    4. Das Ultimative Markisen / Rolladen Blockly - Script
    • smile
      smile last edited by Negalein
      Alles klar, hier kommt der Blockly Export:
       <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="/q*fhP`a}D~:yGIl2Rz]" x="-462" y="2238.1600036621094"><mutation items="1"></mutation>
        <field name="ACK_CONDITION">true</field>
        <value name="OID0"><shadow type="field_oid" id="!k]IS277@k`sP^g=Eqkm"><field name="oid">hm-rpc.0.LEQ1288980.1.STATE</field></shadow></value>
        <statement name="STATEMENT"><block type="controls_if" id="/lGDf!o#|U*eIwAXW;I1"><value name="IF0"><block type="logic_operation" id="}Y[6R:jFi[2kV3[5%d{r"><field name="OP">OR</field>
                <value name="A"><block type="logic_operation" id="U6O8[BN7e9iJn`P9A0Hv"><field name="OP">OR</field>
                    <value name="A"><block type="logic_compare" id="y9BPccUgkPbs(XA(C-Ua"><field name="OP">EQ</field>
                        <value name="A"><block type="variables_get" id="j``KC-3q8}i!nW1BW:2@"><field name="VAR">Regen</field></block></value>
                        <value name="B"><block type="text" id="6{rE(fXNn9L-|64:Ba@n"><field name="TEXT">Kein Regen</field></block></value></block></value>
                    <value name="B"><block type="logic_compare" id="_gio_J9:cAyapYmizLa`"><field name="OP">EQ</field>
                        <value name="A"><block type="variables_get" id="O]y!Cfj2RXL^`](!_7qT"><field name="VAR">Regen</field></block></value>
                        <value name="B"></value></block></value></block></value>
                <value name="B"><block type="logic_compare" id="1}W22SPXABoar;oNBW%y"><field name="OP">EQ</field>
                    <value name="A"><block type="variables_get" id="o;N1xav(uT)8G{xS93Nj"><field name="VAR">Regen</field></block></value>
                    <value name="B"><block type="text" id="Nm}J?f21HngKd/yyP2-V"><field name="TEXT">Regen Abklingphase</field></block></value></block></value></block></value>
            <statement name="DO0"><block type="debug" id="4I)jAzD^Clm[~M,1xhtF"><field name="Severity">log</field>
                <value name="TEXT"><shadow type="text" id="]u{I@T1=]ciorGiYiULV"><field name="TEXT">Regen</field></shadow></value>
                <next><block type="timeouts_cleartimeout" id="HbROdXG2mP2@hRk,;F;Z"><field name="NAME">timeout_Regen4</field>
                    <next><block type="timeouts_cleartimeout" id="e!-sVViI@G5s9Q07PrR,"><field name="NAME">timeout_Regen3</field>
                        <next><block type="variables_set" id="dP431ZOlBrrlV;sELkuL"><field name="VAR">Regen</field>
                            <value name="VALUE"><block type="text" id="i|P?`;buz}g1fu!a#LTK"><field name="TEXT">Regen</field></block></value>
                            <next><block type="procedures_callnoreturn" id="AO1%}Bl.diaV;=yX%p~P"><mutation name="Regen_Wind_Rollo"></mutation>
                                <next><block type="pushover" id="TKkFuNpoNB[`.6kuESPS"><field name="INSTANCE">.0</field>
                                    <field name="PRIORITY">0</field>
                                    <value name="MESSAGE"><shadow type="text" id="txQ_WuqpCB`U|J/kh-:i"><field name="TEXT">Es regnet in Braak</field></shadow></value></block></next></block></next></block></next></block></next></block></next></block></statement></block></statement></block>
      Ein Problem scheint noch beim Regensensor Blockly zu sein:
      Ich kriege es noch nicht hin, dass er bei dauerndem Regen nicht andauernd immer wieder NEU Regen meldet.
      Ich muss dazu sagen dass ich mit dem Regensensor etwas geschummelt hab: Es ist nicht der Original Homematic Regensensor. (weil der so unzuverlässig war). Sondern ein normaler Regensensor, welcher an einen Homematic Fensterkontakt gelötet wurde 😉 Wenn es regnet meldet der Fensterkontakt "offen".
      Jedoch habe ich das Problem dass ich ständig eine Meldung vom Regensensor bekomme, wenn es regnet:
      10:07:51.788 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:20:32.115 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:22:52.371 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:41:48.981 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:41:53.742 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:42:03.481 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:42:27.489 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:42:33.028 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:44:21.751 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:44:44.032 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      10:48:16.016 [info] javascript.0 script.js.Beschattung_Auto_2: Regen
      Also in viel zu kurzen Intervallen. Wäre das mit einem original HM Regensensor anders? Oder muss ich das einfach umscripten?
      Kann hierfür die Funktion "wurde geändert" statt "ist wahr" hilfreich sein?
      Danke nochmals für den Support :!:
      • rantanplan
        rantanplan last edited by
        Hi
        Da scheint beim Export etwas nicht geklappt zu haben.
        Da muss alles selektiert werden.
        Das fängt mit <xml…......an<br>und hört mit auf.
        (Einfach STRG+a)
        Klick vor dem Export auch bitte mal auf "Blöcke prüfen"
        Grüße</xml…......an<br>
        • smile
          Alles klar, da ich leider aufgrund von zu vielen Zeichen das Script hier nicht posten kann, hab ich das mal in ein .txt. Dokument gepackt - hoffe das geht so.
          3472_blockly_export.txt
          • rantanplan
            Import hat geklappt.
            Aber da muss ich erst in Ruhe durchsteigen :shock:
            Warum alles in einem Blockly?
            Ich sehe da einiges an Aufräumpotential 😉
            Ich melde mich.
              weimaraner last edited by
              Also, wenn ich Deine Anforderungen so sehe, würde ich Dir diese Seite mal empfehlen:
              https://www.stall.biz/project/so-steuer … -homematic
              Ich habe dieses Skript in abgewandelter Form und mit meinen Werten angepaßt seit gut drei Jahren laufen. Die HM-Skripte werde ich demnächst in blockly überführen. Ich denke, da ist einiges dabei, was Du auch als mögliche trigger möchtest. Wenn Du dort einmal durchgestiegen bist, dürfte es nicht schwer sein, das auf blockly zu übertragen.
              Grüße Andreas
              • smile
                @weimaraner:
                Grüße Andreas `
                Hi Andreas, danke für den Link, da hat sich jemand wirklich Mühe gegeben.
                Bei mir sind ein paar Anforderungen anders, bzw. manches ist bisher halt anders gelöst.
                Der von stall.biz misst z.B. nach Temperaturdifferenz, bei mir ist es Abfrage (Mindest-)Außentemperatur + Helligkeit, was auch völlig ok ist.
                @ rantaplan:
                Hm gute Frage, warum nicht? Sollte man das lieber auf mehrere verteilen?
                Ich wollte z.B. ja nicht für jeden Rolladen Helligkeitswerte einzeln abfragen, sondern ein Gesamtscript dafür nutzen.
                Darüber hinaus kann ich so mit einem Knopfdruck das Script deaktivieren und habe so einen "manuell" Schalter für die Beschattungen.
                Momentan kämpfe ich hauptsächlich mit 2 Dingen:
                –> Ich kann die Homematic Rolladenaktoren nur mit 0% oder 100% (Oder Zwischenzahl) ansteuern, also sprich feste Werte. Mir fehlt der Simple Befehl UP oder DOWN, aber ich komme aus io.broker da irgendwie nicht ran. Siehe Screenshot, das sind die möglichen Variablen in io.broker von dem Homemativ wired Rolladenaktor.
                Folge: Wenn das Script mal durcheinander kommt und mehrere Befehle hintereinander sendet, dann weiß glaube ich der Rolladen)aktor) nicht mehr was 0% und was 100% ist, und bleibt an willkürlichen Stellen stehen. Sehr bescheiden bei Regen....
                --> Der "Türkontakt-Regensensor" löst zwar zuverlässig aus, aber ich bekomme es nicht so hingescripted, dass er nicht jede Minute ein Auslöse Update macht.
                Oder sollte ich den lieber auch per Zeitintervall abfragen?
                  @smile:
                  @weimaraner:
                  Grüße Andreas `
                  Das stimmt. Wobei die Temperaturdifferenz genau genommen eine Art Sonnendetektor ist.
                  Schau mal hier: https://www.stall.biz/project/robuster- … nz-einfach
                  und hier:https://www.stall.biz/project/sonnensen … nsteuerung
                  Den zweiten mit dem Marmeladenglas und dem Metallrohr habe ich nachgebaut und der funktioniert 1A! 😄
                  Das ganze wird mit einer Hysterese von 20 Minuten über eine Variable gesteuert. Damit umgehst du zu häufiges öffnen und schließen bei schnellem Helligkeitswechsel durch z.B. schnelle Wolken bei Wind. Wird es dunkel, schlägt auch der Sonnendetektor an (Sonne ist ja weg).
                  Schöner Nebeneffekt. Du kannst die Sonnenscheindauer grafisch sehr gut darstellen.
                  Grüße Andreas
                  • rantanplan
                    rantanplan last edited by Negalein
                    Hallo smile
                    Einen Teil habe ich mal umgetellt.
                    Da Du alles über Timer-Trigger gelöst hast, ist das alles recht unübersichtlich.
                    Und mehrere Trigger können gleichzeitig starten, was jede Menge ungewollte Nebeneffekte hat.
                    Um Dein Blockly in mehrere logische Einheiten aufzudröseln, müssen wir als erstes von den lokalen Variablen weg!
