    3. Einsteigerfragen
    4. Erstinstallation Ip Adresse nicht gefunden
    • wendy2702
      wendy2702 @pmther last edited by
      @pmther Wo zeigt er das an?
      Du vergisst das wir deinen Bildschirm nicht sehen.
      • DJMarc75
        DJMarc75 @pmther last edited by
        @pmther zeig nochmal die Ausgabe von
        iob diag
        bitte...
        Tippe drauf dass da jetzt schon kein Speicher mehr verfügbar ist.
        P 2 Replies Last reply Reply Quote 0
          pmther @DJMarc75 last edited by
          @djmarc75
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Model		: Raspberry Pi 3 Model A Plus Rev 1.0
          Architecture: 	aarch64
          Docker: 	false
          Virtualization: none
          Distributor ID:	Debian
          Description:	Debian GNU/Linux 11 (bullseye)
          Release:	11
          Codename:	bullseye
          PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
          NAME="Debian GNU/Linux"
          VERSION_ID="11"
          VERSION="11 (bullseye)"
          VERSION_CODENAME=bullseye
          ID=debian
          HOME_URL="https://www.debian.org/"
          SUPPORT_URL="https://www.debian.org/support"
          BUG_REPORT_URL="https://bugs.debian.org/"
          Systemuptime and Load:
           21:10:22 up  1:12,  1 user,  load average: 0.16, 0.22, 0.89
          CPU threads: 4
          *** Time and Time Zones ***
          Thu Mar 16 20:10:22 UTC 2023
          Thu Mar 16 21:10:22 CET 2023
          CET +0100
          Europe/Berlin
          *** User and Groups ***
          paul
          /home/paul
          paul adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop:
          Terminal: 	tty
          Boot Target: 	multi-user.target
          *** MEMORY ***
          Mem:            419M        253M         93M        0.0K         72M        113M
          Swap:            99M         95M        4.0M
          Total:          519M        348M         97M
                    419 M total memory
                    253 M used memory
                     75 M active memory
                    183 M inactive memory
                     93 M free memory
                      5 M buffer memory
                     67 M swap cache
                     99 M total swap
                     95 M used swap
                      4 M free swap
          *** FILESYSTEM ***
          /dev/root      ext4       29G  2.2G   26G   8% /
          devtmpfs       devtmpfs   80M     0   80M   0% /dev
          tmpfs          tmpfs     210M     0  210M   0% /dev/shm
          tmpfs          tmpfs      84M 1020K   83M   2% /run
          /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
          tmpfs          tmpfs      42M     0   42M   0% /run/user/1000
          Messages in dmesg:
          [Thu Mar 16 19:57:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4a98718-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Thu Mar 16 19:57:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Thu Mar 16 19:57:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Mar 16 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
          Show mounted filesystems (real ones only):
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          481M	/var/
          178M	/var/cache
          172M	/var/cache/apt
          147M	/var/lib
          122M	/var/lib/apt/lists
          /opt/iobroker/backups:
          4.0K	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          18M	/opt/iobroker/iobroker-data/
          15M	/opt/iobroker/iobroker-data/files
          13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
          3.2M	/opt/iobroker/iobroker-data/objects.jsonl
          2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
          1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
          652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v16.19.1
          /usr/bin/node 		v16.19.1
          /usr/bin/npm 		8.19.3
          /usr/bin/npx 		8.19.3
          nodejs:
            Installed: 16.19.1-deb-1nodesource1
            Candidate: 16.19.1-deb-1nodesource1
            Version table:
           *** 16.19.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                  100 /var/lib/dpkg/status
               12.22.12~dfsg-1~deb11u3 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.5~dfsg-2~11u1 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	4.0.24
          admin: 		6.3.5
          javascript: 	"javascript" not found
          Adapters from github: 	0
          Adapter State
          + system.adapter.admin.0                  : admin                 : paul                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : paul                                     -  enabled
          + system.adapter.discovery.0              : discovery             : paul                                     -  enabled
          + system.adapter.hue.0                    : hue                   : paul                                     -  enabled, port: 443
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.3.5    , installed 6.3.5
          Adapter    "backitup"     : 2.5.12   , installed 2.5.12
          Adapter    "discovery"    : 3.1.0    , installed 3.1.0
          Adapter    "hue"          : 3.7.1    , installed 3.7.1
          Controller "js-controller": 4.0.24   , installed 4.0.24
          Objects and States
          Objects: 	164
          States: 	122
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30946      6898/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30939      6898/iobroker.js-co
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12810      483/sshd: /usr/sbin
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12821      483/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41198      9258/io.admin.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12111      654/dhcpcd
          udp        0      0 0.0.0.0:58815           0.0.0.0:*                           108        9723       361/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9721       361/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          9776       654/dhcpcd
          udp6       0      0 :::55504                :::*                                108        9724       361/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        9722       361/avahi-daemon: r
