    4. Adapter: SMA SEMP
    Adapter: SMA SEMP
      Webwanze @Rene_HM last edited by
      @rene_hm
      die Instanz wird jetzt grün:
      2023-03-11 09:55:55.393 - info: host.ioBroker "system.adapter.semp.0" enabled
      2023-03-11 09:55:55.426 - info: host.ioBroker instance system.adapter.semp.0 started with pid 53629
      2023-03-11 09:55:56.057 - debug: semp.0 (53629) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2023-03-11 09:55:56.076 - debug: semp.0 (53629) Objects client ready ... initialize now
      2023-03-11 09:55:56.078 - debug: semp.0 (53629) Objects create System PubSub Client
      2023-03-11 09:55:56.078 - debug: semp.0 (53629) Objects create User PubSub Client
      2023-03-11 09:55:56.099 - debug: semp.0 (53629) Objects client initialize lua scripts
      2023-03-11 09:55:56.103 - debug: semp.0 (53629) Objects connected to redis: 127.0.0.1:9001
      2023-03-11 09:55:56.114 - debug: semp.0 (53629) Redis States: Use Redis connection: 127.0.0.1:9000
      2023-03-11 09:55:56.120 - debug: semp.0 (53629) States create System PubSub Client
      2023-03-11 09:55:56.121 - debug: semp.0 (53629) States create User PubSub Client
      2023-03-11 09:55:56.128 - debug: semp.0 (53629) States connected to redis: 127.0.0.1:9000
      2023-03-11 09:55:56.154 - debug: semp.0 (53629) Plugin sentry Initialize Plugin (enabled=true)
      2023-03-11 09:55:56.299 - info: semp.0 (53629) starting. Version 0.3.1 (non-npm: rg-engineering/ioBroker.semp#6225ab9cb4be90b2b25f1f20179f6e884e287309) in /opt/iobroker/node_modules/iobroker.semp, node: v16.19.0, js-controller: 4.0.24
      2023-03-11 09:55:56.317 - debug: semp.0 (53629) SSDPServer created: http://192.168.1.2:9765/description.xml ba7895e3-74c6-47ee-a912-e544105b6f50
      2023-03-11 09:55:56.322 - debug: semp.0 (53629) SEMPServer created
      2023-03-11 09:55:56.322 - debug: semp.0 (53629) gateway created...
      2023-03-11 09:55:56.325 - debug: semp.0 (53629) SEMP server listening on 9765
      2023-03-11 09:55:56.328 - debug: semp.0 (53629) SSDPServer started
      2023-03-11 09:55:56.328 - debug: semp.0 (53629) gateway started...
      2023-03-11 09:55:56.328 - debug: semp.0 (53629) Started all!
      2023-03-11 09:55:56.328 - debug: semp.0 (53629) add device {"IsActive":true,"ID":"F-0-000000000001-00","Name":"newDevice0","Vendor":"ACME","Type":"Heater","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}]}
      2023-03-11 09:55:56.329 - debug: semp.0 (53629) add device F-0-000000000001-00
      2023-03-11 09:55:56.330 - error: semp.0 (53629) newDevice0 wrong device id F-0-000000000001-00! must follow F-xxxxxxxx-yyyyyyyyyyyy-zz
      2023-03-11 09:55:56.330 - debug: semp.0 (53629) can use optional energy: false
      2023-03-11 09:55:56.330 - debug: semp.0 (53629) subscribe OID_Power 0_userdata.0.DEVICES.ECENTRALHEATING_P
      2023-03-11 09:55:56.332 - info: semp.0 (53629) device created F-0-000000000001-00 newDevice0
      2023-03-11 09:55:56.333 - debug: semp.0 (53629) set device
      2023-03-11 09:55:56.333 - debug: semp.0 (53629) newDevice0 setState On
      2023-03-11 09:55:56.334 - debug: semp.0 (53629) UpdateData
      2023-03-11 09:55:56.334 - debug: semp.0 (53629) device {"IsActive":true,"ID":"F-0-000000000001-00","Name":"newDevice0","Vendor":"ACME","Type":"Heater","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}
      2023-03-11 09:55:56.334 - debug: semp.0 (53629) result [{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}]
      2023-03-11 09:55:56.334 - debug: semp.0 (53629) result [{"IsActive":true,"ID":"F-0-000000000001-00","Name":"newDevice0","Vendor":"ACME","Type":"Heater","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}]
      2023-03-11 09:55:56.348 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
      2023-03-11 09:55:56.350 - debug: semp.0 (53629) newDevice0 got null from Devices.newDevice0.State
      2023-03-11 09:55:56.351 - error: semp.0 (53629) newDevice0 could not set state waiting on Devices.newDevice0.State
      2023-03-11 09:55:56.354 - debug: semp.0 (53629) newDevice0 got null from Devices.newDevice0.State
