    4. Node-Red
    5. [Gelöst] Benötige Hilfe mit Node-Red in Verbindung mit homee
    • O
      Oli @mickym last edited by
      @mickym
      habe mir das ganze mal angesehen und versucht durch zu blicken, aber leider funktioniert es nicht.
      Der Obere Teil sieht wie folgt aus:
      Bei den Debug-Nodes der einzelnen Geräte kommt immer folgendes:
      Bei der Debug-Node 5 schreibt er folgendes:
      {"attribute":{"id":358,"node_id":56,"instance":0,"minimum":0,"maximum":20,"current_value":0.412,"target_value":0.412,"last_value":0.438,"unit":"A","step_value":1,"editable":0,"type":193,"state":1,"last_changed":1678519354,"changed_by":1,"changed_by_id":0,"based_on":1,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}}}
      Aber nach meinem Verständnis, sollte doch eigentlich die "node" abgefragt werden, nicht die "attribute"
      {"node":{"id":29,"name":"EG%20%2F%20Wohnzimmer%20%2F%20Netatmo","profile":3014,"image":"default","favorite":0,"order":42,"protocol":9,"routing":0,"state":1,"state_changed":1678428037,"added":1607519624,"history":0,"cube_type":8,"note":"","services":5,"phonetic_name":"Klima%20Wohnzimmer","owner":1,"security":0,"attributes":[{"id":253,"node_id":29,"instance":0,"minimum":0,"maximum":50,"current_value":20.6,"target_value":20.6,"last_value":20.5,"unit":"%C2%B0C","step_value":0.5,"editable":0,"type":5,"state":1,"last_changed":1678519389,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":254,"node_id":29,"instance":0,"minimum":0,"maximum":100,"current_value":33,"target_value":33,"last_value":34,"unit":"%25","step_value":1,"editable":0,"type":7,"state":1,"last_changed":1678515784,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":255,"node_id":29,"instance":0,"minimum":0,"maximum":5000,"current_value":444,"target_value":444,"last_value":449,"unit":"ppm","step_value":50,"editable":0,"type":20,"state":1,"last_changed":1678519389,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":256,"node_id":29,"instance":0,"minimum":35,"maximum":120,"current_value":32,"target_value":32,"last_value":33,"unit":"dB","step_value":1,"editable":0,"type":93,"state":1,"last_changed":1678515183,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":257,"node_id":29,"instance":0,"minimum":260,"maximum":1160,"current_value":1003.7,"target_value":1003.7,"last_value":1003.6,"unit":"mBar","step_value":5,"editable":0,"type":94,"state":1,"last_changed":1678519389,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":"","options":{"history":{"day":1,"week":26,"month":6}}},{"id":258,"node_id":29,"instance":0,"minimum":0,"maximum":4,"current_value":4,"target_value":4,"last_value":2,"unit":"n%2Fa","step_value":1,"editable":0,"type":33,"state":1,"last_changed":1677083197,"changed_by":1,"changed_by_id":0,"based_on":4,"data":"","name":""},{"id":475,"node_id":29,"instance":0,"minimum":0,"maximum":1,"current_value":1,"target_value":1,"last_value":0,"unit":"","step_value":1,"editable":1,"type":385,"state":1,"last_changed":0,"changed_by":0,"changed_by_id":0,"based_on":0,"data":"","name":""}]}}
      Wenn dem so ist, wo kann ich das ändern?
      • mickym
        mickym Most Active @Oli last edited by mickym
        @oli Nein dem ist nicht so - im Gegenteil die attribute werden entfernt. - Ich denke wir haben ggf. nicht mit der gleichen Datenbasis gearbeitet.
        Bei mir sind also in dem Input alle 46 Geräte zu sehen.
        Mit der Change Node - werden im Gegenteil die einzelnen attribute weggenommen.
        Also haben wir eine unterschiedliche Ausgangsbasis. Kommen denn die Geräte einzeln an? oder insgesamt?
        Ich habe halt mit der Datenbasis gearbeitet, bei der alle Geräte aufeinmal ankommen. Also im Prinzip mit dem was Du mir in der Datei aus : https://forum.iobroker.net/post/960869 geschickt hast.
        Deswegen heißt mein Array auch nodes und nicht node. 😉
        Jetzt ist halt die Frage - kannst Du das auch so machen oder müssen wir die einzelnen Geräte mühsam sammeln? Wenn die Geräte einzeln ankommen - müssen wir den Flow umändern.
        Also sag mir, ob die Geräte sich da nun einzeln melden oder ob Du die ganze Geräteliste als Input zur Verfügung stellen kannst?
        Im Prinzip hat der wohl die Nodes global gesammelt, da dies in der 1. Zeile der function Node so steht:
        const nodes = global.get('homee.nodes');
        Falls dem so ist, kannst Du mal in Deinem globalen Kontext schauen, ob da die vollständigen Nodeliste drin ist 😉 ?
        Wenn ja dann - ignorieren wir nämlich den Input und setzen die payload am Anfang auf den globalen Kontext.
        Also schau mal, was ggf. hier in Deinem globalen Kontext drin steht:
        Du musst rechts auf das Aktualisieren Icon drücken.
        Falls dem so ist, wie ich vermute, dann ist das was rein kommt in Deinen Flow nur ein trigger - den wir später auch verfeinern können.
        Du kannst die payload - wie in der function Node auf alle Nodes setzen, wenn Du vorher noch folgende Change Node dran machst:
        die Change Node muss folgenden Inhalt haben:
                "id": "4bb866d9e36a197e",
                "type": "change",
                "z": "9c280ddf049b2b4d",
                "name": "",
                "rules": [
                        "t": "set",
                        "p": "payload.nodes",
                        "pt": "msg",
                        "to": "homee.nodes",
                        "tot": "global"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 390,
                "y": 460,
                "wires": [
                        "6f4c16eed7166074"
        Im Prinzip holen wir dann bei jedem Geräteupdate die vollständige Liste bzw. analysieren diese.
        Im Prinzip filtert er aus, dass nur diese Ereignisse triggern:
        if((msg.payload.node && ((msg.payload.node.state === 2)||(msg.payload.node.state === 12)))||msg.payload === true)
        das müssen wir halt nochmal schauen, ob das Sinn macht. Das bedeutet, dass momentan die Auswertung nur läuft wenn die payload nur true ist oder die payload eine Eigenschaft node hat, deren states 2 oder 12 ist.
        Ich hoffe ich habe mich verständlich ausgedrückt. - Also setze mal die payload auf den globalen Kontext, mit der Change Node und mit den triggern überlegen wir uns noch.
