    4. Test für mihome-vacuum 3.10.x
      BamBam89 @dirkhe last edited by
      @dirkhe
      Ich bekomme ja auch eine Karte angezeigt, aber eben irgend einen "alten" Stand.
      Das ist die Karte dir mir im VIS angezeigt wird:
      Und das ist die aktuelle Karte wenn ich die APP auf dem Handy öffne:
      Gruß Christian
        dirkhe Developer @BamBam89 last edited by
        @bambam89 Also dann schick mal dein Log (debug), da drin solltest du sehen, ob er deine Karte updatet oder nicht. Wie oft er das macht, kannst du auch einstellen.
          @dirkhe
          hier mal ein Auszug aus den Logs.
          mihome-vacuum.0
          2023-02-23 08:49:08.120	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":70}
          mihome-vacuum.0
          2023-02-23 08:49:08.109	debug	Message= {"id":70,"method":"get_carpet_mode"}
          mihome-vacuum.0
          2023-02-23 08:49:08.108	debug	MIIO RECIVE: {"result":[100],"id":69}
          mihome-vacuum.0
          2023-02-23 08:49:08.099	debug	Message= {"id":69,"method":"get_sound_volume"}
          mihome-vacuum.0
          2023-02-23 08:49:08.069	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-67},"id":68}
          mihome-vacuum.0
          2023-02-23 08:49:08.044	debug	Message= {"id":68,"method":"get_network_info"}
          mihome-vacuum.0
          2023-02-23 08:49:08.042	debug	setGetStatus {"msg_ver":3,"msg_seq":1888,"state":18,"battery":99,"clean_time":108,"clean_area":3117500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
          mihome-vacuum.0
          2023-02-23 08:49:08.041	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":1888,"state":18,"battery":99,"clean_time":108,"clean_area":3117500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":67}
          mihome-vacuum.0
          2023-02-23 08:49:08.032	debug	Message= {"id":67,"method":"get_status"}
          mihome-vacuum.0
          2023-02-23 08:49:08.032	debug	get params for stock Vacuum
          mihome-vacuum.0
          2023-02-23 08:49:01.800	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
          mihome-vacuum.0
          2023-02-23 08:49:01.799	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f71a6effffffffffffffffffffffffffffffff
          mihome-vacuum.0
          2023-02-23 08:48:57.991	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":66}
          mihome-vacuum.0
          2023-02-23 08:48:57.981	debug	Message= {"id":66,"method":"get_carpet_mode"}
          mihome-vacuum.0
          2023-02-23 08:48:57.979	debug	MIIO RECIVE: {"result":[100],"id":65}
          mihome-vacuum.0
          2023-02-23 08:48:57.968	debug	Message= {"id":65,"method":"get_sound_volume"}
          mihome-vacuum.0
          2023-02-23 08:48:57.889	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-67},"id":64}
          mihome-vacuum.0
          2023-02-23 08:48:57.858	debug	Message= {"id":64,"method":"get_network_info"}
          mihome-vacuum.0
          2023-02-23 08:48:57.855	debug	setGetStatus {"msg_ver":3,"msg_seq":1887,"state":18,"battery":99,"clean_time":96,"clean_area":2742500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
          mihome-vacuum.0
          2023-02-23 08:48:57.853	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":1887,"state":18,"battery":99,"clean_time":96,"clean_area":2742500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":63}
          mihome-vacuum.0
          2023-02-23 08:48:57.842	debug	Message= {"id":63,"method":"get_status"}
          mihome-vacuum.0
          2023-02-23 08:48:57.841	debug	get params for stock Vacuum
          mihome-vacuum.0
          2023-02-23 08:48:51.795	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
          mihome-vacuum.0
          2023-02-23 08:48:51.794	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f71a64ffffffffffffffffffffffffffffffff
          mihome-vacuum.0
          2023-02-23 08:48:47.788	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":62}
          mihome-vacuum.0
          2023-02-23 08:48:47.779	debug	Message= {"id":62,"method":"get_carpet_mode"}
          mihome-vacuum.0
          2023-02-23 08:48:47.777	debug	MIIO RECIVE: {"result":[100],"id":61}
          mihome-vacuum.0
          2023-02-23 08:48:47.769	debug	Message= {"id":61,"method":"get_sound_volume"}
          mihome-vacuum.0
          2023-02-23 08:48:47.707	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-62},"id":60}
          mihome-vacuum.0
          2023-02-23 08:48:47.656	debug	Message= {"id":60,"method":"get_network_info"}
          mihome-vacuum.0
          2023-02-23 08:48:47.654	debug	setGetStatus {"msg_ver":3,"msg_seq":1886,"state":18,"battery":99,"clean_time":90,"clean_area":2392500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
          mihome-vacuum.0
          2023-02-23 08:48:47.654	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":1886,"state":18,"battery":99,"clean_time":90,"clean_area":2392500,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":59}
          mihome-vacuum.0
          2023-02-23 08:48:47.629	debug	Message= {"id":59,"method":"get_status"}
          mihome-vacuum.0
