    4. TEST - Adapter Fully Browser mit MQTT (0.0.11)
    • Neuschwansteini
      Neuschwansteini @Acgua last edited by Neuschwansteini
      @acgua
      Super, vielen Dank!
      Funktioniert hier einwandfrei, sauber programmiert, nur eins wird gemeldet:
      Meine den hier:
      Info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:46:53.540  - info: host.iobroker instance system.adapter.fully-mqtt.0 started with pid 290320
      2023-03-09 20:46:54.103  - debug: fully-mqtt.0 (290320) Redis Objects: Use Redis connection: 10.1.1.4:6379
      2023-03-09 20:46:54.125  - debug: fully-mqtt.0 (290320) Objects client ready ... initialize now
      2023-03-09 20:46:54.126  - debug: fully-mqtt.0 (290320) Objects create System PubSub Client
      2023-03-09 20:46:54.127  - debug: fully-mqtt.0 (290320) Objects create User PubSub Client
      2023-03-09 20:46:54.376  - debug: fully-mqtt.0 (290320) Objects client initialize lua scripts
      2023-03-09 20:46:54.381  - debug: fully-mqtt.0 (290320) Objects connected to redis: 10.1.1.4:6379
      2023-03-09 20:46:54.654  - debug: fully-mqtt.0 (290320) Redis States: Use Redis connection: 10.1.1.4:6379
      2023-03-09 20:46:54.657  - debug: fully-mqtt.0 (290320) States create System PubSub Client
      2023-03-09 20:46:54.658  - debug: fully-mqtt.0 (290320) States create User PubSub Client
      2023-03-09 20:46:54.661  - debug: fully-mqtt.0 (290320) States connected to redis: 10.1.1.4:6379
      2023-03-09 20:46:55.037  - info: fully-mqtt.0 (290320) starting. Version 0.0.1-alpha (non-npm: Acgua/ioBroker.fully-mqtt#9f946a67a951d57ba770ec08be30eedb3c0d711d) in /opt/iobroker/node_modules/iobroker.fully-mqtt, node: v16.19.1, js-controller: 4.0.24
      2023-03-09 20:46:55.059  - debug: fully-mqtt.0 (290320) Final Config: {"name":"Huawei-WZDG","id":"Huawei-WZDG","ip":"10.1.1.54","useMQTT":true,"restProtocol":"http","restPort":2323,"restPassword":"Winston2006","lastSeen":0,"isAlive":false}
      2023-03-09 20:46:55.060  - info: fully-mqtt.0 (290320) 🗸​ Config of Huawei-WZDG (10.1.1.54) successfully verified.
      2023-03-09 20:46:55.061  - debug: fully-mqtt.0 (290320) Adapter settings successfully verified and initialized.
      2023-03-09 20:46:55.067  - debug: fully-mqtt.0 (290320) Start main() - Huawei-WZDG (10.1.1.54)…
      2023-03-09 20:46:55.068  - info: fully-mqtt.0 (290320) [MQTT]🚀​ Server started and listening on port 1888
      2023-03-09 20:46:59.959  - debug: fully-mqtt.0 (290320) [MQTT] client.conn.remoteAddress = "::ffff:10.1.1.54" - Huawei-WZDG
      2023-03-09 20:46:59.961  - info: fully-mqtt.0 (290320) [MQTT] Client Huawei-WZDG (10.1.1.54) trys to authenticate...
      2023-03-09 20:46:59.961  - info: fully-mqtt.0 (290320) [MQTT]🔑​ Client Huawei-WZDG (10.1.1.54) authenticated successfully.
      2023-03-09 20:46:59.963  - info: fully-mqtt.0 (290320) [MQTT] Huawei-WZDG is alive.