        So ich hab das jetzt nochmal simuliert:
        Wenn bei Dir der globale Kontext so aussieht:
        Dann sollte jetzt dieser ganze Flow funktionieren, indem Du einfach auf den trigger Knopf drückst oder auch von Deinem anderen Flow triggern lässt:
               "id": "1a49f3e7a72eeb98",
               "type": "debug",
               "name": "inaktive Geräte",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "complete": "payload",
               "targetType": "msg",
               "statusVal": "",
               "statusType": "auto",
               "x": 1620,
               "y": 620,
               "wires": []
               "id": "6f4c16eed7166074",
               "type": "change",
               "name": "decodeUrlComponents",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload ~> |$.nodes|{\"name\":$decodeUrlComponent(name),\t\"note\":$decodeUrlComponent(note),\t\"phonetic_name\":$decodeUrlComponent(phonetic_name)},\"attributes\"|",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 580,
               "y": 680,
               "wires": [
                       "5c62dbd7992ee76d"
               "id": "5c62dbd7992ee76d",
               "type": "change",
               "name": "Alle Geräte",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload.nodes",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 790,
               "y": 680,
               "wires": [
                       "9ed44d883152b608"
               "id": "99528e0bbb0f2491",
               "type": "change",
               "name": "Alle inaktiven Geräte",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload[state = 2]",
                       "tot": "jsonata"
                       "t": "set",
                       "p": "homee.inactive",
                       "pt": "flow",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1340,
               "y": 680,
               "wires": [
                       "1a49f3e7a72eeb98",
                       "79c90e3a205144c8",
                       "852a4580fa93381d"
               "id": "139fe3d8efb20402",
               "type": "change",
               "name": "Alle aktiven Geräte",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload[state = 1]",
                       "tot": "jsonata"
                       "t": "set",
                       "p": "homee.active",
                       "pt": "flow",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1330,
               "y": 440,
               "wires": [
                       "f8402a89bc3c1103",
                       "b1946c337b7d80ef",
                       "d95e18df200eadee"
               "id": "f8402a89bc3c1103",
               "type": "debug",
               "name": "aktive Geräte",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1550,
               "y": 400,
               "wires": []
               "id": "43f88f1028d1af0a",
               "type": "change",
               "name": "Geräte, die aktualisiert werden",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload[state = 12] ",
                       "tot": "jsonata"
                       "t": "set",
                       "p": "homee.updating",
                       "pt": "flow",
                       "to": "payload",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1370,
               "y": 940,
               "wires": [
                       "ceb8932892417bf3",
                       "4e3680fd1ba7cc1e",
                       "21b0ae03da03035d"
               "id": "ceb8932892417bf3",
               "type": "debug",
               "name": "Geräte die aktualisiert werden",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1690,
               "y": 880,
               "wires": []
               "id": "4e3680fd1ba7cc1e",
               "type": "change",
               "name": "Anzahl",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload ? $count(payload) : \"Keine Geräte im Aktualisierungsstatus\"",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1630,
               "y": 940,
               "wires": [
                       "d629bd7188fa7121"
               "id": "d629bd7188fa7121",
               "type": "debug",
               "name": "Anzahl Geräte im Aktualisierungsstatus",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1880,
               "y": 940,
               "wires": []
               "id": "79c90e3a205144c8",
               "type": "change",
               "name": "Anzahl",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1610,
               "y": 680,
               "wires": [
                       "6636132bd627fd5a"
               "id": "6636132bd627fd5a",
               "type": "debug",
               "name": "Anzahl inaktive Geräte",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1800,
               "y": 680,
               "wires": []
               "id": "b1946c337b7d80ef",
               "type": "change",
               "name": "Anzahl",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1550,
               "y": 440,
               "wires": [
                       "1871f120aa223a8d"
               "id": "1871f120aa223a8d",
               "type": "debug",
               "name": "Anzahl aktiver Geräte",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1740,
               "y": 440,
               "wires": []
               "id": "d95e18df200eadee",
               "type": "change",
               "name": "Namen",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload.phonetic_name",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1540,
               "y": 500,
               "wires": [
                       "ae2e5ba148bb399a"
               "id": "ae2e5ba148bb399a",
               "type": "debug",
               "name": "Namen aktiver Geräte (Phoenetic Name)",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1820,
               "y": 540,
               "wires": []
               "id": "852a4580fa93381d",
               "type": "change",
               "name": "Namen",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1620,
               "y": 740,
               "wires": [
                       "43f62f9f3bc5bc3d"
               "id": "43f62f9f3bc5bc3d",
               "type": "debug",
               "name": "Namen inaktiver Geräte (Phoenetic Name)",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1910,
               "y": 740,
               "wires": []
               "id": "21b0ae03da03035d",
               "type": "change",
               "name": "Namen",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1640,
               "y": 1000,
               "wires": [
                       "02eb40a627f4e90d"
               "id": "02eb40a627f4e90d",
               "type": "debug",
               "name": "Namen aktualisierende Geräte (Phoenetic Name)",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1950,
               "y": 1000,
               "wires": []
               "id": "9ed44d883152b608",
               "type": "change",
               "name": "Geräte ausschliessen",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload ~> $filter(function($value){$value.id in [-1] != true})",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 1000,
               "y": 680,
               "wires": [
                       "bc383b50669e8145"
               "id": "8295d28d57fdb5f9",
               "type": "inject",
               "name": "Trigger Report",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "",
               "payloadType": "date",
               "x": 250,
               "y": 1140,
               "wires": [
                       "bb70522cf511b632"
               "id": "bb70522cf511b632",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "homee",
                       "tot": "flow"
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "{\t   \"active\" : {\t       \"count\": payload.active ? $count(payload.active): 0,\t       \"names\" :  payload.active ?  $join(payload.active.phonetic_name,\"\\n\") : \"Keine aktiven Geräte vorhanden\"\t   },\t   \"inactive\" : {\t       \"count\": payload.inactive ? $count(payload.inactive): 0,\t        \"names\" :  payload.inactive ?  $join(payload.inactive.phonetic_name,\"\\n\") : \"Keine inaktiven Geräte vorhanden\"\t   },\t   \"updating\" : {\t       \"count\": payload.updating ? $count(payload.inactive): 0,\t        \"names\" :  payload.updating ?  $join(payload.updating.phonetic_name,\"\\n\") : \"Keine Geräte im Aktualisierungsstatus\"\t   },\t   \"summary\" : payload.updating or payload.inactive ? \"Nicht alle Geräte bereit!\" : \"Alle Geräte aktiv\"\t}",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 470,
               "y": 1200,
               "wires": [
                       "886c19b24989ed4d",
                       "a76c7c09a28be0d6",
                       "f422b5bcbb03ca87",
                       "5ea7fcec46176042"
               "id": "886c19b24989ed4d",
               "type": "template",
               "name": "",
               "field": "payload",
               "fieldType": "msg",
               "format": "html",
               "syntax": "mustache",
               "template": "<!DOCTYPE html>\n<html>\n\n<body>\n<h1>Status der Geräte:</h1>\n\n<h3>aktive Geräte: {{payload.active.count}}\n<pre>{{payload.active.names}}</pre>\n\n<h3>inaktive Geräte: {{payload.inactive.count}}\n<pre>{{payload.inactive.names}}</pre>\n\n<h3>aktualisierende Geräte: {{payload.updating.count}}\n<pre>{{payload.updating.names}}</pre>\n\n<h3>{{payload.summary}}</h3>\n</body>\n</html>",
               "output": "str",
               "x": 700,
               "y": 1200,
               "wires": [
                       "e9df565834fa1f46"
               "id": "ea538b90d2d339e0",
               "type": "file",
               "name": "",
               "filename": "filename",
               "filenameType": "msg",
               "appendNewline": false,
               "createDir": false,
               "overwriteFile": "true",
               "encoding": "none",
               "x": 1120,
               "y": 1200,
               "wires": [
               "id": "e9df565834fa1f46",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "filename",
                       "pt": "msg",
                       "to": "/home/iobroker/homee-report.html",
                       "tot": "str"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 910,
               "y": 1200,
               "wires": [
                       "ea538b90d2d339e0"
               "id": "a76c7c09a28be0d6",
               "type": "switch",
               "name": "",
               "property": "payload.summary",
               "propertyType": "msg",
               "rules": [
                       "t": "neq",
                       "v": "Alle Geräte aktiv",
                       "vt": "str"
               "checkall": "true",
               "repair": false,
               "outputs": 1,
               "x": 690,
               "y": 1280,
               "wires": [
                       "d8673a8fe1b1dfc2"
               "id": "48226cba37067157",
               "type": "debug",
               "name": "Warnung ausgeben - wenn nicht alle Geräte aktiv",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1190,
               "y": 1280,
               "wires": []
               "id": "d8673a8fe1b1dfc2",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload.summary",
                       "tot": "msg"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 870,
               "y": 1280,
               "wires": [
                       "48226cba37067157"
               "id": "f99cd78780beb8e7",
               "type": "ioBroker in",
               "name": "start",
               "topic": "0_userdata.0.System.homee.StartGeräteinfo",
               "payloadType": "value",
               "onlyack": "",
               "func": "all",
               "gap": "",
               "fireOnStart": "false",
               "outFormat": "MQTT",
               "x": 230,
               "y": 1200,
               "wires": [
                       "bb70522cf511b632"
               "id": "f422b5bcbb03ca87",
               "type": "change",
               "name": "Anzahl nicht aktiver Geräte",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "payload.inactive.count + payload.updating.count",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 760,
               "y": 1360,
               "wires": [
                       "8b40e4fbe4ba993d"
               "id": "8b40e4fbe4ba993d",
               "type": "debug",
               "name": "Nicht aktive Geräte (updating oder inaktiv)",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1100,
               "y": 1360,
               "wires": []
               "type": "change",
               "name": "hole alle Geräte",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "homee",
                       "tot": "global"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 340,
               "y": 680,
               "wires": [
                       "6f4c16eed7166074"
               "id": "a48d4a225b9f0daa",
               "type": "inject",
               "name": "trigger",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "true",
               "payloadType": "bool",
               "x": 170,
               "y": 680,
               "wires": [
                       "4bb866d9e36a197e"
               "id": "5ea7fcec46176042",
               "type": "debug",
               "name": "Zusammenfassung",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 730,
               "y": 1140,
               "wires": []
               "id": "bc383b50669e8145",
               "type": "junction",
               "x": 1160,
               "y": 680,
               "wires": [
                       "43f88f1028d1af0a",
                       "99528e0bbb0f2491",
                       "139fe3d8efb20402"
        Wenn Du dann unten den Trigger Report anklickst - dann solltest Du im Debug Fenster folgende Daten erhalten:
          "active": {
            "count": 44,
            "names": "Bewegungsmelder Kirsten\nBewegungsmelder Oliver\nLuftreiniger\nNachtlicht TV\nNachtlicht Kirsten\n\nNachtlicht Oliver\nHeizung Wohnzimmer Balkon\nWaschmaschine\nMultimedia\nRauchmelder Flur Dachgeschoss\nRauchmelder Flur Erdgeschoss\nRauchmelder Flur Keller\nFenster Bad\nBalkontür Esszimmer\nBalkontür Wohnzimmer\nFenster Toilette\nFenster Büro Rechts\nFenster Büro Links\nSchlafzimmer Rauchmelder\nRauchmelder Schlafzimmer Keller\nHeizung Büro\nVitrine Wohnzimmer\nTemperatur Weinkühlschrank\nHeizung Wohnzimmer Links\nSchrank Wohnzimmer\nHeizung Esszimmer\nHeizung Toilette\nWeinschrank Wohnzimmer\nThermostat Wohnzimmer\nComputer\nKühlschrank\nGeschirrspüler\nWassersensor Küche\nHeizung Bad\nKlima Wohnzimmer\nKlima Balkon\nKlima Büro\nKlima Schlafzimmer\nKlimaanlage\nTablet\nStehlampe Wohnzimmer\nBar Wohnzimmer\nTemperatur Kühlschrank"
          "inactive": {
            "count": 1,
            "names": "Licht Glasvitrine Flur"
          "updating": {
            "count": 0,
            "names": "Keine Geräte im Aktualisierungsstatus"
          "summary": "Nicht alle Geräte bereit!"
