    4. Energiefluss Adapter - Support
      Thomas Braun Most Active @Neo77 last edited by
      @neo77 sagte in Test Adapter Energiefluss v3.6.x GitHub/Latest:
      Einer eine Idee?
      In das LogFile schauen ist eigentlich immer eine gute Idee.
      iob logs --watch | uniq
      Adapter neustarten und staunen.
      N 1 Reply Last reply Reply Quote 1
      • N
        Neo77 @Thomas Braun last edited by Homoran
        host.IOBROKER
        2023-03-15 17:18:48.712	error	instance system.adapter.energiefluss.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:963:27)
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: at wrapSafe (internal/modules/cjs/loader.js:915:16)
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: SyntaxError: Unexpected token '.'
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: ^
        host.IOBROKER
        2023-03-15 17:18:48.712	error	Caught by controller[0]: if (this.config?.car_charge) {
        host.IOBROKER
        2023-03-15 17:18:48.709	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.energiefluss/main.js:781
        host.IOBROKER
        2023-03-15 17:18:48.592	info	instance system.adapter.energiefluss.0 started with pid 3874454
        Jede Menge Fehler im Log 😞
        Thomas Braun wendy2702 SKB 3 Replies Last reply Reply Quote 0
          @neo77
          Das kann aber nicht die Ausgabe vom obigen Befehl sein, der wäre nämlich chronologisch richtig von oben nach unten.
          • Longbow
            Longbow @Homoran last edited by
            @homoran sagte in Energiefluss Adapter - Support:
            iobroker install vis@1.4.10
            Vis war installiert schon, als ich das backup wieder eingespielt habe hab.
            Dein Befehl iobroker install vis@1.4.10 hat nur das
            "iobroker install vis@1.4.10
            adapter "vis" already installed. Use "upgrade" to upgrade to a newer version."
            Das ist nur passiert.
            Hier der Fehler vom Adpater !
            Was kann ich nun machen?
            • Longbow
              Longbow @SKB last edited by
              @skb nun leider bei Mac gibt es keine Reaktion
              • SKB
                SKB Developer Most Active @Longbow last edited by
                @longbow dann schaust Du via Google, wie in Deinem Browser die Konsole öffnet. Dort stehen ggf. Fehler.
                Ansonsten steht der WebAdapter auf integriert oder socket.io?
                Der muss auf integriert. Da dann aber VIS nicht mehr richtig klappt, ist eine zweite WebInstanz empfehlenswert.
                Longbow 1 Reply Last reply Reply Quote 0
                • Longbow
                  @skb Ok... [
                  [2023-03-15T18:26:54.880Z] Start reconnect 5
                  socket.io.js:68
                         [2023-03-15T18:26:54.881Z] ws connection error: CLOSE_ABNORMAL
                  error @ socket.io.js:68
                  2socket.io.js:66 [2023-03-15T18:26:54.881Z] Reconnect is already running 5
                  socket.io.js:66 [2023-03-15T18:27:14.668Z] Try to connect
                  Das steht da...
                  also es geht auch nicht mit dem aufrufen über den Adminbereich, also kann es ja nicht an die Instanz VIS liegen oder ?
                  • BananaJoe
                    BananaJoe Most Active @Longbow last edited by BananaJoe
                    @longbow hast du an den Web-Adaptern WS (Websockets) an?
                    Das mag der Adapter nicht. Ggf. eine weitere Web-Adapter Instanz hinzufügen ohne Websockets und dann über diesen Adapter (= anderer Port) aufrufen
                    Longbow 1 Reply Last reply Reply Quote 1
                    • Longbow
                      Longbow @BananaJoe last edited by
                      @bananajoe VIELEN DANK, das war es... keine Ahnung wieso das drin war... Danke, es geht wieder
                      • BananaJoe
                        @longbow sagte in Energiefluss Adapter - Support:
                        Wenn jetzt der VIS-Editor rumzickt ... dann will der WS haben ...
