    4. [Neuer Adapter] EuSec
    • astuermer
      astuermer @Fabio last edited by
      @fa-bio
      Keine Mail. Kein Captcha im Log.
      2023-03-22 14:23:30.258 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 (force=false, process=true)
      2023-03-22 14:23:30.269 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 send kill signal
      2023-03-22 14:23:30.950 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-22 14:23:31.121 - info: host.RasPi-Smarthome instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-03-22 14:23:31.122 - info: host.RasPi-Smarthome Restart adapter system.adapter.web.0 because enabled
      2023-03-22 14:23:32.247 - info: host.RasPi-Smarthome instance system.adapter.web.0 started with pid 5371
      2023-03-22 14:23:33.410 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 started with pid 5390
      2023-03-22 14:24:29.478 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 (force=false, process=true)
      2023-03-22 14:24:29.490 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 send kill signal
      2023-03-22 14:24:33.131 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-22 14:24:37.107 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 started with pid 6053
      2023-03-22 14:25:40.134 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 (force=false, process=true)
      2023-03-22 14:25:40.155 - info: host.RasPi-Smarthome stopInstance system.adapter.tuya.0 send kill signal
      2023-03-22 14:25:43.776 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-22 14:25:47.791 - info: host.RasPi-Smarthome instance system.adapter.tuya.0 started with pid 6793
      2023-03-22 14:30:56.925 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 (force=false, process=true)
      2023-03-22 14:30:56.945 - info: host.RasPi-Smarthome stopInstance system.adapter.eusec.0 send kill signal
      2023-03-22 14:30:57.600 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-03-22 14:30:57.692 - info: host.RasPi-Smarthome instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
      2023-03-22 14:30:57.693 - info: host.RasPi-Smarthome Restart adapter system.adapter.web.0 because enabled
      2023-03-22 14:30:58.824 - info: host.RasPi-Smarthome instance system.adapter.web.0 started with pid 9916
      2023-03-22 14:31:00.079 - info: host.RasPi-Smarthome instance system.adapter.eusec.0 started with pid 9932
      Fabio 1 Reply Last reply Reply Quote 0
      • Fabio
        Fabio @astuermer last edited by
        @astuermer läuft der web adapter?
        astuermer 1 Reply Last reply Reply Quote 0
        • astuermer
          astuermer @Fabio last edited by astuermer
          @fa-bio Jap, der ist grün.
          Zuerst auf allen IPs, habs aber auf die WLAN IP meines Raspberrys jetzt gelegt.
          Port 8082 ist eingestellt.
          Mein ioBroker läuft auf Port 8084.
          Ist das ein Problem?
          Fabio 2 Replies Last reply Reply Quote 0
          • Fabio
            @astuermer ja dann weiß ich auch nicht. Evtl. solltest du dann mit zwei Faktor arbeiten bei Eufy. Ist dein Sytem aktuell?
            • astuermer
              @fa-bio Hab auch soeben 2FA aktiviert, da kommt aber auch nichts im Log.
              System ist aktuell, Update läuft 2x wöchentlich.
              • Fabio
                @astuermer meiner auf 8082 könnte evtl daran liegen
                • Fabio
                  @astuermer du musst doch eine Email von Eufy bekommen.
                  • astuermer
                    @fa-bio Ja, war für die 2FA Aktivierung am Smartphone.
                    Aber derselbe Code wird ja nicht in ioBroker funktionieren nehm ich an?
                    • Fabio
                      Fabio @astuermer last edited by Fabio
                      @astuermer doch trage ihn ein unter objekte eusec verify_code
                      • astuermer
                        @fa-bio Ok hab ihn eingetragen, er wird dann aber rot - hat das was zu bedeuten?
                        Verbindung dennoch nicht möglich, vermutlich wegen dem noch fehlenden Captcha. Wie kommt man an das wenns im Log nicht aufscheint?
                        • astuermer
                          astuermer @astuermer last edited by
                          @astuermer Fehler gefunden... 😄 Das Log für den Adapter war nur auf error gestellt. Hab nun Captcha und 2FA bekommen. Adapter ist grün 🙂
                          • Fabio
                            @astuermer prima 👍 😊
                            • astuermer
                              @fa-bio Eine Frage aber noch... bei mir sind die 4 Datenfelder für "livestream" und "last_livestream*" leer bzw auf NULL. Wie bekomme ich da die Daten rein?
                              Ist eine Eufy Solocam E40.
                              • Fabio
                                @astuermer es wird zur Zeit nicht mehr unterstüzt bitte lesen:
                                https://github.com/bropat/ioBroker.eusec/releases/tag/0.9.10
                                • astuermer
                                  @fa-bio Ach mist, danke. Hatte die Cam extra bestellt weil sie als kompatibel auf Github markiert war 🙂
                                  Danke trotzdem!
                                  • Fabio
                                    @astuermer ist sie ja auch 😉 , das Problem liegt da wohl bei Eufy, so wie ich das verstehe.🤷‍♂️
                                      MINKI @Fabio last edited by
                                      @fa-bio Ich klinke mich hier jetzt aus. Habe meine cams eingepackt und die gehen zurück nach China. Habe vorgestern eine andere Cam gekauft und läuft bereits heute problemlos in der Home-App. Danke für euren ganzen Support hier! Macht weiter so!
                                      • Fabio
                                        Fabio @MINKI last edited by
                                        @minki okay gern geschehen, hab viel Freude mit deiner neuen Cam. 👍😉
                                          bishop9191 last edited by
                                          Gibts denn Alternativen zu Eufy?
                                          -Komplett Kabellos
                                          -kein Abo
                                          -einbindbar in ioBroker
                                          astuermer 1 Reply Last reply Reply Quote 1
                                          • astuermer
                                            astuermer @bishop9191 last edited by
                                            @bishop9191 Ich hab mir statt der Eufy Solocam jetzt die Eufycam 2C geholt. Derzeit mit 40 Euro Rabatt und direkt Homekit kompatibel - so spar ich mir die Einbindung über ioBroker.
                                            1.2k
                                            adapter cameras doorbell eufy eufycam security
                                            160
                                            1173
                                            456159
