    3. Einsteigerfragen
    4. Absturzursache Raspi und iO Broker finden
      Laser @Thomas Braun last edited by
      pi@Heizung:~ $ sudo apt update
      Ign:1 http://security.debian.org/debian-security stable/updates InRelease
      Err:2 http://security.debian.org/debian-security stable/updates Release
        404  Not Found [IP: 2a04:4e42:6f::644 80]
      Get:3 http://ftp.debian.org/debian stable InRelease [116 kB]
      Hit:4 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:6 http://ftp.debian.org/debian stable-updates InRelease [44.1 kB]
      Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
      Err:3 http://ftp.debian.org/debian stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
      Err:6 http://ftp.debian.org/debian stable-updates InRelease
      Reading package lists... Done
      E: The repository 'http://security.debian.org/debian-security stable/updates Release' does not have a Release file.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      W: GPG error: http://ftp.debian.org/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
      E: The repository 'http://ftp.debian.org/debian stable InRelease' is not signed.
      W: GPG error: http://ftp.debian.org/debian stable-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
      E: The repository 'http://ftp.debian.org/debian stable-updates InRelease' is not signed.
        Laser @Laser last edited by
        @Thomas-Braun
        Jetzt noch "sudo apt" upgrade gemacht. Mehr brauche ich nicht.
        Einmal habe ich eine Adapter von der Konsole aus installiert, weil ich den im offiziellen Repostery nicht gefunden habe. "opendtu". Das war das Außergewöhnlichste, was ich "getrieben" habe. Ansonsten spiele ich nicht aus Langeweile am System herum.
        Warte auf den nächsten "Hänger"...
          Thomas Braun Most Active @Laser last edited by
          @laser sagte in Absturzursache Raspi und iO Broker finden:
          @Thomas-Braun
          Das wird nicht richtig funktionieren, solange da noch die Quelle falsch ist.
            Wie kommt der Verweis auf eine fehlerhafte Quelle da rein und wie korrigiere ich das?
              @laser
              Kann ich gerade nicht nachschauen, vielleicht jemand anderes, bei dem die Quellen für bullseye richtig sind.
                Laser @Thomas Braun last edited by Laser
                Ich versuche da was zu finden und passe die /etc/apt/sources.list an.
                Evtl. auf einen anderen PI bullseye installieren und dort nachsehen?
                IOBroker ändert da nichts?
                  @laser
                  cat /etc/apt/sources.list
                    bin da gerade drin: (läßt sich ja Alles rückgängig machen)
                    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
                    #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
                    #neu:
                    ### official Debian mirrors might be more up-to-date...
                    deb http://ftp.debian.org/debian stable main contrib non-free
                    deb http://security.debian.org/debian-security stable/updates main contrib non-free
                    deb http://ftp.debian.org/debian stable-updates main contrib non-free
                    #deb http://ftp.debian.org/debian stable-proposed-updates main contrib non-free
                      Thomas Braun Most Active @Laser last edited by Thomas Braun
                      Trag das mal so ein:
                      deb http://deb.debian.org/debian stable main contrib non-free
                      deb http://security.debian.org/debian-security stable-security main contrib non-free
                      deb http://deb.debian.org/debian stable-updates main contrib non-free
                        @laser
                        Und danach
                        sudo apt update
                          pi@Heizung:~ $ sudo apt upgrade
                          Building dependency tree... Done
                          Calculating upgrade... Done
                          The following package was automatically installed and is no longer required:
                            raspinfo
                          Use 'sudo apt autoremove' to remove it.
                          The following packages will be upgraded:
                            curl libcurl3-gnutls libcurl4 libtiff5
                          4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          Need to get 1,144 kB of archives.
                          After this operation, 0 B of additional disk space will be used.
