    4. Huawei Sun2000 & ioBroker via JS script funktioniert
    • Alex Warkentin
      Alex Warkentin @juggi1962 last edited by
      @juggi1962 Poste mal die Logs, wenn der Fehler auftritt
      Hier ist das Script, was ich für mich angepasst habe. Achtung! Ich habe die Batterie und andere für mich uninteressante Sachen rausgeschmissen und die Namen von Variablen und Funktionen angepasst. Für die Neuverbindung nach Verbindungsabbruch brauchst du die Zeilen 18 - 27 , 107-122 und 235 -237
      // License: Beerware! Do what ever you like with this, but I'm not liable for anything that you do with it.
      // If you like this code, feel free to buy me a beer ...
      // Have fun with it! der Kachel
      // @ts-ignore
      var modbusRTU = require("modbus-serial");
      var client = new modbusRTU();
      var modbusErrorMessages = [
          "Unknown error",
          "Illegal function (device does not support this read/write function)",
          "Illegal data address (register not supported by device)",
          "Illegal data value (value cannot be written to this register)",
          "Slave device failure (device reports internal error)",
          "Acknowledge (requested data will be available later)",
          "Slave device busy (retry request again later)"
      // Enter your inverter modbus IP and port here:
      const modbusHost = "000.000.000.000";
      const modbusPort = 502;
      // Enter the Modbus-IDs of your Sun2000 inverters here:
      const modbusID = [1];
      // On which Modbus-ID can we reach the power meter? (via Sun2000!)
      const powerMeterID = 0;
      // Connect to modbus client
      ConnectModbus();
      // These register spaces need to be read:
      const registerSpacesToReadContinuously = [[37100, 114], [32000, 116]];
      var registerSpacesToReadContinuouslyPtr = 0;
      var globalDataBuffer = new Array(1);
      globalDataBuffer[0] = new Array(50000); // not optimized....
      // Some helper functions:
      function ReadUnsignedInt16(array) {
          var value = array[0];
          return value;
      function ReadUnsignedInt32(array) {
          var value = array[0] * 256 * 256 + array[1];
          return value;
      function ReadSignedInt16(array) {
          var value = 0;
          if (array[0] > 32767)
              value = array[0] - 65535;
          else
              value = array[0];
          return value;
      function ReadSignedInt32(array) {
          var value = 0;
          for (var i = 0; i < 2; i++) {
              value = (value << 16) | array[i];
          return value;
      function GetU16(dataarray, index) {
          var value = ReadUnsignedInt16(dataarray.slice(index, index+1));
          return value;
      function GetU32(dataarray, index) {
          var value = ReadUnsignedInt32(dataarray.slice(index, index+2));
          return value;
      function GetI16(dataarray, index) {
          var value = ReadSignedInt16(dataarray.slice(index, index+1));
          return value;
      function GetI32(dataarray, index) {
          var value = ReadSignedInt32(dataarray.slice(index, index+2));
          return value;
      function GetString(dataarray, index, length) {
          var shortarray = dataarray.slice(index, index+length);
          var bytearray = [];
          for(var i = 0; i < length; i++) {
              bytearray.push(dataarray[index+i] >> 8);
              bytearray.push(dataarray[index+i] & 0xff);
          var value =  String.fromCharCode.apply(null, bytearray);
          return value;
      function GetZeroTerminatedString(dataarray, index, length) {
          var bytearray = [];
          var value2 = new String(value).trim();
          return value2;
      // Funktion zum Herstellen einer Modbus-Verbindung
      function ConnectModbus() {
          console.log("Init connection to: " + modbusHost +":" + modbusPort);
          // set requests parameters
          client.setTimeout (10000);
          // try to connect
          client.connectTCP (modbusHost, { port: modbusPort })
              .then(function()
                  console.log("Connected, wait for reading...");
              .catch(function(e)
                  console.log(e);
      // Funktion zum Anlegen und Beschreiben eines Datenpunkts
      function ForceSetState(objectname, value, options) {
          if(!existsState("javascript.0." + objectname))      createState(objectname, value, options);
          else                                                setState(objectname, value);
      // Functions to map registers into ioBreaker objects:
      function ProcessPowerMeterStatus() {
