    4. [Umfrage] BlueLink Adapter welches Fahrzeug
      GerdSo @arteck last edited by
      @arteck
      Da es bei mir auch nicht mehr das Raw Object gibt, habe ich es auf Debug umgestellt, anbei die Log-Meldung und danach fehlt das Raw Object immer noch
      bluelink.0 2023-03-15 11:37:49.715	debug	Set 90 battery state for XXX
      bluelink.0 2023-03-15 11:37:49.592	debug	{"chassis":{"hoodOpen":false,XXX}
      bluelink.0 2023-03-15 11:37:49.591	debug	Set new GetNormalStatus for XXX
      bluelink.0 2023-03-15 11:37:45.366	info	Error on API-Full-Status - Fallback GetNormalStatus
      bluelink.0 2023-03-15 11:37:45.315	debug	{"etc2":{"value":180,"unit":1},"etc3":{"value":150,"unit":1},"atc":{"value":480,"unit":1}}
      bluelink.0 2023-03-15 11:37:45.314	debug	Folgende Ladezeiten Moeglichkeiten wurden gefunden:
      bluelink.0 2023-03-15 11:37:45.267	debug	{"vehicleLocation":{"coord":XXX}
      bluelink.0 2023-03-15 11:37:45.267	debug	Set new full status for XXX
      bluelink.0 2023-03-15 11:37:38.114	debug	Read new status from api for XXX
      bluelink.0 2023-03-15 11:37:37.916	debug	[{"vehicleConfig":{"nickname":"Niro","name":"Niro",XXX]
      bluelink.0 2023-03-15 11:37:37.915	info	1 Vehicles found
      bluelink.0 2023-03-15 11:37:33.485	info	Login to api
      bluelink.0 2023-03-15 11:37:33.441	info	starting. Version 2.2.8 (non-npm: Newan/ioBroker.bluelink#XXX) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.1, js-controller: 4.0.24
      bluelink.0 2023-03-15 11:37:33.227	debug	States connected to redis: 127.0.0.1:9000
      bluelink.0 2023-03-15 11:37:33.177	debug	States create User PubSub Client
      bluelink.0 2023-03-15 11:37:33.175	debug	States create System PubSub Client
      bluelink.0 2023-03-15 11:37:33.145	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      bluelink.0 2023-03-15 11:37:33.114	debug	Objects connected to redis: 127.0.0.1:9001
      bluelink.0 2023-03-15 11:37:33.066	debug	Objects client initialize lua scripts
      bluelink.0 2023-03-15 11:37:32.953	debug	Objects create User PubSub Client
      bluelink.0 2023-03-15 11:37:32.952	debug	Objects create System PubSub Client
      bluelink.0 2023-03-15 11:37:32.942	debug	Objects client ready ... initialize now
      bluelink.0 2023-03-15 11:37:32.882	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        Matze_B @arteck last edited by
        @arteck
        Funktioniert leider nicht:
        Habe die Instanz und den Adapter auch mal gelöscht und über Github neu installiert.
        Sieht aber genau gleich aus...
        2023-03-15 19:11:58.957 - info: bluelink.0 (31733) starting. Version 2.2.8 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v16.19.1, js-controller: 4.0.24
        2023-03-15 19:11:59.011 - info: bluelink.0 (31733) Login to api
        2023-03-15 19:12:05.331 - info: bluelink.0 (31733) 1 Vehicles found
        2023-03-15 19:12:17.514 - debug: bluelink.0 (31733) Read new status from api for KMH******
        2023-03-15 19:12:37.958 - debug: bluelink.0 (31733) Set new full status for KMH******
        2023-03-15 19:12:37.959 - debug: bluelink.0 (31733) {"vehicleLocation":{"coord":{"lat":xx.xxxx,"lon":x.xxxx,"alt":0,"type":0},"head":0,"speed":{"value":0,"unit":0},"accuracy":{"hdop":0,"pdop":0},"time":"20230315181235"},"vehicleStatus"XXXXXXX
        2023-03-15 19:12:38.072 - debug: bluelink.0 (31733) Folgende Ladezeiten Moeglichkeiten wurden gefunden:
        2023-03-15 19:12:38.073 - debug: bluelink.0 (31733) {"etc1":{"value":54,"unit":1},"etc2":{"value":1220,"unit":1},"etc3":{"value":295,"unit":1},"atc":{"value":295,"unit":1}}
        2023-03-15 19:12:38.142 - info: bluelink.0 (31733) Error on API-Full-Status - Fallback GetNormalStatus
        2023-03-15 19:12:46.270 - debug: bluelink.0 (31733) Set new GetNormalStatus for KMH*****
        2023-03-15 19:12:46.272 - debug: bluelink.0 (31733) {"chassis":{"hoodOpen":false,"trunkOpen":false,"locked":true,"openDoors":...XXXXXX
        2023-03-15 19:12:56.013 - debug: bluelink.0 (31733) Set 90 battery state for KMH*****
        Matthias
          hmmmmm muss ich mir anschauen
          der ordner sollte zumindest jetzt angelegt werden
          und wird jetzt auch gefüllt..
