Erstinstallation Ip Adresse nicht gefunden
Der PI3 spricht 64bit. Das kann also nicht das Problem sein.
@pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
habe alles auf dem Terminal vom Mac aus gemacht und so wie es in der Anleitung steht
Dann zeig mal das vollständige Terminal. Inkl. der vollständigen Eingabezeile.
In CodeTags eingebettet.Ich halte da jede Wette, das du da gar nicht auf dem Raspberry eingeloggt bist...
Last login: Thu Mar 16 19:20:20 on ttys000
Paul@Saskias-Air ~ % ssh paul@192.168.178.41
The authenticity of host '192.168.178.41 (192.168.178.41)' can't be established.
ED25519 key fingerprint is SHA256:vFjguricu5KqpRk0lsjyEx9OxnGTuzr0BL0LehEYF5E.
This key is not known by any other names
Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
Warning: Permanently added '192.168.178.41' (ED25519) to the list of known hosts.
paul@192.168.178.41's password:
Linux paul 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
paul@paul:~ $ sudo apt update && sudo apt full-upgrade
Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
Hit:2 http://deb.debian.org/debian bullseye InRelease
Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [232 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [232 kB]
Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [154 kB]
Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [315 kB]
Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [307 kB]
Fetched 1,355 kB in 2s (632 kB/s)
Reading package lists... Done
Building dependency tree... Done
12 packages can be upgraded. Run 'apt list --upgradable' to see them.
Calculating upgrade... Done
The following packages will be upgraded:
curl libcamera-apps-lite libcamera0 libcurl3-gnutls libcurl4 libtiff5
linux-libc-dev python3-libcamera python3-picamera2 python3-v4l2
raspberrypi-bootloader raspberrypi-kernel
12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 35.0 MB of archives.
After this operation, 38.9 kB of additional disk space will be used.
Do you want to continue? [Y/n] yes
Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 curl arm64 7.74.0-1.3+deb11u7 [265 kB]
Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-kernel arm64 1:1.20230306-1 [26.8 MB]
Get:3 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u7 [325 kB]
Get:4 http://security.debian.org/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u4 [278 kB]
Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u7 [321 kB]
Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230302+923f5d70-1 [804 kB]
Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 0~git20230301+54a781d-1 [280 kB]
Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 linux-libc-dev arm64 1:1.20230306-1 [1,073 kB]
Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230302+923f5d70-1 [226 kB]
Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-v4l2 all 0.3.2-1 [14.4 kB]
Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.9-1 [48.9 kB]
Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-bootloader arm64 1:1.20230306-1 [4,540 kB]
Fetched 35.0 MB in 4s (9,177 kB/s)
Reading changelogs... Done
(Reading database ... 37663 files and directories currently installed.)
Preparing to unpack .../00-curl_7.74.0-1.3+deb11u7_arm64.deb ...
Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
Preparing to unpack .../01-libcurl4_7.74.0-1.3+deb11u7_arm64.deb ...
Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
Preparing to unpack .../02-raspberrypi-kernel_1%3a1.20230306-1_arm64.deb ...
Leaving 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Leaving 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Leaving 'diversion of /boot/kernel7l.img to /usr/share/rpikernelhack/kernel7l.img by rpikernelhack'
Adding 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
Leaving 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Leaving 'diversion of /boot/bcm2708-rpi-b-rev1.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-rev1.dtb by rpikernelhack'
Leaving 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Leaving 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Leaving 'diversion of /boot/bcm2708-rpi-zero-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero-w.dtb by rpikernelhack'
Leaving 'diversion of /boot/bcm2708-rpi-zero.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero.dtb by rpikernelhack'
Leaving 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Leaving 'diversion of /boot/bcm2709-rpi-cm2.dtb to /usr/share/rpikernelhack/bcm2709-rpi-cm2.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Adding 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Adding 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
Unpacking raspberrypi-kernel (1:1.20230306-1) over (1:1.20230106-1) ...
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84+ /boot/kernel.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
Preparing to unpack .../03-libcamera0_0~git20230302+923f5d70-1_arm64.deb ...
