    3. Einsteigerfragen
    4. "Warn" Logeinträge InfluxDB-Adapter
    • mango1402
      mango1402 @mango1402 last edited by mango1402
      anbei noch das logging für die 24h-Abfrage meiner 2 Kurven:
      2023-03-09 09:17:05.552 - debug: influxdb.1 (461) PING OK
      2023-03-09 09:17:08.856 - debug: influxdb.1 (461) Incoming message getHistory from system.adapter.admin.0
      2023-03-09 09:17:08.856 - debug: influxdb.1 (461) 0_userdata.0.Zaehler.SmartMeter.Zaehlerstand16783498288560.08961875976288836 getHistory message: {"id":"0_userdata.0.Zaehler.SmartMeter.Zaehlerstand","options":{"start":1678263440688,"end":1678349840688,"aggregate":"minmax","from":false,"ack":false,"q":false,"addID":false,"count":300,"instance":"system.adapter.influxdb.1","sessionId":155,"user":"system.user.admin"}}
      2023-03-09 09:17:08.857 - debug: influxdb.1 (461) Query to execute:
      from(bucket: "iobrokerV2")
      |> range(start: 2023-03-08T08:17:20.688Z, stop: 2023-03-09T08:17:20.688Z)
      |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.Zaehlerstand" and contains(value: r._value, set: [true, false]))
      |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
      |> group()
      2023-03-09 09:17:08.947 - debug: influxdb.1 (461) Query to execute: from(bucket: "iobrokerV2")
      |> range(start: 2022-03-08T08:17:20.688Z, stop: 2023-03-08T08:17:20.687Z)
      |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.Zaehlerstand")
      |> group()
      |> sort(columns: ["_time"], desc: true)
      |> limit(n: 1)
      2023-03-09 09:17:14.910 - debug: influxdb.1 (461) Query to execute: from(bucket: "iobrokerV2") |> range(start: 2023-03-08T08:17:20.688Z, stop: 2023-03-09T08:17:20.688Z) |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.Zaehlerstand") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns:["_time"], desc: false)
      2023-03-09 09:17:15.024 - debug: influxdb.1 (461) Query to execute: from(bucket: "iobrokerV2")
      |> range(start: 2023-03-09T08:17:20.689Z)
      |> group()
      |> sort(columns: ["_time"], desc: false)
      |> limit(n: 1)
      2023-03-09 09:17:15.098 - debug: influxdb.1 (461) Send: 600 of: 7632 in: 6242ms
      2023-03-09 09:17:15.238 - debug: influxdb.1 (461) Incoming message getHistory from system.adapter.admin.0
      2023-03-09 09:17:15.238 - debug: influxdb.1 (461) 0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung16783498352380.47825413161981967 getHistory message: {"id":"0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung","options":{"start":1678263440688,"end":1678349840688,"aggregate":"minmax","from":false,"ack":false,"q":false,"addID":false,"count":300,"instance":"system.adapter.influxdb.1","sessionId":155,"user":"system.user.admin"}}
      2023-03-09 09:17:15.240 - debug: influxdb.1 (461) Query to execute:
      |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung" and contains(value: r._value, set: [true, false]))
      |> group()
      2023-03-09 09:17:15.328 - debug: influxdb.1 (461) Query to execute: from(bucket: "iobrokerV2")
      |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung")
      |> group()
      |> limit(n: 1)
      2023-03-09 09:17:20.502 - debug: influxdb.1 (461) Query to execute: from(bucket: "iobrokerV2") |> range(start: 2023-03-08T08:17:20.688Z, stop: 2023-03-09T08:17:20.688Z) |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns:["_time"], desc: false)
      2023-03-09 09:17:20.552 - debug: influxdb.1 (461) PING OK
      2023-03-09 09:17:20.592 - debug: influxdb.1 (461) Query to execute: from(bucket: "iobrokerV2")
      |> group()
      |> limit(n: 1)
      2023-03-09 09:17:20.644 - debug: influxdb.1 (461) Send: 1130 of: 7295 in: 5406ms
      2023-03-09 09:17:35.553 - debug: influxdb.1 (461) PING OK
      nicht verwirren lassen: Instanz '1' vom influxdb-Adapter ist auf die Influx-V2-db verbunden.
