    4. Test Adapter ioBroker.imap latest/stable
      sigi234 Forum Testing Most Active @Lucky_ESA last edited by
      @lucky_esa
      Hallo, was ist da der Unterschied?
      imap.0.xxxxxx_gmail_com.remote.html.header_text_color
      imap.0.xxxxxx_gmail_com.remote.html.mails_today_color_odd
        @lucky_esa
        Diese Warn kommt sehr oft:
        web.0
        2023-03-03 17:41:21.139	warn	Read-only state "imap.0.xxxxxx_gmail_com.last_activity" has been written without ack-flag with value "null"
          @lucky_esa
          Als Info:
          imap.0
          2023-03-03 18:12:42.183	info	Es gibt eine neue Post für das Gerät xxxxx_gmail_com - 1.
          imap.0
          2023-03-03 18:08:07.826	info	Datapoint (change_folder) für xxxxxxxx_gmail_com erstellen.
          imap.0
          2023-03-03 18:08:07.747	info	Mit xxxxxxxxx_gmail_com verbunden
          imap.0
          2023-03-03 18:08:06.237	info	Die IMAP-Verbindung xxxxxxxxx_gmail_com wird nun neu gestartet.
          imap.0
          2023-03-03 18:07:06.234	info	Start IMAP-Verbindung vom Gerät xxxxxxx_gmail_com in 60 Sekunden.
          imap.0
          2023-03-03 18:07:06.234	info	IMAP-Verbindung verloren von xxxxxx_gmail_com - TRUE.
          imap.0
          2023-03-03 18:07:06.232	error	Fehler bei Host xxxxxxx_gmail_com - Error: This socket has been ended by the other party at Socket.writeAfterFIN [as write] (node:net:521:14) at JSStreamSocket.doWrite (node:internal/js_stream_socket:176:19) at JSStream.onwrite (node:internal/js_stream_socket:33:57) at TLSSocket.Socket._final (node:net:491:28) at callFinal (node:internal/streams/writable:696:27) at prefinish (node:internal/streams/writable:725:7) at finishMaybe (node:internal/streams/writable:735:5) at TLSSocket.Writable.end (node:internal/streams/writable:633:5) at TLSSocket.Socket.end (node:net:679:31) { code: 'EPIPE', source: 'socket'}.
          imap.0
          2023-03-03 17:44:27.607	info	Eine E-Mail mit der UID xxxxxxxx_gmail_com von {"uid":109715,"modseq":"11202287","flags":["\\Seen"]} wurde außerhalb von max aktualisiert 48
          L matze55 2 Replies Last reply Reply Quote 0
            Lucky_ESA Developer Most Active @sigi234 last edited by
            @sigi234 Das ist normal. Daher habe ich den reconnected hinzugefügt. Bin mir aber nicht sicher in welchem Interval alle die imap connection beenden. Bin der Meinung es kam bei mir alle 12 Std. Das mit den null werde ich abfangen.
            Das ist der Header wie SEQ, ID etc.
            Gruß//Lucky
            • D3ltoroxp
              D3ltoroxp @Lucky_ESA last edited by
              @lucky_esa said in Test Adapter ioBroker.imap v0.0.1 GitHub:
              Ich verwende das NPM Modul node-imap und es funktioniert noch. Habe allerdings auch ein aktuelles imapflow gefunden was ich parrallel teste.
              ich würde mir das hier auch gern mal anschauen, damit alles funktioniert brauch ich den Adapter und diese node-imap Modul ? Das mit den Flags muss auch installiert werden ?
                liv-in-sky @D3ltoroxp last edited by
                @d3ltoroxp nein - nur den adapter installieren und im setting deine mailbox angeben
                dann findest du die mails in den datenpunkten
                • D3ltoroxp
                  D3ltoroxp @liv-in-sky last edited by
                  @liv-in-sky Super Danke. Hat auch direkt funktioniert, nachdem ich bei gmail ein App Passwort erstellt habe. Jetzt muss ich mir mal noch die Blockly Scripte anschauen.
                    Lucky_ESA Developer Most Active @MCU last edited by
                    @mcu sagte in Test Adapter ioBroker.imap v0.0.1 GitHub:
                    min-width:100%;
                    erledigt
                    Gruß//Lucky
                    • matze55
                      matze55 @sigi234 last edited by
                      @sigi234 ---->>hallo.....deine Vis die du machst ..einfach geil.....bei dem Adapter bekomme ich einfach es nicht hin alle emails abzufragen.
                      Wenn ich in die abfrage gehe zeigt mir es an-66 Emails aber zeigt absolut nicht an.
                      Aber ich bin ein wartender mensch.....ich warte bis morgen mal ab
                      lg----->>>Geile VIS machst du
                        sigi234 Forum Testing Most Active @matze55 last edited by
                        @matze55 sagte in Test Adapter ioBroker.imap v0.0.1 GitHub:
                        GMail?
