    4. Huawei Sun2000 & ioBroker via JS script funktioniert
    • oswibz
      oswibz @Thomas42 last edited by
      @thomas42
      wo finde ich den korrekten ID?
        Thomas42 @oswibz last edited by
        @oswibz Keine Ahnung, ich habe geraten.
        Das Smartmeter scheint immer die Null zu sein, der erste WR war bei die 1, der zweite die 2.
          WILHER last edited by
          Hallo zusammen, versuche auch meinen SUN2000 ausgelesen zu bekommen, leider funktioniert es nicht. Es werde auch irgendwie keine Werte geschrieben. Habe 1 String, 1 Batteriespeicher LUNA2000 10kw. Was fehlt hier ggf noch?
          // License: Beerware! Do what ever you like with this, but I'm not liable for anything that you do with it.
          // If you like this code, feel free to buy me a beer ...
          // Have fun with it! der Kachel
          var ModbusRTU = require("modbus-serial");
          var client = new ModbusRTU();
          var modbusErrorMessages = [
          "Unknown error",
          "Illegal function (device does not support this read/write function)",
          "Illegal data address (register not supported by device)",
          "Illegal data value (value cannot be written to this register)",
          "Slave device failure (device reports internal error)",
          "Acknowledge (requested data will be available later)",
          "Slave device busy (retry request again later)"
          // open connection to a tcp line
          client.setTimeout(10000);
          // Enter your inverter modbus IP and port here:
          client.connectTCP("192.168.10.101", { port: 502 });
          // Enter the Modbus-IDs of your Sun2000 inverters here:
          const ModBusIDs = [16, 1];
          // On which Modbus-ID can we reach the power meter? (via Sun2000!)
          const PowerMeterID = 0;
          // Enter your battery stack setup. 2 dimensional array.
          // e.g. [[3, 2], [3, 0]] means:
          // First inverter has two battery stacks with 3 + 2 battery modules
          // while second inverter has only one battery stack with 3 battery modules
          const BatteryUnits = [[3, 2], [3, 0]];
          // These register spaces need to be read:
          const RegisterSpacesToReadContinuously = [[30000, 81], [37100, 114], [32000, 116], [37000, 68], [37700, 100], [37800, 100], [38200, 100], [38300, 100], [38400, 100], [35300, 40]];
          var RegisterSpacesToReadContinuouslyPtr = 0;
          var GlobalDataBuffer = new Array(2);
          for(var i=0; i<ModBusIDs.length; i++) {
          GlobalDataBuffer[i] = new Array(50000); // not optimized....
          // Some helper functions:
          function readUnsignedInt16(array) {
          var value = array[0];
          return value;
          function readUnsignedInt32(array) {
          var value = array[0] * 256 * 256 + array[1];
          return value;
          function readSignedInt16(array) {
          var value = 0;
          if (array[0] > 32767)
          value = array[0] - 65535;
          else
          value = array[0];
          return value;
          function readSignedInt32(array) {
          var value = 0;
          for (var i = 0; i < 2; i++) {
          value = (value << 16) | array[i];
          return value;
          function getU16(dataarray, index) {
          var value = readUnsignedInt16(dataarray.slice(index, index+1));
          return value;
          function getU32(dataarray, index) {
          var value = readUnsignedInt32(dataarray.slice(index, index+2));
          return value;
          function getI16(dataarray, index) {
          var value = readSignedInt16(dataarray.slice(index, index+1));
          return value;
          function getI32(dataarray, index) {
          var value = readSignedInt32(dataarray.slice(index, index+2));
          return value;
          function getString(dataarray, index, length) {
          var shortarray = dataarray.slice(index, index+length);
          var bytearray = [];
          for(var i = 0; i < length; i++) {
          bytearray.push(dataarray[index+i] >> 8);
          bytearray.push(dataarray[index+i] & 0xff);
          var value = String.fromCharCode.apply(null, bytearray);
          return value;
          function getZeroTerminatedString(dataarray, index, length) {
          var bytearray = [];
          var value2 = new String(value).trim();
          return value2;
          function forcesetState(objectname, value, options) {
          if(!existsState(objectname)) {
          createState(objectname, value, options);
          else {
          setState(objectname, value);
          // Functions to map registers into ioBreaker objects:
          function processOptimizers(id) {
          forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerTotalNumber", getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerOnlineNumber", getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".OptimizerFeatureData", getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
          function processInverterPowerAdjustments(id) {
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode", getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue", getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand", getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode", getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue", getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower", getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
          function processBattery(id) {
          // Battery registers 1-15 (Stack 1 related)
          if(BatteryUnits[id-1][0] > 0) {
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus", getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage", getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC", getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode", getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower", getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower", getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.FaultID", getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent", getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature", getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime", getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion", getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.BMSversion", getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
