    4. iobroker mit Docker: Kann keine Ports mehr durchschleifen
      pingo @Glasfaser last edited by pingo
      @glasfaser said in iobroker mit Docker: Kann keine Ports mehr durchschleifen:
      curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      <Skript v.2023-01-02
      *** BASE SYSTEM ***
      Architecture: x86_64
      Docker: false
      Virtualization: Unknown (buanet/Synology?)
      diag.sh: line 66: lsb_release: command not found
      cat: /etc/os-release: No such file or directory
      Systemuptime and Load:
      15:19:58 up 1 day, 20:09, 1 user, load average: 0.88, 0.86, 0.69 [IO: 0.71, 0.57, 0.37 CPU: 0.17, 0.27, 0.27]
      CPU threads: 4
      *** Time and Time Zones ***
      Sun Mar 19 14:19:58 UTC 2023
      Sun Mar 19 15:19:58 CET 2023
      CET +0100
      cat: /etc/timezone: No such file or directory
      *** User and Groups ***
      root
      /root
      diag.sh: line 83: groups: command not found
      *** X-Server-Setup ***
      X-Server: false
      Desktop:
      Terminal:
      Boot Target: syno-bootup-done.target
      *** MEMORY ***
      total used free shared buff/cache available
      Mem: 3.8G 2.0G 120M 22M 1.6G 1.5G
      Swap: 4.3G 554M 3.8G
      Total: 8.1G 2.6G 3.9G
      diag.sh: line 100: vmstat: command not found
      *** FILESYSTEM ***
      Filesystem Type Size Used Avail Use% Mounted on
      /dev/md0 ext4 2.3G 2.0G 252M 89% /
      devtmpfs devtmpfs 1.9G 0 1.9G 0% /dev
      tmpfs tmpfs 1.9G 2.2M 1.9G 1% /dev/shm
      tmpfs tmpfs 1.9G 17M 1.9G 1% /run
      tmpfs tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
      tmpfs tmpfs 1.9G 1.7M 1.9G 1% /tmp
      /dev/mapper/cachedev_0 ext4 28T 22T 6.0T 78% /volume1
      /dev/usb1p1 hfsplus 1.9T 206G 1.7T 12% /volumeUSB1/usbshare
      none aufs 28T 22T 6.0T 78% /volume1/@docker/aufs/mnt/f63aaf1ee160276583588147957dc0ab8ed509048905b85f90e0d8804b430cc2
      Messages in dmesg:
      [Fri Mar 17 19:11:01 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Fri Mar 17 19:11:01 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Mar 17 19:11:02 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Fri Mar 17 19:11:02 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Mar 17 19:11:02 2023] EXT4-fs (loop0): couldn't mount as ext3 due to feature incompatibilities
      [Fri Mar 17 19:11:02 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Mar 17 19:11:06 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Fri Mar 17 19:11:06 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Mar 17 19:11:07 2023] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities
      [Fri Mar 17 19:11:07 2023] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      [Fri Mar 17 19:11:26 2023] EXT4-fs (dm-2): barriers disabled
      [Fri Mar 17 19:11:27 2023] EXT4-fs (dm-2): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl
      [Fri Mar 17 19:11:34 2023] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
      Show mounted filesystems (real ones only):
      diag.sh: line 109: findmnt: command not found
      /var:
      168M /var/
      79M /var/db
      77M /var/db/geoip-database
