    4. JavaScript
    5. Roborock Adapter tester gesucht
    • David G.
      David G. last edited by
      Hab eben mal die 0.1.4-beta.3 (2023-03-10) installiert.
      Beim Start erscheint im Log:
      roborock.0
      2023-03-10 23:47:11.414	warn	Unknown block type! Please report this to the developer. Block type is:1024
      roborock.0
      2023-03-10 23:47:11.413	warn	Unknown block type! Please report this to the developer. Block type is:26
      roborock.0
      2023-03-10 23:47:11.413	warn	Unknown block type! Please report this to the developer. Block type is:25
      roborock.0
      2023-03-10 23:47:11.412	warn	Unknown block type! Please report this to the developer. Block type is:24
      roborock.0
      2023-03-10 23:47:11.411	warn	Unknown block type! Please report this to the developer. Block type is:22
      roborock.0
      2023-03-10 23:47:11.410	warn	Unknown block type! Please report this to the developer. Block type is:19
      roborock.0
      2023-03-10 23:47:11.382	warn	Unknown block type! Please report this to the developer. Block type is:16
      roborock.0
      2023-03-10 23:47:11.382	warn	Unknown block type! Please report this to the developer. Block type is:15
      roborock.0
      2023-03-10 23:47:11.381	warn	Unknown block type! Please report this to the developer. Block type is:12
      roborock.0
      2023-03-10 23:47:11.375	warn	Unknown block type! Please report this to the developer. Block type is:21
      copystring 1 Reply Last reply Reply Quote 0
      • copystring
        copystring @David G. last edited by copystring
        @david-g said in Roborock Adapter tester gesucht:
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        Das habe ich eingebaut da die Karte noch mehr kann als aktuell. Bist du so nett und erstellst auf GitHub ein issue mit dem Log und postest dann dort auch mapdata unter den Objekten vom roborock Adapter? Dann kann ich mir das angucken und die fehlenden Blöcke entsprechend einbauen.
        • David G.
          David G. @copystring last edited by David G.
          @copystring
          Ist unter
          https://github.com/copystring/ioBroker.roborock/issues/108
          erstellt.
          Leider hat mapdata zu viele Zeichen und finde keine Option zum Dateiupload.
          Sende dir die Datei später hier. Am Smartphone stürzt jeder Texteditor ab. Scheinbar was zu lang alles.....
          EDIT
          Hier ist der Inhalt von mapdata:
          dp_maptata.txt
          ipod86 created this issue in copystring/ioBroker.roborock
          closed Fehlermeldungen beim Adapterstart #108
            Daniel1337 last edited by
            Habe den Adapter installiert.
            Bei mir wird die Karte nicht angezeigt. Bleibt einfach schwarz muss man was weiteres beachten?
            Desweiteren wenn man nur die IP eingibt plus Port kommt cannot Get /...
            • wendy2702
              wendy2702 @Daniel1337 last edited by
              @daniel1337 sagte in Roborock Adapter tester gesucht:
              Gibt ne Checkbox zum aktivieren
              Wo gibt man das denn ein?
                Daniel1337 @wendy2702 last edited by Daniel1337
                @wendy2702
                Ja das habe ich aktiviert. Ohne wird der Webserver erst gar nicht gestartet. Ich bekomme aber keine Karte angezeigt...
                Getestet Chrome am Handy..
                Siehe Bild
                • wendy2702
                  @daniel1337 OK.
                  Das da jetzt ein Webserver mit läuft lese ich gerade erst. Muss mal schauen ob/ wie das funktioniert.
                  • copystring
                    copystring @Daniel1337 last edited by
                    @daniel1337 said in Roborock Adapter tester gesucht:
                    @wendy2702
                    Siehe Bild
                    Da sind mit Sicherheit Fehler im Protokoll.
                      Daniel1337 @copystring last edited by Daniel1337
                      @copystring Leider nein. Keinerleifehler im Iobroker Protokoll... Hab auch extra den Roborock mal verfahren lassen keine Änderung... vll ein Bug mit den Rechten in IObroker / System?
                      Nachtrag: Wenn ich fahre zum Dock mittels des Buttons mache auf der Webpage erscheint ein Fehler: vorher nicht (Der Robrock ist dann zum Dock zurück)
                      Nachtrag2: Ich habe das Loglevel auf silly umgestellt vom Adapter und bekomme nun mehr angezeigt. Dort ist vermerkt..
                      Started map updater on robot: 4EYxx
                      Map updater on robot: 4EYxx already running!
                      Update map
                      Stopped map updater on robot: 4EYxx
                      anzeigen tut er trotzdem nicht.
                      -> Auch gerade auf PC getestet
                      -> Ebenfalls im Inkognito Modus nicht
                      -> Port wechsel bringt auch nichts
                      -> Floors werden angezeigt in den DP
                      • copystring
                        OK. Das ist aber kein Fehler. Der Roboter sucht nur seine Position. In der Zeit kann logischerweise die Karte nicht abgerufen werden, da er ja gar nicht weiß auf welcher Karte er sich befindet.
                        Lass ihn mal laufen, bis er weiß, wo er ist. Wenn die Karte dann in der App zu sehen ist, ist sie auch im Adapter zu sehen.
                        Falls nicht, schau mal bitte nach, ob unter den Objekten vom Adapter im Ordner Map alles korrekt ausgefüllt wird. Dort sind drei Datenpunkte zu sehen. Keins davon sollte null sein.
                          @copystring Karte wird in der Handyapp korrekt angezeigt.
                          Die Datenpunkte von map sind leider leer
                          Locating Fehler war nur weil ich mit Pin und go mittels Handy zu einem Punkt gefahren bin und dann nachhause zum Dock mittels Webserver ("Dock")
                          • copystring
                            Dann brauche ich ein vollständiges debug log.
                              @copystring gerne. wohin kann ich es dir schicken?
                              • copystring
                                Einfach hier als Datei hochladen.
                                  "Log entfernt"
                                  • copystring
                                    @daniel1337 Ach so. Du bist auf noch auf 0.1.4-beta.3? Installier mal bitte 0.1.4-beta.5
                                      @copystring ich konnte das Problem lösen!
                                      Es musste initial einmal in der App auf Reinigen klicken...
                                      • copystring
                                        @daniel1337 Prima. Trotzdem bitte 0.1.4-beta.5 installieren. 0.1.4-beta.3 hat Fehler beim Erstellen der Karte.
                                        Die Warnungen sind erstmal normal. Ich kümmere irgendwann darum. Aktuell will ich nur Bugs lösen.
                                          @copystring Alles klar danke der schnellen Rückmeldung!
                                            leuchtturm last edited by
                                            Darf ich hier mal ein Lob an @copystring aussprechen:
                                            Grandiose Arbeit, der Adapter funktioniert schon wirklich gut 🙂
                                            1 Reply Last reply Reply Quote 5
                                            766
                                            242824
