlich das auslesen der Parameter gereicht und es hätte so noch die nächsten x Jahre rumgelegen.
                                    Ich versuche jetzt erst mal die gleichzeitigen Abfragen auszuschließen, so das keine Fehler mehr bei den Aufrufen auftreten. Ich denke ich habe da einen Ansatz.
                                    • rrov1
                                      @tklein Hallo, es hat zwar ein bisschen gedauert, aber ich habe jetzt ein größeres Update der Skripte fertig, das ein die aus meiner Sicht wichtigsten Defizite erst mal bereinigt:
                                      • keine Konstanten in den Python Skripten mehr (alles wird per Parameter übergeben)
                                      • kein cron Schedule mehr, sondern alles in ioBroker-Schedules
                                      • Die Skripte passen auf, das nicht mehrere gleichzeitig laufen (da der Spa Controller mit mehreren gleichzeitigen Anfragen nicht zurecht kommt)
                                      Das Update liegt auf github. Beim Einspielen vorgehen wie dort beschrieben:
                                      1. SpaGlobal.js bereitstellen
                                      2. SpaVariablen.js aktualisieren und ausführen, da sich die Datenpunkte geändert haben
                                      3. Die Skripte für die Konfiguration (SpaUpdateConfig.js + spa_config.py, sowie SpaUpdateValues.js + spa_updateBulk.px) austauschen und testen
                                      4. Weitere Skripte für das Schalten verschiedener Funktionen austauschen (jeweils Javascript und Python, wie in der Doku) und testen
                                      Was noch nicht geht sind die Erinnerungen. Ich habe leider auch kein Feedback auf meine Frage bekommen, die geckolib kann die Werte nicht auslesen 😞 .
                                      Schönes WE,
                                      rrov1
                                      • rrov1
                                        Es gibt wieder mal ein Update auf github, welches u.a. dafür sorgt, dass die Werte für Erinnerungen aktualisiert werden. Beim Einspielen vorgehen wie dort als Installation/Update beschrieben, die Datenpunkte müssen aktualisiert werden und alle Skripte ausgetauscht (JavaScript und Python).
                                          Bernie last edited by Bernie
                                          Hallo rrov1,
                                          ich habe lt. Deiner Anleitung mein Gecko in.Touch2 unter ioBroker zum laufen gebracht.
                                          Dafür schicke ich Dir ein ganz großes Dankeschön für die reingesteckte Arbeit.
                                          Tolle Leistung!! Vielen Dank.
                                          Noch einen schönen RestSonntag 😉
                                          Bernd
                                          • rrov1
                                            rrov1 @Bernie last edited by
                                            @bernie Schön, dann hat sich der Aufwand ins aufhübschen der Anleitung ja schon gelohnt 🙂 . Bis letztes Jahr dachte ich noch, ich wäre der Einzige hier der so eine Steuerung hat/nutzt, denn auch bei den Adapter Requests auf github (https://github.com/ioBroker/AdapterRequests/issues/720) haben bisher nur 3 den Daumen hochgehoben.
                                            Konni1234 created this issue in ioBroker/AdapterRequests
                                            open Gecko intouch2 Whirlpoolcontrol #720
                                            81.1k
                                            27807
