    3. Einsteigerfragen
    4. Erstinstallation Ip Adresse nicht gefunden
      pmther @Thomas Braun last edited by
      @thomas-braun habe alles auf dem Terminal vom Mac aus gemacht und so wie es in der Anleitung steht
        Thomas Braun Most Active @DJMarc75 last edited by
        @djmarc75
        Der PI3 spricht 64bit. Das kann also nicht das Problem sein.
          Thomas Braun Most Active @pmther last edited by Thomas Braun
          @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
          Dann zeig mal das vollständige Terminal. Inkl. der vollständigen Eingabezeile.
          In CodeTags eingebettet.
          Ich halte da jede Wette, das du da gar nicht auf dem Raspberry eingeloggt bist...
            Last login: Thu Mar 16 19:20:20 on ttys000
            Paul@Saskias-Air ~ % ssh paul@192.168.178.41
            The authenticity of host '192.168.178.41 (192.168.178.41)' can't be established.
            ED25519 key fingerprint is SHA256:vFjguricu5KqpRk0lsjyEx9OxnGTuzr0BL0LehEYF5E.
            This key is not known by any other names
            Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
            Warning: Permanently added '192.168.178.41' (ED25519) to the list of known hosts.
            paul@192.168.178.41's password:
            Linux paul 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            paul@paul:~ $ sudo apt update && sudo apt full-upgrade
            Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
            Hit:2 http://deb.debian.org/debian bullseye InRelease
            Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
            Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
            Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [232 kB]
            Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [232 kB]
            Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [154 kB]
            Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [315 kB]
            Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [307 kB]
            Fetched 1,355 kB in 2s (632 kB/s)
            Reading package lists... Done
            Building dependency tree... Done
            12 packages can be upgraded. Run 'apt list --upgradable' to see them.
            Calculating upgrade... Done
            The following packages will be upgraded:
            curl libcamera-apps-lite libcamera0 libcurl3-gnutls libcurl4 libtiff5
            linux-libc-dev python3-libcamera python3-picamera2 python3-v4l2
            raspberrypi-bootloader raspberrypi-kernel
            12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            Need to get 35.0 MB of archives.
            After this operation, 38.9 kB of additional disk space will be used.
            Do you want to continue? [Y/n] yes
            Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 curl arm64 7.74.0-1.3+deb11u7 [265 kB]
            Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-kernel arm64 1:1.20230306-1 [26.8 MB]
            Get:3 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u7 [325 kB]
            Get:4 http://security.debian.org/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u4 [278 kB]
            Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u7 [321 kB]
            Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230302+923f5d70-1 [804 kB]
            Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 0~git20230301+54a781d-1 [280 kB]
            Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 linux-libc-dev arm64 1:1.20230306-1 [1,073 kB]
            Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230302+923f5d70-1 [226 kB]
            Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-v4l2 all 0.3.2-1 [14.4 kB]
            Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.9-1 [48.9 kB]
            Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-bootloader arm64 1:1.20230306-1 [4,540 kB]
            Fetched 35.0 MB in 4s (9,177 kB/s)
            Reading changelogs... Done
            (Reading database ... 37663 files and directories currently installed.)
            Preparing to unpack .../00-curl_7.74.0-1.3+deb11u7_arm64.deb ...
            Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
            Preparing to unpack .../01-libcurl4_7.74.0-1.3+deb11u7_arm64.deb ...
            Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
            Preparing to unpack .../02-raspberrypi-kernel_1%3a1.20230306-1_arm64.deb ...