Unpacking libcamera0:arm64 (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
Preparing to unpack .../04-libtiff5_4.2.0-1+deb11u4_arm64.deb ...
Unpacking libtiff5:arm64 (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
Preparing to unpack .../05-libcamera-apps-lite_0~git20230301+54a781d-1_arm64.deb ...
Unpacking libcamera-apps-lite (0~git20230301+54a781d-1) over (0~git20230125+9f08463-1) ...
Preparing to unpack .../06-libcurl3-gnutls_7.74.0-1.3+deb11u7_arm64.deb ...
Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
Preparing to unpack .../07-linux-libc-dev_1%3a1.20230306-1_arm64.deb ...
Unpacking linux-libc-dev:arm64 (1:1.20230306-1) over (1:1.20230106-1) ...
Preparing to unpack .../08-python3-libcamera_0~git20230302+923f5d70-1_arm64.deb ...
Unpacking python3-libcamera (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
Preparing to unpack .../09-python3-v4l2_0.3.2-1_all.deb ...
Unpacking python3-v4l2 (0.3.2-1) over (0.3.1-1) ...
Preparing to unpack .../10-python3-picamera2_0.3.9-1_all.deb ...
Unpacking python3-picamera2 (0.3.9-1) over (0.3.8-1) ...
Preparing to unpack .../11-raspberrypi-bootloader_1%3a1.20230306-1_arm64.deb ...
Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Adding 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
Adding 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
Adding 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
Adding 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
Adding 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
Adding 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Unpacking raspberrypi-bootloader (1:1.20230306-1) over (1:1.20230106-1) ...
Setting up linux-libc-dev:arm64 (1:1.20230306-1) ...
Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) ...
Setting up raspberrypi-kernel (1:1.20230306-1) ...
Removing 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Removing 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v8+ /boot/kernel8.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
Setting up python3-v4l2 (0.3.2-1) ...
Setting up raspberrypi-bootloader (1:1.20230306-1) ...
Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Removing 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
Removing 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
Removing 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
Removing 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
Removing 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
Removing 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
Removing 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
Removing 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Setting up libcurl4:arm64 (7.74.0-1.3+deb11u7) ...
Setting up libtiff5:arm64 (4.2.0-1+deb11u4) ...
Setting up curl (7.74.0-1.3+deb11u7) ...
Setting up libcamera0:arm64 (0~git20230302+923f5d70-1) ...
Setting up python3-libcamera (0~git20230302+923f5d70-1) ...
Setting up libcamera-apps-lite (0~git20230301+54a781d-1) ...
Setting up python3-picamera2 (0.3.9-1) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
paul@paul:~ $ sudo sed -i -e 's/defaults,noatime/defaults,noatime,commit=600/' /etc/fstab
paul@paul:~ $ sudo reboot
Connection to 192.168.178.41 closed by remote host.
Connection to 192.168.178.41 closed.
Paul@Saskias-Air ~ % curl sLf https://iobroker.net/install.sh | bash -
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: sLf
100 65 100 65 0 0 218 0 --:--:-- --:--:-- --:--:-- 218
bash: line 1: Moved: command not found
Paul@Saskias-Air ~ % curl -sLf https://iobroker.net/install.sh | bash -
library: loaded
Library version=2022-12-09==========================================================================
Welcome to the ioBroker installer! Installer version: 2022-12-22 You might need to enter your password a couple of times.
Installing prerequisites (1/4)Password:
sudo: brew: command not found==========================================================================
Node.js not found. Installing...
Cannot install Node.js using brew.
Please download Node.js from https://nodejs.org/dist/v14.18.1/node-v16.15.1.pkg
Then try to install ioBroker again! -
@pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
was ist das für ein Käse ? Aus einer gängigen Anleitung hast Du das sicher nicht.
und @Thomas-Braun hatte recht ... das ist NCHT auf dem PI
@djmarc75 sagte in Erstinstallation Ip Adresse nicht gefunden:
doch, das ist aus der Anleitung kopiert
aus welcher genau ? gibts da einen Link zu der Anleitung ?