        • O
          @mickym
          sieht bei mir so aus:
          • mickym
            @oli Ok - dann lass mich noch eine kleine Modifikation machen. 😉
            • mickym
              @oli sagte in Benötige Hilfe mit Node-Red in Verbindung mit homee:
              @mickym
              Wobei es jetzt eigentlich bei Dir schon gehen sollte, weil ich Deinen Flow Kontext sehe. 😉
              so hier nochmal der gesamte Flow:
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1620,
                     "y": 620,
                     "wires": []
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 580,
                     "y": 680,
                     "wires": [
                             "5c62dbd7992ee76d"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 790,
                     "y": 680,
                     "wires": [
                             "9ed44d883152b608"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                             "t": "set",
                             "pt": "flow",
                             "to": "payload",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1340,
                     "y": 680,
                     "wires": [
                             "1a49f3e7a72eeb98",
                             "79c90e3a205144c8",
                             "852a4580fa93381d"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                             "t": "set",
                             "pt": "flow",
                             "to": "payload",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1330,
                     "y": 440,
                     "wires": [
                             "f8402a89bc3c1103",
                             "b1946c337b7d80ef",
                             "d95e18df200eadee"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1550,
                     "y": 400,
                     "wires": []
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                             "t": "set",
                             "pt": "flow",
                             "to": "payload",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1370,
                     "y": 940,
                     "wires": [
                             "ceb8932892417bf3",
                             "4e3680fd1ba7cc1e",
                             "21b0ae03da03035d"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1690,
                     "y": 880,
                     "wires": []
                     "type": "change",
                     "name": "Anzahl",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1630,
                     "y": 940,
                     "wires": [
                             "d629bd7188fa7121"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1880,
                     "y": 940,
                     "wires": []
                     "type": "change",
                     "name": "Anzahl",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1610,
                     "y": 680,
                     "wires": [
                             "6636132bd627fd5a"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1800,
                     "y": 680,
                     "wires": []
                     "type": "change",
                     "name": "Anzahl",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1550,
                     "y": 440,
                     "wires": [
                             "1871f120aa223a8d"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1740,
                     "y": 440,
                     "wires": []
                     "type": "change",
                     "name": "Namen",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1540,
                     "y": 500,
                     "wires": [
                             "ae2e5ba148bb399a"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1820,
                     "y": 540,
                     "wires": []
                     "type": "change",
                     "name": "Namen",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1620,
                     "y": 740,
                     "wires": [
                             "43f62f9f3bc5bc3d"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1910,
                     "y": 740,
                     "wires": []
                     "type": "change",
                     "name": "Namen",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1640,
                     "y": 1000,
                     "wires": [
                             "02eb40a627f4e90d"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1950,
                     "y": 1000,
                     "wires": []
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1000,
                     "y": 680,
                     "wires": [
                             "bc383b50669e8145"
                     "type": "inject",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "",
                     "x": 250,
                     "y": 1140,
                     "wires": [
                             "bb70522cf511b632"
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "homee",
                             "tot": "flow"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 470,
                     "y": 1200,
                     "wires": [
                             "886c19b24989ed4d",
                             "a76c7c09a28be0d6",
                             "f422b5bcbb03ca87",
                             "5ea7fcec46176042"
                     "type": "template",
                     "name": "",
                     "field": "payload",
                     "fieldType": "msg",
                     "format": "html",
                     "output": "str",
                     "x": 700,
                     "y": 1200,
                     "wires": [
                             "e9df565834fa1f46"
                     "type": "file",
                     "name": "",
                     "createDir": false,
                     "encoding": "none",
                     "x": 1120,
                     "y": 1200,
                     "wires": [
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "filename",
                             "pt": "msg",
                             "tot": "str"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 910,
                     "y": 1200,
                     "wires": [
                             "ea538b90d2d339e0"
                     "type": "switch",
                     "name": "",
                     "rules": [
                             "t": "neq",
                             "vt": "str"
                     "checkall": "true",
                     "repair": false,
                     "outputs": 1,
                     "x": 690,
                     "y": 1280,
                     "wires": [
                             "d8673a8fe1b1dfc2"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1190,
                     "y": 1280,
                     "wires": []
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 870,
                     "y": 1280,
                     "wires": [
                             "48226cba37067157"
                     "name": "start",
                     "onlyack": "",
                     "func": "all",
                     "gap": "",
                     "x": 230,
                     "y": 1200,
                     "wires": [
                             "bb70522cf511b632"
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 760,
                     "y": 1360,
                     "wires": [
                             "8b40e4fbe4ba993d"
                     "type": "debug",
                     "active": false,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 1100,
                     "y": 1360,
                     "wires": []
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "to": "{}",
                             "tot": "json"
                             "t": "set",
                             "pt": "msg",
                             "tot": "global"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 340,
                     "y": 680,
                     "wires": [
                             "6f4c16eed7166074"
                     "type": "inject",
                     "name": "trigger",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "payload": "true",
                     "x": 170,
                     "y": 680,
                     "wires": [
                             "4bb866d9e36a197e"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 730,
                     "y": 1140,
                     "wires": []
                     "type": "junction",
                     "x": 1160,
                     "y": 680,
                     "wires": [
                             "43f88f1028d1af0a",
                             "99528e0bbb0f2491",
                             "139fe3d8efb20402"
              Im Wesentlichen holen wir nun nur aus dem globalen Kontext die gesamte Geräteliste:
              Ist halt immer bissi schwierig, wenn man sich halt mit den Daten die Realität zusammensimulieren muss, aber sollte nun eigentlich passen.
              Wie gesagt wir müssen uns ggf. halt nur über den Trigger unterhalten. Vielleicht langt es da auch wenn Du mit deinem VIS Datenpunkt triggerst - da die globale Geräteliste ja bereits erstellt wird.
              • O
                @mickym
                super, jetzt funktioniert es 🙂
                • mickym
                  @mickym
                  Sehr gut. Dann probier halt erst mal bissi aus. Ggf. brauchst Du den Report nur wenn Du ihn antriggerst oder keine Ahnung ob der mit jedem Geräteupdate ausgegeben werden muss. Ich würde es nicht als final bezeichnen, aber es ist eine Basis damit Du die Zusammenhänge verstehst und das nun Deinen Bedürfnissen anpassen kannst.