                    Über globale Variablen/Zustände können sich die einzelnen Blocklys "unterhalten".
                    Und da wären wir beim nächten Thema, Zustände!
                    Man muss z.B. nicht jede Minute den "Wind" überprüfen.
                    Man muss nur reagieren, wenn der "Wind" seinen "Zustand" ändert!
                    Genau so mit der Temperatur es ist quatsch diese alle 5 Sek. zu überprüfen!!!
                    Ich bin mal mit dem Teil "Rollo Automatik Vormittag/Nachmittag" angefangen.
                    Dazu müssen einige globale Variablen in ioBroker angelegt werden.
                    Das solltest Du in ein neues Blockly importieren und als ERSTES starten!
                    Export Variablen:
                     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="create" id="}=Y-O-vl`*2YuCcv_F^*" x="-2788" y="4237"><field name="NAME">Sonne vormittag</field>
                        <statement name="STATEMENT"><block type="create" id="4434IyAnZn93df[8IL)B"><field name="NAME">Sonne nachmittag</field>
                            <statement name="STATEMENT"><block type="create" id="08D_xiK+@q-Cwp#{9j|4"><field name="NAME">Temperatur</field>
                                <statement name="STATEMENT"><block type="create" id="c6,QVVu?U2CJiT*E=Pp*"><field name="NAME">Wind</field>
                                    <statement name="STATEMENT"><block type="create" id="1At9e*9_D.Nm?V/plCkh"><field name="NAME">Regen</field></block></statement></block></statement></block></statement></block></statement></block></xml>
                    So sieht mein "Umbau" aus.
                    OHNE ANPASSUNG DER ANDEREN TEILE KLAPPT DAS NARÜRLICH NOCH NICHT.
                    Aber Du kannst ja schon mal schauen.
                    Hier der Exort:
                     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="IR94DiuG7v6~=Zg2dVp6" x="-762" y="4638"><field name="COMMENT">Variablen initialisieren</field>
                        <next><block type="procedures_callnoreturn" id="iW:+%8blE]XvSDS~rIw5"><mutation name="InitVariablen"></mutation>
                            <next><block type="comment" id="_:tJ@Ut#F5ws5(QdD#18"><field name="COMMENT">Variablen überwachen</field>
                                <next><block type="comment" id="Mlyo7L0-(5%m9dgr4!hg"><field name="COMMENT">Wenn sich eine ändert, startet Trigger</field>
                                    <next><block type="on_ext" id="QiHPKverivP=8WkSGytV"><mutation items="5"></mutation>
                                        <value name="OID0"><shadow type="field_oid" id="+,BC{lp_F!LRvdS~JX5?"><field name="oid">javascript.0.Sonne vormittag</field></shadow></value>
                                        <value name="OID1"><shadow type="field_oid" id="Yp8-^gw:4dzjsmj2:E|X"><field name="oid">javascript.0.Sonne nachmittag</field></shadow></value>
                                        <value name="OID2"><shadow type="field_oid" id="_L%Q;_E;przz^IB8H7ku"><field name="oid">javascript.0.Wind</field></shadow></value>
                                        <value name="OID3"><shadow type="field_oid" id="4%FQBEBoKZscIw(xCfvK"><field name="oid">javascript.0.Regen</field></shadow></value>
                                        <value name="OID4"><shadow type="field_oid" id="(YD{}gWxz15@1erb8dYW"><field name="oid">javascript.0.Temperatur</field></shadow></value>
                                        <statement name="STATEMENT"><block type="comment" id="KBTszICK@=[wDZb5;*~,"><field name="COMMENT">Rollo Automatik Vormittags</field>
                                            <next><block type="controls_if" id="PE7b{%TNQd*9zP!jf^Vh"><value name="IF0"><block type="time_compare" id="wiw`_@oW7L;@Lqp}_Bbk"><mutation end_time="true"></mutation>
                                                    <field name="START_TIME">12:45</field>
                                                    <field name="END_TIME">15:00</field></block></value>
                                                <statement name="DO0"><block type="controls_if" id="-qm_GxNYec;/oVqc#/FG"><mutation elseif="1"></mutation>
                                                    <value name="IF0"><block type="logic_operation" id="3MvSq_rbvziv0hO!pv4X" inline="false"><field name="OP">AND</field>
                                                        <value name="A"><block type="logic_compare" id="(4xyzp46rX#2!bau(%nV"><field name="OP">EQ</field>
                                                            <value name="A"><block type="get_value" id="xXd].0z/eJi_OfvmDFxA"><field name="ATTR">val</field>
        <field name="OID">javascript.0.Sonne vormittag</field></block></value>
                                                            <value name="B"><block type="text" id="MOZ_dv*(#ZY/~FULWUPu"><field name="TEXT">Sonne vormittag da</field></block></value></block></value>
                                                        <value name="B"><block type="logic_operation" id="S};QeEeRv)|[*|0@2)c8" inline="false"><field name="OP">AND</field>
                                                            <value name="A"><block type="logic_compare" id="vu2.^T;[R(_T6hOXlr_."><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="~F:Z},!7~ykNJwrOkbGO"><field name="ATTR">val</field>
        <field name="OID">javascript.0.Temperatur</field></block></value>
        <value name="B"><block type="text" id="n*xk_f@Zq@~B.=up.`US"><field name="TEXT">Warm</field></block></value></block></value>
                                                            <value name="B"><block type="logic_operation" id="_=4D??A;0FI8ra-O(0F?" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="[PHCg{Ie(#.YcDNAWXmd"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="8{ERfH|U})t=s3IU#^13"><field name="ATTR">val</field>
        <field name="OID">javascript.0.Wind</field></block></value>
        <value name="B"><block type="text" id="um}}z7,tc/4!Hi@tah*5"><field name="TEXT">Kein Wind</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="LMn!w9FZvoVEuwl%D6mY"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="2%;WPqm*uJ|_WvU=(n|D"><field name="ATTR">val</field>
        <field name="OID">javascript.0.Regen</field></block></value>
        <value name="B"><block type="text" id=":7(gB.uFfPECZEwe3pxW"><field name="TEXT">Kein Regen</field></block></value></block></value></block></value></block></value></block></value>
                                                    <statement name="DO0"><block type="controls_if" id="yC6hZ|KW5Stt%3^5rlh2"><value name="IF0"><block type="logic_compare" id="%{03m~#w#0V;65s{%?nv"><field name="OP">GT</field>
                                                            <value name="A"><block type="get_value" id="DU)Iz,zfo_moiHn0ViwR"><field name="ATTR">val</field>
        <field name="OID">hm-rpc.0.JEQ0299861.1.LEVEL</field></block></value>
                                                            <value name="B"><block type="text" id="ba6YoJ6#1bP-y9hi7(Fw"><field name="TEXT">2</field></block></value></block></value>
                                                        <statement name="DO0"><block type="control" id="_yRXeMIFf6*;^DuLm0{Y"><mutation delay_input="false"></mutation>
                                                            <value name="VALUE"><block type="text" id="8v@#`#`P@u_J,_xFVA-1"><field name="TEXT">0</field></block></value></block></statement>
                                                        <next><block type="controls_if" id="da_(t)1H+*[|uObdu^7E"><value name="IF0"><block type="logic_compare" id="@1{B?Sr;8on}:0~Z/bv}"><field name="OP">GT</field>
        <value name="A"><block type="get_value" id="92TuOd8vS[yojxAkXsdz"><field name="ATTR">val</field>
        <field name="OID">hm-rpc.0.JEQ0299851.1.LEVEL</field></block></value>
        <value name="B"><block type="text" id=":Ky@O(uLcK*h5cE|MRl4"><field name="TEXT">2</field></block></value></block></value>
                                                            <statement name="DO0"><block type="control" id="OhJ*jMYtH]-,vuf7J0Nj"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="/(ZI:L2Z*dv@5r}W2enm"><field name="TEXT">0</field></block></value></block></statement></block></next></block></statement>
                                                    <value name="IF1"><block type="logic_operation" id="vJ5:~jZO:NC(Pd96O(;G" inline="false"><field name="OP">OR</field>
                                                        <value name="A"><block type="logic_compare" id="Ad!8`?NG.(OL.g_odN~o"><field name="OP">EQ</field>
                                                            <value name="A"><block type="get_value" id="S7/gkd+O%sL!3genk)cI"><field name="ATTR">val</field>
                                                            <value name="B"><block type="text" id="9Fs[=kKwVkBLVK?]#jN3"><field name="TEXT">Sonne vormittag weg</field></block></value></block></value>
                                                        <value name="B"><block type="logic_compare" id="G2+kr0haz~Ox4Vo!EM)W"><field name="OP">EQ</field>
                                                            <value name="A"><block type="get_value" id="5io?01yhTDr)?mdJJ_F2"><field name="ATTR">val</field>
                                                            <value name="B"><block type="text" id="-jtS7S)=EeSKNn[v0iI."><field name="TEXT">Kühl</field></block></value></block></value></block></value>
                                                    <statement name="DO1"><block type="controls_if" id="FcNEyO_Z11Ce7C=:!(}S"><value name="IF0"><block type="logic_compare" id="~6U1U.`obRseMnyazi!n"><field name="OP">LT</field>
                                                            <value name="A"><block type="get_value" id="Z3^aVRk+QqhVuP4k0TZn"><field name="ATTR">val</field>
                                                            <value name="B"><block type="text" id="n,!VeekwVG~sM94[XNQN"><field name="TEXT">99</field></block></value></block></value>