      2023-03-09 20:46:59.964  - debug: fully-mqtt.0 (290320) [MQTT] Client Huawei-WZDG (10.1.1.54) connected to broker a621d092-8b12-4b18-b371-f5bbb3e5d489
      2023-03-09 20:46:59.964  - info: fully-mqtt.0 (290320) [MQTT]🔗​ Client Huawei-WZDG (10.1.1.54) successfully connected.
      2023-03-09 20:47:00.146  - debug: fully-mqtt.0 (290320) [MQTT] Client Huawei-WZDG = Huawei-WZDG = 10.1.1.54
      2023-03-09 20:47:00.146  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:47:00.146  - debug: fully-mqtt.0 (290320) [MQTT] Huawei-WZDG: Creating info objects (if not yet existing)
      2023-03-09 20:47:00.167  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:47:33.794  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:47:33.804  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:48:19.617  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:48:19.627  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:49:00.217  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:49:00.282  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:49:33.914  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:49:33.922  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:50:19.720  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:50:19.729  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:51:00.350  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:51:00.357  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      2023-03-09 20:51:33.996  - debug: fully-mqtt.0 (290320) [MQTT]📡​ Huawei-WZDG published info, topic: fully/deviceInfo/e494e50e-8038fd2e
      2023-03-09 20:51:34.006  - info: fully-mqtt.0 (290320) State value to set for "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo" has to be stringified but received type "object"
      [/s]
      Homoran Acgua 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Neuschwansteini last edited by
        @ilovegym muss das log sooooo groß sein?
        es lähmt die ganze Seite!
        Wenn ja, dann ja!
        Neuschwansteini 1 Reply Last reply Reply Quote 0
        • Neuschwansteini
          Neuschwansteini @Homoran last edited by
          Sorry hab ausversehen alles kopiert.. aber jetzt geändert..
            @ilovegym komme jetzt auch wieder auf die Seite!
            • Acgua
              Acgua @Neuschwansteini last edited by
              @ilovegym said in TEST - Adapter Fully Browser mit MQTT (0.0.1-alpha):
              Super, vielen Dank!
              Cool, das freut mich 🙂
              1. Kannst du bitte in den Objekten bei fully-mqtt.0.Huawei-WZDG.Info.sensorInfo rechts auf den Stift klicken und dann posten was angezeigt wird.
              2. MQTT hast du aktiviert und läuft, richtig? Ich frage, weil ansonsten die Info via REST API kommt...
              • Neuschwansteini
                @acgua
                Hier die info vom Objekt und ja, mqtt ist aktiv, im Adapter und im Fully.
                  "type": "state",
                  "common": {
                    "name": "Info: sensorInfo",
                    "type": "object",
                    "role": "value",
                    "read": true,
                    "write": false
                  "native": {},
                  "from": "system.adapter.fully-mqtt.0",
                  "user": "system.user.admin",
                  "ts": 1678390504642,
                  "_id": "fully-mqtt.0.Huawei-WZDG.Info.sensorInfo",
                  "acl": {
                    "object": 1636,
                    "state": 1636,
                    "owner": "system.user.admin",
                  mrjeschke last edited by
                  Läuft bis jetzt bei mir auch sehr gut.
                  Alles wird vermutlich nicht funktionieren, da ich eine Show15 habe.
                  Fehlermeldungen bekomme ich noch wenn ich Datenpunkte unter Commands ändere.
                  Danach stet im DP ein true und es kommen die Fehler.
                  State value to set for "fully-mqtt.0.Show15.Commands.setAudioVolume" has to be type "number" but received type "boolean"
                  State value to set for "fully-mqtt.0.Show15.Commands.textToSpeech" has to be type "string" but received type "boolean"
                  State value to set for "fully-mqtt.0.Show15.Commands.loadURL" has to be type "string" but received type "boolean"
                  Acgua 1 Reply Last reply Reply Quote 0
                    arteck Developer Most Active @Acgua last edited by arteck
                    @acgua jetzt doch ein extra Adapter .. ?? dann motte ich meinen ein ..
