    4. Test Adapter vis 2.0 (Alpha)
    • Feuersturm
      Feuersturm last edited by
      Vis2 Version 2.0.22 steht auf npm zur Verfügung.
      • mmoeller53
        mmoeller53 @Feuersturm last edited by
        @feuersturm sehen tue ich es, beim öffnen ist die seite halt nur weiß, anbei die vis in anonymisierte export form, kann eigentlich auch die andere version hochladen
        iobroker.vis-2-beta@2.0.21 using theme "colored"
        main.8aaf24be.js:657
        main.8aaf24be.js:657 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
        main.8aaf24be.js:657 Help us to create open source project with reactJS!
        main.8aaf24be.js:657 See you :)
        Runtime.jsx:261 Rename widget w000003 to w000044
        Runtime.jsx:261 Rename widget w000004 to w000045
        Runtime.jsx:261 Rename widget w000009 to w000046
        Runtime.jsx:261 Rename widget w000010 to w000047
        Runtime.jsx:261 Rename widget w000012 to w000048
        Runtime.jsx:261 Rename widget w000013 to w000049
        Runtime.jsx:261 Rename widget w000014 to w000050
        Runtime.jsx:261 Rename widget w000015 to w000051
        Runtime.jsx:261 Rename widget g000001 to g000010
        Runtime.jsx:261 Rename widget w000016 to w000052
        Runtime.jsx:261 Rename widget w000017 to w000053
        Runtime.jsx:261 Rename widget w000018 to w000054
        Runtime.jsx:261 Rename widget g000002 to g000011
        Runtime.jsx:261 Rename widget w000019 to w000055
        Runtime.jsx:261 Rename widget w000020 to w000056
        Runtime.jsx:261 Rename widget w000021 to w000057
        Runtime.jsx:261 Rename widget g000003 to g000012
        Runtime.jsx:261 Rename widget w000022 to w000058
        Runtime.jsx:261 Rename widget w000023 to w000059
        Runtime.jsx:261 Rename widget w000024 to w000060
        Runtime.jsx:261 Rename widget g000004 to g000013
        Runtime.jsx:261 Rename widget w000025 to w000061
        Runtime.jsx:261 Rename widget w000026 to w000062
        Runtime.jsx:261 Rename widget g000005 to g000014
        Runtime.jsx:261 Rename widget w000027 to w000063
        Runtime.jsx:261 Rename widget w000028 to w000064
        Runtime.jsx:261 Rename widget w000029 to w000065
        Runtime.jsx:261 Rename widget w000030 to w000066
        Runtime.jsx:261 Rename widget g000006 to g000015
        Runtime.jsx:261 Rename widget w000031 to w000067
        Runtime.jsx:261 Rename widget w000032 to w000068
        Runtime.jsx:261 Rename widget w000033 to w000069
        Runtime.jsx:261 Rename widget g000007 to g000016
        Runtime.jsx:261 Rename widget w000034 to w000070
        Runtime.jsx:261 Rename widget w000035 to w000071
        Runtime.jsx:261 Rename widget w000036 to w000072
        Runtime.jsx:261 Rename widget g000008 to g000017
        Runtime.jsx:261 Rename widget w000037 to w000073
        Runtime.jsx:261 Rename widget w000038 to w000074
        Runtime.jsx:261 Rename widget w000039 to w000075
        Runtime.jsx:261 Rename widget w000040 to w000076
        Runtime.jsx:261 Rename widget g000009 to g000018
        Runtime.jsx:261 Rename widget w000041 to w000077
        Runtime.jsx:261 Rename widget w000042 to w000078
        Runtime.jsx:261 Rename widget w000043 to w000079
        VM222:4 Uncaught TypeError: Cannot read properties of undefined (reading 'localization')
            at <anonymous>:4:39
            at Ve.<anonymous> (visEngine.jsx:1215:42)
            at Generator.next (<anonymous>)
            at 360.f837ec6e.chunk.js:29:17460
            at new Promise (<anonymous>)
            at Ei (360.f837ec6e.chunk.js:29:17280)
            at Ve.setInnerHTML (visEngine.jsx:1177:42)
            at Ve.<anonymous> (visEngine.jsx:1247:29)
            at r (360.f837ec6e.chunk.js:29:17318)
        VM224:110 Version vis-jqui-mfd: 1.0.12
        VM226:645 Metro version: "1.2.0"
        VM230:1269 Version vis-weather: 2.5.6
        kodi.js:48 Version kodi: 2.0.0
        lib.min.js:44 Download the Vue Devtools extension for a better development experience:
        https://github.com/vuejs/vue-devtools
        lib.min.js:44 You are running Vue in development mode.
