    3. Off Topic
    4. InfluxDB
    5. [Gelöst] InfluxDB Upgrade error
    • Latzi
      Latzi @Guest last edited by
      @dp20eic
      schaut bei mir so aus:
      latzi@influxDB:~$ ls -la /etc/apt//sources.list.d/
      total 16
      drwxr-xr-x 2 root root 4096 Jan 27 11:10 .
      drwxr-xr-x 8 root root 4096 Aug 16  2021 ..
      -rw-r--r-- 1 root root  117 Jan 27 11:01 influxdata.list
      -rw-r--r-- 1 root root  101 Jan 27 11:10 influxdb.list
      latzi@influxDB:~$
      latzi@influxDB:~$ ls -la /etc/apt/trusted.gpg.d/
      total 80
      drwxr-xr-x 2 root root 4096 Jan 27 08:25 .
      -rw-r--r-- 1 root root 8700 Feb 25  2021 debian-archive-bullseye-automatic.gpg
      -rw-r--r-- 1 root root 8709 Feb 25  2021 debian-archive-bullseye-security-automatic.gpg
      -rw-r--r-- 1 root root 2453 Feb 25  2021 debian-archive-bullseye-stable.gpg
      -rw-r--r-- 1 root root 8132 Feb 25  2021 debian-archive-buster-automatic.gpg
      -rw-r--r-- 1 root root 8141 Feb 25  2021 debian-archive-buster-security-automatic.gpg
      -rw-r--r-- 1 root root 2332 Feb 25  2021 debian-archive-buster-stable.gpg
      -rw-r--r-- 1 root root 7443 Feb 25  2021 debian-archive-stretch-automatic.gpg
      -rw-r--r-- 1 root root 7452 Feb 25  2021 debian-archive-stretch-security-automatic.gpg
      -rw-r--r-- 1 root root 2263 Feb 25  2021 debian-archive-stretch-stable.gpg
      -rw-r--r-- 1 root root 1185 Jan 27 11:00 influxdata-archive_compat.gpg
      latzi@influxDB:~$
        A Former User @Latzi last edited by
        @latzi sagte in [Gelöst] InfluxDB Upgrade error:
        Moin,
        Du hast da noch zwei Sorces für Influx, siehe
        total 16
        Wenn Du apt-get update ausführst, dann bekommst Du den Fehler
        latzi@influxDB:~$ sudo apt update
        Hit:1 http://security.debian.org bullseye-security InRelease
        Hit:2 http://ftp.debian.org/debian bullseye InRelease
        Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Get:5 https://repos.influxdata.com/debian bullseye InRelease [7022 B]
        Err:5 https://repos.influxdata.com/debian bullseye InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
        Schau mal was in den einzelnen Source-Listen steht
        [dp20eic@influxDB ~]$ cat /etc/apt/sources.list.d/influxdata.list
        deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
        Und dann verschiebe mal die die nicht mehr benötigte Datei influxdb.list nach /tmp und mach mal ein update
        # sudo mv /etc/apt/sources.list.d/influxdb.list /tmp
        # sudo apt-get update
        VG
        Bernd
        Latzi 1 Reply Last reply Reply Quote 3
        • Latzi
          @dp20eic
          das ist der Inhalt der beiden:
          latzi@influxDB:~$ cat /etc/apt/sources.list.d/influxdata.list
          latzi@influxDB:~$ cat /etc/apt/sources.list.d/influxdb.list
          deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
          latzi@influxDB:~$
          wenn ich die influxdb.list verschiebe schaut das apt update so aus:
          latzi@influxDB:/$ sudo apt update
          Get:1 http://security.debian.org bullseye-security InRelease [48.4 kB]
          Fetched 48.4 kB in 0s (116 kB/s)
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          latzi@influxDB:/$
          Ich würde mal behaupten es passt (zumindest ist der Fehler weg), vielen herzlichen Dank! 👍 👏
            @latzi
            Moin,
            wichtig ist, dass Du die zusammenhänge erkennst, zwischen dem Fehler von oben und der Lösung 😉
            Und/oder auch erkennst was Du da mit dem Update des Keys gemacht hast.
