    4. [Aufruf] TP-Link HS100 HS110 Adapter Testen
      A Former User last edited by
      Hallo @ All
      Adapter erfolgreich installiert.
      Kann mir jemand sagen wie ich die Verbrauchsdaten mit iobroker angezeigt bekomme?
      Grüße Pocky 🙂
        muckel last edited by
        Hallo Arteck
        Kannst du mir dazu einen Tip geben.
        Danke im Voraus
        liebe Grüße
        host.iobroker	2017-09-12 17:59:22.814	info	Restart adapter system.adapter.hs100.0 because enabled
        host.iobroker	2017-09-12 17:59:22.813	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
        hs100.0	2017-09-12 17:59:22.313	error	TypeError: Cannot read property 'length' of undefined at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:377:32) at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.
        hs100.0	2017-09-12 17:59:22.313	error	uncaught exception: Cannot read property 'length' of undefined
        hs100.0	2017-09-12 17:59:22.311	info	starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.hs100, node: v4.7.2
        host.iobroker	2017-09-12 17:59:20.913	info	instance system.adapter.hs100.0 started with pid 768
        host.iobroker	2017-09-12 17:58:50.869	info	Restart adapter system.adapter.hs100.0 because enabled
        host.iobroker	2017-09-12 17:58:50.869	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
        hs100.0	2017-09-12 17:58:50.369	error	TypeError: Cannot read property 'length' of undefined at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:377:32) at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.
        hs100.0	2017-09-12 17:58:50.368	error	uncaught exception: Cannot read property 'length' of undefined
        hs100.0	2017-09-12 17:58:50.367	info	starting. Version 0.0.16 in /opt/iobroker/node_modules/iobroker.hs100, node: v4.7.2
        host.iobroker	2017-09-12 17:58:49.035	info	instance system.adapter.hs100.0 started with pid 758
        host.iobroker	2017-09-12 17:58:18.982	info	Restart adapter system.adapter.hs100.0 because enabled
        host.iobroker	2017-09-12 17:58:18.982	error	instance system.adapter.hs100.0 terminated with code 0 (OK)
        hs100.0	2017-09-12 17:58:18.959	info	terminating
        hs100.0	2017-09-12 17:58:18.448	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        hs100.0	2017-09-12 17:58:18.448	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
        hs100.0	2017-09-12 17:58:18.448	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
        hs100.0	2017-09-12 17:58:18.448	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
        hs100.0	2017-09-12 17:58:18.448	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:703:25)
        hs100.0	2017-09-12 17:58:18.448	error	at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4527:18)
        hs100.0	2017-09-12 17:58:18.448	error	at Adapter.emit (events.js:166:7)
        hs100.0	2017-09-12 17:58:18.448	error	at emitNone (events.js:67:13)
        hs100.0	2017-09-12 17:58:18.448	error	at Adapter. (/opt/iobroker/node_modules/iobroker.hs100/main.js:30:5)
        hs100.0	2017-09-12 17:58:18.448	error	at main (/opt/iobroker/node_modules/iobroker.hs100/main.js:377:32)
        hs100.0	2017-09-12 17:58:18.448	error	TypeError: Cannot read property 'length' of undefined
        hs100.0	2017-09-12 17:58:18.438	error	uncaught exception: Cannot read property 'length' of undefined
          @Pocky:
          Hallo @ All
          Grüße Pocky 🙂 `
          nur die HS110 sammelt nur die Daten .. da gibt es Datenobjekte für ..
          die HS100 hat die nicht
            @muckel:
            Hallo Arteck
            Danke im Voraus
            liebe Grüße
            hast du IP's eingetragen ?? von den Dosen
              @arteck:
              @muckel:
              Hallo Arteck
              Danke im Voraus
              liebe Grüße
              hast du IP's eingetragen ?? von den Dosen `
                @muckel:
                @arteck:
                @muckel:
                Hallo Arteck
                Danke im Voraus
                liebe Grüße
                Gesendet von iPhone mit Tapatalk `
                Ja natürlich.
                Es funktioniert ja alles.
                • AlCalzone
                  bedeutet
                  {ZEILE 377}: if (!adapter.config.devices.length) {
                  adapter.config.devices ist undefined.
                  Da fehlt wohl die Eigenschaft im Adapter-Objekt (müsste per Expertenmodus unter hs100.0 zu finden sein, Abschnitt "native").
                  Wurde die eventuell mit einem Update hinzugefügt?
