Node Red Victron mqqt schreiben
@mickym
ja das value müsste noch weg, eine zahl reicht. zum visualisieren!MEGA! Danke Dir!!!!!
@mousenray sagte in Node Red Victron mqqt schreiben:
Na dann musst an der payload ja gar nichts machen - und stellst das auf on release ein. Dann kommt nur der letzte Wert als Zahl raus.
Brauche da noch mal Hilfe, ich möchte das sich der Status des Set Points mit ändert.
Also das mir Änderungen die ich zb an der Wallbox app mache, am Slider mit aktualisiert wird.Danke
[ { "id": "642daddb926630e9", "type": "mqtt out", "z": "2f5fbbe5e47e3e01", "name": "", "topic": "W/d41243d30***/evcharger/40/SetCurrent", "qos": "", "retain": "", "respTopic": "", "contentType": "", "userProps": "", "correl": "", "expiry": "", "broker": "1701f33596afcf6b", "x": 1300, "y": 360, "wires": [] }, { "id": "30244ef6f2cc7914", "type": "ui_slider", "z": "2f5fbbe5e47e3e01", "name": "", "label": "Ladestrom", "tooltip": "", "group": "8ff3d45936e216f8", "order": 2, "width": 0, "height": 0, "passthru": false, "outs": "end", "topic": "topic", "topicType": "msg", "min": "6", "max": "20", "step": "1", "x": 810, "y": 360, "wires": [ [ "213726cc8c3e9702" ] ] }, { "id": "213726cc8c3e9702", "type": "change", "z": "2f5fbbe5e47e3e01", "name": "", "rules": [ { "t": "move", "p": "payload", "pt": "msg", "to": "payload.value", "tot": "msg" } ], "action": "", "property": "", "from": "", "to": "", "reg": false, "x": 1020, "y": 360, "wires": [ [ "642daddb926630e9" ] ] }, { "id": "591497b3edade42f", "type": "mqtt in", "z": "2f5fbbe5e47e3e01", "name": "", "topic": "N/d41243d30***/evcharger/40/SetCurrent", "qos": "0", "datatype": "auto", "broker": "1701f33596afcf6b", "nl": false, "rap": false, "inputs": 0, "x": 240, "y": 360, "wires": [ [ "9a88850298e6a618", "8411957fdc0fda6a" ] ] }, { "id": "9a88850298e6a618", "type": "change", "z": "2f5fbbe5e47e3e01", "name": "", "rules": [ { "t": "set", "p": "payload.value", "pt": "msg", "to": "payload", "tot": "msg" } ], "action": "", "property": "", "from": "", "to": "", "reg": false, "x": 570, "y": 360, "wires": [ [ "30244ef6f2cc7914", "0760f3a27eaa442e" ] ] }, { "id": "0760f3a27eaa442e", "type": "debug", "z": "2f5fbbe5e47e3e01", "name": "debug 69", "active": true, "tosidebar": true, "console": false, "tostatus": false, "complete": "false", "statusVal": "", "statusType": "auto", "x": 720, "y": 500, "wires": [] }, { "id": "8411957fdc0fda6a", "type": "debug", "z": "2f5fbbe5e47e3e01", "name": "debug 70", "active": true, "tosidebar": true, "console": false, "tostatus": false, "complete": "false", "statusVal": "", "statusType": "auto", "x": 460, "y": 520, "wires": [] }, { "id": "1701f33596afcf6b", "type": "mqtt-broker", "name": "mosquitto-on-alarm", "broker": "192.168.10.22", "port": "1883", "clientid": "", "autoConnect": true, "usetls": false, "protocolVersion": "4", "keepalive": "60", "cleansession": true, "birthTopic": "", "birthQos": "0", "birthPayload": "", "birthMsg": {}, "closeTopic": "", "closeQos": "0", "closePayload": "", "closeMsg": {}, "willTopic": "", "willQos": "0", "willPayload": "", "willMsg": {}, "userProps": "", "sessionExpiry": "" }, { "id": "8ff3d45936e216f8", "type": "ui_group", "name": "Wallbox", "tab": "0469c04257b5af1f", "order": 1, "disp": true, "width": "6", "collapse": false }, { "id": "0469c04257b5af1f", "type": "ui_tab", "name": "Wallbox", "icon": "dashboard", "order": 5, "disabled": false, "hidden": false } ] -
Das habe ich versucht, geht nicht
@mousenray Dann poste was aus der mqtt rauskommt also debug 70
"{"value": 10}"
@mousenray Ja dann geht das . was ich gepostet habe - poste das debug Fenster als Screenshot mit der debug 70 Node.
Ansonsten geht das:
Ach so ich sehe Du hast was falsch in der mqtt-Node konfiguriert:
Warum auch immer.
16.3.2023, 20:23:16node: 283daac876b30898
msg : string[53]
"Cannot set property of non-object type: payload.value"16.3.2023, 20:25:40node: debug 69
N/d41243d30486/evcharger/40/SetCurrent : msg.payload : undefined
undefineddas sagt die node.
screen muss ich schauen wie das hier geht
ja das war es, Danke!!!!
@mousenray Nochmal die mqtt Node muss das Objekt analysieren.
Im debug 70 steht das Objekt - im debug 69 nur noch der Wert.
