    4. NodeJS Versions Problem bei NSPANEL Script (gelöst)
    • Dark Angel
      Dark Angel last edited by
                           v.2023-01-02
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Installation:           lxc
      Timezone:               Europe/Berlin
      User-ID:                0
      X-Server:               false
      Boot Target:            graphical.target
      Pending OS-Updates:     0
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                              /usr/bin/node           v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Pending iob updates:    0
      Active repo(s): Stable (default)
      Objects:                11049
      States:                 10614
      Size of iob-Database:
      39M     /opt/iobroker/iobroker-data/objects.jsonl
      13M     /opt/iobroker/iobroker-data/states.jsonl
      • wendy2702
        wendy2702 @Dark Angel last edited by wendy2702
        @dark-angel Magst du uns davon die Lang Version zeigen und hast du den Javascript Adapter mal neu gestartet?
        • Dark Angel
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Architecture: 	x86_64
          Docker: 	false
          Virtualization: lxc
          Distributor ID:	Debian
          Description:	Debian GNU/Linux 11 (bullseye)
          Release:	11
          Codename:	bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           09:59:15 up 13:29,  2 users,  load average: 0.18, 0.21, 0.26
          CPU threads: 2
          *** Time and Time Zones ***
          Sun Mar 12 08:59:15 UTC 2023
          Sun Mar 12 09:59:15 CET 2023
          CET +0100
          Europe/Berlin
          *** User and Groups ***
          root
          /root
          root
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Mem:            4.1G        1.1G        2.6G        0.0K        370M        3.0G
          Swap:           512M        312M        199M
          Total:          4.6G        1.4G        2.8G
                   4096 M total memory
                   1101 M used memory
                    505 M active memory
                    867 M inactive memory
                   2623 M free memory
                      0 M buffer memory
                    370 M swap cache
                    512 M total swap
                    312 M used swap
                    199 M free swap
          *** FILESYSTEM ***
          Filesystem                       Type   Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--101--disk--0 ext4    20G  3.4G   16G  19% /
          none                             tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
          tmpfs                            tmpfs  3.2G  112K  3.2G   1% /run
          tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
          tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/0
          Messages in dmesg:
          [Sat Mar 11 20:14:47 2023] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar 11 20:14:48 2023] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
          [Sat Mar 11 20:14:55 2023] EXT4-fs (dm-13): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar 11 20:14:57 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar 11 20:14:59 2023] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar 11 20:15:03 2023] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar 11 20:15:05 2023] EXT4-fs (dm-11): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar 11 20:15:07 2023] EXT4-fs (dm-10): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Sat Mar 11 20:29:37 2023] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
          /var:
          500M	/var/
          226M	/var/cache
          222M	/var/cache/apt
          155M	/var/cache/apt/archives
          137M	/var/log/journal/9ee502583c9c486791c77bc51ed6a2f5
          /opt/iobroker/backups:
          4.0K	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          251M	/opt/iobroker/iobroker-data/
          143M	/opt/iobroker/iobroker-data/files
          55M	/opt/iobroker/iobroker-data/backup-objects
          51M	/opt/iobroker/iobroker-data/files/javascript.admin
          42M	/opt/iobroker/iobroker-data/files/devices.admin
          33M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
          15M	/opt/iobroker/iobroker-data/states.jsonl
          8.2M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js
          6.9M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/npm 		8.19.3
          /usr/bin/npx 		8.19.3
          nodejs:
            Installed: 16.19.1-deb-1nodesource1
            Candidate: 16.19.1-deb-1nodesource1
            Version table:
           *** 16.19.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u3 500
                  500 http://security.debian.org bullseye-security/main amd64 Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	4.0.24
          admin: 		6.3.5
          javascript: 	6.1.4
          Adapters from github: 	0
          Adapter State
          + system.adapter.accuweather.0            : accuweather           : ioBroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
            system.adapter.asterisk.0               : asterisk              : ioBroker                                 - disabled, port: 5038
          + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
            system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
          + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
            system.adapter.fritzbox.0               : fritzbox              : ioBroker                                 - disabled
            system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 - disabled
          + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
          + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1886, bind: 0.0.0.0
          + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
            system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled
            system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
            system.adapter.parser.0                 : parser                : ioBroker                                 - disabled
          + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
          + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 192.168.213.249
          + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
            system.adapter.tr-064.1                 : tr-064                : ioBroker                                 - disabled
          + system.adapter.tr-064.2                 : tr-064                : ioBroker                                 -  enabled
          + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Stable (default): http://download.iobroker.net/sources-dist.json
          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
          Installed ioBroker-Instances
          Used repository: Stable (default)
          Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "alias-manager": 1.2.4    , installed 1.2.4
          Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
          Adapter    "backitup"     : 2.5.12   , installed 2.5.12
          Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
          Adapter    "devices"      : 1.1.2    , installed 1.1.2
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "email"        : 1.1.4    , installed 1.1.4
          Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
          Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
          Adapter    "info"         : 1.9.19   , installed 1.9.19
          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
          Adapter    "onvif"        : 1.0.2    , installed 1.0.2
          Adapter    "openweathermap": 0.3.3   , installed 0.3.3
          Adapter    "parser"       : 1.1.8    , installed 1.1.8
          Adapter    "ping"         : 1.5.3    , installed 1.5.3
          Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
          Adapter    "shelly"       : 6.3.1    , installed 6.3.1
          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
          Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
          Objects and States
          Objects: 	11049
          States: 	10614
          Hit:1 http://security.debian.org bullseye-security InRelease
          Hit:2 https://deb.nodesource.com/node_16.x bullseye InRelease
          Hit:3 http://ftp.debian.org/debian bullseye InRelease
          Hit:4 http://ftp.debian.org/debian bullseye-updates InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          101896     1/init
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1000       110696     914/io.jarvis.0
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       103611     366/io.mqtt.0
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       103925     437/io.shelly.0
          tcp        0      0 192.168.213.249:1884    0.0.0.0:*               LISTEN      1000       106619     452/io.sonoff.0
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       102729     118/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       103442     118/iobroker.js-con
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        102113     108/systemd-resolve
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          102288     298/master
          tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        102107     108/systemd-resolve
          tcp6       0      0 :::22                   :::*                    LISTEN      0          102042     1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          101900     1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          102289     298/master
          tcp6       0      0 :::5355                 :::*                    LISTEN      104        102110     108/systemd-resolve
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       110786     949/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       100107     309/io.admin.0
          udp        0      0 192.168.213.249:5353    0.0.0.0:*                           1000       106794     494/io.tr-064.2
          udp        0      0 192.168.213.249:5353    0.0.0.0:*                           1000       106695     467/io.tr-064.0
          udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        102106     108/systemd-resolve
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        102112     108/systemd-resolve
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          101897     1/init
          udp        0      0 192.168.213.249:123     0.0.0.0:*                           0          102625     130/ntpd
          udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          102623     130/ntpd
          udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          102619     130/ntpd
          udp6       0      0 :::5355                 :::*                                104        102109     108/systemd-resolve
          udp6       0      0 :::111                  :::*                                0          101903     1/init
          udp6       0      0 fe80::34d0:3cff:fe1:123 :::*                                0          103504     130/ntpd
          udp6       0      0 ::1:123                 :::*                                0          102627     130/ntpd
          udp6       0      0 :::123                  :::*                                0          102616     130/ntpd
          2023-03-12 09:57:00.005  - warn: javascript.0 (21806)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          2023-03-12 09:57:00.005  - warn: javascript.0 (21806)     at listOnTimeout (node:internal/timers:559:17)
          2023-03-12 09:57:00.005  - warn: javascript.0 (21806)     at processTimers (node:internal/timers:502:7)
          2023-03-12 09:58:30.062  - warn: javascript.0 (21806) getState "0_userdata.0.wetter.Windrichtung" not found (3)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at HandleScreensaverUpdate (script.js.NSPanels.NS_Wohnzimmer:7536:31)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at Object.<anonymous> (script.js.NSPanels.NS_Wohnzimmer:2265:17)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at step (script.js.NSPanels.NS_Wohnzimmer:33:23)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at Object.next (script.js.NSPanels.NS_Wohnzimmer:14:53)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at script.js.NSPanels.NS_Wohnzimmer:8:71
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at new Promise (<anonymous>:null:null)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at __awaiter (script.js.NSPanels.NS_Wohnzimmer:4:12)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at Object.<anonymous> (script.js.NSPanels.NS_Wohnzimmer:2261:12)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5381:56)
          2023-03-12 09:58:30.063  - warn: javascript.0 (21806)     at processImmediate (node:internal/timers:466:21)
          2023-03-12 09:59:00.004  - warn: javascript.0 (21806) getState "0_userdata.0.wetter.Windrichtung" not found (3)
          2023-03-12 09:59:00.004  - warn: javascript.0 (21806)     at HandleScreensaverUpdate (script.js.NSPanels.NS_Wohnzimmer:7536:31)
          2023-03-12 09:59:00.004  - warn: javascript.0 (21806)     at Object.<anonymous> (script.js.NSPanels.NS_Wohnzimmer:2202:9)
          2023-03-12 09:59:00.005  - warn: javascript.0 (21806)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
          2023-03-12 09:59:00.005  - warn: javascript.0 (21806)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          2023-03-12 09:59:00.005  - warn: javascript.0 (21806)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          2023-03-12 09:59:00.005  - warn: javascript.0 (21806)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          2023-03-12 09:59:00.005  - warn: javascript.0 (21806)     at listOnTimeout (node:internal/timers:559:17)
          2023-03-12 09:59:00.005  - warn: javascript.0 (21806)     at processTimers (node:internal/timers:502:7)
          • Dark Angel
            JS neu gestartet, den kleinen Fehler im TS (Windrichtung bezieht im original TS Daten von einen nicht vorhandenen Pfad) "behoben" und Script neu gestartet:
            12.3.2023, 10:09:53.916	[info ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: compiling TypeScript source...
            12.3.2023, 10:09:54.712	[info ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: source code did not change, using cached compilation result...
            12.3.2023, 10:09:54.752	[warn ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: nodeJS must be at least v16.X.X. Currently: v14.20.1! Please Update your System!
