    3. Einsteigerfragen
    4. Erstinstallation Ip Adresse nicht gefunden
      Thomas Braun Most Active @pmther last edited by Thomas Braun
      @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
      habe alles auf dem Terminal vom Mac aus gemacht und so wie es in der Anleitung steht
      Dann zeig mal das vollständige Terminal. Inkl. der vollständigen Eingabezeile.
      In CodeTags eingebettet.
      Ich halte da jede Wette, das du da gar nicht auf dem Raspberry eingeloggt bist...
        pmther @Thomas Braun last edited by
        Last login: Thu Mar 16 19:20:20 on ttys000
        Paul@Saskias-Air ~ % ssh paul@192.168.178.41
        The authenticity of host '192.168.178.41 (192.168.178.41)' can't be established.
        ED25519 key fingerprint is SHA256:vFjguricu5KqpRk0lsjyEx9OxnGTuzr0BL0LehEYF5E.
        This key is not known by any other names
        Are you sure you want to continue connecting (yes/no/[fingerprint])? yes
        Warning: Permanently added '192.168.178.41' (ED25519) to the list of known hosts.
        paul@192.168.178.41's password:
        Linux paul 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        paul@paul:~ $ sudo apt update && sudo apt full-upgrade
        Get:1 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
        Get:4 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
        Get:5 http://security.debian.org/debian-security bullseye-security/main armhf Packages [232 kB]
        Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [232 kB]
        Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [154 kB]
        Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [315 kB]
        Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [307 kB]
        Fetched 1,355 kB in 2s (632 kB/s)
        Reading package lists... Done
        Building dependency tree... Done
        12 packages can be upgraded. Run 'apt list --upgradable' to see them.
        Calculating upgrade... Done
        The following packages will be upgraded:
        curl libcamera-apps-lite libcamera0 libcurl3-gnutls libcurl4 libtiff5
        linux-libc-dev python3-libcamera python3-picamera2 python3-v4l2
        raspberrypi-bootloader raspberrypi-kernel
        12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        Need to get 35.0 MB of archives.
        After this operation, 38.9 kB of additional disk space will be used.
        Do you want to continue? [Y/n] yes
        Get:1 http://security.debian.org/debian-security bullseye-security/main arm64 curl arm64 7.74.0-1.3+deb11u7 [265 kB]
        Get:2 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-kernel arm64 1:1.20230306-1 [26.8 MB]
        Get:3 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u7 [325 kB]
        Get:4 http://security.debian.org/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u4 [278 kB]
        Get:5 http://security.debian.org/debian-security bullseye-security/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u7 [321 kB]
        Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera0 arm64 0~git20230302+923f5d70-1 [804 kB]
        Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 libcamera-apps-lite arm64 0~git20230301+54a781d-1 [280 kB]
        Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 linux-libc-dev arm64 1:1.20230306-1 [1,073 kB]
        Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-libcamera arm64 0~git20230302+923f5d70-1 [226 kB]
        Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-v4l2 all 0.3.2-1 [14.4 kB]
        Get:11 http://archive.raspberrypi.org/debian bullseye/main arm64 python3-picamera2 all 0.3.9-1 [48.9 kB]
        Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 raspberrypi-bootloader arm64 1:1.20230306-1 [4,540 kB]
        Fetched 35.0 MB in 4s (9,177 kB/s)
        Reading changelogs... Done
        (Reading database ... 37663 files and directories currently installed.)
        Preparing to unpack .../00-curl_7.74.0-1.3+deb11u7_arm64.deb ...
        Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
        Preparing to unpack .../01-libcurl4_7.74.0-1.3+deb11u7_arm64.deb ...
        Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
        Preparing to unpack .../02-raspberrypi-kernel_1%3a1.20230306-1_arm64.deb ...
        Leaving 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
        Leaving 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
        Leaving 'diversion of /boot/kernel7l.img to /usr/share/rpikernelhack/kernel7l.img by rpikernelhack'
        Adding 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
        Leaving 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
        Leaving 'diversion of /boot/bcm2708-rpi-b-rev1.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-rev1.dtb by rpikernelhack'
        Leaving 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
        Leaving 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
        Leaving 'diversion of /boot/bcm2708-rpi-zero-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero-w.dtb by rpikernelhack'
        Leaving 'diversion of /boot/bcm2708-rpi-zero.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero.dtb by rpikernelhack'
        Leaving 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
        Leaving 'diversion of /boot/bcm2709-rpi-cm2.dtb to /usr/share/rpikernelhack/bcm2709-rpi-cm2.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
        Adding 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
        Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
        Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
        Adding 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
        Adding 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
        Adding 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
        Unpacking raspberrypi-kernel (1:1.20230306-1) over (1:1.20230106-1) ...
        run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84+ /boot/kernel.img
        run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
        run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
        run-parts: executing /etc/kernel/postrm.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
        Preparing to unpack .../03-libcamera0_0~git20230302+923f5d70-1_arm64.deb ...
