    4. Wrong Type
    Wrong Type
    • kmxak
      Hi
      habe in den Logs folgende Fehlermeldung:
      javascript.0	2017-09-14 18:51:09.643	warn	Wrong type of javascript.0.User.Alarmserver.Treppenhaus: "boolean". Please fix, while deprecated and will not work in next versions.
        "common": {
          "name": "Treppenhaus",
          "type": "boolean",
          "role": "javascript",
          "read": true,
          "write": true
        "native": {
          "type": "undefined",
          "name": "Name",
          "read": true,
          "write": true
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
          "state": 1636
        "_id": "javascript.0.User.Alarmserver.Treppenhaus",
        "type": "state"
      Das Script setzt bei dem Objekt true oder false
      Kann mir einer sagen was ich falsch gemacht habe und es mir ggf erklären wieso und warum?
      Hier das Blockly
      <block xmlns="http://www.w3.org/1999/xhtml" type="on" id="N6C2ZjF4]-0asMUuag4`" x="-112" y="-12"><field name="OID">javascript.0.User.Alarmserver.Treppenhaus</field>
      <statement name="STATEMENT"><block type="control_ex" id="LHY@M73y2DBgl9nNdV,%"><field name="TYPE">false</field>
      <value name="OID"><shadow type="field_oid" id="x9A+=[4oakX[Gp^DLn?v"><field name="oid">javascript.0.scriptEnabled.User.Telegram.Alarm_Bild_Treppenhaus</field></shadow></value>
      <value name="VALUE"><shadow type="logic_boolean" id="x.4(37R1r9*[7LewyXQ"><field name="BOOL">TRUE</field></shadow></value> <value name="DELAY_MS"><shadow type="math_number" id="3%1oXQ2lYz?hRe[]YrFP"><field name="NUM">0</field></shadow></value> <next><block type="control_ex" id="vpSJ;5:laVtc!X/TDs;p"><field name="TYPE">true</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"><shadow type="field_oid" id="vw;CuoF[N@gidGB_U9r"><field name="oid">javascript.0.User.Alarmserver.Treppenhaus</field></shadow></value>
      <value name="VALUE"><shadow type="logic_boolean" id=";gpo*/6nnO_RK``l5SQt"><field name="BOOL">FALSE</field></shadow></value>
      <value name="DELAY_MS"><shadow type="math_number" id="R{utQ?^!d#-lN[W/imNq"><field name="NUM">15000</field></shadow></value>
      <next><block type="debug" id="9Iul0^cpGL/CcnZPX#so"><field name="Severity">debug</field>
      <value name="TEXT"><shadow type="text" id="|LopY4TO7ir8*^T=FSY~"><field name="TEXT">test</field></shadow></value></block></next></block></next></block></statement></block>
        paul53 last edited by
        Sieh so das Objekt wirklich aus ? Wenn ja, dann ist eine öffnende geschweifte Klammer zu viel (1. oder 2. Zeile).
        • kmxak
          tippfehler sorry in den objekten ist es richtig
            apollon77 last edited by
            Die Fehlermeldung bedeutet das ein anderer Wert geschrieben wird bei "setState".
            Schick mal den generierten JavaScript code bitte
            • kmxak
              on({id: "javascript.0.User.Alarmserver.Treppenhaus"/*Treppenhaus*/, val: true}, function (obj) {
                var value = obj.state.val;
                setStateDelayed('javascript.0.scriptEnabled.User.Telegram.Alarm_Bild_Treppenhaus', true, false, parseInt(0, 10), false);
                setStateDelayed('javascript.0.User.Alarmserver.Treppenhaus', false, true, parseInt(15000, 10), false);
                console.debug('test');
              Bitte