          // Battery registers 16+17 (Storage-related)
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumChargePower", getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.MaximumDischargePower", getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
          // Battery register 18-20 (Stack 1 related)
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SN",                         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",             getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
          // Battery register 21-31 (Stack 2 related)
          if(BatteryUnits[id-1][1] > 0) {
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SN",                     getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
          // Battery register 32-41 (Storage related)
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
          // Battery registers 42+43 (Battery stack related)
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
              forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
          // Registers 44 to 98: (Battery pack related)
          for(var i = 1; i <= 2; i++){
              if(BatteryUnits[id-1][i-1] >= 0) {
                  for(var j = 1; j <= BatteryUnits[id-1][i-1]; j++) {
                      //[[38200, 38242, 38284] [38326, 38368, 38410]]; (+42 for each battery pack, +126 for each stack)
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                      // [[38452, 38454, 38456][38458, 38460, 38462]] ( +2 for each pack, +6 for each stack)
                      createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                      createState("Solarpower.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
          // Battery registers 110-141 are not supported by this script yet!
          function ProcessPowerMeterStatus() {
          forcesetState("Solarpower.Huawei.Meter.Status", getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Meter.VoltageL1", getI32(GlobalDataBuffer[PowerMeterID], 37101) / 10, {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Meter.VoltageL2", getI32(GlobalDataBuffer[PowerMeterID], 37103) / 10, {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Meter.VoltageL3", getI32(GlobalDataBuffer[PowerMeterID], 37105) / 10, {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Meter.CurrentL1", getI32(GlobalDataBuffer[PowerMeterID], 37107) / 100, {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Meter.CurrentL2", getI32(GlobalDataBuffer[PowerMeterID], 37109) / 100, {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Meter.CurrentL3", getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Meter.ActivePower", getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Meter.ReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
          forcesetState("Solarpower.Huawei.Meter.PowerFactor", getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Meter.GridFrequency", getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
          forcesetState("Solarpower.Huawei.Meter.PositiveActiveEnergy", getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Meter.ReverseActiveEnergy", getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
          forcesetState("Solarpower.Huawei.Meter.MeterType", getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Meter.VoltageL1-L2", getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Meter.VoltageL2-L3", getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Meter.VoltageL3-L1", getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Meter.ActivePowerL1", getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Meter.ActivePowerL2", getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Meter.ActivePowerL3", getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
          forcesetState("Solarpower.Huawei.Meter.MeterModel", getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
          function processInverterStatus(id) {
          forcesetState("Solarpower.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage", getI16(GlobalDataBuffer[id-1], 32016) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current", getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage", getI16(GlobalDataBuffer[id-1], 32018) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current", getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".InputPower", getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage", getU16(GlobalDataBuffer[id-1], 32066) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage", getU16(GlobalDataBuffer[id-1], 32067) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage", getU16(GlobalDataBuffer[id-1], 32068) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage", getU16(GlobalDataBuffer[id-1], 32069) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage", getU16(GlobalDataBuffer[id-1], 32070) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage", getU16(GlobalDataBuffer[id-1], 32071) / 10 , {name: "", unit: "V"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current", getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current", getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current", getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay", getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ActivePower", getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower", getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor", getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency", getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Efficiency", getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature", getI16(GlobalDataBuffer[id-1], 32087) / 10 , {name: "", unit: "°C"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance", getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus", getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".FaultCode", getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".StartupTime", getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime", getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield", getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield", getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
