    5. Blockly DP wird nicht false
      mrfloppy last edited by
      Frage an die Profis. Mein DP wird nach dem Schliessen der Balkontüre in der Nacht nicht wieder false.
      Wo ist da mein Denkfehler?
      Habe schon steuere Dp , aktualisiere DP versucht. Keine Änderung.
      LG
      <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="6NTf}*4Hs@H?k/54~dHi" x="-537" y="-1486">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="3"></mutation>
        <value name="OID0">
          <shadow type="field_oid" id="eIwD5nRX(N$RuC,J1uKe">
            <field name="oid">hm-rpc.1.NEQ0119621.1.MOTION</field>
        <value name="OID1">
          <shadow type="field_oid" id=".,b50y=^Z^X,#iPP9XI1">
            <field name="oid">hm-rpc.1.MEQ0222392.1.STATE</field>
        <value name="OID2">
          <shadow type="field_oid" id="RvLxvwPtZFz~hQ[$wUgM">
            <field name="oid">hm-rpc.1.NEQ1762489.1.STATE</field>
          <block type="controls_if" id="uRT!pK$k2YLKLTL2E2Hk">
              <block type="logic_compare" id="8Bsb2zF`RPVD`n]2{O/*">
                <field name="OP">EQ</field>
                  <block type="get_value" id="UC$c*xp:9JZ`?GZ^xF#s">
                    <field name="OID">javascript.0.Nachtcheck</field>
                  <block type="logic_boolean" id="L36,g}f=*k(NZtL*{X+b">
              <block type="controls_if" id="cjkfgJXx(/SD;HLnc/T=">
                  <block type="logic_operation" id="+74C?;/MiXQbGFjibW{R" inline="false">
                    <field name="OP">OR</field>
                      <block type="logic_compare" id=",0jkdg+;{Xx)er#dgePH">
                          <block type="get_value" id="o-6[QWD7WRQ0D$L-74W#">
                            <field name="OID">hm-rpc.1.MEQ0222392.1.STATE</field>
                          <block type="math_number" id="jk0)!_-0!GEsS@1ki21U">
                            <field name="NUM">2</field>
                      <block type="logic_compare" id="Mzd=:CB:=k-?V!k_z%}=">
                          <block type="get_value" id="Izs51IVntc~qiFL;}Xj:">
                            <field name="OID">hm-rpc.1.NEQ1762489.1.STATE</field>
                          <block type="math_number" id="D@K[0+m1t)nE~x;BH{C}">
                  <block type="comment" id="{$jUW$B*~U#rCS9bD36G">
                    <field name="COMMENT">bei FK1 oder FK2 open</field>
                      <block type="comment" id="[=:SR$6dtmje}-%N@Sh#">
                        <field name="COMMENT">Setze DP Dauerlicht true</field>
                          <block type="update" id="yCM@^=D9~ZRV[!+2=:n,">
                            <field name="OID">javascript.0.Eigene_Datenpunkte.Dauerlicht_Terasse</field>
                              <block type="logic_boolean" id="f,aU^.mjf~.r|/kQ.re*">
                <value name="IF1">
                  <block type="logic_operation" id="6,7HRyKOS/DjF*HQ0968" inline="false">
                    <field name="OP">AND</field>
                      <block type="logic_compare" id="$XviPL9aQBAAww7y6Wej">
                        <field name="OP">NEQ</field>
                          <block type="get_value" id="oLuvD`aFvy^ka.Bn)6x3">
                          <block type="math_number" id="s;=98TYjN]8E1%^U[XS?">
                      <block type="logic_compare" id=":W(|C,myu[qDJmgMa*i%">
                          <block type="get_value" id="~|(tyg]u=FY7/z`E7XZR">
                          <block type="math_number" id="7bgj@Ohii86jX}_YqamJ">
                <statement name="DO1">
                  <block type="comment" id="$}9I-]PmA/J@)WV$xQ~0">
                    <field name="COMMENT">bei FK1 und FK2 tilted/closed</field>
                      <block type="comment" id="Pb,:nFQVkO2A,GjrmnG#">
                        <field name="COMMENT">Setze DP Dauerlicht false</field>
                          <block type="update" id="sU$:xq~AiH?%97ynl(mK">
                              <block type="logic_boolean" id="F6q6~0mBIvpMIz).{Z^x">
            <value name="IF1">
              <block type="logic_compare" id="CqZNY:*(vrxga1.RZh]K">
                  <block type="get_value" id=",GLaSEdsWaaZ/}{a.7v`">
                  <block type="logic_boolean" id="U}YsVIA3rugxIG5vycnR">
              <block type="controls_if" id="RNJfa(5,`/10kucC8^O$">