@djmarc75 okay, wie verbinde ich mich denn dann damit?
habe gedacht der Befehl ssh... wäre dafür -
Und der LoginPrompt verrät dir, dass du da eben NICHT auf dem Pi herumspringst sondern versuchst der Saskia auf ihr Air den ioBroker in der Linux-Version zu installieren.
ja, hier https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht/2 -
@thomas-braun okay und wie kann ich das ändern?
Du musst dich natürlich nach dem erfolgten Reboot wieder auf dem Pi einloggen.
Ich dachte das sei selbstverständlich... -
@pmther wenn Du den Raspi rebootest dann musst Du Dich ja auch danach neu drauf einloggen.
ok, sorry, kann man, muss man aber nicht.
@thomas-braun okay, nein das war es für mich nicht. Mache sowas zum ersten mal und habe dadurch keinerlei Erfahrung damit gemacht
@thomas-braun jetzt scheint es zu funktionieren. er hängt gerade beim dritten von vierten schritt aber das liegt dann an den geringem Arbeitsspeicher.
Ja, da wirst du einiges an Geduld und sonstige Einschränkungen aufbringen müssen. Für mehr als einen ersten Einblick was möglich sein könnte wird das System nicht ausreichen.
@thomas-braun jetzt ist alles fertig. unter der ip Adresse kann ich leider wieder nichts öffnen.. der gleiche Fehler wie vorhin
@pmther dann jetzt nochmal die Ausgabe von
iob diag
diesmal aber in CODETAGS posten und nicht einfach nur wild hier einfügen...
mehr dazu gibt es hier:
Wenn man wie vorgesehen den Output kopiert sind sie codetags beim diag schon dabei.
Skript v.2023-01-02 *** BASE SYSTEM *** Model : Raspberry Pi 3 Model A Plus Rev 1.0 Architecture: aarch64 Docker: false Virtualization: none Distributor ID: Debian Description: Debian GNU/Linux 11 (bullseye) Release: 11 Codename: bullseye PRETTY_NAME="Debian GNU/Linux 11 (bullseye)" NAME="Debian GNU/Linux" VERSION_ID="11" VERSION="11 (bullseye)" VERSION_CODENAME=bullseye ID=debian HOME_URL="https://www.debian.org/" SUPPORT_URL="https://www.debian.org/support" BUG_REPORT_URL="https://bugs.debian.org/" Systemuptime and Load: 20:39:35 up 42 min, 1 user, load average: 1.04, 1.46, 4.30 CPU threads: 4 *** Time and Time Zones *** Thu Mar 16 19:39:35 UTC 2023 Thu Mar 16 20:39:35 CET 2023 CET +0100 Europe/Berlin *** User and Groups *** paul /home/paul paul adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi *** X-Server-Setup *** X-Server: false Desktop: Terminal: tty Boot Target: multi-user.target *** MEMORY *** total used free shared buff/cache available Mem: 419M 107M 125M 0.0K 185M 256M Swap: 99M 31M 68M Total: 519M 139M 193M 419 M total memory 108 M used memory 94 M active memory 118 M inactive memory 125 M free memory 10 M buffer memory 174 M swap cache 99 M total swap 31 M used swap 68 M free swap *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/root ext4 29G 2.2G 26G 8% / devtmpfs devtmpfs 80M 0 80M 0% /dev tmpfs tmpfs 210M 0 210M 0% /dev/shm tmpfs tmpfs 84M 1020K 83M 2% /run tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 255M 32M 224M 13% /boot tmpfs tmpfs 42M 0 42M 0% /run/user/1000 Messages in dmesg: [Thu Mar 16 19:57:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=c4a98718-02 rootfstype=ext4 fsck.repair=yes rootwait [Thu Mar 16 19:57:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [Thu Mar 16 19:57:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [Thu Mar 16 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none. Show mounted filesystems (real ones only): TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime,commit=600 `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 481M /var/ 178M /var/cache 172M /var/cache/apt 147M /var/lib 122M /var/lib/apt/lists /opt/iobroker/backups: du: cannot access '/opt/iobroker/backups/': No such file or