                  Und wie gesagt: Hänge Dir so viele Debug-Nodes dran, wie Du willst, nur so verstehst Du wie die Befehle funktionieren.
                  • O
                    @mickym
                    den Report bräuchte ich eigentlich nur, wenn sich am Gerätestatus was ändert,
                    den oberen bräuchte ich ebenfalls nur wenn sich am Gerätestatus was ändert, oder ein neues gerät hinzukommt
                    ist das möglich?
                    • mickym
                      @oli Du sollst das ja nicht als finalen Flow betrachten. Momentan kannst Du das mit der trigger Node anstossen. 😉
                      Das hängt doch von "Dir" ab, was Du triggern lässt und wie Du das ermittelst. 😉 Ggf. an der Stelle an der die globale Geräteliste zusammen gezimmert wird.
                      Der Ersteller des ursprünglichen flows hatte das ja als Bedingung - aber das musst Du beurteilen:
                      sprich NUR wenn payload eine Eigenschaft node hat oder true ist - und wenn sie eine Eigenschaft node hat - dann nur wenn die Geräte nicht verfügbar sind.
                      Ob dass das ist, was Du willst - weiss ich nicht, aber dann hättest Du die gleiche Situation wie vorher.
                      Dazu baust Du für Deine Trigger folgenden Filter davor:
                             "id": "9c97a2e21b3710d3",
                             "type": "switch",
                             "name": "filter trigger",
                             "property": "(payload.node and (payload.node.state =2 or payload.node.state = 12)) or payload = true",
                             "propertyType": "jsonata",
                             "rules": [
                                     "t": "true"
                             "checkall": "true",
                             "repair": false,
                             "outputs": 1,
                             "x": 570,
                             "y": 440,
                             "wires": [
                                     "0f17893e37ac0581"
                      Wie gesagt - das ist der Filter der in der function Node war - wenn es andere Möglichkeiten gibt, dann musst du halt schauen. Ich überlege noch was anderes - aber das ist erst mal das, was bislang Dein jetziger Status mit dem anderen Flow war.
                      • mickym
                        @mickym
                        ist das möglich?
                        OK - habe ich Dir nun auch gemacht. Also nicht den Filter von dem ursprünglichen Flowersteller nehmen, sondern ich hab jetzt folgendes gebastelt: 😉
                        • Es wird geprüft, ob es ein Gerät ist
                        • Wenn ja wird es in die Nachrichteneigenschaft device geschoben
                        • Dann wird wieder die komplette Geräteliste geholt
                        • Dann wird das Gerät aus der Geräteliste selektiert und überprüft ob es vorhanden ist bzw. sich der status geändert hat und nur dann fortgesetzt.
                        Statt der Inject Node ein Gerät - kannst dann wieder mit Deinem anderen Flow verlinken:
                               "id": "94fbc6ce08554a92",
                               "type": "inject",
                               "name": "Ein Gerät",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "{\"node\":{\"id\":29,\"name\":\"EG%20%2F%20Wohnzimmer%20%2F%20Netatmo\",\"profile\":3014,\"image\":\"default\",\"favorite\":0,\"order\":42,\"protocol\":9,\"routing\":0,\"state\":1,\"state_changed\":1678428037,\"added\":1607519624,\"history\":0,\"cube_type\":8,\"note\":\"\",\"services\":5,\"phonetic_name\":\"Klima%20Wohnzimmer\",\"owner\":1,\"security\":0,\"attributes\":[{\"id\":253,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":50,\"current_value\":20.6,\"target_value\":20.6,\"last_value\":20.5,\"unit\":\"%C2%B0C\",\"step_value\":0.5,\"editable\":0,\"type\":5,\"state\":1,\"last_changed\":1678519389,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":254,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":100,\"current_value\":33,\"target_value\":33,\"last_value\":34,\"unit\":\"%25\",\"step_value\":1,\"editable\":0,\"type\":7,\"state\":1,\"last_changed\":1678515784,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":255,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":5000,\"current_value\":444,\"target_value\":444,\"last_value\":449,\"unit\":\"ppm\",\"step_value\":50,\"editable\":0,\"type\":20,\"state\":1,\"last_changed\":1678519389,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":256,\"node_id\":29,\"instance\":0,\"minimum\":35,\"maximum\":120,\"current_value\":32,\"target_value\":32,\"last_value\":33,\"unit\":\"dB\",\"step_value\":1,\"editable\":0,\"type\":93,\"state\":1,\"last_changed\":1678515183,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":257,\"node_id\":29,\"instance\":0,\"minimum\":260,\"maximum\":1160,\"current_value\":1003.7,\"target_value\":1003.7,\"last_value\":1003.6,\"unit\":\"mBar\",\"step_value\":5,\"editable\":0,\"type\":94,\"state\":1,\"last_changed\":1678519389,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\",\"options\":{\"history\":{\"day\":1,\"week\":26,\"month\":6}}},{\"id\":258,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":4,\"current_value\":4,\"target_value\":4,\"last_value\":2,\"unit\":\"n%2Fa\",\"step_value\":1,\"editable\":0,\"type\":33,\"state\":1,\"last_changed\":1677083197,\"changed_by\":1,\"changed_by_id\":0,\"based_on\":4,\"data\":\"\",\"name\":\"\"},{\"id\":475,\"node_id\":29,\"instance\":0,\"minimum\":0,\"maximum\":1,\"current_value\":1,\"target_value\":1,\"last_value\":0,\"unit\":\"\",\"step_value\":1,\"editable\":1,\"type\":385,\"state\":1,\"last_changed\":0,\"changed_by\":0,\"changed_by_id\":0,\"based_on\":0,\"data\":\"\",\"name\":\"\"}]}}",
                               "payloadType": "json",
                               "x": 120,
                               "y": 800,
                               "wires": [
                                       "e565ecbc06eb639f"
                               "id": "306e283de06793a5",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "move",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "device",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 500,
                               "y": 800,
                               "wires": [
                                       "3fcd14dd3eda98a3"
                               "id": "3fcd14dd3eda98a3",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "{}",
                                       "tot": "json"
                                       "t": "set",
                                       "pt": "msg",
                                       "tot": "global"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 720,
                               "y": 800,
                               "wires": [
                                       "3981f0834f60fe3d"
                               "id": "3981f0834f60fe3d",
                               "type": "switch",
                               "name": "Nur wenn Gerätestatus geändert",
                               "property": "payload.nodes[id=$$.device.node.id].state = device.node.state",
                               "rules": [
                                       "t": "false"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 1,
                               "x": 970,
                               "y": 800,
                               "wires": [
                                       "6f4c16eed7166074"
                               "id": "e565ecbc06eb639f",
                               "type": "switch",
                               "name": "verify device",
                               "property": "payload.node",
                               "rules": [
                                       "t": "nnull"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 1,
                               "x": 290,
                               "y": 800,
                               "wires": [
                                       "306e283de06793a5"
                        Nachdem Du die Zusammenfassung automatisch haben willst kannst Du das mit einer Complete Node erledigen, später würde ich das alles wegschmeissen und mit dem Hauptflow zusammenführen.
                               "id": "615f1d935afd46f7",
                               "type": "complete",
                               "name": "",
                               "scope": [
                                   "99528e0bbb0f2491",
                                   "43f88f1028d1af0a",
                                   "139fe3d8efb20402"
                               "uncaught": false,
                               "x": 230,
                               "y": 1260,
                               "wires": [
                                       "bb70522cf511b632"
                        Falls in der Complete Node nichts ausgewählt ist dann halt diese 3 Change Nodes auswählen
                        Wie gesagt final - wenn Du genug rumexperimentiert hast - würde ich das eh zusammenfassen.
                        und hinten raus - den Report willst Du ja auch ganz anders gestalten.