          function ProcessDeviceInfo(id) {
          // Note: Manual says its quantitiy is 15, but that is the number (+1) of 8bit characters
          forcesetState("Solarpower.Huawei.Inverter." + id + ".Model", getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".SN", getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".PN", getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".ModelID", getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".PVStrings", getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".MPPTrackers", getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxRatedPower", getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxActivePower", getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxApparentPower", getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerToGrid", getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
          forcesetState("Solarpower.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid", getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
          function readRegisterSpace(id, address, length) {
          client.setID(ModBusIDs[id-1]);
          client.readHoldingRegisters(address, length, function(err, data) {
          if (err) {
          console.warn("Error received reading address " + address + " from id: " + ModBusIDs[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
          else
          console.debug("Read data from id/address " + ModBusIDs[id-1] + "/" + address + "\nData is: " + data.data);
          GlobalDataBuffer[id-1][address+i] = data.data[i];
          function processData() {
          console.log("Processing new data...");
          for(var i = 1; i <= ModBusIDs.length; i++) {
          ProcessDeviceInfo(i);
          processInverterStatus(i);
          processBattery(i);
          processInverterPowerAdjustments(i);
          processOptimizers(i);
          ProcessPowerMeterStatus();
          console.log("Processing done!");
          // This is the main function triggering a read via modbus-tcp every two seconds.
          // Processing of data is triggered as soon as one complete set of registers is copied.
          var triggerprocessing = 0;
          var currentinverter = 1;
          setInterval(function() {
          if(triggerprocessing == 1) {
          processData();
          console.log("Triggering read of inverter " + currentinverter + " at address " + RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0] + " with length " +  RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
          readRegisterSpace(currentinverter, RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][0], RegisterSpacesToReadContinuously[RegisterSpacesToReadContinuouslyPtr][1]);
          RegisterSpacesToReadContinuouslyPtr++;
          if(RegisterSpacesToReadContinuouslyPtr >= RegisterSpacesToReadContinuously.length) {
              currentinverter++
              if(currentinverter > ModBusIDs.length){
                  triggerprocessing = 1;
          }, 2000);
          Wäre schön wenn mir da jemand helfen könnte.
            Thomas42 @WILHER last edited by
            @wilher Hi,
            wäre eventuell hifreich, wenn Du Dein Log posten würdest und nicht das Script 🙂
            • Z
              zoid1988 @oswibz last edited by
              @oswibz
              Leider gibt es hier bei mir nichts neues ... Es funktioniert immer noch nicht ...
              • Alex Warkentin
                Alex Warkentin last edited by
                Ich habe das Script gerade erfolgreich eingerichtet. War nicht ganz so einfach. Daher hier noch ein paar Tipps:
                Javascript Adapter und Nodejs sollten auf dem neuesten Stand sein, oder zumindest zueinander passen.
                In den Einstellungen des Javascript-Adapters muss die Erweiterung "modbus-serial" eingetragen werden (einfach reinschreiben und bestätigen). Bei mir meckert das Script danach trotzdem über die Zeile, funktioniert aber.
                Die IP eures Dongles muss eingetragen werden (ohne $$$)
                client.connectTCP("192.xxx.xxx.xxx", { port: 502 });
                Die IDs des WRs und der Batterien könnt ihr im Gerätemanagement in der Fusionsolar Web-Oberfläche herausfinden, oder direkt am Gerät. Dafür braucht ihr aber den Installateur-Zugang. Normalerweise hat der WR aber die ID 1 und der SmartMeter die 0. Bei der Batterie kann ich nicht weiterhelfen. Habe keine.
                const modBusIDs = [1];
                const powerMeterID = 0;
                Die existState Funktion ist fehlerhaft, da objectname nicht den vollen Pfad beinhaltet. So funktioniert es:
                if(!existsState("javascript.0." + objectname))
                Bei der Start- und Stopzeit habe ich die Sekunden in Datum umgewandelt. Bitte auf Groß-Kleinschreibung achten
                ForceSetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",              new Date(GetU32(globalDataBuffer[id-1], 32091)*1000),          {name: "", unit: ""});
                ForceSetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",             new Date(GetU32(globalDataBuffer[id-1], 32093)*1000),          {name: "", unit: ""});
                  striegel26 @Alex Warkentin last edited by striegel26
                  Hallo zusammen
                  ich brauche mal eure Hilfe. Das Script scheint soweit zu funktionieren, aber es werden leider die Werte des PowerMeters nicht aktualisiert, das erste mal hat es funktioniert. Was habe ich falsch gemacht ?
