    4. Yet another HomeKit adapter
      Thomas Braun Most Active @MINKI last edited by Thomas Braun
      @minki
      Möglicherweise läuft der Ton über ein unfreies Format.
      Da muss dann evtl. der entsprechende Codec nachinstalliert werden.
      Versuch mal mit
      sudo apt update
      sudo apt install libavcodec-extra
      dein Glück.
      Ansonsten würde ich mir den Stream anschauen:
      https://trac.ffmpeg.org/wiki/FFprobeTips
        MINKI @Thomas Braun last edited by
        @thomas-braun said in Yet another HomeKit adapter:
        Guter Tipp! Folgendes hat ffprobe ausgespuckt:
        STREAM]
        index=0
        codec_name=h264
        codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
        profile=Main
        codec_type=video
        codec_tag_string=[0][0][0][0]
        codec_tag=0x0000
        width=2560
        height=1440
        coded_width=2560
        coded_height=1440
        closed_captions=0
        has_b_frames=0
        sample_aspect_ratio=N/A
        display_aspect_ratio=N/A
        pix_fmt=yuv420p
        level=50
        color_range=tv
        color_space=unknown
        color_transfer=unknown
        color_primaries=unknown
        chroma_location=left
        field_order=progressive
        refs=1
        is_avc=false
        nal_length_size=0
        id=N/A
        r_frame_rate=20/1
        avg_frame_rate=15/1
        time_base=1/90000
        start_pts=30000
        start_time=0.333333
        duration_ts=N/A
        duration=N/A
        bit_rate=N/A
        max_bit_rate=N/A
        bits_per_raw_sample=8
        nb_frames=N/A
        nb_read_frames=N/A
        nb_read_packets=N/A
        DISPOSITION:default=0
        DISPOSITION:dub=0
        DISPOSITION:original=0
        DISPOSITION:comment=0
        DISPOSITION:lyrics=0
        DISPOSITION:karaoke=0
        DISPOSITION:forced=0
        DISPOSITION:hearing_impaired=0
        DISPOSITION:visual_impaired=0
        DISPOSITION:clean_effects=0
        DISPOSITION:attached_pic=0
        DISPOSITION:timed_thumbnails=0
        [/STREAM]
        [STREAM]
        index=1
        codec_name=pcm_alaw
        codec_long_name=PCM A-law / G.711 A-law
        profile=unknown
        codec_type=audio
        codec_tag=0x0000
        sample_fmt=s16
        sample_rate=8000
        channels=1
        channel_layout=unknown
        bits_per_sample=8
        id=N/A
        r_frame_rate=0/0
        avg_frame_rate=0/0
        time_base=1/8000
        start_pts=0
        start_time=0.000000
        duration_ts=N/A
        duration=N/A
        bit_rate=64000
        max_bit_rate=N/A
        bits_per_raw_sample=N/A
        nb_frames=N/A
        nb_read_frames=N/A
        nb_read_packets=N/A
        DISPOSITION:dub=0
        [/STREAM]
        [FORMAT]
        filename=<CENSORED>
        nb_streams=2
        nb_programs=0
        format_name=rtsp
        format_long_name=RTSP input
        start_time=0.000000
        duration=N/A
        size=N/A
        bit_rate=N/A
        probe_score=100
        TAG:title=Session streamed by "TP-LINK RTSP Server"
        [/FORMAT]
          @minki sagte in Yet another HomeKit adapter:
          pcm_alaw
          Sollte eigentlich aber unterstützt werden.
          ffmpeg -formats | grep PCM
          sagt?