                        1. Konsolidierung:
                               "id": "afaeceb73a81b97a",
                               "type": "tab",
                               "label": "Homee 1. Konsoldierung",
                               "disabled": false,
                               "info": "",
                               "env": []
                               "id": "1f31a8a611e8ae62",
                               "type": "junction",
                               "z": "afaeceb73a81b97a",
                               "x": 1100,
                               "y": 400,
                               "wires": [
                                       "d1362666d0d6498d",
                                       "e5e4c67350b62fb9",
                                       "9c0a0c2ec54309c4"
                               "id": "d6ba83fcbbf8632b",
                               "type": "junction",
                               "x": 1560,
                               "y": 260,
                               "wires": [
                                       "4fc32434b1ad9e30"
                               "id": "ba0d73a9ecf905bb",
                               "type": "junction",
                               "x": 1500,
                               "y": 400,
                               "wires": [
                                       "d6ba83fcbbf8632b"
                               "id": "ccc13bcc415bf46d",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 520,
                               "y": 400,
                               "wires": [
                                       "c97f121d294f1458"
                               "id": "c97f121d294f1458",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 730,
                               "y": 400,
                               "wires": [
                                       "913391f5d68d5666"
                               "id": "e5e4c67350b62fb9",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1320,
                               "y": 400,
                               "wires": [
                                       "ba0d73a9ecf905bb"
                               "id": "9c0a0c2ec54309c4",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1330,
                               "y": 340,
                               "wires": [
                                       "ba0d73a9ecf905bb"
                               "id": "d1362666d0d6498d",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                                       "t": "set",
                                       "pt": "flow",
                                       "to": "payload",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1290,
                               "y": 460,
                               "wires": [
                                       "ba0d73a9ecf905bb"
                               "id": "913391f5d68d5666",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 940,
                               "y": 400,
                               "wires": [
                                       "1f31a8a611e8ae62"
                               "id": "bf00496a9f44421a",
                               "type": "inject",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "",
                               "x": 1330,
                               "y": 200,
                               "wires": [
                                       "d6ba83fcbbf8632b"
                               "id": "ee98fce5a9a9aa0a",
                               "name": "start",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "x": 1350,
                               "y": 260,
                               "wires": [
                                       "d6ba83fcbbf8632b"
                               "id": "f750a4c387a2be4e",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "{}",
                                       "tot": "json"
                                       "t": "set",
                                       "pt": "msg",
                                       "tot": "global"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 280,
                               "y": 400,
                               "wires": [
                                       "ccc13bcc415bf46d"
                               "id": "bc3f5ae2440a7bd8",
                               "type": "inject",
                               "name": "trigger",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "payload": "true",
                               "x": 110,
                               "y": 400,
                               "wires": [
                                       "f750a4c387a2be4e"
                               "id": "cb19c80f141b5ec7",
                               "type": "inject",
                               "props": [
                                       "p": "payload"
                               "repeat": "",
                               "crontab": "",
                               "once": false,
                               "onceDelay": 0.1,
                               "topic": "",
                               "x": 60,
                               "y": 520,
                               "wires": [
                                       "477f8cdd68a623d6"
                               "id": "ea25ff19366dbd8b",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "move",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "device",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 440,
                               "y": 520,
                               "wires": [
                                       "13fef03679554dae"
                               "id": "13fef03679554dae",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "{}",
                                       "tot": "json"
                                       "t": "set",
                                       "pt": "msg",
                                       "tot": "global"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 660,
                               "y": 520,
                               "wires": [
                                       "3e5a3f328d92cbec"
                               "id": "3e5a3f328d92cbec",
                               "type": "switch",
                               "rules": [
                                       "t": "false"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 1,
                               "x": 910,
                               "y": 520,
                               "wires": [
                                       "ccc13bcc415bf46d"
                               "id": "477f8cdd68a623d6",
                               "type": "switch",
                               "rules": [
                                       "t": "nnull"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 1,
                               "x": 230,
                               "y": 520,
                               "wires": [
                                       "ea25ff19366dbd8b"
                               "id": "4fc32434b1ad9e30",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "homee",
                                       "tot": "flow"
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 1710,
                               "y": 260,
                               "wires": [
                                       "93b337c8b0c958f0",
                                       "6208fe0589c08c8c",
                                       "91df4ca35b0811b5",
                                       "a9b7cfa0138adb7c"
                               "id": "93b337c8b0c958f0",
                               "type": "template",
                               "name": "",
                               "field": "payload",
                               "fieldType": "msg",
                               "format": "html",
                               "output": "str",
                               "x": 1940,
                               "y": 260,
                               "wires": [
                                       "bd020f5de81b6984"
                               "id": "1b3a14e37e06a753",
                               "type": "file",
                               "name": "",
                               "createDir": false,
                               "encoding": "none",
                               "x": 2360,
                               "y": 260,
                               "wires": [
                               "id": "bd020f5de81b6984",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "filename",
                                       "pt": "msg",
                                       "tot": "str"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 2150,
                               "y": 260,
                               "wires": [
                                       "1b3a14e37e06a753"
                               "id": "6208fe0589c08c8c",
                               "type": "switch",
                               "name": "",
                               "rules": [
                                       "t": "neq",
                                       "vt": "str"
                               "checkall": "true",
                               "repair": false,
                               "outputs": 1,
                               "x": 1930,
                               "y": 340,
                               "wires": [
                                       "e7ee2a2337e50af1"
                               "id": "f533e9122ec7d98d",
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 2430,
                               "y": 340,
                               "wires": []
                               "id": "e7ee2a2337e50af1",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "msg"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 2110,
                               "y": 340,
                               "wires": [
                                       "f533e9122ec7d98d"
                               "id": "91df4ca35b0811b5",
                               "type": "change",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 2000,
                               "y": 420,
                               "wires": [
                                       "49ce4151b0046769"
                               "id": "49ce4151b0046769",
                               "type": "debug",
                               "active": false,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 2340,
                               "y": 420,
                               "wires": []
                               "id": "a9b7cfa0138adb7c",
                               "type": "debug",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "statusVal": "",
                               "x": 1970,
                               "y": 200,
                               "wires": []
                        • O
                          @mickym
                          oh, oh, dass ging mir jetzt alles zu schnell, also nochmal zum mitschreiben für dumme wie mich.
                          1. den unteren Teil des ersten Flow kann ich löschen und dafür den neuen Flow Konsolidierung importieren?
                          2. Muss ich am "Ein Gerät" noch etwas ändern oder nachtragen?
                          3. habe ich nicht begriffe, was "Ein Gerät" bewirkt?
                          • mickym
                            @oli Ja ich dachte eigentlich Du willst erst mal lernen - deswegen lass das halt mit der Konsolidierung weg.
                            Anstelle der Inject Node kommt der Link aus deinem anderen Flow. Ich muss ja immer simulieren. Ich habe also nur das Geräte mit der ID29 zum Testen genommen. Also anstelle der Inject Node - kannst Du deinen Flow anschliessen, der die Geräte liefert.
                            • mickym
                              Den importierst Du erst - wenn Du genügend geübt hast. Es geht mir nicht darum, dass Du jetzt den finalen Flow hast. Ich dachte Du willst das erst mal verstehen????
                              Lass das mit der Konsolidierung erst mal weg. Den kannst ja später immer noch importieren.
                              • O
                                @mickym
                                deswegen frage ich ja nach, weil ich es verstehen will
                                • mickym
                                  @mickym
                                  Gut also Konsolidierungsflow für später aufheben. 😉 - Die anderen Nodes kannst importieren - und statt "Ein Gerät" - schließt Du Deinen anderen Flow an, der Dir Updates von Deinen Geräten liefert.
                                  Im Prinzip brauchst Du auch das manuelle Antriggern dann nicht mehr. Das ist nur damit Du sehen kannst, wie Du hinten mit JSONATA verschiedene Informationen aus deinen Node-Objekten holst. (Ich habe ja nur mal den phonetischen_name herausgeholt).
                                  • O
                                    @mickym
                                    so, jetzt habe ich mal mit dem oberen Flow etwas gespielt und mir zusätzliche Daten geholt und schon kommt die nächste Frage.
                                    Wie erstelle ich mir daraus ein Json, was ich in der VIS in einem Tabellen-Widget anzeigen lassen kann?
                                    Folgende Spalten würde ich benötigen:
                                    Name = Gerätename
                                    Gerätetyp = Gerätetyp
                                    Protokoll = Funkprotokoll (ZWave, ZigBee usw)
                                    Gerätestatus = Gerätestatus (verfügbar, .....)
                                    Die Daten werden im Flow alle schon abgefragt.
