    4. [Problem] Dream btw. Enigma2 Adapter
    • Matten Matten
      Matten Matten last edited by
      hmmm… bei mir hat er das nicht gemacht.
      bei mir startet der Adapter so:
      enigma2.0	2017-09-08 19:44:53.218	info	starting Polling every 3000 ms
      enigma2.0	2017-09-08 19:44:53.214	info	starting. Version 0.0.3 in E:/Programme/ioBroker/node_modules/iobroker.enigma2, node: v4.5.0
      Non	2017-09-08 19:44:53.017	info	npm module. No package.json
      2017-09-08 19:44:52.508	info	instance system.adapter.enigma2.0 started with pid 9588
      2017-09-08 19:44:50.012	info	instance system.adapter.enigma2.0 terminated with code null ()
      2017-09-08 19:44:50.011	warn	instance system.adapter.enigma2.0 terminated due to SIGTERM
      2017-09-08 19:44:49.997	info	stopInstance system.adapter.enigma2.0 killing pid 2476
      • kmxak
        beim deinstallieren:
        host.ioBroker	2017-09-08 19:46:55.688	error	Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/enigma2.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node
        host.ioBroker	2017-09-08 19:46:55.687	error	Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/enigma2/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modul
        iobroker	2017-09-08 19:46:55.254	info	exit 22
        host.ioBroker	2017-09-08 19:46:55.049	info	object deleted system.adapter.enigma2.0
        host.ioBroker	2017-09-08 19:46:55.049	info	object change system.adapter.enigma2.0
        neuer fehler:
        host.ioBroker	2017-09-08 19:47:35.278	info	Restart adapter system.adapter.enigma2.0 because enabled
        host.ioBroker	2017-09-08 19:47:35.277	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
        enigma2.0	2017-09-08 19:47:34.799	error	TypeError: Cannot read property '0' of undefined at evaluateCommandResponse (/opt/iobroker/node_modules/iobroker.enigma2/enigma2.js:240:87) at /opt/iobroker/node_modules/iobroker.enigma2/enigm
        enigma2.0	2017-09-08 19:47:34.799	error	uncaught exception: Cannot read property '0' of undefined
        enigma2.0	2017-09-08 19:47:31.600	info	starting Polling every 3000 ms
        enigma2.0	2017-09-08 19:47:31.593	info	starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v6.11.3
        Non	2017-09-08 19:47:31.344	info	npm module. No package.json
        • Matten Matten
          kann das an den unterschiedlichen Versionen von Node liegen?
          ich hab node: v4.5.0 und node: v6.11.2
          • Matten Matten
            ich hab es jetzt auch nochmal auf meinem RPI3 geladen und gestartet. ohne probleme…..
            enigma2.0	2017-09-08 18:06:00.136	info	starting Polling every 3000 ms
            enigma2.0	2017-09-08 18:06:00.110	info	starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.enigma2, node: v6.11.2
            Non	2017-09-08 18:05:58.869	info	npm module. No package.json
            host.raspberrypi	2017-09-08 18:05:57.037	info	instance system.adapter.enigma2.0 started with pid 19724
            host.raspberrypi	2017-09-08 18:05:55.094	info	instance system.adapter.enigma2.0 terminated with code 0 (OK)
            enigma2.0	2017-09-08 18:05:55.030	info	terminating
            host.raspberrypi	2017-09-08 18:05:54.516	info	stopInstance system.adapter.enigma2.0 killing pid 19712
            host.raspberrypi	2017-09-08 18:05:54.515	info	stopInstance system.adapter.enigma2.0
            Ich habe das sogar mit dream-webIf und mit openweb If getestet.
            da muss ich noch mal genauer schauen.
            • Matten Matten
              @kmxak:
              so ganz rund läuft es noch nicht. bekomme folgende fehler:
              <code>host.ioBroker	2017-09-08 15:19:28.716	info	Restart adapter system.adapter.enigma2.0 because enabled
              host.ioBroker	2017-09-08 15:19:28.715	error	instance system.adapter.enigma2.0 terminated with code 0 (OK)
              enigma2.0	2017-09-08 15:19:28.515	debug	using no authorization
              enigma2.0	2017-09-08 15:19:28.515	debug	creating request for command 'GETCURRENT' (deviceId: 1, host: 192.168.2.55, port: 80, path: '/web/getcurrent')
              enigma2.0	2017-09-08 15:19:28.515	debug	creating request for command 'GETVOLUME' (deviceId: 1, host: 192.168.2.55, port: 80, path: '/web/vol')
              bekommst du die Fehler auch wenn du den vuplus Adapter von "vader722" installierst und startest?</code>
              • kmxak
                Den hatte ich gar nicht installiert bekommen
                Gesendet von meinem SM-G930F mit Tapatalk
                • rantanplan
                  rantanplan last edited by
                  @kmxak:
                  so ganz rund läuft es noch nicht. bekomme folgende fehler: `
                  Hallo kmxak
                  Bitte den Code-Tag zusätzlich in einen Spoiler-Tag packen.
                  • Dutchman
                    @Matten Matten:
                    ok hab noch was geändert -> https://www.dropbox.com/s/ybu1j2h7490s1 … 2.rar?dl=0
                    Hast du den adapter inzwischen auch auf git gestellt das macht installieren nach aenderungen doch um so einiges leichter 🙂
                    blicke jetzt nicht ganz durch ob ich dein dropbox pakket nehmen sollte oder den gitlink von vader722 : https://github.com/vader722/ioBroker.vu … its/master
                    ~Dutch
                    • Matten Matten
                      https://github.com/Matten-Matten/iobroker.enigma2
                      • N
                        NightWatcher last edited by
                        Was genau hast du vor? Das, was du dort absetzt, ist eine Nachricht an die VU+.