            g.polat last edited by
            Hyundai Tucson PHEV
              arteck Developer Most Active @g.polat last edited by
              @g-polat sicher dass du richtig schaust.. deiner ist wie mein Kia Sportage ist ja die gleiche Plattform ..
                g.polat @arteck last edited by g.polat
                @arteck sagte in [Umfrage] BlueLink Adapter welches Fahrzeug:
                wie soll ich anders schauen?
                • FredF
                  FredF Most Active Forum Testing @g.polat last edited by FredF
                  @g-polat sagte in [Umfrage] BlueLink Adapter welches Fahrzeug:
                  unter
                  vehicleStatusRaw
                  und nicht unter
                  vehicleStatus
                    g.polat @FredF last edited by
                    @fredf sagte in [Umfrage] BlueLink Adapter welches Fahrzeug:
                    unter
                    vehicleStatusRaw
                    und nicht unter
                    vehicleStatus
                    Die Ordner fehlen bei mir wie oben bei den anderen.
                      @g-polat ahh das ist was anders dann installier mal die GIT version .. da gab es ein Bug
                      G G 2 Replies Last reply Reply Quote 0
                        GerdSo @arteck last edited by GerdSo
                        @arteck Ich habe gerade per https://github.com/Newan/ioBroker.bluelink die aktuellste Version (weiterhin 2.2.8 - ist etwas verwirrend) geholt und da wird bei mir (nach dem Löschen der Objekte) jetzt vehicleStatusRaw angelegt -> Kia Niro PHEV (Mod. 2023)
                        Auto | battWarning | batSoc (aktualisierte Version 2.2.8)
                        Niro-PHEV (Mod. 2023) | ja | ja
                          Das hat funktioniert 🙂
                            fichte_112 last edited by
                            Kia XCeed PHEV
                              @fichte_112 hast den adapter von GIT isntalliert ?? 255 ist ein asehr alter Bug
                                fichte_112 @arteck last edited by
                                @arteck ja, ist von GIT installiert. 255 wird nur angezeigt, wenn die Batterie mit einem externen Ladegerät geladen wurde.
                                arteck clfberlin 2 Replies Last reply Reply Quote 0
                                  arteck Developer Most Active @fichte_112 last edited by
                                  @fichte_112 extern meinst du an der Ladeseule ?
                                    @arteck nein, nur die 12 Volt Batterie mit Erhaltungsladung.
                                    clfberlin 1 Reply Last reply Reply Quote 0
                                    • clfberlin
                                      clfberlin @fichte_112 last edited by clfberlin
                                      Ioniq PHEV (2021) nein | ja
                                        arteck Developer Most Active @clfberlin last edited by
                                        @clfberlin ist das dann nicht der ioniq 5 ?
                                        • clfberlin
                                          clfberlin @arteck last edited by
                                          @arteck Nein, der Ioniq hat auch einen PlugIn Hybriden am Start.
                                          Der Adapter hatte mir übrigens schon mal bei einem Service-Problem mit der Hyundai-Werkstatt geholfen, als die Starter-Batterie mucken gemacht hatte. Ich konnte eine Historie des Ladestands zeigen. 😉
                                          • clfberlin
                                            Einen Wert von 255 habe ich übrigens auch an der Starterbatterie, wenn ich ein (externes) Ladegerät dran habe. Version 2.2.5
                                            45
                                            3566
