    4. Test Adapter mihome-cloud
      tombox @tequila74 last edited by
      @tequila74 Wieviel Minuten nach dem Neustart kommt die erste Meldung
        DocGame @tombox last edited by
        @tombox Die neuste Github habe ich immer drauf.
        Nach Adapterstart kommen ja hunderte Infomeldungen. Diese ist nach Start nicht dabei.
        Zwischen den vielen Infomeldungen sind einige Warn- und Error-Meldungen.
        Ich habe diese mal zwischen den Infomeldungen rauskopiert....Vielleicht sind diese von Interesse für dich:
        mihome-cloud.0 2023-02-28 13:07:00.865	warn	No properties for lumi.sensor_86sw2.v1 Both Switch Sensor cannot extract information
        mihome-cloud.0 2023-02-28 13:07:00.865	warn	No properties for lumi.sensor_86sw2.v1 Right Switch Sensor cannot extract information
        mihome-cloud.0 2023-02-28 13:07:00.865	warn	No properties for lumi.sensor_86sw2.v1 Left Switch Sensor cannot extract information
        mihome-cloud.0 2023-02-28 13:07:04.045	warn	No properties for lumi.remote.b186acn01 Battery cannot extract information
        mihome-cloud.0 2023-02-28 13:07:04.045	warn	No properties for lumi.remote.b186acn01 Switch Sensor cannot extract information
        mihome-cloud.0 2023-02-28 13:07:12.918	warn	No properties for chuangmi.camera.ipc009 Memory Card Management cannot extract information
        mihome-cloud.0 2023-02-28 13:07:12.918	warn	No properties for chuangmi.camera.ipc009 P2P Stream cannot extract information
        mihome-cloud.0 2023-02-28 13:07:17.733	warn	No properties for lumi.sensor_ht.v1 Battery cannot extract information
        mihome-cloud.0 2023-02-28 13:09:31.108	error	Error: read ETIMEDOUT at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/adapters/http.js:569:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at ClientRequest.req.emit (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/http-cookie-agent/dist/http/create_cookie_agent.js:84:16) at TLSSocket.socketErrorListener (node:_http_client:494:9) at TLSSocket.emit (node:events:513:28)
        mihome-cloud.0 2023-02-28 13:09:31.058	error	Error: read ETIMEDOUT
        mihome-cloud.0 2023-02-28 13:09:31.058	error	/miotspec/prop/get
          tequila74 @tombox last edited by
          @tombox
          Also, Neustart des Adapters war gestern 15:11 Uhr.
          Die erste neue Meldung kam heute Nacht um 3:11 Uhr.
          Also genau 12h später. Seit dem alle 10min.
          • astuermer
            astuermer last edited by
            Hab hier leider auch täglich Meldungen wie diese...
            mihome-cloud.0
            2023-03-18 15:27:51.428 error {"code":0,"message":"auth err"}
            mihome-cloud.0
            2023-03-18 15:27:51.425 error AxiosError: Request failed with status code 401
            mihome-cloud.0
            2023-03-18 15:27:49.187 error {"code":0,"message":"auth err"}
            mihome-cloud.0
            2023-03-18 15:27:49.122 error AxiosError: Request failed with status code 401
              kuerfra @tombox last edited by
              @tombox Moin, alle Geräte (Fensterkontakte, Thermometer ) werden angezeigt, nur beim öffnen der Fenster Ändert sich nichts, die Anzeigen bleiben gleich.