      Warum werden eingentlich pro measurement 4 Querys abgeschickt?
      im Vergleich dazu die selben 2 measurements mit den komplett selben Parametern, jedoch aus Influx-V1:
      2023-03-09 09:28:06.403 - debug: influxdb.0 (391) Incoming message getHistory from system.adapter.admin.0
      2023-03-09 09:28:06.403 - debug: influxdb.0 (391) 0_userdata.0.Zaehler.SmartMeter.Zaehlerstand16783504864030.7789047989952527 getHistory message: {"id":"0_userdata.0.Zaehler.SmartMeter.Zaehlerstand","options":{"start":1678264098244,"end":1678350498244,"aggregate":"minmax","from":false,"ack":false,"q":false,"addID":false,"count":300,"instance":"system.adapter.influxdb.0","sessionId":156,"user":"system.user.admin"}}
      2023-03-09 09:28:06.404 - debug: influxdb.0 (391) Query to execute: SELECT value from "0_userdata.0.Zaehler.SmartMeter.Zaehlerstand" WHERE time <= '2023-03-08T08:28:18.244Z' ORDER BY time DESC LIMIT 1;SELECT * from "0_userdata.0.Zaehler.SmartMeter.Zaehlerstand" WHERE time > '2023-03-08T08:28:18.244Z' AND time < '2023-03-09T08:28:18.244Z' ORDER BY time ASC;SELECT value from "0_userdata.0.Zaehler.SmartMeter.Zaehlerstand" WHERE time >= '2023-03-09T08:28:18.244Z' LIMIT 1
      2023-03-09 09:28:06.484 - debug: influxdb.0 (391) Send: 602 of: 7669 in: 81ms
      2023-03-09 09:28:06.935 - debug: influxdb.0 (391) Incoming message getHistory from system.adapter.admin.0
      2023-03-09 09:28:06.936 - debug: influxdb.0 (391) 0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung16783504869360.16072003977466132 getHistory message: {"id":"0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung","options":{"start":1678264098244,"end":1678350498244,"aggregate":"minmax","from":false,"ack":false,"q":false,"addID":false,"count":300,"instance":"system.adapter.influxdb.0","sessionId":156,"user":"system.user.admin"}}
      2023-03-09 09:28:06.937 - debug: influxdb.0 (391) Query to execute: SELECT value from "0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung" WHERE time <= '2023-03-08T08:28:18.244Z' ORDER BY time DESC LIMIT 1;SELECT * from "0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung" WHERE time > '2023-03-08T08:28:18.244Z' AND time < '2023-03-09T08:28:18.244Z' ORDER BY time ASC;SELECT value from "0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung" WHERE time >= '2023-03-09T08:28:18.244Z' LIMIT 1
      2023-03-09 09:28:07.003 - debug: influxdb.0 (391) Send: 1122 of: 7328 in: 67ms
        apollon77 last edited by apollon77
        Am Ende macht der Adapter bei InfluxDB 1 das gleiche.
        4 Queries weil:
        1.) Spezieller check wegen Datentypenkram um zu sehen was für Daten drin stehen weil boolean und Zahlen anders selektiert erden müssen
        2.) Ein Wert VOR dem eigentlichen Zeitraum
        3.) Der Zeitraum
        4.) Ein Wert NACH dem eigentlichen Zeitraum
        2 und 4 sind dazu da das wir für die Grafische Darstellung im zweifel den Wert vor als ersten Wert zum Zeitraumstart einfügen können und am Ende einen ans Ende. Sonst würde der Chart irgendwann erst nach dem startdatum einen ersten Wert haben und vor dem Ende enden (oder den ersten /letzten Wert fälschlicherweise als "der galt auf davor/danach" annehmen und damit verfälschen.