                    Neuschwansteini Acgua 2 Replies Last reply Reply Quote 0
                    • Neuschwansteini
                      Neuschwansteini @arteck last edited by
                      @arteck hmmf dachte ihr haettet euch abgesprochen.. aber sieh's mal so: da hast du weniger Support-Arbeit.. 🙂
                      Zigbee fordert doch genug nerven.. oder 🙂
                      • Neuschwansteini
                        @acgua
                        ab und zu gibts n keep alive timeout, komischerweise bei den Tablets auch, die per LAN verbunden sind.. kann ich da das Timeout irgendwo einstellen??
                        2023-03-10 11:48:30.069  - warn: fully-mqtt.0 (1061251) [MQTT] Huawei-FlurOG is not alive!
                        2023-03-10 11:48:30.717  - error: fully-mqtt.0 (1061251) [MQTT]🔥 Client error - keep alive timeout
                        2023-03-10 11:48:30.718  - warn: fully-mqtt.0 (1061251) [MQTT] Client Huawei-FlurOG disconnected.
                        2023-03-10 11:48:34.700  - info: lightcontrol.1 (1566) [ Controller ] Reaching, Group="Muellanzeige" Property="actualLux" NewVal="137.87", OldVal=137.87"
                        2023-03-10 11:48:42.252  - info: fully-mqtt.0 (1061251) [MQTT] Client Huawei-FlurOG (10.1.1.56) trys to authenticate...
                        2023-03-10 11:48:42.253  - info: fully-mqtt.0 (1061251) [MQTT]🔑 Client Huawei-FlurOG (10.1.1.56) authenticated successfully.
                        2023-03-10 11:48:42.253  - info: fully-mqtt.0 (1061251) [MQTT] Huawei-FlurOG is alive.
                        2023-03-10 11:48:42.253  - info: fully-mqtt.0 (1061251) [MQTT]🔗 Client Huawei-FlurOG (10.1.1.56) successfully connected.
                        Hier meine Config vom Adapter:
                        oder kann man das im Fullybrowser einstellen? Hab da nix gefunden..
                        BananaJoe Acgua 2 Replies Last reply Reply Quote 0
                        • BananaJoe
                          BananaJoe Most Active @Neuschwansteini last edited by
                          @ilovegym leck mich fett, du bist aber gut mit Anzeigen ausgestattet ... Gutes Argument wenn meine Frau mal wieder meint ich würde überteiben ...
                          Neuschwansteini 1 Reply Last reply Reply Quote 1
                          • Neuschwansteini
                            Neuschwansteini @BananaJoe last edited by
                            @bananajoe Oehm, hat nicht alles auf den Screen gepasst, hab im Haus paarundzwanzig Tablets verstreut.. die meisten Android mit Fully, natürlich auch n paar IPads und 5x 55" TV und n 86" fuer die Dashboards
                            Die Tablets waren am Anfang zur Steuerung gedacht, genutzt wird ziemlich genau davon eins.. die anderen zeigen nur die Grafana-Playlist.. sorry, hab sonst kein Hobby.. 🙂
                            • Acgua
                              Acgua @arteck last edited by
                              @arteck said in TEST - Adapter Fully Browser mit MQTT (0.0.1-alpha):
                              Nein, bitte nicht einmotten 🙂 Ich habe jetzt erst mal einen separaten Adapter gebaut, da es doch sehr umfangreich wurde wegen MQTT etc. Auch damit erst mal getestet werden kann, Fehler behoben werden können, ggf. noch paar Features einbauen falls notwendig/sinnvoll. Sobald stabil, dann am liebsten in deinen Adapter "verschmelzen" unter https://github.com/arteck/ioBroker.fullybrowser. Habe auch versucht, soweit abwärtskompatibel zu sein, lediglich fehlen noch paar Zeichen Code, um die alten Settings in die vom neuen Adapter zu überführen.
                              @ilovegym und @mrjeschke
                              Danke für eure Rückmeldungen, schaue ich mir alsbald an, nur heute komme ich nicht dazu.
