    4. TEST - Adapter Fully Browser mit MQTT (0.0.11)
      ManfredHi last edited by
      Ich bekomme keine Verbindung. Im debug-Logfile steht folgendes:
      2023-03-21 19:50:23.331 - debug: fully-mqtt.0 (3757147) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-03-21 19:50:23.399 - debug: fully-mqtt.0 (3757147) Objects client ready ... initialize now
      2023-03-21 19:50:23.400 - debug: fully-mqtt.0 (3757147) Objects create System PubSub Client
      2023-03-21 19:50:23.401 - debug: fully-mqtt.0 (3757147) Objects create User PubSub Client
      2023-03-21 19:50:23.573 - debug: fully-mqtt.0 (3757147) Objects client initialize lua scripts
      2023-03-21 19:50:23.577 - debug: fully-mqtt.0 (3757147) Objects connected to redis: 127.0.0.1:9001
      2023-03-21 19:50:23.643 - debug: fully-mqtt.0 (3757147) Redis States: Use Redis connection: 127.0.0.1:6379
      2023-03-21 19:50:23.649 - debug: fully-mqtt.0 (3757147) States create System PubSub Client
      2023-03-21 19:50:23.650 - debug: fully-mqtt.0 (3757147) States create User PubSub Client
      2023-03-21 19:50:23.659 - debug: fully-mqtt.0 (3757147) States connected to redis: 127.0.0.1:6379
      2023-03-21 19:50:23.811 - info: fully-mqtt.0 (3757147) starting. Version 0.0.8 (non-npm: Acgua/ioBroker.fully-mqtt#9dbcc3f09e70be6688d93d8544027aab1514a846) in /opt/iobroker/node_modules/iobroker.fully-mqtt, node: v16.19.0, js-controller: 4.0.24
      2023-03-21 19:50:23.827 - debug: fully-mqtt.0 (3757147) Final Config: {"name":"Galaxy Tab S2","id":"Galaxy_Tab_S2","ip":"192.168.0.88","useMQTT":true,"restProtocol":"http","restPort":2323,"restPassword":"xxxx","lastSeen":0,"isAlive":false,"timeoutRestRequestInfo":null,"mqttInfoObjectsCreated":false,"mqttInfoKeys":[],"restInfoKeys":[]}
      2023-03-21 19:50:23.828 - debug: fully-mqtt.0 (3757147) Device Galaxy Tab S2 (192.168.0.88) is not enabled, so skip it.
      2023-03-21 19:50:23.828 - error: fully-mqtt.0 (3757147) No active devices with correct configuration found.
      2023-03-21 19:50:23.829 - error: fully-mqtt.0 (3757147) Adapter settings initialization failed. ---> Please check your adapter instance settings!
      Im Fullybrowser ist folgendes eingestellt:
      Der Adapter hat folgende Einstellungen:
      Wo hab ich da den Fehler ?
      • Neuschwansteini
        Neuschwansteini last edited by
        @manfredhi
        Lt logfile ist das Tablett im Adapter nicht enabled, also mal Haken raus und wieder rein…
          ManfredHi @Neuschwansteini last edited by
          @ilovegym sagte in TEST - Adapter Fully Browser mit MQTT (0.0.4):
          @manfredhi
          Alles schon ausprobiert. Funktioniert einfach nicht. Adapter bleibt gelb und immer die gleiche Fehlermeldung im Log.
          metaxa 1 Reply Last reply Reply Quote 1
          • metaxa
            metaxa @ManfredHi last edited by metaxa
            @acgua & @manfredhi ich schließe mich an, bei mir exakt das gleiche Fehlerbild.
            fully-mqtt.0
            3405440	2023-03-21 23:26:16.730	error	Adapter settings initialization failed. ---> Please check your adapter instance settings!
            fully-mqtt.0
            3405440	2023-03-21 23:26:16.727	error	No active devices with correct configuration found.
            fully-mqtt.0
            3405440	2023-03-21 23:26:16.726	debug	Device Tab3_Bad (192.168.0.121) is not enabled, so skip it.
            fully-mqtt.0
            3405440	2023-03-21 23:26:16.723	debug	Final Config: {"name":"Tab3_Bad","id":"Tab3_Bad","ip":"192.168.0.121","useMQTT":true,"restProtocol":"http","restPort":2323,"restPassword":"xxxxxxx","lastSeen":0,"isAlive":false,"timeoutRestRequestInfo":null,"mqttInfoObjectsCreated":false,"mqttInfoKeys":[],"restInfoKeys":[]}
            fully-mqtt.0
            3405440	2023-03-21 23:26:16.655	info	starting. Version 0.0.8 (non-npm: Acgua/ioBroker.fully-mqtt#9dbcc3f09e70be6688d93d8544027aab1514a846) in /opt/iobroker/node_modules/iobroker.fully-mqtt, node: v16.19.1, js-controller: 4.0.24
            fully-mqtt.0
            3403847	2023-03-21 23:26:02.333	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            Hakerl schon mehrfach raus & rein und immer wieder abgespeichert. Leider nein. Tablet auch schon neu gestartet, leider keine Änderung.