                <mutation elseif="4"></mutation>
                  <block type="logic_compare" id="!fa8e;lcDVeSgu444uN:">
                      <block type="get_value" id="h?2)u$Z(Ul:#`Y2req+;">
                      <block type="logic_boolean" id="C^FV.Vm=RU-M8oaiuale">
                  <block type="comment" id="QNns8,KAgSzPSwrKzC#Q">
                    <field name="COMMENT">Wenn Balkon schon offen und es nacht wird, dann licht ein!</field>
                      <block type="timeouts_cleartimeout" id="`4AC!O6bz!RcP|ypC,/F">
                          <block type="timeouts_cleartimeout" id="rE}=eBf7)[h|cbcYdQ6T">
                              <block type="comment" id="{6z_VJ(#^wQBsivl@U]$">
                                <field name="COMMENT">Schalte Gartenhauslicht Außen ein</field>
                                  <block type="control" id="N-ZLT,NL}2Ub.{N=Uff3">
                                    <field name="OID">hm-rpc.1.LEQ0883156.2.STATE</field>
                                      <block type="logic_boolean" id="V%OYv|9S@KF~R8,=}{2@">
                <value name="IF1">
                  <block type="logic_operation" id="5$F85NvuKZ/3C2;a3L/^" inline="false">
                      <block type="logic_compare" id="$ZZElYox:SJ:6cHka`Mz">
                          <block type="get_value" id="5qS}:1)CnTEjhO/Ms_(n">
                          <block type="math_number" id="SkAZ?k-p(,sRaw3G%FgU">
                      <block type="logic_compare" id="77?Dt?EKASwwjgdxM$t1">
                          <block type="get_value" id="R[Q2AgOV,_?s(!Xp]fNL">
                          <block type="math_number" id=";9i.m],uM}6S(sw+8(aR">
                  <block type="comment" id="Y@_xNDiIE}1)f-0+2ky]">
                      <block type="comment" id="}67cND.sh]o=^FXmVgz(">
                          <block type="timeouts_cleartimeout" id="}j7Xh?wjBEGrIhM(A$p?">
                              <block type="control" id="F7Ud0fjI2kIZsdFu`/gW">
                                  <block type="logic_boolean" id="-EV:v#nl@UrIy??TX6n{">
                                  <block type="comment" id="%uNHJV19zu*GN?Vk21;d">
                                      <block type="update" id="[7?Q*SgZg7Heix$|1c21">
                                          <block type="logic_boolean" id="R]*CggPgzhOmv.!*.n4M">
                <value name="IF2">
                  <block type="logic_operation" id="q(+D:$Ep/=ie?JSJ+bl~" inline="false">
                      <block type="logic_compare" id="#/UV7^GONs$a.3TcsZM`">
                          <block type="get_value" id="~m:_1yMkGRe)G.:9:J;?">
                          <block type="math_number" id="6y:5oEqf(jv~@3~,2eE!">
                      <block type="logic_compare" id="d$UqoQyMrha.5cAO3uj%">
                          <block type="get_value" id="~p1bi#avd+N@-bnd3;UV">
                          <block type="math_number" id="jTL[JUnHkgsj}}X^QyIN">
                <statement name="DO2">
                  <block type="comment" id=")iHh5(),jsYvNy,#Vbt*">
                      <block type="comment" id="ll:{gqh8Afp[luJIx/n@">
                        <field name="COMMENT">Schalte Gartenhauslicht nach 20 Sek Außen aus</field>
                          <block type="timeouts_cleartimeout" id="qh[o63[nte|ibzWG;pUr">
                              <block type="timeouts_settimeout" id="8~j6HTMCbO~%:K3nWq/[">
                                <field name="DELAY">20</field>
                                  <block type="control" id="rp,Ey;MUA,^=!h$Q6=e+">
                                      <block type="logic_boolean" id="}tSWhm`+71Hx2U@daD;w">
                                  <block type="comment" id="*F@okqD$EIxqiPK$O+!Y">
                                      <block type="update" id="6D~ShE^f*tDB4M4NmidG">
                                          <block type="logic_boolean" id="2V69+SEH{h6HZ3+tigi(">
                <value name="IF3">
                  <block type="logic_operation" id="=S+/tlbeA)dtrvWMpl|N" inline="false">
                      <block type="logic_compare" id="%7y$jh_`6UJItoxn6g-{">
                          <block type="get_value" id="UTYa!=1!|;gBHUYc_Xwv">
                            <field name="OID">hm-rpc.1.NEQ0119621.1.MOTION</field>
                          <block type="logic_boolean" id="^.m#/5_9|0NH|^,4xD:v">