        Make sure to turn on production mode when deploying for production.
        See more tips at https://vuejs.org/guide/deployment.html
        materialdesign.js:33 Version vis-materialdesign: 0.5.94
        widgets.min.js:1 vis-materialdesign: vibration supported by device: 'true'
        widgets.min.js:1 vis-materialdesign: click audio file '/vis.0/materialdesign-widgets-click-sound.mp3' not exists!
        (anonymous) @ widgets.min.js:1
        instrument.ts:129 sentry initialized for vis-materialdesign
        :8082/vis-2-beta/widgets/vis-2-widgets-energy/static/js/node_modules_iobroker_vis-2-widgets-react-dev_index_jsx-_adb40.0d7063a4.chunk.js:1          Failed to load resource: the server responded with a status of 404 (Not Found)
        instrument.ts:129 Cannot load widget system.adapter.vis-2-widgets-energy.0:  ChunkLoadError: Loading chunk node_modules_iobroker_vis-2-widgets-react-dev_index_jsx-_adb40 failed.
        (error: http://192.168.178.55:8082/vis-2-beta/widgets/vis-2-widgets-energy/static/js/node_modules_iobroker_vis-2-widgets-react-dev_index_jsx-_adb40.0d7063a4.chunk.js)
            at e.f.j (jsonp chunk loading:27:18)
            at ensure chunk:6:28
            at Array.reduce (<anonymous>)
            at e.e (ensure chunk:5:56)
            at Object.get (sharing:39:420)
            at y (consumes:77:15)
            at j (consumes:45:9)
            at consumes:122:9
            at consumes:82:9
            at 88411 (consumes:144:29)
            at consumes:199:44
            at Array.forEach (<anonymous>)
            at e.f.consumes (consumes:182:25)
            at ./ConsumptionComparison (container-entry:3:398)
            at Object.v (container-entry:22:22)
            at visUtils.jsx:777:36
            at async Promise.all (:8082/vis-2-beta/index 1)
        (anonymous) @ instrument.ts:129
        instrument.ts:129 Cannot load widget system.adapter.vis-2-widgets-energy.0:  TypeError: Class extends value undefined is not a constructor or null
            at 44411 (IntervalSelector.jsx:26:32)
            at e (bootstrap:19:32)
            at container-entry:9:682
            at visUtils.jsx:778:26
            at async Promise.all (:8082/vis-2-beta/index 3)
            at 33136 (Consumption.jsx:24:27)
            at container-entry:6:769
            at async Promise.all (:8082/vis-2-beta/index 2)
            at 85165 (Distribution.jsx:36:28)
            at container-entry:12:628
            at async Promise.all (:8082/vis-2-beta/index 4)
        instrument.ts:129 Cannot load widget system.adapter.vis-2-widgets-material.0:  ChunkLoadError: Loading chunk node_modules_iobroker_vis-2-widgets-react-dev_index_jsx-_adb40 failed.