                          Do you want to continue? [Y/n] y
                          Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf curl armhf 7.                       74.0-1.3+deb11u7 [258 kB]
                          Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl4 armh                       f 7.74.0-1.3+deb11u7 [310 kB]
                          Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl3-gnut                       ls armhf 7.74.0-1.3+deb11u7 [306 kB]
                          Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libtiff5 armh                       f 4.2.0-1+deb11u4 [270 kB]
                          Fetched 1,144 kB in 1s (1,171 kB/s)
                          Reading changelogs... Done
                          (Reading database ... 54016 files and directories currently installed.)
                          Preparing to unpack .../curl_7.74.0-1.3+deb11u7_armhf.deb ...
                          Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
                          Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u7_armhf.deb ...
                          Unpacking libcurl4:armhf (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
                          Preparing to unpack .../libcurl3-gnutls_7.74.0-1.3+deb11u7_armhf.deb ...
                          Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) .                       ..
                          Preparing to unpack .../libtiff5_4.2.0-1+deb11u4_armhf.deb ...
                          Unpacking libtiff5:armhf (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
                          Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u7) ...
                          Setting up libcurl4:armhf (7.74.0-1.3+deb11u7) ...
                          Setting up libtiff5:armhf (4.2.0-1+deb11u4) ...
                          Setting up curl (7.74.0-1.3+deb11u7) ...
                          Processing triggers for man-db (2.9.4-2) ...
                          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                          pi@Heizung:~ $ nano /etc/apt/sources.list
                          pi@Heizung:~ $ sudo nano/etc/apt/sources.list
                          sudo: nano/etc/apt/sources.list: command not found
                          pi@Heizung:~ $ sudo nano /etc/apt/sources.list
                          pi@Heizung:~ $
                          Get:1 http://security.debian.org/debian-security stable-security InRelease [48.4 kB]
                          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                          Get:3 http://deb.debian.org/debian stable InRelease [116 kB]
                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                          Get:5 http://deb.debian.org/debian stable-updates InRelease [44.1 kB]
                          Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                          0% [Working]gpgv: Signature made Wed Mar  1 05:32:51 2023 CET
                          gpgv:                using RSA key A0DA38D0D76E8B5D638872819165938D90FDDD2E
                          gpgv: Good signature from "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>"
                          /usr/bin/apt-key: 57: cannot create /dev/null: Permission denied
                          0% [Working]gpgv: Signature made Sat Dec 17 11:15:20 2022 CET
                          gpgv:                using RSA key 0146DC6D4A0B2914BDED34DB648ACFD622F3D138
                          gpgv: Can't check signature: No public key
                          gpgv: Signature made Sat Dec 17 11:15:21 2022 CET
                          gpgv:                using RSA key A7236886F3CCCAAD148A27F80E98404D386FA1D9
                          gpgv: Signature made Sat Dec 17 11:20:04 2022 CET
                          gpgv:                using RSA key A4285295FC7B1A81600062A9605C66F00D6C9793
                          gpgv:                issuer "debian-release@lists.debian.org"
                          Err:3 http://deb.debian.org/debian stable InRelease
                          0% [Working]gpgv: Signature made Wed Mar  1 06:32:42 2023 CET
                          gpgv:                using RSA key 5237CEEEF212F3D51C74ABE0112695A0E562B32A
                          gpgv: Signature made Wed Mar  1 06:32:43 2023 CET
                          gpgv:                using RSA key ED541312A33F1128F10B1C6C54404762BBB6E853
                          Err:1 http://security.debian.org/debian-security stable-security InRelease
                            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
                          0% [Working]gpgv: Signature made Tue Feb 28 15:00:50 2023 CET
                          gpgv:                using RSA key CF8A1AF502A2AA2D763BAE7E82B129927FA3303E
                          gpgv: Good signature from "Raspberry Pi Archive Signing Key"
                          0% [Working]gpgv: Signature made Wed Mar  1 09:14:56 2023 CET
                          gpgv: Signature made Wed Mar  1 09:15:35 2023 CET
                          Err:5 http://deb.debian.org/debian stable-updates InRelease
                          0% [Working]gpgv: Signature made Fri Feb 17 01:55:45 2023 CET
                          gpgv:                using RSA key 9FD3B784BC1C6FC31A8A0A1C1655A0AB68576280
                          gpgv: Good signature from "NodeSource <gpg@nodesource.com>"
                          W: GPG error: http://deb.debian.org/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
                          E: The repository 'http://deb.debian.org/debian stable InRelease' is not signed.