                  VG Dennis
                      "Unknown error",
                  client.connectTCP("192.168.178.95", { port: 502 });
                  const PowerMeterID = 11;
                  const BatteryUnits = [[3, 0], [3, 0]];
                      return value;
                      return value;
                      var value = 0;
                      else
                          value = array[0];
                      return value;
                      var value = 0;
                      return value;
                      return value;
                      return value;
                      return value;
                      return value;
                      var bytearray = [];
                      return value;
                      var bytearray = [];
                      return value2;
                      if(!existsState("javascript.0." + objectname)) {
                          console.log("createstate " +  objectname + " to value " + value);
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerTotalNumber",     getU16(GlobalDataBuffer[id-1], 35200), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerOnlineNumber",    getU16(GlobalDataBuffer[id-1], 35201), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".OptimizerFeatureData",     getU16(GlobalDataBuffer[id-1], 35202), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementMode",     getU16(GlobalDataBuffer[id-1], 35300), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementValue",    getU32(GlobalDataBuffer[id-1], 35301), {name: "", unit: ""}); // Note: This might be an error in the manual. It says register 35302 with quantity 2, but on 35303 is already the next value.
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ActiveAdjustementCommand",  getU16(GlobalDataBuffer[id-1], 35303), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementMode",   getU16(GlobalDataBuffer[id-1], 35304), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementValue",  getU32(GlobalDataBuffer[id-1], 35305), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.ReactiveAdjustementCommand",getU16(GlobalDataBuffer[id-1], 35307), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActiveAdjustement.PowerMeterActivePower",     getI32(GlobalDataBuffer[id-1], 35313), {name: "", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37000), {name: "", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37001), {name: "Charge and Discharge Power", unit: "W"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37003) / 10, {name: "Busvoltage", unit: "V"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37004) / 10, {name: "Battery SOC", unit: "%"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.WorkingMode",            getU16(GlobalDataBuffer[id-1], 37006), {name: "Working Mode", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedChargePower",       getU32(GlobalDataBuffer[id-1], 37007), {name: "", unit: "W"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RatedDischargePower",    getU32(GlobalDataBuffer[id-1], 37009), {name: "", unit: "W"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.FaultID",                getU16(GlobalDataBuffer[id-1], 37014), {name: "", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37015) / 100, {name: "", unit: "kWh"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37017) / 100, {name: "", unit: "kWh"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37021) / 10, {name: "Buscurrent", unit: "A"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37022) / 10, {name: "Battery Temperatue", unit: "°C"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.RemainingChargeDischargeTime", getU16(GlobalDataBuffer[id-1], 37025), {name: "", unit: "mins"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.DCDCversion",            getZeroTerminatedString(GlobalDataBuffer[id-1], 37026, 10), {name: "", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.BMSversion",             getZeroTerminatedString(GlobalDataBuffer[id-1], 37036, 10), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumChargePower",                getU32(GlobalDataBuffer[id-1], 37046), {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.MaximumDischargePower",             getU32(GlobalDataBuffer[id-1], 37048), {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SN",                         getZeroTerminatedString(GlobalDataBuffer[id-1], 37052, 10), {name: "Serialnumber", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalCharge",                getU32(GlobalDataBuffer[id-1], 37066) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.TotalDischarge",             getU32(GlobalDataBuffer[id-1], 37068) / 100, {name: "", unit: "kWh"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SN",                     getZeroTerminatedString(GlobalDataBuffer[id-1], 37700, 10), {name: "Serialnumber", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatterySOC",             