            Neuschwansteini 1 Reply Last reply Reply Quote 0
            • Neuschwansteini
              Neuschwansteini @metaxa last edited by
              @metaxa @ManfredHi @Acgua
              den einzigsten Unterschied, den ich erkenne, ist, dass ich bei mqtt ein Username und Passwort verwende, und bei euch das nicht der Fall ist.
              Vielleicht ist hier im Code der Wurm drin ?
              • metaxa
                metaxa @Neuschwansteini last edited by
                @ilovegym @ManfredHi @Acgua sagte in TEST - Adapter Fully Browser mit MQTT (0.0.4):
                Leider Nein!
                Neuschwansteini M 2 Replies Last reply Reply Quote 0
                • Neuschwansteini
                  @metaxa @Acgua
                  da ist ein Bug in der 0.0.8, bei mir sind nach dem upgrade KEINE Haken vorne gesetzt, und es funktioniert...
                    ManfredHi @metaxa last edited by
                    @metaxa @ilovegym @Acgua sagte in TEST - Adapter Fully Browser mit MQTT (0.0.4):
                    Leider Nein!
                    Bei mir genauso. Kein Unterschied ob mit username und password oder ohne, egal ob das nicht verifizieren angehakt ist oder nicht. Der Adapter bleibt auf gelb und es ist immer die gleiche FEhlermeldung im log.
                    Acgua 1 Reply Last reply Reply Quote 0
                    • Acgua
                      Acgua @ManfredHi last edited by
                      Sorry, ist ein Bug, wird alsbald behoben. Ich melde mich wieder.
                      Acgua 1 Reply Last reply Reply Quote 2
                      • Acgua
                        Acgua @Acgua last edited by Acgua
                        jetzt ausführlicher. Danke für eure Rückmeldungen @ManfredHi @metaxa @ilovegym
                        War ein Bug in der Adapter-Konfiguration. In der ersten Spalte aktivierte Geräte wurden nicht mehr als aktiviert erkannt, da wurde ein "suchen/ersetzen" bei Übersetzungs-Umsetzungen falsch gesetzt.
                        Sollte nun in Version 0.0.9 korrigiert sein.
                        WICHTIG: Falls Update von vorheriger Version: In die Adapter-Einstellungen gehen und bei allen Geräten in der Tabelle das Häkchen in der ersten Spalte (siehe roter Pfeil oben) 2x anklicken, d.h. inaktiv und wieder aktiv setzen. Danach speichern. Das ist einmalig nötig, weil der Identifizierer dieser Option geändert wurde.
                        Sollte das nicht gehen, meldet euch hier. Alternativ könnt ihr die Instanz löschen und neu hinzufügen, sollte aber nicht notwendig sein.
                        Bitte testen. Danke 🙂
                        0.0.9 (2023-03-22)
                        • (Acgua) Breaking Change If you update from a previous version: In Adapter config, device table: disable and enable your all of your devices, and save options afterwards.
                        • (Acgua) Bug fix: enabled devices in config were skipped
                        • (Acgua) English adapter documentation added.
                        • (Acgua) Adapter was added to Weblate (#108)
                        • (Acgua) Verified that device objects are removed when device was deleted or renamed in config
                        metaxa 1 Reply Last reply Reply Quote 0
                        • metaxa
                          metaxa @Acgua last edited by metaxa
                          @acgua Sieht vielversprechend aus 🙂
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:40.447	debug	[MQTT] Tab3_Bad: Creating info objects (if not yet existing)
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:40.447	debug	[MQTT]📡 Tab3_Bad published info, topic: fully/deviceInfo/16c1a367-a11e0afe
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:40.445	debug	[MQTT] Client ad79a841-5ed8-44e7-9911-40e5ca60685e = Tab3_Bad = 192.168.0.121
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:39.690	info	[MQTT] Tab3_Bad is alive.
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:39.687	info	[MQTT]🔗 Client Tab3_Bad (192.168.0.121) successfully connected.
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:39.686	debug	[MQTT] Client Tab3_Bad (192.168.0.121) connected to broker 2d570c3a-308c-4309-a8c3-8521ef1f23e2
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:39.683	info	[MQTT]🔑 Client Tab3_Bad (192.168.0.121) successfully authenticated.
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:39.682	info	[MQTT] Client Tab3_Bad (192.168.0.121) trys to authenticate...
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:39.678	debug	[MQTT] client.conn.remoteAddress = "::ffff:192.168.0.121" - ad79a841-5ed8-44e7-9911-40e5ca60685e
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:28.115	info	[MQTT]🚀 Server started and listening on port 3000
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:28.104	debug	Start main() - Tab3_Bad (192.168.0.121)…
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:28.012	debug	Adapter settings successfully verified and initialized.