          ForceSetState("Solarpower.Huawei.Meter.Status",                     GetU16(globalDataBuffer[powerMeterID], 37100),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL1",                  GetI32(globalDataBuffer[powerMeterID], 37101) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL2",                  GetI32(globalDataBuffer[powerMeterID], 37103) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL3",                  GetI32(globalDataBuffer[powerMeterID], 37105) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.CurrentL1",                  GetI32(globalDataBuffer[powerMeterID], 37107) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Meter.CurrentL2",                  GetI32(globalDataBuffer[powerMeterID], 37109) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Meter.CurrentL3",                  GetI32(globalDataBuffer[powerMeterID], 37111) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePower",                GetI32(globalDataBuffer[powerMeterID], 37113) / 1,      {name: "", unit: "W"});
          ForceSetState("Solarpower.Huawei.Meter.ReactivePower",              GetI32(globalDataBuffer[powerMeterID], 37115) / 1,      {name: "", unit: "Var"});
          ForceSetState("Solarpower.Huawei.Meter.PowerFactor",                GetI16(globalDataBuffer[powerMeterID], 37117) / 1000,   {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Meter.GridFrequency",              GetI16(globalDataBuffer[powerMeterID], 37118) / 100,    {name: "", unit: "Hz"});
          ForceSetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",       GetI32(globalDataBuffer[powerMeterID], 37119) / 100,    {name: "", unit: "kWh"});
          ForceSetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",        GetI32(globalDataBuffer[powerMeterID], 37121) / 100,    {name: "", unit: "kWh"});
          ForceSetState("Solarpower.Huawei.Meter.AccumulatedReactivePower",   GetI32(globalDataBuffer[powerMeterID], 37123) / 100,    {name: "", unit: "kVarh"});
          //ForceSetState("Solarpower.Huawei.Meter.MeterType",                  GetU16(globalDataBuffer[powerMeterID], 37125),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL1-L2",               GetI32(globalDataBuffer[powerMeterID], 37126) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL2-L3",               GetI32(globalDataBuffer[powerMeterID], 37128) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.VoltageL3-L1",               GetI32(globalDataBuffer[powerMeterID], 37130) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePowerL1",              GetI32(globalDataBuffer[powerMeterID], 37132) / 1,      {name: "", unit: "W"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePowerL2",              GetI32(globalDataBuffer[powerMeterID], 37134) / 1,      {name: "", unit: "W"});
          ForceSetState("Solarpower.Huawei.Meter.ActivePowerL3",              GetI32(globalDataBuffer[powerMeterID], 37136) / 1,      {name: "", unit: "W"});
          //ForceSetState("Solarpower.Huawei.Meter.MeterModel",                 GetU16(globalDataBuffer[powerMeterID], 37138),          {name: "", unit: ""});
      function ProcessInverterStatus(id) {
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".State1",                   GetU16(globalDataBuffer[id-1], 32000),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".State2",                   GetU16(globalDataBuffer[id-1], 32002),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".State3",                   GetU32(globalDataBuffer[id-1], 32003),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm1",                   GetU16(globalDataBuffer[id-1], 32008),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm2",                   GetU16(globalDataBuffer[id-1], 32009),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm3",                   GetU16(globalDataBuffer[id-1], 32010),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",         GetI16(globalDataBuffer[id-1], 32016) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",         GetI16(globalDataBuffer[id-1], 32017) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",         GetI16(globalDataBuffer[id-1], 32018) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",         GetI16(globalDataBuffer[id-1], 32019) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Voltage",         GetI16(globalDataBuffer[id-1], 32020) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Current",         GetI16(globalDataBuffer[id-1], 32021) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Voltage",         GetI16(globalDataBuffer[id-1], 32022) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Current",         GetI16(globalDataBuffer[id-1], 32023) / 100,    {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".InputPower",               GetI32(globalDataBuffer[id-1], 32064) / 1000,   {name: "", unit: "kW"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",       GetU16(globalDataBuffer[id-1], 32066) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",       GetU16(globalDataBuffer[id-1], 32067) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",       GetU16(globalDataBuffer[id-1], 32068) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",          GetU16(globalDataBuffer[id-1], 32069) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",          GetU16(globalDataBuffer[id-1], 32070) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",          GetU16(globalDataBuffer[id-1], 32071) / 10,     {name: "", unit: "V"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",          GetI32(globalDataBuffer[id-1], 32072) / 1000,   {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",          