    4. RFlink (LOS GEHT ES ) Bestellung d.Hardware (20€) + 5€ Spende an Forum f.d. Adapter (crowdfunding like :-)
      fraenkie76 last edited by
      die Hardware habe ich mir jetzt über den nodo-Shop besorgt.
      Jetzt scheitert bei mir die Installation des Adapters:
      ! $ ./iobroker add rflink
      ! npm install iobroker.rflink –production --prefix "/opt/iobroker" (System call)
      ! node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.0 (node-v48 ABI) (falling back to source compile with node-gyp)
      ! gyp
      ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"
      ! gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/serialport/.node-gyp"
      ! make: *** No rule to make target '../.node-gyp/6.10.0/include/node/common.gypi', needed by 'Makefile'. Schluss.
      ! gyp
      ! ERR!
      ! build error
      ! gyp
      ! ERR!
      ! stack Error: make failed with exit code: 2
      ! gyp
      ! ERR!
      ! stack
      ! at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
      ! gyp
      ! ERR!
      ! stack
      ! at emitTwo (events.js:106:13)gyp ERR!
      ! stack at ChildProcess.emit (events.js:191:7)
      ! gyp
      ! ERR!
      ! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      ! gyp
      ! ERR! System Linux 4.4.50-v7+gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
      ! gyp ERR! cwd /opt/iobroker/node_modules/serialport
      ! gyp ERR! node -v v6.10.0
      ! gyp ERR! node-gyp -v v3.6.0
      ! gyp ERR! not ok
      ! node-pre-gyp
      ! ERR! build error
      ! node-pre-gyp
      ! ERR! stack Error: Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      ! node-pre-gyp ERR! stack at emitTwo (events.js:106:13)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      ! node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:877:16)
      ! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      ! node-pre-gyp ERR! System Linux 4.4.50-v7+node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      ! node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
      ! node-pre-gyp ERR! node -v v6.10.0
      ! node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      ! node-pre-gyp ERR! not ok
      ! npm ERR! Linux 4.4.50-v7+
      ! npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.10.0
      ! npm ERR! npm v3.10.10
      ! npm ERR! code ELIFECYCLE
      ! npm ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1
      ! npm ERR!
      ! npm ERR! Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.
      ! npm ERR! Make sure you have the latest version of node.js and npm installed.
      ! npm ERR! If you do, this is most likely a problem with the serialport package,
      ! npm ERR! not with npm itself.
      ! npm ERR! Tell the author that this fails on your system:
      ! npm ERR! node-pre-gyp install --fallback-to-build
      ! npm ERR! You can get information on how to open an issue for this project with:
      ! npm ERR! npm bugs serialport
      ! npm ERR! Or if that isn't available, you can get their info via:
      ! npm ERR! npm owner ls serialport
      ! npm ERR! There is likely additional logging output above.
      ! npm ERR! Please include the following file with any support request:
      ! npm ERR! /opt/npm-debug.log
      ! npm ERR! code 1
      ! host.ioBroker-RasPi install adapter rflink
      ! npm install iobroker.rflink --production --prefix "/opt/iobroker" (System call)
      ! node-pre-gyp
      ! ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz
      ! node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.0 (node-v48 ABI) (falling back to source compile with node-gyp)
      ! gyp
      ! WARN
      ! EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"
      ! gyp
      ! ERR!
      ! build error
      ! gyp
      ! ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
      ! gyp
      ! ERR! stack
      ! gyp
      ! ERR! stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      ! gyp ERR! System Linux 4.4.50-v7+
      ! gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"
      ! gyp
      ! ERR! cwd /opt/iobroker/node_modules/serialport
      ! gyp
      ! ERR! node -v v6.10.0
      ! gyp ERR! node-gyp -v v3.6.0gyp ERR! not ok
      ! node-pre-gyp
      ! ERR! build error
      ! node-pre-gyp
      ! node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      ! node-pre-gyp
      ! node-pre-gyp ERR! command
      ! "/usr/bin/nodejs" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
      ! node-pre-gyp
      ! ERR! node -v v6.10.0node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      ! node-pre-gyp ERR!
