    3. Einsteigerfragen
    4. Absturzursache Raspi und iO Broker finden
      Laser @Thomas Braun last edited by Laser
      @thomas-braun so?
      deb http://deb.debian.org/debian bullseye main contrib non-free
      deb http://security.debian.org/debian-security bullseye-security main contrib non-free
      deb http://deb.debian.org/debian bullseye-updates main contrib non-free
      pi@Heizung:/etc/apt$ sudo apt update
      Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
      Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48                     .4 kB]
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:5 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      0% [Working]gpgv: Signature made Wed Mar  1 05:32:51 2023 CET
      gpgv:                using RSA key A0DA38D0D76E8B5D638872819165938D90FDDD2E
      gpgv: Good signature from "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <                     mpthompson@gmail.com>"
      /usr/bin/apt-key: 57: cannot create /dev/null: Permission denied
      0% [Working]gpgv: Signature made Wed Mar  1 06:32:42 2023 CET
      gpgv:                using RSA key 5237CEEEF212F3D51C74ABE0112695A0E562B32A
      gpgv: Can't check signature: No public key
      gpgv: Signature made Wed Mar  1 06:32:43 2023 CET
      gpgv:                using RSA key ED541312A33F1128F10B1C6C54404762BBB6E853
      Err:2 http://security.debian.org/debian-security bullseye-security InRelease
        The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
      0% [Working]gpgv: Signature made Tue Feb 28 15:00:50 2023 CET
      gpgv:                using RSA key CF8A1AF502A2AA2D763BAE7E82B129927FA3303E
      gpgv: Good signature from "Raspberry Pi Archive Signing Key"
      0% [Working]gpgv: Signature made Sat Dec 17 11:15:20 2022 CET
      gpgv:                using RSA key 0146DC6D4A0B2914BDED34DB648ACFD622F3D138
      gpgv: Signature made Sat Dec 17 11:15:21 2022 CET
      gpgv:                using RSA key A7236886F3CCCAAD148A27F80E98404D386FA1D9
      gpgv: Signature made Sat Dec 17 11:20:04 2022 CET
      gpgv:                using RSA key A4285295FC7B1A81600062A9605C66F00D6C9793
      gpgv:                issuer "debian-release@lists.debian.org"
      Err:1 http://deb.debian.org/debian bullseye InRelease
        The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F                     00D6C9793
      0% [Working]gpgv: Signature made Wed Mar  1 09:14:56 2023 CET
      gpgv: Signature made Wed Mar  1 09:15:35 2023 CET
      Err:5 http://deb.debian.org/debian bullseye-updates InRelease
      0% [Working]gpgv: Signature made Fri Feb 17 01:55:45 2023 CET
      gpgv:                using RSA key 9FD3B784BC1C6FC31A8A0A1C1655A0AB68576280
      gpgv: Good signature from "NodeSource <gpg@nodesource.com>"
      Reading package lists... Done
      W: GPG error: http://security.debian.org/debian-security bullseye-security InRel                     ease: The following signatures couldn't be verified because the public key is no                     t available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
      E: The repository 'http://security.debian.org/debian-security bullseye-security                      InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disa                     bled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration deta                     ils.
      W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following sig                     natures couldn't be verified because the public key is not available: NO_PUBKEY                      648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
      E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signe                     d.
      W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The follo                     wing signatures couldn't be verified because the public key is not available: NO                     _PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
      E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is n                     ot signed.
      pi@Heizung:/etc/apt$ sudo apt upgrade
      Building dependency tree... Done
      Calculating upgrade... Done
      The following package was automatically installed and is no longer required:
        raspinfo
      Use 'sudo apt autoremove' to remove it.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Thomas Braun Most Active @Laser last edited by
        @laser
        Irgendwas stimmt mit den signaturen noch nicht.
        Ich kann aber im Moment nicht nachschauen, weil ich hier ein ganz anderes System fahre.
          Kein Problem!
          Ich suche mal nach einem anderen Pi zur Testinstallation. Ich muß jetzt auch erst mal weg.
          Unabhängig von den falschen Quellen hat meine FritzBox ein Problem. Muß ich auch immer mal neu starten. Evtl. hat der Hersteller ein "Gute Nacht- kauf mal was Neues" - Update installiert?