        Unpacking libcamera0:arm64 (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
        Preparing to unpack .../04-libtiff5_4.2.0-1+deb11u4_arm64.deb ...
        Unpacking libtiff5:arm64 (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
        Preparing to unpack .../05-libcamera-apps-lite_0~git20230301+54a781d-1_arm64.deb ...
        Unpacking libcamera-apps-lite (0~git20230301+54a781d-1) over (0~git20230125+9f08463-1) ...
        Preparing to unpack .../06-libcurl3-gnutls_7.74.0-1.3+deb11u7_arm64.deb ...
        Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
        Preparing to unpack .../07-linux-libc-dev_1%3a1.20230306-1_arm64.deb ...
        Unpacking linux-libc-dev:arm64 (1:1.20230306-1) over (1:1.20230106-1) ...
        Preparing to unpack .../08-python3-libcamera_0~git20230302+923f5d70-1_arm64.deb ...
        Unpacking python3-libcamera (0~git20230302+923f5d70-1) over (0~git20230124+9b860a66-1) ...
        Preparing to unpack .../09-python3-v4l2_0.3.2-1_all.deb ...
        Unpacking python3-v4l2 (0.3.2-1) over (0.3.1-1) ...
        Preparing to unpack .../10-python3-picamera2_0.3.9-1_all.deb ...
        Unpacking python3-picamera2 (0.3.9-1) over (0.3.8-1) ...
        Preparing to unpack .../11-raspberrypi-bootloader_1%3a1.20230306-1_arm64.deb ...
        Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
        Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
        Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
        Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
        Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
        Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
        Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
        Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
        Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
        Adding 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
        Adding 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
        Adding 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
        Adding 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
        Adding 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
        Adding 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
        Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
        Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
        Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
        Unpacking raspberrypi-bootloader (1:1.20230306-1) over (1:1.20230106-1) ...
        Setting up linux-libc-dev:arm64 (1:1.20230306-1) ...
        Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u7) ...
        Setting up raspberrypi-kernel (1:1.20230306-1) ...
        Removing 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
        Removing 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
        Removing 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
        Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
        Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
        Removing 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/arducam-64mp.dtbo to /usr/share/rpikernelhack/overlays/arducam-64mp.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/arducam-pivariety.dtbo to /usr/share/rpikernelhack/overlays/arducam-pivariety.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/audioinjector-bare-i2s.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-bare-i2s.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/camera-mux-2port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-2port.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/camera-mux-4port.dtbo to /usr/share/rpikernelhack/overlays/camera-mux-4port.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/cirrus-wm5102.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/cm-swap-i2c0.dtbo to /usr/share/rpikernelhack/overlays/cm-swap-i2c0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/crystalfontz-cfa050_pi_m.dtbo to /usr/share/rpikernelhack/overlays/crystalfontz-cfa050_pi_m.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dacberry400.dtbo to /usr/share/rpikernelhack/overlays/dacberry400.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dionaudio-kiwi.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-kiwi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/disable-emmc2.dtbo to /usr/share/rpikernelhack/overlays/disable-emmc2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gc9a01.dtbo to /usr/share/rpikernelhack/overlays/gc9a01.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-hog.dtbo to /usr/share/rpikernelhack/overlays/gpio-hog.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-amp3.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp3.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-fan.dtbo to /usr/share/rpikernelhack/overlays/i2c-fan.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2s-dac.dtbo to /usr/share/rpikernelhack/overlays/i2s-dac.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx258.dtbo to /usr/share/rpikernelhack/overlays/imx258.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx296.dtbo to /usr/share/rpikernelhack/overlays/imx296.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx327.dtbo to /usr/share/rpikernelhack/overlays/imx327.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx462.dtbo to /usr/share/rpikernelhack/overlays/imx462.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/imx708.dtbo to /usr/share/rpikernelhack/overlays/imx708.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
