    4. Alexa2 wird nicht grün
      Micha487 @Thomas Braun last edited by
      hab die Gruppe 'root' bei dem User 'michael' entfernt entfernt.
      Den Alexa2-Adapter habe ich gelöscht und neu angelegt, hier die Ausgabe im Log:
      alexa2.0
      2023-03-23 16:48:36.322	error	Error: You can try to get the cookie manually by opening http://192.168.178.195:46821/ with your browser.
      alexa2.0
      alexa2.0
      2023-03-23 16:48:36.322	debug	Error from Alexa init: You can try to get the cookie manually by opening http://192.168.178.195:46821/ with your browser.
      alexa2.0
      2023-03-23 16:48:36.321	debug	Alexa-Remote: Error from retrieving cookies
      alexa2.0
      2023-03-23 16:48:36.321	debug	Alexa-Cookie: Proxy-Server listening on port 46821
      alexa2.0
      2023-03-23 16:48:36.307	debug	Alexa-Cookie: Proxy-Mode enabled if needed: 192.168.178.195:0 to listen on 0.0.0.0
      alexa2.0
      2023-03-23 16:48:36.307	debug	Alexa-Cookie: Use as Accept-Language: de-DE
      alexa2.0
      2023-03-23 16:48:36.307	debug	Alexa-Cookie: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36
      alexa2.0
      2023-03-23 16:48:36.307	debug	Alexa-Cookie: Use as Device-App-Name: ioBroker Alexa2
      alexa2.0
      2023-03-23 16:48:36.306	debug	Alexa-Cookie: Use as Base-Amazon-URL: amazon.com
      alexa2.0
      2023-03-23 16:48:36.306	debug	Alexa-Cookie: Use as Login-Amazon-URL: amazon.de
      alexa2.0
      2023-03-23 16:48:36.163	debug	Alexa-Remote: No cookie given, generate one
      alexa2.0
      2023-03-23 16:48:36.162	debug	Alexa-Remote: Use as Base-URL: alexa.amazon.de
      alexa2.0
      2023-03-23 16:48:36.162	debug	Alexa-Remote: Use as Login-Amazon-URL: amazon.de
      alexa2.0
      2023-03-23 16:48:36.162	debug	Alexa-Remote: Use as API User-Agent Postfix: ioBroAlexa2/3.23.2
      alexa2.0
      2023-03-23 16:48:36.161	debug	Alexa-Remote: Use as User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36
      alexa2.0
      2023-03-23 16:48:36.161	debug	Update Devices Configuration Interval: 3604s
      alexa2.0
      2023-03-23 16:48:36.160	debug	Update Device State Interval: 309s
      alexa2.0
      2023-03-23 16:48:36.160	debug	Update History Interval: 300s
      alexa2.0
      2023-03-23 16:48:36.159	info	Proxy IP not set, use first network interface (192.168.178.195) instead
      alexa2.0
      2023-03-23 16:48:36.157	info	Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      alexa2.0
      2023-03-23 16:48:36.114	info	starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.15.0, js-controller: 4.0.24
      alexa2.0
      2023-03-23 16:48:35.909	debug	Plugin sentry Initialize Plugin (enabled=true)
      alexa2.0
      2023-03-23 16:48:35.885	debug	States connected to redis: 127.0.0.1:9000
      alexa2.0
      2023-03-23 16:48:35.839	debug	States create User PubSub Client
      alexa2.0
      2023-03-23 16:48:35.838	debug	States create System PubSub Client
      alexa2.0
      2023-03-23 16:48:35.833	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      alexa2.0
      2023-03-23 16:48:35.821	debug	Objects connected to redis: 127.0.0.1:9001
      alexa2.0
      2023-03-23 16:48:35.817	debug	Objects client initialize lua scripts
      alexa2.0
      2023-03-23 16:48:35.806	debug	Objects create User PubSub Client
      alexa2.0
      2023-03-23 16:48:35.804	debug	Objects create System PubSub Client
      alexa2.0
      2023-03-23 16:48:35.797	debug	Objects client ready ... initialize now
      alexa2.0
      2023-03-23 16:48:35.765	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      alexa2.0
      2023-03-23 16:48:08.517	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      alexa2.0
      2023-03-23 16:48:07.514	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
      alexa2.0
      2023-03-23 16:48:07.510	info	Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      alexa2.0
      2023-03-23 16:48:07.461	info	starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.15.0, js-controller: 4.0.24
      alexa2.0
      2023-03-23 16:48:04.599	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      alexa2.0
      2023-03-23 16:48:04.596	error	Error: Unexpected end of JSON input
      alexa2.0
      2023-03-23 16:47:47.687	error	Error: You can try to get the cookie manually by opening http://192.168.178.195:42089/ with your browser.