            ffmpeg version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2000-2021 the FFmpeg developers
              built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
              configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
              WARNING: library configuration mismatch
              avcodec     configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --enable-version3 --disable-doc --disable-programs --enable-libaribb24 --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libtesseract --enable-libvo_amrwbenc --enable-libsmbclient
              libavutil      56. 70.100 / 56. 70.100
              libavcodec     58.134.100 / 58.134.100
              libavformat    58. 76.100 / 58. 76.100
              libavdevice    58. 13.100 / 58. 13.100
              libavfilter     7.110.100 /  7.110.100
              libswscale      5.  9.100 /  5.  9.100
              libswresample   3.  9.100 /  3.  9.100
              libpostproc    55.  9.100 / 55.  9.100
             DE alaw            PCM A-law
             DE f32be           PCM 32-bit floating-point big-endian
             DE f32le           PCM 32-bit floating-point little-endian
             DE f64be           PCM 64-bit floating-point big-endian
             DE f64le           PCM 64-bit floating-point little-endian
             DE mulaw           PCM mu-law
             DE s16be           PCM signed 16-bit big-endian
             DE s16le           PCM signed 16-bit little-endian
             DE s24be           PCM signed 24-bit big-endian
             DE s24le           PCM signed 24-bit little-endian
             DE s32be           PCM signed 32-bit big-endian
             DE s32le           PCM signed 32-bit little-endian
             DE s8              PCM signed 8-bit
             DE u16be           PCM unsigned 16-bit big-endian
             DE u16le           PCM unsigned 16-bit little-endian
             DE u24be           PCM unsigned 24-bit big-endian
             DE u24le           PCM unsigned 24-bit little-endian
             DE u32be           PCM unsigned 32-bit big-endian
             DE u32le           PCM unsigned 32-bit little-endian
             DE u8              PCM unsigned 8-bit
             DE vidc            PCM Archimedes VIDC
            wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
            • wendy2702
              wendy2702 @MINKI last edited by
              @minki Führe doch mal bitte das ffmpeg kommando aus und zeige das log davon. Laut den Einstellungen im Adapter versucht er AAC als Codec.
              Müsste man mal im ffmpeg befehl schauen und zum testen ersetzen.
                Das macht mich schon stutzig.
                Ist bei meiner Installation nicht der Fall.
                  MINKI @wendy2702 last edited by MINKI
                  @wendy2702
                  Das schmeißt der Log raus wenn der Stream mit Ton ausgeführt wird.
                  Session Request:{ "sessionID": "14c4a5bf-d742-4daf-b34e-bef2745dd025", "type": "start", "video": { "codec": 0, "profile": 2, "level": 2, "packetizationMode": 0, "width": 1280, "height": 720, "fps": 30, "pt": 99, "ssrc": 3828249404, "max_bit_rate": 299, "rtcp_interval": 0.5, "mtu": 1378 }, "audio": { "codec": "AAC-eld", "channel": 1, "bit_rate": 0, "sample_rate": 16, "packet_time": 30, "pt": 110, "ssrc": 420990154, "max_bit_rate": 24, "rtcp_interval": 5, "comfort_pt": 13, "comfortNoiseEnabled": false } }
                  Meine Audio Stream Config aus dem Adapter sieht wie folgt aus (UNVERÄNDERT):
                    "-vn",
                    "-sn",
                    "-dn",
                    "-codec:a",
                    "libfdk_aac",
                    "-profile:a",
                    "aac_eld",
                    "-flags",
                    "+global_header",
                    "-f",
                    "null",
                    "-ar",
                    "${samplerate}k",
                    "-b:a",
                    "${bitrate}k",
                    "-bufsize:a",
                    "${bitrate}k",
                    "-ac",
                    "${channel}",
                    "-payload_type",
                    "${payloadtype}",
                    "-ssrc",
                    "${targetAudioSsrc}",
                    "-f",
                    "rtp",
                    "-srtp_out_suite",
                    "AES_CM_128_HMAC_SHA1_80",
                    "-srtp_out_params",
                    "${audiokey}",
                    "srtp://${targetAddress}:${targetAudioPort}?rtcpport=${targetAudioPort}&localrtcpport=${targetAudioPort}&pkt_size=188"
                  • wendy2702
                    @minki Wie sieht der vollständige FFMPEG Befehl aus?
                    Login daten der Kamera kannst du ersetzen.
                    Steht da was von
                    - quiet
                    drin?
                    füge mal
                    - loglevel verbose
                    direkt hinter das "ffmpeg" ein.
                      @wendy2702 Sorry, was meinst du mit FFMPEG Befehl? Ich habe unter stream properties in yahka "ADD CAMERA" den rtsp stream eingegeben. Ich rufe selber keinen FFMPEG Befehl auf. Muss ich das tun?
                      • wendy2702
                        @minki Kannst du mal die Yahka Instanz auf "Debug" stellen und dann schauen ob im iob log der "FFMPEG" Befehl kommt wenn du den Stream startest.