                                           "id": "b8ad42061a6d5f2e",
                                           "type": "tab",
                                           "label": "Flow 2",
                                           "disabled": false,
                                           "info": "",
                                           "env": []
                                           "type": "junction",
                                           "z": "b8ad42061a6d5f2e",
                                           "x": 1120,
                                           "y": 380,
                                           "wires": [
                                                   "43f88f1028d1af0a",
                                                   "99528e0bbb0f2491",
                                                   "139fe3d8efb20402",
                                                   "afc0236a6dc34b6c",
                                                   "3baf2b45228f3514",
                                                   "61efee2e1293f2f8",
                                                   "18ed2cb5de54b4e1"
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1620,
                                           "y": 320,
                                           "wires": []
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 540,
                                           "y": 380,
                                           "wires": [
                                                   "5c62dbd7992ee76d"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 750,
                                           "y": 380,
                                           "wires": [
                                                   "9ed44d883152b608"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1300,
                                           "y": 380,
                                           "wires": [
                                                   "1a49f3e7a72eeb98",
                                                   "79c90e3a205144c8",
                                                   "852a4580fa93381d"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1290,
                                           "y": 180,
                                           "wires": [
                                                   "f8402a89bc3c1103",
                                                   "b1946c337b7d80ef",
                                                   "d95e18df200eadee"
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1610,
                                           "y": 120,
                                           "wires": []
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1330,
                                           "y": 580,
                                           "wires": [
                                                   "ceb8932892417bf3",
                                                   "4e3680fd1ba7cc1e",
                                                   "21b0ae03da03035d"
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1670,
                                           "y": 520,
                                           "wires": []
                                           "type": "change",
                                           "name": "Anzahl",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 580,
                                           "wires": [
                                                   "d629bd7188fa7121"
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1840,
                                           "y": 580,
                                           "wires": []
                                           "type": "change",
                                           "name": "Anzahl",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 380,
                                           "wires": [
                                                   "6636132bd627fd5a"
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1880,
                                           "y": 380,
                                           "wires": []
                                           "type": "change",
                                           "name": "Anzahl",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 180,
                                           "wires": [
                                                   "1871f120aa223a8d"
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1800,
                                           "y": 180,
                                           "wires": []
                                           "type": "change",
                                           "name": "Namen",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "payload.name",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 240,
                                           "wires": [
                                                   "ae2e5ba148bb399a"
                                           "type": "debug",
                                           "name": "Namen aktiver Geräte",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1800,
                                           "y": 240,
                                           "wires": []
                                           "type": "change",
                                           "name": "Namen",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 440,
                                           "wires": [
                                                   "43f62f9f3bc5bc3d"
                                           "type": "debug",
                                           "name": "Namen inaktiver Geräte",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1810,
                                           "y": 440,
                                           "wires": []
                                           "type": "change",
                                           "name": "Namen",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 640,
                                           "wires": [
                                                   "02eb40a627f4e90d"
                                           "type": "debug",
                                           "name": "Namen aktualisierende Geräte",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1850,
                                           "y": 640,
                                           "wires": []
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 960,
                                           "y": 380,
                                           "wires": [
                                                   "bc383b50669e8145"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "{}",
                                                   "tot": "json"
                                                   "t": "set",
                                                   "pt": "msg",
                                                   "tot": "global"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 300,
                                           "y": 380,
                                           "wires": [
                                                   "6f4c16eed7166074"
                                           "type": "inject",
                                           "name": "trigger",
                                           "props": [
                                                   "p": "payload"
                                           "repeat": "",
                                           "crontab": "",
                                           "once": false,
                                           "onceDelay": 0.1,
                                           "topic": "",
                                           "payload": "true",
                                           "x": 130,
                                           "y": 380,
                                           "wires": [
                                                   "4bb866d9e36a197e"
                                           "id": "afc0236a6dc34b6c",
                                           "type": "change",
                                           "name": "Alle ZWave Geräte",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "payload[protocol = 1]",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1290,
                                           "y": 780,
                                           "wires": [
                                                   "3f5d54fa1161d7c3",
                                                   "fb541319f5065b26",
                                                   "08ef2be1a63734c5",
                                                   "94e00d809404b4a6"
                                           "id": "3f5d54fa1161d7c3",
                                           "type": "debug",
                                           "name": "Geräte mit ZWave",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1630,
                                           "y": 720,
                                           "wires": []
                                           "id": "fb541319f5065b26",
                                           "type": "change",
                                           "name": "Anzahl",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "payload ? $count(payload) : 0",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 780,
                                           "wires": [
                                                   "8b5f07919d5020d8",
                                                   "27bd5b6a0a11f64b"
                                           "id": "8b5f07919d5020d8",
                                           "type": "debug",
                                           "name": "Anzahl Geräte ZWave",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1900,
                                           "y": 720,
                                           "wires": []
                                           "id": "08ef2be1a63734c5",
                                           "type": "change",
                                           "name": "Namen",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 840,
                                           "wires": [
                                                   "3a0ad671056f0682"
                                           "id": "3a0ad671056f0682",
                                           "type": "debug",
                                           "name": "Namen ZWave Geräte",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1820,
                                           "y": 840,
                                           "wires": []
                                           "id": "27bd5b6a0a11f64b",
                                           "type": "ioBroker out",
                                           "name": "Anzahl ZWave Geräte",
                                           "topic": "0_userdata.0.System.homee.NichtVerfügbar",
                                           "ack": "true",
                                           "autoCreate": "true",
                                           "stateName": "0_userdata.0.System.homee.ZWave",
                                           "role": "",
                                           "payloadType": "number",
                                           "readonly": "false",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 1840,
                                           "y": 780,
                                           "wires": []
                                           "id": "3baf2b45228f3514",
                                           "type": "change",
                                           "name": "Alle ZigBee Geräte",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "payload[protocol = 2]",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1290,
                                           "y": 1040,
                                           "wires": [
                                                   "b0d34d08416e6c10",
                                                   "adb5799593bc282a",
                                                   "251973e2ae0fef12",
                                                   "82e4d47fe4eafc92"
                                           "id": "b0d34d08416e6c10",
                                           "type": "debug",
                                           "name": "Geräte mit ZigBee",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1630,
                                           "y": 980,
                                           "wires": []
                                           "id": "adb5799593bc282a",
                                           "type": "change",
                                           "name": "Anzahl",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 1040,
                                           "wires": [
                                                   "b553c35fe84e7ff1",
                                                   "a722c9c32ead9437"
                                           "id": "b553c35fe84e7ff1",
                                           "type": "debug",
                                           "name": "Anzahl Geräte ZigBee",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1900,
                                           "y": 980,
                                           "wires": []
                                           "id": "251973e2ae0fef12",
                                           "type": "change",
                                           "name": "Namen",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 1100,
                                           "wires": [
                                                   "382b28ab778199d6"
                                           "id": "382b28ab778199d6",
                                           "type": "debug",
                                           "name": "Namen ZigBee Geräte",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1820,
                                           "y": 1100,
                                           "wires": []
                                           "id": "a722c9c32ead9437",
                                           "name": "Anzahl ZigBee Geräte",
                                           "topic": "0_userdata.0.System.homee.ZigBee",
                                           "ack": "true",