getU16(GlobalDataBuffer[id-1], 37738) / 10, {name: "", unit: "%"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.RunningStatus",          getU16(GlobalDataBuffer[id-1], 37741), {name: "", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.ChargeAndDischargePower",getI32(GlobalDataBuffer[id-1], 37743), {name: "", unit: "W"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayChargeCapacity",    getU32(GlobalDataBuffer[id-1], 37746) / 100, {name: "", unit: "kWh"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37748) / 100, {name: "", unit: "kWh"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusVoltage",             getU16(GlobalDataBuffer[id-1], 37750) / 10, {name: "", unit: "V"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BusCurrent",             getI16(GlobalDataBuffer[id-1], 37751) / 10, {name: "", unit: "A"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.BatteryTemperature",     getI16(GlobalDataBuffer[id-1], 37752) / 10, {name: "", unit: "°C"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalCharge",                 getU32(GlobalDataBuffer[id-1], 37753) / 100, {name: "", unit: "kWh"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.TotalDischarge",              getU32(GlobalDataBuffer[id-1], 37755) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RatedCapacity", getU32(GlobalDataBuffer[id-1], 37758) / 1, {name: "", unit: "Wh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.SOC", getU16(GlobalDataBuffer[id-1], 37760) / 10, {name: "", unit: "%"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.RunningStatus", getU16(GlobalDataBuffer[id-1], 37762) / 1, {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusVoltage", getU16(GlobalDataBuffer[id-1], 37763) / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.BusCurrent", getI16(GlobalDataBuffer[id-1], 37764) / 10, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 37765) / 1, {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalCharge", getU32(GlobalDataBuffer[id-1], 37780) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.TotalDischarge", getU32(GlobalDataBuffer[id-1], 37782) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayChargeCapacity", getU32(GlobalDataBuffer[id-1], 37784) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Battery.CurrentDayDischargeCapacity", getU32(GlobalDataBuffer[id-1], 37786) / 100, {name: "Current DayDiscarge ", unit: "kWh"});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.2.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37814, 8), {name: "Softwareversion", unit: ""});
                          forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack.1.SoftwareVersion",    getZeroTerminatedString(GlobalDataBuffer[id-1], 37799, 8), {name: "Softwareversion", unit: ""});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".SN",                getZeroTerminatedString(GlobalDataBuffer[id-1], 38200+(i-1)*126+(j-1)*42, 6), {name: "", unit: ""});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".FirmwareVersion",   getZeroTerminatedString(GlobalDataBuffer[id-1], 38210+(i-1)*126+(j-1)*42, 8), {name: "", unit: ""});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".WorkingStatus",     getU16(GlobalDataBuffer[id-1], 38228+(i-1)*126+(j-1)*42), {name: "", unit: ""});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".BatterySOC",        getU16(GlobalDataBuffer[id-1], 38229+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "%"});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".ChargeAndDischargePower", getI32(GlobalDataBuffer[id-1], 38233+(i-1)*126+(j-1)*42) / 1000, {name: "", unit: "kW"});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Voltage",           getU16(GlobalDataBuffer[id-1], 38235+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "V"});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".Current",           getI16(GlobalDataBuffer[id-1], 38236+(i-1)*126+(j-1)*42) / 10, {name: "", unit: "A"});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalCharge",       getU32(GlobalDataBuffer[id-1], 38238+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                                  forcesetState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".TotalDischarge",    getU32(GlobalDataBuffer[id-1], 38240+(i-1)*126+(j-1)*42) / 100, {name: "", unit: "kWh"});
                                  createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MaxTemperature", getI16(GlobalDataBuffer[id-1], 38452+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                                  createState("Solarpower2.Huawei.Inverter." + id + ".Batterystack." + i + ".Battery" + j + ".MinTemperature", getI16(GlobalDataBuffer[id-1], 38453+(i-1)*6+(j-1)*2) / 10, {name: "", unit: "°C"});
