    4. JavaScript
    5. Wie nutze ich eine custom class / npm Modul?
      Kentrath last edited by
      @wendy2702
      Ich habe jetzt mal einen ganz frischen lxc gestartet und iob installiert (als user nicht als root). Danach habe ich nur den wiz Adapter installiert. Es kommt eine identische Fehlermeldung:
      host.ioBroker
      2023-02-23 19:30:28.583	info	Rebuild for adapter system.adapter.wizconnect.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.ioBroker
      2023-02-23 19:30:28.583	error	instance system.adapter.wizconnect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: }
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: requireStack: [ '/opt/iobroker/node_modules/iobroker.wizconnect/main.js' ]
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:904:12)
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32)
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
      host.ioBroker
      2023-02-23 19:30:28.583	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.wizconnect/main.js:10:22)
      host.ioBroker
      2023-02-23 19:30:28.582	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
      host.ioBroker
      2023-02-23 19:30:28.582	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
      host.ioBroker
      2023-02-23 19:30:28.582	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
      host.ioBroker
      2023-02-23 19:30:28.582	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1021:15)
      host.ioBroker
      2023-02-23 19:30:28.582	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.wizconnect/main.js
      host.ioBroker
      2023-02-23 19:30:28.581	error	Caught by controller[0]: Require stack:
      host.ioBroker
      2023-02-23 19:30:28.581	error	Caught by controller[0]: Error: Cannot find module '@apollon/iobroker-tools'
      host.ioBroker
      2023-02-23 19:30:28.581	error	Caught by controller[0]: ^
      host.ioBroker
      2023-02-23 19:30:28.580	error	Caught by controller[0]: throw err;
      host.ioBroker
      2023-02-23 19:30:28.580	error	Caught by controller[0]: node:internal/modules/cjs/loader:1024
      host.ioBroker
      2023-02-23 19:30:28.347	info	instance system.adapter.wizconnect.0 started with pid 13195
      • wendy2702
        wendy2702 @Kentrath last edited by wendy2702
        @kentrath sagte in Wie nutze ich eine custom class / npm Modul?:
        Wie genau? Will das mal testen
        EDIT: Läuft auch bei mir nicht. Denke da musst du dich am besten per Github an den Entwickler wenden wenn sonst niemandem etwas einfällt.
        1Topf 1 Reply Last reply Reply Quote 0
        • 1Topf
          1Topf @wendy2702 last edited by
          @wendy2702
          Ich hab ihn erst letzte Woche installiert und lief sofort.
            disaster123 last edited by
            Sieht für mich nach nem nodejs / npm Problem aus. Ich installiere ihn normal via GUI und er läuft.
            • wendy2702
              wendy2702 @1Topf last edited by
              @1topf sagte in Wie nutze ich eine custom class / npm Modul?:
              @wendy2702
              @disaster123 sagte in Wie nutze ich eine custom class / npm Modul?:
              Welche Versionen habt ihr denn für Node/NPM ?
              Und was bedeutet "normal via Gui" ?
              Ich habe eine neue iobroker installation und befinde mich im latest:
              oder im Stable
              Nix "wiz" oder wie heisst der Adapter?
                Über die Katze im Menü und dann die URL: https://github.com/disaster123/ioBroker.wizconnect
                • wendy2702
                  wendy2702 @disaster123 last edited by
                  @disaster123 Und welche NPM/Node Version läuft bei dir?
                  Das, ist übrigens nicht "normal über Gui" sondern wie du selber schreibst per GIthub Link im Expertenmodus.
                    Muss ich nachher mal gucken bitte das Original docker image von iobroker. Die Versionen sind da quasi fest.
                    • 1Topf
                      @wendy2702
                      Bei mir node.js 16.19.0 und npm 8.19.3.