                        Aber kein Befehl.
                        Möchtest du per Klick auf den Homematic Button den Sender wechseln?
                        • Matten Matten
                          @Matten Matten:
                          hab noch nie was auf github hochgeladen (kein Plan wie) :roll: :?:
                          deshalb den Dropbox Link bitte.
                          https://www.dropbox.com/s/ybu1j2h7490s1 … 2.rar?dl=0 `
                          UPDATE auf Version 0.0.4!!!
                          hab noch ein paar sachen hinzugefügt und die Konfigurationsmaske optimiert.
                          https://www.dropbox.com/s/oklkr9tiem7xh … 2.rar?dl=0
                          • kmxak
                            GIT wäre aber trotzdem am besten aus der DropBox ist das sehr umständlich.
                            Schau mal hier: https://www.youtube.com/playlist?list=P … _0Uy0YLdHW
                            GitHub ist kein Hexenwerk
                            • Matten Matten
                              @kmxak:
                              GitHub ist kein Hexenwerk `
                              ok, danke für den link 🙂 das werde ich mir heute Nacht mal reinziehen vielleicht hab ich's ja bis morgen früh auf github.
                              mit freundlichen Grüßen
                              Matze
                              • Matten Matten
                                  Guten Morgen 😉
                                  @Matten Matten:
                                  vielleicht hab ich's ja bis morgen früh auf github. `
                                  Super Arbeit!
                                  Rainer
                                    gst666 last edited by
                                    Konnte den Adapter leider nicht installieren:
                                    $ ./iobroker url "https://github.com/Matten-Matten/iobroker.enigma2"
                                    install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master
                                    npm install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master --production --prefix "/opt/iobroker" (System call)
                                    npm
                                     WARN excluding symbolic link node_modules/request/node_modules/.bin/har-validator -> ../har-validator/bin/har-validatornpm WARN excluding symbolic link node_modules/request/node_modules/.bin/uuid -> ../node-uuid/bin/uuid
                                    npm ERR! Linux 4.4.0-89-genericnpm ERR! argv "/root/.nvm/versions/node/v6.11.0/bin/node" "/root/.nvm/versions/node/v6.11.0/bin/npm" "install" "https://github.com/Matten-Matten/iobroker.enigma2/tarball/master" "--production" "--prefix" "/opt/iobroker"
                                    npm ERR! node v6.11.0
                                    npm ERR! npm  v3.10.10
                                    npm ERR! path /tmp/npm-13415-92695ca7/unpack-1811fc56/package.json
                                    npm ERR! code ENOENT
                                    npm ERR! errno -2
                                    npm ERR! syscall open
                                    npm ERR! enoent ENOENT: no such file or directory, open '/tmp/npm-13415-92695ca7/unpack-1811fc56/package.json'
                                    npm ERR! enoent This is most likely not a problem with npm itself
                                    npm ERR! enoent and is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR! Please include the following file with any support request:npm
                                    ERR!     /opt/npm-debug.log
                                    ERROR: host.automation Cannot install https://github.com/Matten-Matten/iobroker.enigma2/tarball/master: 254
                                    ERROR: process exited with code 25
                                    • Matten Matten
                                      @gst666:
                                      npm
                                      npm ERR! errno -2
                                      npm ERR! enoent
                                      so hab ich es auch nicht installiert bekommen. deshalb hab ich den ganzen Ordner immer in ioBroker\node_modules eingefügt.
                                      ich hab auch nicht die Programmier Kenntnisse um so ein Fehler zu beheben. sry 😞
                                      • N
                                        Es wäre vorteilhafter, wenn du den original Adapter geforked hättest und per push request der eigentliche Entwickler deine Änderungen in den richtigen Adapter einfügt.
                                        Dein Adapter basiert nämlich auf einer alten Version des originals.
                                        • Matten Matten
                                          @NightWatcher:
                                          Dein Adapter basiert nämlich auf einer alten Version des originals. `
                                          Wie gesagt ich bin eigentlich nur Anwender. Hab lediglich für mich ein paar Veränderungen hinzugefügt und wollte es hier teilen. Hab den Adapter nur für mich in Enigma2 umbenannt, da er ja mit alle Boxen (webif oder openwebif ) funktioniert. Ich hab gesehen, dass du bereits Veränderungen am vuplus Adapter vorgenommen hast, sonst nimm doch alles nützliche aus meinen Veränderungen und füge die dem vuplus Adapter hinzu.
                                          (Hatte den vuplus Adapter nach deinen Veränderungen nochmals versucht übers iobroker.admin webif zu installieren aber ohne erfolg. auch wenn ich den manuell in den Ordner schiebe und hochlade, kann ich zwar den Adapter einrichten und starten, jedoch steigt er gleich mit Fehlermeldung aus und stoppt.)
                                          • N
                                            Okay, dass mein Adapter nen Fehler bringt, ist mir bisher nicht bekannt.
                                            Bei mir läuft er super. Was für ein Fehler kommt denn im Log? Vorher braucht man ja auch noch nicht drüber nachdenken, die beiden Adapter zusammenzulegen, sonst holt man den Fehler ggf. noch mit.
                                            739
                                            189624