                          W: GPG error: http://security.debian.org/debian-security stable-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
                          E: The repository 'http://security.debian.org/debian-security stable-security InRelease' is not signed.
                          W: GPG error: http://deb.debian.org/debian stable-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
                          E: The repository 'http://deb.debian.org/debian stable-updates InRelease' is not signed.
                            raspinfo
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                            @laser
                            Ersetz mal 'stable' durch den Releasename das du da fährst. 'bullseye'?
                              @thomas-braun so?
                              deb http://deb.debian.org/debian bullseye main contrib non-free
                              deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                              deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                              pi@Heizung:/etc/apt$ sudo apt update
                              Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
                              Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48                     .4 kB]
                              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Get:5 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                              gpgv: Good signature from "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <                     mpthompson@gmail.com>"
                              Err:2 http://security.debian.org/debian-security bullseye-security InRelease
                                The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
                              Err:1 http://deb.debian.org/debian bullseye InRelease
                                The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F                     00D6C9793
                              Err:5 http://deb.debian.org/debian bullseye-updates InRelease
                              W: GPG error: http://security.debian.org/debian-security bullseye-security InRel                     ease: The following signatures couldn't be verified because the public key is no                     t available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
                              E: The repository 'http://security.debian.org/debian-security bullseye-security                      InRelease' is not signed.
                              N: Updating from such a repository can't be done securely, and is therefore disa                     bled by default.
                              N: See apt-secure(8) manpage for repository creation and user configuration deta                     ils.
                              W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following sig                     natures couldn't be verified because the public key is not available: NO_PUBKEY                      648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
                              E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signe                     d.
                              W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The follo                     wing signatures couldn't be verified because the public key is not available: NO                     _PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
                              E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is n                     ot signed.
                              pi@Heizung:/etc/apt$ sudo apt upgrade
                                raspinfo
                                @laser
                                Irgendwas stimmt mit den signaturen noch nicht.
                                Ich kann aber im Moment nicht nachschauen, weil ich hier ein ganz anderes System fahre.
                                  Kein Problem!
                                  Ich suche mal nach einem anderen Pi zur Testinstallation. Ich muß jetzt auch erst mal weg.
                                  Unabhängig von den falschen Quellen hat meine FritzBox ein Problem. Muß ich auch immer mal neu starten. Evtl. hat der Hersteller ein "Gute Nacht- kauf mal was Neues" - Update installiert?
                                    Das siehst du ja in entsprechenden Logs.
                                    Wenn du die nicht ausknipsen würdest jedenfalls...
                                      ich werde die logs wieder einschalten. Aber gefunden habe ich darin bisher nichts Brauchbares...
                                        Homoran Global Moderator Administrators @Laser last edited by
                                        wie es die Anleitung gezeigt hat.
                                        welche?
                                          Laser @Homoran last edited by Laser
                                          Da müßte ich jetzt suchen. Ist schon eine Weile her. Aber es war die, welche mir hier einige Beiträge vorher hier im Forum empfohlen wurde.
                                          IO-Broker so mit dem Script:
                                          sudo apt install curl
                                          sudo curl -sL https://iobroker.net/install.sh | bash -
                                          Zu Beginn hatte ich noch Debmatic mit drauf. Habe ich jetzt auf einem extra Pi.
                                          • DJMarc75
                                            DJMarc75 @Laser last edited by
                                            @laser hör bitte auf wie "früher" deine Beiträge nachträglich zu editieren... und:
                                            macht man nicht --- ohne sudo ist da angesagt auf einem gescheiten System !
                                            148
                                            9285