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:28.009	info	🗸 Tab3_Bad (192.168.0.121): Config successfully verified.
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:28.008	info	Tab3_Bad (192.168.0.121) MQTT is activated in adapter instance settings.
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:27.991	debug	Final Config: {"name":"Tab3_Bad","id":"Tab3_Bad","ip":"192.168.0.121","useMQTT":true,"restProtocol":"http","restPort":2323,"restPassword":"xxxxxx","lastSeen":0,"isAlive":false,"timeoutRestRequestInfo":null,"mqttInfoObjectsCreated":false,"mqttInfoKeys":[],"restInfoKeys":[]}
                          fully-mqtt.0
                          2021567	2023-03-22 20:20:27.869	info	starting. Version 0.0.9 (non-npm: Acgua/ioBroker.fully-mqtt#6d21ea182d0b600b2868059f30e32fa1c099870d) in /opt/iobroker/node_modules/iobroker.fully-mqtt, node: v16.19.1, js-controller: 4.0.24
                          Acgua 1 Reply Last reply Reply Quote 1
                          • Acgua
                            Acgua @metaxa last edited by
                            @metaxa
                            freut mich, danke für deine Rückmeldung.
                            Achtung: Im Debug-Log wird in Zeile Final Config: ... das MQTT-Passwort ausgegeben. Oben auch in deinem Auszug. Bitte entfernen, falls du das nicht möchtest.
                            Ich habe mir hierfür ein Issue aufgemacht.
                            https://github.com/Acgua/ioBroker.fully-mqtt/issues/14
                            Acgua created this issue in Acgua/ioBroker.fully-mqtt
                            closed Debug Log shows the clear Remote Admin Password in "Final Config: ..." #14
                            metaxa 2 Replies Last reply Reply Quote 1
                            • metaxa
                              @acgua sagte in TEST - Adapter Fully Browser mit MQTT (0.0.4):
                              Gestern hatte ich es noch gesehen und ausgebessert, vorhin gerade daran gedacht aber vor Freude über die Funktion des Adapters das Löschen vegessen 🙂
                              Bitte entfernen
                              done.
                              • metaxa
                                nein, es wird das "Remote Admin Password" ausgegeben
                                • Acgua
                                  @metaxa
                                  danke 🙂
                                  Ist behoben.
                                  debug: fully-mqtt.0 Final Config: {"name":"123", ... "restPassword":"(hidden)", ...}
                                  0.0.10 (2023-03-22)
                                  • (Acgua) Do not show Remote Admin Password in debug log (#14)
                                    Der Adapter startet nun, so wie es sein soll. Der Objektbaum ist auch vorhanden.
                                    Wenn ich jedoch etwas aus den Commands ausführen will (z.B. restartApp oder loadstarturl usw.) bekomme ich folgende Fehlermeldung im Logfile und es passiert nichts weiter.
                                    fully-mqtt.0
                                    2023-03-22 21:20:07.425	error	[REST] [REST] Galaxy Tab S2: Undefined response when sending cmd sendCmd: 200 - OK
                                    fully-mqtt.0
                                    2023-03-22 21:14:28.473	error	[REST] [REST] Galaxy Tab S2: Undefined response when sending cmd sendCmd: 200 - OK
                                    fully-mqtt.0
                                    2023-03-22 21:11:27.131	error	[REST] [REST] Galaxy Tab S2: Undefined response when sending cmd sendCmd: 200 - OK
                                    • Acgua
                                      @manfredhi
                                      Was bekommst du denn als Ausgabe, wenn du im Browser folgendes eingibst:
                                      http://x.x.x.x:2323/?cmd=loadStartURL&type=json&password=zzz
                                      Dabei:
                                      • x.x.x.x durch die IP-Adresse vom Fully Tablet ersetzen
                                      • zzz durch dein Remote Admin Passwort ersetzen
                                        ManfredHi @Acgua last edited by
                                        Das hier:
                                        {"statustext":"Loading Start URL http://192.168.0.30:9082/vis/index.html?tablet#PV ...","status":"OK"}
                                        Acgua 2 Replies Last reply Reply Quote 0
                                        • Acgua
                                          Acgua @ManfredHi last edited by Acgua
                                          @manfredhi
                                          danke. Ich schau mir das morgen an.
                                          Ggf. muss wohl noch weitere Debug-Logausgaben hinzufügen, um die Ursache zu finden, da es ja bei anderen, und bei mir, ja funktioniert.
                                          Ich kann es aber ziemlich gut eingrenzen im Adapter Code.
                                          • Acgua
                                            @manfredhi
                                            Kannst du bitte Debug Log einschalten, und dann noch mal testen (Command loadStartUrl ausführen), und das komplette Log hier posten ab Adapter-Start.
                                            31.7k
                                            79.8k
                                            87
                                            7806
