    4. jarvis v3.1.x - just another remarkable vis
      Titanflex @Thomas Braun last edited by
      also da ich ein iobroker backup gemacht habe, werde ich das mal so probieren
        Thomas Braun Most Active @Titanflex last edited by
        @titanflex sagte in jarvis v3.1.x - just another remarkable vis:
        Das hat man selbstredend ja immer zu Hand.
          vielen Dank für die Hilfe. Hat geklappt.
          Ja ein Backup ist sehr sehr wichtig 🙂
            @titanflex
            Was sagt jetzt der Check aus dem HowTo oder
            iob diag
              das sagt
              iob diag
              code_text
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Architecture:   x86_64
              Docker:         false
              Virtualization: lxc
              Distributor ID: Debian
              Description:    Debian GNU/Linux 11 (bullseye)
              Release:        11
              Codename:       bullseye
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              Systemuptime and Load:
               17:29:37 up 0 min,  1 user,  load average: 0.67, 0.59, 0.44
              CPU threads: 2
              *** Time and Time Zones ***
              Sun Mar  5 17:29:37 UTC 2023
              UTC +0000
              Etc/UTC
              *** User and Groups ***
              simon
              /home/simon
              simon sudo iobroker
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            4.1G        848M        3.0G        1.0M        238M        3.2G
              Swap:           1.0G          0B        1.0G
              Total:          5.1G        848M        4.0G
                       4096 M total memory
                        849 M used memory
                         75 M active memory
                        952 M inactive memory
                       3007 M free memory
                          0 M buffer memory
                        238 M swap cache
                       1024 M total swap
                          0 M used swap
                       1024 M free swap
              *** FILESYSTEM ***
              Filesystem                       Type      Size  Used Avail Use% Mounted on
              /dev/mapper/pve-vm--101--disk--0 ext4       32G  7.9G   22G  27% /
              none                             tmpfs     492K  4.0K  488K   1% /dev
              udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
              tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
              tmpfs                            tmpfs     1.6G  1.5M  1.6G   1% /run
              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
              Messages in dmesg:
              dmesg: read kernel buffer failed: Operation not permitted
              Show mounted filesystems (real ones only):
              TARGET SOURCE                           FSTYPE OPTIONS
              /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
              /var:
              737M    /var/
              425M    /var/cache
              418M    /var/cache/apt
              349M    /var/cache/apt/archives
              190M    /var/lib
              /opt/iobroker/backups:
              161M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              495M    /opt/iobroker/iobroker-data/
              330M    /opt/iobroker/iobroker-data/files
              103M    /opt/iobroker/iobroker-data/backup-objects
              72M     /opt/iobroker/iobroker-data/files/telegram.admin
              51M     /opt/iobroker/iobroker-data/files/javascript.admin
              26M     /opt/iobroker/iobroker-data/objects.jsonl
              19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.a5972028.js.map
              18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
              15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
              15M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v16.19.1
              /usr/bin/node           v16.19.1
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Installed: 16.19.1-deb-1nodesource1
                Candidate: 16.19.1-deb-1nodesource1
                Version table:
               *** 16.19.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                      100 /var/lib/dpkg/status
                   12.22.12~dfsg-1~deb11u3 500
                      500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                   12.22.5~dfsg-2~11u1 500
                      500 http://ftp.debian.org/debian stable/main amd64 Packages
                   10.24.0~dfsg-1~deb10u3 500
                      500 http://security.debian.org buster/updates/main amd64 Packages
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  4.0.24
              admin:          6.3.6
              javascript:     7.0.1
              Adapters from github:   0
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled
                system.adapter.go-e.0                   : go-e                  : iobroker                                 - disabled
              + system.adapter.history.0                : history               : iobroker                                 -  enabled
              + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
              + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                system.adapter.iqontrol.0               : iqontrol              : iobroker                                 - disabled
                system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                system.adapter.lovelace.0               : lovelace              : iobroker                                 - disabled, port: 8091, bind: 0.0.0.0, run as: admin