        Wer weiss und rausfindet wie man diese Queries mit fluxQL optimieren kann gern Zeit investieren - genau dafür haben ich aktuell eher keine Zeit und dazu muss man kein Entwickler sein.
        Nehmt die Query aus dem Log prüft was rauskommt und schaut ob es bessere/performantere Queries gibt die das gleiche Ergebnis liefern.
        mango1402 1 Reply Last reply Reply Quote 2
        • mango1402
          mango1402 @apollon77 last edited by
          @apollon77
          So, dies ist der Übeltäter:
          |> group()
          |> limit(n: 1)
          benötigt im Influx-Frontend 5,24s. Ein bisserl lang für genau einen Wert.... (OK, durchsucht ja auch ein ganzes Jahr 😉 )
          Wenn man es so macht, kommt genau das selbe raus, aber in 0,01s:
          |> range(start: 2022-02-08T08:28:18.244Z, stop: 2023-02-08T08:28:18.244Z)
          |> last()
          |> limit(n: 1)
          Abfrage für den ersten Wert nach Bereich ließe sich auch optimieren und damit 0,06s rausholen:
          |> range(start: 2023-02-09T08:17:20.689Z)
          |> first()
          |> limit(n: 1)
          Der Datenabruf selbst schaut in Ordnung aus. Braucht bei 24h lediglich 0,10. Sollte noch im Rahmen sein.
          Ob nun mit pivot und sortieren, oder ohne spielt keine Rolle.
          Was ich noch nicht verstehe ist die erste Abfrage nach bool.
          Bei mir macht es bei der 'Hauptabfrage' keinen Unterschied, welcher Datentyp gespeichert ist.
          Jetzt wär's toll das Ganze in's coding zu bringen, dann kann ich es auch im Echtbetrieb ausprobieren.
          • mango1402
            So, hab nun selbst gebastelt und den Adapter mal angepasst.
            Ergebnis:
            2023-03-11 10:28:33.910 - debug: influxdb.1 (3577787) Incoming message getHistory from system.adapter.admin.0
            2023-03-11 10:28:33.910 - debug: influxdb.1 (3577787) 0_userdata.0.Zaehler.SmartMeter.Zaehlerstand16785269139100.18926732151144776 getHistory message: {"id":"0_userdata.0.Zaehler.SmartMeter.Zaehlerstand","options":{"start":1678440515587,"end":1678526915587,"aggregate":"minmax","from":false,"ack":false,"q":false,"addID":false,"count":300,"instance":"system.adapter.influxdb.1","sessionId":5,"user":"system.user.admin"}}
            2023-03-11 10:28:33.911 - debug: influxdb.1 (3577787) Query to execute:
            |> range(start: 2023-03-10T09:28:35.587Z, stop: 2023-03-11T09:28:35.587Z)
            |> group()
            2023-03-11 10:28:34.012 - debug: influxdb.1 (3577787) Query to execute: from(bucket: "iobrokerV2")
            |> range(start: 2022-03-10T09:28:35.587Z, stop: 2023-03-10T09:28:35.586Z)
            |> last()
            2023-03-11 10:28:34.030 - debug: influxdb.1 (3577787) Query to execute: from(bucket: "iobrokerV2") |> range(start: 2023-03-10T09:28:35.587Z, stop: 2023-03-11T09:28:35.587Z) |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.Zaehlerstand") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns:["_time"], desc: false)
            2023-03-11 10:28:34.181 - debug: influxdb.1 (3577787) Query to execute: from(bucket: "iobrokerV2")
            |> range(start: 2023-03-11T09:28:35.588Z)
            |> first()
            2023-03-11 10:28:34.237 - debug: influxdb.1 (3577787) Send: 602 of: 7557 in: 327ms
            2023-03-11 10:28:34.445 - debug: influxdb.1 (3577787) Incoming message getHistory from system.adapter.admin.0
            2023-03-11 10:28:34.445 - debug: influxdb.1 (3577787) 0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung16785269144450.6908542122702093 getHistory message: {"id":"0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung","options":{"start":1678440515587,"end":1678526915587,"aggregate":"minmax","from":false,"ack":false,"q":false,"addID":false,"count":300,"instance":"system.adapter.influxdb.1","sessionId":5,"user":"system.user.admin"}}