        Removing 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/proto-codec.dtbo to /usr/share/rpikernelhack/overlays/proto-codec.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/pwm1.dtbo to /usr/share/rpikernelhack/overlays/pwm1.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ramoops-pi4.dtbo to /usr/share/rpikernelhack/overlays/ramoops-pi4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ramoops.dtbo to /usr/share/rpikernelhack/overlays/ramoops.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-codeczero.dtbo to /usr/share/rpikernelhack/overlays/rpi-codeczero.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-dacplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacplus.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-dacpro.dtbo to /usr/share/rpikernelhack/overlays/rpi-dacpro.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-digiampplus.dtbo to /usr/share/rpikernelhack/overlays/rpi-digiampplus.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-sense-v2.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense-v2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/watterott-display.dtbo to /usr/share/rpikernelhack/overlays/watterott-display.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
        Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
        run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84+ /boot/kernel.img
        run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84+ /boot/kernel.img
        run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7+ /boot/kernel7.img
        run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7+ /boot/kernel7.img
        run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v7l+ /boot/kernel7l.img
        run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v7l+ /boot/kernel7l.img
        run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.84-v8+ /boot/kernel8.img
        run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.15.84-v8+ /boot/kernel8.img
        Setting up python3-v4l2 (0.3.2-1) ...
        Setting up raspberrypi-bootloader (1:1.20230306-1) ...
        Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
        Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
        Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
        Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
        Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
        Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
        Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
        Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
        Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
        Removing 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
        Removing 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
        Removing 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
        Removing 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
        Removing 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
        Removing 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
        Removing 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
        Removing 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
        Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
        Setting up libcurl4:arm64 (7.74.0-1.3+deb11u7) ...
        Setting up libtiff5:arm64 (4.2.0-1+deb11u4) ...
        Setting up curl (7.74.0-1.3+deb11u7) ...
        Setting up libcamera0:arm64 (0~git20230302+923f5d70-1) ...
        Setting up python3-libcamera (0~git20230302+923f5d70-1) ...
        Setting up libcamera-apps-lite (0~git20230301+54a781d-1) ...
        Setting up python3-picamera2 (0.3.9-1) ...
        Processing triggers for man-db (2.9.4-2) ...
        Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
        paul@paul:~ $ sudo sed -i -e 's/defaults,noatime/defaults,noatime,commit=600/' /etc/fstab
        paul@paul:~ $ sudo reboot
        Connection to 192.168.178.41 closed by remote host.
        Connection to 192.168.178.41 closed.
        Paul@Saskias-Air ~ % curl sLf https://iobroker.net/install.sh | bash -
        % Total % Received % Xferd Average Speed Time Time Time Current
        Dload Upload Total Spent Left Speed
        0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (6) Could not resolve host: sLf
        100 65 100 65 0 0 218 0 --:--:-- --:--:-- --:--:-- 218
        bash: line 1: Moved: command not found
        Paul@Saskias-Air ~ % curl -sLf https://iobroker.net/install.sh | bash -
        library: loaded
        Library version=2022-12-09
        Welcome to the ioBroker installer!
        Installer version: 2022-12-22
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
        Password:
        sudo: brew: command not found
        Node.js not found. Installing...
        Cannot install Node.js using brew.
        Please download Node.js from https://nodejs.org/dist/v14.18.1/node-v16.15.1.pkg
        Then try to install ioBroker again!
        DJMarc75 Thomas Braun 3 Replies Last reply Reply Quote 0
        • DJMarc75
          DJMarc75 @pmther last edited by
          @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
          was ist das für ein Käse ? Aus einer gängigen Anleitung hast Du das sicher nicht.
          • DJMarc75
            und @Thomas-Braun hatte recht ... das ist NCHT auf dem PI 😉
              pmther @DJMarc75 last edited by
              @djmarc75 sagte in Erstinstallation Ip Adresse nicht gefunden:
              doch, das ist aus der Anleitung kopiert
              • DJMarc75
                aus welcher genau ? gibts da einen Link zu der Anleitung ?