      2023-03-11 09:55:56.355 - error: semp.0 (53629) newDevice0 could not set state on on Devices.newDevice0.State
      2023-03-11 09:55:56.357 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"recommended state from SHM","type":"boolean","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926725,"_id":"semp.0.Devices.newDevice0.RecommendedState","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2023-03-11 09:55:56.381 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"last time recommendation changed","type":"string","role":"value.time","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926734,"_id":"semp.0.Devices.newDevice0.Changed","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2023-03-11 09:55:56.385 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"current State","type":"string","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926738,"_id":"semp.0.Devices.newDevice0.State","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2023-03-11 09:55:56.386 - debug: semp.0 (53629) newDevice0 got object {"type":"state","common":{"name":"Energy used","type":"number","unit":"Wh","role":"value","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678524926744,"_id":"semp.0.Devices.newDevice0.Energy","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      2023-03-11 09:55:59.376 - debug: semp.0 (53629) SHM requested description
      2023-03-11 09:55:59.377 - info: semp.0 (53629) adapter discovered by SHM
      2023-03-11 09:56:00.033 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
      2023-03-11 09:56:00.033 - debug: semp.0 (53629) newDevice0 calc energy 117 1678524956349 = 0.11973000000000002Wh
      2023-03-11 09:56:15.007 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
      2023-03-11 09:56:15.008 - debug: semp.0 (53629) newDevice0 calc energy 117 1678524960033 = 0.6064175Wh
      2023-03-11 09:56:16.376 - debug: semp.0 (53629) SHM requested description
      2023-03-11 09:56:30.009 - debug: semp.0 (53629) newDevice0 setLastPower 117 number AlwaysOn W
      2023-03-11 09:56:30.009 - debug: semp.0 (53629) newDevice0 calc energy 117 1678524975008 = 1.09395Wh
      2023-03-11 09:56:36.377 - debug: semp.0 (53629) SHM requested description
      2023-03-11 09:56:45.007 - debug: semp.0 (53629) newDevice0 setLastPower 122 number AlwaysOn W
      2023-03-11 09:56:45.007 - debug: semp.0 (53629) newDevice0 calc energy 122 1678524990009 = 1.6022155555555555Wh
      Bei den Objekten finden sich immer noch die (null)s.
      Danke für deine Unterstützung!!!
      • Rene_HM
        Rene_HM Developer @Webwanze last edited by Rene_HM
        @webwanze sagte in Adapter: SMA SEMP:
        Der Fehler ist noch nicht behoben, nur ignoriert. Ich schaue das log nochmal genauer an. Irgendetwas passt noch nicht...
        und den Fehler darfst du auch nicht ignorieren...
          @rene_hm sagte in Adapter: SMA SEMP:
          Ich habe da nichts geändert. Die ID wurde beim Hinzufügen des Devices automatisch generiert. Habe es aber jetzt mal geändert. Macht natürlich keinen Unterschied.
          Über Java-Script
          setState("semp.0.Devices.newDevice0.State", "test")
          kann ich den State übrigens ändern.
          • Rene_HM
            für o.g. Problem macht es keinen Unterschied, funktionell ist das wichtig.
              Webwanze @Rene_HM last edited by Webwanze
              @rene_hm
              Ich habe noch etwas herumgespielt und auch was herausgefunden:
              Adapter installieren
              Device anlegen
              -> kein Update State
              Host neu starten
              State von Hand oder Script ändern
              -> Fehler verschwunden, allerdings wird mein String "test" nicht upgedated
              -> ich nehme an, weil sich der State für die Instanz nicht geändert hat, erfolgt kein Update. OK.
              Instanz neu starten
              -> Alles i.O.
              -> State wird auf "on" gesetzt.
                Webwanze @Webwanze last edited by Webwanze
                Wenn ich nun ein weiteres Device hinzufüge, wird der State ebenfalls nicht upgedated.