            2023-03-11 10:28:34.446 - debug: influxdb.1 (3577787) Query to execute:
            |> group()
            2023-03-11 10:28:34.542 - debug: influxdb.1 (3577787) Query to execute: from(bucket: "iobrokerV2")
            |> last()
            2023-03-11 10:28:34.556 - debug: influxdb.1 (3577787) Query to execute: from(bucket: "iobrokerV2") |> range(start: 2023-03-10T09:28:35.587Z, stop: 2023-03-11T09:28:35.587Z) |> filter(fn: (r) => r["_measurement"] == "0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung") |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") |> sort(columns:["_time"], desc: false)
            2023-03-11 10:28:34.664 - debug: influxdb.1 (3577787) Query to execute: from(bucket: "iobrokerV2")
            |> first()
            2023-03-11 10:28:34.716 - debug: influxdb.1 (3577787) Send: 1111 of: 7198 in: 271ms
            Ergebnis: laut Debugs Verbesserung der Laufzeit von 11,8s auf 0,8s.
              apollon77 @mango1402 last edited by
              @mango1402 Goil ... machste einen PR? oder wenigstens die Infos bitte ins GitHub Issue.
              DANKE!
                Homoran Global Moderator Administrators @apollon77 last edited by
                @apollon77 passt das dann auch zu history und flot?
                da gibt es einige Threads, dass das zu lange dauert.
                  apollon77 @Homoran last edited by
                  @homoran Ja klar ... wenn die alle sich um InfluxDB drehen dann betrifft der Fix dort alle
                    Homoran Global Moderator Administrators @apollon77 last edited by Homoran
                    @apollon77 sagte in "Warn" Logeinträge InfluxDB-Adapter:
                    eben nicht
                    @homoran sagte in "Warn" Logeinträge InfluxDB-Adapter:
                    z.b. https://forum.iobroker.net/post/960310
                      @homoran Wenn "History" dann ist das durch einen Fix bei Influxdb nicht abgedeckt.
                      Ich kenne Keine Github issues zu performanceproblemen bei history ... 😉 Bei History muss man dinge anders prüfen ... auch hier sollte der Anfang ein Debug log sein und ein Github issue
                      Homoran mango1402 2 Replies Last reply Reply Quote 0
                        ich auch nicht.
                        muss mal die entsprechenden Threads durchflöhen und
                        ein Debug log s
                        versuchen zu bekommen
                        DANKE
                        • mango1402
                          mango1402 @apollon77 last edited by mango1402
                          @apollon77
                          File im GIT angehängt. kenn mich leider nixht so mit PR usw aus.....
                          Hab auch mit float gecheckt - Ja, rennt wieder rund 😀
                          Wobei - es dürft egal sein, wer am Adapter das getHistory() abfragt. Die alle zünden wieder den Turbo.
                          DANKE schon mal vorab für's rasche einhängen und releasen in eine saubere Version 😉
                          lg
                          Manfred
                            @mango1402 sagte in "Warn" Logeinträge InfluxDB-Adapter:
                            Im zweifel einfach: Im Github auf das zu ändernde File gehen, rechts oben auf den Stift klicken, ändern was zu ändern ist und dann unten "propose change" klicken, und auf der nächsten Seite "Create pull request", done 🙂 Aber mit dem File kann ichs auch so vergleichen. Danke
                            mango1402 1 Reply Last reply Reply Quote 0
                            • mango1402
                              @apollon77
                              Danke für die GitHub-Einschulung 😉 Geht ja einfacher als ich gedacht habe.