      ! not ok
      ! npm
      ! ERR!
      ! Linux 4.4.50-v7+
      ! npm ERR!
      ! npm
      ! ERR! If you do, this is most likely a problem with the serialport package,npm ERR! not with npm itself.
      ! npm
      ! ERR! There is likely additional logging output above.
      ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
      ! npm ERR! code 1
      ! node-pre-gyp
      ! ERR! Tried to download(404): https://github.com/EmergingTechnologyAd ... arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.10.0 (node-v48 ABI) (falling back to source compile with node-gyp)
      ! gyp
      ! WARN EACCES
      ! user "root" does not have permission to access the dev dir "/root/.node-gyp/6.10.0"gyp
      ! WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/serialport/.node-gyp"
      ! gyp
      ! ERR!
      ! build error
      ! gyp
      ! gyp ERR! stack at emitTwo (events.js:106:13)gyp
      ! gyp
      ! ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/serialport/build/Release"gyp
      ! ERR! cwd /opt/iobroker/node_modules/serialportgyp ERR! node -v v6.10.0
      ! not ok
      ! node-pre-gyp
      ! ERR! build error
      ! node-pre-gyp
      ! node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/serialport
      ! node-pre-gyp ERR! node -v v6.10.0node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      ! npm
      ! ERR! Linux 4.4.50-v7+
      ! npm
      ! ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.rflink" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.10.0
      ! npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE
      ! npm ERR! Exit status 1
      ! npm ERR!
      ! npm ERR! npm owner ls serialportnpm ERR! There is likely additional logging output above.
      ! npm ERR! code 1
      ! ERROR: host.ioBroker-RasPi Cannot install rflink
      ! ERROR: process exited with code 13</anonymous></anonymous></anonymous>
      Kann mit der Fehlermeldung leider gar nichts anfangen… 😞
      Bis jetzt habe ich nur den arduino zusammengesteckt und über USB mit dem iobroker-Raspi verbunden....
      Danke schonmal für eure Hilfe...
      fraenkie
      • N
        noxx last edited by
        Ist der arduino geflasht oder noch jungfräulich?
        Gesendet von meinem Huawei P10lite mit Tapatalk
          Stuntteam last edited by
          Neue RFLink firmware
          R47: (15/09/2017)
          • New Device: Micro Tybox X2D / Tybox H X2D Thermostats (works with 433 and/or 868 mhz)
          • New Device: Tybox 310 X2D Thermostat (868mhz)
          • New Device: Delta Dore - Deltia 8.03 X2D Thermostat (868mhz)
          • New Device: TYXIA 261/461 X2D micro modules (868mhz) (Receive only, more logs needed)
          • New Device: Milight RGB+CCT (a.o. 4-zone FUT092/ 8-zone FUT089)
          • New Device: Milight RGB (a.o. FUT098)
          • New Device: Bofu motor BF-301, EY1612, EY1624 and others
          • New Device: Oregon Scientific SL109
          • New Device: AR53002 / AR50055 X2D Thermostats
          • New Device: Atlantic MD-210R / Focus MD-210R - 868mhz door contact
          • New Device: Legrand CAD Radio
          • New Device: Gelia EMW100T switch set
          • New Device: ELEC EDB-40 / QH-1085TX V1.1 Quhwa doorbell
          • New Device: X10 Sensors
          • New Device: Ambient FT004T temperature sensor
          • New Device: Ambient FT004B temperature sensor
          • New Device: ASA radio technology Go-1
          • New Device: Telis 4 Modulis RTS
          • New Device: Added support for a new version of the Rubicson WT0122 pool thermometer
          • New Device: Renkforce E0190TA and compatible temperature sensors
          • New Device: Ematronic AC114-01B shutter/blinds controller
          • New Device: Yooda Melody shutter/blinds controller
          • New Device: Viking 02813 Temperature sensor
          • New Device: Marquant 943134 Temperature sensor
          • New Device: Arlec RC10 switch set
          • New Device: V2 Phoenix remote signals (Receive only)