directory /opt/iobroker/iobroker-data: 3.2M /opt/iobroker/iobroker-data/ 4.0K /opt/iobroker/iobroker-data/states.jsonl.lock 4.0K /opt/iobroker/iobroker-data/objects.jsonl.lock 4.0K /opt/iobroker/iobroker-data/backup-objects The five largest files in iobroker-data are: 3.1M /opt/iobroker/iobroker-data/objects.jsonl 36K /opt/iobroker/iobroker-data/states.jsonl 8.0K /opt/iobroker/iobroker-data/iobroker.json *** NodeJS-Installation *** /usr/bin/nodejs v16.19.1 /usr/bin/node v16.19.1 /usr/bin/npm 8.19.3 /usr/bin/npx 8.19.3 nodejs: Installed: 16.19.1-deb-1nodesource1 Candidate: 16.19.1-deb-1nodesource1 Version table: *** 16.19.1-deb-1nodesource1 500 500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages 100 /var/lib/dpkg/status 12.22.12~dfsg-1~deb11u3 500 500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages 12.22.5~dfsg-2~11u1 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages Temp directories causing npm8 problem: 0 *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Core adapters versions js-controller: 4.0.24 admin: 6.3.5 javascript: "javascript" not found npm ERR! code ELSPROBLEMS npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin npm ERR! invalid: iobroker.backitup@2.5.12 /opt/iobroker/node_modules/iobroker.backitup npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller npm ERR! A complete log of this run can be found in: npm ERR! /home/paul/.npm/_logs/2023-03-16T19_39_57_392Z-debug-0.log Adapters from github: 0 Adapter State + instance is alive Enabled adapters with bindings ioBroker-Repositories stable : http://download.iobroker.net/sources-dist.json beta : http://download.iobroker.net/sources-dist-latest.json Active repo(s): stable Installed ioBroker-Instances Used repository: stable Adapter "admin" : 6.3.5 , installed 6.3.5 Adapter "backitup" : 2.5.12 , installed 2.5.12 Adapter "discovery" : 3.1.0 , installed 3.1.0 Controller "js-controller": 4.0.24 , installed 4.0.24 Objects and States Please stand by - This may take a while Objects: 43 States: 25 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bullseye InRelease Hit:2 http://security.debian.org/debian-security bullseye-security InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 30946 6898/iobroker.js-co tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 30939 6898/iobroker.js-co tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12810 483/sshd: /usr/sbin tcp6 0 0 :::22 :::* LISTEN 0 12821 483/sshd: /usr/sbin udp 0 0 0.0.0.0:68 0.0.0.0:* 0 12111 654/dhcpcd udp 0 0 0.0.0.0:58815 0.0.0.0:* 108 9723 361/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 9721 361/avahi-daemon: r udp6 0 0 :::546 :::* 0 9776 654/dhcpcd udp6 0 0 :::55504 :::* 108 9724 361/avahi-daemon: r udp6 0 0 :::5353 :::* 108 9722 361/avahi-daemon: r *** Log File - Last 25 Lines *** 2023-03-16 20:26:10.242 - info: host.paul iobroker.js-controller version 4.0.24 js-controller starting 2023-03-16 20:26:10.256 - info: host.paul Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker 2023-03-16 20:26:10.295 - info: host.paul hostname: paul, node: v16.19.1 2023-03-16 20:26:10.298 - info: host.paul ip addresses: 192.168.178.41 2a02:8108:83c0:6be6:6e48:546e:9c43:f897 fe80::f368:a842:35d3:70a 2023-03-16 20:26:11.530 - info: host.paul connected to Objects and States 2023-03-16 20:26:11.639 - info: host.paul Node.js version has changed from unknown to 16.19.1 2023-03-16 20:26:11.774 - info: host.paul Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node 2023-03-16 20:26:12.015 - info: host.paul added notifications configuration of host 2023-03-16 20:26:13.212 - info: host.paul no instances found 2023-03-16 20:26:13.214 - info: host.paul no instances found