                      forcesetState("Solarpower2.Huawei.Meter.Status",          getU16(GlobalDataBuffer[PowerMeterID], 37100), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Meter.VoltageL1",        getI32(GlobalDataBuffer[PowerMeterID], 37101)  / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Meter.VoltageL2",        getI32(GlobalDataBuffer[PowerMeterID], 37103)  / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Meter.VoltageL3",        getI32(GlobalDataBuffer[PowerMeterID], 37105)  / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Meter.CurrentL1",        getI32(GlobalDataBuffer[PowerMeterID], 37107)  / 100, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Meter.CurrentL2",        getI32(GlobalDataBuffer[PowerMeterID], 37109)  / 100, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Meter.CurrentL3",        getI32(GlobalDataBuffer[PowerMeterID], 37111) / 100, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Meter.ActivePower",     getI32(GlobalDataBuffer[PowerMeterID], 37113) / 1, {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Meter.ReactivePower",   getI32(GlobalDataBuffer[PowerMeterID], 37115) / 1, {name: "", unit: "Var"});
                      forcesetState("Solarpower2.Huawei.Meter.PowerFactor",     getI16(GlobalDataBuffer[PowerMeterID], 37117) / 1000, {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Meter.GridFrequency",   getI16(GlobalDataBuffer[PowerMeterID], 37118) / 100, {name: "", unit: "Hz"});
                      forcesetState("Solarpower2.Huawei.Meter.PositiveActiveEnergy",     getI32(GlobalDataBuffer[PowerMeterID], 37119) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Meter.ReverseActiveEnergy",      getI32(GlobalDataBuffer[PowerMeterID], 37121) / 100, {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Meter.AccumulatedReactivePower", getI32(GlobalDataBuffer[PowerMeterID], 37123) / 100, {name: "", unit: "kVarh"});
                      forcesetState("Solarpower2.Huawei.Meter.MeterType",       getU16(GlobalDataBuffer[PowerMeterID], 37125), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Meter.VoltageL1-L2",       getI32(GlobalDataBuffer[PowerMeterID], 37126) / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Meter.VoltageL2-L3",       getI32(GlobalDataBuffer[PowerMeterID], 37128) / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Meter.VoltageL3-L1",       getI32(GlobalDataBuffer[PowerMeterID], 37130) / 10, {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Meter.ActivePowerL1",    getI32(GlobalDataBuffer[PowerMeterID], 37132) / 1, {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Meter.ActivePowerL2",    getI32(GlobalDataBuffer[PowerMeterID], 37134) / 1, {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Meter.ActivePowerL3",    getI32(GlobalDataBuffer[PowerMeterID], 37136) / 1, {name: "", unit: "W"});
                      forcesetState("Solarpower2.Huawei.Meter.MeterModel",      getU16(GlobalDataBuffer[PowerMeterID], 37138), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".State1", getU16(GlobalDataBuffer[id-1], 32000), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".State2", getU16(GlobalDataBuffer[id-1], 32001), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".State3", getU16(GlobalDataBuffer[id-1], 32002), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm1", getU16(GlobalDataBuffer[id-1], 32008), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm2", getU16(GlobalDataBuffer[id-1], 32009), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Alarm3", getU16(GlobalDataBuffer[id-1], 32010), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Voltage",       getI16(GlobalDataBuffer[id-1], 32016) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.1_Current",       getI16(GlobalDataBuffer[id-1], 32017) / 100 , {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Voltage",       getI16(GlobalDataBuffer[id-1], 32018) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".String.2_Current",       getI16(GlobalDataBuffer[id-1], 32019) / 100 , {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".InputPower",             getI32(GlobalDataBuffer[id-1], 32064) / 1000, {name: "", unit: "kW"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",           getU16(GlobalDataBuffer[id-1], 32066) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",           getU16(GlobalDataBuffer[id-1], 32067) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",           getU16(GlobalDataBuffer[id-1], 32068) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Voltage",            getU16(GlobalDataBuffer[id-1], 32069) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Voltage",            getU16(GlobalDataBuffer[id-1], 32070) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Voltage",            getU16(GlobalDataBuffer[id-1], 32071) / 10  , {name: "", unit: "V"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L1_Current",         getI32(GlobalDataBuffer[id-1], 32072) / 1000, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L2_Current",         getI32(GlobalDataBuffer[id-1], 32074) / 1000, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Grid.L3_Current",         