    4. Test Adapter ioBroker.imap latest/stable
      sigi234 Forum Testing Most Active @Lucky_ESA last edited by sigi234
      @lucky_esa
      Hallo, wollte es gerade auf einen neuen System installieren:
      imap.0
      2023-03-08 23:50:45.537	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      imap.0
      2023-03-08 23:50:45.533	error	adapter disabled
      imap.0
      2023-03-08 23:50:13.675	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      imap.0
      2023-03-08 23:50:13.675	info	terminating
      imap.0
      2023-03-08 23:50:13.672	error	Exception-Code: ERR_OSSL_EVP_BAD_DECRYPT: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
      imap.0
      2023-03-08 23:50:13.672	error	Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt at Decipheriv.final (node:internal/crypto/cipher:193:29) at Object.decrypt (C:\ioBroker1\node_modules\@iobroker\js-controller-common\lib\common\tools.js:2409:79) at Imap.decrypt (C:\ioBroker1\node_modules\@iobroker\js-controller-adapter\build\lib\adapter\adapter.js:7391:26) at Imap.onReady (C:\ioBroker1\node_modules\iobroker.imap\main.js:101:37)
      imap.0
      2023-03-08 23:50:13.670	error	unhandled promise rejection: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
      imap.0
      2023-03-08 23:50:13.669	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      imap.0
      2023-03-08 23:50:13.651	info	starting. Version 0.0.4 (non-npm: Lucky-ESA/ioBroker.imap#b061bc88fc01b1d1e00c1210a1f05a2ebc8520aa) in C:/ioBroker1/node_modules/iobroker.imap, node: v16.19.1, js-controller: 4.0.24
        sigi234 Forum Testing Most Active @sigi234 last edited by sigi234
        @sigi234 sagte in Test Adapter ioBroker.imap v0.0.1 GitHub:
        @lucky_esa
        Nochmal installiert, geht jetzt bis auf das Passwort. Anscheinend mag Google keine 2fach Installationen.
          Lucky_ESA Developer Most Active @sigi234 last edited by
          @lucky_esa
          Du musste dann erneut app passwort aufrufen und den login bestätigen. Bin auch mit Live und Dev angemeldet. Sorry für die Umstände mit der o. g. Fehlermeldung aber hier greift mein Workaround. Wenn die Instanz deaktiviert ist, ist eine Eingabe von IMAP`s nicht möglich. Vielleicht wird das noch im Controller aufgenommen. PW
          Bin mir allerdings nicht sicher ob dieser Workaround beim Latest Test Bestand haben wird.
          Habe immer noch Probleme mit Attachements...grrrrr. Gestern eine Mail mit 4MB erhalten und sofort der RAM von 130MB auf 170MB....
          • matze55
            matze55 @sigi234 last edited by
            @sigi234
            Ich kann die Emails abfragen aber in der VIS ist doch untergalb dieser Farbbalken den bekomme ich einfach nicht definiert.
            Bei der Kopffarbe suche ich im html Ordner ,,headline_color,, aber der farbalken da klemmt es
            lg
              sigi234 Forum Testing Most Active @matze55 last edited by
              @matze55 sagte in Test Adapter ioBroker.imap v0.0.1 GitHub:
              lg
              • D3ltoroxp
                D3ltoroxp last edited by D3ltoroxp
                ich versuche gerade die Mails meiner Kids ab zu fragen. Das sind quasi outlook.office365.com Mails von der Schule / MS Teams. Hier werden ja immer wieder Infos geschrieben. Da MS aber zu blöd ist mehrere Accounts gleichzeitig zu verwalten würde ich gerne informiert werden ohne ständig die Accounts zu wechseln.
                Ich kann mich aber mit den Einstellungen vom Thunderbird nicht einloggen.
                Geht das mit den Accounts nicht oder mit office365 ?
                Fehler bei Host xxx - Error: LOGIN failed. at Connection._resTagged (/opt/iobroker/node_modules/node-imap/lib/Connection.js:1272:13) at Parser.<anonymous> (/opt/iobroker/node_modules/node-imap/lib/Connection.js:190:12) at Parser.emit (node:events:513:28) at Parser._resTagged (/opt/iobroker/node_modules/node-imap/lib/Parser.js:169:12) at Parser._parse (/opt/iobroker/node_modules/node-imap/lib/Parser.js:135:18) at Parser._tryread (/opt/iobroker/node_modules/node-imap/lib/Parser.js:77:17) at TLSSocket.Parser._cbReadable (/opt/iobroker/node_modules/node-imap/lib/Parser.js:55:14) at TLSSocket.emit (node:events:513:28) at emitReadable_ (node:internal/streams/readable:578:12) at processTicksAndRejections (node:internal/process/task_queues:82:21) { type: 'no', textCode: undefined, source: 'authentication' }.