                                                        <statement name="DO0"><block type="control" id="|s@Eet(_I#Q9o(yH}a1-"><mutation delay_input="false"></mutation>
                                                            <value name="VALUE"><block type="text" id=";j*Ma@j~rj/h/npu3%Sx"><field name="TEXT">100</field></block></value></block></statement>
                                                        <next><block type="controls_if" id="Zg^9xF`u;g67wy8/U@To"><value name="IF0"><block type="logic_compare" id="!Ar%r9;J+0}x)E5}ZE`Y"><field name="OP">LT</field>
        <value name="A"><block type="get_value" id="-[3W?T{(ij8b`9-5OQrn"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="T@LFM75gL}gt3-LjhRl,"><field name="TEXT">99</field></block></value></block></value>
                                                            <statement name="DO0"><block type="control" id="Xzb5[el97QU~kgep1wCC"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="vY4e8ev;i1/y;K+ww`Kr"><field name="TEXT">100</field></block></value></block></statement></block></next></block></statement></block></statement>
                                                <next><block type="comment" id="WebbG)%):f^o3IOrXx9k"><field name="COMMENT">Rollo Automatik Nachmittags</field>
                                                    <next><block type="controls_if" id="`1r57@w,vq.]_)1URYw{"><value name="IF0"><block type="time_compare" id="mv#=V=^xD_3#5K7@0,;#"><mutation end_time="true"></mutation>
                                                            <field name="START_TIME">15:00</field>
                                                            <field name="END_TIME">22:00</field></block></value>
                                                        <statement name="DO0"><block type="controls_if" id="06]icFPv.|4I]5RZFVxK"><mutation elseif="1"></mutation>
                                                            <value name="IF0"><block type="logic_operation" id="H)[?N6jnM;U/P,N2k%c3" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id=",*e.*[%4U5aOqU|+6piK"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="*hp9dJ)CcN8C:m11UvGS"><field name="ATTR">val</field>
        <field name="OID">javascript.0.Sonne nachmittag</field></block></value>
        <value name="B"><block type="text" id="qd0#1t7adf%NzoxZIPe;"><field name="TEXT">Sonne nachmittag da</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="0[8LT!cRt?8vVFyYvR%-" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id=";tTT}MT4?wfKPcv4R0z}"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="Za216GQPdEI5TAHu(8wm"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="J)p4A^J^?3B?6`nC]{G+"><field name="TEXT">Warm</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="f9}0Bzs5hiI4;NGj,,x_" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="_QmL%I+!rf/(Q@!3%-*|"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="QI1*j%HxyXp3(J5LyE#s"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="?bJyjwmT{QX.!]zge^ml"><field name="TEXT">Kein Wind</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="rL__AI7HbK.6TXQKjENq"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="f9X*^y]z6O)7o6#CUVNT"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="kzGhN6U:[gC);VgYO+or"><field name="TEXT">Kein Regen</field></block></value></block></value></block></value></block></value></block></value>
                                                            <statement name="DO0"><block type="controls_if" id="cmE{`w9X:d6z~U(;h)q2"><value name="IF0"><block type="logic_compare" id="}=t1L@V75YROUx76UtJI"><field name="OP">GT</field>
        <value name="A"><block type="get_value" id="(-6;[Tvq`yFSRfRQ)fl}"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="e6IT6bR~(kd2lU2kVwxg"><field name="TEXT">2</field></block></value></block></value>
        <statement name="DO0"><block type="control" id="rK5dtkmDK*?o6+RNY!m`"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="c2kl1smjFi;R2`Zxm)=)"><field name="TEXT">0</field></block></value></block></statement>
        <next><block type="controls_if" id="=(kBQkiVxmc{IK@/BnN["><value name="IF0"><block type="logic_compare" id="HW^lkc(tnxE9sXz3el7H"><field name="OP">GT</field>
        <value name="A"><block type="get_value" id="F(VWL|VR}uTz}AH-KkJR"><field name="ATTR">val</field>
        <value name="B"><block type="text" id=";I?@e#;0`~G,k:C2l/fn"><field name="TEXT">2</field></block></value></block></value>
        <statement name="DO0"><block type="control" id="s9V*Poyqeda}hCDiq8Rg"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="ZWNuP0|avd=bwa0gl[bq"><field name="TEXT">0</field></block></value></block></statement></block></next></block></statement>
                                                            <value name="IF1"><block type="logic_operation" id="deYn|DwA4C6WDszez|N?" inline="false"><field name="OP">OR</field>
        <value name="A"><block type="logic_compare" id="3otRi*ZZ^.DmSmOsCTd5"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="GNsq}r-(XJSOr#`TkcpG"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="qCdb(O-FlFpl/4%bQ|ZH"><field name="TEXT">Sonne nachmittag weg</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="!5R4nTl9UB9Gu2I|!.r_"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="iC^b3Q8DO:ajXg=5n9l2"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="yDJp[#W)ST{V{YQP}br]"><field name="TEXT">Kühl</field></block></value></block></value></block></value>
                                                            <statement name="DO1"><block type="controls_if" id="BrJx+TOrgC5::]2b6fbQ"><value name="IF0"><block type="logic_compare" id="9CZ5^vv#K7S*_ZK7igZ4"><field name="OP">LT</field>
        <value name="A"><block type="get_value" id="@gEto~k2Uj|q@{ey{Tce"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="628tYGpk@^xz0j%8gjg1"><field name="TEXT">99</field></block></value></block></value>
        <statement name="DO0"><block type="control" id="[.MirZd!YIUo`BuD`xh("><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="2SMw+RRV-XTXko0:uL1~"><field name="TEXT">100</field></block></value></block></statement>
        <next><block type="controls_if" id="zS@pM}dP.?Jj;g[l7Nl3"><value name="IF0"><block type="logic_compare" id="_ujq6r5ysA7(d^7bI=1:"><field name="OP">LT</field>
        <value name="A"><block type="get_value" id=";*Ch*E/(v7s,CiFe1TKY"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="9OU@m_5Y|FF]Mwi~Jf*n"><field name="TEXT">99</field></block></value></block></value>
        <statement name="DO0"><block type="control" id="+r4~Y6o!J(VNB`CJ,RJ|"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="DrF0QNw_G0?(/Q*/eM#R"><field name="TEXT">100</field></block></value></block></statement></block></next></block></statement></block></statement></block></next></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block>
                      <block type="procedures_defnoreturn" id="(+6Mz{Je,L}7n^5*t*wO" x="-187" y="4662"><field name="NAME">InitVariablen</field>
                        <statement name="STACK"><block type="control" id="XPIeH#R01T5KR1EP?ge6"><mutation delay_input="false"></mutation>
                            <value name="VALUE"></value>
                            <next><block type="control" id="p?`r0r!rP+l-DL?HVpBE"><mutation delay_input="false"></mutation>
                                <next><block type="control" id="d:8g!N[q^)G{PlAhNaz-"><mutation delay_input="false"></mutation>
                                    <next><block type="control" id="aE`7d?_]rfE]MD%PNtMy"><mutation delay_input="false"></mutation>
                                        <next><block type="control" id="}j@12@xg3yqq;4gXl%rl"><mutation delay_input="false"></mutation>
                                            <value name="VALUE"></value></block></next></block></next></block></next></block></next></block></statement></block></xml>
                    • smile
                      Wahnisnn. Ich bin mega begeistert. Danke für deine Hilfe…. :shock:
                      Ich mach mich gleich mal ran und werde das bei mir eintickern und testen 🙂
                      Kurz vorab zu deiner Frage:
                      @rantanplan:
                      Genau so mit der Temperatur es ist quatsch diese alle 5 Sek. zu überprüfen!!! `
                      Das hatte ich so gemacht, um in mehreren Intervallen die Zustände zu prüfen, ob diese immer noch vorliegen.
                      z.B. Bei Sonne: Prüfe ob Sonne da ist, und prüfe in 30 Sekunden ob sie immer noch da ist. Damit nicht immer die Beschattungen rein und rausfahren.
                      Bei Wind sekündlich, da dies natürlich ein Wert ist auf den sofort eine Reaktion kommen muss.
                      Aber du hast Recht, wenn ich so darüber nachdenke… reicht es natürlich wenn immer nur dann eine Meldung erfolgt, wenn der entsprechende Wert unter - oder überschritten wird. Logo.
                      Danach kann man ja mit Zeittriggern weiterarbeiten und beim Aktionsscript des Rollos nach z.B. 2 Minuten eine Abfrage machen, ob "Sonne da" immer noch wahr ist !?!?
                      • rantanplan
                        @smile:
                        Danach kann man ja mit Zeittriggern weiterarbeiten und beim Aktionsscript des Rollos nach z.B. 2 Minuten eine Abfrage machen, ob "Sonne da" immer noch wahr ist !?!? `
                        Du brauchst keinen Zeit-Trigger 😉
                        Als nächstes baue ich die "Steuerzentrale".
                        Mal sehen ob ich heute noch Zeit finde.
                        Momentan ist bei mir "Sonnen Nachmittag da" 😄
                        PS. Du musst nichts "eintickern" sondern IMPORTIEREN.
                        Aber laufen wird es "noch" nicht.
                        • smile
                          @rantanplan:
                          Momentan ist bei mir "Sonnen Nachmittag da" 😄 `
                          😄 Bei uns in Hamburg heute auch!
                          Ich hab schon angefangen dein Blockly zu Importieren und mir anzuschauen.
                          Ich teste das ganze jetzt mal mit meiner Klima Automatik.