getI32(GlobalDataBuffer[id-1], 32076) / 1000, {name: "", unit: "A"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".PeakActivePowerDay",     getI32(GlobalDataBuffer[id-1], 32078) / 1000, {name: "", unit: "kW"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ActivePower",            getI32(GlobalDataBuffer[id-1], 32080) / 1000, {name: "", unit: "kW"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ReactivePower",          getI32(GlobalDataBuffer[id-1], 32082) / 1000, {name: "", unit: "kVar"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".PowerFactor",            getI16(GlobalDataBuffer[id-1], 32084) / 1000, {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".GridFrequency",          getU16(GlobalDataBuffer[id-1], 32085) / 100 , {name: "", unit: "Hz"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Efficiency",             getU16(GlobalDataBuffer[id-1], 32086) / 100 , {name: "", unit: "%"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".InternalTemperature",    getI16(GlobalDataBuffer[id-1], 32087) / 10  , {name: "", unit: "°C"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".InsulationResistance",   getU16(GlobalDataBuffer[id-1], 32088) / 1000, {name: "", unit: "MOhm"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".DeviceStatus",              getU16(GlobalDataBuffer[id-1], 32089), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".FaultCode",                 getU16(GlobalDataBuffer[id-1], 32090), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".StartupTime",               getU16(GlobalDataBuffer[id-1], 32091), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ShutdownTime",              getU16(GlobalDataBuffer[id-1], 32093), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".AccomulatedEnergyYield",    getU16(GlobalDataBuffer[id-1], 32106), {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".DailyEnergyYield",          getU16(GlobalDataBuffer[id-1], 32114), {name: "", unit: "kWh"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".Model",  getZeroTerminatedString(GlobalDataBuffer[id-1], 30000, 8), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".SN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30015, 6), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".PN",     getZeroTerminatedString(GlobalDataBuffer[id-1], 30025, 6), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".ModelID",           getU16(GlobalDataBuffer[id-1], 30070), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".PVStrings",         getU16(GlobalDataBuffer[id-1], 30071), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".MPPTrackers",       getU16(GlobalDataBuffer[id-1], 30072), {name: "", unit: ""});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxRatedPower",     getU32(GlobalDataBuffer[id-1], 30073) / 1000, {name: "", unit: "kW"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxActivePower",    getU32(GlobalDataBuffer[id-1], 30075) / 1000, {name: "", unit: "kW"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxApparentPower",  getU32(GlobalDataBuffer[id-1], 30077) / 1000, {name: "", unit: "kVA"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerToGrid",        getI32(GlobalDataBuffer[id-1], 30079) / 1000, {name: "", unit: "kVAr"});
                      forcesetState("Solarpower2.Huawei.Inverter." + id + ".MaxReactivePowerFromGrid",      getI32(GlobalDataBuffer[id-1], 30081) / 1000, {name: "", unit: "kVAr"});
                          if (err) {
                          else
                          processBattery(i);
                          processData();
                          currentinverter++
                  }, 2000);
                  Alex Warkentin 1 Reply Last reply Reply Quote 0
                  • Alex Warkentin
                    Alex Warkentin @striegel26 last edited by
                    @striegel26 Bist du sicher, dass dein Powermeter die ID 11 hat und hast du zwei Wechselrichter mit 16 und 1?
                    Was sagen denn deine Protokolle?
                      @alex-warkentin ja mir kam das auch komisch vor mit der ID11 aber schau ...... oder verstehe ich da was falsch? WR mit 16 und 1 mein fehler 16 ist gelöscht natürlich.
                      Log_PV.txt
                      • Alex Warkentin
                        @striegel26 Ich bin mir da nicht sicher. Bei mir steht dort auch die 11 drin, aber ich habe die 0 von Anfang an stehen gelassen und damit funktioniert es.
                          @alex-warkentin Oh man ja die 0 ist es !!! Danke dir 😊 Jetzt funktioniert alles
                            juggi1962 last edited by
                            Hallo an alle Wissenden 🙂
                            Funktioniert dieses Skript auch ohne Speicher?
                            Ich hab leider keinen Speicher was muss ich dann daran ändern.
                            Für mich ist JS Neuland.
                            Wäre schön wenn mir jemand helfen könnte.