                              • Acgua
                                Acgua @mrjeschke last edited by
                                @mrjeschke said in TEST - Adapter Fully Browser mit MQTT (0.0.1-alpha):
                                Eigentlich sollte auch in Verbindung mit Show15 der Adapter korrekt laufen, sofern halt die Fully App das unterstützt... 😉
                                Danke für deine Rückmeldung, war ein Bug und ist sollte nun behoben sein.
                                Bitte Adapter noch mal neu installieren von URL (https://github.com/Acgua/ioBroker.fully-mqtt)
                                • Acgua
                                  Acgua @Neuschwansteini last edited by Acgua
                                  Meine den hier:
                                  Danke für die Rückmeldung. Hier beschrieben:
                                  @paul53 said in Fehler nach update js-controller 3.3.9:
                                  Ab Version 3.3 des js-controllers sollen keine Objekte / Arrays mehr in Datenpunkte geschrieben werden, sondern nur noch per JSON.stringify(obj) gewandelte Objekte. Diese Info-Logs sollen die Adapter-Entwickler informieren, dies anzupassen.
                                  Wenn die Logs stören, stelle die Log-Stufe des js-controllers in der Datei /opt/iobroker/iobroker-data/iobroker.json auf "warn" (anschließend ioBroker neu starten).
                                  Ich mache jetzt
                                  const newVal = typeof infoObj[key] === 'object' ? JSON.stringify(infoObj[key]) : infoObj[key];
                                  Ich verstehe zwar diese ioBroker-Einschränkung nicht wirklich, aber nun eingebaut 🙂
                                  Bitte Adapter noch mal neu installieren von URL (https://github.com/Acgua/ioBroker.fully-mqtt) und testen.
                                  • Acgua
                                    (hier stand vorher eine andere, falsche, Antwort von mir)
                                    Hier hat sich tatsächlich der Client, also der Fully Browser und/oder das Tablet, verabschiedet.
                                    Das kann ich nicht wirklich beeinflussen mit dem Adapter.
                                    Kommt das öfter vor, und in welchem Abstand in Sekunden wird "is not alive" -> "is alive" angezeigt im Log (also jeweils separate Log-Zeilen), so im Durchschnitt?
                                    • Neuschwansteini
                                      @acgua sagte in TEST - Adapter Fully Browser mit MQTT (0.0.1-alpha):
                                      hmm das ist komisch, denn ich komme ganz normal auf die Gui von Fullybrowser, wenn das kommt. . und dann ist er ja nach 12 Sek. auch wieder fuer den Adapter erreichbar.. hier sieht es mir nach einem timeout problem aus.. ich hab zeitgleich mal n ping durchlaufen lassen, da gibts keine breaks/interrupts und auch keine lost packets oder so..
                                      Was mich wundert, es sind bei der Meldung immer 12sek, dann ist er wieder erreichbar..
                                      naja, ich behalts mal im Auge.. denn:
                                      98% meiner Tablets schalten sich um 23.00 Uhr aus, und um 5 / 7 uhr morgens wieder ein, in der zwischenzeit sind die natuerlich offline.
                                      Auch da sollte der Adapter das abkoennen, oder das log zu zu pflastern.. kannste das vielleicht so machen, wie beim mqtt oder sonoff adapter, dass man in den Instanzen sieht, welcher client verbunden ist?
                                      Dann hat der Adapter noch Probleme, die Datenpunkte im '/Info directory anzulegen, das geht meist erst, wenn ich mqtt im Adapter ausschalte, dann legt er alle Datenpunkte an, schalte ich dann mqtt ein, funktionierts...
                                      Hab jetzt den alten Adapter geloscht, auch die Datenpunkte, neu von Git installiert, die Konfig importiert, und alles neu anlegen lassen.