            Leaving 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
            Leaving 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
            Leaving 'diversion of /boot/kernel7l.img to /usr/share/rpikernelhack/kernel7l.img by rpikernelhack'
            Adding 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
            Leaving 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
            Leaving 'diversion of /boot/bcm2708-rpi-b-rev1.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-rev1.dtb by rpikernelhack'
            Leaving 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
            Leaving 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
            Leaving 'diversion of /boot/bcm2708-rpi-zero-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero-w.dtb by rpikernelhack'
            Leaving 'diversion of /boot/bcm2708-rpi-zero.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero.dtb by rpikernelhack'
            Leaving 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
            Leaving 'diversion of /boot/bcm2709-rpi-cm2.dtb to /usr/share/rpikernelhack/bcm2709-rpi-cm2.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
            Adding 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
            Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
            Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
            Adding 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
            Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
            Adding 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
            Unpacking raspberrypi-kernel (1:1.20230306-1) over (1:1.20230106-1) ...
            run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84+ /boot/kernel.img
            run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
            run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
            run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
            Preparing to unpack .../03-libcamera0_0~git20230302+923f5d70-1_arm64.deb ...
            Unpacking libcamera0:arm64 (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
            Preparing to unpack .../04-libtiff5_4.2.0-1+deb11u4_arm64.deb ...
            Unpacking libtiff5:arm64 (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
            Preparing to unpack .../05-libcamera-apps-lite_0~git20230301+54a781d-1_arm64.deb ...
            Unpacking libcamera-apps-lite (0~git20230301+54a781d-1) over (0~git20230125+9f08463-1) ...
            Preparing to unpack .../06-libcurl3-gnutls_7.74.0-1.3+deb11u7_arm64.deb ...
            Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
            Preparing to unpack .../07-linux-libc-dev_1%3a1.20230306-1_arm64.deb ...
            Unpacking linux-libc-dev:arm64 (1:1.20230306-1) over (1:1.20230106-1) ...
            Preparing to unpack .../08-python3-libcamera_0~git20230302+923f5d70-1_arm64.deb ...
            Unpacking python3-libcamera (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
            Preparing to unpack .../09-python3-v4l2_0.3.2-1_all.deb ...
            Unpacking python3-v4l2 (0.3.2-1) over (0.3.1-1) ...
            Preparing to unpack .../10-python3-picamera2_0.3.9-1_all.deb ...
            Unpacking python3-picamera2 (0.3.9-1) over (0.3.8-1) ...
            Preparing to unpack .../11-raspberrypi-bootloader_1%3a1.20230306-1_arm64.deb ...
            Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
            Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
            Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
            Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
            Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
            Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
            Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
            Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
            Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
            Adding 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
            Adding 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
            Adding 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
            Adding 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
            Adding 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
            Adding 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
            Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
            Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
            Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
            Unpacking raspberrypi-bootloader (1:1.20230306-1) over (1:1.20230106-1) ...
            Setting up linux-libc-dev:arm64 (1:1.20230306-1) ...
            Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) ...
            Setting up raspberrypi-kernel (1:1.20230306-1) ...
            Removing 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
            Removing 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
            Removing 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
            Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
            Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
            Removing 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
            Removing 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
            Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
            run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84+ /boot/kernel.img
            run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84+ /boot/kernel.img
            run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7+ /boot/kernel7.img
            run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
            run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7l+ /boot/kernel7l.img
            run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
            run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v8+ /boot/kernel8.img
            run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
            Setting up python3-v4l2 (0.3.2-1) ...
            Setting up raspberrypi-bootloader (1:1.20230306-1) ...
            Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
            Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
            Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
            Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
            Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
            Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
            Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
            Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
            Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
            Removing 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
            Removing 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
            Removing 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
            Removing 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
            Removing 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
            Removing 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
            Removing 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
            Removing 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
            Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
            Setting up libcurl4:arm64 (7.74.0-1.3+deb11u7) ...
            Setting up libtiff5:arm64 (4.2.0-1+deb11u4) ...
            Setting up curl (7.74.0-1.3+deb11u7) ...
            Setting up libcamera0:arm64 (0~git20230302+923f5d70-1) ...
            Setting up python3-libcamera (0~git20230302+923f5d70-1) ...
            Setting up libcamera-apps-lite (0~git20230301+54a781d-1) ...
            Setting up python3-picamera2 (0.3.9-1) ...
            Processing triggers for man-db (2.9.4-2) ...
            Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
            paul@paul:~ $ sudo sed -i -e 's/defaults,noatime/defaults,noatime,commit=600/' /etc/fstab
            paul@paul:~ $ sudo reboot
            Connection to 192.168.178.41 closed by remote host.
            Connection to 192.168.178.41 closed.
            Paul@Saskias-Air ~ % curl sLf https://iobroker.net/install.sh | bash -
            % Total % Received % Xferd Average Speed Time Time Time Current
            Dload Upload Total Spent Left Speed
            0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: sLf
            100 65 100 65 0 0 218 0 --:--:-- --:--:-- --:--:-- 218
            bash: line 1: Moved: command not found
            Paul@Saskias-Air ~ % curl -sLf https://iobroker.net/install.sh | bash -
            library: loaded
            Library version=2022-12-09
            Welcome to the ioBroker installer!
            Installer version: 2022-12-22
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
            Password:
            sudo: brew: command not found
            Node.js not found. Installing...
            Cannot install Node.js using brew.
            Please download Node.js from https://nodejs.org/dist/v14.18.1/node-v16.15.1.pkg
            Then try to install ioBroker again!
            DJMarc75 Thomas Braun 3 Replies Last reply Reply Quote 0
            • DJMarc75
              DJMarc75 @pmther last edited by
              @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
              was ist das für ein Käse ? Aus einer gängigen Anleitung hast Du das sicher nicht.
              • DJMarc75
                und @Thomas-Braun hatte recht ... das ist NCHT auf dem PI 😉
                  pmther @DJMarc75 last edited by
                  @djmarc75 sagte in Erstinstallation Ip Adresse nicht gefunden:
                  doch, das ist aus der Anleitung kopiert
                  • DJMarc75
                    aus welcher genau ? gibts da einen Link zu der Anleitung ?
                      @djmarc75 okay, wie verbinde ich mich denn dann damit?
                      habe gedacht der Befehl ssh... wäre dafür
                        Thomas Braun Most Active @pmther last edited by
                        @pmther
                        Und der LoginPrompt verrät dir, dass du da eben NICHT auf dem Pi herumspringst sondern versuchst der Saskia auf ihr Air den ioBroker in der Linux-Version zu installieren.
                          ja, hier https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht/2
                            pmther @Thomas Braun last edited by
                            @thomas-braun okay und wie kann ich das ändern?
                              @pmther
                              Du musst dich natürlich nach dem erfolgten Reboot wieder auf dem Pi einloggen.
                              Ich dachte das sei selbstverständlich...
                              P 2 Replies Last reply Reply Quote 0
                              • DJMarc75
                                @pmther wenn Du den Raspi rebootest dann musst Du Dich ja auch danach neu drauf einloggen.
                                ok, sorry, kann man, muss man aber nicht.
                                  @thomas-braun okay, nein das war es für mich nicht. Mache sowas zum ersten mal und habe dadurch keinerlei Erfahrung damit gemacht
                                    @thomas-braun jetzt scheint es zu funktionieren. er hängt gerade beim dritten von vierten schritt aber das liegt dann an den geringem Arbeitsspeicher.
                                      @pmther
                                      Ja, da wirst du einiges an Geduld und sonstige Einschränkungen aufbringen müssen. Für mehr als einen ersten Einblick was möglich sein könnte wird das System nicht ausreichen.
                                        @thomas-braun jetzt ist alles fertig. unter der ip Adresse kann ich leider wieder nichts öffnen.. der gleiche Fehler wie vorhin
                                        • DJMarc75
                                          @pmther dann jetzt nochmal die Ausgabe von
                                          iob diag
                                          diesmal aber in CODETAGS posten und nicht einfach nur wild hier einfügen...
                                          mehr dazu gibt es hier:
                                          Thomas Braun P 3 Replies Last reply Reply Quote 1
                                            Thomas Braun Most Active @DJMarc75 last edited by
                                            Wenn man wie vorgesehen den Output kopiert sind sie codetags beim diag schon dabei. 🙂
                                            5606