                          @wendy2702
                          yahka.0
                          2023-03-22 22:09:37.344	debug	Session Request:{ "sessionID": "e230bf3a-9312-43ba-bbd8-1417ed069f24", "type": "start", "video": { "codec": 0, "profile": 2, "level": 2, "packetizationMode": 0, "width": 1280, "height": 720, "fps": 30, "pt": 99, "ssrc": 281489091, "max_bit_rate": 299, "rtcp_interval": 0.5, "mtu": 1378 }, "audio": { "codec": "AAC-eld", "channel": 1, "bit_rate": 0, "sample_rate": 16, "packet_time": 30, "pt": 110, "ssrc": 2212050935, "max_bit_rate": 24, "rtcp_interval": 5, "comfort_pt": 13, "comfortNoiseEnabled": false } }
                          yahka.0
                          2023-03-22 22:09:33.541	debug	Snapshot run: ffmpeg -re -i rtsp://XXX:XXX@XXX:554/live/stream1 -t 1 -s 1280x720 -f image2 -
                          • wendy2702
                            "codec": "AAC-eld",
                            Ist ja der Falsche.
                            Kannst mal versuchen in den Erweiterten Einstellungen das zu ändern:
                            und da anstelle des AAC das einsetzen:
                            pcm_alaw
                            Sonst muss man sich tiefer mit der Syntax beschäftigen und testen. Ich habe aber keine Audio Kamera.
                              @wendy2702 said in Yet another HomeKit adapter:
                              pcm_alaw
                              Fehlermeldung bleibt gleich! Muss ich evtl auch den -codec:a ändern? Falls ja, was müsste da rein?
                                "-vn",
                                "-sn",
                                "-dn",
                                "-codec:a",
                                "libfdk_aac",
                                "-profile:a",
                                "pcm_alaw",
                                "-flags",
                                "+global_header",
                                "-f",
                                "null",
                                "-ar",
                                "${samplerate}k",
                                "-b:a",
                                "${bitrate}k",
                                "-bufsize:a",
                                "${bitrate}k",
                                "-ac",
                                "${channel}",
                                "-payload_type",
                                "${payloadtype}",
                                "-ssrc",
                                "-f",
                                "rtp",
                                "-srtp_out_suite",
                                "-srtp_out_params",
                                "${audiokey}",
                              • wendy2702
                                @minki Dafür würde ich gerne das FFMPEG LOG sehen.
                                Welche Version YAHKA und FFMPEG hast du installiert?
                                Wenn ich einen Livestream bei mir starte bekomme ich nur diese Einträge im log:
                                2023-03-23 08:17:15.109  - debug: yahka.4 (45656) Session Request:{
                                2023-03-23 08:17:15.292  - debug: yahka.4 (45656) FFMPEG: received first frame
                                2023-03-23 08:17:25.213  - debug: yahka.4 (45656) Stopped streaming session!
                                2023-03-23 08:17:25.225  - debug: yahka.4 (45656) [Video] ffmpeg exited with code: null and signal: SIGKILL (Video stream stopped!)
                                  @wendy2702
                                  Yahka --> 0.17.0
                                  ffmpeg --> 4.4.2
                                  Falls du was anderes brauchst, dann versteh ich leider nicht genau was du brauchst. Kannst du mir vielleicht sagen was ich dann tun müsste um dir die Info zur Verfügung zu stellen? Danke dir!
                                  • Hiltex
                                    Hiltex last edited by
                                    Ich habe vom vielen Testen noch zwei Kamera-Relikte in yahka. Kann mir jemand sagen, wie man die löscht?
                                    Der Button "Gerät entfernen" funktioniert dafür leider nicht.
                                    • wendy2702
                                      @minki Das wollte ich wissen, kann aber mangels Audio kamera nicht weiter testen.
                                        loverz last edited by
                                        Seit gestern ist die Aqara Doorbell G4 erhältlich.
                                        Die kann HKSV nativ. Vielleicht eine Alternative zu den Bastellösungen hier.
                                          TDCroPower last edited by TDCroPower
                                          Kann es sein das durch ein Update von 0.17.0 auf die 1.0.0 alle Geräte verloren gehen?
                                          Habe eben ein Update versucht und alles war weg.
                                          Bin daher zurück vor dem Update und wollte daher erstmal nachfragen bevor ich den Sprung erneut versuche.
                                          edit:
                                          sehe gerade gibt ja schon einen PullRequest dazu, wird wohl in 1.0.1 gefixt oder?
                                          https://github.com/jensweigele/ioBroker.yahka/pull/413
                                          TA2k created this issue in jensweigele/ioBroker.yahka
                                          closed Fix empty device list with rebuild #413
                                            MINKI @Hiltex last edited by MINKI
                                            @wendy2702
                                            WEnn du noch weitere Infos brauchst, lass es mich einfach wissen.
                                            80.8k
                                            1761
                                            795428