GetI32(globalDataBuffer[id-1], 32074) / 1000,   {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",          GetI32(globalDataBuffer[id-1], 32076) / 1000,   {name: "", unit: "A"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",       GetI32(globalDataBuffer[id-1], 32078) / 1000,   {name: "", unit: "kW"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",              GetI32(globalDataBuffer[id-1], 32080) / 1000,   {name: "", unit: "kW"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",            GetI32(globalDataBuffer[id-1], 32082) / 1000,   {name: "", unit: "kVar"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",              GetI16(globalDataBuffer[id-1], 32084) / 1000,   {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",            GetU16(globalDataBuffer[id-1], 32085) / 100,    {name: "", unit: "Hz"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",               GetU16(globalDataBuffer[id-1], 32086) / 100,    {name: "", unit: "%"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",      GetI16(globalDataBuffer[id-1], 32087) / 10,     {name: "", unit: "°C"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",     GetU16(globalDataBuffer[id-1], 32088) / 1000,   {name: "", unit: "MOhm"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",             GetU16(globalDataBuffer[id-1], 32089),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",                GetU16(globalDataBuffer[id-1], 32090),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",              String(new Date(GetU32(globalDataBuffer[id-1], 32091)*1000)),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",             String(new Date(GetU32(globalDataBuffer[id-1], 32093)*1000)),          {name: "", unit: ""});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",   GetU32(globalDataBuffer[id-1], 32106),          {name: "", unit: "kWh"});
          ForceSetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",         GetU32(globalDataBuffer[id-1], 32114),          {name: "", unit: "kWh"});
      function ReadRegisterSpace(id, address, length) {
          client.setID(modbusID[id-1]);
          client.readHoldingRegisters(address, length, function(err, data) {
              if (err) {
                  console.warn("Error received reading address " + address + " from id: " + modbusID[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
              else
                  console.debug("Read data from id/address " + modbusID[id-1] + "/" + address + "\nData is: " + data.data);
                      globalDataBuffer[id-1][address+i] = data.data[i];
      function ProcessData() {
          //console.log("Processing new data...");
          for(var i = 1; i <= modbusID.length; i++) {
              //ProcessDeviceInfo(i);
              ProcessInverterStatus(i);
              //processBattery(i);
              //processInverterPowerAdjustments(i);
              //processOptimizers(i);
          ProcessPowerMeterStatus();
          //console.log("Processing done!");
      // This is the main function triggering a  read via modbus-tcp every two seconds.
      // Processing of data is triggered as soon as one complete set of registers is copied.
      var triggerprocessing = 0;
      var currentinverter = 1;
      setInterval(function() {
              if (!client.isOpen){
                  ConnectModbus();
              if(triggerprocessing == 1) {
              ProcessData();
          //console.log("Triggering read of inverter " + currentinverter + " at address " + registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0] + " with length " +  registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
          ReadRegisterSpace(currentinverter, registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0], registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
          registerSpacesToReadContinuouslyPtr++;
          if(registerSpacesToReadContinuouslyPtr >= registerSpacesToReadContinuously.length) {
              currentinverter++
              if(currentinverter > modbusID.length){
                  triggerprocessing = 1;
      }, 3000);
      J H 3 Replies Last reply Reply Quote 0
        juggi1962 @Alex Warkentin last edited by
        @alex-warkentin sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
        // @ts-ignore
            "Unknown error",
        ConnectModbus();
            return value;
            return value;
            var value = 0;
            else
                value = array[0];
            return value;
            var value = 0;
            return value;
            return value;
            return value;
            return value;
            return value;
            var bytearray = [];
            return value;
            var bytearray = [];
            return value2;
            // try to connect
                .then(function()
                .catch(function(e)
                    console.log(e);
                if (err) {
                else
                    ConnectModbus();
                ProcessData();
                currentinverter++
        }, 3000);
        Super Danke.