                              Hab jetzt meinen ersten PR erstellt. Hoffe es passt so.
                              lg
                              manfred
                                @mango1402 Cool, checke die Tage ... (Bin gerade in anderen Themen zu tief drin ... aber bald, DANKE!) und ja GitHub ist ganz einfach 🙂
                                • V
                                  viper4iob last edited by
                                  @mango1402 said in [Linux Shell-Skript] WLAN-Wetterstation:
                                  @viper4iob @ilovegym @Latzi
                                  zum Thema mit der lahmen Influx-V2 Abfrage siehe hier:
                                  https://forum.iobroker.net/post/958290
                                  Es erscheint Licht am Ende des Tunnels 😉
                                  Vielen Dank fürs Analysieren 👍
                                  Somit hat sich bestätigt, dass es am Influx Adapter vom iobroker liegt.
                                  Ich bin gespannt, wann dein Pull Request in einem Release landet.
                                  • V
                                    viper4iob last edited by viper4iob
                                    @mango1402
                                    Ich habe mal deinen Code in der iobroker/node_modules/iobroker.influxdb/main.js eingesetzt und die ECharts gehen wieder deutlich schneller 👍
                                    Wenn man aber bei einem Datenpunkt auf das Zahnrädchen klickt und den Verlauf von z.B. einem Tag anschaut, dauert es im Vergleich zum V1 Modus immer noch mehrere Sekunden bis die Daten angezeigt werden. Da hat sich also zumindest bei mir nichts verbessert.
                                    Hat deine Änderung da keinen Einfluss?
                                    mango1402 Negalein 2 Replies Last reply Reply Quote 0
                                    • mango1402
                                      mango1402 @viper4iob last edited by
                                      @viper4iob
                                      also bei mir ist auch bei dem 'Zahnrädchen' eine deutliche Verbesserung wahrnehmbar.
                                      Ich werwende aber diese Art von Darstellung nicht - war schon mit V1 ein Lotteriespiel ob und wann man überhaupt eine Anzeige bekommt.....
                                      • V
                                        viper4iob @mango1402 last edited by
                                        @mango1402
                                        Das sieht auch gar nicht so richtig danach aus, dass eine Abfrage an Influx so lange braucht, denn die Sekunden, in denen es lädt, steht das Datum auf 01.01.1970.
                                        Sobald er auf das richtige Zeitfenster springt, sind die Daten sofort da.
                                        Im V1 Modus zeigt er gleich den richtigen Zeitraum an, ist also eventuell noch ein anderer Fehler an dieser Stelle.
                                        Aber ich nutze das auch nicht wirklich, wichtiger ist, dass die ECharts und eventuell andere Adpater die Daten schneller laden können.
                                        • Negalein
                                          Negalein Global Moderator @viper4iob last edited by
                                          @viper4iob @mango1402
                                          ich habe eure Beiträge hierher verschoben. Passen besser hier als zur Wetterstation 😉
                                          • mango1402
                                            @viper4iob
                                            das 'Zahnrädchen' möchte scheinbar immer alle daten ab 2000 bis jetzt:
                                            2023-03-24 12:49:39.344 - debug: influxdb.0 (489) 0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung16796585793440.6297946848561795 getHistory message: {"id":"0_userdata.0.Zaehler.SmartMeter.aktuelleLeistung","options":{"instance":"influxdb.0","start":946681200000,"end":1679658580637,"limit":1,"from":false,"ack":false,"q":false,"addID":false,"aggregate":"none","user":"system.user.admin"}}
                                            946681200000 = Fri Dec 31 1999 23:00:00 GMT+0000
                                            Hat aber nix mit dem Influx-Adapter zu tun. Der macht ja nur was ihm 'aufgetragen' wird.
                                            Ich glaub das geht hier in Richtung 'admin-Adapter'.....
                                            3428