      alexa2.0
      alexa2.0
      2023-03-23 16:47:47.526	info	Proxy IP not set, use first network interface (192.168.178.195) instead
      alexa2.0
      2023-03-23 16:47:47.524	info	Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      alexa2.0
      2023-03-23 16:47:47.478	info	starting. Version 3.23.2 in /opt/iobroker/node_modules/iobroker.alexa2, node: v18.15.0, js-controller: 4.0.24
      • DJMarc75
        DJMarc75 @Micha487 last edited by
        @micha487 sagte in Alexa2 wird nicht grün:
        Debian läuft auf meiner NAS, habe dort Debian installiert und dann OMV drauf gepackt. Deutlich später habe ich dann iobroker mit Grafana drauf gezogen
        Grafana hat da mal jetzt nix im Beitrag zu suchen... aber das ganze Zeuch VOR dem Grafana ist nicht grad uninteressant... NAS... welches System ?
          apollon77 last edited by
          Jetzt lasst mal das arme Netzwerk-Interace in ruhe :-)) Das ist das egal.
          Was ist denn das für ein Amazon Account? Ein Deutscher? Oder was anderes? Irgendwie komischer Familienaccount oder sonstwas?
          Diesen Fehler das am Ende der Cookie Nummer ein 401 mit nem Fehler wie hier kommt hatten auch schon ne handvoll andrer User. So richtig rausfinden konnten wir die Ursache nie. Meistens waren es komische Acccounts oder Länderkram oder Ip/DNS Blocker oder es ging plötzlich ein paar Tage später wieder ...
          Thomas Braun M 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @apollon77 last edited by
            @apollon77
            Was ist denn
            für ein Fehler? Korruptes JSON?
              apollon77 @Thomas Braun last edited by
              @thomas-braun In dem Falle von 401 als Fehler kommt scheinbar eine HTML seite zurück und der Adapter versucht das JSON zu parsen ... Die Frage warum diese 401 kommt ist die Magische
                Micha487 @apollon77 last edited by
                @apollon77 ist eigentlich kein Familienaccount sondern mein eigener. Auch wenn ich damit quasi an jedem PC, Fernseher, mehreren Alexas, Fire-TV-Sticks etc. angemeldet bin. Sollte hier aber wohl keine Rolle spielen?
                Es handelt sich dabei um einen deutschen Account.
                @DJMarc75 Ist ein Eigenbau-NAS. Ist ein ASRock J4105-ITX SoC So.BGA Dual Channel DDR Mini-ITX Retail mit nem Inter-Tech Mini-ITX PSU 120W als Netzteil mit nem M.2 SSD fürs Betriebssystem in einem Thermaltake Core V1 Cube Case schwarz Mini ITX
                DJMarc75 apollon77 2 Replies Last reply Reply Quote 0
                • DJMarc75
                  aha
                    apollon77 @Micha487 last edited by
                    @micha487 Hm... wenn sonst nichts im "Wege" ist wie Pihole oder andere DNS dinge dann muss ich sagen bin ich im Moment ratlos. Ich könnte nur anbieten das Du mir Zugangsdaten gibts (also ändere dein passwort vorher bzw nachher) und ich es so mal selbst versuchen kann und schauen kann was bei mir passiert. Wenn das eine option ist schreb mir bitte eine E-Mail an iobroker@fischer-ka.de mit referenz hierher damit wir dann einen zeitpunkt abstimmen können (also ändere mal jetzt noch keine Passwörter, ich muss nen Zeit slot finden wo ich reinschauen kann).