            @laser sagte in Absturzursache Raspi und iO Broker finden:
            Das siehst du ja in entsprechenden Logs.
            Wenn du die nicht ausknipsen würdest jedenfalls...
              ich werde die logs wieder einschalten. Aber gefunden habe ich darin bisher nichts Brauchbares...
                Homoran Global Moderator Administrators @Laser last edited by
                wie es die Anleitung gezeigt hat.
                welche?
                  Laser @Homoran last edited by Laser
                  Da müßte ich jetzt suchen. Ist schon eine Weile her. Aber es war die, welche mir hier einige Beiträge vorher hier im Forum empfohlen wurde.
                  IO-Broker so mit dem Script:
                  sudo apt install curl
                  sudo curl -sL https://iobroker.net/install.sh | bash -
                  Zu Beginn hatte ich noch Debmatic mit drauf. Habe ich jetzt auf einem extra Pi.
                  • DJMarc75
                    DJMarc75 @Laser last edited by
                    @laser hör bitte auf wie "früher" deine Beiträge nachträglich zu editieren... und:
                    macht man nicht --- ohne sudo ist da angesagt auf einem gescheiten System !
                      Laser @DJMarc75 last edited by
                      @djmarc75
                      Das habe ich jetzt nur aus einer alten Textdatei kopiert. Jetzt sehe ich es auch. Habe zum Schluß aber ohne sudo installiert. Muß die abgelegte Hilfedatei korrigieren.
                        Laser @Laser last edited by
                        @laser und vorher Debian mit dem Rasberry Imager.
                        Wenn ich nicht eine offline Vis Lizenz hätte, würde ich Alles neu auf einem anderen Pi installieren...
                          @laser lassen sie die Rechte nachträglich mit sinnvollem Aufwand anpassen?
                          • wendy2702
                            wendy2702 @Laser last edited by
                            @laser welche Rechte willst du anpassen?
                              Laser @wendy2702 last edited by
                              @wendy2702
                              Falls ich, wie hier vermutet wurde, etwas mit Sudo Rechten installiert hätte.
                              L DJMarc75 2 Replies Last reply Reply Quote 0
                                @laser
                                Brauche das System heute noch. Habe gerade ein Backup gemacht. Wie lange wird eine komplette Neuinstallation etwa dauern?
                                  @laser
                                  Beschreibe gerade eine neue SD Card. Ziehe ein Image und schreibe das auf die SSD. Dann habe ich immer noch meine alte SSD, wenn es nicht so klappt.
                                  • DJMarc75
                                    Wenn man mal Deine vielen Probleme aus Deinen Beiträgen so liest, dann hast Du definitiv da mit irgendwelchem Murks gearbeitet... kein Vorwurf sondern eine Feststellung !
                                    Dann:
                                    wie machs Du das ?
                                    Was sollte das nicht klappen wenn man es richtig macht ?
                                      @djmarc75
                                      -Installieren mit Raspberry Pi Imager. Image mit Win32 Diskmanager. Beschreiben der SSD mit Balena.
                                      -OW Server installiern
                                      -IOBroker: installieren mit Script.
                                      Ist da was falsch dran?
                                        @laser
                                        Das Einzige, was ich nicht mehr genau weiß- habe ich damals Debmatic nur deinstalliert oder den kompletten Pi neu gemacht.
                                        • DJMarc75
                                          DJMarc75 @Laser last edited by DJMarc75
                                          @Laser
                                          keine Ahnung was Du da machst aber man installiert auf einer SD, SSD oder USB-Stick per Imager das Debian Bullseye OHNE Desktop... da gibts nix mit Win32 oder Balena....
                                          Was ist OW Server ???
                                          zeig mal das "Script" zum installieren vom iob !
                                          kein Plan was Du damit meinst.
                                          L Homoran 2 Replies Last reply Reply Quote 0
                                            @djmarc75
                                            Es wurde immer angeraten, den PI-Imager zu benutzen. Kann ich damit auch direkt ein Image erzeugen?
                                            Script für IOBroker: curl -sL https://iobroker.net/install.sh | bash -
                                            OW-Server- brauche ich u.a. für meine Temperaturmessungen
                                            148
                                            9285