      49M /var/log
      21M /var/lib
      /opt/iobroker/backups:
      du: cannot access '/opt/iobroker/backups/': No such file or directory
      /opt/iobroker/iobroker-data:
      du: cannot access '/opt/iobroker/iobroker-data/': No such file or directory
      find: `/opt/iobroker/iobroker-data': No such file or directory
      *** NodeJS-Installation ***
      diag.sh: line 132: nodejs: command not found
      /usr/local/bin/node v12.22.12
      /usr/local/bin/npm 6.14.16
      diag.sh: line 135: npx: command not found
      diag.sh: line 137: apt-cache: command not found
      find: `/opt/iobroker/node_modules': No such file or directory
      *** ioBroker-Installation ***
      ioBroker Status
      diag.sh: line 152: iobroker: command not found
      Core adapters versions
      diag.sh: line 155: iob: command not found
      js-controller:
      diag.sh: line 156: iob: command not found
      admin:
      diag.sh: line 157: iob: command not found
      javascript:
      diag.sh: line 159: cd: /opt/iobroker: No such file or directory
      Adapters from github:
      Adapter State
      diag.sh: line 162: iob: command not found
      diag.sh: line 165: iob: command not found
      ioBroker-Repositories
      diag.sh: line 168: iob: command not found
      Installed ioBroker-Instances
      diag.sh: line 171: iob: command not found
      Objects and States
      Objects: 0
      States: 0
      sudo: apt-get: command not found
      diag.sh: line 182: apt-get: command not found
      Pending Updates:
      *** Listening Ports ***
      Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
      tcp 0 0 127.0.0.1:143 0.0.0.0:* LISTEN 0 96027 20977/dovecot
      tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 0 39198 6000/nginx: worker
      tcp 0 0 0.0.0.0:2001 0.0.0.0:* LISTEN 0 10414849 722/docker-proxy
      tcp 0 0 0.0.0.0:8081 0.0.0.0:* LISTEN 0 10415616 679/docker-proxy
      tcp 0 0 0.0.0.0:8082 0.0.0.0:* LISTEN 0 10416312 658/docker-proxy
      tcp 0 0 127.0.0.1:914 0.0.0.0:* LISTEN 0 90667 5917/fcgi-pm
      tcp 0 0 127.0.0.1:915 0.0.0.0:* LISTEN 0 89594 6179/httpd24
      tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN 0 38790 11463/ftpd
      tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 23450 8452/sshd: /usr/bin
      tcp 0 0 0.0.0.0:631 0.0.0.0:* LISTEN 0 42711 11868/cupsd
      tcp 0 0 0.0.0.0:1880 0.0.0.0:* LISTEN 0 10411894 762/docker-proxy
      tcp 0 0 0.0.0.0:8088 0.0.0.0:* LISTEN 0 10411822 640/docker-proxy
      tcp 0 0 127.0.0.1:5432 0.0.0.0:* LISTEN 55 66882 14817/postgres
      tcp 0 0 0.0.0.0:2010 0.0.0.0:* LISTEN 0 10416341 699/docker-proxy
      tcp 0 0 0.0.0.0:8282 0.0.0.0:* LISTEN 0 10416297 620/docker-proxy
      tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 0 10415672 743/docker-proxy
      tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 0 39200 6000/nginx: worker
      tcp 0 0 0.0.0.0:8284 0.0.0.0:* LISTEN 0 10415537 601/docker-proxy
      tcp 0 0 127.0.0.1:4700 0.0.0.0:* LISTEN 0 40096 11551/cnid_metad
      tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 0 41343 11450/smbd