        Hab eh keine Batterie. Werde es gleich testen.
        Gruß Jürgen
          juggi1962 @juggi1962 last edited by
          @juggi1962 sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
          // @ts-ignore
              "Unknown error",
          ConnectModbus();
              return value;
              return value;
              var value = 0;
              else
                  value = array[0];
              return value;
              var value = 0;
              return value;
              return value;
              return value;
              return value;
              return value;
              var bytearray = [];
              return value;
              var bytearray = [];
              return value2;
              // try to connect
                  .then(function()
                  .catch(function(e)
                      console.log(e);
                  if (err) {
                  else
                      ConnectModbus();
                  ProcessData();
                  currentinverter++
          }, 3000);
          Super Danke.
          Gruß Jürgen
          Guten Morgen soweit läuft es mal, aber kann es sein, dass bei
          Solarpower Huawei Inverter 1 AccomulatedEnergyYield und
          Solarpower.Huawei.Inverter.1.DailyEnergyYield
          das Komma fehlt, denn der Tägliche Ertrag wäre schön aber nicht war 🙂
          kann man das irgend wie ändern?
          Alex Warkentin 1 Reply Last reply Reply Quote 0
            // @ts-ignore
                "Unknown error",
            ConnectModbus();
                return value;
                return value;
                var value = 0;
                else
                    value = array[0];
                return value;
                var value = 0;
                return value;
                return value;
                return value;
                return value;
                return value;
                var bytearray = [];
                return value;
                var bytearray = [];
                return value2;
                // try to connect
                    .then(function()
                    .catch(function(e)
                        console.log(e);
                    if (err) {
                    else
                        ConnectModbus();
                    ProcessData();
                    currentinverter++
            }, 3000);
            So der Fehler ist wieder da, die Freude hat nicht lange angehalten.
            Hier die Logs vom Fehler, nach Neustart des Skrips läufts wieder 😞
            javascript.0
            2023-03-06 10:27:26.845	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:23.846	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 37100 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:20.841	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:17.842	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 37100 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:14.840	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:11.842	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 37100 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:08.839	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:05.841	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 37100 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:27:02.838	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:26:59.839	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 37100 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:26:56.837	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
            javascript.0
            2023-03-06 10:26:53.840	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 37100 from id: 1 with error: undefined
            • Alex Warkentin
              @juggi1962 said in Huawei Sun2000 & ioBroker via JS script funktioniert:
              // @ts-ignore
                  "Unknown error",
              ConnectModbus();
                  return value;
                  return value;
                  var value = 0;
                  else
                      value = array[0];
                  return value;
                  var value = 0;
                  return value;
                  return value;
                  return value;
                  return value;
                  return value;
                  var bytearray = [];
                  return value;
                  var bytearray = [];
                  return value2;
                  // try to connect
                      .then(function()
                      .catch(function(e)
                          console.log(e);
                      if (err) {
                      else
                          ConnectModbus();
                      ProcessData();
                      currentinverter++
              }, 3000);
              Super Danke.
              Gruß Jürgen
              Diese Werte habe ich mir noch gar nicht angeschaut. Hier fehlt im Script (Zeilen 193 und 194) tatsächlich der Multiplikator.
              ForceSetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",   GetU32(globalDataBuffer[id-1], 32106) / 100,          {name: "", unit: "kWh"});
                  ForceSetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",         GetU32(globalDataBuffer[id-1], 32114) / 100,          {name: "", unit: "kWh"});
              Zu deinem Hauptproblem: Ich bin mir aktuell nicht ganz sicher, ob die Wiederverbindung im Script korrekt funktioniert. Ich habe bisher nur das Netzwerkkabel des ioBrokers für 10 Sekunden gezogen und das machte ihm nichts aus. Aber die Meldung, die bei einer neuen Verbindung geloggt werden sollten, kamen nicht. Daher kann es gut sein, dass client.isOpen vielleicht gar nicht so funktioniert wie erhofft.
                @alex-warkentin
                Danke für deine Bemühungen und für die Richtigstellung der Multiplikatoren 👍
                Kannst du das mit dem client.isOpen vielleicht testen und verbessern, das wäre echt super.
                Ich kenne mich leider mit JS gar nicht aus.
                Danke im Voraus, Gruß Jürgen
                Alex Warkentin 2 Replies Last reply Reply Quote 0
                • Alex Warkentin
                  @juggi1962
                  Ich bin aktuell beruflich ziemlich eingespannt, aber mich interessiert das auch. Ich werde das bei Gelegenheit mal genauer anschauen.
                  • Alex Warkentin
                    @alex-warkentin
                    isOpen soll laut Doku eigentlich ein Funktion an. Wird aber als solche nicht zur Verfügung gestellt und ist sonst auch immer true. Probiere bitte dein Script mit folgendem Snippet ab Zeile 197 zu überschreiben. Nun frage ich den ErrorCode nach null ab und reconnecte dann.
                            if (err) {
                                if (err.modbusCode == null) {
                                    console.warn("Lost connection to client. Trying to reconnect...");
                                    ConnectModbus();
                                else console.warn("Error received reading address " + address + " from id: " + modbusID[id-1] + " with error: " + modbusErrorMessages[err.modbusCode]);
                            else
                            ProcessData();
                            currentinverter++
                    }, 3000);
                    Du solltest aber trotzdem versuchen zu ergründen, warum die ständigen Verbindungsabbrüche kommen. Falls möglich vielleicht das Ethernet-Kabel tauschen.
                      @alex-warkentin
                      Hallo und noch mal danke für deine Bemühungen.
                      Leider gibt es immer noch die selben Fehlermeldungen, bis jetzt immer mal einzelne,
                      mal schauen ob es wieder dauerhaft wird.
                      Ich habe jetzt für eine Stunde einen Ping laufen lassen und hatte beim Ping keine Abbrüche aber im Skript 10 Fehler.
                      Lankabel wurde vorher gegen ein neues getauscht.
                      Hmmmmm komisch 😞
                      • Alex Warkentin
                        @alex-warkentin
                        Hmmmmm komisch 😞
                        Naja, jetzt müsste die Fehlermeldung "Lost connection...." lauten. Und danach die Verbindung neu aufgebaut werden. Dann funktioniert das Script erwartungsgemäß.
                        Wie ist es denn mit deiner ioBroker Hardware? Kann es sein, dass hier die Abbrüche stattfinden?
                          @alex-warkentin
                          Die Fehlermeldung Lost connection... kommt nur wenn ich das LAN Kabel ziehe.
                          Mein Raspberry und IoBroker laufen ohne Aussetzer.
                          Diese Fehlermeldungen auch mit 32000 kommen immer mal wieder, hören aber dazwischen wieder auf.
                          Gruß Jürgen.
                          • Alex Warkentin
                            @juggi1962
                            Modbus hat einige Fehlercodes. Nur einige davon werden von dem Script auch in Klartext übersetzt. Ich weiß auch nicht, ob das Plugin was wir da verwenden, die ganzen Fehlercodes behandeln kann. Vielleicht hast du ja gar keine Verbindungsabbrüche, sondern der Errorcode liegt einfach außerhalb des Arrays der Messages.
