    3. Off Topic
    4. MariaDb verschieben
    MariaDb verschieben
      Mark @Thomas Braun last edited by
      @thomas-braun Wenn du mit Desktop meinst, dass da ein Bildschirm und Tastatur dranhängt: nein
      Auf der SD-Karte ist aber "ubuntu-22.10-desktop-amd64" installiert, insofern: ja
      pi@raspberrypi:/media/pi/RaspData/mariadb $ mount | sort
      bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
      cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
      configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
      debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
      /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
      /dev/mmcblk0p2 on / type ext4 (rw,noatime,commit=600)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
      /dev/sda1 on /media/pi/RaspData type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096,uhelper=udisks2)
      devtmpfs on /dev type devtmpfs (rw,relatime,size=340548k,nr_inodes=85137,mode=755)
      fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
      gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
      mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
      proc on /proc type proc (rw,relatime)
      pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
      securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
      sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
      systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
      tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
      tmpfs on /run type tmpfs (rw,nosuid,nodev,size=188856k,nr_inodes=819200,mode=755)
      tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=94424k,nr_inodes=23606,mode=700,uid=1000,gid=1000)
      tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        Thomas Braun Most Active @Mark last edited by Thomas Braun
        @mark sagte in MariaDb verschieben:
        Und das ganze Ding spuckt dir jetzt per Automount da rein.
        Ubuntu 22.10 verwendet man eh nicht sondern die aktuelle Ubuntu-LTS-Version. (Wenn es denn unbedingt Ubuntu sein muss. Ich würde da ein Debian empfehlen).
        Warum installiert man da einen Desktop, wenn weder Bildschirm noch Tastatur dranhängt? Komplett sinnfrei.
        M D 2 Replies Last reply Reply Quote 0
          @thomas-braun ok, dann sind wir ja schon einen Schritt weiter. Ich hatte ja bereits erwähnt, dass ich blutiger Anfänger bin. Die installierte Version hab ich drauf gemacht, als das Ding noch bei mir im Hobbyraum mit Bildschirm und Tastatur lag. Danach hab ich einige Anleitungen ausprobiert und versucht mich etwas einzuarbeiten. Daraufhin hab ich iobroker installiert und den Raspy in den Keller gepackt. Von da an ging es nur noch per SSH.
          Du hast mit Sicherheit recht mit dem was du sagst, das bedeutet aber, dass ich jetzt erstmal eine andere Karte suchen muss, Debian installiere, iobroker und adapter drauf, alles wieder neu einrichten und dann aber vermutlich am gleichen Punkt wieder stehe und die Datenbank bzw das Verzeichnis nicht hinbekomme. (Wobei ich auch gleich mit der Datenbank beginnen könnte...)
            @mark
            Wenn alles 'frisch neu', dann könntest du direkt bei der Installation den Stick in den richtigen Mountpunkt hängen.
            Wobei ich auf einen Raspberry auch ein RaspberryOS installieren würde.
              @thomas-braun Hey Thomas, vielen Dank für Deine Hilfe! War wohl echt das einfachste mit dem neu aufsetzten. Bin begeistert, wie schnell und einfach das jetzt so funktioniert hat.
                @mark
                Ja, mein Reden. GUIs stehen eigentlich immer nur im Weg herum, wenn man wirklich MIT/AN einem Server-System arbeiten möchte.
                  @thomas-braun zu früh gefreut!
                  Hat alles super funktioniert. Auf einmal war 'sda' weg und tauchte als 'sdb' wieder auf. Der Mountpunkt ist dadurch auch weg.
                  Hab dann sdb per mount ins richtige Verzeichnis eingebunden und mariadb neu gestartet (mit passworteingabe). Dann funktionierte es wieder.
                  Kurze Zeit später das selbe. sdb weg, sdc da?!
                  Was läuft hier schief?
                  ich habe auch versucht die Platte per in etc/fstab mit
                  PARTUUID=c378a661-7bf4-47b7-bdc0-c3b144fbf629 /var/lib/mysql ext4 defaults 0 2
                  einzubinden. (weiß aber nicht, ob das so stimmt)
                  lsblk
                  NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
                  sdb           8:16   0 931.5G  0 disk
                  └─sdb1        8:17   0 931.5G  0 part
                  mmcblk0     179:0    0  29.7G  0 disk
                  ├─mmcblk0p1 179:1    0   256M  0 part /boot
                  └─mmcblk0p2 179:2    0  29.5G  0 part /
                  blkid
                  /dev/mmcblk0p1: LABEL_FATBOOT="bootfs" LABEL="bootfs" UUID="37CA-39EC" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="6af5191f-01"
                  /dev/mmcblk0p2: LABEL="rootfs" UUID="a4af13c6-d165-4cbd-a9f6-c961fef8255d" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="6af5191f-02"
                  mount | sort
                  /dev/mmcblk0p2 on / type ext4 (rw,noatime)
                  /dev/sda1 on /var/lib/mysql type ext4 (rw,relatime)
                  devtmpfs on /dev type devtmpfs (rw,relatime,size=332768k,nr_inodes=83192,mode=755)
                  systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                  tmpfs on /run type tmpfs (rw,nosuid,nodev,size=186292k,nr_inodes=819200,mode=755)
                  tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=93144k,nr_inodes=23286,mode=700,uid=1000,gid=1000)
                  sudo blkid /dev/sdb1
                  /dev/sdb1: UUID="708ae917-260f-4c93-b41b-1da779cb715a" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="Basic data partition" PARTUUID="c378a661-7bf4-47b7-bdc0-c3b144fbf629"
                    diwoma @Thomas Braun last edited by
                    @thomas-braun said in MariaDb verschieben:
                    Weil man dann mit VNC rauf kann?