          2023-02-23 08:48:47.629	debug	get params for stock Vacuum
          mihome-vacuum.0
          2023-02-23 08:48:40.655	debug	Time difference between Mihome Vacuum and ioBroker: 1 sec
          mihome-vacuum.0
          2023-02-23 08:48:40.655	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f71a59ffffffffffffffffffffffffffffffff
          mihome-vacuum.0
          2023-02-23 08:48:37.502	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":58}
          mihome-vacuum.0
          2023-02-23 08:48:37.492	debug	Message= {"id":58,"method":"get_carpet_mode"}
          mihome-vacuum.0
          2023-02-23 08:48:37.491	debug	MIIO RECIVE: {"result":[100],"id":57}
          mihome-vacuum.0
          2023-02-23 08:48:37.483	debug	Message= {"id":57,"method":"get_sound_volume"}
          mihome-vacuum.0
          2023-02-23 08:48:37.219	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"7c:ff:4d:85:1b:8f","rssi":-62},"id":56}
          mihome-vacuum.0
          2023-02-23 08:48:37.189	debug	Message= {"id":56,"method":"get_network_info"}
          mihome-vacuum.0
          2023-02-23 08:48:37.188	debug	setGetStatus {"msg_ver":3,"msg_seq":1885,"state":18,"battery":99,"clean_time":79,"clean_area":1992500,"error_code":0,"map_present":true,"in_cleaning":false,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
          Der Intervall steht auf 2 Sekunden:
            dirkhe Developer last edited by
            @bambam89 Ähhh, da saugt er doch gar nicht. Du solltest schon zu der Zeit das log schicken, wo er saugt. Da müsste dann drin stehen, dass er eine neue Karte bekommt. Wenn du den Adapter startetest steht aber nicht von canvas Problemen?
              @dirkhe
              Der Log ist entstanden, als der S5 gesaugt hat.
              aktueller Log: (saugt gerade)
              mihome-vacuum.0
              2023-02-23 18:54:16.376	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f7a847ffffffffffffffffffffffffffffffff
              mihome-vacuum.0
              2023-02-23 18:54:10.918	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":120}
              mihome-vacuum.0
              2023-02-23 18:54:10.912	debug	Message= {"id":120,"method":"get_carpet_mode"}
              mihome-vacuum.0
              2023-02-23 18:54:10.911	debug	MIIO RECIVE: {"result":[100],"id":119}
              mihome-vacuum.0
              2023-02-23 18:54:10.902	debug	Message= {"id":119,"method":"get_sound_volume"}
              mihome-vacuum.0
              2023-02-23 18:54:10.837	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"b0:f2:08:c7:6e:83","rssi":-53},"id":118}
              mihome-vacuum.0
              2023-02-23 18:54:10.820	debug	Message= {"id":118,"method":"get_network_info"}
              mihome-vacuum.0
              2023-02-23 18:54:10.819	debug	setGetStatus {"msg_ver":3,"msg_seq":3966,"state":5,"battery":95,"clean_time":49,"clean_area":1210000,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
              mihome-vacuum.0
              2023-02-23 18:54:10.818	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":3966,"state":5,"battery":95,"clean_time":49,"clean_area":1210000,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":117}
              mihome-vacuum.0
              2023-02-23 18:54:10.363	debug	Message= {"id":117,"method":"get_status"}
              mihome-vacuum.0
              2023-02-23 18:54:10.362	debug	get params for stock Vacuum
              mihome-vacuum.0
              2023-02-23 18:54:06.370	debug	Receive <<< Helo <<< 21310020000000000f9b48a163f7a83dffffffffffffffffffffffffffffffff
              mihome-vacuum.0
              2023-02-23 18:54:00.282	debug	MIIO RECIVE: {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":116}
              mihome-vacuum.0
              2023-02-23 18:54:00.275	debug	Message= {"id":116,"method":"get_carpet_mode"}
              mihome-vacuum.0
              2023-02-23 18:54:00.274	debug	MIIO RECIVE: {"result":[100],"id":115}
              mihome-vacuum.0
              2023-02-23 18:54:00.267	debug	Message= {"id":115,"method":"get_sound_volume"}
              mihome-vacuum.0
              2023-02-23 18:54:00.102	debug	MIIO RECIVE: {"result":{"ssid":"Sonnensystem","ip":"192.168.2.51","mac":"50:ec:50:1a:8d:7a","bssid":"b0:f2:08:c7:6e:83","rssi":-58},"id":114}
              mihome-vacuum.0
              2023-02-23 18:54:00.081	debug	Message= {"id":114,"method":"get_network_info"}
              mihome-vacuum.0
              2023-02-23 18:54:00.080	debug	setGetStatus {"msg_ver":3,"msg_seq":3965,"state":5,"battery":95,"clean_time":38,"clean_area":847500,"error_code":0,"map_present":true,"in_cleaning":true,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":false,"map_status":3,"lock_status":0,"error_text":"No error"}
              mihome-vacuum.0
              2023-02-23 18:54:00.079	debug	MIIO RECIVE: {"result":[{"msg_ver":3,"msg_seq":3965,"state":5,"battery":95,"clean_time":38,"clean_area":847500,"error_code":0,"map_present":1,"in_cleaning":1,"in_returning":0,"in_fresh_state":0,"lab_status":1,"water_box_status":0,"fan_power":103,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":113}
