    4. Screenshot wird nicht erstellt.
    • Curtis777
      Curtis777 @Glasfaser last edited by
      @glasfaser
      sorry nicht bedacht.
      sudo apt-get install libfontconfig
      Habe ich natürlich bereits installiert.
      phantomjs.0
      2023-03-15 09:31:00.026	debug	Auto configuration failed 140246576924608:error:25066067:DSO support routines:DLFCN_LOAD:could not load the shared library:dso_dlfcn.c:185:filename(libssl_conf.so): libssl_conf.so: cannot open shared object file: No such file or directory 140246576924608:error:25070067:DSO support routines:DSO_load:could not load the shared library:dso_lib.c:244: 140246576924608:error:0E07506E:configuration file routines:MODULE_LOAD_DSO:error loading dso:conf_mod.c:285:module=ssl_conf, path=ssl_conf 140246576924608:error:0E076071:configuration file routines:MODULE_RUN:unknown module name:conf_mod.c:222:module=ssl_conf
      phantomjs.0
      2023-03-15 09:31:00.026	error	{"code":1,"killed":false,"signal":null,"cmd":"/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs --ignore-ssl-errors=true /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js --url http://192.168.0.2:8082/vis/index.html?main#home --output \"/opt/iobroker/cachefiles/kalender.png\""}
      phantomjs.0
      2023-03-15 09:31:00.025	debug	and save to "/opt/iobroker/cachefiles/kalender.png"
      phantomjs.0
      2023-03-15 09:31:00.004	debug	--ignore-ssl-errors=true /opt/iobroker/node_modules/iobroker.phantomjs/lib/rasterize.js --url http://192.168.0.2:8082/vis/index.html?main#home --output "/opt/iobroker/cachefiles/kalender.png"
      phantomjs.0
      2023-03-15 09:31:00.003	info	Create undefinedpx*undefinedpx in undefinedms - "http://192.168.0.2:8082/vis/index.html?main#home" => "/opt/iobroker/cachefiles/kalender.png"
        liv-in-sky @Curtis777 last edited by liv-in-sky
        @curtis777 ich hatte immer problem mit phantomJS - bin auf puppeteer adapter umgestiegen - funktioniert jetzt
        Curtis777 1 Reply Last reply Reply Quote 0
        • Curtis777
          Curtis777 @liv-in-sky last edited by
          @liv-in-sky der funktioniert bei mir nicht da ich iobroker im docker verwende und da auf den "Erschaffer" des Template abhängig bin.
          und da fehlen einige Dinge.
            Thomas Braun Most Active @Curtis777 last edited by
            @curtis777
            https://groups.google.com/a/opencast.org/g/dev/c/0Ghsxe6Wvr0
            • Curtis777
              Curtis777 @Thomas Braun last edited by
              Ich checks nicht ganz was ich ändern muss um es zum laufen zu bringen.
                @curtis777
                Im Docker-Dosen weiß ich das auch nicht.
                • Curtis777
                  Wie würde man das auf einem Pi lösen ?
                  Ich kann ja komplett auf das Dateisystem zugreifen.
                  allerdings weiss ich nicht wo ich anfangen soll!
                    @curtis777
                    export OPENSSL_CONF=aksdjklfsajdflsadhfkljsahfio
                    in ein Terminal hacken.
                    Wenn das funktioniert würde ich das in den Systemstart integrieren.
                    Systemweite Änderung für alle Benutzer siehe Datei /etc/profile.
                    Bei Debian gilt auch /etc/environment.
                    Curtis777 1 Reply Last reply Reply Quote 1
                    • Curtis777
                      Hab das mal so wie du gesagt hast blind reingehackt.
                        @curtis777
                        Auch mal wieder die klassischen Fehler...
                        NIE NIE NIE als root herumhampeln.
                        Und Text aus der Konsole als Text in CodeTags eingebettet hier rein, nicht als Screenshot.
                        • Curtis777
                          Hier im Docker ist alles abgeschlossen man kann nur per Webinterface intern rein.
                          Ausserdem kann der Root user welcher für den Docker zuständig ist nicht auf das System zugreifen.
                          root@HomeBeast:/opt/iobroker# export OPENSSL_CONF=aksdjklfsajdflsadhfkljsahfio
                            @curtis777
                            Ahja, die Docker-Kacke...
                            Curtis777 andre 3 Replies Last reply Reply Quote 0
                            • Curtis777
                              @thomas-braun funktioniert aber zum großteil 🙏
                              Jedoch hab ich hier probleme beim Screenshot erstellen.
                              • Curtis777
                                @thomas-braun Hast du noch eine Idee wie ich Screenshots in meinem Docker erstellen kann ?