                          Gehört ja quasi zu einer Beschattungs Steuerung dazu, denn all diese Sachen sollen ja durchaus das Klima / Temperatur in der Wohnung beeinflusssen.
                          Temperaturabfrage mit Variablensetzung
                          Klima Einschalten NICHT nach Zeitsteuerung sondern sobald sich eine Variable ändert.
                          filename="Klima_Ausführen.png" index="0">~~
                           <xml xmlns="http://www.w3.org/1999/xhtml"><block type="procedures_defnoreturn" id="M-.z#fgX|~KI@30*R;vF" x="-412" y="-662"><field name="NAME">Temperatur Abfrage</field>
                              <statement name="STACK"><block type="controls_if" id="2:W^w:ig.+dp?Y_`8t,t"><value name="IF0"><block type="logic_compare" id="G42]?_F/nz*wxEc?3?M8"><field name="OP">GT</field>
                                      <value name="A"><block type="get_value" id="fD#FRl~`/cn1Ji4kh*P8"><field name="ATTR">val</field>
                                          <field name="OID">hm-rpc.0.KEQ0048986.1.TEMPERATURE</field></block></value>
                                      <value name="B"><block type="text" id="bZC~%nv_z.D@/}tJ5eCT"><field name="TEXT">24</field></block></value></block></value>
                                  <statement name="DO0"><block type="controls_if" id="[C8Csoo%)icUb/2IEtHP"><value name="IF0"><block type="logic_operation" id="[;{N?f7xSk%(@ZG1O-OM"><field name="OP">OR</field>
                                          <value name="A"><block type="logic_compare" id="VRvO`.RmfaN=g0bt_N@B"><field name="OP">EQ</field>
                                              <value name="A"><block type="variables_get" id="G|Bqeb(2JdrvQnK)!@t("><field name="VAR">Temperatur</field></block></value>
                                              <value name="B"><block type="text" id="wEv%OB%ana!:y?8ywgTX"><field name="TEXT">kühl</field></block></value></block></value>
                                          <value name="B"><block type="logic_operation" id="Tl+t4/6:6MpDq0V/=?ik"><field name="OP">OR</field>
                                              <value name="A"><block type="logic_compare" id="gH0n-~dmhKESF{)?6VPH"><field name="OP">EQ</field>
                                                  <value name="A"><block type="variables_get" id="d-h18U(P_hXJS{2Kmu|/"><field name="VAR">Temperatur</field></block></value>
                                                  <value name="B"><block type="text" id="oD%|4pe0gqY^JE*_-M:d"><field name="TEXT">angenehm</field></block></value></block></value>
                                              <value name="B"><block type="logic_compare" id="BK~nz@9QZ:z_cP~/o00I"><field name="OP">EQ</field>
                                                  <value name="A"><block type="variables_get" id="TiF:e!gO;gJO]aK{z[V3"><field name="VAR">Temperatur</field></block></value>
                                                  <value name="B"></value></block></value></block></value></block></value>
                                      <statement name="DO0"><block type="variables_set" id="!U8W^mT^O.=o5.u,]oY9"><field name="VAR">Temperatur</field>
                                          <value name="VALUE"><block type="text" id="tPl}yQiNWM2RrFB+YHww"><field name="TEXT">warm</field></block></value>
                                          <next><block type="debug" id="z}la@I.`9Zp-rnN*ONNJ"><field name="Severity">log</field>
                                              <value name="TEXT"><shadow type="text" id="YRvmAA||WilQ?;0#bQ{F"><field name="TEXT">warm</field></shadow></value></block></next></block></statement></block></statement>
                                  <next><block type="controls_if" id="WQ*t]M|jhl6[*#1f_LO9"><value name="IF0"><block type="logic_operation" id="JKg5aPy?cLnts{aMJFyW"><field name="OP">AND</field>
                                          <value name="A"><block type="logic_compare" id="t0Xa*0x.:[~1ny#GoP|G"><field name="OP">LTE</field>
                                              <value name="A"><block type="get_value" id="e2dEF6IJ(i{fK.@Mnv5("><field name="ATTR">val</field>
                                              <value name="B"><block type="text" id="eC0X=zoR7x~e274%{AWz"><field name="TEXT">24</field></block></value></block></value>
                                          <value name="B"><block type="logic_compare" id="W!t6pY5xZ:2HJVXu6nLp"><field name="OP">GTE</field>
                                              <value name="A"><block type="get_value" id="XeTO#O-9mV.[[]-xB4N!"><field name="ATTR">val</field>
                                              <value name="B"><block type="text" id="j^|Bv;;BIjZ4@k_XEzMc"><field name="TEXT">21</field></block></value></block></value></block></value>
                                      <statement name="DO0"><block type="controls_if" id="OwmXoujd-`Ro`CM{ZJ[N"><value name="IF0"><block type="logic_operation" id="C:?m]3IY+g(m6s^]O[y-"><field name="OP">OR</field>
                                              <value name="A"><block type="logic_compare" id="MHtVH@X.)B*44nEb_Rdu"><field name="OP">EQ</field>
                                                  <value name="A"><block type="variables_get" id="lvA0fHr?BXZ5tlTi7I}y"><field name="VAR">Temperatur</field></block></value>
                                                  <value name="B"><block type="text" id="2O,{K2rURG8_No~O4!#Q"><field name="TEXT">warm</field></block></value></block></value>
                                              <value name="B"><block type="logic_operation" id=")0#B@WN|maTR4hcI*Za6"><field name="OP">OR</field>
                                                  <value name="A"><block type="logic_compare" id="OdS=.T3dV;Mrk1N+geW="><field name="OP">EQ</field>
                                                      <value name="A"><block type="variables_get" id="I|Noz_8-g?Sw6MR%RomU"><field name="VAR">Temperatur</field></block></value>
                                                      <value name="B"><block type="text" id=")+w+(7g15q;z.~IZiAC2"><field name="TEXT">kühl</field></block></value></block></value>
                                                  <value name="B"><block type="logic_compare" id="aFP*D_uc#jW24ojS[T%("><field name="OP">EQ</field>
                                                      <value name="A"><block type="variables_get" id=":f^l2U.+n^7]K)+GTSln"><field name="VAR">Temperatur</field></block></value>
                                          <statement name="DO0"><block type="variables_set" id="zBV(agAeh?5_RnVqp.*k"><field name="VAR">Temperatur</field>
                                              <value name="VALUE"><block type="text" id="MlvJPsP]fO1AKF=V5oP{"><field name="TEXT">angenehm</field></block></value>
                                              <next><block type="debug" id="C:(jJ}y(g%WmnGaJ11q~"><field name="Severity">log</field>
                                                  <value name="TEXT"><shadow type="text" id="aGBiMR7`%IXBNl#1s96."><field name="TEXT">angenehm</field></shadow></value></block></next></block></statement></block></statement>
                                      <next><block type="controls_if" id="{3{%g6t8Pm;XyHWhOKpX"><value name="IF0"><block type="logic_compare" id="N^l`9clBFvc?Xn/;}WCc"><field name="OP">LT</field>
                                              <value name="A"><block type="get_value" id="4EGjklq)IP5#ryz%fykH"><field name="ATTR">val</field>
                                              <value name="B"><block type="text" id="BOLDj9}yy.6OZAKSh`vW"><field name="TEXT">21</field></block></value></block></value>
                                          <statement name="DO0"><block type="controls_if" id="FG~-}Qk6KJzl7-bD|_j1"><value name="IF0"><block type="logic_operation" id="J~-+n~kURA4p=rC_AirF"><field name="OP">OR</field>
                                                  <value name="A"><block type="logic_compare" id="6db|O2V!nS`mcrAf*qma"><field name="OP">EQ</field>
                                                      <value name="A"><block type="variables_get" id="L`(N@b_/!5J4|zn?=x|s"><field name="VAR">Temperatur</field></block></value>
                                                      <value name="B"><block type="text" id="NH?l}/gS^PtXa1hO}S:6"><field name="TEXT">angenehm</field></block></value></block></value>
                                                  <value name="B"><block type="logic_operation" id="(^)JromdE6X+V-hk27hC"><field name="OP">OR</field>
                                                      <value name="A"><block type="logic_compare" id="VN,w?|+^%Vr[YN-#bYi~"><field name="OP">EQ</field>
                                                          <value name="A"><block type="variables_get" id=";W2xtZXh2%%Vq_[:(!PS"><field name="VAR">Temperatur</field></block></value>
                                                          <value name="B"><block type="text" id="]4^Co2`~_!^Y-=`o5Bf!"><field name="TEXT">warm</field></block></value></block></value>
                                                      <value name="B"><block type="logic_compare" id="G.w[n-4(l;?~N;c`]Rw4"><field name="OP">EQ</field>
                                                          <value name="A"><block type="variables_get" id="}Hg4{xZ5E`uz2Smzrm^%"><field name="VAR">Temperatur</field></block></value>
                                              <statement name="DO0"><block type="variables_set" id="s_:t)7Mp%#kKIY(h_BxA"><field name="VAR">Temperatur</field>
                                                  <value name="VALUE"><block type="text" id=")ZOtM|-bv|1FZ*=~+uQO"><field name="TEXT">kühl</field></block></value>
                                                  <next><block type="debug" id=";Kr6(jM+CLv;V9hVZeD."><field name="Severity">log</field>