                State von Hand auf z.B. "off" setzen.
                Instanz neu starten
                funktioniert.
                Die Were für "Changed" und "RecommendedState" werden übrigens nicht gesetzt. Evtl. wird das auch nicht von der Instanz versucht ...
                Rene_HM 2 Replies Last reply Reply Quote 0
                • Rene_HM
                  Die Werte für "Changed" und "RecommendedState" werden übrigens nicht gesetzt
                  Die werden erst gesetzt, wenn eine Energieanforderung vom SHM beantwortet wurde. Solange du dein Gerät auf "immer an" hast und keine Energieanforderung stellst, reagiert der SHM nicht. Das Gerät wird dann nur im Portal dargestellt und zur Berechnung der Prognose herangezogen...
                  • Rene_HM
                    Instanz neu starten
                    funktioniert.
                    Habe die Reihenfolge des startups vom Adapter geändert. Außerdem schreibe ich jetzt default-Werte auf die DP. Hoffe, das löst das Problem...
                      @rene_hm
                      Scheint jetzt zu funkionieren:
                      2023-03-11 14:33:46.618 - info: host.ioBroker "system.adapter.semp.0" enabled
                      2023-03-11 14:33:46.650 - info: host.ioBroker instance system.adapter.semp.0 started with pid 4472
                      2023-03-11 14:33:47.283 - debug: semp.0 (4472) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-03-11 14:33:47.302 - debug: semp.0 (4472) Objects client ready ... initialize now
                      2023-03-11 14:33:47.303 - debug: semp.0 (4472) Objects create System PubSub Client
                      2023-03-11 14:33:47.304 - debug: semp.0 (4472) Objects create User PubSub Client
                      2023-03-11 14:33:47.317 - debug: semp.0 (4472) Objects client initialize lua scripts
                      2023-03-11 14:33:47.321 - debug: semp.0 (4472) Objects connected to redis: 127.0.0.1:9001
                      2023-03-11 14:33:47.332 - debug: semp.0 (4472) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-03-11 14:33:47.337 - debug: semp.0 (4472) States create System PubSub Client
                      2023-03-11 14:33:47.338 - debug: semp.0 (4472) States create User PubSub Client
                      2023-03-11 14:33:47.347 - debug: semp.0 (4472) States connected to redis: 127.0.0.1:9000
                      2023-03-11 14:33:47.370 - debug: semp.0 (4472) Plugin sentry Initialize Plugin (enabled=true)
                      2023-03-11 14:33:47.546 - info: semp.0 (4472) starting. Version 0.3.1 (non-npm: rg-engineering/ioBroker.semp#ba417263657375badc4c456e5859f8b0e308da66) in /opt/iobroker/node_modules/iobroker.semp, node: v16.19.0, js-controller: 4.0.24
                      2023-03-11 14:33:47.563 - debug: semp.0 (4472) SSDPServer created: http://192.168.1.2:9765/description.xml 58ee6313-b746-46aa-aae2-954018429865
                      2023-03-11 14:33:47.568 - debug: semp.0 (4472) SEMPServer created
                      2023-03-11 14:33:47.568 - debug: semp.0 (4472) gateway created...
                      2023-03-11 14:33:47.571 - debug: semp.0 (4472) SEMP server listening on 9765
                      2023-03-11 14:33:47.574 - debug: semp.0 (4472) SSDPServer started
                      2023-03-11 14:33:47.574 - debug: semp.0 (4472) gateway started...
                      2023-03-11 14:33:47.574 - debug: semp.0 (4472) Started all!