            Der Fehler von oben hing nur noch mit der alten Liste zusammen, einem
            # sudo apt-get upgrade
            hätte das nicht gestört, glaube ich :), wäre halt nur immer eine Fehlermeldung, die man nicht haben möchte.
            VG
            Bernd
              Rushmed Most Active last edited by Rushmed
              Was hat denn das zu bedeuten?
              pi@Smartazamba:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
              pi@Smartazamba:~ $ gpg --with-fingerprint --show-keys ./influxdata-archive_compat.key
              pub   rsa4096 2023-01-18 [SC] [expires: 2026-01-17]
                      9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
              uid                     InfluxData Package Signing Key <support@influxdata.com>
              gpg: directory '/home/pi/.gnupg' created
              gpg: keybox '/home/pi/.gnupg/pubring.kbx' created
              -bash: pub: command not found
              -bash: 9D53: command not found
              -bash: syntax error near unexpected token `newline'
              EDIT: Hat doch geklappt.
              Meister Mopper R 2 Replies Last reply Reply Quote 0
              • Meister Mopper
                Meister Mopper @Rushmed last edited by
                Sehr gut Männer,
                das Problem hat mich den ganzen Tag beschäftigt. Jetzt ist es keines mehr! 👍
                  cbrocker last edited by
                  @dp20eic sagte
                  kennst Du dich mit der InfluxDB Abfragesprache influxQL gut aus und Flux ist häh wasn das, dann bleib lieber bei der 1.8 Version und fang heute schon mal an Dich mit Flux zu beschäftigen
                  Wenn Du gerade erst beginnst, dann kannst Du auch gleich mit V2.x weitermachen, vorher natürlich gut einlesen, wegen Datenmigration 1.8 -> 2.x und wie immer Backups nicht vergessen
                  Hey dp20eic,
                  hast du selber mal InfluxDB Daten von 1.8.x auf 2.6 migriert?
                    A Former User @cbrocker last edited by
                    @cbrocker
                    Moin,
                    war im Urlaub, daher muss ich erst einiges durchlesen.
                    Ja, habe ich. Hier im Forum sollte es aber auch schon einige Beiträge zum Theme geben, schmeiß einfach mal die Suche an.
                    Ich bin eigentlich stur nach der influxDB Anleitung auf deren Seiten vorgegangen.
                    Wenn Du aber spezielle Fragen hast, dann stell sie mal, besser dafür einen eigenen Thread aufmachen oder einen noch offenen finden und sich dranhängen.
                    VG
                    Bernd
                      Sushibomba last edited by Sushibomba
                      pi@Pi4ioBroker128GB:~ $ sudo apt-get update
                      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                      Get:3 https://repos.influxdata.com/debian stable InRelease [6,883 B]
                      Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Get:5 https://packages.grafana.com/oss/deb stable InRelease [5,984 B]
                      Get:6 https://repos.influxdata.com/debian stretch InRelease [7,030 B]
                      Get:7 https://repos.influxdata.com/debian stable/main armhf Packages [2,105 B]
                      Err:5 https://packages.grafana.com/oss/deb stable InRelease
                        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                      Get:8 https://repos.influxdata.com/debian stretch/stable armhf Packages [2,105 B]
                      Fetched 18.1 kB in 2s (7,716 B/s)
                      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
                      W: Some index files failed to download. They have been ignored, or old ones used instead.
                      Irgendwie komme ich nicht weiter. Bin nach der ANleitung von InfluxDB vorgegnagen aber bekomme immer noch die Meldung. Kann mir vielleicht jemand helfen und sagen warum?
                      Gehe ich da einfach nach dieser Anleitung vor? https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
                        A Former User @Sushibomba last edited by A Former User
                        @sushibomba sagte in [Gelöst] InfluxDB Upgrade error:
                        Moin,
                        Du hast, zwar die Signaturen für influxDB erneuert, aber noch nicht für Grafana, auch dafür gibt es hier im Forum schon Anleitungen, wie das aktualisiert wird, oder schau
                        hier
                        Nach, wie Du das ändern musst.