                      @apollon77 danke für das Angebot, ich probiere einfach mal bissle weiter rum, ob ich dahinter komme. Sollte ich auf dein Angebot zurück kommen wollen, melde ich mich per Mail bei dir, wie angeboten 🙂
                      • DJMarc75
                        DJMarc75 @Micha487 last edited by DJMarc75
                        Wenn man einem Hilfsangebot des Adapterentwicklers quasi in die Fresse schlägt - selten erlebt, aber ok 😁
                        Ich entschuldige mich für diese Aussage nachdrücklich !
                        apollon77 1 Reply Last reply Reply Quote -1
                          apollon77 @DJMarc75 last edited by
                          @djmarc75 Ne ehrlich, das ist schon ok ... Zugang zum Amazon Account weiterzugeben ist schon so eine Sache. Und es ist vollkommen ok wenn jemand das nicht annimmt
                          DJMarc75 wcag22 2 Replies Last reply Reply Quote 2
                          • DJMarc75
                            DJMarc75 @apollon77 last edited by
                            @apollon77 ja schon, aber dann wird halt nur suboptimal geholfen - weil nicht anders möglich... da fällt mir grad ein: schon von den geplanten neuen AmazonTV gelesen ? 😀 (am Rande gefragt und - schwupps - gern ausgelagert 🙂 )
                            • wcag22
                              wcag22 @apollon77 last edited by
                              @apollon77 sagte in Alexa2 wird nicht grün:
                              Ausserdem lernt man durch selber machen mehr, als durch nachmachen. Aber das ist ja Konsens hier im Forum,
                              • DJMarc75
                                DJMarc75 @wcag22 last edited by
                                @pi-ter sagte in Alexa2 wird nicht grün:
                                Und durch Downvotes zeigt man auch wie man so tickt - danke dafür.... gemerkt !
                                haselchen wcag22 2 Replies Last reply Reply Quote 0
                                • haselchen
                                  haselchen Most Active @DJMarc75 last edited by
                                  @djmarc75 sagte in Alexa2 wird nicht grün:
                                  Wer im Glashaus sitzt…..
                                  • wcag22
                                    wcag22 @DJMarc75 last edited by
                                    @djmarc75
                                    Ich weiß nicht welches Problem Du gerade hattest, aber Dir auch ein schönes Wochenende.
                                    Ich fand nur Deine Bemerkung in die Fresse schlägt unpassend und unnötig.
                                    • DJMarc75
                                      DJMarc75 @wcag22 last edited by DJMarc75
                                      @pi-ter jo, war vll überzogen...und ich hab den betroffenen Beitrag auch bearbeitet !
                                      • maximal1981
                                        maximal1981 last edited by
                                        meine Alexas haben heute auch die Kommunikation eingestellt.
                                        ich habe den Adapter auch schon neu installiert, komme aber immer wieder zu dieser URL nach dem ich mich authentifiziert und den PIN den ich via SMS eingebe: IP-iobroker:41033/www.amazon.com/404
                                        mit https://www.gehrig.info/alexa/Alexa.html komm ich auch nicht weiter.
                                        AdGuard umgehe ich bereits, somit kann hier nicht das Problem zu Grunde liegen.
                                        Jemand eine Idee?
                                        haselchen apollon77 2 Replies Last reply Reply Quote 0
                                        • haselchen
                                          haselchen Most Active @maximal1981 last edited by
                                          @maximal1981
                                          Debug Log beim Adapterstart?
                                            apollon77 @maximal1981 last edited by
                                            @maximal1981 Siehe Readme ... OTP/2FA Verfahren auf das aktuelle aktualisieren. 4040 kommt bei einem alten Verfahren.
                                            maximal1981 1 Reply Last reply Reply Quote 0
                                            2296