                Oder wie muss man diese Account im Adapter anlegen ?
                matze55 L 3 Replies Last reply Reply Quote 0
                • matze55
                  matze55 @D3ltoroxp last edited by
                  @d3ltoroxp bei dem Adapter IMAP musst du für live mail folgendes eintragen:
                  Host: outlook.office365.com
                  Posteingang: INBOX
                  Port: 993
                  Benutzname: DEINE Mailadresse
                  Paswort: DEIN PW
                  TLS: Kreuz Setzen bzw. Haken
                  tls-Option: {"rejectUnauthorized": false}
                  Auto-TLS: never
                  lg
                  D3ltoroxp 1 Reply Last reply Reply Quote 1
                  • D3ltoroxp
                    D3ltoroxp @matze55 last edited by
                    @matze55 Genau so hab ich es.
                    Aber es funktioniert nicht. In Thunderbird steht auch OAuth2. Wenn ich mich mit dem Konto neu in Thunderbird anmelde, kommt ein kleines Browser Fenster wo ich das noch mal bestätigen muss. Vllt liegt da das Problem ?
                    M matze55 2 Replies Last reply Reply Quote 0
                      MCU @D3ltoroxp last edited by MCU
                      @d3ltoroxp Man braucht ein APP Passwort.
                      https://mcuiobroker.gitbook.io/jarvis-infos/tipps/allgemein/microsoft-windows/2-fach-authentifizierung
                        Lucky_ESA Developer Most Active @D3ltoroxp last edited by
                        @d3ltoroxp
                        Für den 365 Login musst du die Logindaten verwenden, die du von der Schule erhalten hast und nicht die Logindaten von Thunderbird.
                        Am Besten dann pro Kind ein IMAP anlegen.
                        Gruß//Lucky
                        • matze55
                          matze55 @D3ltoroxp last edited by matze55
                          @d3ltoroxp Hast du auch das zusätzliche NPM Modul in Javascript eingetragen ?
                          Adapter auch mal neu gestartet, aber ich muss dazu auch sagen ich hatte ihn auch mal deinstalliert, nachdem hatte er mir die Emails angezeigt. Und ein APP Passwort brauchte ich nicht.
                          Ich teste das auch jetzt noch mit T-Online mal sehen ob das auch klappt.adapter.png
                          M L 2 Replies Last reply Reply Quote 0
                            MCU @matze55 last edited by
                            @matze55 APP Passwort wird immer dann benötigt, wenn man eine 2Fach-Authentifizierung aktiviert hat zum E-MAil-Konto.
                              Lucky_ESA Developer Most Active @MCU last edited by
                              @mcu sagte in Test Adapter ioBroker.imap v0.0.1 GitHub:
                              Danke, nehme ich mit auf.
                                Lucky_ESA Developer Most Active @matze55 last edited by
                                Welches Modul? In Java muss kein Modul eingetragen werden.
                                Gruß//Lucky
                                matze55 1 Reply Last reply Reply Quote 0
                                • matze55
                                  matze55 @Lucky_ESA last edited by
                                  In T-online , was auch klappt mit der Abfrage muss man ein zusätzliches Passwort erstellen......sorry Lucky_ESA(<_----Recht gehabt) damit die Sicherheit gewährt wird. Also T-Online klappt mit dem Adapter auch.
                                    Hast du eine Anleitung dazu?
                                    • matze55
                                      matze55 @Lucky_ESA last edited by matze55
                                      Die Flags sind nicht zwingend notwendig, ich habe sie auf ,,alle stehen. Der Adapter ist nicht schlecht der Geht Tadellos
                                        @sigi234 Hallo Sigi234, deine VIS funktionieren super, danke dafür. Jetzt habe ich leider noch ein Problem. Wollte die letzten 2 Funktionen noch aktivieren (move & copy) die dummerweise die UID benötigen und nicht die SEQNO. In json_table habe ich diese bereits hinzugefügt (noch nicht auf`m GIT) aber im HTML Code noch nicht.
                                        Soll ich diese da noch mit aufnehmen? WÄre wieder Mehraufwand für dich...
                                        Auch für den Blockly die Flags zu ändern muss die UID verwendet werden und nicht die SEQNO...
                                        Gruß//Lucky
                                          @lucky_esa
                                          Ok, was macht move and copy?
                                          Baue ich ein in Vis und stell sie Online.
                                            @lucky_esa
                                            Man kann aus der Inbox Mails in Unterordner kopieren oder verschieben. War hier weiter oben eine Anfrage zu...Hierzu würde ich pro IMAP 3 neue Datenpunkte anlegen. 1 x Folder Auswahl, 2 x UID ID und ein Button für Anwenden.
                                            Gruß//Lucky
                                            406
                                            64764