              mihome-vacuum.0
              2023-02-23 18:54:00.072	debug	Message= {"id":113,"method":"get_status"}
              mihome-vacuum.0
              2023-02-23 18:54:00.071	debug	get params for stock Vacuum
              Hier sieht man das der Sauger gestartet wurde:
              mihome-vacuum.0
              2023-02-23 18:53:19.834	info	trigger cleaning all
                @bambam89 er ruft aber keine karte ab, entweder in den einstellungen den haken nivgt gesetzt oder canvas ist nicht verfügbar
                  michael 1975 last edited by
                  Zeit gestern verbindet sich mein Sauger S7max unltra nicht mehr adapter bleibt gelb
                  kann mir jemand helfen
                  • Damrak2022
                    Damrak2022 @dirkhe last edited by Damrak2022
                    @dirkheDa ich keine Vis mehr nutze sondern das Node Red Dashboard, habe ich Probleme mit der Einbindung der Karte
                    Sobald ich die cleanmap.mapUrl mit der Iobroker in Node verbinde hängt sich das ganze System auf.
                    Oder mache ich hier einen Fehler und ich muss nur die Url, welche mir im Browser komplett angezeigt wird, nur in die template node packen?
                    So geht es jedenfalls nicht
                      @damrak2022 das kann dir leider nicht beantworten, in den einem datenpunkt steht halt eine url, relativ zum internen webserver, in dem anderen steht das img halt als data string. Was du brauchst, mußt du halt selber wissen.
                      • Damrak2022
                        @dirkhe Wenn ich aber meine Url:
                        http://192.168.178.24:8082/mihome-vacuum.0.cleanmap.mapURL
                        im Browser aufrufe, sollte er mir doch eigentlich die Karte anzeigen, oder?
                        Bei mir steht dann aber lediglich: File not found:{}
                          dirkhe Developer @Damrak2022 last edited by dirkhe
                          @damrak2022 nein, dh musst den inhalt des datenpunktes hinter die ip + port hängen
                          • Damrak2022
                            @dirkhe Wenn ich das so mache
                            http://192.168.178.24:8082/mihome-vacuum.0.cleanmap.mapURL/mihome-vacuum.0.userfiles/actualMap.png
                            bekomme ich das als Ergebnis:
                            Kann das sein das für die Karte zwingend Canvas installiert sein muss Ich hatte da nämlich mal ein Problem und da wurde mir geraten es wegzulassen.
                            Thomas Braun D 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @Damrak2022 last edited by
                              @damrak2022 sagte in Test für mihome-vacuum 3.9.x:
                              Ja.
                              • Damrak2022
                                Damrak2022 @Thomas Braun last edited by
                                @thomas-braun Okay, dann werde ich nochmal versuchen eine korrekte Canvas Installation nach der Beschreibung des mihome Adapters hinzubekommen.
                                  @damrak2022
                                  Die erforderlichen Pakete bringt ein
                                  iob fix
                                  auf den Rechner.
                                    @damrak2022
                                    http://192.168.178.24:8082/mihome-vacuum.0.userfiles/actualMap.png
                                    • Damrak2022
                                      @thomas-braun Das habe ich durchgeführt. Wie prüfe ich das nun alles korrekt ist?
                                      pi@homebridge:~ $ iob fix
                                      library: loaded
                                      Library version=2022-12-09
                                      ioBroker or some processes are still running:
                                       io.admin.0
                                       io.history.0
                                       io.javascript.0
                                       io.scenes.0
                                       io.influxdb.0
                                       io.pushover.0
                                       io.ham.0
                                       io.ping.0
                                       io.rpi2.0
                                       io.shelly.0
                                       io.geofency.0
                                       io.hue.0
                                       io.zigbee.0
                                       io.discovery.0
                                       io.alexa2.0
                                       io.backitup.0
                                       io.web.0
                                       io.info.0
                                       io.snmp.0
                                       io.upnp.0
                                       io.iot.0
                                       io.withings.0
                                       io.twinkly.0
                                      Please stop them first and try again!