            at consumes:122:9
            at consumes:82:9
            at consumes:199:44
        instrument.ts:129 Cannot load widget system.adapter.vis-2-widgets-material.0:  TypeError: Class extends value undefined is not a constructor or null
            at 14390 (Actual.jsx:110:22)
            at container-entry:6:1031
            at async Promise.all (:8082/vis-2-beta/index 7)
            at 56255 (Static.jsx:47:22)
            at container-entry:9:944
            at async Promise.all (:8082/vis-2-beta/index 8)
            at 61824 (Switches.jsx:81:24)
            at container-entry:12:757
            at async Promise.all (:8082/vis-2-beta/index 9)
            at 76362 (Blinds.jsx:108:22)
            at container-entry:18:835
            at async Promise.all (:8082/vis-2-beta/index 10)
            at 87969 (Clock.jsx:60:21)
            at container-entry:21:548
            at async Promise.all (:8082/vis-2-beta/index 11)
            at 89178 (SimpleState.jsx:137:27)
            at container-entry:15:847
            at async Promise.all (:8082/vis-2-beta/index 12)
            at 85076 (ViewInWidget.jsx:18:28)
            at container-entry:24:555
            at async Promise.all (:8082/vis-2-beta/index 13)
            at 55207 (Camera.jsx:48:22)
            at container-entry:27:709
            at async Promise.all (:8082/vis-2-beta/index 14)
            at 35445 (Security.jsx:29:24)
            at container-entry:30:757
            at async Promise.all (:8082/vis-2-beta/index 15)
            at 21107 (Player.jsx:99:22)
            at container-entry:33:752
            at async Promise.all (:8082/vis-2-beta/index 16)
            at 19050 (Map.jsx:146:19)
            at container-entry:36:936
            at async Promise.all (:8082/vis-2-beta/index 17)
            at 47996 (Html.jsx:6:20)
            at container-entry:39:467
            at async Promise.all (:8082/vis-2-beta/index 18)
        instrument.ts:129 Common user CSS not found: Not exists
        Prev_SliderTabs.png:1          Failed to load resource: the server responded with a status of 404 (Not Found)
        instrument.ts:129 [2023-03-21T16:23:39.185Z] +SUBSCRIBE: sonoff.0.Licht PC_ACCDA0.POWER1
        instrument.ts:129 Version vis-timeandweather: 1.2.1
        instrument.ts:129 [2023-03-21T16:23:39.207Z] +SUBSCRIBE: sourceanalytix.0.sonoff__0__Steckdose-pv-laden__ENERGY_Power.currentYear.costs.05_currentYear
        instrument.ts:129 [2023-03-21T16:23:39.209Z] +SUBSCRIBE: sourceanalytix.0.sonoff__0__Steckdose-pv-laden__ENERGY_Power.currentYear.consumed.05_currentYear
        9instrument.ts:129 TypeError: Cannot read properties of undefined (reading 'style')
            at BasicGroup.jsx:71:45
            at Array.sort (<anonymous>)
            at zt.renderWidgetBody (BasicGroup.jsx:68:26)
            at zt.render (visBaseWidget.jsx:1448:31)
            at zt.render (visRxWidget.jsx:472:22)
            at $t (main.8aaf24be.js:1907:6419)
            at Lt (main.8aaf24be.js:1907:6206)
            at ca (main.8aaf24be.js:1907:46375)
            at Ga (main.8aaf24be.js:1907:41086)
            at ko (main.8aaf24be.js:1907:41014)
            at Ka (main.8aaf24be.js:1907:40866)
            at S3 (main.8aaf24be.js:1907:37107)
            at U8 (main.8aaf24be.js:1907:37921)
            at y0 (main.8aaf24be.js:1905:3299)
            at Io (main.8aaf24be.js:1907:42609)
            at lr (main.8aaf24be.js:1907:41575)
            at Fo (main.8aaf24be.js:1907:36907)
            at M (main.8aaf24be.js:1941:1548)
            at MessagePort.w (main.8aaf24be.js:1941:1907)
        main.8aaf24be.js:1905 Uncaught TypeError: Cannot read properties of undefined (reading 'style')
        instrument.ts:129 [waitForWidgets] stop waiting for vis widgets after 500 retries
        DevTools failed to load source map: Could not load content for http://192.168.178.55:8082/vis-2-beta/static/js/993.6e483261.chunk.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        DevTools failed to load source map: Could not load content for http://192.168.178.55:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        DevTools failed to load source map: Could not load content for http://192.168.178.55:8082/vis-2-beta/static/js/main.8aaf24be.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
        2023-03-21-neue vis.zip
        • Feuersturm
          Feuersturm @mmoeller53 last edited by
          @mmoeller53 Ich kann dein Problem bei mir nachstellen, nachdem ich dein Projekt importiert habe.