                                                      <value name="TEXT"><shadow type="text" id="?s=.a{)4@gant^H+^Blj"><field name="TEXT">kühl</field></shadow></value></block></next></block></statement></block></statement></block></next></block></next></block></statement></block>
                            <block type="comment" id="Vlxo`y:Fxt|8tlNww){B" x="-413" y="12"><field name="COMMENT">Klima einschalten</field>
                              <next><block type="procedures_callnoreturn" id="fC~cc+fM!#jI717dqqD3"><mutation name="Temperatur Abfrage"></mutation>
                                  <next><block type="on_ext" id="S|tlmQi*+~k;1g!8`rAJ"><mutation items="1"></mutation>
                                      <value name="OID0"><shadow type="field_oid" id="NdM!z9Nft`Y*xsf)d_Ht"><field name="oid">default</field></shadow>
                                        <block type="variables_get" id="x}:[f;6SW,RSu.1Pu/n#"><field name="VAR">Temperatur</field></block></value>
                                      <statement name="STATEMENT"><block type="controls_if" id="a-]ch.!MT+Hn03_t~#x7"><value name="IF0"><block type="logic_operation" id="jtsXJ%bH_4OJyp2GA7X8" inline="false"><field name="OP">AND</field>
                                              <value name="A"><block type="logic_operation" id="AIOi=[Aq|.iH}rm;~|dz" inline="false"><field name="OP">AND</field>
                                                  <value name="A"><block type="time_compare_ex" id="SJ]-Ix(IxMuF8[5%usBf"><mutation end_time="true" actual_time="true"></mutation>
                                                      <value name="START_TIME"><shadow type="text" id="vwTkZhalu=p,yw%%Y]`l"><field name="TEXT">11:00</field></shadow></value>
                                                      <value name="END_TIME"><shadow type="text" id="s5L+uX_a{fgkbtPj^UOI"><field name="TEXT">23:00</field></shadow></value></block></value>
                                                  <value name="B"><block type="logic_compare" id="^(Y~KddcNPe^NFtU-{,P"><field name="OP">EQ</field>
                                                      <value name="A"><block type="variables_get" id="N)n|kXO}XZ+McHUPxVov"><field name="VAR">Temperatur</field></block></value>
                                                      <value name="B"><block type="text" id="+-:ct]AV!fe*@ia-[:JU"><field name="TEXT">warm</field></block></value></block></value></block></value>
                                              <value name="B"><block type="logic_operation" id="]mpb*Ov4L.6WkODr)iPR"><field name="OP">OR</field>
                                                  <value name="A"><block type="logic_compare" id="J,3ye{.d[EFS0:9z3d)q"><field name="OP">EQ</field>
                                                      <value name="A"><block type="variables_get" id="~q9=iU:*{]V#J#K-_=5^"><field name="VAR">Klimaanlage</field></block></value>
                                                      <value name="B"><block type="text" id="5GDKS`O{_]B]k;}mY*Z~"><field name="TEXT">Klima aus</field></block></value></block></value>
                                                  <value name="B"><block type="logic_compare" id="y5X|m=/lqgku.bue#(,L"><field name="OP">EQ</field>
                                                      <value name="A"><block type="variables_get" id="-gmW?34V`_)M+t7F{,R5"><field name="VAR">Klimaanlage</field></block></value>
                                          <statement name="DO0"><block type="control" id="?/WNJOfO/:lLo9g#N=5q"><mutation delay_input="false"></mutation>
                                              <field name="OID">hm-rpc.0.BidCoS-RF.9.PRESS_SHORT</field>
                                              <value name="VALUE"><block type="logic_boolean" id="nC8}.7SsG]bG4u_r?l7C"><field name="BOOL">TRUE</field></block></value>
                                              <next><block type="variables_set" id="z??u^sEs#)CY+q)MTsK)"><field name="VAR">Klimaanlage</field>
                                                  <value name="VALUE"><block type="text" id="a!eRrys:TfND{g)KXu(1"><field name="TEXT">Klima an 20°</field></block></value>
                                                  <next><block type="debug" id="U%w.Sp}k=!Mhp7KM!JYO"><field name="Severity">log</field>
                                                      <value name="TEXT"><shadow type="text" id="cpc,OUzBccic?Ldkv:ky"><field name="TEXT">Klima läuft</field></shadow></value></block></next></block></next></block></statement>
                                          <next><block type="comment" id=")~T4i5c?Tf#YQ|yFi_Sw"><field name="COMMENT">Klima ausschalten</field>
                                              <next><block type="controls_if" id="L]!,y5hBwGBv|W/R3Y(y"><value name="IF0"><block type="logic_operation" id="whpLC^,mj4N2J2#n(IZ?" inline="false"><field name="OP">AND</field>
                                                      <value name="A"><block type="logic_compare" id="2_FW*t;}Em].~64fFlHM"><field name="OP">EQ</field>
                                                          <value name="A"><block type="variables_get" id="z7#-J5?NoO63txy-hE{D"><field name="VAR">Klimaanlage</field></block></value>
                                                          <value name="B"><block type="text" id="1E6oSELdr)Txz6z=O+[N"><field name="TEXT">Klima an 20°</field></block></value></block></value>
                                                      <value name="B"><block type="logic_operation" id="G=cKdG{*DLx,:?BS`aIz"><field name="OP">OR</field>
                                                          <value name="A"><block type="logic_compare" id="j*((*OoS09X`F6/,t/vw"><field name="OP">EQ</field>
                                                              <value name="A"><block type="variables_get" id="{MxyQjlb6=BG0?W@]N}5"><field name="VAR">Temperatur</field></block></value>
                                                              <value name="B"><block type="text" id="KG{;3EaOJ.4s{,q+5dzq"><field name="TEXT">angenehm</field></block></value></block></value>
                                                          <value name="B"><block type="logic_compare" id="Nr@iI#JR-d}HAty_TSeg"><field name="OP">EQ</field>
                                                              <value name="A"><block type="variables_get" id="v4C6@ZxymG!L!K9T*!Hf"><field name="VAR">Temperatur</field></block></value>
                                                              <value name="B"><block type="text" id="b[wUp.G5si~WSVqpExJ)"><field name="TEXT">kühl</field></block></value></block></value></block></value></block></value>
                                                  <statement name="DO0"><block type="variables_set" id="KklN4ykwIm5l/5:{EIx("><field name="VAR">Klimaanlage</field>
                                                      <value name="VALUE"><block type="text" id="MPmEc|%95*t_yn!9fFk+"><field name="TEXT">Klima Restlaufzeit</field></block></value>
                                                      <next><block type="timeouts_settimeout" id="=-oTruDZK*8./~A}3HxE"><field name="NAME">timeout</field>
                                                          <field name="DELAY">120</field>
                                                          <statement name="STATEMENT"><block type="control" id="Ee?@_zLBoef07]q{W7La"><mutation delay_input="false"></mutation>
                                                              <field name="OID">hm-rpc.0.BidCoS-RF.12.PRESS_SHORT</field>
                                                              <value name="VALUE"><block type="logic_boolean" id="YUgvqzTL2QJT.(;L`tDE"><field name="BOOL">TRUE</field></block></value>
                                                              <next><block type="variables_set" id="LH!JX5w.G{sx1TX[*zCa"><field name="VAR">Klimaanlage</field>
        <value name="VALUE"><block type="text" id="txsJ4(Xs`-cEfLsN,_vJ"><field name="TEXT">Klima aus</field></block></value>
        <next><block type="debug" id="NKEHsLr{R-Z!YLt6iS[,"><field name="Severity">log</field>
        <value name="TEXT"><shadow type="text" id="g3sDxB30^L|s=k_]94DB"><field name="TEXT">Klima läuft nicht mehr</field></shadow></value></block></next></block></next></block></statement></block></next></block></statement></block></next></block></next></block></statement></block></next></block></next></block></xml>
                          Dazu fällt mir ein: Wenn man das und auch das Beschattungs Script das erste mal startet, und es z.B. gerade "Warm" ist, dann löst der trigger doch nicht aus, weil er die Schwelle ja nicht aktiv überschritten hat, korrekt? Wäre dann ggf. ein kleiner Nachteil gegenüber der Zeitgesteuerten Abfrage?
                          Kleine Nebeninfo zur Klimaanlage: Ist eine Daikin Klimaanlage, welche sich eigentlich nur mit der Systemeigenen Fernbedienung ansteuern lässt. Die Brücke schlage ich hier üer ir.trans, ein kleiner Infrarot Miniserver der sich im Netzwerk befindet, dem ich vorher die Daikin Befehle beigebracht habe und nun kann ich per Homematic / CuxD http Befehl die Klimaanlage steuern 8-)
                          • rantanplan
                            Hallo smile
                            Mir ist schon ganz schwindelig 😉
                            So viele doppelte und teilweise widersprüchliche Bedingungen erschweren den Durchblick.
                            Und alles in einem Blockly 😮
                            Zum "aufdröseln" fange ich mal mit der Sonne an.
                            Das nächste Beispiel kannst Du in ein neues Blockly importieren und z.B. "checkSonne" benennen.
                            Brauchen wirst Du noch "checkWind", "checkTemperatur", "checkRegen"
                            Schau Dir mal "checkSonne" an. Vielleicht bekommst Du ja die anderen alleine hin.
                            Diesmal nur den Export.
                            Bei Fragen…fragen.
