    3. Entwicklung
    4. [Neuer Adapter] Reolink Kamera
    • skvarel
      skvarel Developer @michihorn last edited by skvarel
      @michihorn sagte in [Neuer Adapter] Reolink Kamera:
      Hallo habe heute im ferienhaus eine E1 Outdoor installiert. Leider klappt es zu Hause nicht mit dem Adapter. Folgendes steht im Log:
      reolink.0
      2023-03-21 22:02:59.100	error	Error: connect EHOSTUNREACH 192.168.xxx.249:443: EHOSTUNREACH
      reolink.0
      2023-03-21 22:02:53.771	silly	States system redis pmessage system.adapter.reolink.0.logLevel/system.adapter.reolink.0.logLevel:{"val":"silly","ack":true,"ts":1679432573639,"q":0,"from":"system.adapter.reolink.0","lc":1679432506968}
      reolink.0
      2023-03-21 22:02:53.631	info	Current IP: 192.168.xxx.249
      reolink.0
      2023-03-21 22:02:53.626	info	Reolink adapter has started
      reolink.0
      2023-03-21 22:02:53.540	info	starting. Version 0.1.1 (non-npm: aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.12.0, js-controller: 4.0.24
      reolink.0
      2023-03-21 22:02:49.183	silly	statesDB connected
      reolink.0
      2023-03-21 22:02:49.181	debug	States connected to redis: 127.0.0.1:9000
      reolink.0
      2023-03-21 22:02:49.006	debug	States create User PubSub Client
      reolink.0
      2023-03-21 22:02:49.005	debug	States create System PubSub Client
      reolink.0
      2023-03-21 22:02:48.940	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      reolink.0
      2023-03-21 22:02:48.937	silly	objectDB connected
      reolink.0
      2023-03-21 22:02:48.931	silly	redis psubscribe cfg.o.enum.*
      reolink.0
      2023-03-21 22:02:48.842	silly	redis psubscribe cfg.o.system.user.*
      reolink.0
      2023-03-21 22:02:48.839	debug	Objects connected to redis: 127.0.0.1:9001
      reolink.0
      2023-03-21 22:02:48.830	debug	Objects client initialize lua scripts
      reolink.0
      2023-03-21 22:02:48.556	debug	Objects create User PubSub Client
      reolink.0
      2023-03-21 22:02:48.554	debug	Objects create System PubSub Client
      reolink.0
      2023-03-21 22:02:48.552	debug	Objects client ready ... initialize now
      reolink.0
      2023-03-21 22:02:48.427	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      Wo bin ich falsch abgebogen?
      Was muss ich bei Kanal eintragen?
      Gruß Michael
      .. alle Ports in der Browseransicht aktiviert?
      Die E1 Outdoor läuft auf jeden Fall mit dem Adapter
      Michael Schumann 1 Reply Last reply Reply Quote 0
      • skvarel
        skvarel Developer @Tobi68 last edited by skvarel
        @tobi68 sagte in [Neuer Adapter] Reolink Kamera:
        @skvarel sagte in [Neuer Adapter] Reolink Kamera:
        Ich bin jetzt zu dem Entschluss gekommen, auf motionEye verzichten zu wollen.
        Ich habe aber jetzt auch das Problem, dass sich das Image Widget nicht aktualisiert. Standbild klappt, mehr aber auch nicht.
        @spanier .. hattest du eine Lösung gefunden? Ich habe genau das selbe Problem.
        EDIT: Jetzt läuft es! Kürzer als 300ms geht halt nicht. Damit kann ich aber leben.
        Wenn man jetzt noch die Bewegungserkennung bzw. den Upload über den Adapter stoppen könnte, wäre es super 🙂
        Sag mal wie und bei welcher cam!
        Ich musste mit einer Cam auch über Motioneye gehen und möchte davon weg.
        Zur Zeit habe ich die E1 Outdoor und die RLC-410W im Reolink Adapter. Weitere Kameras kommen im Laufe des Jahres.
        Mit der IP über einen Browser einloggen und dann in den Network Settings alle Ports aktivieren.
        • skvarel
          @skvarel
          Zeig mal bitte!
          Ich finde eure Widgets wirklich sehr toll, sind aber durch die Universalität recht komplex geworden
          Ich mache es jetzt so.. würde es aber eigentlich besser finden wenn ich direkt wenn ich das Ikon gedrückt habe schon ein feedback bekomme das es auch wirklich geschaltet ist, die Kamera/Adapter haben 1-2 sec. Verzögerung bis sich was bewegt..
          Ich nutze unsere Radio-Buttons. Die Presets werden über die ID angesteuert. 1 = erstes Preset, 2 = zweites Preset usw.
          Feedback können unsrer Widgets aber auch. Einfach hier 500 (oder mehr) eintragen
          • skvarel
            ... Image Widget mit 300ms Aktualisierung
            • skvarel
              skvarel Developer last edited by skvarel
              Die Aufnahmen kann ich jetzt auch per VIS, Script und Sprache steuern 😉
              Ich de- und aktiviere einfach den ftp-User über einer Userliste. Dazu überschreibe ich die User einfach per Ll8inux-Control Adapter.
              Jede Kamera hat einen eigen ftp Zugang. Durch ein Hinzufügen oder Löschen eines Useres in der vsftpd.user_list kann die Kamera entweder speichern oder eben nicht 😉
                hansmeier @skvarel last edited by
                Im Edit VIS Fenster habe sehe ich meine RLC-811A auch noch wunderbar. Jedoch in der View auf Tablett oder Browser sehe ich nur noch ein kleines blinkendes Grafik-Symbol.
                was mache ich falsch mit dem Image - Widget ?