                      2023-03-11 14:33:47.575 - debug: semp.0 (4472) add device {"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}]}
                      2023-03-11 14:33:47.575 - debug: semp.0 (4472) add device F-12345678-123456789012-12
                      2023-03-11 14:33:47.576 - debug: semp.0 (4472) can use optional energy: false
                      2023-03-11 14:33:47.577 - info: semp.0 (4472) device created F-12345678-123456789012-12 newDevice0
                      2023-03-11 14:33:47.577 - debug: semp.0 (4472) set device
                      2023-03-11 14:33:47.577 - debug: semp.0 (4472) newDevice0 setState On
                      2023-03-11 14:33:47.578 - debug: semp.0 (4472) UpdateData
                      2023-03-11 14:33:47.579 - debug: semp.0 (4472) device {"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}
                      2023-03-11 14:33:47.579 - debug: semp.0 (4472) result [{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}]
                      2023-03-11 14:33:47.579 - debug: semp.0 (4472) result [{"IsActive":true,"ID":"F-12345678-123456789012-12","Name":"newDevice0","Vendor":"ACME","Type":"Dryer","SerialNr":"1234","MaxPower":"1000","MinPower":"0","InterruptionsAllowed":false,"MinOnTime":"","MaxOnTime":"","MinOffTime":"","MaxOffTime":"","MeasurementMethod":"Measurement","OID_Power":"0_userdata.0.DEVICES.ECENTRALHEATING_P","MeasurementUnit":"W","BatteryCapacity":"","WallboxHas3phaseEnabler":false,"StatusDetection":"AlwaysOn","StatusDetectionLimit":0,"StatusDetectionLimitTimeOn":0,"StatusDetectionLimitTimeOff":0,"StatusDetectionMinRunTime":0,"OID_Status":"","HasOIDSwitch":false,"OID_Switch":"","SwitchOffAtEndOfTimer":false,"TimerActive":false,"TimerCancelIfNotOn":false,"TimerCancelIfNotOnTime":0,"EnergyRequestPeriods":[{"ID":"1","Days":"","EarliestStartTime":"","LatestEndTime":"","MinRunTime":"","MaxRunTime":""}],"WallboxOIDs":[{"active":true,"must":"obligatorisch","Name":"DeviceOIDPlugConnected","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsCharging","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDIsError","OID":"","Type":"Boolean","SetValue":"true"},{"active":true,"must":"obligatorisch","Name":"DeviceOIDChargePower","OID":"","Type":"Number","SetValue":"0"},{"active":false,"must":"optional","Name":"DeviceOIDStartCharge","OID":"","Type":"Boolean","SetValue":"true"},{"active":false,"must":"optional","Name":"DeviceOIDStopCharge","OID":"","Type":"Boolean","SetValue":"true"}],"OptionalEnergy":false}]
                      2023-03-11 14:33:47.593 - debug: semp.0 (4472) newDevice0 got {"val":"on","ack":true,"ts":1678541192446,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1678541192446} from Devices.newDevice0.State
                      2023-03-11 14:33:47.597 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"recommended state from SHM","type":"boolean","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192445,"_id":"semp.0.Devices.newDevice0.RecommendedState","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.RecommendedState
                      2023-03-11 14:33:47.649 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"last time recommendation changed","type":"string","role":"value.time","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192499,"_id":"semp.0.Devices.newDevice0.Changed","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.Changed
                      2023-03-11 14:33:47.650 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"current State","type":"string","role":"state","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192505,"_id":"semp.0.Devices.newDevice0.State","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.State
                      2023-03-11 14:33:47.652 - debug: semp.0 (4472) newDevice0 got object {"type":"state","common":{"name":"Energy used","type":"number","unit":"Wh","role":"value","read":true,"write":false},"from":"system.adapter.semp.0","user":"system.user.admin","ts":1678541192509,"_id":"semp.0.Devices.newDevice0.Energy","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}} for Devices.newDevice0.Energy
                      2023-03-11 14:33:47.655 - debug: semp.0 (4472) subscribe OID_Power 0_userdata.0.DEVICES.ECENTRALHEATING_P
                      2023-03-11 14:33:47.657 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                      2023-03-11 14:33:47.681 - debug: semp.0 (4472) newDevice0 got {"val":"on","ack":true,"ts":1678541192446,"q":0,"from":"system.adapter.semp.0","user":"system.user.admin","lc":1678541192446} from Devices.newDevice0.State
                      2023-03-11 14:33:50.632 - debug: semp.0 (4472) SHM requested description
                      2023-03-11 14:33:50.632 - info: semp.0 (4472) adapter discovered by SHM
                      2023-03-11 14:33:56.466 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                      2023-03-11 14:33:56.466 - debug: semp.0 (4472) get all devices
                      2023-03-11 14:33:56.467 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                      2023-03-11 14:33:56.469 - debug: semp.0 (4472) response xml
                      newDevice0
                      Dryer
                      1234
                      ACME
                      1000
                      Measurement
                      false
                      false
                      false
                      true
                      On
                      33
                      0
                      60
                      2023-03-11 14:33:56.470 - debug: semp.0 (4472) response sent
                      2023-03-11 14:33:56.627 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                      2023-03-11 14:33:56.627 - debug: semp.0 (4472) get all devices
                      2023-03-11 14:33:56.627 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                      2023-03-11 14:33:56.628 - debug: semp.0 (4472) response xml
                      newDevice0
                      Dryer
                      1234
                      ACME
                      1000