                  @djmarc75 okay, wie verbinde ich mich denn dann damit?
                  habe gedacht der Befehl ssh... wäre dafür
                    Thomas Braun Most Active @pmther last edited by
                    @pmther
                    Und der LoginPrompt verrät dir, dass du da eben NICHT auf dem Pi herumspringst sondern versuchst der Saskia auf ihr Air den ioBroker in der Linux-Version zu installieren.
                      ja, hier https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht/2
                        pmther @Thomas Braun last edited by
                        @thomas-braun okay und wie kann ich das ändern?
                          @pmther
                          Du musst dich natürlich nach dem erfolgten Reboot wieder auf dem Pi einloggen.
                          Ich dachte das sei selbstverständlich...
                          P 2 Replies Last reply Reply Quote 0
                          • DJMarc75
                            @pmther wenn Du den Raspi rebootest dann musst Du Dich ja auch danach neu drauf einloggen.
                            ok, sorry, kann man, muss man aber nicht.
                              @thomas-braun okay, nein das war es für mich nicht. Mache sowas zum ersten mal und habe dadurch keinerlei Erfahrung damit gemacht
                                @thomas-braun jetzt scheint es zu funktionieren. er hängt gerade beim dritten von vierten schritt aber das liegt dann an den geringem Arbeitsspeicher.
                                  @pmther
                                  Ja, da wirst du einiges an Geduld und sonstige Einschränkungen aufbringen müssen. Für mehr als einen ersten Einblick was möglich sein könnte wird das System nicht ausreichen.
                                    @thomas-braun jetzt ist alles fertig. unter der ip Adresse kann ich leider wieder nichts öffnen.. der gleiche Fehler wie vorhin
                                    • DJMarc75
                                      @pmther dann jetzt nochmal die Ausgabe von
                                      iob diag
                                      diesmal aber in CODETAGS posten und nicht einfach nur wild hier einfügen...
                                      mehr dazu gibt es hier:
                                      Thomas Braun P 3 Replies Last reply Reply Quote 1
                                        Thomas Braun Most Active @DJMarc75 last edited by
                                        Wenn man wie vorgesehen den Output kopiert sind sie codetags beim diag schon dabei. 🙂
                                          @djmarc75 @Thomas-Braun
                                          Skript v.2023-01-02
                                          *** BASE SYSTEM ***
                                          Model		: Raspberry Pi 3 Model A Plus Rev 1.0
                                          Architecture: 	aarch64
                                          Docker: 	false
                                          Virtualization: none
                                          Distributor ID:	Debian
                                          Description:	Debian GNU/Linux 11 (bullseye)
                                          Release:	11
                                          Codename:	bullseye
                                          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                                          NAME="Debian GNU/Linux"
                                          VERSION_ID="11"
                                          VERSION="11 (bullseye)"
                                          VERSION_CODENAME=bullseye
                                          ID=debian
                                          HOME_URL="https://www.debian.org/"
                                          SUPPORT_URL="https://www.debian.org/support"
                                          BUG_REPORT_URL="https://bugs.debian.org/"
                                          Systemuptime and Load:
                                           20:39:35 up 42 min,  1 user,  load average: 1.04, 1.46, 4.30
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                          Thu Mar 16 19:39:35 UTC 2023
                                          Thu Mar 16 20:39:35 CET 2023
                                          CET +0100
                                          Europe/Berlin
                                          *** User and Groups ***
                                          paul
                                          /home/paul
                                          paul adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
                                          *** X-Server-Setup ***
                                          X-Server: 	false
                                          Desktop:
                                          Terminal: 	tty
                                          Boot Target: 	multi-user.target
                                          *** MEMORY ***
                                          Mem:            419M        107M        125M        0.0K        185M        256M
                                          Swap:            99M         31M         68M
                                          Total:          519M        139M        193M
                                                    419 M total memory
                                                    108 M used memory
                                                     94 M active memory
                                                    118 M inactive memory
                                                    125 M free memory
                                                     10 M buffer memory
                                                    174 M swap cache
                                                     99 M total swap
                                                     31 M used swap
                                                     68 M free swap
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       29G  2.2G   26G   8% /
                                          devtmpfs       devtmpfs   80M     0   80M   0% /dev
                                          tmpfs          tmpfs     210M     0  210M   0% /dev/shm
                                          tmpfs          tmpfs      84M 1020K   83M   2% /run
                                          /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                                          tmpfs          tmpfs      42M     0   42M   0% /run/user/1000
                                          Messages in dmesg:
