    5. Gleitender Durchschnitt mit Blockly
      paul53 @chemieka last edited by paul53
      @chemieka sagte: Ohne String kommen noch mehr Alarme.
      Lass unbedingt "nach String" weg!
      Die Liste scheint nicht in Ordnung zu sein. Bau einen Debug-output der Variablen Liste ein.
        chemieka @paul53 last edited by Homoran
        String ist raus:
        Debug
        22:37:50.002	info	javascript.0 (30115) script.js.javascript.MittelTemp: [7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,6.9,6.9,6.9,6.9,6.9,6.9,6.9,6.9]
        22:37:50.005	warn	javascript.0 (30115) at Object.<anonymous> (script.js.javascript.MittelTemp:21:3)
        22:37:50.017	error	javascript.0 (30115) script.js.javascript.MittelTemp: TypeError: Liste.push is not a function
        22:37:50.017	error	javascript.0 (30115) at Object.<anonymous> (script.js.javascript.MittelTemp:17:9)
        22:38:00.003	error	javascript.0 (30115) script.js.javascript.MittelTemp: TypeError: Liste.push is not a function
        22:38:00.003	error	javascript.0 (30115) at Object.<anonymous> (script.js.javascript.MittelTemp:17:9)
        22:38:00.006	info	javascript.0 (30115) script.js.javascript.MittelTemp: [7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.2,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,7.1,6.9,6.9,6.9,6.9,6.9,6.9,6.9,6.9,6.9]
        22:38:00.008	warn	javascript.0 (30115) at Object.<anonymous> (script.js.javascript.MittelTemp:21:3)
          Homoran Global Moderator Administrators @chemieka last edited by
          @chemieka Da sind doch jetzt wahrscheinlich auch Strings drin.
          Mach die Liste mal leer.
          und was steht in den Zeilen, die als Fehler angegeben werden?
            @chemieka sagte: TypeError: Liste.push is not a function
            Das kann ich nicht nachvollziehen, denn Liste.push() wird ausgeführt, wie man im Log von Liste sehen kann.
            Zur Warnung schau im Tab "Protokolle", wo weitere Informationen zu finden sind.
              Als Code:
              var Anzahl, Liste;
              function mathMean(myList) {
                return myList.reduce(function(x, y) {return x + y;}) / myList.length;
              if (getState("admin.0.MittelTempMonat").val) {
                Liste = getState("admin.0.MittelTempMonat").val;
              } else {
                Liste = [];
                setState("admin.0.MittelTempMonat"/*MittelTempMonat*/, Liste, true);
              schedule("*/10 * * * * *", async function () {
                console.log(Liste);
                if (Liste.length >= Anzahl) {
                  Liste.shift();
                Liste.push(getState("hm-rpc.1.001818A992BC16.1.ACTUAL_TEMPERATURE").val);
                setState("admin.0.MittelTemp"/*MittelTemp*/, Math.round((mathMean(Liste))*10)/10, true);
              Anzahl = 96;
              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
                chemieka @chemieka last edited by
                @chemieka
                Protokoll
                2023-01-11 22:48:30.021	error	at processTimers (internal/timers.js:500:7)
                javascript.0
                2023-01-11 22:48:30.021	error	at listOnTimeout (internal/timers.js:557:17)
                javascript.0
                2023-01-11 22:48:30.021	error	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                javascript.0
                2023-01-11 22:48:30.020	error	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                javascript.0
                2023-01-11 22:48:30.020	error	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                javascript.0
                2023-01-11 22:48:30.019	error	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
                javascript.0
                2023-01-11 22:48:30.019	error	at Object.<anonymous> (script.js.javascript.MittelTemp:17:9)
                javascript.0
                2023-01-11 22:48:30.018	error	script.js.javascript.MittelTemp: TypeError: Liste.push is not a function
                javascript.0
                2023-01-11 22:48:30.009	warn	at processTimers (internal/timers.js:500:7)
                javascript.0
                2023-01-11 22:48:30.008	warn	at listOnTimeout (internal/timers.js:557:17)
                javascript.0
                2023-01-11 22:48:30.008	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
                javascript.0
                2023-01-11 22:48:30.008	warn	at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
                javascript.0
                2023-01-11 22:48:30.007	warn	at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
                javascript.0
                2023-01-11 22:48:30.007	warn	at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1595:34)
                javascript.0
                2023-01-11 22:48:30.007	warn	at Object.<anonymous> (script.js.javascript.MittelTemp:21:3)
                javascript.0
                2023-01-11 22:48:30.006	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1719:20)
                javascript.0
                2023-01-11 22:48:30.005	warn	You are assigning a number to the state "admin.0.MittelTemp" which expects a array. Please fix your code to use a array or change the state type to number. This warning might become an error in future versions.
                  @chemieka sagte in Gleitender Durchschnitt mit Blockly:
                  hast du den falsche Datenpunkt geändert?
                  der muss number sein.
                    @chemieka sagte: You are assigning a number to the state "admin.0.MittelTemp" which expects a array.
                    Ändere den Typ in Zahl ("number").
                    Was hat der Datenpunkt unter "admin.0" zu suchen?
                      HM den Adapter neu gestartet und Typ Zahl für den Mittelwert gewählt, wobei ich das auch schon vorher mal hatte. Jetzt keine Meldungen mehr.
                      Butzig. Aber vielen Dank zu so später Stunde.👍 😊
                        brokeling @chemieka last edited by
                        @chemieka said in Gleitender Durchschnitt mit Blockly:
                        @chemieka
                        Ich glaube so stimmen die Ergebnisse:
                        Ich bräuchte auch eine Verarbeitung von Daten in einer Liste, ich kann aber die Option "entferne" aus der Liste wie im Projekt oben nicht finden!?!
                        Ich hab nur die zwei Möglichkeiten "setze für" und "füge als":
                          Homoran Global Moderator Administrators @brokeling last edited by
                          @brokeling sagte in Gleitender Durchschnitt mit Blockly:
                          dann ist das der falsche Block.
                            brokeling @Homoran last edited by
                            @homoran said in Gleitender Durchschnitt mit Blockly:
                            Es gibt bei mir nur das zur Auswahl:
                              @brokeling dann imm doch den 2. Block mit "Liste"
                                Ich gehe davon aus, dass ich nur den markierten nehmen kann:
                                  paul53 @brokeling last edited by
                                  @brokeling sagte: Ich gehe davon aus, dass ich nur den markierten nehmen kann:
                                  Falsch!
                                    brokeling @paul53 last edited by brokeling
                                    @paul53 said in Gleitender Durchschnitt mit Blockly:
                                    Falsch!
                                    Das lässt sich so in die Struktur aber nicht einfügen wegen dem puzzle-Haken vorne dran.
                                    Ich beziehe mich auf dieses Beispiel:
                                      @brokeling sagte: nicht einfügen wegen dem puzzle-Haken vorne dran.
                                      Der Haken verschwindet, wenn man "entferne" selektiert.
                                        oh mann, ok danke!
                                        blockly
                                        15
                                        67
                                        12146