                      Measurement
                      false
                      false
                      false
                      true
                      On
                      33
                      0
                      60
                      2023-03-11 14:33:56.629 - debug: semp.0 (4472) response sent
                      2023-03-11 14:33:56.727 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                      2023-03-11 14:33:56.727 - debug: semp.0 (4472) get all devices
                      2023-03-11 14:33:56.727 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                      2023-03-11 14:33:56.728 - debug: semp.0 (4472) response xml
                      newDevice0
                      Dryer
                      1234
                      ACME
                      1000
                      Measurement
                      false
                      false
                      false
                      true
                      On
                      33
                      0
                      60
                      2023-03-11 14:33:56.728 - debug: semp.0 (4472) response sent
                      2023-03-11 14:34:00.048 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                      2023-03-11 14:34:00.048 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541627657 = 0.11358416666666667Wh
                      2023-03-11 14:34:07.617 - debug: semp.0 (4472) SHM requested description
                      2023-03-11 14:34:15.008 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                      2023-03-11 14:34:15.008 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541640048 = 0.2507175Wh
                      2023-03-11 14:34:27.620 - debug: semp.0 (4472) SHM requested description
                      2023-03-11 14:34:30.026 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                      2023-03-11 14:34:30.027 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541655008 = 0.3883916666666667Wh
                      2023-03-11 14:34:41.757 - debug: semp.0 (4472) SHM requested description
                      2023-03-11 14:34:41.795 - debug: semp.0 (4472) SHM requested description
                      2023-03-11 14:34:45.008 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                      2023-03-11 14:34:45.008 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541670027 = 0.5257175000000001Wh
                      2023-03-11 14:34:47.615 - debug: semp.0 (4472) SHM requested description
                      2023-03-11 14:34:56.905 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                      2023-03-11 14:34:56.905 - debug: semp.0 (4472) get all devices
                      2023-03-11 14:34:56.906 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                      2023-03-11 14:34:56.907 - debug: semp.0 (4472) response xml
                      newDevice0
                      Dryer
                      1234
                      ACME
                      1000
                      Measurement
                      false
                      false
                      false
                      true
                      On
                      33
                      0
                      60
                      2023-03-11 14:34:56.909 - debug: semp.0 (4472) response sent
                      2023-03-11 14:34:57.093 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                      2023-03-11 14:34:57.093 - debug: semp.0 (4472) get all devices
                      2023-03-11 14:34:57.094 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                      2023-03-11 14:34:57.094 - debug: semp.0 (4472) response xml
                      newDevice0
                      Dryer
                      1234
                      ACME
                      1000
                      Measurement
                      false
                      false
                      false
                      true
                      On
                      33
                      0
                      60
                      2023-03-11 14:34:57.095 - debug: semp.0 (4472) response sent
                      2023-03-11 14:34:57.185 - debug: semp.0 (4472) SHM requested all devices. /semp/ ::ffff:192.168.0.49 http
                      2023-03-11 14:34:57.186 - debug: semp.0 (4472) get all devices
                      2023-03-11 14:34:57.186 - debug: semp.0 (4472) get all devices [{"deviceInfo":{"Identification":{"DeviceId":"F-12345678-123456789012-12","DeviceName":"newDevice0","DeviceType":"Dryer","DeviceSerial":"1234","DeviceVendor":"ACME"},"Characteristics":{"MaxPowerConsumption":"1000"},"Capabilities":{"CurrentPower":{"Method":"Measurement"},"Timestamps":{"AbsoluteTimestamps":false},"Interruptions":{"InterruptionsAllowed":false},"Requests":{"OptionalEnergy":false}}},"deviceStatus":{"DeviceId":"F-12345678-123456789012-12","EMSignalsAccepted":true,"Status":"On","PowerConsumption":{"PowerInfo":[{"AveragePower":33,"Timestamp":0,"AveragingInterval":60}]}},"planningRequest":{"Timeframe":[]}}]
                      2023-03-11 14:34:57.186 - debug: semp.0 (4472) response xml
                      newDevice0
                      Dryer
                      1234
                      ACME
                      1000
                      Measurement
                      false
                      false
                      false
                      true
                      On
                      33
                      0
                      60
                      2023-03-11 14:34:57.187 - debug: semp.0 (4472) response sent
                      2023-03-11 14:35:00.013 - debug: semp.0 (4472) newDevice0 setLastPower 33 number AlwaysOn W
                      2023-03-11 14:35:00.014 - debug: semp.0 (4472) newDevice0 calc energy 33 1678541685008 = 0.6632633333333334Wh
                        cb187 @Webwanze last edited by
                        Nutzt hier noch keiner die PV Überschussladen Funktion mit automatischer Phasenumschaltung?