                system.adapter.meteoalarm.0             : meteoalarm            : iobroker                                 -  enabled
                system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
                system.adapter.mobile.0                 : mobile                : iobroker                                 -  enabled
              + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                system.adapter.mqtt.0                   : mqtt                  : iobroker                                 - disabled, port: 2000, bind: 0.0.0.0
              + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
                system.adapter.ocpp.0                   : ocpp                  : iobroker                                 - disabled, port: 9220
                system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
              + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                system.adapter.sonnen.0                 : sonnen                : iobroker                                 -  enabled
              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 3306
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
              + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
              + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
                system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              Stable (default): http://download.iobroker.net/sources-dist-latest.json
              Active repo(s): Stable (default)
              Installed ioBroker-Instances
              Used repository: Stable (default)
              Adapter    "admin"        : 6.3.6    , installed 6.3.6
              Adapter    "backitup"     : 2.6.6    , installed 2.6.6
              Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
              Adapter    "discovery"    : 3.1.0    , installed 3.1.0
              Adapter    "ems-esp"      : 1.26.0   , installed 1.26.0
              Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
              Adapter    "fronius"      : 1.1.3    , installed 1.1.3
              Adapter    "go-e"         : 1.0.25   , installed 1.0.25
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "hmip"         : 1.20.0   , installed 1.20.0
              Adapter    "ical"         : 1.13.2   , installed 1.13.2
              Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
              Adapter    "info"         : 1.9.26   , installed 1.9.26
              Adapter    "iqontrol"     : 2.1.0    , installed 2.1.0
              Adapter    "jarvis"       : 3.1.3    , installed 3.1.3
              Adapter    "javascript"   : 7.0.1    , installed 7.0.1
              Controller "js-controller": 4.0.24   , installed 4.0.24
              Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
              Adapter    "meteoalarm"   : 2.3.3    , installed 2.3.3
              Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
              Adapter    "mobile"       : 1.0.1    , installed 1.0.1
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
              Adapter    "node-red"     : 4.0.0    , installed 4.0.0
              Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
              Adapter    "octoprint"    : 4.1.0    , installed 4.1.0
              Adapter    "ping"         : 1.5.3    , installed 1.5.3
              Adapter    "proxmox"      : 1.3.5    , installed 1.3.5
              Adapter    "shelly"       : 6.4.0    , installed 6.4.0
              Adapter    "socketio"     : 6.3.4    , installed 6.3.4
              Adapter    "sonnen"       : 1.16.0   , installed 1.16.0
              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
              Adapter    "sql"          : 2.2.0    , installed 2.2.0
              Adapter    "telegram"     : 1.15.6   , installed 1.15.6
              Adapter    "text2command" : 3.0.2    , installed 3.0.2
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "unifi"        : 0.6.3    , installed 0.6.3
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "vis"          : 1.4.16   , installed 1.4.16
              Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
              Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
              Adapter    "web"          : 5.5.2    , installed 5.5.2
              Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
              Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
              Adapter    "ws"           : 2.3.6    , installed 2.3.6
              Adapter    "yahka"        : 0.17.0   , installed 0.17.0
              Objects and States
              Objects:        11938
              States:         9351
              Hit:1 http://ftp.debian.org/debian stable InRelease
              Hit:2 http://security.debian.org buster/updates InRelease
              Hit:3 http://ftp.debian.org/debian buster-updates InRelease
              Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       6500319    504/io.shelly.0
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6502559    646/io.sonoff.0
              tcp        0      0 0.0.0.0:34377           0.0.0.0:*               LISTEN      1001       6505832    1496/io.yahka.0
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6500448    246/smbd
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          6499435    1/init
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6497241    165/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6500449    246/smbd
              tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       6501236    530/sshd: simon@pts