                        Kentrath @1Topf last edited by
                        @1topf
                        Bei mir ist es node 16.19.1
                        • wendy2702
                          Könnt ihr mal die Ausgabe davon zeigen:
                          cd/opt/iobroker/
                          npm list
                            Node.js:
                            v16.19.0
                            NPM:
                            8.19.3
                            • 1Topf
                              @wendy2702 sagte in Wie nutze ich eine custom class / npm Modul?:
                              cd/opt/iobroker/
                              npm list
                              iobroker@ioBroker:/opt/iobroker$ npm list
                              iobroker.inst@3.0.0 /opt/iobroker
                              ├── iobroker.admin@6.3.5
                              ├── iobroker.alexa2@3.23.2
                              ├── iobroker.backitup@2.5.12
                              ├── iobroker.device-watcher@2.6.1
                              ├── iobroker.discovery@3.1.0
                              ├── iobroker.echarts@1.0.12
                              ├── iobroker.enigma2@1.3.3 (git+ssh://git@github.com/Matten-Matten/ioBroker.enigma2.git#975e828ab4595b81333bcca5b32af3cbf3c287bc)
                              ├── iobroker.flot@1.11.0
                              ├── iobroker.fullcalendar@1.2.0
                              ├── iobroker.habpanel@0.5.0
                              ├── iobroker.hiob@0.0.30
                              ├── iobroker.history@2.2.4
                              ├── iobroker.hs100@2.1.3 (git+ssh://git@github.com/arteck/ioBroker.hs100.git#bc5e7c89fe24cd4da1376a3e749e133bb564c4f6)
                              ├── iobroker.ical@1.13.2
                              ├── iobroker.icons-addictive-flavour-png@0.1.0
                              ├── iobroker.icons-fatcow-hosting@0.1.0
                              ├── iobroker.icons-icons8@0.0.1
                              ├── iobroker.icons-material-png@0.1.0
                              ├── iobroker.icons-material-svg@0.1.0
                              ├── iobroker.icons-mfd-png@1.1.0
                              ├── iobroker.icons-mfd-svg@1.1.0
                              ├── iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                              ├── iobroker.icons-ultimate-png@1.0.1
                              ├── iobroker.info@1.9.19
                              ├── iobroker.iot@1.14.2
                              ├── iobroker.jarvis@3.1.2
                              ├── iobroker.javascript@6.1.4
                              ├── iobroker.js-controller@4.0.24
                              ├── iobroker.lgtv@1.1.10
                              ├── iobroker.linux-control@1.1.3
                              ├── iobroker.minuvis@2.2.0
                              ├── iobroker.moma@1.2.9
                              ├── iobroker.mqtt@4.0.7
                              ├── iobroker.net-tools@0.2.0
                              ├── iobroker.onvif@1.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git#a4cf207db3917eaa7f2f83bea79daf2b617d46a4)
                              ├── iobroker.ping@1.5.3
                              ├── iobroker.shelly@6.3.1
                              ├── iobroker.signal-cmb@0.3.0
                              ├── iobroker.smartstate@0.0.1
                              ├── iobroker.sonoff@2.5.1
                              ├── iobroker.statistics@2.3.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.statistics.git#b20bc874be5382f1eeaeeae4efa7f5dd23967e0b)
                              ├── iobroker.tr-064@4.2.17
                              ├── iobroker.tuya@3.13.1
                              ├── iobroker.vis-2-widgets-energy@0.1.3
                              ├── iobroker.vis-2-widgets-gauges@0.1.4
                              ├── iobroker.vis-2-widgets-material@0.2.1
                              ├── iobroker.vis-bars@0.1.4
                              ├── iobroker.vis-canvas-gauges@1.0.1
                              ├── iobroker.vis-colorpicker@1.2.0
                              ├── iobroker.vis-fancyswitch@1.1.0
                              ├── iobroker.vis-google-fonts@1.0.4
                              ├── iobroker.vis-history@1.0.0
                              ├── iobroker.vis-hqwidgets@1.3.0
                              ├── iobroker.vis-icontwo@0.90.0
                              ├── iobroker.vis-inventwo@3.3.1
                              ├── iobroker.vis-jqui-mfd@1.0.12
                              ├── iobroker.vis-justgage@1.0.2
                              ├── iobroker.vis-lcars@1.0.4
                              ├── iobroker.vis-material-advanced@1.7.2
                              ├── iobroker.vis-metro@1.2.0
                              ├── iobroker.vis-plumb@1.0.2
                              ├── iobroker.vis-rgraph@0.0.2
                              ├── iobroker.vis-timeandweather@1.2.2
                              ├── iobroker.vis-weather@2.5.6
                              ├── iobroker.vis@1.4.15
                              ├── iobroker.web@4.3.0
                              ├── iobroker.wizconnect@0.0.5 (git+ssh://git@github.com/disaster123/ioBroker.wizconnect.git#ad84f06e2e5e73de575ad53b91c9d7a24d8b9384)
                              ├── iobroker.zigbee@1.8.10
                              └── iobroker.zigbee2mqtt@2.7.3
                              6592