                          cb187 @cb187 last edited by
                          Hab jetzt mal zwei Wallbox hinzugefügt, schade er lässt nicht beide gleichzeitig laden und teilt sich das auf.Schaltet nur zwischen beiden Boxen immer um.
                          • Rene_HM
                            Rene_HM Developer @cb187 last edited by
                            @cb187 reicht PV - Leistung nicht für beide?
                              cb187 @Rene_HM last edited by
                              @rene_hm für beide hätte es gereicht wenn es aufgeteilt wäre.Aber ka wie sma das handhabt bzw ist die frage ob das bei den überhaupt geht.
                                @Rene_HM Was ich nicht verstehe beobachte ich gerade wieder wenn zb die WP eingeplant ist und genügend PV Überschusss da ist bricht immer Wallbox nach kurzer Zeit ab.Wenn die nicht existiert dann funzt das top.Ich glaub wir müssen uns mal über anydesk verbinden.Damit du da mal life siehst und besser interpretieren kannst.
                                  Besser machts der Evcc usw auch nicht.
                                    beender last edited by
                                    ich verstehe das Verhalten von dem Plugin oder SMA nicht, oder ich habe etwas komplett falsch konfiguriert.
                                    Aktuell habe ich einen Überschuss von ca. 6000W und die Empfehlung vom Home Manager sind 0 W:
                                    Ich versuche damit meine Wallbox zu steuern. Für eine halbe Stunde hat diese auch geladen, dann wurde diese gestoppt.
                                    Die Wallbox ist recht minimal konfiguriert:
                                    Philipp
                                      cb187 @beender last edited by cb187
                                      @beender hey stell mal min energy und max energy auf 0 ein.Und dann sollte reiner PV Überschuss direkt gehen.
                                      Wenn du ne 11kw Wallbox hast solltest du dann auch bei max power 11020 einstellen.Bildschirm­foto 2023-04-03 um 12.00.18.png Bildschirm­foto 2023-04-03 um 12.00.47.png
                                      beim go musste ich noch drei script hinzufügen.
                                        beender @cb187 last edited by beender
                                        @cb187
                                        Ich habe noch eine Vermutung. Ich lese die Daten per Modbus von meiner ABB Terra AC aus, bekomme aber gefühlt nicht den korrekten State für "Plug Connected" raus. Das ist vermutlich auch der Grund für den Abbruch.
                                        Die 3800 W sind eher auf mein Hybrid-Auto bezogen, da dieses nur 1-phasig laden kann. Ich habe es trotzdem mal auf die 11kW gesetzt.
                                        Ich werde noch probieren den Plug Connected Status konstant auf true zu setzen. Von mir aus kann der SHM die Wallbox dauerhaft überwachen / kontrollieren. Vermutlich geht das meiste eh über die genutzte Charge Power.
                                          Ok probier mal aus.ist ja schnell gemacht plug connect zuerstellen.
                                          @beender said in Adapter: SMA SEMP:
                                          @cb187
                                          • Rene_HM
                                            Rene_HM Developer last edited by
                                            Ich habe die Version 1.2.0 des Adapters released.
                                            Folgende Änderungen sind enthalten:
                                            • man kann eine URL anstatt eines einfachen Datenpunktes für die Konfiguration der Schnittstelle der wallbox verwenden
                                            • bug fix: ein Gerät, welches aufgrund einer Energeianforderung durch den SHM eingeschaltet wird, wird am Ende der maximalen Einschaltdauer oder am Ende des timeframes automatisch ausgeschaltet. Die Optio diesbezüglich wurde entfernt
                                            232
                                            29764