            12.3.2023, 10:09:54.752	[info ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: setObjects enabled - create Alias Channels possible
            12.3.2023, 10:09:54.756	[info ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: weather alias for accuweather.0. already exists
            12.3.2023, 10:09:54.809	[info ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: registered 28 subscriptions, 7 schedules, 0 messages, 0 logs and 0 file subscriptions
            12.3.2023, 10:09:54.981	[info ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: Desired TFT Firmware: 50 / v4.0.4
            12.3.2023, 10:09:54.981	[info ]: javascript.0 (25778) script.js.NSPanels.NS_Wohnzimmer: Installed TFT Firmware: 50 / v4.0.4
            12.3.2023, 10:10:05.659	[warn ]: javascript.0 (25778)     at HandleScreensaverUpdate (script.js.NSPanels.NS_Wohnzimmer:7536:31)
            12.3.2023, 10:10:05.659	[warn ]: javascript.0 (25778)     at HandleScreensaver (script.js.NSPanels.NS_Wohnzimmer:7315:5)
            12.3.2023, 10:10:05.659	[warn ]: javascript.0 (25778)     at HandleMessage (script.js.NSPanels.NS_Wohnzimmer:3263:21)
            12.3.2023, 10:10:05.659	[warn ]: javascript.0 (25778)     at Object.<anonymous> (script.js.NSPanels.NS_Wohnzimmer:3192:25)
            12.3.2023, 10:10:05.659	[warn ]: javascript.0 (25778)     at step (script.js.NSPanels.NS_Wohnzimmer:33:23)
            12.3.2023, 10:10:05.659	[warn ]: javascript.0 (25778)     at Object.next (script.js.NSPanels.NS_Wohnzimmer:14:53)
            12.3.2023, 10:10:05.660	[warn ]: javascript.0 (25778)     at script.js.NSPanels.NS_Wohnzimmer:8:71
            12.3.2023, 10:10:05.660	[warn ]: javascript.0 (25778)     at __awaiter (script.js.NSPanels.NS_Wohnzimmer:4:12)
            12.3.2023, 10:10:05.660	[warn ]: javascript.0 (25778)     at Object.<anonymous> (script.js.NSPanels.NS_Wohnzimmer:3184:12)
            wendy2702 JLeg 2 Replies Last reply Reply Quote 0
            • wendy2702
              @dark-angel sagte in NodeJS Versions Problem bei NSPANEL Script:
              Keine Ahnung wo da scheinbar das Script was denkt welche Version noch vorhanden ist.
              Ich würde folgendes Probieren.
              Script komplett löschen
              iob Server neu starten
              Script neu anlegen.
              • JLeg
                JLeg @Dark Angel last edited by
                @dark-angel
                das sieht mir nach einem Bug im Nspanel-Script aus - das prüft die Nodeversion über system.host.*.nodeCurrent - es gibt zwar einen Dp ‚npmCurrent‘, der für Node heisst aber anders (kannst du im Expertenmodus in deinem Objektbaum prüfen)..
                Dark Angel 1 Reply Last reply Reply Quote 0
                • Dark Angel
                  Dark Angel @JLeg last edited by
                  @jleg sagte in NodeJS Versions Problem bei NSPANEL Script:
                  @dark-angel
                  Danke @JLeg.
                  Wieder was gelernt...
                  Also: da diese Proxmox-CT mittlerweile die 3. Installation ist, bei der ich einfach die Backups der Vorgängermaschinen nach der Installation importiert habe (Raspberry Pi3 > Raspberry Pi4 > Proxmox), scheint bei jeden Import die "alte" Installation als Host unter "system.host." mit erstellt worden zu sein.
                  Dadurch scheint das Script etwas durcheinander zu kommen, da es unter "system.host.*.nodeCurrent" bei mir 3 Hosts findet.
                  Die überflüssigen Hosts gelöscht, ioBroker neu gestartet und siehe da: Keine Fehlermeldung mehr, das NodeJS veraltet ist.
                  Mal sehen, ob irgendwelche andere Instanzen, oder Scripte damit ein Problem haben, dass ich die "alte" Hosts gelöscht habe...
                  Vielleicht könnte trotzdem das Script dahingehend etwas "verbessert" werden, damit es wirklich nur die NodeJS Version des Hosts prüft, auf dem es läuft.
                  Danke euch allen, dass Ihr euch so intensiv um eine Lösung bemüht habt.
                  wendy2702 1 Reply Last reply Reply Quote 1
                  • wendy2702
                    @dark-angel danke das du die Lösung mit uns teilst. 👍
                    • Dark Angel
                      Dark Angel @wendy2702 last edited by
                      @wendy2702: Ich dachte, dass ist der Sinn und Zweck einer solchen Community: Lösungen mit den anderen Teilen... 👍
                      Also, kein Grund für euch Danke zu sagen. Ich danke euch, dass ihr mir bei der Lösung des Problems geholfen habt.
                      • wendy2702
                        @dark-angel Du glaubst garnicht wieviele Threads hier gelöst sind und die Lösung nie verraten wurde.
                        767