          • New Device: IDK CAR-200 doorbell (Receive only)
          • New Feature: GPIO pin state at boot can be selected with a wire from pin 5 to ground to set the pin default to high
          • Added: X2D/X3D protocol support
          • Added: Milight RGB and RGB+CCT protocol support
          • Added: Direct dimming support for Flamingo and compatible devices
          • Added: Additional WH3 detection
          • Added: Two Additional Dooya protocol flavors
          • Added: Additional Dooya signal recognition
          • Added: Additional Blyss remote control recognition
          • Added: Additional Brell remote control recognition
          • Added: STOP command support to (first) extended RTS protocol version
          • Added: Support for second extended RTS protocol version
          • Added: Additional Pair option for Bofu motor devices
          • Added: upon request added 6 additional GPIO pin's for generic use
          The GPIO pins are often used to 'press buttons' on incompatible devices
          • Fixed: Added pairing command for Ansluta
          • Fixed: Increased transmission duration for Ansluta
          • Fixed: corrected barometric pressure value of BTHR918
          • Fixed: UPM Esic negative temperatures
          • Fixed: Further improved X10 protocol detection
          • Fixed: 'newkaku' send command handling improved
          • Fixed: 'newkaku' group commands put at a unique switch number
          • Fixed: imrpoved newkaku filtering
          • Fixed: improved Acurite SL109 negative temperature handling
          • Fixed: CM113 ampere precision
          • Fixed: Milight: bug in unit selection
          • Fixed: bug with the number of RFCustom records
          • Fixed: removal of RFCustom records
          • Fixed: Improved Xiron sensor detection
          • Fixed: Alecto rain meter values
          http://www.rflink.nl
            der Arduino ist noch jungfräulich…
            nach mehreren erneuten Versuchen und zwischenzeitlichen Neustarts hab ich jetzt eine RFLink-Instanz.
            Allerdings fehlt mir bei Port der USB-Port über den ich angeschlossen habe. Habe nur die Auswahlmöglichkeiten ttyACM0 und ttyAMA0.
            Muß ich an der Stelle noch den Arduino flashen? Mit welcher Software?
            Ich hab mir u.a. dieses Video angeschaut:
            https://www.youtube.com/watch?v=j19QPLn … ex=1&t=56s
            Da wird das nicht erwähnt, da gibts auch den Button "Arduino flashen" bei der Adapterparametrisierung nicht….
              Dann lade dir Mal die aktuelle Firmware aus dem Link vom Stuhrteam herunter und flashen sie auf den Mega
              Rainer
                Arduino geflasht, Adapter gelöscht, Adapter neu installiert, Anschluß ttyACM0 ausgewählt
                Jetzt scheint es zu funktionieren, die ersten Objekte (Wetterstation) werden geliefert!
                Besten Dank!
                  muckel last edited by
                  Hallo Maxtox!
                  Ist das RFlink auch für den Raspi 3 geeignet?
                  Kann ich es noch bestellen?
                  Danke im Voraus
                  Liebe Grüße
                  • N
                    noxx last edited by
                    Warum sollte er nicht? Bei mir lief er auf pi2 und jetzt auf OrangePi +2
                    • Dolomiti
                      Dolomiti last edited by
                      @muckel: Ja funktioniert tadellos. Habe ich auch so im Einsatz.
                        Hallo !
                        Danke für die Infos.
                        Bestellvorgang ist noch immer so wie am Anfang beschrieben?
                        EUR 20 an MAXTOX und EUR 5 Spende an Board?
                        Liebe Grüße
                        • N
                          nelzon last edited by
                          @muckel:
                          Hallo !
                          Liebe Grüße `
                          Ich schließe mich an. Bin interessiert an einem 🙂
                            Hallo Helfende!