                             <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="iq)T|5XZ5a[grP|:#]ko" x="-412" y="-2063"><field name="COMMENT">Hier musst Du Deinen Datenpunkt einsetzen</field>
                                <next><block type="on_ext" id="X^pURd.J~{|Qy%!FAT:c"><mutation items="1"></mutation>
                                    <value name="OID0"><shadow type="field_oid" id="Pzhtf4n4H6K8[tlkt]~1"><field name="oid">default</field></shadow>
                                      <block type="text" id="ll^6_zy.(b)W^Ni@IuF~"><field name="TEXT">Datenpunk Brightness</field></block></value>
                                    <statement name="STATEMENT"><block type="comment" id="wDSePIi}BB4`W7{k|OV_"><field name="COMMENT">Abfrage Sonne Vormittag</field>
                                        <next><block type="controls_if" id="vp!,0i}:wu*OJ][nB8=."><value name="IF0"><block type="time_compare" id="6i6dO#/N`hGx8B-8;tH3"><mutation end_time="true"></mutation>
                                                <field name="START_TIME">08:00</field>
                                            <statement name="DO0"><block type="controls_if" id="}^)vQcW(i0DQ?Ty{rMZB"><mutation elseif="1"></mutation>
                                                <value name="IF0"><block type="logic_compare" id="yHWuOq#S2@:qwcn(NCj("><field name="OP">GT</field>
                                                    <value name="A"><block type="get_value" id="+{PQ.~sdV7,2TCisbUB@"><field name="ATTR">val</field>
                                                        <field name="OID">hm-rpc.0.NEQ1100463.1.BRIGHTNESS</field></block></value>
                                                    <value name="B"><block type="text" id="%T}.Q8rVjc!/;,4mj+tn"><field name="TEXT">200</field></block></value></block></value>
                                                <statement name="DO0"><block type="control" id="#X6xT+IU%qObrw^I:D7L"><mutation delay_input="false"></mutation>
                                                    <value name="VALUE"><block type="text" id="(I=U0!0Ils:27}I;-RqJ"><field name="TEXT">Sonne vormittag da</field></block></value>
                                                    <next><block type="debug" id="bG0I2XaGZ,4C^_?[Q!w!"><field name="Severity">log</field>
                                                        <value name="TEXT"><shadow type="text" id="_e4F?`=/t9GoPJ4w_79_"><field name="TEXT">***Sonne vormittag da</field></shadow></value></block></next></block></statement>
                                                <value name="IF1"><block type="logic_compare" id="WvG%rNBkDFZAdnkrd46m"><field name="OP">LT</field>
                                                    <value name="A"><block type="get_value" id="6I?G^y`_@09`)_{`/AVw"><field name="ATTR">val</field>
                                                    <value name="B"><block type="text" id="ZI|k3w-PzfO3]~=WOltK"><field name="TEXT">200</field></block></value></block></value>
                                                <statement name="DO1"><block type="control" id="}l_QoYUoMU(s{9m.7Z2T"><mutation delay_input="false"></mutation>
                                                    <value name="VALUE"><block type="text" id="hr.PTQOz)OyqSHpnk8Jx"><field name="TEXT">Sonne vormittag weg</field></block></value>
                                                    <next><block type="debug" id="`N%wGh+cZ+U3x;6EK)0D"><field name="Severity">log</field>
                                                        <value name="TEXT"><shadow type="text" id="CS+;:.SD?}CxMf**Xoy9"><field name="TEXT">***Sonne vormittag weg</field></shadow></value></block></next></block></statement></block></statement>
                                            <next><block type="comment" id="d)eKPvYD=b{i?(FD*R}X"><field name="COMMENT">Abfrage Sonne Nachmittag</field>
                                                <next><block type="comment" id="EpTYEa;+b;vi2p`Mo]kE"><field name="COMMENT">Zeit >15:00 !!!!! s. Bedingung vorher!!!</field>
                                                    <next><block type="controls_if" id="fySpyS~y%2bWw|DnDHaR"><value name="IF0"><block type="time_compare" id="=nyP^-OQbA*-Z5fe1AU3"><mutation end_time="true"></mutation>
                                                            <field name="START_TIME">15:01</field>
                                                        <statement name="DO0"><block type="controls_if" id="ei1,8806M]^hHj_tgIoO"><mutation elseif="1"></mutation>
                                                            <value name="IF0"><block type="logic_compare" id="d3bMmntK18Wyn;?twFeR"><field name="OP">GT</field>
        <value name="A"><block type="get_value" id="BE~.aZoA0%4?(6X_#Q/*"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="u[)MQ6*Kt=GcfBOfs+/c"><field name="TEXT">205</field></block></value></block></value>
                                                            <statement name="DO0"><block type="control" id="%*,.g]Dm*_f;Jt3w+-6X"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="@cAw:.T1GGLW.o;CFx0S"><field name="TEXT">Sonne nachmittag da</field></block></value>
        <next><block type="debug" id="sBh={G..8CZX@e%1A?6c"><field name="Severity">log</field>
        <value name="TEXT"><shadow type="text" id="ND@9!1JgC:W0Fg!=_Qt^"><field name="TEXT">***Sonne Nachmittag da</field></shadow></value></block></next></block></statement>
                                                            <value name="IF1"><block type="logic_compare" id="5GlygkH`O[xilq0I-F!D"><field name="OP">LT</field>
        <value name="A"><block type="get_value" id="}yiCbDnHf@[tTW9;Z-/Q"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="^R9wf{r9J{PN(pXC812="><field name="TEXT">205</field></block></value></block></value>
                                                            <statement name="DO1"><block type="control" id="g8[Ye^d^8Ri]BljN6vU~"><mutation delay_input="false"></mutation>
        <value name="VALUE"><block type="text" id="LMx=CYq)))0b.*@m1,D!"><field name="TEXT">Sonne nachmittag weg</field></block></value>
        <next><block type="debug" id="HthN5,l`oW[:/rX-fuan"><field name="Severity">log</field>
        <value name="TEXT"><shadow type="text" id="`k5[~_m@;9ZtJzu!)ptH"><field name="TEXT">***Sonne Nachmittag weg</field></shadow></value></block></next></block></statement></block></statement></block></next></block></next></block></next></block></next></block></statement></block></next></block></xml>
                            • rantanplan
                              @smile:
                              Klima Einschalten NICHT nach Zeitsteuerung sondern sobald sich eine Variable ändert. `
                              Hi
                              Du bist ja wieder bei lokalen Variablen und einem Blockly :?
                              Das wird so nicht funktionieren!!!
                              Lokale Variablen lassen sich NICHT triggern!
                              Wenn Du den ersten Teil ausgeführt hast, hast Du doch eine Globale Variable "Temperatur".
                              • smile
                                Langsam wird n Schuh draus 😉
                                Was ich heute dazu gelernt habe: Es gibt Lokale Variablen (Quasi in ein und demselben Script) und Globale Variablen, welche ich dann unter den "Objekten" finden kann.
                                Das mag für die meisten von euch so banal und dämlich klingen, aber vor 2 Wochen wusste ich noch nichtmal was Variablen sind….. :roll:
                                Dementsprechend habe ich mich nun rangemacht und erstmal mit dem einfacheren Klima Script angefangen und nach der Anleitung von rantaplan das Klimascript umgestellt:
                                Temperaturabfrage mit globalen Variablen:
                                Daraufhin Ausführen der Klimaanlage:
                                Da sind zwar auch wieder lokale Variablen für den aktuellen Status Klimaanlage mit dabei, aber das sollte erstmal nicht stören. Werd ich ggf. später noch ändern.
                                Nichts desto trotz bleibt für mich für dieses Script als auch für das Beschattungs Script die Frage: Ohne "Timeouts" und zweitmaliger Abfrage werde ich das Problem haben dass zu viel hin und hergeswitched wird, oder?
                                Beisiel: Die Helligkeitsschwelle liegt bei 205. Nun ist es hell und die Wetterstation meldet den Wert 206, –> Variable "Sonne da" wird gesetzt, Beschattung fährt aus. 2 Min später (oder wie auch immer das Sendeintervall der HM Wetterstation ist), liegt der Helligkeitswert zufällig bei 204. Die Beschattung würde dann wieder einfahren.
                                Wenn es z.B. wolkig ist mit Abwechselnd Sonne / Wolken, dann würden entsprechend viele Trigger gesetzt werden und die Beschattung fährt ständig ein und aus.
                                Dies hatte ich vorher mit der "Zeitplan" abfrage etwas unter kontrolle, indem ich einfach gesagt habe er sollte z.B. nur alle 4 Minuten statt 1 Minute abfragen.
                                Bzw. mit Timeout: Wenn der Trigger gesetzt wird, soll er nochmal 4 Minuten warten und dann prüfen ob die Variable immer noch Wahr ist, und erst dann die Beschattung ausfahren.
                                Also wäre jetzt ein Timeout die passende Wahl oder?
                                • rantanplan
                                  @smile:
                                  Langsam wird n Schuh draus 😉 `
                                  Freut mich
                                  @smile:
                                  Was ich heute dazu gelernt habe: Es gibt Lokale Variablen (Quasi in ein und demselben Script) und Globale Variablen, welche ich dann unter den "Objekten" finden kann. `
                                  Und die globalen Variablen kann man mit VIS darstellen/steuern!
                                  @smile:
                                  Das mag für die meisten von euch so banal und dämlich klingen, aber vor 2 Wochen wusste ich noch nichtmal was Variablen sind….. :roll: `
                                  Dafür hast Du aber mit einem tollkühen Projekt angefangen 😉
                                  @smile:
                                  Da sind zwar auch wieder lokale Variablen für den aktuellen Status Klimaanlage mit dabei, aber das sollte erstmal nicht stören. Werd ich ggf. später noch ändern. `
                                  Lokale Variablen haben durch aus einen Sinn. Aber eben "nur" als lokale "Hilfsvariablen"
                                  @smile:
                                  Also wäre jetzt ein Timeout die passende Wahl oder? `
                                  Bei schnell wechselnen Bedingungen ist eine Automation, von bewegenden Teilen, recht schwierig.