          2023-03-16 20:59:37.383  - info: host.paul iobroker host.paul object system.adapter.hue.0.memHeapTotal created
          2023-03-16 20:59:37.404  - info: host.paul iobroker host.paul object system.adapter.hue.0.memRss created
          2023-03-16 20:59:37.423  - info: host.paul iobroker host.paul object system.adapter.hue.0.uptime created
          2023-03-16 20:59:37.444  - info: host.paul iobroker host.paul object system.adapter.hue.0.inputCount created
          2023-03-16 20:59:37.474  - info: host.paul iobroker host.paul object system.adapter.hue.0.outputCount created
          2023-03-16 20:59:37.492  - info: host.paul iobroker host.paul object system.adapter.hue.0.eventLoopLag created
          2023-03-16 20:59:37.523  - info: host.paul iobroker host.paul object system.adapter.hue.0.sigKill created
          2023-03-16 20:59:37.538  - info: host.paul iobroker host.paul object system.adapter.hue.0.logLevel created
          2023-03-16 20:59:37.551  - info: host.paul iobroker host.paul object hue.0.info created
          2023-03-16 20:59:37.565  - info: host.paul iobroker host.paul object hue.0.info.connection created
          2023-03-16 20:59:37.586  - info: host.paul iobroker host.paul Set default value of hue.0.info.connection: false
          2023-03-16 20:59:37.620  - info: host.paul iobroker host.paul object system.adapter.hue.0 created
          2023-03-16 20:59:37.949  - info: backitup.0 (9434) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
          2023-03-16 20:59:38.183  - info: backitup.0 (9434) [iobroker] backup was activated at 02:40 every 1 day(s)
          2023-03-16 20:59:38.778  - info: host.paul iobroker exit 0
          2023-03-16 20:59:40.678  - info: host.paul instance system.adapter.hue.0 started with pid 9457
          2023-03-16 20:59:40.852  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
          2023-03-16 20:59:44.837  - info: hue.0 (9457) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.1, js-controller: 4.0.24
          2023-03-16 20:59:44.897  - warn: hue.0 (9457) No bridge configured yet - please configure the adapter first
          2023-03-16 21:01:20.805  - error: hue.0 (9457) Error on browsing via NUPNP: Problems resolving hue bridges, Request failed with status code 429
          2023-03-16 21:01:26.662  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31
          2023-03-16 21:02:05.344  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
          2023-03-16 21:02:05.919  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
          2023-03-16 21:12:39.742  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
          2023-03-16 21:12:40.568  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
            @djmarc75
            Habe gerade schon nach einem vierer geschaut. Meinst du, die 2gb Variante reicht oder ist das wieder nichts halbes und nichts ganzes?
            wendy2702 DJMarc75 2 Replies Last reply Reply Quote 0
            • wendy2702
              @pmther Nichts halbes und nichts ganzes.
              Meine Meinung.
                pmther @wendy2702 last edited by
                @wendy2702 okay, also gleich den 8er?
                • DJMarc75
                  @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
                  Ich hab mal nen 2GB als Prodsystem genutzt - nach paar Wochen dann aber nen 8GB geholt mit dem ich mehr als zufrieden bin.
                  Bedenke:
                  Die Ansprüche wachsen mit der Zeit und dann sind 2GB eigentlich NIX 😉
                    @djmarc75 ja gut das stimmt natürlich. dann werde ich mir wohl einen 8 gb holen. Ist bei meinem jetzt das Problem der Arbeitsspeicher?
                    • DJMarc75
                      Kurz und knapp: ja, wie am Anfang schon geschrieben 😉
                        @djmarc75 okay, das heißt, dass ich mit dem rein gar nichts anfangen kann im Moment?
                        • DJMarc75
                          naja, vll bissle üben was Linux angeht 😀
                            @djmarc75 nagut okay, dann danke trotzdem für die ganze Hilfe. Ich werde dann mal schauen ob ich ihn verkauft kriege...
                              Thomas Braun Most Active @pmther last edited by
                              jetzt zeigt der Biobroker mir langsame Verbindung an.
                              Das bezieht sich auf den Speicher. Der Kleine ist schwer am kämpfen.
                                pmther @Thomas Braun last edited by
                                @thomas-braun Ja, habe grad auch eine Meldung bekommen, dass nur 86 mb Arbeitsspeicher verfügbar sind.
                                  @pmther
                                  Ja, mit 512 MB kannste halt ein paar Trockenübungen machen. Mit viel Geduld...
                                    Die Visualisierung kann ich doch aber schonmal anfangen oder läuft das nur mit den entsprechenden Adaptern?
                                    Worüber macht man die Visualisierung dann?
                                      Mit dem schmalen RAM ist da nix gescheites mit Vis. Der ist schon etwas hungriger.
                                        Moin, ich habe nun den neuen Raspberry mit 8 GB RAM. Gestern habe ich mich dann mal an der Visualisierung versucht. Immer wenn ich die „fertige“ visualisierung aufrufe kommt ein Lizenzfehler.. Im Forum hab ich gelesen, dass es hilft eine ältere Version runterzuladen. Bei mir leider nicht.
                                        Könnt ihr mir da vielleicht helfen?
                                        lg
                                        Paul
                                          Off Topic.
                                          Neuen Thread und dann dort die genaue Fehlermeldung aus dem Logfile in Textform rein.
                                            Thomas Braun Most Active @wendy2702 last edited by
                                            @wendy2702
                                            Bitte hier antworten:
                                            https://forum.iobroker.net/topic/64097/visualisierung-lizenzfehler
                                            5606