                            Gehe mal zu der Zeile wo die Warnung generiert wird und dort ganz ans Ende und lösche modbuserrormessages und die eckigen Klammern um den errorcode, sodass nicht die oben definierten Messages, sondern der Fehlercode selbst dargestellt wird. Vielleicht kommt da ja ne Meldung, die man besser analysieren kann.
                              juggi1962 @Alex Warkentin last edited by juggi1962
                              @alex-warkentin
                              Danke, hab das gerade gemacht und werde es heute beobachten.
                              Wenn ich weiterhin lästig sein darf geb ich dir falls was daher kommt Bescheid.
                              Gruß Jürgen.
                              So nun sind die ersten Fehlermeldungen gekommen und zwar
                              Error received reading address 37100 from id: 1 with error: 6
                              Error received reading address 32000 from id: 1 with error: 6
                              Gruß Jürgen
                              B Alex Warkentin 2 Replies Last reply Reply Quote 0
                                badsnoopy667 @juggi1962 last edited by
                                @juggi1962
                                Ließt er denn den Rest der Register, oder geht gar nix?
                                37100 scheint laut Modbus Interface Definitions V4 eine Adresse des Energy Meters zu sein. Ist die dann unter der ID 1 ansprechbar, oder muss man da eine andere ID nehmen? Ist aber auch nur der "Meter status", also eig. relativ uninteressant würde ich sagen.
                                32000 hat als Typ "Bitfield16". Vielleicht wird hier nicht der richtige Typ abgefragt? Aber auch 32000 ist (aus meiner Sicht) ein relativ uninteressantes Register. Sprich: Wenn der Rest geht, würde ich die beiden Register einfach nicht abfragen.
                                  juggi1962 @badsnoopy667 last edited by
                                  @badsnoopy667
                                  Die Fehler kommen nur bei 37100 und 37200
                                  Ich habe aber das Skript von @Alex-Warkentin und da wurde einiges rausgestrichen.
                                  bei dem Original Skript kamen viel mehr Fehlermeldungen.
                                  Hier das Skript.
                                  // @ts-ignore
                                      "Unknown error",
                                      // "Slave device busy (retry request again later)"
                                  const modbusHost = "192.168.1.7";
                                  ConnectModbus();
                                      return value;
                                      return value;
                                      var value = 0;
                                      else
                                          value = array[0];
                                      return value;
                                      var value = 0;
                                      return value;
                                      return value;
                                      return value;
                                      return value;
                                      return value;
                                      var bytearray = [];
                                      return value;
                                      var bytearray = [];
                                      return value2;
                                      // try to connect
                                          .then(function()
                                          .catch(function(e)
                                              console.log(e);
                                          if (err) {
                                                  ConnectModbus();
                                              else console.warn("Error received reading address " + address + " from id: " + modbusID[id-1] + " with error: " + err.modbusCode);
                                          else
                                          ProcessData();
                                          currentinverter++
                                  }, 3000);
                                  Leider kenne ich mich mit dem JS überhaupt nicht aus 😞
                                  Gruß Jürgen
                                    @juggi1962
                                    Kommentier die beiden Zeilen wo 37100 und 32000 abgefragt werden doch einfach aus! Also // davorschreiben, so wie das im Script bei anderen Zeilen ja auch schon gemacht wurde.
                                      @badsnoopy667
                                      Meinst du diese?
                                      Brauch ich die gar nicht?
                                        @juggi1962
                                        Ja, das sollten die beiden Zeilen sein. Die brauchst Du nur, wenn du die beiden Register abfragen willst. Aber wie gesagt: Da steht meiner Meinung nach nix wirklich wichtiges drin. Wenn es also nicht klappt, würde ich die einfach nicht abfragen und gut ist.
                                          @badsnoopy667
                                          Okay Danke, werde ich mal versuchen.
                                          Gruß Jürgen
                                            @badsnoopy667
                                            kannst du mir vielleicht sagen, was der Unterschid zwischen
                                            AktivePower und InputPower ist?
                                            Was von beiden kommt bei mir im Zählerkasten an?
                                            477
                                            90365