                                  Selbst mit Timern muss das nicht immer klappen. Sonne und Wolken haben nun mal keinen Rythmus.
                                  Da muss man sich überlegen, ob bei wechselhaften Wetter eine Automation Sinn macht.
                                  Ich würde mir einen globale Variable "Beschattung", vom Typ Logikwert anlegen.
                                  Dies ist der nächste Variablentyp, den Du unbedingt lernen solltest.
                                  Diese Variablen kennen nur den Zustand wahr/unwahr. (Wie ein Lichtschalter an=wahr aus=unwahr)
                                  Bei wechselhaften Wetter würde ich "Beschattung" auf "unwahr" setzten.
                                  Dann im Beschattungs-Blockly als erstes die Bedingung "Falls Beschattung = wahr… mache...."
                                  Nochmal zu den Logik-Variablen.
                                  Du benutzt immer Text-Vergleiche. Das ist die schlechteste Art Vergleiche zu machen.
                                  1. Textvergleiche sind "langsam" und verbrauchen Rechenleistung
                                  2. Fehleranfällig!!!!! Texte werden 1zu1 verglichen. Mit Gross-/Kleinscheibung.
                                  Auch ein versehendlich angefügtes Leerzeichen führt zu Fehlern die man stundenlang suchen kann.
                                  Du vergleichst z.B.
                                  Sonne vormittag = "Sonne vormittag da"
                                  oder
                                  Sonne vormittag = "Sonne vormittag weg"
                                  Wie Du siehst sind das ja nur 2 Zustände!
                                  Entweder "da" oder "weg" -> "wahr" oder "unwahr"
                                  Variable "Sonne vormittag" als Logikwert spart Tipparbeit und macht die Sache fehlerunanfälliger.
                                  Falls "Sonne vormittag" = "wahr" mache.....
                                  Für "wahr"/"unwahr" gibt es einen extra Baustein unter "Logik".
                                  Du siehst es gibt noch viel zu tun 😉
                                  • smile
                                    @rantanplan:
                                    Und die globalen Variablen kann man mit VIS darstellen/steuern! `
                                    DAS wurde mir dann auch klar als die Variablen dann unter den Objekten auftauchten, was dem ganzen natürlich noch mehr Sinnhaftigkeit gibt.
                                    Mit VIS werde ich starten wenn die Großzahl der Scripte rund laufen.
                                    @rantanplan:
                                    Da muss man sich überlegen, ob bei wechselhaften Wetter eine Automation Sinn macht. `
                                    Hmm ich kann den Gedankengang mit der gobalen Beschattungsvariable nachvollziehen, ABER für mich macht die Automatik gerade auch bei wechselhaften Wetter Sinn.
                                    Es bringt mir nichts wenn es ein heißer Sommertag ist, aber zwischendurch kurz Wolken oder kleine Schauer, und du Beschattungs-Automatik dann auf "unwahr" steht.
                                    Ich versuche das mal mit "Verzögerung" oder mit der Timout Funktion.
                                    Dazu eine Frage: Was ist eigentlich genau der Unterschied zwischen diesen beiden:
                                    Also dem Arbeiten mit Timeouts und dem Arbeiten mit Verzögerungen?
                                    Was bewirkt "löschen falls läuft" bei der Verzögerung?
                                    Ich werde den Test mal wagen und gucken wie sich das mit wechselhaftem Wetter verhält.
                                    Mittwoch mache ich wohl mal wieder einen reinen io.broker Tag… 😄
                                    @rantanplan:
                                    Falls "Sonne vormittag" = "wahr" mache….. `
                                    Logisch… Macht auf jeden Fall Sinn sofern man nur 2 Zustände hat, das werd ich auch anpassen.
                                    nochmals Danke für die viele super Hilfe. Ich hoffe ich kann irgendwann auch gut beitragen zu diversen Themen. 🙂
                                    • smile
                                      So, ich habe das Blockly jetzt mal Stück für Stück umgesetzt.
                                      Das mit den Systemvariablen funktioniert sehr gut.
                                      Aber wie erwartet Springt bei wechselhafter Sonne das Rollo ständig hin und her.
                                      Deshalb habe ich jetzt jeweils einen Timout eingefügt, der nach einer gewissen Zeit nochmal prüft, ob immer noch alle Bedingungen wahr sind, und erst dann die Rolladen fährt.
                                      Allerdings bekomme ich die Fehlermeldung:
                                      17:19:51.877 [error] javascript.0 script.js.Beschattung_Auto_NEU compile failed: SyntaxError: Unexpected identifier
                                      Dies ist das aktuelle Blockly:
                                       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="IR94DiuG7v6~=Zg2dVp6" x="-862" y="4413"><field name="COMMENT">Variablen initialisieren</field>
                                                              <next><block type="comment" id="8ad`[k`vChnAS/G:n55C"><field name="COMMENT">Rollo runter</field>
        <value name="B"><block type="logic_boolean" id="yM7D*3,6*!%NyTfs.y0#"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_boolean" id="aM_V+TG|fstf69LZO525"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_boolean" id="u,L[}8Jtx4Cc-;-ZZSdj"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value></block></value>
        <statement name="DO0"><block type="timeouts_cleartimeout" id="~}{/Ke;zWRs*|29FD;^`"><field name="NAME">rollo vormittag hoch</field>
        <next><block type="timeouts_settimeout" id="T}#8)DPS~6z/0K{(zJuZ"><field name="NAME">timeout Rollo vormittag runter</field>
        <field name="DELAY">2</field>
        <statement name="STATEMENT"><block type="controls_if" id="q/)rtF35i@Xv2F=;]Iqj"><value name="IF0"><block type="logic_operation" id="*X`dQPE`f%%-B3@k+DJ." inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="otcq/KN#l(cJsZRfdh]%"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="j#I:xz+vB,Sa=n].e[w."><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="Qq4l_|`rdoTiycyoIa-8"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="!Xz/Tv,S7BXPcQD5sYz}" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="*7z[Z|;k.%cGkc8=9__f"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="/FoDQ*IQR(F~C(3klDhH"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="?I+NJ-hkSzhqAubTzKpB"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="0XTlJZv=A:@.RUX`+xK," inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="!9RHUQ?0cx(aAzKed=^b"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="m#+kbM5c:NLIU?6FVnzO"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="j]Fp^P|OKPUNJ}i?aWiw"><field name="TEXT">Kein Wind</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="(zY_O^yD_EJH6.HGzMfC"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="OiGGRpAy}P1u2^0g3ohK"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="s?V/;Ams?GK#5Ak!GaN0"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value></block></value>
        <statement name="DO0"><block type="controls_if" id="2C_;cBna5MA0KX:d7W[Z"><value name="IF0"><block type="logic_compare" id="o0E{x9{3_F5Pu7]2)Ny`"><field name="OP">GT</field>
        <value name="A"><block type="get_value" id="O*bY@=(A9JVKR5?_b#zt"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="bAd6iS3:QTbdXKZ(Gm4@"><field name="TEXT">2</field></block></value></block></value>
        <statement name="DO0"><block type="control" id="E0FqB.vmqN)0oxR3i8Tl"><mutation delay_input="false"></mutation>
        <field name="OID">hm-rpc.0.BidCoS-RF.15.PRESS_SHORT</field>
        <value name="VALUE"><block type="logic_boolean" id="*o*giSZH_/A33/dtxt1M"><field name="BOOL">TRUE</field></block></value>
        <next><block type="debug" id="_/q;4w4IIxw)vN12fc,0"><field name="Severity">log</field>
        <value name="TEXT"><shadow type="text" id="?Hj,KRuyA#BUy`)g(pDz"><field name="TEXT">***Rollo vormittag runter</field></shadow></value></block></next></block></statement>
        <field name="OID">hm-rpc.0.BidCoS-RF.17.PRESS_SHORT</field>
        <value name="VALUE"><block type="logic_boolean" id="T58k4CuSjyRb#}@QqaZN"><field name="BOOL">TRUE</field></block></value></block></statement></block></next></block></statement></block></statement></block></next></block></statement>
        <value name="B"><block type="logic_boolean" id="cV7C3CPU?!!gNIn%QV9z"><field name="BOOL">FALSE</field></block></value></block></value>
        <value name="B"><block type="logic_boolean" id="2^[cXK3WpM)m8XR{oyk("><field name="BOOL">FALSE</field></block></value></block></value></block></value>
        <statement name="DO1"><block type="timeouts_cleartimeout" id="Mjl{H_9sTe[P(_7,VBnN"><field name="NAME">timeout Rollo vormittag runter</field>
        <next><block type="timeouts_settimeout" id="?0iD9}*T9:9/%vN%)!r]"><field name="NAME">timeout rollo vormittag hoch</field>
        <field name="DELAY">5</field>
        <statement name="STATEMENT"><block type="comment" id="oaDOVEV9`{g3RKT)aHQ2"><field name="COMMENT">Rollo vormittag hoch</field>
        <next><block type="controls_if" id="FcNEyO_Z11Ce7C=:!(}S"><value name="IF0"><block type="logic_operation" id="zS}/%ym4_1Z*Hl7P_5JW" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="tOT:^|;vdkZ9v/{*1/Kr"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="[D}eHU4Yahb-p,ar^5F2"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="VmlrqRhpWk~p{Y^#/?r@"><field name="BOOL">FALSE</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="f*}_1;3,:iqoO[l.3?}Q"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id=".(P=.~ll??lL@o~hw=dv"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="EZ/ve5Y2|x^;X#NN}lES"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