                                          [Thu Mar 16 19:57:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4a98718-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Thu Mar 16 19:57:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                          [Thu Mar 16 19:57:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Thu Mar 16 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
                                          Show mounted filesystems (real ones only):
                                          TARGET  SOURCE         FSTYPE OPTIONS
                                          /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          481M	/var/
                                          178M	/var/cache
                                          172M	/var/cache/apt
                                          147M	/var/lib
                                          122M	/var/lib/apt/lists
                                          /opt/iobroker/backups:
                                          du: cannot access '/opt/iobroker/backups/': No such file or directory
                                          /opt/iobroker/iobroker-data:
                                          3.2M	/opt/iobroker/iobroker-data/
                                          4.0K	/opt/iobroker/iobroker-data/states.jsonl.lock
                                          4.0K	/opt/iobroker/iobroker-data/objects.jsonl.lock
                                          4.0K	/opt/iobroker/iobroker-data/backup-objects
                                          3.1M	/opt/iobroker/iobroker-data/objects.jsonl
                                          36K	/opt/iobroker/iobroker-data/states.jsonl
                                          8.0K	/opt/iobroker/iobroker-data/iobroker.json
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs 	v16.19.1
                                          /usr/bin/node 		v16.19.1
                                          /usr/bin/npm 		8.19.3
                                          /usr/bin/npx 		8.19.3
                                          nodejs:
                                            Installed: 16.19.1-deb-1nodesource1
                                            Candidate: 16.19.1-deb-1nodesource1
                                            Version table:
                                           *** 16.19.1-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                                  100 /var/lib/dpkg/status
                                               12.22.12~dfsg-1~deb11u3 500
                                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                               12.22.5~dfsg-2~11u1 500
                                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller: 	4.0.24
                                          admin: 		6.3.5
                                          javascript: 	"javascript" not found
                                          npm ERR! code ELSPROBLEMS
                                          npm ERR! invalid: iobroker.admin@6.3.5 /opt/iobroker/node_modules/iobroker.admin
                                          npm ERR! invalid: iobroker.backitup@2.5.12 /opt/iobroker/node_modules/iobroker.backitup
                                          npm ERR! invalid: iobroker.discovery@3.1.0 /opt/iobroker/node_modules/iobroker.discovery
                                          npm ERR! invalid: iobroker.js-controller@4.0.24 /opt/iobroker/node_modules/iobroker.js-controller
                                          npm ERR!     /home/paul/.npm/_logs/2023-03-16T19_39_57_392Z-debug-0.log
                                          Adapters from github: 	0
                                          Adapter State
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): stable
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "admin"        : 6.3.5    , installed 6.3.5
                                          Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                                          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
                                          Controller "js-controller": 4.0.24   , installed 4.0.24
                                          Objects and States
                                          Objects: 	43
                                          States: 	25
                                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                                          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30946      6898/iobroker.js-co
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30939      6898/iobroker.js-co
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12810      483/sshd: /usr/sbin
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12821      483/sshd: /usr/sbin
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12111      654/dhcpcd
                                          udp        0      0 0.0.0.0:58815           0.0.0.0:*                           108        9723       361/avahi-daemon: r
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9721       361/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          9776       654/dhcpcd
                                          udp6       0      0 :::55504                :::*                                108        9724       361/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        9722       361/avahi-daemon: r
                                          2023-03-16 20:26:10.242  - info: host.paul iobroker.js-controller version 4.0.24 js-controller starting
                                          2023-03-16 20:26:10.256  - info: host.paul Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                          2023-03-16 20:26:10.295  - info: host.paul hostname: paul, node: v16.19.1
                                          2023-03-16 20:26:10.298  - info: host.paul ip addresses: 192.168.178.41 2a02:8108:83c0:6be6:6e48:546e:9c43:f897 fe80::f368:a842:35d3:70a
                                          2023-03-16 20:26:11.530  - info: host.paul connected to Objects and States
                                          2023-03-16 20:26:11.639  - info: host.paul Node.js version has changed from unknown to 16.19.1
                                          2023-03-16 20:26:11.774  - info: host.paul Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
                                          2023-03-16 20:26:12.015  - info: host.paul added notifications configuration of host
                                          2023-03-16 20:26:13.212  - info: host.paul  no instances found
                                          2023-03-16 20:26:13.214  - info: host.paul no instances found
                                            @djmarc75 Danke, so sieht es doch gleich viel besser aus 🙂
                                            5606