                                Das würde mir einen Riesen Schritt nach vorne bringen.
                                Ich habe leider gerade keine Ahnung woran es liegt. 😞
                                Selbst das mit dem Screenshot ist schon ein Workaround für mich da mein Android so alt ist und keine neueren Webview packt.
                                somit kann ich die JS sachen nicht anzeigen lassen in der Wallpanel App.
                                im Browser und auf anderen Geräten zeigt er alles an.
                                  @curtis777 sagte in Screenshot wird nicht erstellt.:
                                  in meinem Docker
                                  Ich hab keine Ahnung von eingedockertem Krams.
                                  • Curtis777
                                    @thomas-braun hat ja so nichts mit Docker zu tun !
                                    Wie gesagt es ist wie ein eigenständiges Betriebssystem
                                      Nein, ein Docker ist eben nicht wie ein eigenständiges OS. Das ist ja das 'Problem'.
                                      • andre
                                        andre Developer @Thomas Braun last edited by
                                        @thomas-braun sagte in Screenshot wird nicht erstellt.:
                                        Ganz ehrlich, was läuft bei dir denn verkehrt? Must du zwangsläufig auf jeden Thread antworten, auch wenn es gar nicht dein Fachgebiet ist und du gar nichts dazu beitragen kannst? Tu uns doch bitte einen Gefallen und schreibe einfach mal gar nichts, wenn es nichts konstruktives ist!
                                        Dieses Docker gehate geht nicht nur mir mittlerweile tierisch auf die Eier. Ich meine wir sind eine tolerante Community. Wenn Docker nicht dein Ding ist, ist das für mich und sicher auch viele andere in Ordnung. Es wird hier niemand missioniert und
                                        wir resprektieren dein Wissen im Bereich Linux doch trotzdem! Aber bitte, bitte schenk dir in Zukunft solche Kommentare. Zumal @Curtis777 die Karten von Anfang an offen auf den Tisch gelegt hat:
                                        Kann jemand einen Fehler in meinem Skript entdecken ?
                                        IOB läuft auf einem unraid Docker Container
                                        ...Das wäre der Punkt gewesen zu sagen: "Das ist Docker, hier kann ich nichts beisteuern, da lass ich die Anderen ran."
                                        @Curtis777 Jetzt kann ich auch verstehen warum du den Eindruck hast, dass die ioBroker Community Unraid verteufelt! In meinen Augen ist das absoluter Quatsch! Die Community besteht zum Glück nicht nur aus @Thomas-Braun. Hier gibt es Viele die auch Docker verwenden (derzeit ca. 15% aller User) und einige die dies auch unter Unraid tun!
                                        Höre lieber auf Leute wie @Glasfaser der war mit seinem Fingerzeig schon dicht an der (hoffentlich) Lösung dran. 🙂
                                        @glasfaser sagte in Screenshot wird nicht erstellt.:
                                        https://forum.iobroker.net/search?term=--ignore-ssl-errors&in=titlesposts
                                        Über den Link habe ich nämlich dies gefunden:
                                        https://github.com/ioBroker/ioBroker.phantomjs/issues/19#issuecomment-757137884
                                        Unter Docker kannst du Umgebungsvariablen für den Container einfach beim Erstellen des Containers mitgeben.
                                        In Unraid müsste das so gehen:
                                        Angaben ohne Gewähr, kann es gerade auf meinem Unraid nicht testen, in meiner Testumgebung hat es mit der Umgebungsvariable aber geklappt und der Fehler ist weg.
                                        MfG,
                                        André
                                        liv-in-sky created this issue in ioBroker/ioBroker.phantomjs
                                        closed ssl error - autoconf failed #19
                                          Thomas Braun Most Active @andre last edited by
                                          @andre sagte in Screenshot wird nicht erstellt.:
                                          Alles prima.
                                          Docker ist halt imho die ungünstigste Umgebung, um einen Serverdienst dauerhaft zu betreiben.
                                          Codierknecht 1 Reply Last reply Reply Quote 1
                                          • Codierknecht
                                            Codierknecht Developer Most Active @Thomas Braun last edited by
                                            Das sehen andere allerdings völlig anders.
                                            Viele Produktivumgebungen diverser Serversysteme laufen mittlerweile als Docker-Container.
                                            Das ganze Thema DevOps kommt wohl kaum daran vorbei.
                                            Du hast allerdings insofern Recht, dass Anwender mit eh schon begrenzten Kenntnissen sich mit jeder weiteren Schicht noch zusätzliche Probleme in den Rucksack laden.
                                            Da kommen dann schon mal so Stilblüten wie Proxmox=>VM=>Docker=>Container bei raus. Für einen Einsteiger eher ein suboptimales Setup.
                                            1354