                        • wendy2702
                          wendy2702 @Neo77 last edited by
                          @neo77 sagte in Energiefluss Adapter - Support:
                          host.IOBROKER
                          host.IOBROKER
                          Zeig mal Screenshots deiner Konfig und der Verwendeten Datenpunkte
                          • SKB
                            SKB Developer Most Active @Neo77 last edited by
                            @neo77 Bitte den Js-Controller updaten. Der Fehler tritt bei älteren Versionen auf.
                            • N
                              Neo77 @wendy2702 last edited by
                              CPU: 11.13 %
                              RAM: 14.4 %
                              Betriebszeit: 0h
                              Verfügbar: 4.0.24
                              Installiert: 4.0.24
                              Ereignisse: ⇥29 / ↦13
                              Plattform: linux
                              Betriebssystem: linux
                              Architektur: x64
                              CPUs: 1
                              Geschwindigkeit: 2712 MHz
                              Modell: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
                              RAM: 3.8 GB
                              System-Betriebszeit: 106 T. 11:57:26
                              Node.js: v12.22.12
                              time: 1679040308830
                              timeOffset: -60
                              Adapter-Anzahl: 470
                              NPM: v6.14.16
                              Datenträgergröße: 15.2 GB
                              Freier Festplattenspeicher: 1.3 GB
                              Betriebszeit: 10:51:23
                              Aktive Instanzen: 28
                              Pfad: /opt/iobroker/
                              aktiv: true
                              Latzi Thomas Braun wendy2702 4 Replies Last reply Reply Quote 0
                              • wendy2702
                                @neo77 Da nichts mit dem Adapter zu tun... geht es hier weiter:
                                https://forum.iobroker.net/topic/63955/altes-system-updaten-wie-genau
                                  jpa last edited by
                                  Hallo zusammen, ich bin ganz neu hier und mach mich gerade mit allem vertraut. Freue mich, dass Energiefluss super leicht einzurichten war und standardmäßig optisch gut aussieht. Wenn ich den Thread richtig verfolgt habt ist eine manuelle grafische Platzierung der Datenpunkte z.B. via CSS o.ä. nicht möglich - richtig?
                                  Wie sieht es denn mit der iobroker.net Einbindung aus? Wenn ich ein iFrame nehme, dann wird das dort ja nicht mit VIS funktionieren. Gibt es einen anderen weg wie man das hinbekommen könnte?
                                  Danke!
                                  Winni Homoran da_Woody 3 Replies Last reply Reply Quote 0
                                  • Winni
                                    Winni @jpa last edited by
                                    @jpa ich bin mir jetzt nicht sicher ob ich dich ganz richtig verstanden habe, aber wenn du deinen Energiefluss in ein VIS einbinden willst geht das mit diesem Link: http://192.168.1.xxx:8082/energiefluss/index.html
                                      Homoran Global Moderator Administrators @jpa last edited by
                                      @jpa sagte in Energiefluss Adapter - Support:
                                      warum nicht?
                                      solange es iobroker Daten sind und über einen relativen URL zu erreichen, klappt das.
                                      • da_Woody
                                        da_Woody @jpa last edited by
                                        nope, die gibts definitiv noch nicht.
                                          Radi last edited by Radi
                                          Ist es eigentlich normal, dass der Adapter beim Entladen keine Restzeit anzeigt. Ich verwende die Version 3.6.0. Beim Laden wird die Restzeit angezeigt.
                                          Hier noch die Einstellungen der relevanten Datenpunkte im Adapter
                                          maximal1981 1 Reply Last reply Reply Quote 0
                                          • maximal1981
                                            maximal1981 @Radi last edited by
                                            @radi
                                            • sollte es hier hin https://forum.iobroker.net/topic/63300/energiefluss-adapter-support
                                            • du hast Probleme mit der Restzeit vom Akku, und deine relevanten Datenpunkte sind Verbrauch und öffentliches Netz 🤦
                                            Homoran R 2 Replies Last reply Reply Quote 1
                                            81.1k
                                            energiefluss support vis visualisierung visualization
                                            48
                                            459
                                            128997