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6499877    146/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6499870    146/iobroker.js-con
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6500511    324/master
              tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       6501235    530/sshd: simon@pts
              tcp6       0      0 :::445                  :::*                    LISTEN      0          6500446    246/smbd
              tcp6       0      0 :::111                  :::*                    LISTEN      0          6499437    1/init
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6500512    324/master
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6497252    165/sshd: /usr/sbin
              tcp6       0      0 :::139                  :::*                    LISTEN      0          6500447    246/smbd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6500701    340/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6505105    1440/io.web.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6499552    75/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          6499436    1/init
              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          6500385    147/nmbd
              udp        0      0 192.168.178.21:137      0.0.0.0:*                           0          6500384    147/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          6500371    147/nmbd
              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          6500387    147/nmbd
              udp        0      0 192.168.178.21:138      0.0.0.0:*                           0          6500386    147/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          6500372    147/nmbd
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       6505829    1496/io.yahka.0
              udp        0      0 0.0.0.0:46740           0.0.0.0:*                           1001       6504961    1388/io.upnp.0
              udp6       0      0 :::111                  :::*                                0          6499438    1/init
              2023-03-05 17:29:46.211  - info: net-tools.0 (908) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
              2023-03-05 17:29:48.378  - info: net-tools.0 (908) Port scan finished
              2023-03-05 17:29:49.058  - info: host.iobroker instance system.adapter.tankerkoenig.0 started with pid 1267
              2023-03-05 17:29:49.896  - info: tankerkoenig.0 (1267) starting. Version 3.3.7 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v16.19.1, js-controller: 4.0.24
              2023-03-05 17:29:49.919  - info: tankerkoenig.0 (1267) Adapter is already in daemon mode
              2023-03-05 17:29:49.919  - warn: tankerkoenig.0 (1267) Sync time was too short (5). New sync time is 10 min
              2023-03-05 17:29:49.920  - info: tankerkoenig.0 (1267) Sync time set to 10 minutes or 600000 ms
              2023-03-05 17:29:49.921  - error: tankerkoenig.0 (1267) No stations defined
              2023-03-05 17:29:53.047  - info: host.iobroker instance system.adapter.text2command.0 started with pid 1329
              2023-03-05 17:29:54.099  - info: text2command.0 (1329) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.text2command, node: v16.19.1, js-controller: 4.0.24
              2023-03-05 17:29:57.063  - info: host.iobroker instance system.adapter.upnp.0 started with pid 1388
              2023-03-05 17:29:58.083  - info: upnp.0 (1388) starting. Version 1.0.21 in /opt/iobroker/node_modules/iobroker.upnp, node: v16.19.1, js-controller: 4.0.24
              2023-03-05 17:29:58.098  - info: upnp.0 (1388) Auto discover: true
              2023-03-05 17:30:01.045  - info: host.iobroker instance system.adapter.web.0 started with pid 1440
              2023-03-05 17:30:02.305  - info: web.0 (1440) starting. Version 5.5.2 in /opt/iobroker/node_modules/iobroker.web, node: v16.19.1, js-controller: 4.0.24
              2023-03-05 17:30:02.576  - info: web.0 (1440) socket.io server listening on port 8082
              2023-03-05 17:30:02.579  - info: web.0 (1440) http server listening on port 8082
              2023-03-05 17:30:05.014  - info: host.iobroker instance system.adapter.yahka.0 started with pid 1496
              2023-03-05 17:30:06.199  - info: yahka.0 (1496) starting. Version 0.17.0 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.19.1, js-controller: 4.0.24
              2023-03-05 17:30:06.217  - info: yahka.0 (1496) adapter ready, checking config
              2023-03-05 17:30:06.223  - info: yahka.0 (1496) adding Steckdose 3D Drucker with UUID: 2a4c30c5-52e2-4981-af31-49959a32f72c
              2023-03-05 17:30:06.227  - info: yahka.0 (1496) adding Licht with UUID: f5a9c7c8-3bf9-48b3-8441-909729e85566
              2023-03-05 17:30:06.229  - info: yahka.0 (1496) adding AußenTemp with UUID: 21b2351e-6fb0-4620-b6b5-6990fd029145
              2023-03-05 17:30:06.231  - info: yahka.0 (1496) publishing bridge Yahka-0 on 0.0.0.0 using avahi
              2023-03-05 17:30:09.050  - info: host.iobroker instance system.adapter.proxmox.0 started with pid 2251
              iob diag has finished.
                @titanflex
                Setz die Zeitzone und deine Quellen verweisen z.T. auf Buster, stell das richtig auf bullseye um.
                Dominik F. 1 Reply Last reply Reply Quote 0
                • Dominik F.
                  Dominik F. @Thomas Braun last edited by
                  es gibt ja das Widget JasonTable, das funktioniert super und sieht super aus. Gibt es die Möglichkeit, dieses auf den Inhalt eines PopUps anzuwenden?