                                      Es kommen immer noch Warnings mit
                                      2023-03-12 09:41:26.786  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.deviceId" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.786  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.longitude" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.786  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.latitude" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.version" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.versionCode" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.model" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.manufacturer" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.SDK" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.787  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.foreground" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.788  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.appStartTime" has no existing object, this might lead to an error in future versions
                                      2023-03-12 09:41:26.789  - warn: fully-mqtt.0 (2973073) State "fully-mqtt.0.Huawei-BadDG.Info.currentPageUrl" has no existing object, this might lead to an error in future versions
                                      • Acgua
                                        @ilovegym
                                        Nochmals vielen Dank fürs Testen!
                                        Info-Datenpunkte
                                        Das war ein Bug, wenn mehrere Tablets konfiguriert sind und ist nun behoben auf Github, werden nun also für alle Tablets sauber angelegt.
                                        MQTT Keep Alive Timeout
                                        Ich hatte zunächst mit einem Lenovo-Tablet getestet, da kam das nie. Aber beim Testen mit einem Huawei-Tablet habe ich das auch schon mal gesehen jetzt.
                                        Was hier passiert: Der Aedes MQTT Server bekommt einen "client error" Event gemeldet vom Tablet.
                                        Aktuell wird im Adapter bei einem solchen Client Error sofort ein Error "[MQTT] Client error - ..." ausgegeben und der Status des Tablets auf "not alive" gesetzt.
                                        Ich überlege, hier "keep alive timeout" Error abzufangen und nicht gleich einen Error auszugeben. Meldet sich das Tablet länger nicht, geht es eh auf "not alive".
                                        Hab bei mir auch kurzzeitig ein "Huawei: Client error - read ECONNRESET" Error, und paar Sekunden später ist das Tablet aber wieder verbunden.
                                        Ich bleib dran und verbessere das mit Logausgaben und Fehler abfangen.
                                        Zu "welcher Client verbunden ist"
                                        Absolut muss ein Adapter das abkönnen 🙂
                                        Wie meinst du das mit den "in den Instanzen sehen"?
                                        Derzeit wird der Status für jedes Tablet über fully-mqtt.0.Tablet-Name.alive angezeigt. Zusätzlich geht die Adapter-Instanz von gelb auf grün, wenn alle Clients verbunden sind. Ist ein Client nicht verbunden -> gelb. (über fully-mqtt.0.info.connection).
                                        • Acgua
                                          Du meinst sowas, oder?
                                          Ist jetzt drin.
                                          Ebenso diese MQTT-Option. Wenn aktiviert, werden die client errors etc. nur noch als Info ausgegeben. Wenn nach einer Weile (60s + 10s) der Fully sich gar nicht mehr meldet per MQTT, wird einmalig ein "[MQTT] Tablet-Name is not alive!" ausgegeben als Warn ausgegeben, mehr nicht.
                                          Ansonsten noch paar Fixes.
                                          0.0.3-alpha (2023-03-12)
                                          • (Acgua) Fix: various issues
                                          • (Acgua) Encrypt MQTT password (#11)
                                          • (Acgua) New: MQTT option to log client and connection errors as info and not error
                                          • (Acgua) New: Online status for each device is now displayed in objects: e.g. 'fully-mqtt.0.Tablet-Hallway' is green with a connection icon if it is alive
                                          • Neuschwansteini
                                            @acgua
                                            guten Morgen,
                                            super, die Warnings sind weg, das Log sieht jetzt sehr sauber aus, in allen Konfigurationen ( also Client and Connection enabled und auch disabled), die verschiedenen Logstufen funktionieren auch.
                                            Was nicht geht, ist die Anzeige
                                            https://forum.iobroker.net/assets/uploads/files/1678650418308-28617329-ad62-4cfd-8258-3e17aced1ede-image.png
                                            bei mir sieht das im Chrome und Firefox so aus:
                                            brauchst Du ein debug-log?
                                            31.7k
                                            79.8k
                                            87
                                            7806