                  • AlCalzone
                    @UweRLP:
                    laut Changelog soll es eine 0.0.16 (2017-08-19) geben, installiert wird aber eine 0.0.15 (Anzeige in Admin). `
                    Da hat arteck wohl vergessen die io-package.json anzupassen.
                    Adapter-testing fängt dieses Problem übrigens ab, könnte man mal aktivieren 😉
                      @AlCalzone:
                      @UweRLP:
                      Adapter-testing fängt dieses Problem übrigens ab, könnte man mal aktivieren 😉 `
                        @muckel:
                        @AlCalzone:
                        @UweRLP:
                        Das könnte ich mal probieren.
                        Danke für den tip.
                        Liebe Grüße
                        • AlCalzone
                          @muckel:
                          Danke für den tip. `
                          Das war an Arteck als Entwickler gerichtet. Dann sieht man wie https://github.com/AlCalzone/ioBroker.tradfri/blob/master/README.md auf den ersten Blick ob irgendwas grundlegendes nicht stimmt.
                            ihr müsst mir verzeihen.. ich bau gerade mein Haus um.. soweit ich Zeit finde.. wirds korrigiert
                              DavidT last edited by
                              ich habe den ganzen Abend verzweifelt versucht den Adapter zu installieren (wie von Dir beschrieben), leider ohne Erfolg.
                              Bei dem Versuch mein node zu updaten habe ich mir meinen Container total zerschossen, hatte kein Backup usw. Ohne viele Linux und Docker-Kenntnisse echt eine Herausforderung 🙂
                              Ich habe wie von dir beschrieben das ganze in der Shell installiert (0.0.17) mit aktuellen node und bekomme bei "iobroker add hs100" folgenden Fehler:
                              root@T-NAS:/opt/iobroker# iobroker add hs100
                              host.T-NAS install adapter hs100
                              host.T-NAS error: reading io-package.json SyntaxError: Unexpected token , in JSON at position 1152
                              Mache ich irgendwas falsch!? Bin mit meinem Latein am ende 🙂
                              Gruß David
                                Ok, wenn man die einfachen Probleme nicht sieht… In der io-package.json ist ein Syntaxfehler. Habe es gefixt und einen Pullrequest erstellt.
                                Danke für Deine Arbeit!
                                  ich habs auch schon korrigiert.. version 0.0.18
                                    mamoel last edited by
                                    Hallo zusammen, die Installation des Adapters war recht einfach und wurde auch sofort in iobroker angezeigt. Mein HS100 wird erkannt und ich kann aus iobroker heraus (admin->Objects->HS100 …) die Steckdose über den 'state' ein- und ausschalten.
                                    Was jedoch seltsamerweise nicht funktioniert:
                                    Ich ändere den Status über die KASA-App am Smartphone und höre wie die Steckdose schaltet. In iobroker bleibt der Status jedoch unverändert. Haben das andere User hier auch?
                                    Wenn ich den Adapter 'durchstarte' holt er sich den aktuellen Status korrekt.
                                    Ich habe Node.js 6.11.4 und den neuesten HS100 Adapter 0.18 installiert. Das Intervall habe ich aktuell auf 3000ms.
                                      @mamoel:
                                      Ich habe Node.js 6.11.4 und den neuesten HS100 Adapter 0.18 installiert. Das Intervall habe ich aktuell auf 3000ms. `
                                      das Problem ist das gleiche wie in Hue .. es wird nicht sofort aktuallisiert.. das kannst du im Adapter einstellen … unter Intervall..
                                      das kleinste ist 5 sec. (auch wenn du kleiner einstellst.. grösser geht aber immer) um das System nicht so zu belasten
                                        @arteck:
                                        das kleinste ist 5 sec. (auch wenn du kleiner einstellst.. grösser geht aber immer) um das System nicht so zu belasten `
                                        Ich habe das Intervall jetzt auf 5000 ms gesetzt, das Ergebnis ist aber leider identisch: wenn ich den Schalter mit der Kasa-App betätige, aktualisiert sich der Status in iobroker auch nach einer Minute noch nicht.
                                          @mamoel:
                                          @arteck:
                                          das kleinste ist 5 sec. (auch wenn du kleiner einstellst.. grösser geht aber immer) um das System nicht so zu belasten Ich habe das Intervall jetzt auf 5000 ms gesetzt, das Ergebnis ist aber leider identisch: wenn ich den Schalter mit der Kasa-App betätige, aktualisiert sich der Status in iobroker auch nach einer Minute noch nicht.
                                          welches Betriebssystem ??
                                            Läuft bei mir auf einem Mac Mini (Late 2009) unter OSX.
                                            31.7k
                                            79.8k
                                            215
                                            43169