                      Homoran Global Moderator Administrators @diwoma last edited by Homoran
                      @diwoma sagte in MariaDb verschieben:
                      und wofür braucht man vnc auf einem Server?
                      zum Öffnen der Konsole?
                      Server werden per Fernkonsole administriert.
                        Thomas Braun Most Active @diwoma last edited by
                        Auch komplett sinnfrei. Das Terminal schaut über VNC auch nicht anders aus.
                          @mark
                          Mounte über die
                          dann rutscht das Device auch nicht auf /dev/sdX
                            Mark last edited by
                            @thomas-braun hab jetzt die fstab wie folgt geändert:
                            proc            /proc           proc    defaults          0       0
                            PARTUUID=6af5191f-01  /boot           vfat    defaults          0       2
                            PARTUUID=6af5191f-02  /               ext4    defaults,noatime  0       1
                            UUID=708ae917-260f-4c93-b41b-1da779cb715a /var/lib/mysql ext4     defaults      0    2
                            # a swapfile is not a swap partition, no line here
                            #   use  dphys-swapfile swap[on|off]  for that
                            Nach dem reboot
                            lsblk
                            sda           8:0    0 931.5G  0 disk
                            └─sda1        8:1    0 931.5G  0 part /var/lib/mysql
                            funktioniert es erstmal.
                            Zugrif auf die Datenbank hab ich.
                            kurze Zeit später:
                            pi@raspberrypi:~ $ lsblk
                            Was mache ich hier falsch?
                              @mark
                              Keine Ahnung. Steht was in den einschlägigen Logs?
                                ich hab keine Ahnung von dem Kram!
                                Aber bei
                                auf eine USB-Festplatte
                                und
                                raspberrypi
                                sowie dem beschriebenen Verhalten, sehe ich die Möglichkeit dass die Festplatte z.B. wegen mangelhafter Stromversorgung, kurzfristig den Kontakt verliert und neu verbindet.
                                  Mark @Homoran last edited by
                                  @homoran Du hattest recht. Hab jetzt eine andere Festplatte probiert und bisher läuft alles einwandfrei. Auch nach reboot.
                                  Sieht wohl so aus als ob tatsächlich die Festplatte oder der Controller bzw die Stromversorgung was hat. Muss nächste Woche mal ein anderes Netzteil probieren. Vielleicht liegt es ja wirklich daran.
                                  Egal, Hauptsache es geht jetzt!
                                  Danke Euch!!!
                                    @thomas-braun @Homoran
                                    Nun, es ging bei meiner Antwort auf "warum GUI wenn kein Bildschirm oder Keyboard vorhanden ist" darum, dass man immer noch über VNC draufschauen kann (eben weil man keinen BS oder Keyboard angeschlossen hat).
                                    Das man als eingefleischter Linux-User keine GUI braucht, ist klar. Aber manche (vor allem Windows-Nutzer im normalen Leben) sehen halt z.B. das Filesystem lieber grafisch. Und es soll doch niemand davon abgehalten werden, ioBroker zu nutzen, weil er sich auf einem Linux-System unwohl fühlt, auch wenn die Steuerung von ioBroker nur über die Shell erfolgt.
                                      Thomas Braun Most Active @diwoma last edited by Thomas Braun
                                      @diwoma
                                      Braucht keiner. Die drei Befehle zum navigieren durch das Dateisystem kann man sich ja wohl draufschaffen.
                                      Ein GUI hat nur Nachteile.
                                      Zu viel Overhead, zu langsam, zu umständlich, zu unsicher, unnötig laufender Code usw.
                                        @thomas-braun Ist schon klar.
                                          Thomas Braun Most Active last edited by Thomas Braun
                                          @diwoma
                                          Die Lernkurve ist ein wenig steiler am Anfang. Musste halt durch.
                                          Ist übrigens ein ähnliches Thema wie eine Anmeldung als root. Das ist auch 'einfacher', weil da erstmal alles geht.
                                          Ist es aber auch nur auf den ersten Blick und nur solange bis man sich das Rechtegefüge zerballert hat.
                                            ich auch. das mache ich mit filezilla vom PC aus (oder midnight commander vom tablet)
                                            braucht immer noch keine GUI auf dem Server
                                            das bin ich nämlich gar nicht.
                                            2173