                                           "stateName": "0_userdata.0.System.homee.ZigBee",
                                           "role": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 1840,
                                           "y": 1040,
                                           "wires": []
                                           "type": "change",
                                           "name": "",
                                           "rules": [
                                                   "t": "move",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "device",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 500,
                                           "y": 520,
                                           "wires": [
                                                   "3fcd14dd3eda98a3"
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "{}",
                                                   "tot": "json"
                                                   "t": "set",
                                                   "pt": "msg",
                                                   "tot": "global"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 720,
                                           "y": 520,
                                           "wires": [
                                                   "3981f0834f60fe3d"
                                           "type": "switch",
                                           "rules": [
                                                   "t": "false"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 1,
                                           "x": 970,
                                           "y": 520,
                                           "wires": [
                                                   "6f4c16eed7166074"
                                           "type": "switch",
                                           "rules": [
                                                   "t": "nnull"
                                           "checkall": "true",
                                           "repair": false,
                                           "outputs": 1,
                                           "x": 290,
                                           "y": 520,
                                           "wires": [
                                                   "306e283de06793a5"
                                           "id": "94e00d809404b4a6",
                                           "type": "change",
                                           "name": "Gerätetyp",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "payload.note",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 900,
                                           "wires": [
                                                   "0582b181c8bac51c"
                                           "id": "0582b181c8bac51c",
                                           "type": "debug",
                                           "name": "Gerätebezeichnung",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1810,
                                           "y": 900,
                                           "wires": []
                                           "id": "82e4d47fe4eafc92",
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 1160,
                                           "wires": [
                                                   "f575dd92416739a5"
                                           "id": "f575dd92416739a5",
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1840,
                                           "y": 1160,
                                           "wires": []
                                           "id": "61efee2e1293f2f8",
                                           "type": "change",
                                           "name": "Alle EnOcean Geräte",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "payload[protocol = 3]",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1300,
                                           "y": 1300,
                                           "wires": [
                                                   "6174c1fb73ccadf7",
                                                   "6bf0970636cc1e4a",
                                                   "d1def4dc22f8abba",
                                                   "8e7cb4b3ad9ad7e4"
                                           "id": "6174c1fb73ccadf7",
                                           "type": "debug",
                                           "name": "Geräte mit EnOcean",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1640,
                                           "y": 1240,
                                           "wires": []
                                           "id": "6bf0970636cc1e4a",
                                           "type": "change",
                                           "name": "Anzahl",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 1300,
                                           "wires": [
                                                   "ec17a4f04cc1f205",
                                                   "39049bb60e657627"
                                           "id": "ec17a4f04cc1f205",
                                           "type": "debug",
                                           "name": "Anzahl Geräte EnOcean",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1920,
                                           "y": 1240,
                                           "wires": []
                                           "id": "d1def4dc22f8abba",
                                           "type": "change",
                                           "name": "Namen",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 1360,
                                           "wires": [
                                                   "6b83b8e1410bdb8b"
                                           "id": "6b83b8e1410bdb8b",
                                           "type": "debug",
                                           "name": "Namen EnOcean Geräte",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1900,
                                           "y": 1360,
                                           "wires": []
                                           "id": "39049bb60e657627",
                                           "name": "Anzahl EnOcean Geräte",
                                           "topic": "0_userdata.0.System.homee.EnOcean",
                                           "ack": "true",
                                           "stateName": "0_userdata.0.System.homee.EnOcean",
                                           "role": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 1860,
                                           "y": 1300,
                                           "wires": []
                                           "id": "8e7cb4b3ad9ad7e4",
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 1420,
                                           "wires": [
                                                   "682221e81d05e1fb"
                                           "id": "682221e81d05e1fb",
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1840,
                                           "y": 1420,
                                           "wires": []
                                           "id": "18ed2cb5de54b4e1",
                                           "type": "change",
                                           "name": "Alle WLan Geräte",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "to": "payload[protocol = 9]",
                                                   "tot": "jsonata"
                                                   "t": "set",
                                                   "pt": "flow",
                                                   "to": "payload",
                                                   "tot": "msg"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1290,
                                           "y": 1560,
                                           "wires": [
                                                   "73232d6356145c91",
                                                   "1f89021c7a98c311",
                                                   "4d4781ea193feb05",
                                                   "f86809f6445fcbc5"
                                           "id": "73232d6356145c91",
                                           "type": "debug",
                                           "name": "Geräte mit WLan",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1630,
                                           "y": 1500,
                                           "wires": []
                                           "id": "1f89021c7a98c311",
                                           "type": "change",
                                           "name": "Anzahl",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1590,
                                           "y": 1560,
                                           "wires": [
                                                   "1294df0c49809c46",
                                                   "ab79ca8d13f7e817"
                                           "id": "1294df0c49809c46",
                                           "type": "debug",
                                           "name": "Anzahl Geräte WLan",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1910,
                                           "y": 1500,
                                           "wires": []
                                           "id": "4d4781ea193feb05",
                                           "type": "change",
                                           "name": "Namen",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 1620,
                                           "wires": [
                                                   "b4ba55ad0865333b"
                                           "id": "b4ba55ad0865333b",
                                           "type": "debug",
                                           "name": "Namen WLan Geräte",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1890,
                                           "y": 1620,
                                           "wires": []
                                           "id": "ab79ca8d13f7e817",
                                           "name": "Anzahl WLan Geräte",
                                           "topic": "0_userdata.0.System.homee.WLan",
                                           "ack": "true",
                                           "stateName": "0_userdata.0.System.homee.WLan",
                                           "role": "",
                                           "stateUnit": "",
                                           "stateMin": "",
                                           "stateMax": "",
                                           "x": 1850,
                                           "y": 1560,
                                           "wires": []
                                           "id": "f86809f6445fcbc5",
                                           "type": "change",
                                           "rules": [
                                                   "t": "set",
                                                   "p": "payload",
                                                   "pt": "msg",
                                                   "tot": "jsonata"
                                           "action": "",
                                           "property": "",
                                           "from": "",
                                           "to": "",
                                           "reg": false,
                                           "x": 1600,
                                           "y": 1680,
                                           "wires": [
                                                   "0d7f447681a383e1"
                                           "id": "0d7f447681a383e1",
                                           "type": "debug",
                                           "active": false,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "statusVal": "",
                                           "x": 1840,
                                           "y": 1680,
                                           "wires": []
                                           "id": "d8d565711fe0dd22",
                                           "type": "link in",
                                           "name": "",
                                           "links": [
                                               "d87f2174cf715cf2"
                                           "x": 75,
                                           "y": 520,
                                           "wires": [
                                                   "e565ecbc06eb639f"
                                    • mickym
                                      mickym Most Active last edited by mickym
                                      Na nachdem ich nicht so fit bin was VIS betrifft, wollt ich zurückfragen:
                                      Es geht also darum ein JSON aufzu bauen, wie hier:
                                      https://www.smarthome-tricks.de/software-iobroker/iobroker-vis-json-table-widget-teil-1-basics/
                                      Dann lass uns nochmal sicher gehen:
                                         "name": name,
                                        "type": type,
                                         "protocol": protocol,
                                         "state" : state
                                      Die Überschriften bzw. das Mapping macht das Widget ja selbst.
                                      Kannst Du mir vielleicht noch sagen, welche Eigenschaft dem type entspricht? (cube_type ??)
                                      Gibts irgendwie ein lookup, welche Protokolle es gibt oder sind die 4 Protokolle bereits vollständig?
                                      Entspricht type - den Services - und möchtest Du die übersetzt haben?
                                      Ansonsten müsstest Du ggf. die Eigenschaften, der Protokolle halt ergänzen:
                                      {"1":"ZWave","2":"Zigbee","3":"EnOcean","9":"WLan"}
                                      bei den Typen entsprechend.