          Erstelle bitte mal bitte hier https://github.com/ioBroker/ioBroker.vis/issues ein issue inkl. der Beschreibung was du vorher gemacht hast.
          Bluefox kann es sich dann ansehen.
          • Feuersturm
            Feuersturm last edited by Feuersturm
            Ich hab gerade mal die neue Version vis 2.0.22 installiert. Im Editor werden mir meine Projekte weiterhin angezeigt, aber sobald ich die Runtime starte bleibt der Bildschirm weiß. Ist das bei euch auch so?
            Edit: Github issue: https://github.com/ioBroker/ioBroker.vis/issues/677
            Feuer-sturm created this issue in ioBroker/ioBroker.vis
            closed VIS runtime shows only a white screen with vis2-2.0.22 #677
            G Gargano 2 Replies Last reply Reply Quote 0
              goesebrecht @Feuersturm last edited by
              @feuersturm
              Nö, bei mir funktioniert es wie immer. Allerdings habe ich auch keine separaten widgets-Pakete installiert.
              Mein Problem mit der Ausführung der in html eingebundenen Skripte besteht allerdings nach wie vor.
              • Gargano
                Gargano @Feuersturm last edited by Gargano
                @feuersturm Ist bei mir auch so, selbst bei einem neuen Projekt. Die Console spuckt tausend Fehler aus.
                Ist das eigentlich die richtige URL-Schreibweise ?
                http://meine-ip:8082/vis-2-beta/?Panel#Start1
                Bei der VIS1 war da immer ein index.html dazwischen
                  blade-of-fire last edited by
                  Ich habe heute auf die neueste Version (2.0.23) aktualisiert. Leider lässt sich die VIS 2 jetzt nicht mehr starten.
                  Es liegt wohl an der Lizenz, da in den Einstellungen bei "Lizenz prüfen" folgende Meldung kommt.
                  Ich kann in der iobroker Cloud keine weitere VIS Lizenz hinzufügen (zumindest keine kostenfreie), aber die ganze Zeit hatte es ja auch so funktioniert. Hat noch jemand dieses Problem?
                    JamesB last edited by
                    Beim Versuch mein Projekt umzustellen erhalte ich bei den Material Design Line History Chart Widgeds folgenden Fehler:
                    [getTaskForHistoryData - w000813] error: vis.getHistory is not a function, stack: getTaskForHistoryData/<@http://x.x.x.x.:8082/vis-2-beta/widgets/materialdesign/js/widgets.min.js:5:16060
                    getTaskForHistoryData@http://x.x.x.x:8082/vis-2-beta/widgets/materialdesign/js/widgets.min.js:5:15416
                    e@http://x.x.x.x:8082/vis-2-beta/widgets/materialdesign/js/widgets.min.js:6:9558
                    vis.binds.materialdesign.chart.lineHistory/</l/<@http://x.x.x.x.:8082/vis-2-beta/widgets/materialdesign/js/widgets.min.js:6:11326
                    sentryWrapped@http://x.x.x.x:8082/vis-2-beta/widgets/materialdesign/lib/raw/sentry/bundle.min.js:2:53837
                    Ich verwdne vis-materialdesign Version 0.5.94
                    Wenn ich ein Line History Chart neu erstelle, ist das Verhalten "Adapterinstanz" und "Objekt ID" auch sehr speziell. Der Objekt Browser zeigt nur wenige Objekte an.
                      sigi234 Forum Testing Most Active @sigi234 last edited by
                      @sigi234
                      Hallo, Version 2.0.23 keine Reaktion:
                      • Feuersturm
                        Feuersturm @JamesB last edited by
                        @jamesb sagte in Test Adapter vis 2.0 (Alpha):
                        Das widget funktioniert bei mir auch nicht. Leg bitte hier https://github.com/ioBroker/ioBroker.vis/issues ein entsprechendes issue mit allen Informtionen / Fehlverhalten an, welche du siehst. Danke.