                        matze55 1 Reply Last reply Reply Quote 0
                          sigi234 Forum Testing Most Active @Lucky_ESA last edited by sigi234
                          @lucky_esa
                          Hallo, wollte es gerade auf einen neuen System installieren:
                          imap.0
                          2023-03-08 23:50:45.537	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                          imap.0
                          2023-03-08 23:50:45.533	error	adapter disabled
                          imap.0
                          2023-03-08 23:50:13.675	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          imap.0
                          2023-03-08 23:50:13.675	info	terminating
                          imap.0
                          2023-03-08 23:50:13.672	error	Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                          imap.0
                          2023-03-08 23:50:13.672	error	Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt at Decipheriv.final (node:internal/crypto/cipher:193:29) at Object.decrypt (C:\ioBroker1\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2409:79) at Imap.decrypt (C:\ioBroker1\node_modules\@iobroker\js-controller-adapter\build\lib\adapter\adapter.js:7391:26) at Imap.onReady (C:\ioBroker1\node_modules\iobroker.imap\main.js:101:37)
                          imap.0
                          2023-03-08 23:50:13.670	error	unhandled promise rejection: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
                          imap.0
                          2023-03-08 23:50:13.669	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          imap.0
                          2023-03-08 23:50:13.651	info	starting. Version 0.0.4 (non-npm: Lucky-ESA/ioBroker.imap#b061bc88fc01b1d1e00c1210a1f05a2ebc8520aa) in C:/ioBroker1/node_modules/iobroker.imap, node: v16.19.1, js-controller: 4.0.24
                            sigi234 Forum Testing Most Active @sigi234 last edited by sigi234
                            @sigi234 sagte in Test Adapter ioBroker.imap v0.0.1 GitHub:
                            @lucky_esa
                            Nochmal installiert, geht jetzt bis auf das Passwort. Anscheinend mag Google keine 2fach Installationen.
                              @lucky_esa
                              Du musste dann erneut app passwort aufrufen und den login bestätigen. Bin auch mit Live und Dev angemeldet. Sorry für die Umstände mit der o. g. Fehlermeldung aber hier greift mein Workaround. Wenn die Instanz deaktiviert ist, ist eine Eingabe von IMAP`s nicht möglich. Vielleicht wird das noch im Controller aufgenommen. PW
                              Bin mir allerdings nicht sicher ob dieser Workaround beim Latest Test Bestand haben wird.
                              Habe immer noch Probleme mit Attachements...grrrrr. Gestern eine Mail mit 4MB erhalten und sofort der RAM von 130MB auf 170MB....
                              • matze55
                                @sigi234
                                Ich kann die Emails abfragen aber in der VIS ist doch untergalb dieser Farbbalken den bekomme ich einfach nicht definiert.
                                Bei der Kopffarbe suche ich im html Ordner ,,headline_color,, aber der farbalken da klemmt es
                                lg
                                  lg
                                  • D3ltoroxp
                                    D3ltoroxp last edited by D3ltoroxp
                                    ich versuche gerade die Mails meiner Kids ab zu fragen. Das sind quasi outlook.office365.com Mails von der Schule / MS Teams. Hier werden ja immer wieder Infos geschrieben. Da MS aber zu blöd ist mehrere Accounts gleichzeitig zu verwalten würde ich gerne informiert werden ohne ständig die Accounts zu wechseln.
                                    Ich kann mich aber mit den Einstellungen vom Thunderbird nicht einloggen.
                                    Geht das mit den Accounts nicht oder mit office365 ?
                                    Fehler bei Host xxx - Error: LOGIN failed. at Connection._resTagged (/opt/iobroker/node_modules/node-imap/lib/Connection.js:1272:13) at Parser.<anonymous> (/opt/iobroker/node_modules/node-imap/lib/Connection.js:190:12) at Parser.emit (node:events:513:28) at Parser._resTagged (/opt/iobroker/node_modules/node-imap/lib/Parser.js:169:12) at Parser._parse (/opt/iobroker/node_modules/node-imap/lib/Parser.js:135:18) at Parser._tryread (/opt/iobroker/node_modules/node-imap/lib/Parser.js:77:17) at TLSSocket.Parser._cbReadable (/opt/iobroker/node_modules/node-imap/lib/Parser.js:55:14) at TLSSocket.emit (node:events:513:28) at emitReadable_ (node:internal/streams/readable:578:12) at processTicksAndRejections (node:internal/process/task_queues:82:21) { type: 'no', textCode: undefined, source: 'authentication' }.
                                    Oder wie muss man diese Account im Adapter anlegen ?
                                    matze55 L 3 Replies Last reply Reply Quote 0
                                    • matze55
                                      matze55 @D3ltoroxp last edited by
                                      @d3ltoroxp bei dem Adapter IMAP musst du für live mail folgendes eintragen:
                                      Host: outlook.office365.com
                                      Posteingang: INBOX
                                      Port: 993
                                      Benutzname: DEINE Mailadresse
                                      Paswort: DEIN PW
                                      TLS: Kreuz Setzen bzw. Haken
                                      tls-Option: {"rejectUnauthorized": false}
                                      Auto-TLS: never
                                      lg
                                      D3ltoroxp 1 Reply Last reply Reply Quote 1
                                      • D3ltoroxp
                                        D3ltoroxp @matze55 last edited by
                                        @matze55 Genau so hab ich es.
                                        Aber es funktioniert nicht. In Thunderbird steht auch OAuth2. Wenn ich mich mit dem Konto neu in Thunderbird anmelde, kommt ein kleines Browser Fenster wo ich das noch mal bestätigen muss. Vllt liegt da das Problem ?
                                        M matze55 2 Replies Last reply Reply Quote 0
                                          MCU @D3ltoroxp last edited by MCU
                                          @d3ltoroxp Man braucht ein APP Passwort.
                                          https://mcuiobroker.gitbook.io/jarvis-infos/tipps/allgemein/microsoft-windows/2-fach-authentifizierung
                                            Lucky_ESA Developer Most Active @D3ltoroxp last edited by
                                            @d3ltoroxp
                                            Für den 365 Login musst du die Logindaten verwenden, die du von der Schule erhalten hast und nicht die Logindaten von Thunderbird.
                                            Am Besten dann pro Kind ein IMAP anlegen.
                                            Gruß//Lucky
                                            408
                                            82514