                            Danke im Voraus Gruß Jürgen.
                            javascript.0
                            2023-03-05 09:56:27.826	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38200 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:25.826	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37800 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:23.824	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37700 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:21.826	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:19.823	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 32000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:17.823	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37100 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:15.823	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 30000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:13.821	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 35300 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:11.820	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38400 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:09.820	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38300 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:07.819	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38200 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:05.819	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37800 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:03.820	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37700 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:56:01.819	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:59.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 32000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:57.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37100 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:55.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 30000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:53.817	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 35300 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:51.818	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38400 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:49.816	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38300 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:47.816	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 38200 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:45.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37800 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:43.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37700 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:41.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:39.815	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 32000 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:37.814	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 37100 from id: undefined with error: undefined
                            javascript.0
                            2023-03-05 09:55:35.814	warn	script.js.Test.Modbus_Huawei_Sun_2000: Error received reading address 30000 from id: undefined with error: undefined
                            A Alex Warkentin 2 Replies Last reply Reply Quote 0
                              ATARI @juggi1962 last edited by ATARI
                              @juggi1962
                              Bin auch nicht so fit in js..
                              ändere mal die Einstellung für den Speicher.
                              zum Bsp.:
                              const BatteryUnits = [0, 0];
                              ATARI
                              Edit:
                              Deinem Log zufolge bekommst Du keine Daten von der Anlage.
                              Hast Du in den Kom.einstellung des Wechselrichters den ModBus
                              aktiviert?
                                ATARI @Kachel last edited by ATARI
                                @kachel
                                Vielen Dank für das Script und Deine Arbeit !
                                Wie kann ich den Abfrage Intervall nach einem Durchlauf verzögern
                                oder nur einmal pro Minute oder alle 5 Minuten starten lassen?
                                Ein Timer mit: von Uhrzeit bis Uhrzeit alle x Minuten wäre auch super.
                                Momentan bekommt das Script irgendwann im Laufe des Tages keine
                                Daten mehr und erzeugt nur noch Fehlermeldungen.
                                In diesem Fall hilft nur: das Script stoppen und nach einigen Minuten
                                wieder starten.
                                ATARI
                                Edit:
                                Würde Dir für Deine Arbeit 'nen Kaffee oder 'n Bier spendieren.
                                Alex Warkentin J H 3 Replies Last reply Reply Quote 0
                                • Alex Warkentin
                                  Alex Warkentin @juggi1962 last edited by
                                  @juggi1962
                                  Der Fehler besagt, dass deine ID für den Wechselrichter "undefined" ist. Welche ID hast du im Script eingestellt und hast du sie mit deinen aktuellen Einstellungen abgeglichen?
                                  • Alex Warkentin
                                    Alex Warkentin @ATARI last edited by
                                    @atari
                                    Das Abfrageintervall kannst du in der letzten Zeile des Scripts in ms einstellen. Dein Problem liegt wohl aber weniger am Intervall (dann kommt zwischendurch eine Warnung, dass das Gerät beschäftigt ist), sondern, dass das Script beim Verlust der Modbus-Verbindung diese nicht wieder automatisch aufbaut.
                                    J A 2 Replies Last reply Reply Quote 0
                                      juggi1962 @Alex Warkentin last edited by
                                      @alex-warkentin
                                      Danke für deine Antwort. Soweit funktioniert jetzt alles.
                                      Gibt es eigentlich eine Möglichkeit die Infos auszuschalten denn so sehe ich im Log ja nur mehr diese von dem Skript.
                                      Danke für eure Hilfe
                                        juggi1962 @ATARI last edited by
                                        @atari sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                                        @juggi1962
                                        zum Bsp.:
                                        ATARI
                                        Edit:
                                        aktiviert?
                                        Danke für deine Antwort. Soweit läuft jetzt alles
                                        • Alex Warkentin
                                          @juggi1962
                                          Suche mal im Script mit STRG + F nach "console.log" und setze überall, wo dich die Information nicht interessiert "//" vor die Zeile.
                                            @alex-warkentin
                                            Super Danke, werde ich gleich probieren
                                            477
                                            90353