                                      pi@homebridge:~ $ iobroker stop
                                      library: loaded
                                          Welcome to the ioBroker installation fixer!
                                          Script version: 2022-12-22
                                          You might need to enter your password a couple of times.
                                          Installing prerequisites (1/4)
                                      OK:1 http://deb.debian.org/debian bullseye InRelease
                                      Holen:2 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
                                      Holen:3 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
                                      OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                      OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                      OK:6 https://download.docker.com/linux/debian bullseye InRelease
                                      Holen:7 https://apt.grafana.com stable InRelease [5.984 B]
                                      OK:8 https://repos.influxdata.com/debian stable InRelease
                                      OK:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                                      Es wurden 98,4 kB in 7 s geholt (14,0 kB/s).
                                      Paketlisten werden gelesen… Fertig
                                      Installed gcc-c++
                                          Checking ioBroker user and directory permissions (2/4)
                                      Created /etc/sudoers.d/iobroker
                                      Fixing directory permissions...
                                          Database maintenance (3/4)
                                      Checking for uncompressed JSONL databases... This might take a while!
                                      Compressing /opt/iobroker/iobroker-data/states.jsonl
                                      Compressing /opt/iobroker/iobroker-data/objects.jsonl
                                      Compressed 2 JSONL files. Done
                                          Checking autostart (4/4)
                                      Enabling autostart...
                                      Autostart enabled!
                                          Your installation was fixed successfully
                                          Run iobroker start to start ioBroker again!
                                      pi@homebridge:~ $ iobroker start
                                      pi@homebridge:~ $
                                        Thomas Braun Most Active last edited by
                                        @damrak2022
                                        apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                        muss zu jedem Paket sagen das es installiert ist und
                                        cd /opt/iobroker
                                        npm ls canvas
                                        spuckt sowas aus:
                                        echad@chet:/opt/iobroker $ npm ls canvas
                                        iobroker.inst@3.0.0 /opt/iobroker
                                        ├─┬ iobroker.echarts@1.4.13
                                        │ ├── canvas@2.11.0
                                        │ └─┬ jsdom@21.1.1
                                        │   └── canvas@2.11.0 deduped
                                        ├─┬ iobroker.iot@1.14.5 (git+ssh://git@github.com/ioBroker/ioBroker.iot.git#c4f7c5139d48613a655453aed737e9694843ccd4)
                                        ├─┬ iobroker.mihome-vacuum@3.9.5
                                        └─┬ iobroker.parcel@0.0.25
                                          └─┬ jsdom@20.0.3
                                        • Damrak2022
                                          @thomas-braun sagte in Test für mihome-vacuum 3.9.x:
                                          npm ls canvas
                                          Ich denke, das sieht so aus wie es sein soll
                                          pi@homebridge:~ $ apt policy build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                                          build-essential:
                                            Installiert:           12.9
                                            Installationskandidat: 12.9
                                            Versionstabelle:
                                           *** 12.9 500
                                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                                  100 /var/lib/dpkg/status
                                          libcairo2-dev:
                                            Installiert:           1.16.0-5+rpt1
                                            Installationskandidat: 1.16.0-5+rpt1
                                            Versionstabelle:
                                           *** 1.16.0-5+rpt1 500
                                                  500 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages
                                               1.16.0-5 500
                                          libpango1.0-dev:
                                            Installiert:           1.46.2-3
                                            Installationskandidat: 1.46.2-3
                                            Versionstabelle:
                                           *** 1.46.2-3 500
                                          libjpeg-dev:
                                            Installiert:           1:2.0.6-4
                                            Installationskandidat: 1:2.0.6-4
                                            Versionstabelle:
                                           *** 1:2.0.6-4 500
                                          libgif-dev:
                                            Installiert:           5.1.9-2
                                            Installationskandidat: 5.1.9-2
                                            Versionstabelle:
                                           *** 5.1.9-2 500
                                          librsvg2-dev:
                                            Installiert:           2.50.3+dfsg-1
                                            Installationskandidat: 2.50.3+dfsg-1
                                            Versionstabelle:
                                           *** 2.50.3+dfsg-1 500
                                          pi@homebridge:~ $ cd /opt/iobroker
                                          pi@homebridge:/opt/iobroker $ npm ls canvas
                                          ├─┬ iobroker.iot@1.14.2
                                          │ ├── canvas@2.11.0
                                          │ └─┬ jsdom@20.0.3
                                          └─┬ iobroker.mihome-vacuum@3.9.5
                                            @damrak2022
                                            Jau, schaut richtig aus.
                                            Damrak2022 1 Reply Last reply Reply Quote 1
                                            74
                                            5520