                        VG
                        Bernd
                          Thomas Braun Most Active @Guest last edited by Thomas Braun
                          @dp20eic sagte in [Gelöst] InfluxDB Upgrade error:
                          @Sushibomba
                          Schau hier z. B. rein:
                          ist auch falsch, statt stretch sollte da bullseye oder stable stehen. Also anpassen!
                            Sushibomba @Thomas Braun last edited by
                            Dankje Thomas aber wie ändere ich das. Sorry bin auf dem Gebiet leider noch nicht so fit 😕
                            Thomas Braun ? 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @Sushibomba last edited by
                              @sushibomba
                              Im Verzeichnis /etc/apt/sources.list.d/
                              muss es eine influxdb.list (oder ähnlich) geben. Da dann z. B. per Editor
                              nano ändern.
                                Moin,
                                da Du ja schreibst, dass Du noch nicht so Fit bist und ich daraus schließe Du möchtest Fit werden, kann ich Dir das hier wärmstens empfehlen 🙂
                                Debian-Paketmanagement
                                Dort 3.3 ff und 8.46.3. Punkt 8 das interessante, Du musst das nur auf Deine Gegebenheit anpassen, da das Buch schon vor bullseye geschrieben wurde.
                                Dann gibt es noch eine wie ich finde Erleichterung, in meinem Beispiel siehst Du, dass ich zwei Debian Releases buster und bullseye stehen habe, wobei buster durch # kommentiert ist, sodass es bei apt / apt-get nicht benutzt wird
                                dp20eic@iobroker:~$ sudo apt edit-sources
                                [sudo] password for dp20eic:
                                #deb http://ftp.debian.org/debian buster main contrib
                                #deb http://ftp.debian.org/debian buster-updates main contrib
                                #deb http://security.debian.org buster/updates main contrib
                                deb http://ftp.debian.org/debian bullseye main contrib
                                deb http://ftp.debian.org/debian bullseye-updates main contrib
                                deb http://security.debian.org bullseye-security main contrib
                                Wie gesagt, das musst Du an Deine Installation anpassen.
                                VG
                                Bernd
                                Edit:
                                Gerade gesehen, dass es die Einträge zu influxDB betrifft, da kannst Du nicht mit den von mir vorgeschlagenen Weg arbeiten, dann doch lieber so wie @Thomas-Braun geschrieben hat.
                                  Beide Dateien mit nano geöffnet und beide sind leer.
                                  pi@Pi4ioBroker128GB:~ $ nano influxdb.list
                                  pi@Pi4ioBroker128GB:~ $ nano influxdata.list
                                    Thomas Braun Most Active @Sushibomba last edited by Thomas Braun
                                    @sushibomba
                                    Du bist im falschen Verzeichnis. In deinem Home gibt es die nicht.
                                    cd /etc/apt/sources.list.d/
                                      Sushibomba @Thomas Braun last edited by Sushibomba
                                      @thomas-braun Nein ich war schon in dem richtigen Verzeichnis. Habe ja über "ls" gesehen das die Dateien da drin liegen. Wenn ich sie aber öffne sind sie leer.
                                        @sushibomba
                                        Da stehst du in /home/pi
                                        Und da gibt es keine influxdb.list, die von apt gelesen wird, weil apt nur im Verzeichnis /etc/apt/ nach .list-Dateien schaut.
                                        ls -lAh /etc/apt/sources.list.d/
                                        sagt?
                                          @thomas-braun sagte in [Gelöst] InfluxDB Upgrade error:
                                          pi@Pi4ioBroker128GB:~ $ ls -lAh /etc/apt/sources.list.d/
                                          total 20K
                                          -rw-r--r-- 1 root root 84 Mar 21 10:37 grafana.list
                                          -rw-r--r-- 1 root root 117 Mar 20 09:54 influxdata.list
                                          -rw-r--r-- 1 root root 55 Feb 2 2022 influxdb.list
                                          -rw-r--r-- 1 root root 208 Aug 6 2022 nodesource.list
                                          -rw-r--r-- 1 root root 191 Jan 28 2022 raspi.list
                                            sudo rm /etc/apt/sources.list.d/influxdb.list
                                            Und die andere Datei mit nano beackern:
                                            sudo nano /etc/apt/sources.list.d/influxdata.list
                                            error influx upgrade
                                            13519