                        • Feuersturm
                          Feuersturm @sigi234 last edited by
                          @sigi234 sagte in Test Adapter vis 2.0 (Alpha):
                          Ich hab zwischenzeitlich bei mir die vis-2 widget Adapter mal komplett gelöscht und wieder neu installiert. Hast du dies auch schon einmal probiert oder auch mal den vis-2 Adapter komplett löschen und wieder installieren?
                          Bei mir kann ich die v2.0.23 normal benutzen.
                            sigi234 Forum Testing Most Active @Feuersturm last edited by
                            @feuersturm sagte in Test Adapter vis 2.0 (Alpha):
                            Ja, schon gemacht
                              crusader85 @sigi234 last edited by crusader85
                              ich habe auch ein weirdes Problem mit der vis2 (aktuelle 23er Version, Widgets auch aktuell)
                              Wenn ich eines dieser Widgets auf meine Visu ziehe (aus allen drei Kategorien), kommt ein schwarzer Bildschirm:
                              Keine Fehlermeldungen im Log ersichtlich. Der Fehler trat auch in früheren Versionen auf. VIS-2 Adapter auch schon einmal gelöscht und neu hinzugefügt, ebenso die Energie-Widgets und Co.
                              Viele Grüße
                              Feuersturm Bluefox 2 Replies Last reply Reply Quote 0
                              • Feuersturm
                                Feuersturm @crusader85 last edited by
                                @crusader85 stehen Fehler in der "Konsole", wenn du F12 drückst während du die widgets einfügen willst oder die runtime startest?
                                • Bluefox
                                  Bluefox @crusader85 last edited by
                                  @crusader85 Welche vis version? Die neueste ist 2.0.23
                                  • Feuersturm
                                    Feuersturm @Bluefox last edited by
                                    @bluefox Ich kann das Verhalten von @crusader85 bei mir mit dem "Verbrauch" widget reproduzieren. Hab mal ein issue https://github.com/ioBroker/ioBroker.vis/issues/680 angelegt.
                                    Die anderen 3 Widgets aus dem Energie Sektor kann ich in meine View ziehen.
                                    @crusader85 Tritt der Fehler bei dir bei allen 4 Widgets von "Energie Widgets" auf?
                                    closed Using Verbrauch widget from vis-2-widgets-energy causes blank screen #680
                                    miwi 1 Reply Last reply Reply Quote 0
                                    • miwi
                                      miwi @Feuersturm last edited by
                                      In der aktive Widgets Liste werden die Widgets nur mit Ihrer Indexbezeichnung angezeigt (z.B. w00140). Der in den Atributen unter Generell vergebene Name wird nicht angezeigt.
                                      Hierdurch fällt mir das suchen nach bestimmten Widgets auf der Seite (vor allem in unteren Indexlayern) schwer.
                                      • Feuersturm
                                        Feuersturm @miwi last edited by
                                        @miwi Hi, erstelle bitte für deinen Vorschlag ein entsprechendes github Ticket, damit Bluefox es sich ansehen kann.
                                          Heinz2100 last edited by Heinz2100
                                          Hallo zusammen, wie sieht es denn bei euch mit der Ladezeit der VIS2 aus?
                                          Es dauert bei mir egal auf welchem Endgerät circa 10 Sekunden, bis alle Werte (zumeist HTML-Widgets) und Bilder (z.B. DasWetter-Adapter Wettersymbole) in der Runtime geladen werden.
                                          Die VIS1 hat(te) dagegen nahezu keinerlei Verzögerung und zeigt alle Werte sofort an
                                          • Feuersturm
                                            Feuersturm @Heinz2100 last edited by
                                            @heinz2100 passt dieses issue zu deiner Beobachtung? https://github.com/ioBroker/ioBroker.vis/issues/582
                                            open Elements in VIS Runtime are loading very slow #34
                                            Gargano 1 Reply Last reply Reply Quote 0
                                            1.0k
                                            780
                                            261346