                      <block type="logic_compare" id=":{(X]#V`xBIYvY.OsHIu">
                          <block type="get_value" id="Xi/Q}N}7oxt]!%?Q;DK6">
                          <block type="logic_boolean" id="Y}kNvp,BTWQ/+8,OxOV`">
                <statement name="DO3">
                  <block type="comment" id="d8@C6pTb}`qmx4ZR;wud">
                    <field name="COMMENT">Wenn DP Dauerlicht false und BWM Motion</field>
                      <block type="timeouts_cleartimeout" id="ljZ:Ie;l^u==DRCoC1Tu">
                          <block type="control" id="dar9a6aldb%1aMo#8nUS">
                              <block type="logic_boolean" id="tq^PKoxJC4l]jgh;Ai{F">
                <value name="IF4">
                  <block type="logic_operation" id="0R)|FS1}D0e@7E`|nwy}" inline="false">
                      <block type="logic_compare" id="%l|T`Pp={*-*o0go1j~F">
                          <block type="get_value" id="Jqk`7M24Ov0#)~fQjI8O">
                          <block type="logic_boolean" id="(9`:G9TKc;qyg$`P=~Eq">
                      <block type="logic_compare" id="vONC+0qq,NGgXo#XLm~F">
                          <block type="get_value" id="cy8#n66?G^yL%Zgv:48^">
                          <block type="logic_boolean" id="|ssj[.yUtcqEv)5cd4H.">
                <statement name="DO4">
                  <block type="comment" id=":N[HYNM0i1A95%snxunb">
                    <field name="COMMENT">Wenn DP Dauerlicht false und BWM noMotion</field>
                      <block type="timeouts_cleartimeout" id="s+Mih*GxWeskKP]beb1Q">
                          <block type="timeouts_settimeout" id="/IPEkNlUNXy#)W5YJDx;">
                              <block type="control" id=")q[N?]n9}|v:(F.U)iS?">
                                  <block type="logic_boolean" id="lv=A5~;(l$74J7c0UhK_">
      David G. DJMarc75 2 Replies Last reply Reply Quote 0
      • David G.
        David G. @mrfloppy last edited by
        @mrfloppy
        Am besten einen Screenshot posten.
        Dann muss man nicht alles importieren...
        • DJMarc75
          DJMarc75 @mrfloppy last edited by
          @mrfloppy sagte in Blockly DP wird nicht false:
          wie auch schon @David-G schrieb, bitte mal als Screenshot posten...
          (Wird bestimmt schwierig alles auf eine Seite zu bekommen bei den unnötigen Blöcken 😉 )
            @djmarc75 said in Blockly DP wird nicht false:
            Bin noch nicht so der Profi und am lernen.
            LG
            DJMarc75 paul53 3 Replies Last reply Reply Quote 0
            • DJMarc75
              @mrfloppy jetzt erkläre nochmal bitte deutlich was Du alles hast und was Dein Ziel ist....
              Mit dem Blockly und Deinen mauen Erläuterungen kommen wir da nicht viel weiter...
                paul53 @mrfloppy last edited by
                @mrfloppy
                Wenn das Licht bei offener Balkontür einschalten soll, wenn es Nacht wird, muss auf den Nacht-Datenpunkt getriggert werden.
                  paul53 @mrfloppy last edited by paul53
                  @mrfloppy
                  Für den BWM verwende besser einen eigenen Trigger:
                  Der Teil für das Dauerlicht lässt sich vereinfachen:
                    mrfloppy @DJMarc75 last edited by
                    @djmarc75
                    Vorhanden: 2x Fensterkontakt -3State und 1x Bewegungsmelder. Alles Homematic.
                    1. Wenn es Abend ist und wir eine der Balkontüren öffnen, soll das Außenlicht angehen. Wenn alle Türen wieder zu dann ausgehen.
                    2. Wenn die Türen zu sind, soll aber trotzdem mittels Bewegungsmelder das Licht im Garten angehen wenn man von der Gartenseite rein geht.
                    3. Wenn am Tag schon eine der Balkontüren offen ist, dann soll wenn es Nacht wird das Außenlicht angehen.
                    @paul53 said in Blockly DP wird nicht false:
                    .... wenn es Nacht wird, muss auf den Nacht-Datenpunkt getriggert werden.
                    Heist das, es würde reichen wenn ich das am Anfang als 4.te ObjektID hinzufüge?
                    LG
                      @mrfloppy sagte: es würde reichen wenn ich das am Anfang als 4.te ObjektID hinzufüge?
                      Besser so wie hier gezeigt.
