    4. Test Adapter TP-Link Tapo
    • Arno Josef Abler
      Arno Josef Abler last edited by
      Hallo Zusammen!
      Ich habe heute einige TP110 Steckdosen in Betrieb genommen und wollte diese in ioBroker einbinden - Aber ich bekomme immer nur Fehler (wie einige hier auch):
      2023-02-04 18:27:18.269 - debug: tapo.0 (6328) Trying to reconnect...
      2023-02-04 18:27:18.270 - debug: tapo.0 (6328) Handshake P100 on host: 192.168.178.103
      2023-02-04 18:27:18.276 - debug: tapo.0 (6328) "
      200 OK
      2023-02-04 18:27:18.276 - debug: tapo.0 (6328) 371 Error: Cannot read properties of undefined (reading 'response')
      2023-02-04 18:27:18.277 - debug: tapo.0 (6328) {}
      2023-02-04 18:27:18.277 - debug: tapo.0 (6328) 146 Error Code: 9999, Session Timeout 192.168.178.95
      2023-02-04 18:27:18.281 - debug: tapo.0 (6328) Receive energy usage
      2023-02-04 18:27:18.308 - debug: tapo.0 (6328) Received Handshake P100 on host response: 192.168.178.103
      2023-02-04 18:27:18.314 - error: tapo.0 (6328) Error Code: 9999, Session Timeout
      2023-02-04 18:27:18.314 - debug: tapo.0 (6328) Trying to reconnect...
      2023-02-04 18:27:18.314 - debug: tapo.0 (6328) Handshake P100 on host: 192.168.178.95
      2023-02-04 18:27:18.340 - debug: tapo.0 (6328) 152 Error Code: 0, Success 192.168.178.103
      2023-02-04 18:27:18.343 - debug: tapo.0 (6328) {"error_code":9999}
      2023-02-04 18:27:18.343 - debug: tapo.0 (6328) Error Code: 9999, Session Timeout
      2023-02-04 18:27:18.344 - debug: tapo.0 (6328) Trying to reconnect...
      2023-02-04 18:27:18.344 - debug: tapo.0 (6328) Handshake P100 on host: 192.168.178.103
      2023-02-04 18:27:18.352 - debug: tapo.0 (6328) Received Handshake P100 on host response: 192.168.178.95
      2023-02-04 18:27:18.370 - debug: tapo.0 (6328) "
      200 OK
      2023-02-04 18:27:18.371 - debug: tapo.0 (6328) 371 Error: Cannot read properties of undefined (reading 'response')
      2023-02-04 18:27:18.371 - debug: tapo.0 (6328) undefined
      2023-02-04 18:27:18.371 - error: tapo.0 (6328) Get Device Info failed for 8022147AFE1CA2FAD38B3386EC9F42302063F128 - TypeError: Cannot read properties of undefined (reading 'request')
      2023-02-04 18:27:18.377 - debug: tapo.0 (6328) Received Handshake P100 on host response: 192.168.178.103
      2023-02-04 18:27:18.381 - debug: tapo.0 (6328) 146 Error Code: 9999, Session Timeout 192.168.178.95
      2023-02-04 18:27:18.394 - debug: tapo.0 (6328) "
      200 OK
      2023-02-04 18:27:18.395 - debug: tapo.0 (6328) 371 Error: Cannot read properties of undefined (reading 'response')
      2023-02-04 18:27:18.395 - debug: tapo.0 (6328) {}
      2023-02-04 18:27:18.400 - debug: tapo.0 (6328) 146 Error Code: 9999, Session Timeout 192.168.178.103
      2023-02-04 18:27:18.402 - debug: tapo.0 (6328) Receive energy usage
      2023-02-04 18:27:18.416 - debug: tapo.0 (6328) 357 Error Code: 9999, Session Timeout 192.168.178.103
      2023-02-04 18:27:18.417 - debug: tapo.0 (6328) undefined
      2023-02-04 18:27:18.417 - error: tapo.0 (6328) Get Device Info failed for 80220C69DA7EAF4C46D90B4C711304EB20997FEA - TypeError: Cannot read properties of undefined (reading 'request')
      Hier hatten einige den gleichen Fehler, aber ich konnte keine Lösung erkennen - ich habe die aktuellste Version 0.0.8 - einmal über die Weboberfläche installiert und dann nochmal über Github, wie hier empfohlen - keine Änderung.
      Gibt es hier eine Lösung? - danke!
        tombox @Arno Josef Abler last edited by
        @arno-josef-abler Die P110 verhalten sich komisch sicher das sie eine stabile WLAN Verbindung haben.
        Verhalten sich alle P110 gleich?