                            Ich habe mir dieses Set gekauft:
                            https://www.nodo-shop.nl/en/rflink-gate … ipool.html
                            Ich empfange damit einen Temperatur Sensor (noch keine Ahnung welchen) 🙂
                            Angelernt habe ich im Anlernmodus:
                            Markise: BrelMotor_1
                            Name: BLIND_41 ; Typ: State ; Rolle: Blind ; Wert: True
                            Name: BLIND_STOP_41 ; Typ: State ; Rolle: Button
                            Gefunden hat er beim Anlernen die cmd: DOWN, STOP, UP
                            Fehlt da nicht BLIND_DOWN_41 und BLIND_UP_41 (oder so ähnlich?
                            Wie kann ich die Markise Steuern?
                            Hab ich das richtig angelernt?
                            Ich bekomme es einfach nicht hin.
                            Habt ihr dazu ein paar Tips?
                            Danke im Voraus
                            Liebe Grüße
                              Gelöst! 😄
                              War eine kalte Lötstelle am Sendemodul :?
                                badplay last edited by
                                Bekommt man noch alles um sich rflink aufzubauen? Das ganze kann ich dann an mein rpi3 anstecken oder?
                                Bzw sollte man lieber ein eigenen rpi nutzen oder geht der rpi 3 auf dem iobroker läuft?
                                  fangen wir mal hinten an:
                                  @badplay:
                                  oder geht der rpi 3 auf dem iobroker läuft? `
                                  es muss ein ioBroker-Derver sein. Kann auch ein slave sein, aber auch der Master.
                                  Schließlich soll doch der rf-link Adapter auch auf die Hardware zugreifen können.
                                  @badplay:
                                  Bzw sollte man lieber ein eigenen rpi nutzen `
                                  s.o. Dann muss da auch eine ioBroker Installation drauf.
                                  @badplay:
                                  Das ganze kann ich dann an mein rpi3 anstecken oder? `
                                  klar, aber…
                                  wenn du mehrere angesteckte Hardware nutzen willst, die mit serialport arbeiten kann es zu Problemen kommen (außer das ist inzwischen gelöst)
                                  @badplay:
                                  Bekommt man noch alles um sich rflink aufzubauen? `
                                  Wenn nicht hier (kenne den aktuellen Status nicht) dann z.B. https://www.nodo-shop.nl/en/.
                                    bin ein wenig schlauer aber nicht so ganz ^^
                                    also doch alles an den rpi3 ich sehe schon komplikationen mit den gpio pins und so weiter. wie baut man das auf das man mehrere kabel und module an dem selben gpio pin anschließen kann ?
                                    Folgendes wollte ich realisieren vll hat schon jemand eine bessere IDEE.
                                    Max! Thermostat steuern via Iobroker VIS und Alexa
                                    433 mhz Funksteckdosen steuern via iobroker vis und Alexa
                                    Was ich habe
                                    RPI 3, Rpi b+
                                    433 Sende und Empfangsmodul
                                    Harmony Hub
                                    Alexa Echo dot, Alexa Echo Plus mit Smart Hub ( demnächst )
                                    Jetzt ist die Frage, ich habe was von CUL gelesen so kann man wohl das MAX! Thermostat steuern, und so wie ich das verstehe kann man mit CUL auch die 433 Steckdosen steuern.
                                    Was müsste ich mir also aufbauen, damit man nicht hunderte Gateways oder Module hat. Gibt es da eine Lösung? Gibt es die Adapter und so weiter
                                    hoffe mir können die Smart Home Profis helfen
                                      @badplay:
                                      damit man nicht hunderte Gateways oder Module hat. `
                                      Dann hast du das Prinzip von ioBroker nicht verstanden.
                                      ioBroker ist genau das: er ist Middleware um die Informationen aller möglichen Systeme über deren Gateways miteinander zu verbinden.
                                      Rainer
                                        Doch das weiß ich
                                        Ich meine das ich Vll 433 868 und cul kombinieren kann
                                        Oder stapeln wenn ja ist die Frage welche Produkte ich brauche. Gibt unmengen an Platinen und Teile sind für arduino andere für rpi3 da muss man erstmal durchsehen und dann soll es ja auch mit iobroker laufen
                                          knopers1 last edited by
                                          Hi, habe seit neustem Probleme mit dem RFlink Adapter. (neuste Version installiert)
                                          Im Log sehe ich des öfteren, dass dieser alle paar min./Std ein Reconnenct macht.