                                      So nachdem Du Dich gerade nicht meldest - hier die Tabelle mit den Eigenschaften wie oben:
                                      die musst halt einfach dahinter hängen - wo alle Geräte noch beisammen sind:
                                             "id": "ef09455158bdbd20",
                                             "type": "change",
                                             "name": "VIS Tabelle",
                                             "rules": [
                                                     "t": "set",
                                                     "p": "protocols",
                                                     "pt": "msg",
                                                     "to": "{\"1\":\"ZWave\",\"2\":\"Zigbee\",\"3\":\"EnOcean\",\"9\":\"WLan\"}",
                                                     "tot": "json"
                                                     "t": "set",
                                                     "p": "states",
                                                     "pt": "msg",
                                                     "to": "{\"1\":\"aktiv\",\"2\":\"inaktiv\",\"12\":\"wird aktualisiert\"}",
                                                     "tot": "json"
                                                     "t": "set",
                                                     "p": "payload",
                                                     "pt": "msg",
                                                     "to": "payload.{\t   \"name\" :name,\t   \"type\" : cube_type,\t   \"protocol\" :protocol ? $lookup($$.protocols,$string(protocol)) : protocol,\t   \"state\" : $lookup($$.states,$string(state)) \t}",
                                                     "tot": "jsonata"
                                             "action": "",
                                             "property": "",
                                             "from": "",
                                             "to": "",
                                             "reg": false,
                                             "x": 1210,
                                             "y": 3380,
                                             "wires": [
                                                     "1b3e55fcd8eadc58"
                                             "id": "1b3e55fcd8eadc58",
                                             "type": "debug",
                                             "active": true,
                                             "tosidebar": true,
                                             "console": false,
                                             "tostatus": false,
                                             "statusVal": "",
                                             "x": 1410,
                                             "y": 3380,
                                             "wires": []
                                      • O
                                        @mickym
                                        ich verwende für die VIS den Materialdesign Adapter und erstelle mir per Skript schon ein paar Tabellen, vielleicht hilft dir die Json Ausgabe dabei
                                        [{"id":"FloodDetector-23","sensor":"Küche Wassersensor EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 95 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_100.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"FourButtonRemote-64","sensor":"Schlafzimmer Schalter Nachtlicht DG","betrieb":"Batterie","zustand":" <font color=\"#8f8f8f\">  N/A","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_0.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-20","sensor":"Küche Kühlschrank EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-33","sensor":"Schlafzimmer Klimaanlage DG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-34","sensor":"Flur Tablet EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-42","sensor":"Wohnzimmer Weinkühlschrank EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-56","sensor":"Büro Computer EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-57","sensor":"Küche Geschirrspüler EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-58","sensor":"Wohnzimmer Multimedia EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-59","sensor":"Keller Waschmaschine UG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"MeteringPlug-6","sensor":"Flur Vitrine Licht DG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-35","sensor":"Wohnzimmer Stehlampe EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-36","sensor":"Wohnzimmer Bar EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-38","sensor":"Wohnzimmer Vitrine EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-39","sensor":"Wohnzimmer TV-Schrank EG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-63","sensor":"Schlafzimmer Nachtlicht Oliver DG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-65","sensor":"Schlafzimmer Nachtlicht Kirsten DG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-66","sensor":"Schlafzimmer Nachtlicht TV DG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OnOffPlug-68","sensor":"Schlafzimmer Luftreiniger DG","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OpenCloseSensor-10","sensor":"WC Fenster EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_100.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OpenCloseSensor-11","sensor":"Wohnzimmer Balkontüre EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 90 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_90.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OpenCloseSensor-12","sensor":"Esszimmer Balkontüre EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_100.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OpenCloseSensor-13","sensor":"Bad Fenster DG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 86 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_90.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OpenCloseSensor-8","sensor":"Büro Fenster Links EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_100.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"OpenCloseSensor-9","sensor":"Büro Fenster Rechts EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 90 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_90.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"PresenceDetectorWithTemperatureAndBrightnessSensor-70","sensor":"Schlafzimmer Bewegungsmelder Oliver DG","betrieb":"Batterie","zustand":" <font color=\"#8f8f8f\">  N/A","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_0.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"PresenceDetectorWithTemperatureAndBrightnessSensor-71","sensor":"Schlafzimmer Bewegungsmelder DG","betrieb":"Batterie","zustand":" <font color=\"#8f8f8f\">  N/A","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_0.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"RadiatorThermostat-1","sensor":"Büro Heizung EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 55 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_60.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"RadiatorThermostat-2","sensor":"Wohnzimmer Heizung Links EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 85 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_90.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"RadiatorThermostat-26","sensor":"Bad Heizung DG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 85 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_90.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"RadiatorThermostat-4","sensor":"Esszimmer Heizung EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 95 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_100.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"RadiatorThermostat-5","sensor":"WC Heizung EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 55 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_60.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"RadiatorThermostat-62","sensor":"Wohnzimmer Heizung Balkon EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 55 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_60.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"RoomThermostat-19","sensor":"Wohnzimmer Raumthermostat EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 77 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_80.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"SmokeDetector-14","sensor":"Flur Rauchmelder UG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 76 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_80.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"SmokeDetector-15","sensor":"Flur Rauchmelder EG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_100.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"SmokeDetector-16","sensor":"Flur Rauchmelder DG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 98 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_100.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"SmokeDetector-18","sensor":"Schlafzimmer Rauchmelder UG","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 88 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_90.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"SmokeDetector-45","sensor":"Schlafzimmer Rauchmelder DG","betrieb":"Batterie","zustand":" <font color=\"red\"> 12 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_20.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"TemperatureAndHumiditySensor-43","sensor":"Wohnzimmer Temperatur Weinkühlschrank EG","betrieb":"Batterie","zustand":" <font color=\"#8f8f8f\">  N/A","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_0.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"TemperatureAndHumiditySensor-44","sensor":"Wohnzimmer Temperatur Weinkühlschrank EG","betrieb":"Batterie","zustand":" <font color=\"#8f8f8f\">  N/A","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_0.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/homeek.png","adapter":"homee"},{"id":"02-00-00-6b-4f-a0","sensor":"Aussenraum","betrieb":"Batterie","zustand":" <font color=\"yellow\"> 27 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_30.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/netatmok.png","adapter":"homee"},{"id":"03-00-00-09-89-18","sensor":"Netatmo Schlafzimmer","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 76 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_80.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/netatmok.png","adapter":"homee"},{"id":"03-00-00-0a-2b-4e","sensor":"Netatmo Büro","betrieb":"Batterie","zustand":" <font color=\"lightgreen\"> 49 %","image":"/vis.0/main/img/Meine Icons/Batterie/Batterie_50.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/netatmok.png","adapter":"homee"},{"id":"70-ee-50-6b-5f-4e","sensor":"Mein Haus (Netatmo Wohnzimmer)","betrieb":"Strom","zustand":" <font color=\"green\"> 100 %","image":"/vis.0/main/img/Meine Icons/Batterie/Strom.png","logo":"/vis.0/main/img/Meine Icons/Tabellen/netatmok.png","adapter":"homee"}]
                                        Den Status und und das Protokoll müsste man wahrscheinlich übersetzten
                                        Status: 1 = Verfügbar, 2 = nicht verfügbar, 3 = wird aktualisiert
                                        Protokoll: 1 = ZWave, 2 = ZigBee, 3 = EnOcean, 9 = WLan
                                        Widget-Einstellungen
                                        Die Tabelle sieht dann so aus:
                                        • mickym
                                          mickym Most Active @Oli last edited by mickym
                                          @oli Das habe ich doch schon alles gemacht, schaus Dir halt an. Es geht doch nur noch um den Typ. Aktualisert ist 12 und nicht 3.
                                          [{"name":"DG / Schlafzimmer / Bewegungsmelder / Kirsten","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"DG / Schlafzimmer / Bewegungsmelder Oliver","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"DG / Schlafzimmer / Luftreiniger","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"DG / Schlafzimmer / Nachtlicht TV","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"DG / Schlafzimmer / Nachtlicht Kirsten","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"DG / Schlafzimmer / Schalter Nachtlicht","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"DG / Schlafzimmer / Nachtlicht Oliver","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"EG / Wohnzimmer / Heizung Balkon","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"UG / Keller / Waschmaschine","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / Multimedia","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"DG / Flur / Rauchmelder","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Flur / Rauchmelder","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"UG / Flur / Rauchmelder","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"DG / Bad / Fenster","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Esszimmer / Balkontüre","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / Balkontüre","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / WC / Fenster","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Büro / Fenster Rechts","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Büro / Fenster Links","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"DG / Schlafzimmer / Rauchmelder","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"UG / Schlafzimmer / Rauchmelder","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Büro / Heizung","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / Vitrine","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"DG / Flur / Vitrine Licht","type":1,"protocol":"ZWave","state":"inaktiv"},{"name":"EG / Wohnzimmer / Temperatur Weinkühlschrank","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"EG / Wohnzimmer / Heizung Links","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / TV-Schrank","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"EG / Esszimmer / Heizung","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / WC / Heizung","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / Weinkühlschrank","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / Raumthermostat","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Büro / Computer","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Küche / Kühlschrank","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Küche / Geschirrspüler","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Küche / Wassersensor","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"DG / Bad / Heizung","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / Netatmo","type":8,"protocol":"WLan","state":"aktiv"},{"name":"Netatmo Aussenraum","type":8,"protocol":"WLan","state":"aktiv"},{"name":"EG / Büro / Netatmo","type":8,"protocol":"WLan","state":"aktiv"},{"name":"DG / Schlafzimmer / Netatmo","type":8,"protocol":"WLan","state":"aktiv"},{"name":"DG / Schlafzimmer / Klimaanlage","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Flur / Tablet","type":1,"protocol":"ZWave","state":"aktiv"},{"name":"EG / Wohnzimmer / Stehlampe","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"EG / Wohnzimmer / Bar","type":2,"protocol":"Zigbee","state":"aktiv"},{"name":"EG / Küche / Temperatur Kühlschrank","type":2,"protocol":"Zigbee","state":"aktiv"}]
                                          Na egal - Du siehst wie einfach man solche JSONS erstellen kann - das kannst ja dann selbst umsetzen. 😉
                                          • O
                                            Oli @mickym last edited by
                                            @mickym
                                            sorry, hat sich überschnitten, du bist zu schnell für mich, bin gerade am testen 😉
                                            1.5k
                                            node-red
                                            15372