                T skvarel 2 Replies Last reply Reply Quote 0
                  Tobi68 @hansmeier last edited by
                  @hansmeier
                  Das Problem kenne ich, aber auch manchmal umgekehrt!
                  Ist immer sehr mühselig mit den Streams, von Kamera zu Kamera verschieden.
                  Manchmal muss ich auch über den Stream meiner Synology gehen..
                  Motioneye habe ich mal abgeschaltet, darüber gehts auch. Ist aber noch komplexer in der Einrichtung.. hab mir diese 40Watt jetzt mal gespart..
                    hansmeier @Tobi68 last edited by
                    @tobi68 Normalerweise mache ich das auch über MotionEye, jedoch max. der Substream kommt da ohne viel Verzögerung in der VIS an.
                    ich habe gehofft, mit diesem Widget auf den Main-Stream zugreifen zu können.
                      @hansmeier
                      @skvarel
                      Ihr seit wohl etwas fitter mit Cams in der Vis als ich..
                      Jetzt habe ich mir irgenwie was verfummelt was mal ging..
                      Was steuere ich mit dieser updatezeit 500ms?
                      Ich bekomme derzeit zwar in der Vis ein Bild angezeigt wenn ich aber über ein Button den anderen PTZ Punkt anfahre, macht die Kamera das zwar, zeigt es aber nicht in der Vis an, auch nicht nach nach zwei Minuten, nur wenn ich nen Browser refresh mache..
                      • BananaJoe
                        BananaJoe Most Active @Tobi68 last edited by
                        Wie oft du ein neues Bild holst.
                        500ms ist etwas viel, teste mal mit 3 Sekunden / 3.000ms und dann kannst du langsam runter gehen und schauen was er schafft
                          Tobi68 @BananaJoe last edited by
                          @bananajoe
                          das ist ja Problem..
                          da passiert in der VIS nichts.. nur beim Browser refresh..
                          Die Kamera schwenkt das sehe ich in der app..
                          • BananaJoe
                            @tobi68 also, ich hole mir als Hintergrundbild mit folgender URL von meiner RLC-510A ein Bild:
                            http://192.168.1.225/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=test1234
                            rs war meine ich ein zufälliger Wert.
                            Und das aktualisiere ich alle 60.000ms und das funktioniert (sehe ich am Zeitstempel im Bild)
                            • nik82
                              nik82 Most Active @skvarel last edited by
                              Bei mir läufts super mit 500ms.
                              Bei 300ms habe ich zwar auch noch ein Bild, aber dann sieht man das immer mal wieder eine Sekunde übersprungen wird, es werden also Bilder verschluckt, bei mir ist es mit 500ms flüssiger wie mit 300ms und hatte noch keinerlei Bildausfälle.
                              P.S. Habe eine Trackmix und Unifi 6 Pro Accesspoints.
                                @bananajoe
                                Ich verstehe es einfach nicht.. bei mir wird hier gar nichts aktualisiert..
                                Ist eine 823, hängt am Lan, genau die der IOBroker
                                Denke eher wir Reden irgendwie aneinander vorbei:
                                Basic - Image:
                                http://192.168.178.131/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=123456789&user=NAS&password=Pass4NAS
                                nik82 skvarel 2 Replies Last reply Reply Quote 0
                                • nik82
                                  nik82 Most Active @Tobi68 last edited by
                                  @tobi68
                                  Häng hinten mal die breite und höhe an:
                                  http://192.168.1.2/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=952700014VWK6CKG&user=admin&password=xxx&width=1920&height=1080
                                    Tobi68 @nik82 last edited by
                                    @nik82
                                    Habe ich gemacht, ändert aber nichts.
                                    Bild wird nur nach Browser Refresh aktualisiert
                                    nik82 1 Reply Last reply Reply Quote 0
                                    • nik82
                                      @tobi68
                                      Ja dann passts doch, mach doch mal die Update zeit oben auf 1000ms.
                                      So wie du es eingestellt hast wird ja nur alle paar minuten aktualisiert.
                                        Tobi68 @nik82 last edited by Tobi68
                                        @nik82 sagte in [Neuer Adapter] Reolink Kamera:
                                        @tobi68
                                        Nein passt nicht, auch bei 1000ms kommt nichts..
                                        Ich sehe aber gerade das ich bei einer Foscam, die ich über die Synology reinholen musste, es Tip Top funzt.
                                        Dort habe ich ein anders Wiget benutzt..
                                        Das wird halt im editor nicht angezeigt aber nach in der visu schon..🙃
                                        <img src={synology.0.SurveillanceStation.cameras.Foscam.linkMjpegHttpPath} width="100%" height="100%">
                                        wie würde das HTML hier für meine Reo aussehen?
                                        • skvarel
                                          ACHTUNG ...., dieser Haken MUSS raus!
                                          Es wird ein Token an die URL gehängt. Wenn man das mit dem Haken unterbindet gibt es keinen Refresh!
                                          • skvarel
                                            skvarel Developer @hansmeier last edited by
                                            @hansmeier sagte in [Neuer Adapter] Reolink Kamera:
                                            ... die Update-Zeit zu kurz gewählt? Unter 350ms klappt es bei mir nicht!
                                            1.0k
                                            kamera neuer adapter reolink testen
                                            157
                                            1074
                                            448615