                                          Ich habe bereits das Netzteil am OPI getauscht, da ich dort den Fehler vermutete. Leider ohne Erfolg.
                                          Kann ich irgendwie den Fehler eingrenzen?
                                          LOG
                                          host.orangepiplus2e	2017-10-05 14:42:02.559	error	instance system.adapter.rflink.0 terminated with code 0 (OK)
                                          Caught	2017-10-05 14:42:02.558	error	by controller[0]: at Timer.listOnTimeout (timers.js:214:5)
                                          Caught	2017-10-05 14:42:02.558	error	by controller[0]: at tryOnTimeout (timers.js:250:5)
                                          Caught	2017-10-05 14:42:02.558	error	by controller[0]: at ontimeout (timers.js:386:11)
                                          Caught	2017-10-05 14:42:02.557	error	by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3103:38)
                                          Caught	2017-10-05 14:42:02.557	error	by controller[0]: at Adapter.emit (events.js:191:7)
                                          Caught	2017-10-05 14:42:02.557	error	by controller[0]: at emitTwo (events.js:106:13)
                                          Caught	2017-10-05 14:42:02.556	error	by controller[0]: at Adapter. (/opt/iobroker/node_modules/iobroker.rflink/main.js:146:9)
                                          Caught	2017-10-05 14:42:02.556	error	by controller[0]: at writeCommand (/opt/iobroker/node_modules/iobroker.rflink/main.js:181:66)
                                          Caught	2017-10-05 14:42:02.556	error	by controller[0]: at Object.encodeValue (/opt/iobroker/node_modules/iobroker.rflink/admin/parse.js:243:30)
                                          Caught	2017-10-05 14:42:02.554	error	by controller[0]: at Object.ID (/opt/iobroker/node_modules/iobroker.rflink/admin/parse.js:112:26)
                                          Caught	2017-10-05 14:42:02.541	error	by controller[0]: TypeError: Cannot read property 'toString' of undefined
                                          rflink.0	2017-10-05 14:42:02.418	info	terminating
                                          rflink.0	2017-10-05 14:42:02.358	error	at Timer.listOnTimeout (timers.js:214:5)
                                          rflink.0	2017-10-05 14:42:02.358	error	at tryOnTimeout (timers.js:250:5)
                                          rflink.0	2017-10-05 14:42:02.358	error	at ontimeout (timers.js:386:11)
                                          rflink.0	2017-10-05 14:42:02.358	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3103:38)
                                          rflink.0	2017-10-05 14:42:02.358	error	at Adapter.emit (events.js:191:7)
                                          rflink.0	2017-10-05 14:42:02.358	error	at emitTwo (events.js:106:13)
                                          rflink.0	2017-10-05 14:42:02.358	error	at Adapter. (/opt/iobroker/node_modules/iobroker.rflink/main.js:146:9)
                                          rflink.0	2017-10-05 14:42:02.358	error	at writeCommand (/opt/iobroker/node_modules/iobroker.rflink/main.js:181:66)
                                          rflink.0	2017-10-05 14:42:02.358	error	at Object.encodeValue (/opt/iobroker/node_modules/iobroker.rflink/admin/parse.js:243:30)
                                          rflink.0	2017-10-05 14:42:02.358	error	at Object.ID (/opt/iobroker/node_modules/iobroker.rflink/admin/parse.js:112:26)
                                          rflink.0	2017-10-05 14:42:02.358	error	TypeError: Cannot read property 'toString' of undefined
                                          rflink.0	2017-10-05 14:42:02.356	error	uncaught exception: Cannot read property 'toString' of undefined
                                          • N
                                            Nabla last edited by
                                            Ich würde auch noch gerne meine Becker-Rolladen-Motoren (866Mhz) irgendwie anlernen und steuern. Geht das hier mit?
                                            Ich hatte Maxtox schon eine PN geschrieben, aber bislang keine Antwort erhalten.
                                            Ist dieses Thema noch aktiv?
                                            698
                                            200556