        <statement name="DO0"><block type="controls_if" id="Ikr|]3GS7cUr1l-!`~}`"><value name="IF0"><block type="logic_compare" id="~6U1U.`obRseMnyazi!n"><field name="OP">LT</field>
        <field name="OID">hm-rpc.0.BidCoS-RF.14.PRESS_SHORT</field>
        <value name="VALUE"><block type="logic_boolean" id=";I`bgCeW)=yB0|zr/3G,"><field name="BOOL">TRUE</field></block></value>
        <next><block type="debug" id="aW#DciwZNc9w%K}AjQ]U"><field name="Severity">log</field>
        <value name="TEXT"><shadow type="text" id="Tg8;)d7uK2wltZucmF[l"><field name="TEXT">***Rollo vormittag hoch</field></shadow></value></block></next></block></statement>
        <field name="OID">hm-rpc.0.BidCoS-RF.16.PRESS_SHORT</field>
        <value name="VALUE"><block type="logic_boolean" id="(V5s4MZvm7i;rUo#W{Zd"><field name="BOOL">TRUE</field></block></value></block></statement></block></next></block></statement></block></next></block></statement></block></next></block></statement></block></statement>
        <next><block type="comment" id="*v7W|OD.Y(0IB%Uz2N0O"><field name="COMMENT">Rollo runter</field>
        <value name="IF0"><block type="logic_operation" id="%JLXvkH!H]F!S/wjx~wC" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="Bb;9]KvdUlEyzxrIXb1:"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="vnK_E/VE]9[ca}v28HKz"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="F@Y#j%Mie~w7nL=F1i|!"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="EuMu#c3~{hb}Qf^5C~dM" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="=M`hZ/bd^,dTzI.C;~77"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="9WHeiTYXI:.5O0F,y4vH"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="@=TAutx,+7j3#;Z#m#~D"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="F]]pQKq8!;^N!RS|q-DD" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="*7_=PW:A3NV[19A61SQd"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="lOI6siE#eqgO^G;6LOTS"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="2W0SO-0/%;;1tj_g*J(~"><field name="TEXT">Kein Wind</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="Xu]tK/#?vK+Q~#R+Jc@2"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="cg/u.?5ei[TT7,abYD2m"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="Mr*(#Lx14PQ`YS2aWN,="><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value></block></value>
        <statement name="DO0"><block type="timeouts_cleartimeout" id="X5u-BUdw8MX^)SUh9F{7"><field name="NAME">Rollo nachmittag hoch</field>
        <next><block type="timeouts_settimeout" id="1^)pOzA#RdD9/VQ!Soh6"><field name="NAME">Rollo nachmittag runter</field>
        <statement name="STATEMENT"><block type="controls_if" id="Lx3s/gzfzb;qB!{GM[gY"><value name="IF0"><block type="logic_operation" id=".eB^#@yULPVpr}R`Dm|t" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="}gX_z*%m4c0xn]7,Vy*x"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="z]F5:Fc#=tFf21@3z,J?"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="88~~+=HtNg4esSgwsda,"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="~qp}s)_QK@sa~iXf(yZQ" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="=hBREHB0KFI,)e`~BCpC"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="~mPKvt-7Dhbk#UY7`{lK"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="s%3-knhlS-x_{uYNS_16"><field name="BOOL">TRUE</field></block></value></block></value>
        <value name="B"><block type="logic_operation" id="VPQ7XoUWt5#0ryH4eeFr" inline="false"><field name="OP">AND</field>
        <value name="A"><block type="logic_compare" id="EdGc+P0x@R)ff[o?NQx5"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id=".HV4ZH0m-cr:g_%6o`5T"><field name="ATTR">val</field>
        <value name="B"><block type="text" id="{%X]2BeEbcHR[6K2QTfM"><field name="TEXT">Kein Wind</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="s3=q2q{xt4ZEO0Psl^(!"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="[hoXpLD;!X}V/20:a2+/"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="e6X+9VfXH@e@F`dWHE=C"><field name="BOOL">FALSE</field></block></value></block></value></block></value></block></value></block></value>
        <value name="VALUE"><block type="logic_boolean" id="DB6`gmw]VEd;qu(#2Q6u"><field name="BOOL">TRUE</field></block></value>
        <next><block type="debug" id="fL%g,ko,Dt)KCSec1Mxs"><field name="Severity">log</field>
        <value name="TEXT"><shadow type="text" id="9NmAa%Ys0-|_#,l3n?{d"><field name="TEXT">Rollo Nachmittag runter</field></shadow></value></block></next></block></statement>
        <value name="VALUE"><block type="logic_boolean" id="AGAWadFeku(FsPj@{7!T"><field name="BOOL">TRUE</field></block></value></block></statement></block></next></block></statement></block></statement>
        <next><block type="comment" id="O{YbPLA=F^.HAH{7yxQ9"><field name="COMMENT">Rollo hoch</field></block></next></block></next></block></statement>
        <value name="B"><block type="logic_boolean" id="sL%{*o]@E}F?hUE5;5dt"><field name="BOOL">FALSE</field></block></value></block></value>
        <value name="B"><block type="logic_boolean" id="oqzjT`0qWZaBrhW;Zj;X"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
        <statement name="DO1"><block type="timeouts_cleartimeout" id="^HI|eFvbUmSTO1n2|Bf0"><field name="NAME">Rollo nachmittag runter</field>
        <next><block type="timeouts_settimeout" id="Benx4L,ZBQGc;)MHknHr"><field name="NAME">Rollo nachmittag hoch</field>
        <statement name="STATEMENT"><block type="controls_if" id="eeMI^qg1j/uDpWqAIFXQ"><value name="IF0"><block type="logic_operation" id="*BWPJXNg^kr3XJ{9?z^8" inline="false"><field name="OP">OR</field>
        <value name="A"><block type="logic_compare" id=",r5Nx.DEwfuDX^8C|^c}"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="V|;op3(W{NQ?#b{W0bD;"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="H]h{/}~#8r~@|CVRjp},"><field name="BOOL">FALSE</field></block></value></block></value>
        <value name="B"><block type="logic_compare" id="oMHk,}k^DBafPb99od(s"><field name="OP">EQ</field>
        <value name="A"><block type="get_value" id="DJv1TOA+,4P#o*x`lM!3"><field name="ATTR">val</field>
        <value name="B"><block type="logic_boolean" id="?f~fnHgEgxgpbid}!;q1"><field name="BOOL">FALSE</field></block></value></block></value></block></value>
        <statement name="DO0"><block type="controls_if" id="BrJx+TOrgC5::]2b6fbQ"><value name="IF0"><block type="logic_compare" id="9CZ5^vv#K7S*_ZK7igZ4"><field name="OP">LT</field>
        <value name="VALUE"><block type="logic_boolean" id=":h7Xrq;];:`O~hOcdFnM"><field name="BOOL">TRUE</field></block></value>
        <next><block type="debug" id="wZGbdZc`b{R[dNh*fI4K"><field name="Severity">log</field>
        <value name="TEXT"><shadow type="text" id="B;0bWlKqmT,NEPc1X1i;"><field name="TEXT">Rollo Nachmittag hoch</field></shadow></value></block></next></block></statement>
        <value name="VALUE"><block type="logic_boolean" id="wEUqg4[?ueXUUhE=ikAG"><field name="BOOL">TRUE</field></block></value></block></statement></block></next></block></statement></block></statement></block></next></block></statement></block></statement></block>
                                        <block type="procedures_defnoreturn" id="(+6Mz{Je,L}7n^5*t*wO" x="-362" y="4463"><field name="NAME">InitVariablen</field>
                                                              <value name="VALUE"></value></block></next></block></next></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement></block></next></block></next></block></next></block></next></block></xml>
                                      Woran könnte die Fehlermeldung liegen?
                                      Ohne die Timeouts fahren die Rollos ständig rauf und runter. Ohne die Timeouts hatte das Script jedoch keine Fehlermeldung angezeigt.
                                      • smile
                                        smile last edited by
                                        Problem gelöst - man sollte in Timouts keine Leerzeichen verwenden!
                                        Habe es jetzt geändert in z.B. "timeout_Rollo_vormittag_runter" dann taucht der Fehler nicht mehr auf.
                                        Jetzt mal schauen wie sich das in der Praxis verhält 8-)
                                        • rantanplan
                                          @smile:
                                          Problem gelöst - man sollte in Timouts keine Leerzeichen verwenden! `
                                          Hätte ich nicht gewusst.
                                          Aber ich benutze grundsätzlich keine Leerzeichen und Umlaute in Variablen und Gerätenamen.
                                          Funktioniert heutzutage meistens….aber nicht immer. 😉
                                            paul53 last edited by
                                            ` > Javascript-Variablennamen
                                            bestehen aus Buchstaben (wobei auch ein Unterstrich "_" als Buchstabe zählt),
                                            aus Ziffern,
                                            dürfen keine Leerzeichen enthalten und keine Bindestriche enthalten,
                                            dürfen nicht mit einer Zahl, einem Sonderzeichen oder Satzzeichen anfangen,
                                            dürfen nicht mit einem Schlüsselwort übereinstimmen.
                                            Das erste Zeichen muss ein Buchstabe oder ein Unterstrich sein. `
                                            blockly climate
                                            18
                                            80
                                            31827