      tcp 0 0 0.0.0.0:4190 0.0.0.0:* LISTEN 0 95984 20977/dovecot
      tcp 0 0 127.0.0.1:512 0.0.0.0:* LISTEN 0 98185 21178/termd
      tcp 0 0 0.0.0.0:12001 0.0.0.0:* LISTEN 0 10416267 546/docker-proxy
      tcp 0 0 127.0.0.1:161 0.0.0.0:* LISTEN 0 36329 11020/snmpd
      tcp 0 0 0.0.0.0:12002 0.0.0.0:* LISTEN 0 10411751 526/docker-proxy
      tcp 0 0 0.0.0.0:3493 0.0.0.0:* LISTEN 0 101790 21460/upsd
      tcp 0 0 0.0.0.0:50022 0.0.0.0:* LISTEN 0 23454 8452/sshd: /usr/bin
      tcp 0 0 0.0.0.0:44871 0.0.0.0:* LISTEN 0 10415415 506/docker-proxy
      tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 0 10415504 582/docker-proxy
      tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN 0 39194 6000/nginx: worker
      tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 0 10411780 564/docker-proxy
      tcp 0 0 0.0.0.0:5001 0.0.0.0:* LISTEN 0 39196 6000/nginx: worker
      tcp 0 0 0.0.0.0:3307 0.0.0.0:* LISTEN 66 1700649 5364/mysqld
      tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 0 41344 11450/smbd
      tcp 0 0 0.0.0.0:5357 0.0.0.0:* LISTEN 0 39377 6000/nginx: worker
      tcp6 0 0 :::80 :::* LISTEN 0 39199 6000/nginx: worker
      tcp6 0 0 :::21 :::* LISTEN 0 38791 11463/ftpd
      tcp6 0 0 :::22 :::* LISTEN 0 23452 8452/sshd: /usr/bin
      tcp6 0 0 :::631 :::* LISTEN 0 42712 11868/cupsd
      tcp6 0 0 :::443 :::* LISTEN 0 39201 6000/nginx: worker
      tcp6 0 0 :::3261 :::* LISTEN 0 44823 -
      tcp6 0 0 :::445 :::* LISTEN 0 41341 11450/smbd
      tcp6 0 0 :::4190 :::* LISTEN 0 95985 20977/dovecot
      tcp6 0 0 :::3263 :::* LISTEN 0 44821 -
      tcp6 0 0 :::3264 :::* LISTEN 0 46116 -
      tcp6 0 0 :::3265 :::* LISTEN 0 48499 12581/scsi_plugin_s
      tcp6 0 0 :::515 :::* LISTEN 0 39882 1/init
      tcp6 0 0 :::548 :::* LISTEN 0 40185 11550/afpd
      tcp6 0 0 :::50022 :::* LISTEN 0 23456 8452/sshd: /usr/bin
      tcp6 0 0 :::5000 :::* LISTEN 0 39195 6000/nginx: worker
      tcp6 0 0 :::6281 :::* LISTEN 0 81032 17419/img_backupd
      tcp6 0 0 :::5001 :::* LISTEN 0 39197 6000/nginx: worker
      tcp6 0 0 :::139 :::* LISTEN 0 41342 11450/smbd
      tcp6 0 0 :::5357 :::* LISTEN 0 39378 6000/nginx: worker
      udp 0 0 0.0.0.0:5353 0.0.0.0:* 0 73684 16976/avahi-daemon:
      udp 0 0 0.0.0.0:44343 0.0.0.0:* 0 73686 16976/avahi-daemon:
      udp 0 0 0.0.0.0:3702 0.0.0.0:* 99 34843 10620/synowsdiscove
      udp 0 0 0.0.0.0:9997 0.0.0.0:* 0 26087 8468/findhostd
      udp 0 0 0.0.0.0:9998 0.0.0.0:* 0 26086 8468/findhostd
      udp 0 0 0.0.0.0:9999 0.0.0.0:* 0 26085 8468/findhostd
      udp 0 0 0.0.0.0:1900 0.0.0.0:* 0 78468 17664/minissdpd
      udp 0 0 0.0.0.0:36787 0.0.0.0:* 0 1704353 11830/synorelayd
      udp 213248 0 0.0.0.0:68 0.0.0.0:* 0 30841 9763/dhclient
      udp 0 0 0.0.0.0:68 0.0.0.0:* 0 24988 8145/dhclient
      udp 0 0 172.18.0.1:123 0.0.0.0:* 87 10417186 8459/ntpd
      udp 0 0 192.168.178.144:123 0.0.0.0:* 87 34195 8459/ntpd
      udp 0 0 127.0.0.1:123 0.0.0.0:* 0 23387 8459/ntpd
      udp 0 0 0.0.0.0:123 0.0.0.0:* 0 23383 8459/ntpd
      udp 0 0 192.168.178.255:137 0.0.0.0:* 0 76335 17172/nmbd
      udp 0 0 192.168.178.144:137 0.0.0.0:* 0 76334 17172/nmbd