              MfG
              kuerfra
              • astuermer
                Hab den Adapter heute neu von Github installiert... nun bekomme ich das... 😞
                mihome-cloud.0
                2023-03-20 18:49:03.056 error TypeError: service.properties is not iterable at MihomeCloud.extractRemotesFromSpec (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:491:40) at /opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:271:15 at MihomeCloud.getDeviceList (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:207:5) at MihomeCloud.onReady (/opt/iobroker/node_modules/iobroker.mihome-cloud/main.js:96:7)
                mihome-cloud.0
                2023-03-20 18:49:03.054 error TypeError: service.properties is not iterable
                  tombox @astuermer last edited by
                  @astuermer Bei welchem Gerät taucht der Fehler auf
                  astuermer 1 Reply Last reply Reply Quote 0
                  • astuermer
                    astuermer @tombox last edited by
                    @tombox Trat bei jedem auf (1x Saugroboter und 3x Lüfter)
                    Ich hab heute aber dann noch den Adapter komplett gelöscht.
                    Danach nochmal neu installiert und eingerichtet.
                    Aktuell alles grün...
                      kuerfra @kuerfra last edited by
                      @kuerfra sagte in Test Adapter mihome-cloud:
                      MfG
                      kuerfra
                      Ich frag dann nochmal, ist das richtig das die Kontakte nicht funktionieren, oder sollte es schon klappen ?
                      Dann brauch ich da nicht weiter nach Fehler suchen.
                      MfG
                      Kuerfra
                        tombox @kuerfra last edited by
                        @kuerfra kann ich nicht genau beantworten kann sein das es verzögert ist. aber bestimmte bluetooth Sachen gehen nicht
                        Olli_M 1 Reply Last reply Reply Quote 0
                        • Olli_M
                          Olli_M @tombox last edited by Olli_M
                          Danke dir
                          Olli
                            ParaChris82 last edited by
                            Hallo @tombox !
                            ich wollte mich hier mal noch offiziell für den Adapter bedanken. Obwohl er noch nicht offiziell ist, funktioniert er bei mir sehr gut.
                            Wirklich eine Bereicherung auf die ich lange gewartet habe 🙂
                            Danke dir und allen Testern.
                            VG Chris
                            • MigChip
                              MigChip last edited by
                              vielen dank für den Adapter 🙂 habe ihn jetzt mit meinem Dreame l10s ultra verbunden.
                              Wie kann ich jetzt die Raumreinigung starten?
                              Grüße Miguel
                                Superdad last edited by
                                Cooler Adapter!
                                Funktioniert super bis jetzt.
                                Vielen Dank!
                                  Heute habe ich folgenden Fehler drin:
                                  Error: read ETIMEDOUT at Function.AxiosError.from (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/core/AxiosError.js:89:14) at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/axios/lib/adapters/http.js:591:25) at RedirectableRequest.emit (node:events:513:28) at RedirectableRequest.emit (node:domain:489:12) at ClientRequest.eventHandlers.<computed> (/opt/iobroker/node_modules/follow-redirects/index.js:14:24) at ClientRequest.emit (node:events:525:35) at ClientRequest.emit (node:domain:489:12) at ClientRequest.req.emit (/opt/iobroker/node_modules/iobroker.mihome-cloud/node_modules/http-cookie-agent/dist/http/create_cookie_agent.js:84:16) at TLSSocket.socketErrorListener (node:_http_client:502:9) at TLSSocket.emit (node:events:513:28)
                                    tombox @Superdad last edited by
                                    @superdad Sollte selten bei china server auftreten
                                      Herginator @tombox last edited by
                                      @tombox
                                      Hi tombox,
                                      ich habe den Adapter gestern entdeckt und gleich installiert 🙂 Zunächst lieben Dank für die Entwicklung bis hierhin!
                                      Leider bekomme ich inzwischen auch alle paar Minuten folgenden Fehler:
                                      Auch ein Neustart des Adapters ändert daran nichts. Server ist China.
                                      Hast Du eine Idee?
                                      LG
                                      Rob
                                        tombox @Herginator last edited by
                                        @herginator Kannst du die GitHub version mal installieren
                                          Herginator @tombox last edited by Herginator
                                          @tombox
                                          ok, ist nun installiert.
                                            @tombox
                                            Fehler sind leider weiterhin da.
                                            225
                                            37527