        Arno Josef Abler 1 Reply Last reply Reply Quote 0
        • Arno Josef Abler
          Arno Josef Abler @tombox last edited by
          @tombox Ja, WLAN ist stabil und ja, alle P110 erzeugen (zeitlich versetzt) die gleichen Fehler
            @arno-josef-abler Liefern die Geräte auch plausible Daten oder nur diese Fehler
            • Arno Josef Abler
              @tombox Nein - die Steckdosen liefern nach meinem Verständnis keine validen Daten (nur jene, die wohl aus dem Account selbst stammen, also zB Name oder Mac Adresse). Ich habe aber im gleichen Account noch 4 Kameras - die scheinen zumindest grsdtzl. keine Fehler aufzuweisen und liefern Daten (zB MotionDetection)
              • Arno Josef Abler
                Arno Josef Abler last edited by Arno Josef Abler
                @tombox Ich habe jetzt ioBroker neu deployed und zugleich zum Test eine der Steckdosen neu in der App eingebunden - leider kein Erfolg. immer noch die gleichen Fehler und keine Möglichkeit zum Auslesen. Liegt das vllt. an der aktuellen Firmware? (die Steckdosen sind ja ganz neu)
                PS: Ich glaub ich spinn - jetzt habe ich die Lösung: Der "Benutzername" ist - zumindest bei den p110 - "case sensitive" - ich habe mich wohl bei Tapo mit einem Großbuchstaben am Beginn der Email-Adresse angemeldet. Das ist Bei Tapo "online" (also zum Abruf der Gerät) offenbar egal - aber am lokalen Gerät gelten scheinbar die gleichen Daten als "Login" - dort jedoch "case sensitive"
                Die Lösung war also, die Email Adresse im Adapter mit großem Anfangsbuchstaben einzutragen...
                Vielleicht macht es Sinn, dort in der Config einen Hinweis dazuzuschreiben beim Eingeben der Email-Adresse "Achtung - groß/Kleinschreibung ist relevant" oder so
                • astuermer
                  astuermer last edited by astuermer
                  Hat zufällig jemand den Adapter mit den C400S2 oder C420S2 Cams von Tapo getestet? Einbindung in Yahka als Stream wäre ideal ☺️
                    @astuermer
                    Wenn du es in HomeKit haben möchtest wäre es besser den rtsp stream der Kamera direkt bei yahka einzutragen.
                    wenn du hksv haben willst geht das nur über scrypted als docker aufsetzt und dort das onvif und HomeKit plugin installieren.
                    astuermer 1 Reply Last reply Reply Quote 1
                    • astuermer
                      astuermer @tombox last edited by
                      @tombox Danke, werd ich probieren.
                      • astuermer
                        Ok, scheinbar haben die C420 Tapo Cams keinen RTSP Stream weil sie Akku-Cameras sind, die an einem Hub hängen - und nur der hat eine IP.
                        Den Hub seh ich in den Objekten.
                        Aber gibts ne Möglichkeit, den Hub abzufragen?
                        Dort irgendwie die Cam-Streams reinzubekommen?
                          tombox @astuermer last edited by
                          @astuermer Hast du mal geschaut ob Homebridge oder hass es unterstützt dann könnte man schauen wie man es machen kann
                          astuermer 1 Reply Last reply Reply Quote 0
                          • astuermer
                            @tombox Homebridge hat zwar ein Plugin, aber das erfordert auch zwingend IP der Camera und Credentials die man vorher in der App von TP-Link eingerichtet hat. Ich befürchte das geht so nicht.
                              MINKI @astuermer last edited by
                              @astuermer Ich habe keine Lösung für dich, suche aber nach der gleichen Lösung für eine C320WS.
                              Ich habe einen funktionierenden RTSP Stream via VLC. Was genau muss ich bei yahka machen, damit ich den livestream sehen kann?
                                tombox @MINKI last edited by tombox
                                @minki eigentlich nur ffmpeg installieren dann den rstp url mit user:password@ eingeben und hoffen für hksv brauchst du dann scrypted
                                  MINKI @tombox last edited by MINKI
                                  @tombox Danke dir! Die Kamera funktioniert einwandfrei. Ich hatte ein Verständnisproblem in yahka. Läuft aktuell - aber ohne Ton. Habe da noch ein audio codec Problem.
                                  //UPDATE
                                  Ich habe zwei Fragen.
                                  1. Besteht die Möglichkeit neben MotionEvent auch ein IntrusionEvent auszulesen?
                                  2. Besteht die Möglichkeit Benachrichtigungen ans Handy via ioBroker ein-/auszuschalten? (Stichwort: Unterschiedliche Modi auswählen für An- bzw. Abwesenheit)
                                    chriss2007 last edited by
                                    Halo, ich bekomme immer regelmäßig diesen Fehler. Bildschirm­foto 2023-04-07 um 11.26.39.jpg
                                    Thomas Braun T 2 Replies Last reply Reply Quote 0
                                      Thomas Braun Most Active @chriss2007 last edited by
                                      @chriss2007
                                      Das ist in deinem Netzwerk. Ist das Ding stabil erreichbar?
                                      C 1 Reply Last reply Reply Quote 1
                                        tombox @chriss2007 last edited by
                                        @chriss2007 das Gerät ist mal nicht erreichbar kannst du was an deinem wlan verbessern
                                          @tombox an meinen wlan brauch ich nix verbessern da ist alles bestens. Ich schaue dann mal wo die Kamera sich angemeldet hat.
                                            chriss2007 @Thomas Braun last edited by
                                            @thomas-braun Fehler ist behoben. Hab zwei Repeater und fritzbox und die Kamera hat sich zu denn weit entferntesten Repeater verbunden. Hab diese gezwungen sich zum nähren zu verbinden. seit dem ist der Fehler weg
                                            753
                                            188632