                  Sprich, dass ich eine JsonTable in einem PopUp darstellen kann?
                    MCU last edited by
                    @dominik-f
                    Nein. Feature Request erstellen?
                    https://github.com/Zefau/ioBroker.jarvis/issues
                    • Dominik F.
                      Dominik F. last edited by Dominik F.
                      @mcu
                      Hab ich erstellt, ich danke dir für deine Info
                        MCU @Dominik F. last edited by MCU
                        @dominik-f
                        Also ich kann dir sowas anbieten. Geht nur für "normale" JSON.
                        https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/scripts-3.1.x-pro/statelist/jsontohtmlpopup
                        M-A Hueb Dominik F. 2 Replies Last reply Reply Quote 0
                        • M-A Hueb
                          M-A Hueb @MCU last edited by M-A Hueb
                          Ich habe auf meinem Tablett und auf dem iphone das Problem, dass das mit der lila Ecke zum Vollbild vergrößern nicht funktioniert. Kann man das Umstellen, dass es beim Tippen auf den Namen vergrößert?
                            MCU @M-A Hueb last edited by
                            @m-a-hueb Doppelklick auf die Widget Überschrift.
                            M-A Hueb 1 Reply Last reply Reply Quote 0
                            • M-A Hueb
                              @mcu geht bei Touch eingabe nicht 😞
                                MCU @M-A Hueb last edited by MCU
                                @m-a-hueb Normalerweise schon. Funktioniert momentan nur, wenn man anschließend Ansicht von Portrait auf Landscape ändert oder umgekehrt. Ist also ein Bug.
                                https://github.com/Zefau/ioBroker.jarvis/issues/2275
                                mcuiobroker created this issue in Zefau/ioBroker.jarvis
                                closed v3.1.4-beta.6 Vollbild erlauben funktioniert nicht auf dem Handy #2275
                                • Dominik F.
                                  Dominik F. @MCU last edited by
                                  @mcu
                                  Das sieht schon sehr gut aus. Leider wird es bei vielen Zeilen doch sehr unübersichtlich
                                    MCU last edited by MCU
                                    @dominik-f Wie viele Zeilen möchtest du maximal haben?
                                    • Dominik F.
                                      @mcu
                                      Ich hab da momentan so um die 40 Zeilen und 4 Spalten, ich lasse mir die Batterien mittels eines Skriptes anzeigen. Ich müsste mir das ganze also zum einen Sortieren können und zum anderen die Zeilen etwas begrenzen, sagen wir auf 10 Zeilen.
                                      • N
                                        Nonixnarrez @Zefau last edited by Nonixnarrez
                                        @zefau @MCU
                                        Moin zusammen,
                                        kann es sein, dass sich in der letzten oder vorletzten Jarvis Version die Interpretation bzw. das JSON Format für die Datenpunkteigenschaften verändert hat?
                                        Bisher funktionierte min/max und runden (1 Kommastelle) immer mit folgendem JSON Format für die Datenpunkt-Eigenschaften:
                                        {"min":15,"max":25,"value":"val => parseFloat(val).toFixed(1)"}
                                        Jetzt, unter Jarvis 3.1.3, klappt es bei mir leider nur noch entweder {"min":15,"max":25} oder {"value":"val => parseFloat(val).toFixed(1)"}.
                                        Ist das ein Bug (GitHub Issue) oder ein Feature? 🤔
                                        Viele Grüße /// Noni
                                        • Marc_el_K
                                          Marc_el_K last edited by Marc_el_K
                                          @MCU Ich habe von einem anderen Adapter (ONVIF) einen Datenpunkt mit einem Kamera-Snapshot. Der Inhalt des Bilds beginnt mit: data:image/jpg;base64,.................
                                          Kannst du mir sagen, wie man dies in Jarvis integriert?
                                          Danke 🙂
                                          Edit: Okay, habe es als Gerät hinzugefügt und dann via DisplayImage eingefügt.
                                            MCU last edited by
                                            @nonixnarrez Bitte als Issue anlegen.
                                            N 1 Reply Last reply Reply Quote 1
                                            92
                                            1847
                                            708185