      udp 0 0 0.0.0.0:137 0.0.0.0:* 0 78007 17172/nmbd
      udp 0 0 192.168.178.255:138 0.0.0.0:* 0 76337 17172/nmbd
      udp 0 0 192.168.178.144:138 0.0.0.0:* 0 76336 17172/nmbd
      udp 0 0 0.0.0.0:138 0.0.0.0:* 0 78008 17172/nmbd
      udp 0 0 127.0.0.1:161 0.0.0.0:* 0 36328 11020/snmpd
      udp6 0 0 :::5353 :::* 0 73685 16976/avahi-daemon:
      udp6 0 0 :::3702 :::* 99 34845 10620/synowsdiscove
      udp6 0 0 fe80::e44e:4aff:fe3:123 :::* 87 10417192 8459/ntpd
      udp6 0 0 fe80::42:7aff:fea0::123 :::* 87 10417190 8459/ntpd
      udp6 0 0 fe80::9209:d0ff:fe0:123 :::* 87 34198 8459/ntpd
      udp6 0 0 ::1:123 :::* 0 23389 8459/ntpd
      udp6 0 0 :::123 :::* 0 23380 8459/ntpd
      udp6 0 0 :::52099 :::* 0 73687 16976/avahi-daemon:
      tail: cannot open '/opt/iobroker/log/iobroker.current.log' for reading: No such file or directory
      iob diag has finished.
      v.2023-01-02
      diag.sh: line 215: lsb_release: command not found
      Operatingsystem:
      Installation:
      Timezone:
      User-ID: 0
      X-Server: false
      Pending OS-Updates:
      diag.sh: line 239: nodejs: command not found
      Nodejs-Installation:
      diag.sh: line 242: npx: command not found
      diag.sh: line 244: iob: command not found
      ioBroker Core: js-controller
      diag.sh: line 245: iob: command not found
      admin
      diag.sh: line 247: iobroker: command not found
      ioBroker Status:
      Status admin:
      diag.sh: line 251: iobroker: command not found
      diag.sh: line 253: iob: command not found
      Pending iob updates: 0
      diag.sh: line 255: iob: command not found
      Objects: 0
      States: 0
      Size of iob-Database:
      find: /opt/iobroker/iobroker-data': No such file or directory find: /opt/iobroker/iobroker-data': No such file or directory
      =================== END OF SUMMARY ====================>
      Der Portainerversuch ist m.E. gescheitert:
      <root@Diskstation920:~# docker run -d -p 9000:9000 --name portainer --restart always -v /var/run/docker.sock:/var/run/docker.sock -v /volume1/docker/portainer_data:/data portainer/portainer-ce
      Unable to find image 'portainer/portainer-ce:latest' locally
      latest: Pulling from portainer/portainer-ce
      772227786281: Pull complete
      96fd13befc87: Pull complete
      b733663f020c: Pull complete
      9fbfa87be55d: Pull complete
      Digest: sha256:9fa1ec78b4e29d83593cf9720674b72829c9cdc0db7083a962bc30e64e27f64e
      Status: Downloaded newer image for portainer/portainer-ce:latest
      42538ba0f62d1644098d8eeea2b54c57c1bc3a0d2a7fb1a30f81e5e521d44c4d
      docker: Error response from daemon: driver failed programming external connectivity on endpoint portainer (3728dc0bcf157c19a93766fef7892f83600fcb8f8baa191899ab809a8fe199ad): Bind for 0.0.0.0:9000 failed: port is already allocated.>
      Glasfaser Thomas Braun 4 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @pingo last edited by
        @pingo sagte in iobroker mit Docker: Kann keine Ports mehr durchschleifen:
        schon mal ein Fehler von xxxx , weiter lese ich nicht !!!
        Nimm meinen Vorschlag von ganz oben !!!!
          Thomas Braun Most Active @pingo last edited by Thomas Braun
          @pingo
          Nodejs falsch installiert, irgendwas ist mit den mounts und das Kommando 'iobroker' bzw. 'iob' wird auch nicht richtig gefunden.
          So viel zum 'einwandfrei laufenden ioBroker'
          Setz die Kiste neu und gescheit auf.
          • Glasfaser
            @pingo
            Kurzfassung
            Dein ioBroker Container ist schrott ( nicht gepflegt )
            und was mich auch wunder ist
            /docker-proxy
              @glasfaser : Ja ok. Ich werde versuche mit Deinem Vorschlag alles neu aufzusetzen. Hoffentlich geht es gut
                pingo @pingo last edited by
                Leider beginnt nun der Alptraum. Beim Neuaufsetzen kommt dieselbe Fehlermeldung:
                Und nun?
                  Ich erinnere mich an die damaligen Installationsprobleme: link text
                  Das hilft diesmal leider auch nicht. 😠
                  • Glasfaser
                    @pingo
                    Hast du auch das Paket Docker gelöscht / neu installiert
                    Eventuell auch mal die Syn neu starten !?
                    OK .. da war mal was mit deinem Webstation Zugang ...
                      genau. Die Webstation brauche ich.
                      Mag sich vielleicht mal jemand hier aufschalten. Ich denke schon, dass dann die Fehlersuche schneller und einfacher wird? Ich bin mittlerweile echt verzweifelt. Iobroker weg und nix funktioniert, wie früher.😠
                      • Glasfaser
                        nginx
                        ist in deinem Protokoll , hast du das Installiert !?
                        und wie ich schon schrieb :
                        @glasfaser sagte in iobroker mit Docker: Kann keine Ports mehr durchschleifen:
                        /docker-proxy
                          nginx
                          /docker-proxy
                          Nginx ist nicht installiert.
                          Ich habe jetzt mal die Host-Variante ausprobiert und die konnte ich tatsächlich installieren.
                            fastfoot @pingo last edited by
                            wer hat Dir eig. beigebracht tonnenweise Ports anzugeben? Profi-Tipp: Verklagen!
                            Du gibst (erstmal!) maximal 8081:8081 und evtl. noch 8082:8082 an und los gehts!
                              pingo @fastfoot last edited by pingo
                              @fastfoot : Das kam aus einer Anleitung, nach der ich vorgegangen bin. Aktuell läuft aber nur die Host-Installationsvariante.
                              Nun wollte ich mein Google Drive Backup einspielen, aber es nicht zu finden, obwohl alle Backups damals durchgelaufen sind und ich auch die Dateien gesehen hatte. Ich fürchte, dass ich nun wieder komplett von vorne anfangen muss. Das ist der Supergau, den ich vermeiden wollte
                              F Glasfaser 2 Replies Last reply Reply Quote 0
                                @pingo Um etwas einzuspielen müsste der Ccontainer ja laufen, lt. deinen Posts scheitert es aber doch an den Ports. Ja was denn nun?
                                • Glasfaser
                                  Nun wollte ich mein Google Drive Backup einspielen, aber es nicht zu finden.
                                  Neuen Container erstellen ... Mounte ein Ordner , lege ein aktuelles Backup dort rein , starte den Container dann erst
                                    @glasfaser Ich finde leider keine Backupdatei, obwohl ich lokale und google drive Backupdateien hatte
                                    • Glasfaser
                                      auch nicht Online im Google Drive Konto !?
                                        @glasfaser Nein, obwohl mir vor dem Löschen des Containers alle Dateien angezeigt wurden. Habt Ihr noch einen Tipp wo ich suchen kann oder wie die Dateien heißen?
                                          der 'alte' Mountpfad existiert doch noch?
                                          • Glasfaser
                                            wer soll den Online deine Backups jetzt gelöscht haben !?
                                            ? Hääh
                                            Hast du eventuell ein Mount vom Ordner zuvor gemacht
                                            opt/iobroker
                                            Beispiel :
                                            100
                                            5559
